commit 163f0ec1df33cf468509ff38cbcbb5eb0d7fac60 upstream.
Syzbot is reporting that ext4 can enter fs reclaim from kvmalloc() while
the transaction is started like:
fs_reclaim_acquire+0x117/0x150 mm/page_alloc.c:4340
might_alloc include/linux/sched/mm.h:193 [inline]
slab_pre_alloc_hook mm/slab.h:493 [inline]
slab_alloc_node mm/slub.c:2817 [inline]
__kmalloc_node+0x5f/0x430 mm/slub.c:4015
kmalloc_node include/linux/slab.h:575 [inline]
kvmalloc_node+0x61/0xf0 mm/util.c:587
kvmalloc include/linux/mm.h:781 [inline]
ext4_xattr_inode_cache_find fs/ext4/xattr.c:1465 [inline]
ext4_xattr_inode_lookup_create fs/ext4/xattr.c:1508 [inline]
ext4_xattr_set_entry+0x1ce6/0x3780 fs/ext4/xattr.c:1649
ext4_xattr_ibody_set+0x78/0x2b0 fs/ext4/xattr.c:2224
ext4_xattr_set_handle+0x8f4/0x13e0 fs/ext4/xattr.c:2380
ext4_xattr_set+0x13a/0x340 fs/ext4/xattr.c:2493
This should be impossible since transaction start sets PF_MEMALLOC_NOFS.
Add some assertions to the code to catch if something isn't working as
expected early.
Link: https://lore.kernel.org/linux-ext4/000000000000563a0205bafb7970@google.com/
Link: https://lore.kernel.org/r/20210222171626.21884-1-jack@suse.cz
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
commit 6b22489911b726eebbf169caee52fea52013fbdd upstream.
Syzbot report a warning that ext4 may create an empty ea_inode if set
an empty extent attribute to a file on the file system which is no free
blocks left.
WARNING: CPU: 6 PID: 10667 at fs/ext4/xattr.c:1640 ext4_xattr_set_entry+0x10f8/0x1114 fs/ext4/xattr.c:1640
Call trace:
ext4_xattr_block_set+0x1d0/0x1b1c fs/ext4/xattr.c:1942
ext4_xattr_set_handle+0x8a0/0xf1c fs/ext4/xattr.c:2390
ext4_xattr_set+0x120/0x1f0 fs/ext4/xattr.c:2491
ext4_xattr_trusted_set+0x48/0x5c fs/ext4/xattr_trusted.c:37
__vfs_setxattr+0x208/0x23c fs/xattr.c:177
Now, ext4 try to store extent attribute into an external inode if
ext4_xattr_block_set() return -ENOSPC, but for the case of store an
empty extent attribute, store the extent entry into the extent
attribute block is enough. A simple reproduce below.
fallocate test.img -l 1M
mkfs.ext4 -F -b 2048 -O ea_inode test.img
mount test.img /mnt
dd if=/dev/zero of=/mnt/foo bs=2048 count=500
setfattr -n "user.test" /mnt/foo
Reported-by: syzbot+98b881fdd8ebf45ab4ae@syzkaller.appspotmail.com
Fixes: 9c6e7853c531 ("ext4: reserve space for xattr entries/names")
Cc: stable@kernel.org
Signed-off-by: zhangyi (F) <yi.zhang@huawei.com>
Link: https://lore.kernel.org/r/20210305120508.298465-1-yi.zhang@huawei.com
commit 8418897f1bf87da0cb6936489d57a4320c32c0af upstream.
Don't pass error pointers to brelse().
commit 7159a986b420 ("ext4: fix some error pointer dereferences") has fixed
some cases, fix the remaining one case.
Once ext4_xattr_block_find()->ext4_sb_bread() failed, error pointer is
stored in @bs->bh, which will be passed to brelse() in the cleanup
routine of ext4_xattr_set_handle(). This will then cause a NULL panic
crash in __brelse().
