path: root/fs/ext4/mballoc.c
2010-04-25Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: Issue the discard operation *before* releasing the blocks to be reused ext4: Fix buffer head leaks after calls to ext4_get_inode_loc() ext4: Fix possible lost inode write in no journal mode
2010-04-20ext4: Issue the discard operation *before* releasing the blocks to be reusedTheodore Ts'o
Otherwise, we can end up having data corruption because the blocks could get reused and then discarded! https://bugzilla.kernel.org/show_bug.cgi?id=15579 Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-05Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (33 commits) quota: stop using QUOTA_OK / NO_QUOTA dquot: cleanup dquot initialize routine dquot: move dquot initialization responsibility into the filesystem dquot: cleanup dquot drop routine dquot: move dquot drop responsibility into the filesystem dquot: cleanup dquot transfer routine dquot: move dquot transfer responsibility into the filesystem dquot: cleanup inode allocation / freeing routines dquot: cleanup space allocation / freeing routines ext3: add writepage sanity checks ext3: Truncate allocated blocks if direct IO write fails to update i_size quota: Properly invalidate caches even for filesystems with blocksize < pagesize quota: generalize quota transfer interface quota: sb_quota state flags cleanup jbd: Delay discarding buffers in journal_unmap_buffer ext3: quota_write cross block boundary behaviour quota: drop permission checks from xfs_fs_set_xstate/xfs_fs_set_xquota quota: split out compat_sys_quotactl support from quota.c quota: split out netlink notification support from quota.c quota: remove invalid optimization from quota_sync_all ... Fixed trivial conflicts in fs/namei.c and fs/ufs/inode.c
2010-03-04ext4: fix up rb_root initializations to use RB_ROOTVenkatesh Pallipadi
ext4 uses rb_node = NULL; to zero rb_root at few places. Using RB_ROOT as the initializer is more portable in case the underlying implementation of rbtrees changes in the future. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Eric Paris <eparis@redhat.com>
2010-03-05dquot: cleanup space allocation / freeing routinesChristoph Hellwig
Get rid of the alloc_space, free_space, reserve_space, claim_space and release_rsv dquot operations - they are always called from the filesystem and if a filesystem really needs their own (which none currently does) it can just call into it's own routine directly. Move shared logic into the common __dquot_alloc_space, dquot_claim_space_nodirty and __dquot_free_space low-level methods, and rationalize the wrappers around it to move as much as possible code into the common block for CONFIG_QUOTA vs not. Also rename all these helpers to be named dquot_* instead of vfs_dq_*. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-03ext4: cleanup to use ext4_grp_offs_to_block()Akinobu Mita
More cleanup to convert open-coded calculations of the first block number of a free extent to use ext4_grp_offs_to_block() instead. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Andreas Dilger <adilger@sun.com>
2010-03-03ext4: cleanup to use ext4_group_first_block_no()Akinobu Mita
This is a cleanup and simplification patch which takes some open-coded calculations to calculate the first block number of a group and converts them to use the (already defined) ext4_group_first_block_no() function. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Andreas Dilger <adilger@sun.com>
2010-03-01ext4: Fix fencepost error in chosing choosing group vs file preallocation.Tao Ma
