commit 1b8f787ef547230a3249bcf897221ef0cc78481b upstream.
Syzkaller report issue as follows:
EXT4-fs (loop0): Free/Dirty block details
EXT4-fs (loop0): free_blocks=0
EXT4-fs (loop0): dirty_blocks=0
EXT4-fs (loop0): Block reservation details
EXT4-fs (loop0): i_reserved_data_blocks=0
EXT4-fs warning (device loop0): ext4_da_release_space:1527: ext4_da_release_space: ino 18, to_free 1 with only 0 reserved data blocks
WARNING: CPU: 0 PID: 92 at fs/ext4/inode.c:1528 ext4_da_release_space+0x25e/0x370 fs/ext4/inode.c:1524
Modules linked in:
CPU: 0 PID: 92 Comm: kworker/u4:4 Not tainted 6.0.0-syzkaller-09423-g493ffd6605b2 #0
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS Google 09/22/2022
Workqueue: writeback wb_workfn (flush-7:0)
RIP: 0010:ext4_da_release_space+0x25e/0x370 fs/ext4/inode.c:1528
RSP: 0018:ffffc900015f6c90 EFLAGS: 00010296
RAX: 42215896cd52ea00 RBX: 0000000000000000 RCX: 42215896cd52ea00
RDX: 0000000000000000 RSI: 0000000080000001 RDI: 0000000000000000
RBP: 1ffff1100e907d96 R08: ffffffff816aa79d R09: fffff520002bece5
R10: fffff520002bece5 R11: 1ffff920002bece4 R12: ffff888021fd2000
R13: ffff88807483ecb0 R14: 0000000000000001 R15: ffff88807483e740
FS: 0000000000000000(0000) GS:ffff8880b9a00000(0000) knlGS:0000000000000000
CR2: 00005555569ba628 CR3: 000000000c88e000 CR4: 00000000003506f0
DR3: 0000000000000000 DR6: 00000000fffe0ff0 DR7: 0000000000000400
Call Trace:
<TASK>
ext4_es_remove_extent+0x1ab/0x260 fs/ext4/extents_status.c:1461
mpage_release_unused_pages+0x24d/0xef0 fs/ext4/inode.c:1589
ext4_writepages+0x12eb/0x3be0 fs/ext4/inode.c:2852
do_writepages+0x3c3/0x680 mm/page-writeback.c:2469
__writeback_single_inode+0xd1/0x670 fs/fs-writeback.c:1587
writeback_sb_inodes+0xb3b/0x18f0 fs/fs-writeback.c:1870
wb_writeback+0x41f/0x7b0 fs/fs-writeback.c:2044
wb_do_writeback fs/fs-writeback.c:2187 [inline]
wb_workfn+0x3cb/0xef0 fs/fs-writeback.c:2227
process_one_work+0x877/0xdb0 kernel/workqueue.c:2289
worker_thread+0xb14/0x1330 kernel/workqueue.c:2436
kthread+0x266/0x300 kernel/kthread.c:376
ret_from_fork+0x1f/0x30 arch/x86/entry/entry_64.S:306
</TASK>
Above issue may happens as follows:
ext4_da_write_begin
ext4_create_inline_data
ext4_clear_inode_flag(inode, EXT4_INODE_EXTENTS);
ext4_set_inode_flag(inode, EXT4_INODE_INLINE_DATA);
__ext4_ioctl
ext4_ext_migrate -> will lead to eh->eh_entries not zero, and set extent flag
ext4_da_write_begin
ext4_da_convert_inline_data_to_extent
ext4_da_write_inline_data_begin
ext4_da_map_blocks
ext4_insert_delayed_block
if (!ext4_es_scan_clu(inode, &ext4_es_is_delonly, lblk))
if (!ext4_es_scan_clu(inode, &ext4_es_is_mapped, lblk))
ext4_clu_mapped(inode, EXT4_B2C(sbi, lblk)); -> will return 1
allocated = true;
ext4_es_insert_delayed_block(inode, lblk, allocated);
ext4_writepages
mpage_map_and_submit_extent(handle, &mpd, &give_up_on_write); -> return -ENOSPC
mpage_release_unused_pages(&mpd, give_up_on_write); -> give_up_on_write == 1
ext4_da_release_space(inode, reserved);
if (unlikely(to_free > ei->i_reserved_data_blocks))
-> to_free == 1 but ei->i_reserved_data_blocks == 0
-> then trigger warning as above
To solve above issue, forbid inode do migrate which has inline data.
