path: root/fs/ext4/fsync.c
2013-06-12ext4: Fix fsync error handling after filesystem abortDmitry Monakhov
If filesystem was aborted after inode's write back is complete but before its metadata was updated we may return success results in data loss. In order to handle fs abort correctly we have to check fs state once we discover that it is in MS_RDONLY state Test case: http://patchwork.ozlabs.org/patch/244297 Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-06-04ext4: remove i_mutex from ext4_file_sync()Jan Kara
After removal of ext4_flush_unwritten_io() call, ext4_file_sync() doesn't need i_mutex anymore. Forcing of transaction commits doesn't need i_mutex as there's nothing inode specific in that code apart from grabbing transaction ids from the inode. So remove the lock. Reviewed-by: Zheng Liu <wenqing.lz@taobao.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-06-04ext4: use generic_file_fsync() in ext4_file_fsync() in nojournal modeJan Kara
Just use the generic function instead of duplicating it. We only need to reshuffle the read-only check a bit (which is there to prevent writing to a filesystem which has been remounted read-only after error I assume). Reviewed-by: Zheng Liu <wenqing.lz@taobao.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-06-04ext4: defer clearing of PageWriteback after extent conversionJan Kara
Currently PageWriteback bit gets cleared from put_io_page() called from ext4_end_bio(). This is somewhat inconvenient as extent tree is not fully updated at that time (unwritten extents are not marked as written) so we cannot read the data back yet. This design was dictated by lock ordering as we cannot start a transaction while PageWriteback bit is set (we could easily deadlock with ext4_da_writepages()). But now that we use transaction reservation for extent conversion, locking issues are solved and we can move PageWriteback bit clearing after extent conversion is done. As a result we can remove wait for unwritten extent conversion from ext4_sync_file() because it already implicitely happens through wait_on_page_writeback(). We implement deferring of PageWriteback clearing by queueing completed bios to appropriate io_end and processing all the pages when io_end is going to be freed instead of at the moment ext4_io_end() is called. Reviewed-by: Zheng Liu <wenqing.lz@taobao.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2013-04-03ext4/jbd2: don't wait (forever) for stale tid caused by wraparoundTheodore Ts'o
In the case where an inode has a very stale transaction id (tid) in i_datasync_tid or i_sync_tid, it's possible that after a very large (2**31) number of transactions, that the tid number space might wrap, causing tid_geq()'s calculations to fail. Commit deeeaf13 "jbd2: fix fsync() tid wraparound bug", later modified by commit e7b04ac0 "jbd2: don't wake kjournald unnecessarily", attempted to fix this problem, but it only avoided kjournald spinning forever by fixing the logic in jbd2_log_start_commit(). Unfortunately, in the codepaths in fs/ext4/fsync.c and fs/ext4/inode.c that might call jbd2_log_start_commit() with a stale tid, those functions will subsequently call jbd2_log_wait_commit() with the same stale tid, and then wait for a very long time. To fix this, we replace the calls to jbd2_log_start_commit() and jbd2_log_wait_commit() with a call to a new function, jbd2_complete_transaction(), which will correctly handle stale tid's. As a bonus, jbd2_complete_transaction() will avoid locking j_state_lock for writing unless a commit needs to be started. This should have a small (but probably not measurable) improvement for ext4's scalability. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reported-by: Ben Hutchings <ben@decadent.org.uk> Reported-by: George Barnett <gbarnett@atlassian.com> Cc: stable@vger.kernel.org
2012-12-25ext4: fix an incorrect comment about i_mutexAndy Lutomirski
i_mutex is not held when ->sync_file is called. Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2012-12-10ext4: use sync_inode_metadata() when syncing inode metadataGuo Chao
We have a dedicated interface to sync inode metadata. Use it to simplify ext4's code some. Signed-off-by: Guo Chao <yan@linux.vnet.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Lukas Czerner <lczerner@redhat.com>
2012-10-05ext4: fix ext4_flush_completed_IO wait semanticsDmitry Monakhov