BUG: unable to handle kernel NULL pointer dereference at 000000000000005b
RIP: 0010:__brelse+0x1b/0x50
Call Trace:
ext4_xattr_set_handle+0x163/0x5d0
ext4_xattr_set+0x95/0x110
__vfs_setxattr+0x6b/0x80
__vfs_setxattr_noperm+0x68/0x1b0
vfs_setxattr+0xa0/0xb0
setxattr+0x12c/0x1a0
path_setxattr+0x8d/0xc0
__x64_sys_setxattr+0x27/0x30
do_syscall_64+0x60/0x250
entry_SYSCALL_64_after_hwframe+0x49/0xbe
In this case, @bs->bh stores '-EIO' actually.
Fixes: fb265c9cb49e ("ext4: add ext4_sb_bread() to disambiguate ENOMEM cases")
Signed-off-by: Jeffle Xu <jefflexu@linux.alibaba.com>
Reviewed-by: Joseph Qi <joseph.qi@linux.alibaba.com>
Cc: stable@kernel.org # 2.6.19
Reviewed-by: Ritesh Harjani <riteshh@linux.ibm.com>
Link: https://lore.kernel.org/r/1587628004-95123-1-git-send-email-jefflexu@linux.alibaba.com
In other places in fs/ext4/xattr.c, if e_value_inum is non-zero, the
code ignores the value in e_value_offs. The e_value_offs *should* be
zero, but we shouldn't depend upon it, since it might not be true in a
corrupted/fuzzed file system.
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=202897
Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=202877
We can't pass error pointers to brelse().
If we receive a file handle, either from NFS or open_by_handle_at(2),
and it points at an inode which has not been initialized, and the file
system has metadata checksums enabled, we shouldn't try to get the
inode, discover the checksum is invalid, and then declare the file
system as being inconsistent.
This can be reproduced by creating a test file system via "mke2fs -t
ext4 -O metadata_csum /tmp/foo.img 8M", mounting it, cd'ing into that
directory, and then running the following program.
#define _GNU_SOURCE
#include <fcntl.h>
struct handle {
struct file_handle fh;
unsigned char fid[MAX_HANDLE_SZ];
int main(int argc, char **argv)
struct handle h = {{8, 1 }, { 12, }};
open_by_handle_at(AT_FDCWD, &h.fh, O_RDONLY);
return 0;
Google-Bug-Id: 120690101
In ext4_expand_extra_isize_ea(), we calculate the total size of the
xattr header, plus the xattr entries so we know how much of the
beginning part of the xattrs to move when expanding the inode extra
size. We need to include the terminating u32 at the end of the xattr
entries, or else if there is uninitialized, non-zero bytes after the
xattr entries and before the xattr values, the list of xattr entries
won't be properly terminated.
Reported-by: Steve Graham <stgraham2000@gmail.com>
Today, when sb_bread() returns NULL, this can either be because of an
I/O error or because the system failed to allocate the buffer. Since
it's an old interface, changing would require changing many call
sites.
So instead we create our own ext4_sb_bread(), which also allows us to
set the REQ_META flag.
Also fixed a problem in the xattr code where a NULL return in a
function could also mean that the xattr was not found, which could
lead to the wrong error getting returned to userspace.
Fixes: ac27a0ec112a ("ext4: initial copy of files from ext3")
According to Ted Ts'o ext4_getblk() called in ext4_xattr_inode_write()
should not return bh = NULL
The only time that bh could be NULL, then, would be in the case of
something really going wrong; a programming error elsewhere (perhaps a
wild pointer dereference) or I/O error causing on-disk file system
corruption (although that would be highly unlikely given that we had
*just* allocated the blocks and so the metadata blocks in question
probably would still be in the cache).
Fixes: e50e5129f384 ("ext4: xattr-in-inode support")
Signed-off-by: Vasily Averin <vvs@virtuozzo.com>
Cc: stable@kernel.org # 4.13
Fixes: de05ca852679 ("ext4: move call to ext4_error() into ...")
Cc: stable@kernel.org # 4.17
Fixes: 3f2571c1f91f ("ext4: factor out xattr moving")
Fixes: 6dd4ee7cab7e ("ext4: Expand extra_inodes space per ...")
