commit d2dc317d564a46dfc683978a2e5a4f91434e9711 upstream.
Currently it is possible to lose whole file system block worth of data
when we hit the specific interaction with unwritten and delayed extents
in status extent tree.
The problem is that when we insert delayed extent into extent status
tree the only way to get rid of it is when we write out delayed buffer.
However there is a limitation in the extent status tree implementation
so that when inserting unwritten extent should there be even a single
delayed block the whole unwritten extent would be marked as delayed.
At this point, there is no way to get rid of the delayed extents,
because there are no delayed buffers to write out. So when a we write
into said unwritten extent we will convert it to written, but it still
remains delayed.
When we try to write into that block later ext4_da_map_blocks() will set
the buffer new and delayed and map it to invalid block which causes
the rest of the block to be zeroed loosing already written data.
For now we can fix this by simply not allowing to set delayed status on
written extent in the extent status tree. Also add WARN_ON() to make
sure that we notice if this happens in the future.
This problem can be easily reproduced by running the following xfs_io.
xfs_io -f -c "pwrite -S 0xaa 4096 2048" \
-c "falloc 0 131072" \
-c "pwrite -S 0xbb 65536 2048" \
-c "fsync" /mnt/test/fff
echo 3 > /proc/sys/vm/drop_caches
xfs_io -c "pwrite -S 0xdd 67584 2048" /mnt/test/fff
This can be theoretically also reproduced by at random by running fsx,
but it's not very reliable, though on machines with bigger page size
(like ppc) this can be seen more often (especially xfstest generic/127)
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit e12fb97222fc41e8442896934f76d39ef99b590a upstream.
Previously commit 14ece1028b3ed53ffec1b1213ffc6acaf79ad77c added a
support for for syncing parent directory of newly created inodes to
make sure that the inode is not lost after a power failure in
no-journal mode.
However this does not work in majority of cases, namely:
- if the directory has inline data
- if the directory is already indexed
- if the directory already has at least one block and:
- the new entry fits into it
- or we've successfully converted it to indexed
So in those cases we might lose the inode entirely even after fsync in
the no-journal mode. This also includes ext2 default mode obviously.
I've noticed this while running xfstest generic/321 and even though the
test should fail (we need to run fsck after a crash in no-journal mode)
I could not find a newly created entries even when if it was fsynced
before.
Fix this by adjusting the ext4_add_entry() successful exit paths to set
the inode EXT4_STATE_NEWENTRY so that fsync has the chance to fsync the
parent directory as well.
Cc: Frank Mayhar <fmayhar@google.com>
commit a41537e69b4aa43f0fea02498c2595a81267383b upstream.
O_DIRECT flags can be toggeled via fcntl(F_SETFL). But this value checked
twice inside ext4_file_write_iter() and __generic_file_write() which
result in BUG_ON inside ext4_direct_IO.
Let's initialize iocb->private unconditionally.
TESTCASE: xfstest:generic/036 https://patchwork.ozlabs.org/patch/402445/
#TYPICAL STACK TRACE:
kernel BUG at fs/ext4/inode.c:2960!
invalid opcode: 0000 [#1] SMP
Modules linked in: brd iTCO_wdt lpc_ich mfd_core igb ptp dm_mirror dm_region_hash dm_log dm_mod
CPU: 6 PID: 5505 Comm: aio-dio-fcntl-r Not tainted 3.17.0-rc2-00176-gff5c017 #161
Hardware name: Intel Corporation W2600CR/W2600CR, BIOS SE5C600.86B.99.99.x028.061320111235 06/13/2011
task: ffff88080e95a7c0 ti: ffff88080f908000 task.ti: ffff88080f908000
RIP: 0010:[<ffffffff811fabf2>] [<ffffffff811fabf2>] ext4_direct_IO+0x162/0x3d0
RSP: 0018:ffff88080f90bb58 EFLAGS: 00010246
RAX: 0000000000000400 RBX: ffff88080fdb2a28 RCX: 00000000a802c818
RDX: 0000040000080000 RSI: ffff88080d8aeb80 RDI: 0000000000000001
RBP: ffff88080f90bbc8 R08: 0000000000000000 R09: 0000000000001581
R10: 0000000000000000 R11: 0000000000000000 R12: ffff88080d8aeb80
R13: ffff88080f90bbf8 R14: ffff88080fdb28c8 R15: ffff88080fdb2a28
FS: 00007f23b2055700(0000) GS:ffff880818400000(0000) knlGS:0000000000000000
CR2: 00007f23b2045000 CR3: 000000080cedf000 CR4: 00000000000407e0
Stack:
ffff88080f90bb98 0000000000000000 7ffffffffffffffe ffff88080fdb2c30
0000000000000200 0000000000000200 0000000000000001 0000000000000200
ffff88080f90bbc8 ffff88080fdb2c30 ffff88080f90be08 0000000000000200
Call Trace:
[<ffffffff8112ca9d>] generic_file_direct_write+0xed/0x180
[<ffffffff8112f2b2>] __generic_file_write_iter+0x222/0x370
[<ffffffff811f495b>] ext4_file_write_iter+0x34b/0x400
[<ffffffff811bd709>] ? aio_run_iocb+0x239/0x410
[<ffffffff810990e5>] ? local_clock+0x25/0x30
[<ffffffff810abd94>] ? __lock_acquire+0x274/0x700
[<ffffffff811f4610>] ? ext4_unwritten_wait+0xb0/0xb0
[<ffffffff811bd756>] aio_run_iocb+0x286/0x410
[<ffffffff810ac359>] ? lock_release_holdtime+0x29/0x190
[<ffffffff811bc05b>] ? lookup_ioctx+0x4b/0xf0
[<ffffffff811bde3b>] do_io_submit+0x55b/0x740
[<ffffffff811bdcaa>] ? do_io_submit+0x3ca/0x740
[<ffffffff811be030>] SyS_io_submit+0x10/0x20
[<ffffffff815ce192>] system_call_fastpath+0x16/0x1b
Code: 01 48 8b 80 f0 01 00 00 48 8b 18 49 8b 45 10 0f 85 f1 01 00 00 48 03 45 c8 48 3b 43 48 0f 8f e3 01 00 00 49 83 7c
24 18 00 75 04 <0f> 0b eb fe f0 ff 83 ec 01 00 00 49 8b 44 24 18 8b 00 85 c0 89
RIP [<ffffffff811fabf2>] ext4_direct_IO+0x162/0x3d0
RSP <ffff88080f90bb58>
Reported-by: Sasha Levin <sasha.levin@oracle.com>
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
[hujianyang: Backported to 3.10
- Move initialization of iocb->private to ext4_file_write() as we don't
have ext4_file_write_iter(), which is introduced by commit 9b884164.