BUG #1) All places where we call ext4_flush_completed_IO are broken because buffered io and DIO/AIO goes through three stages 1) submitted io, 2) completed io (in i_completed_io_list) conversion pended 3) finished io (conversion done) And by calling ext4_flush_completed_IO we will flush only requests which were in (2) stage, which is wrong because: 1) punch_hole and truncate _must_ wait for all outstanding unwritten io regardless to it's state. 2) fsync and nolock_dio_read should also wait because there is a time window between end_page_writeback() and ext4_add_complete_io() As result integrity fsync is broken in case of buffered write to fallocated region: fsync blkdev_completion ->filemap_write_and_wait_range ->ext4_end_bio ->end_page_writeback <-- filemap_write_and_wait_range return ->ext4_flush_completed_IO sees empty i_completed_io_list but pended conversion still exist ->ext4_add_complete_io BUG #2) Race window becomes wider due to the 'ext4: completed_io locking cleanup V4' patch series This patch make following changes: 1) ext4_flush_completed_io() now first try to flush completed io and when wait for any outstanding unwritten io via ext4_unwritten_wait() 2) Rename function to more appropriate name. 3) Assert that all callers of ext4_flush_unwritten_io should hold i_mutex to prevent endless wait Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Reviewed-by: Jan Kara <jack@suse.cz>
2012-09-29ext4: completed_io locking cleanupDmitry Monakhov
Current unwritten extent conversion state-machine is very fuzzy. - For unknown reason it performs conversion under i_mutex. What for? My diagnosis: We already protect extent tree with i_data_sem, truncate and punch_hole should wait for DIO, so the only data we have to protect is end_io->flags modification, but only flush_completed_IO and end_io_work modified this flags and we can serialize them via i_completed_io_lock. Currently all these games with mutex_trylock result in the following deadlock truncate: kworker: ext4_setattr ext4_end_io_work mutex_lock(i_mutex) inode_dio_wait(inode) ->BLOCK DEADLOCK<- mutex_trylock() inode_dio_done() #TEST_CASE1_BEGIN MNT=/mnt_scrach unlink $MNT/file fallocate -l $((1024*1024*1024)) $MNT/file aio-stress -I 100000 -O -s 100m -n -t 1 -c 10 -o 2 -o 3 $MNT/file sleep 2 truncate -s 0 $MNT/file #TEST_CASE1_END Or use 286's xfstests https://github.com/dmonakhov/xfstests/blob/devel/286 This patch makes state machine simple and clean: (1) xxx_end_io schedule final extent conversion simply by calling ext4_add_complete_io(), which append it to ei->i_completed_io_list NOTE1: because of (2A) work should be queued only if ->i_completed_io_list was empty, otherwise the work is scheduled already. (2) ext4_flush_completed_IO is responsible for handling all pending end_io from ei->i_completed_io_list Flushing sequence consists of following stages: A) LOCKED: Atomically drain completed_io_list to local_list B) Perform extents conversion C) LOCKED: move converted io's to to_free list for final deletion This logic depends on context which we was called from. D) Final end_io context destruction NOTE1: i_mutex is no longer required because end_io->flags modification is protected by ei->ext4_complete_io_lock Full list of changes: - Move all completion end_io related routines to page-io.c in order to improve logic locality - Move open coded logic from various xx_end_xx routines to ext4_add_complete_io() - remove EXT4_IO_END_FSYNC - Improve SMP scalability by removing useless i_mutex which does not protect io->flags anymore. - Reduce lock contention on i_completed_io_lock by optimizing list walk. - Rename ext4_end_io_nolock to end4_end_io and make it static - Check flush completion status to ext4_ext_punch_hole(). Because it is not good idea to punch blocks from corrupted inode. Changes since V3 (in request to Jan's comments): Fall back to active flush_completed_IO() approach in order to prevent performance issues with nolocked DIO reads. Changes since V2: Fix use-after-free caused by race truncate vs end_io_work Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2012-08-17ext4: check return value of blkdev_issue_flush()Theodore Ts'o
blkdev_issue_flush() can fail; make sure the error gets properly propagated. This is a port of the equivalent ext3 patch from commit 44f4f729e7a1. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2012-07-14vfs: switch i_dentry/d_alias to hlistAl Viro
2012-07-14ext4: get rid of open-coded d_find_any_alias()Al Viro
2012-03-05ext4: fix race between sync and completed io workJeff Moyer
The following command line will leave the aio-stress process unkillable on an ext4 file system (in my case, mounted on /mnt/test): aio-stress -t 20 -s 10 -O -S -o 2 -I 1000 /mnt/test/aiostress.3561.4 /mnt/test/aiostress.3561.4.20 /mnt/test/aiostress.3561.4.19 /mnt/test/aiostress.3561.4.18 /mnt/test/aiostress.3561.4.17 /mnt/test/aiostress.3561.4.16 /mnt/test/aiostress.3561.4.15 /mnt/test/aiostress.3561.4.14 /mnt/test/aiostress.3561.4.13 /mnt/test/aiostress.3561.4.12 /mnt/test/aiostress.3561.4.11 /mnt/test/aiostress.3561.4.10 /mnt/test/aiostress.3561.4.9 /mnt/test/aiostress.3561.4.8 /mnt/test/aiostress.3561.4.7 /mnt/test/aiostress.3561.4.6 /mnt/test/aiostress.3561.4.5 /mnt/test/aiostress.3561.4.4 /mnt/test/aiostress.3561.4.3 /mnt/test/aiostress.3561.4.2 This is using the aio-stress