path: root/fs/f2fs/acl.c
2013-06-11f2fs: support xattr security labelsJaegeuk Kim
This patch adds the support of security labels for f2fs, which will be used by Linus Security Models (LSMs). Quote from http://en.wikipedia.org/wiki/Linux_Security_Modules: "Linux Security Modules (LSM) is a framework that allows the Linux kernel to support a variety of computer security models while avoiding favoritism toward any single security implementation. The framework is licensed under the terms of the GNU General Public License and is standard part of the Linux kernel since Linux 2.6. AppArmor, SELinux, Smack and TOMOYO Linux are the currently accepted modules in the official kernel.". Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2013-04-09mode_t, whack-a-mole at 11...Al Viro
2013-01-04f2fs: avoid null dereference in f2fs_acl_from_diskJaegeuk Kim
This patch resolves Coverity #751303: >>> CID 753103: Explicit null dereferenced (FORWARD_NULL) Passing null >>> pointer "value" to function "f2fs_acl_from_disk(char const *, size_t)", which dereferences it. [Error path] - value = NULL; - retval = 0 by f2fs_getxattr(); - f2fs_acl_from_disk(value:NULL, ...); Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2012-12-25f2fs: Don't assign e_id in f2fs_acl_from_diskEric W. Biederman
With user namespaces enabled building f2fs fails with: CC fs/f2fs/acl.o fs/f2fs/acl.c: In function ‘f2fs_acl_from_disk’: fs/f2fs/acl.c:85:21: error: ‘struct posix_acl_entry’ has no member named ‘e_id’ make[2]: *** [fs/f2fs/acl.o] Error 1 make[2]: Target `__build' not remade because of errors. e_id is a backwards compatibility field only used for file systems that haven't been converted to use kuids and kgids. When the posix acl tag field is neither ACL_USER nor ACL_GROUP assigning e_id is unnecessary. Remove the assignment so f2fs will build with user namespaces enabled. Cc: Namjae Jeon <namjae.jeon@samsung.com> Cc: Amit Sahrawat <a.sahrawat@samsung.com> Acked-by: Jaegeuk Kim <jaegeuk.kim@samsung.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2012-12-11f2fs: resolve build failuresJaegeuk Kim
There exist two build failures reported by Randy Dunlap as follows. (on i386) a. (config-r8857) ERROR: "f2fs_xattr_advise_handler" [fs/f2fs/f2fs.ko] undefined! Key configs in (config-r8857) are as follows. CONFIG_F2FS_FS=m # CONFIG_F2FS_STAT_FS is not set CONFIG_F2FS_FS_XATTR=y # CONFIG_F2FS_FS_POSIX_ACL is not set The error was occurred due to the function location that we made a mistake. Recently we added a new functionality for users to indicate cold files explicitly through xattr operations (i.e., f2fs_xattr_advise_handler). This handler should have been added in xattr.c instead of acl.c in order to avoid an undefined operation like in this case where XATTR is set and ACL is not set. b. (config-r8855) fs/f2fs/file.c: In function 'f2fs_vm_page_mkwrite': fs/f2fs/file.c:97:2: error: implicit declaration of function 'block_page_mkwrite_return' Key config in (config-r8855) is CONFIG_BLOCK. Obviously, f2fs works on top of the block device so that we should consider carefully a sort of config dependencies. The reason why this error was occurred was that f2fs_vm_page_mkwrite() calls block_page_mkwrite_return() which is enalbed only if CONFIG_BLOCK is set. Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net>
2012-12-11f2fs: adjust kernel coding styleJaegeuk Kim
As pointed out by Randy Dunlap, this patch removes all usage of "/**" for comment blocks. Instead, just use "/*". Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
2012-12-11f2fs: add xattr and acl functionalitiesJaegeuk Kim
This implements xattr and acl functionalities. - F2FS uses a node page to contain use extended attributes. Signed-off-by: Changman Lee <cm224.lee@samsung.com> Signed-off-by: Jaegeuk Kim <jaegeuk.kim@samsung.com>