Cc: stable@kernel.org
Reported-by: syzbot+c740bb18df70ad00952e@syzkaller.appspotmail.com
Signed-off-by: Ye Bin <yebin10@huawei.com>
Link: https://lore.kernel.org/r/20221018022701.683489-1-yebin10@huawei.com
Signed-off-by: Theodore Ts'o <tytso@mit.edu>
[ Upstream commit 07ea7a617d6b278fb7acedb5cbe1a81ce2de7d0c ]
When migrating to extents, the checksum seed of temporary inode
need to be replaced by inode's, otherwise the inode checksums
will be incorrect when swapping the inodes data.
However, the temporary inode can not match it's checksum to
itself since it has lost it's own checksum seed.
mkfs.ext4 -F /dev/sdc
mount /dev/sdc /mnt/sdc
xfs_io -fc "pwrite 4k 4k" -c "fsync" /mnt/sdc/testfile
chattr -e /mnt/sdc/testfile
chattr +e /mnt/sdc/testfile
umount /dev/sdc
fsck -fn /dev/sdc
Pass 1: Checking inodes, blocks, and sizes
Inode 13 passes checks, but checksum does not match inode. Fix? no
The fix is simple, save the checksum seed of temporary inode, and
recover it after migrating to extents.
Fixes: e81c9302a6c3 ("ext4: set csum seed in tmp inode while migrating to extents")
Signed-off-by: Li Lingfeng <lilingfeng3@huawei.com>
Link: https://lore.kernel.org/r/20220617062515.2113438-1-lilingfeng3@huawei.com
commit 6eeaf88fd586f05aaf1d48cb3a139d2a5c6eb055 upstream.
We probably want to remove the indirect block to extents migration
feature after a deprecation window, but until then, let's fix a
potential data loss problem caused by the fact that we put the
tmp_inode on the orphan list. In the unlikely case where we crash and
do a journal recovery, the data blocks belonging to the inode being
migrated are also represented in the tmp_inode on the orphan list ---
and so its data blocks will get marked unallocated, and available for
reuse.
Instead, stop putting the tmp_inode on the oprhan list. So in the
case where we crash while migrating the inode, we'll leak an inode,
which is not a disaster. It will be easily fixed the next time we run
fsck, and it's better than potentially having blocks getting claimed
by two different files, and losing data as a result.
Reviewed-by: Lukas Czerner <lczerner@redhat.com>
commit e81c9302a6c3c008f5c30beb73b38adb0170ff2d upstream.
When migrating to extents, the temporary inode will have it's own checksum
seed. This means that, when swapping the inodes data, the inode checksums
will be incorrect.
This can be fixed by recalculating the extents checksums again. Or simply
by copying the seed into the temporary inode.
Link: https://bugzilla.kernel.org/show_bug.cgi?id=213357
Reported-by: Jeroen van Wolffelaar <jeroen@wolffelaar.nl>
Signed-off-by: Luís Henriques <lhenriques@suse.de>
Link: https://lore.kernel.org/r/20211214175058.19511-1-lhenriques@suse.de
Signed-off-by: Bhaskar Chowdhury <unixbhaskar@gmail.com>
Link: https://lore.kernel.org/r/cover.1616840203.git.unixbhaskar@gmail.com
ext4_mark_inode_dirty() can fail for real reasons. Ignoring its return
value may lead ext4 to ignore real failures that would result in
corruption / crashes. Harden ext4_mark_inode_dirty error paths to fail
as soon as possible and return errors to the caller whenever
appropriate.
One of the possible scnearios when this bug could affected is that
while creating a new inode, its directory entry gets added
successfully but while writing the inode itself mark_inode_dirty
returns error which is ignored. This would result in inconsistency
that the directory entry points to a non-existent inode.
Ran gce-xfstests smoke tests and verified that there were no
regressions.