program from the xfstests test suite. That particular command line tells aio-stress to do random writes to 20 files from 20 threads (one thread per file). The files are NOT preallocated, so you will get writes to random offsets within the file, thus creating holes and extending i_size. It also opens the file with O_DIRECT and O_SYNC. On to the problem. When an I/O requires unwritten extent conversion, it is queued onto the completed_io_list for the ext4 inode. Two code paths will pull work items from this list. The first is the ext4_end_io_work routine, and the second is ext4_flush_completed_IO, which is called via the fsync path (and O_SYNC handling, as well). There are two issues I've found in these code paths. First, if the fsync path beats the work routine to a particular I/O, the work routine will free the io_end structure! It does not take into account the fact that the io_end may still be in use by the fsync path. I've fixed this issue by adding yet another IO_END flag, indicating that the io_end is being processed by the fsync path. The second problem is that the work routine will make an assignment to io->flag outside of the lock. I have witnessed this result in a hang at umount. Moving the flag setting inside the lock resolved that problem. The problem was introduced by commit b82e384c7b ("ext4: optimize locking for end_io extent conversion"), which first appeared in 3.2. As such, the fix should be backported to that release (probably along with the unwritten extent conversion race fix). Signed-off-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> CC: stable@kernel.org
2011-10-31ext4: optimize locking for end_io extent conversionTheodore Ts'o
Now that we are doing the locking correctly, we need to grab the i_completed_io_lock() twice per end_io. We can clean this up by removing the structure from the i_complted_io_list, and use this as the locking mechanism to prevent ext4_flush_completed_IO() racing against ext4_end_io_work(), instead of clearing the EXT4_IO_END_UNWRITTEN in io->flag. In addition, if the ext4_convert_unwritten_extents() returns an error, we no longer keep the end_io structure on the linked list. This doesn't help, because it tends to lock up the file system and wedges the system. That's one way to call attention to the problem, but it doesn't help the overall robustness of the system. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-10-30ext4: Use correct locking for ext4_end_io_nolock()Tao Ma
We must hold i_completed_io_lock when manipulating anything on the i_completed_io_list linked list. This includes io->lock, which we were checking in ext4_end_io_nolock(). So move this check to ext4_end_io_work(). This also has the bonus of avoiding extra work if it is already done without needing to take the mutex. Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-10-18ext4: functions should not be declared externH Hartley Sweeten
The function declarations in ext4.h are already marked extern, so it's not necessary to do so in the .c files. This quiets the sparse noise: warning: function 'ext4_flush_completed_IO' with external linkage has definition warning: function 'ext4_init_inode_table' with external linkage has definition Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-08-01Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (60 commits) ext4: prevent memory leaks from ext4_mb_init_backend() on error path ext4: use EXT4_BAD_INO for buddy cache to avoid colliding with valid inode # ext4: use ext4_msg() instead of printk in mballoc ext4: use ext4_kvzalloc()/ext4_kvmalloc() for s_group_desc and s_group_info ext4: introduce ext4_kvmalloc(), ext4_kzalloc(), and ext4_kvfree() ext4: use the correct error exit path in ext4_init_inode_table() ext4: add missing kfree() on error return path in add_new_gdb() ext4: change umode_t in tracepoint headers to be an explicit __u16 ext4: fix races in ext4_sync_parent() ext4: Fix overflow caused by missing cast in ext4_fallocate() ext4: add action of moving index in ext4_ext_rm_idx for Punch Hole ext4: simplify parameters of reserve_backup_gdb() ext4: simplify parameters of add_new_gdb() ext4: remove lock_buffer in bclean() and setup_new_group_blocks() ext4: simplify journal handling in setup_new_group_blocks() ext4: let setup_new_group_blocks() set multiple bits at a time ext4: fix a typo in ext4_group_extend() ext4: let ext4_group_add_blocks() handle 0 blocks quickly ext4: let ext4_group_add_blocks() return an error code ext4: rename ext4_add_groupblocks() to ext4_group_add_blocks() ... Fix up conflict in fs/ext4/inode.c: commit aacfc19c626e ("fs: simplify the blockdev_direct_IO prototype") had changed the ext4_ind_direct_IO() function for the new simplified calling convention, while commit dae1e52cb126 ("ext4: move ext4_ind_* functions from inode.c to indirect.c") moved the function to another file.