The ext4 multiblock allocator decides whether to use group or file preallocation based on the file size. When the file size reaches s_mb_stream_request (default is 16 blocks), it changes to use a file-specific preallocation. This is cool, but it has a tiny problem. See a simple script: mkfs.ext4 -b 1024 /dev/sda8 1000000 mount -t ext4 -o nodelalloc /dev/sda8 /mnt/ext4 for((i=0;i<5;i++)) do cat /mnt/4096>>/mnt/ext4/a #4096 is a file with 4096 characters. cat /mnt/4096>>/mnt/ext4/b done debuge4fs -R 'stat a' /dev/sda8|grep BLOCKS -A 1 And you get BLOCKS: (0-14):8705-8719, (15):2356, (16-19):8465-8468 So there are 3 extents, a bit strange for the lonely 15th logical block. As we write to the 16 blocks, we choose file preallocation in ext4_mb_group_or_file, but in ext4_mb_normalize_request, we meet with the 16*1024 range, so no preallocation will be carried. file b then reserves the space after '2356', so when when write 16, we start from another part. This patch just change the check in ext4_mb_group_or_file, so that for the lonely 15 we will still use group preallocation. After the patch, we will get: debuge4fs -R 'stat a' /dev/sda8|grep BLOCKS -A 1 BLOCKS: (0-15):8705-8720, (16-19):8465-8468 Looks more sane. Thanks. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-02-15ext4: move __func__ into a macro for ext4_warning, ext4_errorEric Sandeen
Just a pet peeve of mine; we had a mishash of calls with either __func__ or "function_name" and the latter tends to get out of sync. I think it's easier to just hide the __func__ in a macro, and it'll be consistent from then on. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-02-05tree-wide: fix 'lenght' typo in comments and codeDaniel Mack
Some misspelled occurences of 'octet' and some comments were also fixed as I was on it. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Jiri Kosina <trivial@kernel.org> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-23ext4: Fix potential quota deadlockDmitry Monakhov
We have to delay vfs_dq_claim_space() until allocation context destruction. Currently we have following call-trace: ext4_mb_new_blocks() /* task is already holding ac->alloc_semp */ ->ext4_mb_mark_diskspace_used ->vfs_dq_claim_space() /* acquire dqptr_sem here. Possible deadlock */ ->ext4_mb_release_context() /* drop ac->alloc_semp here */ Let's move quota claiming to ext4_da_update_reserve_space() ======================================================= [ INFO: possible circular locking dependency detected ] 2.6.32-rc7 #18 ------------------------------------------------------- write-truncate-/3465 is trying to acquire lock: (&s->s_dquot.dqptr_sem){++++..}, at: [<c025e73b>] dquot_claim_space+0x3b/0x1b0 but task is already holding lock: (&meta_group_info[i]->alloc_sem){++++..}, at: [<c02ce962>] ext4_mb_load_buddy+0xb2/0x370 which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #3 (&meta_group_info[i]->alloc_sem){++++..}: [<c017d04b>] __lock_acquire+0xd7b/0x1260 [<c017d5ea>] lock_acquire+0xba/0xd0 [<c0527191>] down_read+0x51/0x90 [<c02ce962>] ext4_mb_load_buddy+0xb2/0x370 [<c02d0c1c>] ext4_mb_free_blocks+0x46c/0x870 [<c029c9d3>] ext4_free_blocks+0x73/0x130 [<c02c8cfc>] ext4_ext_truncate+0x76c/0x8d0 [<c02a8087>] ext4_truncate+0x187/0x5e0 [<c01e0f7b>] vmtruncate+0x6b/0x70 [<c022ec02>] inode_setattr+0x62/0x190 [<c02a2d7a>] ext4_setattr+0x25a/0x370 [<c022ee81>] notify_change+0x151/0x340 [<c021349d>] do_truncate+0x6d/0xa0 [<c0221034>] may_open+0x1d4/0x200 [<c022412b>] do_filp_open+0x1eb/0x910 [<c021244d>] do_sys_open+0x6d/0x140 [<c021258e>] sys_open+0x2e/0x40 [<c0103100>] sysenter_do_call+0x12/0x32 -> #2 (&ei->i_data_sem){++++..}: [<c017d04b>] __lock_acquire+0xd7b/0x1260 [<c017d5ea>] lock_acquire+0xba/0xd0 [<c0527191>] down_read+0x51/0x90 [<c02a5787>] ext4_get_blocks+0x47/0x450 [<c02a74c1>] ext4_getblk+0x61/0x1d0 [<c02a7a7f>] ext4_bread+0x1f/0xa0 [<c02bcddc>] ext4_quota_write+0x12c/0x310 [<c0262d23>] qtree_write_dquot+0x93/0x120 [<c0261708>] v2_write_dquot+0x28/0x30 [<c025d3fb>] dquot_commit+0xab/0xf0 [<c02be977>] ext4_write_dquot+0x77/0x90 [<c02be9bf>] ext4_mark_dquot_dirty+0x2f/0x50 [<c025e321>] dquot_alloc_inode+0x101/0x180 [<c029fec2>] ext4_new_inode+0x602/0xf00 [<c02ad789>] ext4_create+0x89/0x150 [<c0221ff2>] vfs_create+0xa2/0xc0 [<c02246e7>] do_filp_open+0x7a7/0x910 [<c021244d>] do_sys_open+0x6d/0x140 [<c021258e>] sys_open+0x2e/0x40 [<c0103100>] sysenter_do_call+0x12/0x32 -> #1 (&sb->s_type->i_mutex_key#7/4){+.+...