- Adjust context to make 'overwrite' changes apply to ext4_file_dio_write()
as ext4_file_dio_write() is not move into ext4_file_write()]
Signed-off-by: hujianyang <hujianyang@huawei.com>
commit 5f16f3225b06242a9ee876f07c1c9b6ed36a22b6 upstream.
Use cmpxchg() to atomically set i_flags instead of clearing out the
S_IMMUTABLE, S_APPEND, etc. flags and then setting them from the
EXT4_IMMUTABLE_FL, EXT4_APPEND_FL flags, since this opens up a race
where an immutable file has the immutable flag cleared for a brief
window of time.
js: there is no change for ext4. This patch defines merely
inode_set_flags for jffs in the next patch. I wonder why do we
have both inode_set_flags and set_mask_bits? Looks like an
improperly resolved merge conflict.
Reported-by: John Sullivan <jsrhbz@kanargh.force9.co.uk>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Cc: stable@kernel.org
commit d311d79de305f1ada47cadd672e6ed1b28a949eb upstream.
It actually goes back to 2004 ([PATCH] Concurrent O_SYNC write support)
when sync_page_range() had been introduced; generic_file_write{,v}() correctly
synced
pos_after_write - written .. pos_after_write - 1
but generic_file_aio_write() synced
pos_before_write .. pos_before_write + written - 1
instead. Which is not the same thing with O_APPEND, obviously.
A couple of years later correct variant had been killed off when
everything switched to use of generic_file_aio_write().
All users of generic_file_aio_write() are affected, and the same bug
has been copied into other instances of ->aio_write().
The fix is trivial; the only subtle point is that generic_write_sync()
ought to be inlined to avoid calculations useless for the majority of
calls.
commit 599a9b77ab289d85c2d5c8607624efbe1f552b0f upstream.
When we fail to load block bitmap in __ext4_new_inode() we will
dereference NULL pointer in ext4_journal_get_write_access(). So check
for error from ext4_read_block_bitmap().
Coverity-id: 989065
commit 98c1a7593fa355fda7f5a5940c8bf5326ca964ba upstream.
If metadata checksumming is turned on for the FS, we need to tell the
journal to use checksumming too.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
commit 9378c6768e4fca48971e7b6a9075bc006eda981d upstream.
When there are no meta block groups update_backups() will compute the
backup block in 32-bit arithmetics thus possibly overflowing the block
number and corrupting the filesystem. OTOH filesystems without meta
block groups larger than 16 TB should be rare. Fix the problem by doing
the counting in 64-bit arithmetics.
Coverity-id: 741252
Reviewed-by: Lukas Czerner <lczerner@redhat.com>
commit 813d32f91333e4c33d5a19b67167c4bae42dae75 upstream.
Convert the ext4_has_group_desc_csum predicate to look for a checksum
driver instead of the metadata_csum flag and change the bg checksum
calculation function to look for GDT_CSUM before taking the crc16
path.
Without this patch, if we mount with ^uninit_bg,^metadata_csum and
later metadata_csum gets turned on by accident, the block group
checksum functions will incorrectly assume that checksumming is
enabled (metadata_csum) but that crc16 should be used
(!s_chksum_driver). This is totally wrong, so fix the predicate
and the checksum formula selection.
(Granted, if the metadata_csum feature bit gets enabled on a live FS
then something underhanded is going on, but we could at least avoid
writing garbage into the on-disk fields.)
Reviewed-by: Dmitry Monakhov <dmonakhov@openvz.org>
commit 9aa5d32ba269bec0e7eaba2697a986a7b0bc8528 upstream.
Besides the fact that this replacement improves code readability
it also protects from errors caused direct EXT4_S(sb)->s_es manipulation
which may result attempt to use uninitialized csum machinery.
#Testcase_BEGIN
IMG=/dev/ram0
MNT=/mnt
mkfs.ext4 $IMG
mount $IMG $MNT
#Enable feature directly on disk, on mounted fs
tune2fs -O metadata_csum $IMG
# Provoke metadata update, likey result in OOPS
touch $MNT/test
umount $MNT
#Testcase_END
# Replacement script
expression E;
- EXT4_HAS_RO_COMPAT_FEATURE(E, EXT4_FEATURE_RO_COMPAT_METADATA_CSUM)
+ ext4_has_metadata_csum(E)
https://bugzilla.kernel.org/show_bug.cgi?id=82201
commit 0ff8947fc5f700172b37cbca811a38eb9cb81e08 upstream.
Delalloc write journal reservations only reserve 1 credit,
to update the inode if necessary. However, it may happen
once in a filesystem's lifetime that a file will cross
the 2G threshold, and require the LARGE_FILE feature to
be set in the superblock as well, if it was not set already.