Signed-off-by: Harshad Shirwadkar <harshadshirwadkar@gmail.com>
Link: https://lore.kernel.org/r/20200427013438.219117-1-harshadshirwadkar@gmail.com
If EXT4_EXTENTS_FL is set on an inode while ext4_writepages() is running
on it, the following warning in ext4_add_complete_io() can be hit:
WARNING: CPU: 1 PID: 0 at fs/ext4/page-io.c:234 ext4_put_io_end_defer+0xf0/0x120
Here's a minimal reproducer (not 100% reliable) (root isn't required):
while true; do
sync
done &
while true; do
rm -f file
touch file
chattr -e file
echo X >> file
chattr +e file
done
The problem is that in ext4_writepages(), ext4_should_dioread_nolock()
(which only returns true on extent-based files) is checked once to set
the number of reserved journal credits, and also again later to select
the flags for ext4_map_blocks() and copy the reserved journal handle to
ext4_io_end::handle. But if EXT4_EXTENTS_FL is being concurrently set,
the first check can see dioread_nolock disabled while the later one can
see it enabled, causing the reserved handle to unexpectedly be NULL.
Since changing EXT4_EXTENTS_FL is uncommon, and there may be other races
related to doing so as well, fix this by synchronizing changing
EXT4_EXTENTS_FL with ext4_writepages() via the existing
s_writepages_rwsem (previously called s_journal_flag_rwsem).
This was originally reported by syzbot without a reproducer at
https://syzkaller.appspot.com/bug?extid=2202a584a00fffd19fbf,
but now that dioread_nolock is the default I also started seeing this
when running syzkaller locally.
Link: https://lore.kernel.org/r/20200219183047.47417-3-ebiggers@kernel.org
Reported-by: syzbot+2202a584a00fffd19fbf@syzkaller.appspotmail.com
Fixes: 6b523df4fb5a ("ext4: use transaction reservation for extent conversion in ext4_end_io")
So far we have reserved only relatively high fixed amount of revoke
credits for each transaction. We over-reserved by large amount for most
cases but when freeing large directories or files with data journalling,
the fixed amount is not enough. In fact the worst case estimate is
inconveniently large (maximum extent size) for freeing of one extent.
We fix this by doing proper estimate of the amount of blocks that need
to be revoked when removing blocks from the inode due to truncate or
hole punching and otherwise reserve just a small amount of revoke
credits for each transaction to accommodate freeing of xattrs block or
so.
Link: https://lore.kernel.org/r/20191105164437.32602-23-jack@suse.cz
Provide ext4_journal_ensure_credits_fn() function to ensure transaction
has given amount of credits and call helper function to prepare for
restarting a transaction. This allows to remove some boilerplate code
from various places, add proper error handling for the case where
transaction extension or restart fails, and reduces following changes
needed for proper revoke record reservation tracking.
Link: https://lore.kernel.org/r/20191105164437.32602-10-jack@suse.cz
There are several lines that are indented too far, clean these
up by removing the tabs.
Today, when sb_bread() returns NULL, this can either be because of an
I/O error or because the system failed to allocate the buffer. Since
it's an old interface, changing would require changing many call
sites.
So instead we create our own ext4_sb_bread(), which also allows us to
set the REQ_META flag.
Also fixed a problem in the xattr code where a NULL return in a
function could also mean that the xattr was not found, which could
lead to the wrong error getting returned to userspace.
Fixes: ac27a0ec112a ("ext4: initial copy of files from ext3")
Cc: stable@kernel.org # 2.6.19
A number of ext4 source files were skipped due because their copyright
permission statements didn't match the expected text used by the
automated conversion utilities. I've added SPDX tags for the rest.
While looking at some of these files, I've noticed that we have quite
a bit of variation on the licenses that were used --- in particular
some of the Red Hat licenses on the jbd2 files use a GPL2+ license,
and we have some files that have a LGPL-2.1 license (which was quite
surprising).
I've not attempted to do any license changes. Even if it is perfectly
legal to relicense to GPL 2.0-only for consistency's sake, that should
be done with ext4 developer community discussion.
We don't need acls on xattr inodes because they are not directly
accessible from user mode.