Cc: stable@kernel.org # 2.6.23
bs.bh was taken in previous ext4_xattr_block_find() call,
it should be released before re-using
Fixes: 7e01c8e5420b ("ext3/4: fix uninitialized bs in ...")
Cc: stable@kernel.org # 2.6.26
Fixes: dec214d00e0d ("ext4: xattr inode deduplication")
Extended attribute names are defined to be NUL-terminated, so the name
must not contain a NUL character. This is important because there are
places when remove extended attribute, the code uses strlen to
determine the length of the entry. That should probably be fixed at
some point, but code is currently really messy, so the simplest fix
for now is to simply validate that the extended attributes are sane.
https://bugzilla.kernel.org/show_bug.cgi?id=200401
Reported-by: Wen Xu <wen.xu@gatech.edu>
Cc: stable@vger.kernel.org
Use a separate journal transaction if it turns out that we need to
convert an inline file to use an data block. Otherwise we could end
up failing due to not having journal credits.
This addresses CVE-2018-10883.
https://bugzilla.kernel.org/show_bug.cgi?id=200071
When expanding the extra isize space, we must never move the
system.data xattr out of the inode body. For performance reasons, it
doesn't make any sense, and the inline data implementation assumes
that system.data xattr is never in the external xattr block.
This addresses CVE-2018-10880
https://bugzilla.kernel.org/show_bug.cgi?id=200005
If there an inode points to a block which is also some other type of
metadata block (such as a block allocation bitmap), the
buffer_verified flag can be set when it was validated as that other
metadata block type; however, it would make a really terrible external
attribute block. The reason why we use the verified flag is to avoid
constantly reverifying the block. However, it doesn't take much
overhead to make sure the magic number of the xattr block is correct,
and this will avoid potential crashes.
This addresses CVE-2018-10879.
https://bugzilla.kernel.org/show_bug.cgi?id=200001
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
In theory this should have been caught earlier when the xattr list was
verified, but in case it got missed, it's simple enough to add check
to make sure we don't overrun the xattr buffer.
Ext4 will always create ext4 extended attributes which do not have a
value (where e_value_size is zero) with e_value_offs set to zero. In
most places e_value_offs will not be used in a substantive way if
e_value_size is zero.
There was one exception to this, which is in ext4_xattr_set_entry(),
where if there is a maliciously crafted file system where there is an
extended attribute with e_value_offs is non-zero and e_value_size is
0, the attempt to remove this xattr will result in a negative value
getting passed to memmove, leading to the following sadness:
[ 41.225365] EXT4-fs (loop0): mounted filesystem with ordered data mode. Opts: (null)
[ 44.538641] BUG: unable to handle kernel paging request at ffff9ec9a3000000
[ 44.538733] IP: __memmove+0x81/0x1a0
[ 44.538755] PGD 1249bd067 P4D 1249bd067 PUD 1249c1067 PMD 80000001230000e1
[ 44.538793] Oops: 0003 [#1] SMP PTI
[ 44.539074] CPU: 0 PID: 1470 Comm: poc Not tainted 4.16.0-rc1+ #1
[ 44.539475] Call Trace:
[ 44.539832] ext4_xattr_set_entry+0x9e7/0xf80
[ 44.539972] ext4_xattr_block_set+0x212/0xea0
[ 44.540041] ext4_xattr_set_handle+0x514/0x610
[ 44.540065] ext4_xattr_set+0x7f/0x120
[ 44.540090] __vfs_removexattr+0x4d/0x60
[ 44.540112] vfs_removexattr+0x75/0xe0
[ 44.540132] removexattr+0x4d/0x80
[ 44.540279] path_removexattr+0x91/0xb0
[ 44.540300] SyS_removexattr+0xf/0x20
[ 44.540322] do_syscall_64+0x71/0x120
[ 44.540344] entry_SYSCALL_64_after_hwframe+0x21/0x86
https://bugzilla.kernel.org/show_bug.cgi?id=199347
This addresses CVE-2018-10840.