This overruns the transaction reservation, and can be
demonstrated simply on any ext4 filesystem without the LARGE_FILE
feature already set:
dd if=/dev/zero of=testfile bs=1 seek=2147483646 count=1 \
conv=notrunc of=testfile
sync
dd if=/dev/zero of=testfile bs=1 seek=2147483647 count=1 \
leads to:
EXT4-fs: ext4_do_update_inode:4296: aborting transaction: error 28 in __ext4_handle_dirty_super
EXT4-fs error (device loop0) in ext4_do_update_inode:4301: error 28
EXT4-fs error (device loop0) in ext4_reserve_inode_write:4757: Readonly filesystem
EXT4-fs error (device loop0) in ext4_dirty_inode:4876: error 28
EXT4-fs error (device loop0) in ext4_da_write_end:2685: error 28
Adjust the number of credits based on whether the flag is
already set, and whether the current write may extend past the
LARGE_FILE limit.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
commit f4bb2981024fc91b23b4d09a8817c415396dbabb upstream.
If there is a corrupted file system which has directory entries that
point at reserved, metadata inodes, prohibit them from being used by
treating them the same way we treat Boot Loader inodes --- that is,
mark them to be bad inodes. This prohibits them from being opened,
deleted, or modified via chmod, chown, utimes, etc.
In particular, this prevents a corrupted file system which has a
directory entry which points at the journal inode from being deleted
and its blocks released, after which point Much Hilarity Ensues.
Reported-by: Sami Liedes <sami.liedes@iki.fi>
commit 3e67cfad22230ebed85c56cbe413876f33fea82b upstream.
Otherwise this provokes complain like follows:
WARNING: CPU: 12 PID: 5795 at fs/ext4/ext4_jbd2.c:48 ext4_journal_check_start+0x4e/0xa0()
CPU: 12 PID: 5795 Comm: python Not tainted 3.17.0-rc2-00175-gae5344f #158
0000000000000030 ffff8808116cfd28 ffffffff815c7dfc 0000000000000030
0000000000000000 ffff8808116cfd68 ffffffff8106ce8c ffff8808116cfdc8
ffff880813b16000 ffff880806ad6ae8 ffffffff81202008 0000000000000000
Call Trace:
[<ffffffff815c7dfc>] dump_stack+0x51/0x6d
[<ffffffff8106ce8c>] warn_slowpath_common+0x8c/0xc0
[<ffffffff81202008>] ? ext4_ioctl+0x9e8/0xeb0
[<ffffffff8106ceda>] warn_slowpath_null+0x1a/0x20
[<ffffffff8122867e>] ext4_journal_check_start+0x4e/0xa0
[<ffffffff81228c10>] __ext4_journal_start_sb+0x90/0x110
[<ffffffff81202008>] ext4_ioctl+0x9e8/0xeb0
[<ffffffff8107b0bd>] ? ptrace_stop+0x24d/0x2f0
[<ffffffff81088530>] ? alloc_pid+0x480/0x480
[<ffffffff8107b1f2>] ? ptrace_do_notify+0x92/0xb0
[<ffffffff81186545>] do_vfs_ioctl+0x4e5/0x550
[<ffffffff815cdbcb>] ? _raw_spin_unlock_irq+0x2b/0x40
[<ffffffff81186603>] SyS_ioctl+0x53/0x80
[<ffffffff815ce2ce>] tracesys+0xd0/0xd5
commit d6320cbfc92910a3e5f10c42d98c231c98db4f60 upstream.
Use truncate_isize_extended() when hole is being created in a file so that
->page_mkwrite() will get called for the partial tail page if it is
mmaped (see the first patch in the series for details).
commit 279bf6d390933d5353ab298fcc306c391a961469 upstream.
The check whether quota format is set even though there are no
quota files with journalled quota is pointless and it actually
makes it impossible to turn off journalled quotas (as there's
no way to unset journalled quota format). Just remove the check.
commit a0626e75954078cfacddb00a4545dde821170bc5 upstream.
When loading extended attributes, check each entry's value offset to
make sure it doesn't collide with the entries.
Without this check it is easy to crash the kernel by mounting a
malicious FS containing a file with an EA wherein e_value_offs = 0 and
e_value_size > 0 and then deleting the EA, which corrupts the name
list.
(See the f_ea_value_crash test's FS image in e2fsprogs for an example.)
possible
commit 2457aec63745e235bcafb7ef312b182d8682f0fc upstream.
aops->write_begin may allocate a new page and make it visible only to have
mark_page_accessed called almost immediately after. Once the page is
visible the atomic operations are necessary which is noticable overhead
when writing to an in-memory filesystem like tmpfs but should also be
noticable with fast storage. The objective of the patch is to initialse
the accessed information with non-atomic operations before the page is
visible.
The bulk of filesystems directly or indirectly use
grab_cache_page_write_begin or find_or_create_page for the initial
allocation of a page cache page. This patch adds an init_page_accessed()
helper which behaves like the first call to mark_page_accessed() but may
called before the page is visible and can be done non-atomically.
The primary APIs of concern in this care are the following and are used
by most filesystems.
find_get_page
find_lock_page
find_or_create_page
grab_cache_page_nowait
All of them are very similar in detail to the patch creates a core helper
pagecache_get_page() which takes a flags parameter that affects its
behavior such as whether the page should be marked accessed or not. Then
old API is preserved but is basically a thin wrapper around this core
function.
Each of the filesystems are then updated to avoid calling
mark_page_accessed when it is known that the VM interfaces have already
done the job. There is a slight snag in that the timing of the
mark_page_accessed() has now changed so in rare cases it's possible a page
gets to the end of the LRU as PageReferenced where as previously it might
have been repromoted. This is expected to be rare but it's worth the
filesystem people thinking about it in case they see a problem with the
timing change. It is also the case that some filesystems may be marking
pages accessed that previously did not but it makes sense that filesystems
have consistent behaviour in this regard.
