path: root/fs/ext4/ialloc.c
2009-04-22ext4: Fix potential inode allocation soft lockup in Orlov allocatorTheodore Ts'o
If the Orlov allocator is having trouble finding an appropriate block group, the fallback code could loop forever, causing a soft lockup warning in find_group_orlov(): BUG: soft lockup - CPU#0 stuck for 61s! [cp:11728] ... Pid: 11728, comm: cp Not tainted (2.6.30-rc1-dirty #77) Lenovo EIP: 0060:[<c021650e>] EFLAGS: 00000246 CPU: 0 EIP is at ext4_get_group_desc+0x54/0x9d ... Call Trace: [<c0218021>] find_group_orlov+0x2ee/0x334 [<c0120a5f>] ? sched_clock+0x8/0xb [<c02188e3>] ext4_new_inode+0x2cf/0xb1a Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-04-14ext4: really print the find_group_flex fallback warning only onceChuck Ebbert
Missing braces caused the warning to print more than once. Signed-Off-By: Chuck Ebbert <cebbert@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-03-04ext4: Use struct flex_groups to calculate get_orlov_stats()Theodore Ts'o
Instead of looping over all of the block groups in a flex group summing their summary statistics, start tracking used_dirs in struct flex_groups, and use struct flex_groups instead. This should save a bit of CPU for mkdir-heavy workloads. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-03-04ext4: Use atomic_t's in struct flex_groupsTheodore Ts'o
Reduce pressure on the sb_bgl_lock family of locks by using atomic_t's to track the number of free blocks and inodes in each flex_group. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-03-12ext4: New inode/block allocation algorithms for flex_bg filesystemsTheodore Ts'o
The find_group_flex() inode allocator is now only used if the filesystem is mounted using the "oldalloc" mount option. It is replaced with the original Orlov allocator that has been updated for flex_bg filesystems (it should behave the same way if flex_bg is disabled). The inode allocator now functions by taking into account each flex_bg group, instead of each block group, when deciding whether or not it's time to allocate a new directory into a fresh flex_bg. The block allocator has also been changed so that the first block group in each flex_bg is preferred for use for storing directory blocks. This keeps directory blocks close together, which is good for speeding up e2fsck since large directories are more likely to look like this: debugfs: stat /home/tytso/Maildir/cur Inode: 1844562 Type: directory Mode: 0700 Flags: 0x81000 Generation: 1132745781 Version: 0x00000000:0000ad71 User: 15806 Group: 15806 Size: 1060864 File ACL: 0 Directory ACL: 0 Links: 2 Blockcount: 2072 Fragment: Address: 0 Number: 0 Size: 0 ctime: 0x499c0ff4:164961f4 -- Wed Feb 18 08:41:08 2009 atime: 0x499c0ff4:00000000 -- Wed Feb 18 08:41:08 2009 mtime: 0x49957f51:00000000 -- Fri Feb 13 09:10:25 2009 crtime: 0x499c0f57:00d51440 -- Wed Feb 18 08:38:31 2009 Size of extra inode fields: 28 BLOCKS: (0):7348651, (1-258):7348654-7348911 TOTAL: 259 Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-02-15ext4: tighten restrictions on inode flagsDuane Griffin
At the moment there are few restrictions on which flags may be set on which inodes. Specifically DIRSYNC may only be set on directories and IMMUTABLE and APPEND may not be set on links. Tighten that to disallow TOPDIR being set on non-directories and only NODUMP and NOATIME to be set on non-regular file, non-directories. Introduces a flags masking function which masks flags based on mode and use it during inode creation and when flags are set via the ioctl to facilitate future consistency. Signed-off-by: Duane Griffin <duaneg@dghda.com> Acked-by: Andreas Dilger <adilger@sun.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-02-15ext4: don't inherit inappropriate inode flags from parentDuane Griffin
At present INDEX and EXTENTS are the only flags that new ext4 inodes do NOT inherit from their parent. In addition prevent the flags DIRTY, ECOMPR, IMAGIC, TOPDIR, HUGE_FILE and EXT_MIGRATE from being inherited. List inheritable flags explicitly to prevent future flags from accidentally being inherited. This fixes the TOPDIR flag inheritance bug reported at http://bugzilla.kernel.org/show_bug.cgi?id=9866. Signed-off-by: Duane Griffin <duaneg@dghda.com> Acked-by: Andreas Dilger <adilger@sun.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-03-26ext4: Use lowercase names of quota functionsJan Kara