2011-07-30ext4: fix races in ext4_sync_parent()Theodore Ts'o
Fix problems if fsync() races against a rename of a parent directory as pointed out by Al Viro in his own inimitable way: >While we are at it, could somebody please explain what the hell is ext4 >doing in >static int ext4_sync_parent(struct inode *inode) >{ > struct writeback_control wbc; > struct dentry *dentry = NULL; > int ret = 0; > > while (inode && ext4_test_inode_state(inode, EXT4_STATE_NEWENTRY)) { > ext4_clear_inode_state(inode, EXT4_STATE_NEWENTRY); > dentry = list_entry(inode->i_dentry.next, > struct dentry, d_alias); > if (!dentry || !dentry->d_parent || !dentry->d_parent->d_inode) > break; > inode = dentry->d_parent->d_inode; > ret = sync_mapping_buffers(inode->i_mapping); > ... >Note that dentry obviously can't be NULL there. dentry->d_parent is never >NULL. And dentry->d_parent would better not be negative, for crying out >loud! What's worse, there's no guarantees that dentry->d_parent will >remain our parent over that sync_mapping_buffers() *and* that inode won't >just be freed under us (after rename() and memory pressure leading to >eviction of what used to be our dentry->d_parent)...... Reported-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-24ext4: fix waiting and sending of a barrier in ext4_sync_file()Jan Kara
jbd2_log_start_commit() returns 1 only when we really start a transaction. But we also need to wait for a transaction when the commit is already running. Fix this problem by waiting for transaction commit unconditionally (which is just a quick check if the transaction is already committed). Also we have to be more careful with sending of a barrier because when transaction is being committed in parallel to ext4_sync_file() running, we cannot be sure that the barrier the journalling code sends happens after we wrote all the data for fsync (note that not every data writeout needs to trigger metadata changes thus commit of some metadata changes can be running while other data is still written out). So use jbd2_will_send_data_barrier() helper to detect the common cases when we can be sure barrier will be issued by the commit code and issue the barrier ourselves in the remaining cases. Reported-by: Edward Goggin <egoggin@vmware.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-05-09ext4: use EXT4FS_DEBUG instead of EXT4_DEBUG in fsync.cTao Ma
We have EXT4FS_DEBUG for some old debug and CONFIG_EXT4_DEBUG for the new mballoc debug, but there isn't any EXT4_DEBUG. As CONFIG_EXT4_DEBUG seems to be only used in mballoc, use EXT4FS_DEBUG in fsync.c. [ It doesn't really matter; although I'm including this commit for consistency's sake. The whole point of the #ifdef's is to disable the debugging code. In general you're not going to want to enable all of the code protected by EXT4FS_DEBUG at the same time. -- Ted ] Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-04-11Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: ext4: fix data corruption regression by reverting commit 6de9843dab3f ext4: Allow indirect-block file to grow the file size to max file size ext4: allow an active handle to be started when freezing ext4: sync the directory inode in ext4_sync_parent() ext4: init timer earlier to avoid a kernel panic in __save_error_info jbd2: fix potential memory leak on transaction commit ext4: fix a double free in ext4_register_li_request ext4: fix credits computing for indirect mapped files ext4: remove unnecessary [cm]time update of quota file jbd2: move bdget out of critical section
2011-04-10ext4: sync the directory inode in ext4_sync_parent()Curt Wohlgemuth
ext4 has taken the stance that, in the absence of a journal, when an fsync/fdatasync of an inode is done, the parent directory should be sync'ed if this inode entry is new. ext4_sync_parent(), which implements this, does indeed sync the dirent pages for parent directories, but it does not sync the directory *inode*. This patch fixes this. Also now return error status from ext4_sync_parent(). I tested this using a power fail test, which panics a machine running a file server getting requests from a client. Without this patch, on about every other test run, the server is missing many, many files that had been synced. With this patch, on > 6 runs, I see zero files being lost. Google-Bug-Id: 4179519 Signed-off-by: Curt Wohlgemuth <curtw@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-03-21ext4: add more tracepoints and use dev_t in the trace bufferJiaying Zhang