The test case used to evaulate this is a simple dd of a large file done
multiple times with the file deleted on each iterations. The size of the
file is 1/10th physical memory to avoid dirty page balancing. In the
async case it will be possible that the workload completes without even
hitting the disk and will have variable results but highlight the impact
of mark_page_accessed for async IO. The sync results are expected to be
more stable. The exception is tmpfs where the normal case is for the "IO"
to not hit the disk.
The test machine was single socket and UMA to avoid any scheduling or NUMA
artifacts. Throughput and wall times are presented for sync IO, only wall
times are shown for async as the granularity reported by dd and the
variability is unsuitable for comparison. As async results were variable
do to writback timings, I'm only reporting the maximum figures. The sync
results were stable enough to make the mean and stddev uninteresting.
The performance results are reported based on a run with no profiling.
Profile data is based on a separate run with oprofile running.
async dd
3.15.0-rc3 3.15.0-rc3
vanilla accessed-v2
ext3 Max elapsed 13.9900 ( 0.00%) 11.5900 ( 17.16%)
tmpfs Max elapsed 0.5100 ( 0.00%) 0.4900 ( 3.92%)
btrfs Max elapsed 12.8100 ( 0.00%) 12.7800 ( 0.23%)
ext4 Max elapsed 18.6000 ( 0.00%) 13.3400 ( 28.28%)
xfs Max elapsed 12.5600 ( 0.00%) 2.0900 ( 83.36%)
The XFS figure is a bit strange as it managed to avoid a worst case by
sheer luck but the average figures looked reasonable.
samples percentage
ext3 86107 0.9783 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext3 23833 0.2710 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext3 5036 0.0573 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
ext4 64566 0.8961 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
ext4 5322 0.0713 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
ext4 2869 0.0384 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 62126 1.7675 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
xfs 1904 0.0554 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
xfs 103 0.0030 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
btrfs 10655 0.1338 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
btrfs 2020 0.0273 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
btrfs 587 0.0079 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
tmpfs 59562 3.2628 vmlinux-3.15.0-rc4-vanilla mark_page_accessed
tmpfs 1210 0.0696 vmlinux-3.15.0-rc4-accessed-v3r25 init_page_accessed
tmpfs 94 0.0054 vmlinux-3.15.0-rc4-accessed-v3r25 mark_page_accessed
[akpm@linux-foundation.org: don't run init_page_accessed() against an uninitialised pointer]
Cc: Jan Kara <jack@suse.cz>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Tested-by: Prabhakar Lad <prabhakar.csengg@gmail.com>
commit db9ee220361de03ee86388f9ea5e529eaad5323c upstream.
It turns out that there are some serious problems with the on-disk
format of journal checksum v2. The foremost is that the function to
calculate descriptor tag size returns sizes that are too big. This
causes alignment issues on some architectures and is compounded by the
fact that some parts of jbd2 use the structure size (incorrectly) to
determine the presence of a 64bit journal instead of checking the
feature flags.
Therefore, introduce journal checksum v3, which enlarges the
descriptor block tag format to allow for full 32-bit checksums of
journal blocks, fix the journal tag function to return the correct
sizes, and fix the jbd2 recovery code to use feature flags to
determine 64bitness.
Add a few function helpers so we don't have to open-code quite so
many pieces.
Switching to a 16-byte block size was found to increase journal size
overhead by a maximum of 0.1%, to convert a 32-bit journal with no
checksumming to a 32-bit journal with checksum v3 enabled.
Reported-by: TR Reardon <thomas_reardon@hotmail.com>
commit 6603120e96eae9a5d6228681ae55c7fdc998d1bb upstream.
In case of delalloc block i_disksize may be less than i_size. So we
have to update i_disksize each time we allocated and submitted some
blocks beyond i_disksize. We weren't doing this on the error paths,
so fix this.
testcase: xfstest generic/019
commit c99d1e6e83b06744c75d9f5e491ed495a7086b7b upstream.
If we suffer a block allocation failure (for example due to a memory
allocation failure), it's possible that we will call
ext4_discard_allocated_blocks() before we've actually allocated any
blocks. In that case, fe_len and fe_start in ac->ac_f_ex will still
be zero, and this will result in mb_free_blocks(inode, e4b, 0, 0)
triggering the BUG_ON on mb_free_blocks():
BUG_ON(last >= (sb->s_blocksize << 3));
Fix this by bailing out of ext4_discard_allocated_blocks() if fs_len
is zero.
Also fix a missing ext4_mb_unload_buddy() call in
ext4_discard_allocated_blocks().
Google-Bug-Id: 16844242
Fixes: 86f0afd463215fc3e58020493482faa4ac3a4d69
Cc: stable@vger.kernel.org
commit 86f0afd463215fc3e58020493482faa4ac3a4d69 upstream.
If there is a failure while allocating the preallocation structure, a
number of blocks can end up getting marked in the in-memory buddy
bitmap, and then not getting released. This can result in the
following corruption getting reported by the kernel:
EXT4-fs error (device sda3): ext4_mb_generate_buddy:758: group 1126,
12793 clusters in bitmap, 12729 in gd
In that case, we need to release the blocks using mb_free_blocks().
Tested: fs smoke test; also demonstrated that with injected errors,
the file system is no longer getting corrupted
Google-Bug-Id: 16657874
commit 77ea2a4ba657a1ad4fb7c64bc5cdce84b8a132b6 upstream.
free_holes_block() passed local variable as a block pointer
to ext4_clear_blocks(). Thus ext4_clear_blocks() zeroed out this local
variable instead of proper place in inode / indirect block. We later
zero out proper place in inode / indirect block but don't dirty the
inode / buffer again which can lead to subtle issues (some changes e.g.
to inode can be lost).
commit 3f1f9b851311a76226140b55b1ea22111234a7c2 upstream.