Reported-by: "Xu, Wen" <wen.xu@gatech.edu>
Fixes: dec214d00e0d7 ("ext4: xattr inode deduplication")
Add explicit checks in ext4_xattr_block_get() just in case the
e_value_offs and e_value_size fields in the the xattr block are
corrupted in memory after the buffer_verified bit is set on the xattr
block.
Add some paranoia checks to make sure we don't stray beyond the end of
the valid memory region containing ext4 xattr entries while we are
scanning for a match.
Also rename the function to xattr_find_entry() since it is static and
thus only used in fs/ext4/xattr.c
Refactor the call to EXT4_ERROR_INODE() into ext4_xattr_check_block().
This simplifies the code, and fixes a problem where not all callers of
ext4_xattr_check_block() were not resulting in ext4_error() getting
called when the xattr block is corrupted.
ext4 isn't validating the sizes of xattrs where the value of the xattr
is stored in an external inode. This is problematic because
->e_value_size is a u32, but ext4_xattr_get() returns an int. A very
large size is misinterpreted as an error code, which ext4_get_acl()
translates into a bogus ERR_PTR() for which IS_ERR() returns false,
causing a crash.
Fix this by validating that all xattrs are <= INT_MAX bytes.
This issue has been assigned CVE-2018-1095.
https://bugzilla.kernel.org/show_bug.cgi?id=199185
https://bugzilla.redhat.com/show_bug.cgi?id=1560793
Signed-off-by: Jeff Layton <jlayton@redhat.com>
Acked-by: Theodore Ts'o <tytso@mit.edu>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Original Lustre ea_inode feature did not have ref counts on xattr inodes
because there was always one parent that referenced it. New
implementation expects ref count to be initialized which is not true for
Lustre case. Handle this by detecting Lustre created xattr inode and set
its ref count to 1.
The quota handling of xattr inodes have also changed with deduplication
support. New implementation manually manages quotas to support sharing
across multiple users. A consequence is that, a referencing inode
incorporates the blocks of xattr inode into its own i_block field.
We need to know how a xattr inode was created so that we can reverse the
block charges during reference removal. This is handled by introducing a
EXT4_STATE_LUSTRE_EA_INODE flag. The flag is set on a xattr inode if
inode appears to have been created by Lustre. During xattr inode reference
removal, the manual quota uncharge is skipped if the flag is set.
Signed-off-by: Tahsin Erdogan <tahsin@google.com>
When updating an extended attribute, if the padded value sizes are the
same, a shortcut is taken to avoid the bulk of the work. This was fine
until the xattr hash update was moved inside ext4_xattr_set_entry().
With that change, the hash update got missed in the shortcut case.
Thanks to ZhangYi (yizhang089@gmail.com) for root causing the problem.
Fixes: daf8328172df ("ext4: eliminate xattr entry e_hash recalculation for removes")
Reported-by: Miklos Szeredi <miklos@szeredi.hu>
Clean up some goto statement, make ext4_expand_extra_isize_ea() clearer.
Signed-off-by: Miao Xie <miaoxie@huawei.com>
Reviewed-by: Wang Shilong <wshilong@ddn.com>
Current ext4_expand_extra_isize just tries to expand extra isize, if
someone is holding xattr lock or some check fails, it will give up.
So rename its name to ext4_try_to_expand_extra_isize.
Besides that, we clean up unnecessary check and move some relative checks
into it.
We should avoid the contention between the i_extra_isize update and
the inline data insertion, so move the xattr trylock in front of
i_extra_isize update.
ext4_xattr_inode_read() currently reads each block sequentially while
waiting for io operation to complete before moving on to the next
block. This prevents request merging in block layer.
Add a ext4_bread_batch() function that starts reads for all blocks
then optionally waits for them to complete. A similar logic is used
in ext4_find_entry(), so update that code to use the new function.