}: [<c017d04b>] __lock_acquire+0xd7b/0x1260 [<c017d5ea>] lock_acquire+0xba/0xd0 [<c0526505>] mutex_lock_nested+0x65/0x2d0 [<c0260c9d>] vfs_load_quota_inode+0x4bd/0x5a0 [<c02610af>] vfs_quota_on_path+0x5f/0x70 [<c02bc812>] ext4_quota_on+0x112/0x190 [<c026345a>] sys_quotactl+0x44a/0x8a0 [<c0103100>] sysenter_do_call+0x12/0x32 -> #0 (&s->s_dquot.dqptr_sem){++++..}: [<c017d361>] __lock_acquire+0x1091/0x1260 [<c017d5ea>] lock_acquire+0xba/0xd0 [<c0527191>] down_read+0x51/0x90 [<c025e73b>] dquot_claim_space+0x3b/0x1b0 [<c02cb95f>] ext4_mb_mark_diskspace_used+0x36f/0x380 [<c02d210a>] ext4_mb_new_blocks+0x34a/0x530 [<c02c83fb>] ext4_ext_get_blocks+0x122b/0x13c0 [<c02a5966>] ext4_get_blocks+0x226/0x450 [<c02a5ff3>] mpage_da_map_blocks+0xc3/0xaa0 [<c02a6ed6>] ext4_da_writepages+0x506/0x790 [<c01de272>] do_writepages+0x22/0x50 [<c01d766d>] __filemap_fdatawrite_range+0x6d/0x80 [<c01d7b9b>] filemap_flush+0x2b/0x30 [<c02a40ac>] ext4_alloc_da_blocks+0x5c/0x60 [<c029e595>] ext4_release_file+0x75/0xb0 [<c0216b59>] __fput+0xf9/0x210 [<c0216c97>] fput+0x27/0x30 [<c02122dc>] filp_close+0x4c/0x80 [<c014510e>] put_files_struct+0x6e/0xd0 [<c01451b7>] exit_files+0x47/0x60 [<c0146a24>] do_exit+0x144/0x710 [<c0147028>] do_group_exit+0x38/0xa0 [<c0159abc>] get_signal_to_deliver+0x2ac/0x410 [<c0102849>] do_notify_resume+0xb9/0x890 [<c01032d2>] work_notifysig+0x13/0x21 other info that might help us debug this: 3 locks held by write-truncate-/3465: #0: (jbd2_handle){+.+...}, at: [<c02e1f8f>] start_this_handle+0x38f/0x5c0 #1: (&ei->i_data_sem){++++..}, at: [<c02a57f6>] ext4_get_blocks+0xb6/0x450 #2: (&meta_group_info[i]->alloc_sem){++++..}, at: [<c02ce962>] ext4_mb_load_buddy+0xb2/0x370 stack backtrace: Pid: 3465, comm: write-truncate- Not tainted 2.6.32-rc7 #18 Call Trace: [<c0524cb3>] ? printk+0x1d/0x22 [<c017ac9a>] print_circular_bug+0xca/0xd0 [<c017d361>] __lock_acquire+0x1091/0x1260 [<c016bca2>] ? sched_clock_local+0xd2/0x170 [<c0178fd0>] ? trace_hardirqs_off_caller+0x20/0xd0 [<c017d5ea>] lock_acquire+0xba/0xd0 [<c025e73b>] ? dquot_claim_space+0x3b/0x1b0 [<c0527191>] down_read+0x51/0x90 [<c025e73b>] ? dquot_claim_space+0x3b/0x1b0 [<c025e73b>] dquot_claim_space+0x3b/0x1b0 [<c02cb95f>] ext4_mb_mark_diskspace_used+0x36f/0x380 [<c02d210a>] ext4_mb_new_blocks+0x34a/0x530 [<c02c601d>] ? ext4_ext_find_extent+0x25d/0x280 [<c02c83fb>] ext4_ext_get_blocks+0x122b/0x13c0 [<c016bca2>] ? sched_clock_local+0xd2/0x170 [<c016be60>] ? sched_clock_cpu+0x120/0x160 [<c016beef>] ? cpu_clock+0x4f/0x60 [<c0178fd0>] ? trace_hardirqs_off_caller+0x20/0xd0 [<c052712c>] ? down_write+0x8c/0xa0 [<c02a5966>] ext4_get_blocks+0x226/0x450 [<c016be60>] ? sched_clock_cpu+0x120/0x160 [<c016beef>] ? cpu_clock+0x4f/0x60 [<c017908b>] ? trace_hardirqs_off+0xb/0x10 [<c02a5ff3>] mpage_da_map_blocks+0xc3/0xaa0 [<c01d69cc>] ? find_get_pages_tag+0x16c/0x180 [<c01d6860>] ? find_get_pages_tag+0x0/0x180 [<c02a73bd>] ? __mpage_da_writepage+0x16d/0x1a0 [<c01dfc4e>] ? pagevec_lookup_tag+0x2e/0x40 [<c01ddf1b>] ? write_cache_pages+0xdb/0x3d0 [<c02a7250>] ? __mpage_da_writepage+0x0/0x1a0 [<c02a6ed6>] ext4_da_writepages+0x506/0x790 [<c016beef>] ? cpu_clock+0x4f/0x60 [<c016bca2>] ? sched_clock_local+0xd2/0x170 [<c016be60>] ? sched_clock_cpu+0x120/0x160 [<c016be60>] ? sched_clock_cpu+0x120/0x160 [<c02a69d0>] ? ext4_da_writepages+0x0/0x790 [<c01de272>] do_writepages+0x22/0x50 [<c01d766d>] __filemap_fdatawrite_range+0x6d/0x80 [<c01d7b9b>] filemap_flush+0x2b/0x30 [<c02a40ac>] ext4_alloc_da_blocks+0x5c/0x60 [<c029e595>] ext4_release_file+0x75/0xb0 [<c0216b59>] __fput+0xf9/0x210 [<c0216c97>] fput+0x27/0x30 [<c02122dc>] filp_close+0x4c/0x80 [<c014510e>] put_files_struct+0x6e/0xd0 [<c01451b7>] exit_files+0x47/0x60 [<c0146a24>] do_exit+0x144/0x710 [<c017b163>] ? lock_release_holdtime+0x33/0x210 [<c0528137>] ? _spin_unlock_irq+0x27/0x30 [<c0147028>] do_group_exit+0x38/0xa0 [<c017babb>] ? trace_hardirqs_on+0xb/0x10 [<c0159abc>] get_signal_to_deliver+0x2ac/0x410 [<c0102849>] do_notify_resume+0xb9/0x890 [<c0178fd0>] ? trace_hardirqs_off_caller+0x20/0xd0 [<c017b163>] ? lock_release_holdtime+0x33/0x210 [<c0165b50>] ? autoremove_wake_function+0x0/0x50 [<c017ba54>] ? trace_hardirqs_on_caller+0x134/0x190 [<c017babb>] ? trace_hardirqs_on+0xb/0x10 [<c0300ba4>] ? security_file_permission+0x14/0x20 [<c0215761>] ? vfs_write+0x131/0x190 [<c0214f50>] ? do_sync_write+0x0/0x120 [<c0103115>] ? sysenter_do_call+0x27/0x32 [<c01032d2>] work_notifysig+0x13/0x21 CC: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (34 commits) m68k: rename global variable vmalloc_end to m68k_vmalloc_end percpu: add missing per_cpu_ptr_to_phys() definition for UP percpu: Fix kdump failure if booted with percpu_alloc=page percpu: make misc percpu symbols unique percpu: make percpu symbols in ia64 unique percpu: make percpu symbols in powerpc unique percpu: make percpu symbols in x86 unique percpu: make percpu symbols in xen unique percpu: make percpu symbols in cpufreq unique percpu: make percpu symbols in oprofile unique percpu: make percpu symbols in tracer unique percpu: make percpu symbols under kernel/ and mm/ unique percpu: remove some sparse warnings percpu: make alloc_percpu() handle array types vmalloc: fix use of non-existent percpu variable in put_cpu_var() this_cpu: Use this_cpu_xx in trace_functions_graph.c this_cpu: Use this_cpu_xx for ftrace this_cpu: Use this_cpu_xx in nmi handling this_cpu: Use this_cpu operations in RCU this_cpu: Use this_cpu ops for VM statistics ... Fix up trivial (famous last words) global per-cpu naming conflicts in arch/x86/kvm/svm.c mm/slab.c
2009-12-10Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (47 commits) ext4: Fix potential fiemap deadlock (mmap_sem vs. i_data_sem) ext4: Do not override ext2 or ext3 if built they are built as modules jbd2: Export jbd2_log_start_commit to fix ext4 build ext4: Fix insufficient checks in EXT4_IOC_MOVE_EXT ext4: Wait for proper transaction commit on fsync ext4: fix incorrect block reservation on quota transfer. ext4: quota macros cleanup ext4: ext4_get_reserved_space() must return bytes instead of blocks ext4: remove blocks from inode prealloc list on failure ext4: wait for log to commit when umounting ext4: Avoid data / filesystem corruption when write fails to copy data ext4: Use ext4 file system driver for ext2/ext3 file system mounts ext4: Return the PTR_ERR of the correct pointer in setup_new_group_blocks() jbd2: Add ENOMEM checking in and for jbd2_journal_write_metadata_buffer() ext4: remove unused parameter wbc from __ext4_journalled_writepage() ext4: remove encountered_congestion trace ext4: move_extent_per_page() cleanup ext4: initialize moved_len before calling ext4_move_extents() ext4: Fix double-free of blocks with EXT4_IOC_MOVE_EXT ext4: use ext4_data_block_valid() in ext4_free_blocks() ...
2010-01-22ext4: Add block validity check when truncating indirect block mapped inodesTheodore Ts'o
Add checks to ext4_free_branches() to make sure a block number found in an indirect block are valid before trying to free it. If a bad block number is found, stop freeing the indirect block immediately, since the file system is corrupt and we will need to run fsck anyway. This also avoids spamming the logs, and specifically avoids driver-level "attempt to access beyond end of device" errors obscure what is really going on. If you get *really*, *really*, *really* unlucky, without this patch, a supposed indirect block containing garbage might contain a reference to a primary block group descriptor, in which case ext4_free_branches() could end up zero'ing out a block group descriptor block, and if then one of the block bitmaps for a block group described by that bg descriptor block is not in memory, and is read in by ext4_read_block_bitmap(). This function calls ext4_valid_block_bitmap(), which assumes that bg_inode_table() was validated at mount time and hasn't been modified since. Since this assumption is no longer valid, it's possible for the value (ext4_inode_table(sb, desc) - group_first_block) to go negative, which will cause ext4_find_next_zero_bit() to trigger a kernel GPF. Addresses-Google-Bug: #2220436 Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-12-08ext4: remove blocks from inode prealloc list on failureCurt Wohlgemuth