Use lowercase names of quota functions instead of old uppercase ones. Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: Mingming Cao <cmm@us.ibm.com> CC: linux-ext4@vger.kernel.org
2009-03-12ext4: Print the find_group_flex() warning only onceTheodore Ts'o
This is a short-term warning, and even printk_ratelimit() can result in too much noise in system logs. So only print it once as a warning. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-03-04ext4: fix ext4_free_inode() vs. ext4_claim_inode() raceEric Sandeen
I was seeing fsck errors on inode bitmaps after a 4 thread dbench run on a 4 cpu machine: Inode bitmap differences: -50736 -(50752--50753) etc... I believe that this is because ext4_free_inode() uses atomic bitops, and although ext4_new_inode() *used* to also use atomic bitops for synchronization, commit 393418676a7602e1d7d3f6e560159c65c8cbd50e changed this to use the sb_bgl_lock, so that we could also synchronize against read_inode_bitmap and initialization of uninit inode tables. However, that change left ext4_free_inode using atomic bitops, which I think leaves no synchronization between setting & unsetting bits in the inode table. The below patch fixes it for me, although I wonder if we're getting at all heavy-handed with this spinlock... Signed-off-by: Eric Sandeen <sandeen@redhat.com> Reviewed-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-02-21ext4: Add fallback for find_group_flexTheodore Ts'o
This is a workaround for find_group_flex() which badly needs to be replaced. One of its problems (besides ignoring the Orlov algorithm) is that it is a bit hyperactive about returning failure under suspicious circumstances. This can lead to spurious ENOSPC failures even when there are inodes still available. Work around this for now by retrying the search using find_group_other() if find_group_flex() returns -1. If find_group_other() succeeds when find_group_flex() has failed, log a warning message. A better block/inode allocator that will fix this problem for real has been queued up for the next merge window. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-01-06ext4: Remove "extents" mount optionTheodore Ts'o
This mount option is largely superfluous, and in fact the way it was implemented was buggy; if a filesystem which did not have the extents feature flag was mounted -o extents, the filesystem would attempt to create and use extents-based file even though the extents feature flag was not eabled. The simplest thing to do is to nuke the mount option entirely. It's not all that useful to force the non-creation of new extent-based files if the filesystem can support it. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-01-03ext4: Add markers for better debuggabilityTheodore Ts'o
2009-01-05ext4: mark the blocks/inode bitmap beyond end of group as usedAneesh Kumar K.V
We need to mark the block/inode bitmap beyond the end of the group with '1'. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2009-01-05ext4: Use new buffer_head flag to check uninit group bitmaps initializationAneesh Kumar K.V
For uninit block group, the on-disk bitmap is not initialized. That implies we cannot depend on the uptodate flag on the bitmap buffer_head to find bitmap validity. Use a new buffer_head flag which would be set after we properly initialize the bitmap. This also prevents (re-)initializing the uninit group bitmap every time we call ext4_read_block_bitmap(). Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2009-01-05ext4: Fix the race between read_inode_bitmap() and ext4_new_inode()Aneesh Kumar K.V
We need to make sure we update the inode bitmap and clear EXT4_BG_INODE_UNINIT flag with sb_bgl_lock held, since ext4_read_inode_bitmap() looks at EXT4_BG_INODE_UNINIT to decide whether to initialize the inode bitmap each time it is called. (introduced by commit c806e68f.) ext4_read_inode_bitmap does: spin_lock(sb_bgl_lock(EXT4_SB(sb), block_group)); if (desc->bg_flags & cpu_to_le16(EXT4_BG_INODE_UNINIT)) { ext4_init_inode_bitmap(sb, bh, block_group, desc); and ext4_new_inode does if (!ext4_set_bit_atomic(sb_bgl_lock(sbi, group), ino, inode_bitmap_bh->b_data)) ...... ... spin_lock(sb_bgl_lock(sbi, group)); gdp->bg_flags &= cpu_to_le16(~EXT4_BG_INODE_UNINIT); i.e., on allocation we update the bitmap then we take