This fixes the following lockdep complaint:
[ INFO: possible circular locking dependency detected ]
3.16.0-rc2-mm1+ #7 Tainted: G O
kworker/u24:0/4356 is trying to acquire lock:
(&(&sbi->s_es_lru_lock)->rlock){+.+.-.}, at: [<ffffffff81285fff>] __ext4_es_shrink+0x4f/0x2e0
but task is already holding lock:
(&ei->i_es_lock){++++-.}, at: [<ffffffff81286961>] ext4_es_insert_extent+0x71/0x180
which lock already depends on the new lock.
Possible unsafe locking scenario:
CPU0 CPU1
lock(&ei->i_es_lock);
lock(&(&sbi->s_es_lru_lock)->rlock);
*** DEADLOCK ***
6 locks held by kworker/u24:0/4356:
#0: ("writeback"){.+.+.+}, at: [<ffffffff81071d00>] process_one_work+0x180/0x560
#1: ((&(&wb->dwork)->work)){+.+.+.}, at: [<ffffffff81071d00>] process_one_work+0x180/0x560
#2: (&type->s_umount_key#22){++++++}, at: [<ffffffff811a9c74>] grab_super_passive+0x44/0x90
#3: (jbd2_handle){+.+...}, at: [<ffffffff812979f9>] start_this_handle+0x189/0x5f0
#4: (&ei->i_data_sem){++++..}, at: [<ffffffff81247062>] ext4_map_blocks+0x132/0x550
#5: (&ei->i_es_lock){++++-.}, at: [<ffffffff81286961>] ext4_es_insert_extent+0x71/0x180
stack backtrace:
CPU: 0 PID: 4356 Comm: kworker/u24:0 Tainted: G O 3.16.0-rc2-mm1+ #7
Hardware name: Bochs Bochs, BIOS Bochs 01/01/2011
Workqueue: writeback bdi_writeback_workfn (flush-253:0)
ffffffff8213dce0 ffff880014b07538 ffffffff815df0bb 0000000000000007
ffffffff8213e040 ffff880014b07588 ffffffff815db3dd ffff880014b07568
ffff880014b07610 ffff88003b868930 ffff88003b868908 ffff88003b868930
Call Trace:
[<ffffffff815df0bb>] dump_stack+0x4e/0x68
[<ffffffff815db3dd>] print_circular_bug+0x1fb/0x20c
[<ffffffff810a7a3e>] __lock_acquire+0x163e/0x1d00
[<ffffffff815e89dc>] ? retint_restore_args+0xe/0xe
[<ffffffff815ddc7b>] ? __slab_alloc+0x4a8/0x4ce
[<ffffffff81285fff>] ? __ext4_es_shrink+0x4f/0x2e0
[<ffffffff810a8707>] lock_acquire+0x87/0x120
[<ffffffff8128592d>] ? ext4_es_free_extent+0x5d/0x70
[<ffffffff815e6f09>] _raw_spin_lock+0x39/0x50
[<ffffffff8119760b>] ? kmem_cache_alloc+0x18b/0x1a0
[<ffffffff812869b8>] ext4_es_insert_extent+0xc8/0x180
[<ffffffff812470f4>] ext4_map_blocks+0x1c4/0x550
[<ffffffff8124c4c4>] ext4_writepages+0x6d4/0xd00
Reported-by: Minchan Kim <minchan@kernel.org>
Cc: Zheng Liu <gnehzuil.liu@gmail.com>
commit 5dd214248f94d430d70e9230bda72f2654ac88a8 upstream.
The mount manpage says of the max_batch_time option,
This optimization can be turned off entirely
by setting max_batch_time to 0.
But the code doesn't do that. So fix the code to do
that.
commit 94d4c066a4ff170a2671b1a9b153febbf36796f6 upstream.
We are spending a lot of time explaining to users what this error
means. Let's try to improve the message to avoid this problem.
commit ae0f78de2c43b6fadd007c231a352b13b5be8ed2 upstream.
Make it clear that values printed are times, and that it is error
since last fsck. Also add note about fsck version required.
Signed-off-by: Pavel Machek <pavel@ucw.cz>
commit 61c219f5814277ecb71d64cb30297028d6665979 upstream.
The first time that we allocate from an uninitialized inode allocation
bitmap, if the block allocation bitmap is also uninitalized, we need
to get write access to the block group descriptor before we start
modifying the block group descriptor flags and updating the free block
count, etc. Otherwise, there is the potential of a bad journal
checksum (if journal checksums are enabled), and of the file system
becoming inconsistent if we crash at exactly the wrong time.
commit a93cd4cf86466caa49cfe64607bea7f0bde3f916 upstream.
Hole punching code for files with indirect blocks wrongly computed
number of blocks which need to be cleared when traversing the indirect
block tree. That could result in punching more blocks than actually
requested and thus effectively cause a data loss. For example:
fallocate -n -p 10240000 4096
will punch the range 10240000 - 12632064 instead of the range 1024000 -
10244096. Fix the calculation.
Fixes: 8bad6fc813a3a5300f51369c39d315679fd88c72
commit c5c7b8ddfbf8cb3b2291e515a34ab1b8982f5a2d upstream.
Error recovery in ext4_alloc_branch() calls ext4_forget() even for
buffer corresponding to indirect block it did not allocate. This leads
to brelse() being called twice for that buffer (once from ext4_forget()
and once from cleanup in ext4_ind_map_blocks()) leading to buffer use
count misaccounting. Eventually (but often much later because there
are other users of the buffer) we will see messages like:
VFS: brelse: Trying to free free buffer
Another manifestation of this problem is an error:
JBD2 unexpected failure: jbd2_journal_revoke: !buffer_revoked(bh);
inconsistent data on disk
The fix is easy - don't forget buffer we did not allocate. Also add an
explanatory comment because the indexing at ext4_alloc_branch() is
somewhat subtle.
commit b5b60778558cafad17bbcbf63e0310bd3c68eb17 upstream.