This fixes a leak of blocks in an inode prealloc list if device failures cause ext4_mb_mark_diskspace_used() to fail. Signed-off-by: Curt Wohlgemuth <curtw@google.com> Acked-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-22ext4: use ext4_data_block_valid() in ext4_free_blocks()Theodore Ts'o
The block validity framework does a more comprehensive set of checks, and it saves object code space to use the ext4_data_block_valid() than the limited open-coded version that had been in ext4_free_blocks(). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-11-23ext4: call ext4_forget() from ext4_free_blocks()Theodore Ts'o
Add the facility for ext4_forget() to be called from ext4_free_blocks(). This simplifies the code in a large number of places, and centralizes most of the work of calling ext4_forget() into a single place. Also fix a bug in the extents migration code; it wasn't calling ext4_forget() when releasing the indirect blocks during the conversion. As a result, if the system cashed during or shortly after the extents migration, and the released indirect blocks get reused as data blocks, the journal replay would corrupt the data blocks. With this new patch, fixing this bug was as simple as adding the EXT4_FREE_BLOCKS_FORGET flags to the call to ext4_free_blocks(). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
2009-11-22ext4: fold ext4_free_blocks() and ext4_mb_free_blocks()Theodore Ts'o
ext4_mb_free_blocks() is only called by ext4_free_blocks(), and the latter function doesn't really do much. So merge the two functions together, such that ext4_free_blocks() is now found in fs/ext4/mballoc.c. This saves about 200 bytes of compiled text space. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-11-19ext4: make trim/discard optional (and off by default)Eric Sandeen
It is anticipated that when sb_issue_discard starts doing real work on trim-capable devices, we may see issues. Make this mount-time optional, and default it to off until we know that things are working out OK. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-10-03this_cpu: Straight transformationsChristoph Lameter
Use this_cpu_ptr and __this_cpu_ptr in locations where straight transformations are possible because per_cpu_ptr is used with either smp_processor_id() or raw_smp_processor_id(). cc: David Howells <dhowells@redhat.com> Acked-by: Tejun Heo <tj@kernel.org> cc: Ingo Molnar <mingo@elte.hu> cc: Rusty Russell <rusty@rustcorp.com.au> cc: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Tejun Heo <tj@kernel.org>
2009-09-30ext4: Use tracepoints for mb_history trace fileTheodore Ts'o
The /proc/fs/ext4/<dev>/mb_history was maintained manually, and had a number of problems: it required a largish amount of memory to be allocated for each ext4 filesystem, and the s_mb_history_lock introduced a CPU contention problem. By ripping out the mb_history code and replacing it with ftrace tracepoints, and we get more functionality: timestamps, event filtering, the ability to correlate mballoc history with other ext4 tracepoints, etc. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-09-29ext4, jbd2: Drop unneeded printks at mount and unmount timeTheodore Ts'o
There are a number of kernel printk's which are printed when an ext4 filesystem is mounted and unmounted. Disable them to economize space in the system logs. In addition, disabling the mballoc stats by default saves a number of unneeded atomic operations for every block allocation or deallocation. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-09-28ext4: Fix hueristic which avoids group preallocation for closed filesTheodore Ts'o
The hueristic was designed to avoid using locality group preallocation when writing the last segment of a closed file. Fix it by move setting size to the maximum of size and isize until after we check whether size == isize. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-09-16ext4: limit block allocations for indirect-block files to < 2^32Eric Sandeen