Besides lockdep complains about recursive locking of xattr_sem as seen
below.
[ INFO: possible recursive locking detected ]
4.11.0-rc8+ #402 Not tainted
python/1894 is trying to acquire lock:
(&ei->xattr_sem){++++..}, at: [<ffffffff804878a6>] ext4_xattr_get+0x66/0x270
but task is already holding lock:
(&ei->xattr_sem){++++..}, at: [<ffffffff80489500>] ext4_xattr_set_handle+0xa0/0x5d0
Possible unsafe locking scenario:
CPU0
lock(&ei->xattr_sem);
*** DEADLOCK ***
May be due to missing lock nesting notation
3 locks held by python/1894:
#0: (sb_writers#10){.+.+.+}, at: [<ffffffff803d829f>] mnt_want_write+0x1f/0x50
#1: (&sb->s_type->i_mutex_key#15){+.+...}, at: [<ffffffff803dda27>] vfs_setxattr+0x57/0xb0
#2: (&ei->xattr_sem){++++..}, at: [<ffffffff80489500>] ext4_xattr_set_handle+0xa0/0x5d0
stack backtrace:
CPU: 0 PID: 1894 Comm: python Not tainted 4.11.0-rc8+ #402
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
Call Trace:
dump_stack+0x67/0x99
__lock_acquire+0x5f3/0x1830
lock_acquire+0xb5/0x1d0
down_read+0x2f/0x60
ext4_get_acl+0x43/0x1e0
get_acl+0x72/0xf0
posix_acl_create+0x5e/0x170
ext4_init_acl+0x21/0xc0
__ext4_new_inode+0xffd/0x16b0
ext4_xattr_set_entry+0x5ea/0xb70
ext4_xattr_block_set+0x1b5/0x970
ext4_xattr_set_handle+0x351/0x5d0
ext4_xattr_set+0x124/0x180
ext4_xattr_user_set+0x34/0x40
__vfs_setxattr+0x66/0x80
__vfs_setxattr_noperm+0x69/0x1c0
vfs_setxattr+0xa2/0xb0
setxattr+0x129/0x160
path_setxattr+0x87/0xb0
SyS_setxattr+0xf/0x20
entry_SYSCALL_64_fastpath+0x18/0xad
Signed-off-by: Tahsin Erdogan <tahsin@google.com>
Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com>
Create separate predicate functions to test/set/clear feature flags,
thereby replacing the wordy old macros. Furthermore, clean out the
places where we open-coded feature tests.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Currently ext4_ind_migrate() doesn't correctly handle a file which
contains a hole at the beginning of the file. This caused the migration
to be done incorrectly, and then if there is a subsequent following
delayed allocation write to the "hole", this would reclaim the same data
blocks again and results in fs corruption.
# assmuing 4k block size ext4, with delalloc enabled
# skip the first block and write to the second block
xfs_io -fc "pwrite 4k 4k" -c "fsync" /mnt/ext4/testfile
# converting to indirect-mapped file, which would move the data blocks
# to the beginning of the file, but extent status cache still marks
# that region as a hole
chattr -e /mnt/ext4/testfile
# delayed allocation writes to the "hole", reclaim the same data block
# again, results in i_blocks corruption
xfs_io -c "pwrite 0 4k" /mnt/ext4/testfile
umount /mnt/ext4
e2fsck -nf /dev/sda6
Inode 53, i_blocks is 16, should be 8. Fix? no
Signed-off-by: Eryu Guan <guaneryu@gmail.com>
Cc: stable@vger.kernel.org
Currently the check in ext4_ind_migrate() is not enough before doing the
real conversion:
a) delayed allocated extents could bypass the check on eh->eh_entries
and eh->eh_depth
This can be demonstrated by this script
xfs_io -fc "pwrite 0 4k" -c "pwrite 8k 4k" /mnt/ext4/testfile
where testfile has two extents but still be converted to non-extent
based file format.