- Add more ext4 tracepoints. - Change ext4 tracepoints to use dev_t field with MAJOR/MINOR macros so that we can save 4 bytes in the ring buffer on some platforms. - Add sync_mode to ext4_da_writepages, ext4_da_write_pages, and ext4_da_writepages_result tracepoints. Also remove for_reclaim field from ext4_da_writepages since it is usually not very useful. Signed-off-by: Jiaying Zhang <jiayingz@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2011-01-10ext4: flush the i_completed_io_list during ext4_truncateJiaying Zhang
Ted first found the bug when running 2.6.36 kernel with dioread_nolock mount option that xfstests #13 complained about wrong file size during fsck. However, the bug exists in the older kernels as well although it is somehow harder to trigger. The problem is that ext4_end_io_work() can happen after we have truncated an inode to a smaller size. Then when ext4_end_io_work() calls ext4_convert_unwritten_extents(), we may reallocate some blocks that have been truncated, so the inode size becomes inconsistent with the allocated blocks. The following patch flushes the i_completed_io_list during truncate to reduce the risk that some pending end_io requests are executed later and convert already truncated blocks to initialized. Note that although the fix helps reduce the problem a lot there may still be a race window between vmtruncate() and ext4_end_io_work(). The fundamental problem is that if vmtruncate() is called without either i_mutex or i_alloc_sem held, it can race with an ongoing write request so that the io_end request is processed later when the corresponding blocks have been truncated. Ted and I have discussed the problem offline and we saw a few ways to fix the race completely: a) We guarantee that i_mutex lock and i_alloc_sem write lock are both hold whenever vmtruncate() is called. The i_mutex lock prevents any new write requests from entering writeback and the i_alloc_sem prevents the race from ext4_page_mkwrite(). Currently we hold both locks if vmtruncate() is called from do_truncate(), which is probably the most common case. However, there are places where we may call vmtruncate() without holding either i_mutex or i_alloc_sem. I would like to ask for other people's opinions on what locks are expected to be held before calling vmtruncate(). There seems a disagreement among the callers of that function. b) We change the ext4 write path so that we change the extent tree to contain the newly allocated blocks and update i_size both at the same time --- when the write of the data blocks is completed. c) We add some additional locking to synchronize vmtruncate() and ext4_end_io_work(). This approach may have performance implications so we need to be careful. All of the above proposals may require more substantial changes, so we may consider to take the following patch as a bandaid. Signed-off-by: Jiaying Zhang <jiayingz@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-10-27Merge branch 'next' into upstream-mergeTheodore Ts'o
Conflicts: fs/ext4/inode.c fs/ext4/mballoc.c include/trace/events/ext4.h
2010-10-27ext4: move flush_completed_IO to fs/ext4/fsync.c and make it staticTheodore Ts'o
Fix a namespace leak by moving the function to the file where it is used and making it static. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-09-16block: remove BLKDEV_IFL_WAITChristoph Hellwig
All the blkdev_issue_* helpers can only sanely be used for synchronous caller. To issue cache flushes or barriers asynchronously the caller needs to set up a bio by itself with a completion callback to move the asynchronous state machine ahead. So drop the BLKDEV_IFL_WAIT flag that is always specified when calling blkdev_issue_* and also remove the now unused flags argument to blkdev_issue_flush and blkdev_issue_zeroout. For blkdev_issue_discard we need to keep it for the secure discard flag, which gains a more descriptive name and loses the bitops vs flag confusion. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-05-27rename the generic fsync implementationsChristoph Hellwig
We don't name our generic fsync implementations very well currently. The no-op implementation for in-memory filesystems currently is called simple_sync_file which doesn't make too much sense to start with, the the generic one for simple filesystems is called simple_fsync which can lead to some confusion. This patch renames the generic file fsync method to generic_file_fsync to match the other generic_file_* routines it is supposed to be used with, and the no-op implementation to noop_fsync to make it obvious what to expect. In addition add some documentation for both methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