Today, the ext4 allocator will happily allocate blocks past 2^32 for indirect-block files, which results in the block numbers getting truncated, and corruption ensues. This patch limits such allocations to < 2^32, and adds BUG_ONs if we do get blocks larger than that. This should address RH Bug 519471, ext4 bitmap allocator must limit blocks to < 2^32 * ext4_find_goal() is modified to choose a goal < UINT_MAX, so that our starting point is in an acceptable range. * ext4_xattr_block_set() is modified such that the goal block is < UINT_MAX, as above. * ext4_mb_regular_allocator() is modified so that the group search does not continue into groups which are too high * ext4_mb_use_preallocated() has a check that we don't use preallocated space which is too far out * ext4_alloc_blocks() and ext4_xattr_block_set() add some BUG_ONs No attempt has been made to limit inode locations to < 2^32, so we may wind up with blocks far from their inodes. Doing this much already will lead to some odd ENOSPC issues when the "lower 32" gets full, and further restricting inodes could make that even weirder. For high inodes, choosing a goal of the original, % UINT_MAX, may be a bit odd, but then we're in an odd situation anyway, and I don't know of a better heuristic. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-09-09ext4: Clarify the locking details in mballocAneesh Kumar K.V
We don't need to take the alloc_sem lock when we are adding new groups, since mballoc won't see the new group added until we bump sbi->s_groups_count. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2009-09-09ext4: check for need init flag in ext4_mb_load_buddyAneesh Kumar K.V
We should check for need init flag with the group's alloc_sem held, to make sure while we are loading the buddy cache and holding a reference to it, a file system resize can't add new blocks to same group. The patch also drops the need init flag check in ext4_mb_regular_allocator() because doing the check without holding alloc_sem is racy. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2009-09-09ext4: move ext4_mb_init_group() function earlier in the mballoc.cAneesh Kumar K.V
This moves the function around so that it can be called from ext4_mb_load_buddy(). Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-09-05ext4: Declare seq_operations and file_operations structures as constTobias Klauser
Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-08-25ext4: use ext4_grpblk_t more extensivelyEric Sandeen
unsigned short is potentially too small to track blocks within a group; today it is safe due to restrictions in e2fsprogs but we have _lo / _hi bits for group blocks with the intent to go up to 32 bits, so clean this up now. There are many more places where we use unsigned/int/unsigned int to contain a group block but this should at least fix all the short types. I added a few comments to the struct ext4_group_info definition as well. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-08-25ext4: use variables not types in sizeofs() for allocationsEric Sandeen
Precursor to changing some types; to keep things in sync, it seems better to allocate/memset based on the size of the variables we are using rather than on some disconnected basic type like "unsigned short" Signed-off-by: Eric Sandeen <sandeen@redhat.com>
2009-08-17simplify some logic in ext4_mb_normalize_requestEric Sandeen
While reading through some of the mballoc code it seems that a couple spots in the size normalization function could be streamlined. The test for non-overlapping PAs can be or'd for the start & end conditions, and the tests for adjacent PAs can be else-if'd - it's essentially independently testing: if (A + B <= C) ... if (A > C) ... These cannot both be true so it seems like the else-if might be slightly more efficient and/or informative. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-08-17ext4: open-code ext4_mb_update_group_infoEric Sandeen