b) only extent length is checked but not the offset, which would result
in data lose (delalloc) or fs corruption (nodelalloc), because
non-extent based file only supports at most (12 + 2^10 + 2^20 + 2^30)
blocks
This can be demostrated by
xfs_io -fc "pwrite 5T 4k" /mnt/ext4/testfile
sync
If delalloc is enabled, dmesg prints
EXT4-fs warning (device dm-4): ext4_block_to_path:105: block 1342177280 > max in inode 53
EXT4-fs (dm-4): Delayed block allocation failed for inode 53 at logical offset 1342177280 with max blocks 1 with error 5
EXT4-fs (dm-4): This should not happen!! Data will be lost
If delalloc is disabled, e2fsck -nf shows corruption
Inode 53, i_size is 5497558142976, should be 4096. Fix? no
Fix the two issues by
a) forcing all delayed allocation blocks to be allocated before checking
eh->eh_depth and eh->eh_entries
b) limiting the last logical block of the extent is within direct map
that's the bulk of filesystem drivers dealing with inodes of their own
ext4_delete_inode() has been renamed for a long time, update
comments for this.
Signed-off-by: Wang Shilong <wshilong@ddn.com>
Make the function name less redundant.
Teach ext4_ext_drop_refs() to accept a NULL argument, much like
kfree(). This allows us to drop a lot of checks to make sure path is
non-NULL before calling ext4_ext_drop_refs().
Drop EXT4_EX_NOFREE_ON_ERR from ext4_ext_create_new_leaf(),
ext4_split_extent(), ext4_convert_unwritten_extents_endio().
This requires fixing all of their callers to potentially
ext4_ext_find_extent() to free the struct ext4_ext_path object in case
of an error, and there are interlocking dependencies all the way up to
ext4_ext_map_blocks(), ext4_swap_extents(), and
ext4_ext_remove_space().
Once this is done, we can drop the EXT4_EX_NOFREE_ON_ERR flag since it
is no longer necessary.
Each caller of ext4_ext_dirty must hold i_data_sem,
The only exception is migration code, let's make it convenient.
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com>
When we read in an extent tree leaf block from disk, arrange to have
all of its entries cached. In nearly all cases the in-memory
representation will be more compact than the on-disk representation in
the buffer cache, and it allows us to get the information without
having to traverse the extent tree for successive extents.
Reviewed-by: Zheng Liu <wenqing.lz@taobao.com>
With bigalloc feature enabled we do not support indirect addressing at all
so we have to prevent extent addressing to indirect addressing
conversion in this case. The problem has been introduced with the commit
"ext4: support simple conversion of extent-mapped inodes to use i_blocks"
Move ext4_ind_migrate() into migrate.c file since it makes much more
sense and ext4_ext_migrate() is there as well.
Also fix tiny style problem - add spaces around "=" in "i=0".
The migration ioctl creates a temporary inode. Since this inode is
never linked to a directory, we don't need to reserve journal credits
required for modifying the directory.
So we can better understand what bits of ext4 are responsible for
long-running jbd2 handles, use jbd2__journal_start() so we can pass
context information for logging purposes.
The recommended way for finding the longer-running handles is:
T=/sys/kernel/debug/tracing
EVENT=$T/events/jbd2/jbd2_handle_stats
echo "interval > 5" > $EVENT/filter
echo 1 > $EVENT/enable
./run-my-fs-benchmark
cat $T/trace > /tmp/problem-handles
This will list handles that were active for longer than 20ms. Having
longer-running handles is bad, because a commit started at the wrong
time could stall for those 20+ milliseconds, which could delay an
fsync() or an O_SYNC operation. Here is an example line from the
trace file describing a handle which lived on for 311 jiffies, or over
1.2 seconds:
postmark-2917 [000] .... 196.435786: jbd2_handle_stats: dev 254,32
tid 570 type 2 line_no 2541 interval 311 sync 0 requested_blocks 1
dirtied_blocks 0
Previously, ext4_extents.h was being included at the end of ext4.h,
which was bad for a number of reasons: (a) it was not being included
in the expected place, and (b) it caused the header to be included
multiple times. There were #ifdef's to prevent this from causing any
problems, but it still was unnecessary.
By moving the function declarations that were in ext4_extents.h to
ext4.h, which is standard practice for where the function declarations
for the rest of ext4.h can be found, we can remove ext4_extents.h from
being included in ext4.h at all, and then we can only include
ext4_extents.h where it is needed in ext4's source files.