the sb_bgl_lock and clear the EXT4_BG_INODE_UNINIT flag. What can happen is a parallel ext4_read_inode_bitmap can zero out the bitmap in between the above ext4_set_bit_atomic and spin_lock(sb_bg_lock..) The race results in below user visible errors EXT4-fs error (device sdb1): ext4_free_inode: bit already cleared for inode 168449 EXT4-fs warning (device sdb1): ext4_unlink: Deleting nonexistent file ... EXT4-fs warning (device sdb1): ext4_rmdir: empty directory has too many links ... # ls -al /mnt/tmp/f/p369/d3/d6/d39/db2/dee/d10f/d3f/l71 ls: /mnt/tmp/f/p369/d3/d6/d39/db2/dee/d10f/d3f/l71: Stale NFS file handle Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@kernel.org
2009-01-03ext4: code cleanupAneesh Kumar K.V
Rename some variables. We also unlock locks in the reverse order we acquired as a part of cleanup. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-01-05ext4: Use high 16 bits of the block group descriptor's free counts fieldsAneesh Kumar K.V
Rename the lower bits with suffix _lo and add helper to access the values. Also rename bg_itable_unused_hi to bg_pad as in e2fsprogs. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-01-05ext4: Make ext4_group_t be an unsigned intTheodore Ts'o
Nearly all places in the ext3/4 code which uses "unsigned long" is probably a bug, since on 32-bit systems a ulong a 32-bits, which means we are wasting stack space on 64-bit systems. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-01-05ext4: remove extraneous newlines from calls to ext4_error() and ext4_warning()Theodore Ts'o
This removes annoying blank syslog entries emitted by ext4_error() or ext4_warning(), since these functions add their own newline. Signed-off-by: Nick Warne <nick@ukfsn.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-01-07ext4: Allow ext4 to run without a journalFrank Mayhar
A few weeks ago I posted a patch for discussion that allowed ext4 to run without a journal. Since that time I've integrated the excellent comments from Andreas and fixed several serious bugs. We're currently running with this patch and generating some performance numbers against both ext2 (with backported reservations code) and ext4 with and without a journal. It just so happens that running without a journal is slightly faster for most everything. We did iozone -T -t 4 s 2g -r 256k -T -I -i0 -i1 -i2 which creates 4 threads, each of which create and do reads and writes on a 2G file, with a buffer size of 256K, using O_DIRECT for all file opens to bypass the page cache. Results: ext2 ext4, default ext4, no journal initial writes 13.0 MB/s 15.4 MB/s 15.7 MB/s rewrites 13.1 MB/s 15.6 MB/s 15.9 MB/s reads 15.2 MB/s 16.9 MB/s 17.2 MB/s re-reads 15.3 MB/s 16.9 MB/s 17.2 MB/s random readers 5.6 MB/s 5.6 MB/s 5.7 MB/s random writers 5.1 MB/s 5.3 MB/s 5.4 MB/s So it seems that, so far, this was a useful exercise. Signed-off-by: Frank Mayhar <fmayhar@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-12-31nfsd race fixes: ext4Al Viro
2008-11-14Merge branch 'master' into nextJames Morris
Conflicts: security/keys/internal.h security/keys/process_keys.c security/keys/request_key.c Fixed conflicts above by using the non 'tsk' versions. Signed-off-by: James Morris <jmorris@namei.org>
2008-11-14CRED: Wrap task credential accesses in the Ext4 filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Stephen Tweedie <sct@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: adilger@sun.com Cc: linux-ext4@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2008-11-07ext4: add checksum calculation when clearing UNINIT flag in ext4_new_inodeFrederic Bohe
When initializing an uninitialized block group in ext4_new_inode(), its block group checksum must be re-calculated. This fixes a race when several threads try to allocate a new inode in an UNINIT'd group. There is some question whether we need to be initializing the block bitmap in ext4_new_inode() at all, but for now, if we are going to init the block group, let's eliminate the race. Signed-off-by: Frederic Bohe <frederic.bohe@bull.net> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-10-10ext4: fix initialization of UNINIT bitmap blocksFrederic Bohe