ext4_mb_update_group_info is only called in one place, and it's extremely simple. There's no reason to have it in a separate function in a separate file as far as I can tell, it just obfuscates what's really going on. Perhaps it was intended to keep the grp->bb_* manipulation local to mballoc.c but we're already accessing other grp-> fields in balloc.c directly so this seems ok. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-09-18ext4: Avoid group preallocation for closed filesTheodore Ts'o
Currently the group preallocation code tries to find a large (512) free block from which to do per-cpu group allocation for small files. The problem with this scheme is that it leaves the filesystem horribly fragmented. In the worst case, if the filesystem is unmounted and remounted (after a system shutdown, for example) we forget the fact that wee were using a particular (now-partially filled) 512 block extent. So the next time we try to allocate space for a small file, we will find *another* completely free 512 block chunk to allocate small files. Given that there are 32,768 blocks in a block group, after 64 iterations of "mount, write one 4k file in a directory, unmount", the block group will have 64 files, each separated by 511 blocks, and the block group will no longer have any free 512 completely free chunks of blocks for group preallocation space. So if we try to allocate blocks for a file that has been closed, such that we know the final size of the file, and the filesystem is not busy, avoid using group preallocation. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-08-09ext4: Fix bugs in mballoc's stream allocation modeTheodore Ts'o
The logic around sbi->s_mb_last_group and sbi->s_mb_last_start was all screwed up. These fields were getting unconditionally all the time, set even when stream allocation had not taken place, and if they were being used when the file was smaller than s_mb_stream_request, which is when the allocation should _not_ be doing stream allocation. Fix this by determining whether or not we stream allocation should take place once, in ext4_mb_group_or_file(), and setting a flag which gets used in ext4_mb_regular_allocator() and ext4_mb_use_best_found(). This simplifies the code and assures that we are consistently using (or not using) the stream allocation logic. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-08-09ext4: Display the mballoc flags in mb_history in hex instead of decimalTheodore Ts'o
Displaying the flags in base 16 makes it easier to see which flags have been set. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-09-18ext4: Add configurable run-time mballoc debuggingTheodore Ts'o
Allow mballoc debugging to be enabled at run-time instead of just at compile time. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-07-05ext4: Fix compile warnings with MB_DEBUGAkira Fujita
When MB_DEBUG is enabled, we get some compile warnings because ext4_group_t is unsigned int. This patch fixes them. Signed-off-by Akira Fujita <a-fujita@rs.jp.nec.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-07-05ext4: Remove unnecessary semicolons in mballoc.cJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-07-17ext4: Fix memory leak fix when mounting an ext4 filesystemAneesh Kumar K.V
The allocation of the ext4_group_info array was moved to a new function ext4_mb_add_group_info() in commit 5f21b0e6 so that online resize would use a common (and correct) codepath. Unfortunately, the call to the new ext4_mb_add_group_info() function was added without removing the code which originally allocated the array. This caused a memory leak each time an ext4 filesystem was mounted. The fix is simple; remove the code that did the original allocation, since it is no longer needed. Reported-by: Catalin Marinas <catalin.marinas@arm.com> Tested-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-07-13ext4: Fix ext4_mb_initialize_context() to initialize all fieldsTheodore Ts'o