2010-05-27Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (40 commits) ext4: Make fsync sync new parent directories in no-journal mode ext4: Drop whitespace at end of lines ext4: Fix compat EXT4_IOC_ADD_GROUP ext4: Conditionally define compat ioctl numbers tracing: Convert more ext4 events to DEFINE_EVENT ext4: Add new tracepoints to track mballoc's buddy bitmap loads ext4: Add a missing trace hook ext4: restart ext4_ext_remove_space() after transaction restart ext4: Clear the EXT4_EOFBLOCKS_FL flag only when warranted ext4: Avoid crashing on NULL ptr dereference on a filesystem error ext4: Use bitops to read/modify i_flags in struct ext4_inode_info ext4: Convert calls of ext4_error() to EXT4_ERROR_INODE() ext4: Convert callers of ext4_get_blocks() to use ext4_map_blocks() ext4: Add new abstraction ext4_map_blocks() underneath ext4_get_blocks() ext4: Use our own write_cache_pages() ext4: Show journal_checksum option ext4: Fix for ext4_mb_collect_stats() ext4: check for a good block group before loading buddy pages ext4: Prevent creation of files larger than RLIMIT_FSIZE using fallocate ext4: Remove extraneous newlines in ext4_msg() calls ... Fixed up trivial conflict in fs/ext4/fsync.c
2010-05-17ext4: Make fsync sync new parent directories in no-journal modeFrank Mayhar
Add a new ext4 state to tell us when a file has been newly created; use that state in ext4_sync_file in no-journal mode to tell us when we need to sync the parent directory as well as the inode and data itself. This fixes a problem in which a panic or power failure may lose the entire file even when using fsync, since the parent directory entry is lost. Addresses-Google-Bug: #2480057 Signed-off-by: Frank Mayhar <fmayhar@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-05-17ext4: Drop whitespace at end of linesTheodore Ts'o
This patch was generated using: #!/usr/bin/perl -i while (<>) { s/[ ]+$//; print; } Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2010-05-10ext4: check missed return value in ext4_sync_file()Dmitry Monakhov
2010-04-28blkdev: generalize flags for blkdev_issue_fn functionsDmitry Monakhov
The patch just convert all blkdev_issue_xxx function to common set of flags. Wait/allocation semantics preserved. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-03-02ext4: mechanical rename some of the direct I/O get_block's identifiersJiaying Zhang
This commit renames some of the direct I/O's block allocation flags, variables, and functions introduced in Mingming's "Direct IO for holes and fallocate" patches so that they can be used by ext4's buffered write path as well. Also changed the related function comments accordingly to cover both direct write and buffered write cases. Signed-off-by: Jiaying Zhang <jiayingz@google.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-12-23ext4, jbd2: Add barriers for file systems with exernal journalsTheodore Ts'o
This is a bit complicated because we are trying to optimize when we send barriers to the fs data disk. We could just throw in an extra barrier to the data disk whenever we send a barrier to the journal disk, but that's not always strictly necessary. We only need to send a barrier during a commit when there are data blocks which are must be written out due to an inode written in ordered mode, or if fsync() depends on the commit to force data blocks to disk. Finally, before we drop transactions from the beginning of the journal during a checkpoint operation, we need to guarantee that any blocks that were flushed out to the data disk are firmly on the rust platter before we drop the transaction from the journal. Thanks to Oleg Drokin for pointing out this flaw in ext3/ext4. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-12-08ext4: Wait for proper transaction commit on fsyncJan Kara
We cannot rely on buffer dirty bits during fsync because pdflush can come before fsync is called and clear dirty bits without forcing a transaction commit. What we do is that we track which transaction has last changed the inode and which transaction last changed allocation and force it to disk on fsync. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-11-23ext4: avoid issuing unnecessary barriersTheodore Ts'o