The variable "size" is expressed as number of blocks and not as
number of clusters, this could trigger a kernel panic when using
ext4 with the size of a cluster different from the size of a block.
Signed-off-by: Maurizio Lombardi <mlombard@redhat.com>
commit eeece469dedadf3918bad50ad80f4616a0064e90 upstream.
Tail of a page straddling inode size must be zeroed when being written
out due to POSIX requirement that modifications of mmaped page beyond
inode size must not be written to the file. ext4_bio_write_page() did
this only for blocks fully beyond inode size but didn't properly zero
blocks partially beyond inode size. Fix this.
The problem has been uncovered by mmap_11-4 test in openposix test suite
(part of LTP).
Reported-by: Xiaoguang Wang <wangxg.fnst@cn.fujitsu.com>
Fixes: 5a0dc7365c240
Fixes: bd2d0210cf22f
CC: stable@vger.kernel.org
commit 1c8349a17137b93f0a83f276c764a6df1b9a116e upstream.
When we perform a data integrity sync we tag all the dirty pages with
PAGECACHE_TAG_TOWRITE at start of ext4_da_writepages. Later we check
for this tag in write_cache_pages_da and creates a struct
mpage_da_data containing contiguously indexed pages tagged with this
tag and sync these pages with a call to mpage_da_map_and_submit. This
process is done in while loop until all the PAGECACHE_TAG_TOWRITE
pages are synced. We also do journal start and stop in each iteration.
journal_stop could initiate journal commit which would call
ext4_writepage which in turn will call ext4_bio_write_page even for
delayed OR unwritten buffers. When ext4_bio_write_page is called for
such buffers, even though it does not sync them but it clears the
PAGECACHE_TAG_TOWRITE of the corresponding page and hence these pages
are also not synced by the currently running data integrity sync. We
will end up with dirty pages although sync is completed.
This could cause a potential data loss when the sync call is followed
by a truncate_pagecache call, which is exactly the case in
collapse_range. (It will cause generic/127 failure in xfstests)
To avoid this issue, we can use set_page_writeback_keepwrite instead of
set_page_writeback, which doesn't clear TOWRITE tag.
Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com>
Signed-off-by: Ashish Sangwan <a.sangwan@samsung.com>
commit 6e6358fc3c3c862bfe9a5bc029d3f8ce43dc9765 upstream.
We haven't taken i_mutex yet, so we need to use i_size_read().
commit 622cad1325e404598fe3b148c3fa640dbaabc235 upstream.
The function ext4_update_i_disksize() is used in only one place, in
the function mpage_map_and_submit_extent(). Move its code to simplify
the code paths, and also move the call to ext4_mark_inode_dirty() into
the i_data_sem's critical region, to be consistent with all of the
other places where we update i_disksize. That way, we also keep the
raw_inode's i_disksize protected, to avoid the following race:
CPU #1 CPU #2
down_write(&i_data_sem)
Modify i_disk_size
up_write(&i_data_sem)
Modify i_disk_size
Copy i_disk_size to on-disk inode
commit ec4cb1aa2b7bae18dd8164f2e9c7c51abcf61280 upstream.
When heavily exercising xattr code the assertion that
jbd2_journal_dirty_metadata() shouldn't return error was triggered:
WARNING: at /srv/autobuild-ceph/gitbuilder.git/build/fs/jbd2/transaction.c:1237
jbd2_journal_dirty_metadata+0x1ba/0x260()
CPU: 0 PID: 8877 Comm: ceph-osd Tainted: G W 3.10.0-ceph-00049-g68d04c9 #1
Hardware name: Dell Inc. PowerEdge R410/01V648, BIOS 1.6.3 02/07/2011
ffffffff81a1d3c8 ffff880214469928 ffffffff816311b0 ffff880214469968
ffffffff8103fae0 ffff880214469958 ffff880170a9dc30 ffff8802240fbe80
0000000000000000 ffff88020b366000 ffff8802256e7510 ffff880214469978
Call Trace:
[<ffffffff816311b0>] dump_stack+0x19/0x1b
[<ffffffff8103fae0>] warn_slowpath_common+0x70/0xa0
[<ffffffff8103fb2a>] warn_slowpath_null+0x1a/0x20
[<ffffffff81267c2a>] jbd2_journal_dirty_metadata+0x1ba/0x260
[<ffffffff81245093>] __ext4_handle_dirty_metadata+0xa3/0x140
[<ffffffff812561f3>] ext4_xattr_release_block+0x103/0x1f0
[<ffffffff81256680>] ext4_xattr_block_set+0x1e0/0x910
[<ffffffff8125795b>] ext4_xattr_set_handle+0x38b/0x4a0
[<ffffffff810a319d>] ? trace_hardirqs_on+0xd/0x10
[<ffffffff81257b32>] ext4_xattr_set+0xc2/0x140
[<ffffffff81258547>] ext4_xattr_user_set+0x47/0x50
[<ffffffff811935ce>] generic_setxattr+0x6e/0x90
[<ffffffff81193ecb>] __vfs_setxattr_noperm+0x7b/0x1c0
[<ffffffff811940d4>] vfs_setxattr+0xc4/0xd0
[<ffffffff8119421e>] setxattr+0x13e/0x1e0
[<ffffffff811719c7>] ? __sb_start_write+0xe7/0x1b0
[<ffffffff8118f2e8>] ? mnt_want_write_file+0x28/0x60
[<ffffffff8118c65c>] ? fget_light+0x3c/0x130
[<ffffffff8118f1f8>] ? __mnt_want_write+0x58/0x70
[<ffffffff811946be>] SyS_fsetxattr+0xbe/0x100
[<ffffffff816407c2>] system_call_fastpath+0x16/0x1b
The reason for the warning is that buffer_head passed into
jbd2_journal_dirty_metadata() didn't have journal_head attached. This is
caused by the following race of two ext4_xattr_release_block() calls:
CPU1 CPU2
ext4_xattr_release_block() ext4_xattr_release_block()
lock_buffer(bh);
/* False */
if (BHDR(bh)->h_refcount == cpu_to_le32(1))
} else {
le32_add_cpu(&BHDR(bh)->h_refcount, -1);
unlock_buffer(bh);
lock_buffer(bh);
/* True */
get_bh(bh);
ext4_free_blocks()
jbd2_journal_forget()
jbd2_journal_unfile_buffer()
-> JH is gone
error = ext4_handle_dirty_xattr_block(handle, inode, bh);
-> triggers the warning
We fix the problem by moving ext4_handle_dirty_xattr_block() under the
buffer lock. Sadly this cannot be done in nojournal mode as that
function can call sync_dirty_buffer() which would deadlock. Luckily in
nojournal mode the race is harmless (we only dirty already freed buffer)
and thus for nojournal mode we leave the dirtying outside of the buffer
lock.