Pavel Roskin pointed out that kmemcheck indicated that ext4_mb_store_history() was accessing uninitialized values of ac->ac_tail and ac->ac_buddy leading to garbage in the mballoc history. Fix this by initializing the entire structure to all zeros first. Also, two fields were getting doubly initialized by the caller of ext4_mb_initialize_context, so remove them for efficiency's sake. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-07-05ext4: Use rcu_barrier() on module unload.Jesper Dangaard Brouer
The ext4 module uses rcu_call() thus it should use rcu_barrier()on module unload. The kmem cache ext4_pspace_cachep is sometimes free'ed using call_rcu() callbacks. Thus, we must wait for completion of call_rcu() before doing kmem_cache_destroy(). Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-07-05ext4: mark several more functions in mballoc.c as noinlineEric Sandeen
Ted noticed a stack-deep callchain through writepages->ext4_mb_regular_allocator->ext4_mb_init_cache->submit_bh ... With all the static functions in mballoc.c, gcc helpfully inlines for us, and we get something like this: ext4_mb_regular_allocator (232 bytes stack) ext4_mb_init_cache (232 bytes stack) submit_bh (starts 464 deeper) the 2 ext4 functions here get several others inlined; by telling gcc not to inline them, we can save stack space for when we head off into submit_bh land and associated block layer callchains. The following noinlined functions are only called once, so this won't impact any other callchains: ext4_mb_regular_allocator (104) (was 232) ext4_mb_find_by_goal (56) (noinlined) ext4_mb_init_group (24) (noinlined) ext4_mb_init_cache (136) (was 232) ext4_mb_generate_buddy (88) (noinlined) ext4_mb_generate_from_pa (40) (noinlined) submit_bh ext4_mb_simple_scan_group (24) (noinlined) ext4_mb_scan_aligned (56) (noinlined) ext4_mb_complex_scan_group (40) (noinlined) ext4_mb_try_best_found (24) (noinlined) now when we head off into submit_bh() we're only 264 bytes deeper in stack than when we entered ext4_mb_regular_allocator() (vs. 464 bytes before). Every 200 bytes helps. :) Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-06-15ext4: Fix 64-bit block type problem on 32-bit platformsTheodore Ts'o
The function ext4_mb_free_blocks() was using an "unsigned long" to pass a block number; this will cause 64-bit block numbers to get truncated on x86 and other 32-bit platforms. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Eric Sandeen <sandeen@redhat.com>
2009-06-17ext4: convert instrumentation from markers to tracepointsTheodore Ts'o
2009-05-17ext4: Add a comprehensive block validity check to ext4_get_blocks()Theodore Ts'o
To catch filesystem bugs or corruption which could lead to the filesystem getting severly damaged, this patch adds a facility for tracking all of the filesystem metadata blocks by contiguous regions in a red-black tree. This allows quick searching of the tree to locate extents which might overlap with filesystem metadata blocks. This facility is also used by the multi-block allocator to assure that it is not allocating blocks out of the system zone, as well as by the routines used when reading indirect blocks and extents information from disk to make sure their contents are valid. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-05-15ext4: Fix spinlock assertions on UP systemsVincent Minet
On UP systems without DEBUG_SPINLOCK, ext4_is_group_locked always fails which triggers a BUG_ON() call. This patch fixes it by using assert_spin_locked instead. Signed-off-by: Vincent Minet <vincent@vincent-minet.net> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-05-02ext4: Convert ext4_lock_group to use sb_bgl_lockAneesh Kumar K.V
We have sb_bgl_lock() and ext4_group_info.bb_state bit spinlock to protech group information. The later is only used within mballoc code. Consolidate them to use sb_bgl_lock(). This makes the mballoc.c code much simpler and also avoid confusion with two locks protecting same info. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