When an xattr block has a single reference, block is updated inplace
and it is reinserted to the cache. Later, a cache lookup is performed
to see whether an existing block has the same contents. This cache
lookup will most of the time return the just inserted entry so
deduplication is not achieved.
Running the following test script will produce two xattr blocks which
can be observed in "File ACL: " line of debugfs output:
mke2fs -b 1024 -I 128 -F -O extent /dev/sdb 1G
mount /dev/sdb /mnt/sdb
touch /mnt/sdb/{x,y}
setfattr -n user.1 -v aaa /mnt/sdb/x
setfattr -n user.2 -v bbb /mnt/sdb/x
setfattr -n user.1 -v aaa /mnt/sdb/y
setfattr -n user.2 -v bbb /mnt/sdb/y
debugfs -R 'stat x' /dev/sdb | cat
debugfs -R 'stat y' /dev/sdb | cat
This patch defers the reinsertion to the cache so that we can locate
other blocks with the same contents.
For Lustre, if ea_inode fails in hash validation but passes parent
inode and generation checks, it won't be added to the cache as well
as the error "-EFSCORRUPTED" should be cleared, otherwise it will
cause "Structure needs cleaning" when running getfattr command.
Intel-bug-id: https://jira.hpdd.intel.com/browse/LU-9723
Fixes: dec214d00e0d78a08b947d7dccdfdb84407a9f4d
Signed-off-by: Emoly Liu <emoly.liu@intel.com>
Reviewed-by: tahsin@google.com
ea_inode feature allows creating extended attributes that are up to
64k in size. Update __ext4_new_inode() to pick increased credit limits.
To avoid overallocating too many journal credits, update
__ext4_xattr_set_credits() to make a distinction between xattr create
vs update. This helps __ext4_new_inode() because all attributes are
known to be new, so we can save credits that are normally needed to
delete old values.
Also, have fscrypt specify its maximum context size so that we don't
end up allocating credits for 64k size.
The main purpose of mb cache is to achieve deduplication in
extended attributes. In use cases where opportunity for deduplication
is unlikely, it only adds overhead.
Add a mount option to explicitly turn off mb cache.
Suggested-by: Andreas Dilger <adilger@dilger.ca>
To verify that a xattr entry is not pointing to the wrong xattr inode,
we currently check that the target inode has EXT4_EA_INODE_FL flag set and
also the entry size matches the target inode size.
For stronger validation, also incorporate crc32c hash of the value into
the e_hash field. This is done regardless of whether the entry lives in
the inode body or external attribute block.
When an extended attribute block is modified, ext4_xattr_hash_entry()
recalculates e_hash for the entry that is pointed by s->here. This is
unnecessary if the modification is to remove an entry.
Currently, if the removed entry is the last one and there are other
entries remaining, hash calculation targets the just erased entry which
has been filled with zeroes and effectively does nothing. If the removed
entry is not the last one and there are more entries, this time it will
recalculate hash on the next entry which is totally unnecessary.
Fix these by moving the decision on when to recalculate hash to
New ea_inode feature allows putting large xattr values into external
inodes. struct ext4_xattr_entry and the attribute name however have to
remain in the inode extra space or external attribute block. Once that
space is exhausted, no further entries can be added. Some of that space
could also be used by values that fit in there at the time of addition.
So, a single xattr entry whose value barely fits in the external block
could prevent further entries being added.
To mitigate the problem, this patch introduces a notion of reserved
space in the external attribute block that cannot be used by value data.
This reserve is enforced when ea_inode feature is enabled. The amount
of reserve is arbitrarily chosen to be min(block_size/8, 1024). The
table below shows how much space is reserved for each block size and the
guaranteed mininum number of entries that can be placed in the external
attribute block.
block size reserved bytes entries (name length = 16)
1k 128 3
2k 256 7
4k 512 15
8k 1024 31
16k 1024 31
32k 1024 31
64k 1024 31
Ext4 ea_inode feature allows storing xattr values in external inodes to
be able to store values that are bigger than a block in size. Ext4 also
has deduplication support for these type of inodes. With deduplication,
the actual storage waste is eliminated but the users of such inodes are
still charged full quota for the inodes as if there was no sharing
happening in the background.