Reported-by: Sage Weil <sage@inktank.com>
commit 9503c67c93ed0b95ba62d12d1fd09da6245dbdd6 upstream.
ext4_end_bio() currently throws away the error that it receives. Chances
are this is part of a spate of errors, one of which will end up getting
the error returned to userspace somehow, but we shouldn't take that risk.
Also print out the errno to aid in debug.
Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
commit 4adb6ab3e0fa71363a5ef229544b2d17de6600d7 upstream.
When we try to get 2^32-1 block of the file which has the extent
(ee_block=2^32-2, ee_len=1) with FIBMAP ioctl, it causes BUG_ON
in ext4_ext_put_gap_in_cache().
To avoid the problem, ext4_map_blocks() needs to check the file logical block
number. ext4_ext_put_gap_in_cache() called via ext4_map_blocks() cannot
handle 2^32-1 because the maximum file logical block number is 2^32-2.
Note that ext4_ind_map_blocks() returns -EIO when the block number is invalid.
So ext4_map_blocks() should also return the same errno.
Signed-off-by: Kazuya Mio <k-mio@sx.jp.nec.com>
commit ad6599ab3ac98a4474544086e048ce86ec15a4d1 upstream.
Xfstests generic/311 and shared/298 fail when run on a bigalloc file
system. Kernel error messages produced during the tests report that
blocks to be freed are already on the to-be-freed list. When e2fsck
is run at the end of the tests, it typically reports bad i_blocks and
bad free blocks counts.
The bug that causes these failures is located in ext4_ext_rm_leaf().
Code at the end of the function frees a partial cluster if it's not
shared with an extent remaining in the leaf. However, if all the
extents in the leaf have been removed, the code dereferences an
invalid extent pointer (off the front of the leaf) when the check for
sharing is made. This generally has the effect of unconditionally
freeing the partial cluster, which leads to the observed failures
when the partial cluster is shared with the last extent in the next
leaf.
Fix this by attempting to free the cluster only if extents remain in
the leaf. Any remaining partial cluster will be freed if possible
when the next leaf is processed or when leaf removal is complete.
Signed-off-by: Eric Whitney <enwlinux@gmail.com>
commit c06344939422bbd032ac967223a7863de57496b5 upstream.
Commit 9cb00419fa, which enables hole punching for bigalloc file
systems, exposed a bug introduced by commit 6ae06ff51e in an earlier
release. When run on a bigalloc file system, xfstests generic/013, 068,
075, 083, 091, 100, 112, 127, 263, 269, and 270 fail with e2fsck errors
or cause kernel error messages indicating that previously freed blocks
are being freed again.
The latter commit optimizes the selection of the starting extent in
ext4_ext_rm_leaf() when hole punching by beginning with the extent
supplied in the path argument rather than with the last extent in the
leaf node (as is still done when truncating). However, the code in
rm_leaf that initially sets partial_cluster to track cluster sharing on
extent boundaries is only guaranteed to run if rm_leaf starts with the
last node in the leaf. Consequently, partial_cluster is not correctly
initialized when hole punching, and a cluster on the boundary of a
punched region that should be retained may instead be deallocated.
commit ce37c42919608e96ade3748fe23c3062a0a966c5 upstream.
Commit 3779473246 breaks the return of error codes from
ext4_ext_handle_uninitialized_extents() in ext4_ext_map_blocks(). A
portion of the patch assigns that function's signed integer return
value to an unsigned int. Consequently, negatively valued error codes
are lost and can be treated as a bogus allocated block count.
commit 10542c229a4e8e25b40357beea66abe9dacda2c0 upstream.
When doing filesystem wide sync, there's no need to force transaction
commit (or synchronously write inode buffer) separately for each inode
because ext4_sync_fs() takes care of forcing commit at the end (VFS
takes care of flushing buffer cache, respectively). Most of the time
this slowness doesn't manifest because previous WB_SYNC_NONE writeback
doesn't leave much to write but when there are processes aggressively
creating new files and several filesystems to sync, the sync slowness
can be noticeable. In the following test script sync(1) takes around 6
minutes when there are two ext4 filesystems mounted on a standard SATA
drive. After this patch sync takes a couple of seconds so we have about
two orders of magnitude improvement.
function run_writers
for (( i = 0; i < 10; i++ )); do
mkdir $1/dir$i
for (( j = 0; j < 40000; j++ )); do
dd if=/dev/zero of=$1/dir$i/$j bs=4k count=4 &>/dev/null
done &
done
for dir in "$@"; do
run_writers $dir
done
sleep 40
time sync
commit 00a1a053ebe5febcfc2ec498bd894f035ad2aa06 upstream.
window of time.
commit dff6efc326a4d5f305797d4a6bba14f374fdd633 upstream.
Currently notify_change directly updates i_version for size updates,
which not only is counter to how all other fields are updated through
struct iattr, but also breaks XFS, which need inode updates to happen
under its own lock, and synchronized to the structure that gets written
to the log.