It should be possible to move a few more things into ext4.h, and
further reduce the number of source files that need to #include
ext4_extents.h, but that's a cleanup for another day.
Reported-by: Sachin Kamat <sachin.kamat@linaro.org>
Reported-by: Wei Yongjun <weiyj.lk@gmail.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
"inode" is a valid pointer here. "tmp_inode" was intended.
Delete any instances of include module.h that were not strictly
required. In the case of ext2, the declaration of MODULE_LICENSE
etc. were in inode.c but the module_init/exit were in super.c, so
relocate the MODULE_LICENCE/AUTHOR block to super.c which makes it
consistent with ext3 and ext4 at the same time.
git://git.kernel.org/pub/scm/linux/kernel/git/hch/vfs-queue
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/hch/vfs-queue:
vfs: add d_prune dentry operation
vfs: protect i_nlink
filesystems: add set_nlink()
filesystems: add missing nlink wrappers
logfs: remove unnecessary nlink setting
ocfs2: remove unnecessary nlink setting
jfs: remove unnecessary nlink setting
hypfs: remove unnecessary nlink setting
vfs: ignore error on forced remount
readlinkat: ensure we return ENOENT for the empty pathname for normal lookups
vfs: fix dentry leak in simple_fill_super()
Replace direct i_nlink updates with the respective updater function
(inc_nlink, drop_nlink, clear_nlink, inode_dec_link_count).
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
The tmp_inode should have same uid/gid as the original inode.
Otherwise new metadata blocks will be accounted to wrong quota-id,
which will result in a quota leak after the inode migration is
completed.
This patch cleanup code a bit, actual logic not changed
- Move current block pointer to migrate_structure, let's all
walk info will be in one structure.
- Get rid of usless null ind-block ptr checks, caller already
does that check.
This patch adds some tracepoints in ext4/extents.c and updates a tracepoint in
ext4/inode.c.
Tested: Built and ran the kernel and verified that these tracepoints work.
Also ran xfstests.
Signed-off-by: Aditya Kali <adityakali@google.com>
Fix a typo that was introduced in commit 07a038245b (in 2.6.36) which
caused the extents flag not to be set at the conclusion of converting
an inode to use extents.
Reported-by: Peter Uchno <peter.uchno@gmail.com>
This patch fixes the warning "Using plain integer as NULL pointer",
generated by sparse, by replacing the offending 0s with NULL.
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
ext4_ext_migrate() calls ext4_new_inode() and passes 0 instead of a pointer
to a struct qstr. This patch uses NULL, to make it obvious to the caller
that this was a pointer.
Signed-off-by: Eric Paris <eparis@redhat.com>
Cleanup namespace leaks from fs/ext4 and the inline trivial functions
ext4_{ext,idx}_pblock() and ext4_{ext,idx}_store_pblock() since the
code size actually shrinks when we make these functions inline,
they're so trivial.
These changes are not ones which are likely to result in races, but
they should be fixed.
At several places we modify EXT4_I(inode)->i_flags without holding
i_mutex (ext4_do_update_inode, ...). These modifications are racy and
we can lose updates to i_flags. So convert handling of i_flags to use
bitops which are atomic.
https://bugzilla.kernel.org/show_bug.cgi?id=15792
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Set i_nlink to zero for temporary inode from very beginning.
otherwise we may fail to start new journal handle and this
inode will be unreferenced but with i_nlink == 1
Since we hold inode reference it can not be pruned.
Also add missed journal_start retval check.
At several places we modify EXT4_I(inode)->i_state without holding
i_mutex (ext4_release_file, ext4_bmap, ext4_journalled_writepage,
ext4_do_update_inode, ...). These modifications are racy and we can
lose updates to i_state. So convert handling of i_state to use bitops
which are atomic.
Cc: Jan Kara <jack@suse.cz>
Currently all quota block reservation macros contains hard-coded "2"
aka MAXQUOTAS value. This is no good because in some places it is not
obvious to understand what does this digit represent. Let's introduce
new macro with self descriptive name.
Acked-by: Mingming Cao <cmm@us.ibm.com>