This fixes a bug which caused on-line resizing of filesystems with a 1k blocksize to fail. The root cause of this bug was the fact that if an uninitalized bitmap block gets read in by userspace (which e2fsprogs does try to avoid, but can happen when the blocksize is less than the pagesize and an adjacent blocks is read into memory) ext4_read_block_bitmap() was erroneously depending on the buffer uptodate flag to decide whether it needed to initialize the bitmap block in memory --- i.e., to set the standard set of blocks in use by a block group (superblock, bitmaps, inode table, etc.). Essentially, ext4_read_block_bitmap() assumed it was the only routine that might try to read a block containing a block bitmap, which is simply not true. To fix this, ext4_read_block_bitmap() and ext4_read_inode_bitmap() must always initialize uninitialized bitmap blocks. Once a block or inode is allocated out of that bitmap, it will be marked as initialized in the block group descriptor, so in general this won't result any extra unnecessary work. Signed-off-by: Frederic Bohe <frederic.bohe@bull.net> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-10-10ext4: Remove old legacy block allocatorTheodore Ts'o
2008-09-08ext4: Fix whitespace checkpatch warnings/errorsTheodore Ts'o
2008-09-08ext4: Add printk priority levels to clean up checkpatch warningsTheodore Ts'o
2008-08-19ext4: Fix bug where we return ENOSPC even though we have plenty of inodesEric Sandeen
The find_group_flex() function starts with best_flex as the parent_fbg_group, which happens to have 0 inodes free. Some of the flex groups searched have free blocks and free inodes, but the flex_freeb_ratio is < 10, so they're skipped. Then when a group is compared to the current "best" flex group, it does not have more free blocks than "best", so it is skipped as well. This continues until no flex group with free inodes is found which has a proper ratio or which has more free blocks than the "best" group, and we're left with a "best" group that has 0 inodes free, and we return -ENOSPC. We fix this by changing the logic so that if the current "best" flex group has no inodes free, and the current one does have room, it is promoted to the next "best." Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-08-02ext4: lock block groups when initializingEric Sandeen
I noticed when filling a 1T filesystem with 4 threads using the fs_mark benchmark: fs_mark -d /mnt/test -D 256 -n 100000 -t 4 -s 20480 -F -S 0 that I occasionally got checksum mismatch errors: EXT4-fs error (device sdb): ext4_init_inode_bitmap: Checksum bad for group 6935 etc. I'd reliably get 4-5 of them during the run. It appears that the problem is likely a race to init the bg's when the uninit_bg feature is enabled. With the patch below, which adds sb_bgl_locking around initialization, I was able to complete several runs with no errors or warnings. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2008-08-02ext4: sync up block and inode bitmap reading functionsEric Sandeen
ext4_read_block_bitmap and read_inode_bitmap do essentially the same thing, and yet they are structured quite differently. I came across this difference while looking at doing bg locking during bg initialization. This patch: * removes unnecessary casts in the error messages * renames read_inode_bitmap to ext4_read_inode_bitmap * and more substantially, restructures the inode bitmap reading function to be more like the block bitmap counterpart. The change to the inode bitmap reader simplifies the locking to be applied in the next patch. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2008-07-11ext4: do not set extents feature from the kernelEric Sandeen
We've talked for a while about getting rid of any feature- setting from the kernel; this gets rid of the code which would set the INCOMPAT_EXTENTS flag on the first file write when mounted as ext4[dev]. With this patch, if the extents feature is not already set on disk, then mounting as ext4 will fall back to noextents with a warning, and if -o extents is explicitly requested, the mount will fail, also with warning. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-07-11ext4: New inode allocation for FLEX_BG meta-data groups.Jose R. Santos