Remove the update in the common code, and it to btrfs and ext4,
XFS already does a proper updaste internally and currently gets a
double update with the existing code.
IMHO this is 3.13 and -stable material and should go in through the XFS
tree.
Acked-by: Jan Kara <jack@suse.cz>
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Signed-off-by: Chris Mason <clm@fb.com>
Signed-off-by: Ben Myers <bpm@sgi.com>
commit 19ea80603715d473600cd993b9987bc97d042e02 upstream.
If the i_crtime field is not present in the inode, don't leave the
field uninitialized.
Fixes: ef7f38359 ("ext4: Add nanosecond timestamps")
Reported-by: Vegard Nossum <vegard.nossum@oracle.com>
Tested-by: Vegard Nossum <vegard.nossum@oracle.com>
commit 3d2660d0c9c2f296837078c189b68a47f6b2e3b5 upstream.
The set_flexbg_block_bitmap() function assumed that the number of
blocks in a blockgroup was sb->blocksize * 8, which is normally true,
but not always! Use EXT4_BLOCKS_PER_GROUP(sb) instead, to fix block
bitmap corruption after:
mke2fs -t ext4 -g 3072 -i 4096 /dev/vdd 1G
mount -t ext4 /dev/vdd /vdd
resize2fs /dev/vdd 8G
Reported-by: Jon Bernard <jbernard@tuxion.com>
commit b93c95353413041a8cebad915a8109619f66bcc6 upstream.
If a file system has a large number of inodes per block group, all of
the metadata blocks in a flex_bg may be larger than what can fit in a
single block group. Unfortunately, ext4_alloc_group_tables() in
resize.c was never tested to see if it would handle this case
correctly, and there were a large number of bugs which caused the
following sequence to result in a BUG_ON:
kernel bug at fs/ext4/resize.c:409!
call trace:
[<ffffffff81256768>] ext4_flex_group_add+0x1448/0x1830
[<ffffffff81257de2>] ext4_resize_fs+0x7b2/0xe80
[<ffffffff8123ac50>] ext4_ioctl+0xbf0/0xf00
[<ffffffff811c111d>] do_vfs_ioctl+0x2dd/0x4b0
[<ffffffff811b9df2>] ? final_putname+0x22/0x50
[<ffffffff811c1371>] sys_ioctl+0x81/0xa0
[<ffffffff81676aa9>] system_call_fastpath+0x16/0x1b
code: c8 4c 89 df e8 41 96 f8 ff 44 89 e8 49 01 c4 44 29 6d d4 0
rip [<ffffffff81254fa1>] set_flexbg_block_bitmap+0x171/0x180
This can be reproduced with the following command sequence:
mke2fs -t ext4 -i 4096 /dev/vdd 1G
To fix this, we need to make sure the right thing happens when a block
group's inode table straddles two block groups, which means the
following bugs had to be fixed:
1) Not clearing the BLOCK_UNINIT flag in the second block group in
ext4_alloc_group_tables --- the was proximate cause of the BUG_ON.
2) Incorrectly determining how many block groups contained contiguous
free blocks in ext4_alloc_group_tables().
3) Incorrectly setting the start of the next block range to be marked
in use after a discontinuity in setup_new_flex_group_blocks().
commit 23301410972330c0ae9a8afc379ba2005e249cc6 upstream.
If an ext4 file system is created by some tool other than mke2fs
(perhaps by someone who has a pathalogical fear of the GPL) that
doesn't set one or the other of the EXT2_FLAGS_{UN}SIGNED_HASH flags,
and that file system is then mounted read-only, don't try to modify
the s_flags field. Otherwise, if dm_verity is in use, the superblock
will change, causing an dm_verity failure.
commit 30d29b119ef01776e0a301444ab24defe8d8bef3 upstream.
In swap_inode_boot_loader() we forgot to release ->i_mutex and resume
unlocked dio for inode and inode_bl if there is an error starting the
journal handle. This commit fixes this issue.
Reported-by: Ahmed Tamrawi <ahmedtamrawi@gmail.com>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Dr. Tilmann Bubeck <t.bubeck@reinform.de>
Signed-off-by: Zheng Liu <wenqing.lz@taobao.com>
commit 15cc17678547676c82a5da9ccf357447333fc342 upstream.
Commit a115f749c1 (ext4: remove wait for unwritten extent conversion from
ext4_truncate) exposed a bug in ext4_ext_handle_uninitialized_extents().
It can be triggered by xfstest generic/299 when run on a test file
system created without a journal. This test continuously fallocates and
truncates files to which random dio/aio writes are simultaneously
performed by a separate process. The test completes successfully, but
if the test filesystem is mounted with the block_validity option, a
warning message stating that a logical block has been mapped to an
illegal physical block is posted in the kernel log.
The bug occurs when an extent is being converted to the written state
by ext4_end_io_dio() and ext4_ext_handle_uninitialized_extents()
discovers a mapping for an existing uninitialized extent. Although it
sets EXT4_MAP_MAPPED in map->m_flags, it fails to set map->m_pblk to
the discovered physical block number. Because map->m_pblk is not
otherwise initialized or set by this function or its callers, its
uninitialized value is returned to ext4_map_blocks(), where it is
stored as a bogus mapping in the extent status tree.
Since map->m_pblk can accidentally contain illegal values that are
larger than the physical size of the file system, calls to
check_block_validity() in ext4_map_blocks() that are enabled if the
block_validity mount option is used can fail, resulting in the logged
warning message.
commit 09c455aaa8f47a94d5bafaa23d58365768210507 upstream.
A missing cast means that when we are truncating a file which is less
than 60 bytes, we don't clear the correct area of memory, and in fact
we can end up truncating the next inode in the inode table, or worse
yet, some other kernel data structure.
Addresses-Coverity-Id: #751987