This design requires ext4 to manually charge the users because the
inodes are shared.
An implication of this is that, if someone calls chown on a file that
has such references we need to transfer the quota for the file and xattr
inodes. Current dquot_transfer() function implicitly transfers one inode
charge. With ea_inode feature, we would like to transfer multiple inode
charges.
Add get_inode_usage callback which can interrogate the total number of
inodes that were charged for a given inode.
[ Applied fix from Colin King to make sure the 'ret' variable is
initialized on the successful return path. Detected by
CoverityScan, CID#1446616 ("Uninitialized scalar variable") --tytso]
Acked-by: Jan Kara <jack@suse.cz>
Ext4 now supports xattr values that are up to 64k in size (vfs limit).
Large xattr values are stored in external inodes each one holding a
single value. Once written the data blocks of these inodes are immutable.
The real world use cases are expected to have a lot of value duplication
such as inherited acls etc. To reduce data duplication on disk, this patch
implements a deduplicator that allows sharing of xattr inodes.
The deduplication is based on an in-memory hash lookup that is a best
effort sharing scheme. When a xattr inode is read from disk (i.e.
getxattr() call), its crc32c hash is added to a hash table. Before
creating a new xattr inode for a value being set, the hash table is
checked to see if an existing inode holds an identical value. If such an
inode is found, the ref count on that inode is incremented. On value
removal the ref count is decremented and if it reaches zero the inode is
deleted.
The quota charging for such inodes is manually managed. Every reference
holder is charged the full size as if there was no sharing happening.
This is consistent with how xattr blocks are also charged.
[ Fixed up journal credits calculation to handle inline data and the
rare case where an shared xattr block can get freed when two thread
race on breaking the xattr block sharing. --tytso ]
During inode deletion, the number of journal credits that will be
needed is hard to determine. For that reason we have journal
extend/restart calls in several places. Whenever a transaction is
restarted, filesystem must be in a consistent state because there is
no atomicity guarantee beyond a restart call.
Add ext4_xattr_ensure_credits() helper function which takes care of
journal extend/restart logic. It also handles getting jbd2 write
access and dirty metadata calls. This function is called at every
iteration of handling an ea_inode reference.
There will be a second mb_cache instance that tracks ea_inodes. Make
existing names more explicit so that it is clear that they refer to
xattr block cache.
Make names more generic so that mbcache usage is not limited to
block sharing. In a subsequent patch in the series
("ext4: xattr inode deduplication"), we start using the mbcache code
for sharing xattr inodes. With that patch, old mb_cache_entry.e_block
field could be holding either a block number or an inode number.
Tracking struct inode * rather than the inode number eliminates the
repeated ext4_xattr_inode_iget() call later. The second call cannot
fail in practice but still requires explanation when it wants to ignore
the return value. Avoid the trouble and make things simple.
Both ext4_set_acl() and ext4_set_context() need to be made aware of
ea_inode feature when it comes to credits calculation.
Also add a sufficient credits check in ext4_xattr_set_handle() right
after xattr write lock is grabbed. Original credits calculation is done
outside the lock so there is a possiblity that the initially calculated
credits are not sufficient anymore.
In a few places the function returns without trying to pass the actual
error code to the caller. Fix those.
When value size is <= EXT4_XATTR_MIN_LARGE_EA_SIZE(), and it
doesn't fit in either inline or xattr block, a second try is made to
store it in an external inode while storing the entry itself in inline
area. There should also be an attempt to store the entry in xattr block.
This patch adds a retry loop to do that. It also makes the caller the
sole decider on whether to store a value in an external inode.
When there is no space for a value in xattr block, it may be stored
in an xattr inode even if the value length is less than
EXT4_XATTR_MIN_LARGE_EA_SIZE(). So the current assumption in credits
calculation is wrong.
When a xattr entry refers to an external inode, the value data is not
available in the inline area so we should not attempt to read it using
value offset.