This patch mostly controls the way inode are allocated in order to make ialloc aware of flex_bg block group grouping. It achieves this by bypassing the Orlov allocator when block group meta-data are packed toghether through mke2fs. Since the impact on the block allocator is minimal, this patch should have little or no effect on other block allocation algorithms. By controlling the inode allocation, it can basically control where the initial search for new block begins and thus indirectly manipulate the block allocator. This allocator favors data and meta-data locality so the disk will gradually be filled from block group zero upward. This helps improve performance by reducing seek time. Since the group of inode tables within one flex_bg are treated as one giant inode table, uninitialized block groups would not need to partially initialize as many inode table as with Orlov which would help fsck time as the filesystem usage goes up. Signed-off-by: Jose R. Santos <jrs@us.ibm.com> Signed-off-by: Valerie Clement <valerie.clement@bull.net> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-07-11ext4: Rename read_block_bitmap() to ext4_read_block_bitmap()Theodore Ts'o
Since this a non-static function, make it be ext4 specific to avoid conflicts with potentially other filesystems. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-07-11ext4: handle corrupted orphan list at mountDuane Griffin
If the orphan node list includes valid, untruncatable nodes with nlink > 0 the ext4_orphan_cleanup loop which attempts to delete them will not do so, causing it to loop forever. Fix by checking for such nodes in the ext4_orphan_get function. This patch fixes the second case (image hdb.20000009.softlockup.gz) reported in http://bugzilla.kernel.org/show_bug.cgi?id=10882. Signed-off-by: Duane Griffin <duaneg@dghda.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu>
2008-04-29ext4: mark inode dirty after initializing the extent treeAneesh Kumar K.V
We should mark the inode dirty only after initializing the extent tree. Also if we fail during extent initialization we need to call DQUOT_FREE_INODE. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-04-29ext4: move headers out of include/linuxChristoph Hellwig
Move ext4 headers out of include/linux. This is just the trivial move, there's some more thing that could be done later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-04-17ext4: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-04-17ext4: le*_add_cpu conversionMarcin Slusarz
replace all: little_endian_variable = cpu_to_leX(leX_to_cpu(little_endian_variable) + expression_in_cpu_byteorder); with: leX_add_cpu(&little_endian_variable, expression_in_cpu_byteorder); generated with semantic patch Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: linux-ext4@vger.kernel.org Cc: sct@redhat.com Cc: Andrew Morton <akpm@linux-foundation.org> Cc: adilger@clusterfs.com Cc: Mingming Cao <cmm@us.ibm.com>
2008-04-29ext4: Enable extent format for symlinks.Aneesh Kumar K.V
This patch enables extent-formatted normal symlinks. Using extents format allows a symlink to refer to a block number larger than 2^32 on large filesystems. We still don't enable extent format for fast symlinks, which are contained in the inode itself. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-04-21ext*: spelling fix prefered -> preferredBenoit Boissinot
Spelling fix: prefered -> preferred Signed-off-by: Benoit Boissinot <benoit.boissinot@ens-lyon.org> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
2008-02-25ext4: set EXT4_EXTENTS_FL only for directory and regular filesAneesh Kumar K.V
In addition, don't inherit EXT4_EXTENTS_FL from parent directory. If we have a directory with extent flag set and later mount the file system with -o noextents, the files created in that directory will also have extent flag set but we would not have called ext4_ext_tree_init for them. This will cause error later when we are verifying the extent header Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Acked-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-02-07iget: stop EXT4 from using iget() and read_inode()David Howells
Stop the EXT4 filesystem from using iget() and read_inode(). Replace ext4_read_inode() with ext4_iget(), and call that instead of iget(). ext4_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. ext4_fill_super() returns any error incurred when getting the root inode instead of EINVAL. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Acked-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28ext4: fix up EXT4FS_DEBUG buildsEric Sandeen
Builds with EXT4FS_DEBUG defined (to enable ext4_debug()) fail without these changes. Clean up some format warnings too. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com>
2008-01-28ext4: Rename i_dir_acl to i_size_highAneesh Kumar K.V
Rename ext4_inode.i_dir_acl to i_size_high drop ext4_inode_info.i_dir_acl as it is not used Rename ext4_inode.i_size to ext4_inode.i_size_lo Add helper function for accessing the ext4_inode combined i_size. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2008-01-28ext4: Introduce ext4_update_*_featureAneesh Kumar K.V
Introduce ext4_update_*_feature and use them instead of opencoding. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
2008-01-28ext4: fixes block group number being set to a negative valueAvantika Mathur
This patch fixes various places where the group number is set to a negative value. Signed-off-by: Avantika Mathur <mathur@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-01-28ext4: add ext4_group_t, and change all group variables to this type.Avantika Mathur
In many places variables for block group are of type int, which limits the maximum number of block groups to 2^31. Each block group can have up to 2^15 blocks, with a 4K block size, and the max filesystem size is limited to 2^31 * (2^15 * 2^12) = 2^58 -- or 256 PB This patch introduces a new type ext4_group_t, of type unsigned long, to represent block group numbers in ext4. All occurrences of block group variables are converted to type ext4_group_t. Signed-off-by: Avantika Mathur <mathur@us.ibm.com>
2007-10-17Ext4: Uninitialized Block GroupsAndreas Dilger
In pass1 of e2fsck, every inode table in the fileystem is scanned and checked, regardless of whether it is in use. This is this the most time consuming part of the filesystem check. The unintialized block group feature can greatly reduce e2fsck time by eliminating checking of uninitialized inodes. With this feature, there is a a high water mark of used inodes for each block group. Block and inode bitmaps can be uninitialized on disk via a flag in the group descriptor to avoid reading or scanning them at e2fsck time. A checksum of each group descriptor is used to ensure that corruption in the group descriptor's bit flags does not cause incorrect operation. The feature is enabled through a mkfs option mke2fs /dev/ -O uninit_groups A patch adding support for uninitialized block groups to e2fsprogs tools has been posted to the linux-ext4 mailing list. The patches have been stress tested with fsstress and fsx. In performance tests testing e2fsck time, we have seen that e2fsck time on ext3 grows linearly with the total number of inodes in the filesytem. In ext4 with the uninitialized block groups feature, the e2fsck time is constant, based solely on the number of used inodes rather than the total inode count. Since typical ext4 filesystems only use 1-10% of their inodes, this feature can greatly reduce e2fsck time for users. With performance improvement of 2-20 times, depending on how full the filesystem is. The attached graph shows the major improvements in e2fsck times in filesystems with a large total inode count, but few inodes in use. In each group descriptor if we have EXT4_BG_INODE_UNINIT set in bg_flags: Inode table is not initialized/used in this group. So we can skip the consistency check during fsck. EXT4_BG_BLOCK_UNINIT set in bg_flags: No block in the group is used. So we can skip the block bitmap verification for this group. We also add two new fields to group descriptor as a part of uninitialized group patch. __le16 bg_itable_unused; /* Unused inodes count */ __le16 bg_checksum; /* crc16(sb_uuid+group+desc) */ bg_itable_unused: If we have EXT4_BG_INODE_UNINIT not set in bg_flags then bg_itable_unused will give the offset within the inode table till the inodes are used. This can be used by fsck to skip list of inodes that are marked unused. bg_checksum: Now that we depend on bg_flags and bg_itable_unused to determine the block and inode usage, we need to make sure group descriptor is not corrupt. We add checksum to group descriptor to detect corruption. If the descriptor is found to be corrupt, we mark all the blocks and inodes in the group used. Signed-off-by: Avantika Mathur <mathur@us.ibm.com> Signed-off-by: Andreas Dilger <adilger@clusterfs.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