We don't to issue an I/O barrier on an error or if we force commit because we are doing data journaling. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Jan Kara <jack@suse.cz> Cc: stable@kernel.org
2009-09-28ext4: async direct IO for holes and fallocate supportMingming Cao
For async direct IO that covers holes or fallocate, the end_io callback function now queued the convertion work on workqueue but don't flush the work rightaway as it might take too long to afford. But when fsync is called after all the data is completed, user expects the metadata also being updated before fsync returns. Thus we need to flush the conversion work when fsync() is called. This patch keep track of a listed of completed async direct io that has a work queued on workqueue. When fsync() is called, it will go through the list and do the conversion. Signed-off-by: Mingming Cao <cmm@us.ibm.com>
2009-09-12ext4: Assure that metadata blocks are written during fsync in no journal modeTheodore Ts'o
When there is no journal present, we must attach buffer heads associated with extent tree and indirect blocks to the inode's mapping->private_list via mark_buffer_dirty_inode() so that ext4_sync_file() --- which is called to service fsync() and fdatasync() system calls --- can write out the inode's metadata blocks by calling sync_mapping_buffers(). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-09-05ext4: fix cache flush in ext4_sync_fileChristoph Hellwig
We need to flush the write cache unconditionally in ->fsync, otherwise writes into already allocated blocks can get lost. Writes into fully allocated files are very common when using disk images for virtualization, and without this fix can easily lose data after an fdatasync, which is the typical implementation for a cache flush on the virtual drive. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2009-06-17ext4: convert instrumentation from markers to tracepointsTheodore Ts'o
2008-10-05ext4: Add debugging markers that can be used by systemtapTheodore Ts'o
This debugging markers are designed to debug problems such as the random filesystem latency problems reported by Arjan. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-09-08ext4: Fix whitespace checkpatch warnings/errorsTheodore Ts'o
2008-07-11ext4: call blkdev_issue_flush on fsyncEric Sandeen
To ensure that bits are truly on-disk after an fsync, we should call blkdev_issue_flush if barriers are supported. Inspired by an old thread on barriers, by reiserfs & xfs which do the same, and by a patch SuSE ships with their kernel Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-04-29ext4: move headers out of include/linuxChristoph Hellwig
Move ext4 headers out of include/linux. This is just the trivial move, there's some more thing that could be done later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-04-17ext4: fdatasync should skip metadata writeout when overwritingHisashi Hifumi
Currently fdatasync is identical to fsync in ext3. I think fdatasync should skip journal flush in data=ordered and data=writeback mode when it overwrites to already-instantiated blocks on HDD. When I_DIRTY_DATASYNC flag is not set, fdatasync should skip journal writeout because this indicates only atime or/and mtime updates. Following patch is the same approach of ext2's fsync code(ext2_sync_file). I did a performance test using the sysbench. #sysbench --num-threads=128 --max-requests=50000 --test=fileio --file-total-size=128G --file-test-mode=rndwr --file-fsync-mode=fdatasync run The result on ext3 was: -2.6.24 Operations performed: 0 Read, 50080 Write, 59600 Other = 109680 Total Read 0b Written 782.5Mb Total transferred 782.5Mb (12.116Mb/sec) 775.45 Requests/sec executed Test execution summary: total time: 64.5814s total number of events: 50080 total time taken by event execution: 3713.9836 per-request statistics: min: 0.0000s avg: 0.0742s max: 0.9375s approx. 95 percentile: 0.2901s Threads fairness: events (avg/stddev): 391.2500/23.26 execution time (avg/stddev): 29.0155/1.99 -2.6.24-patched Operations performed: 0 Read, 50009 Write, 61596 Other = 111605 Total Read 0b Written 781.39Mb Total transferred 781.39Mb (16.419Mb/sec) 1050.83 Requests/sec executed Test execution summary: total time: 47.5900s total number of events: 50009 total time taken by event execution: 2934.5768 per-request statistics: min: 0.0000s avg: 0.0587s max: 0.8938s approx. 95 percentile: 0.1993s Threads fairness: events (avg/stddev): 390.6953/22.64 execution time (avg/stddev): 22.9264/1.17 Filesystem I/O throughput was improved. Signed-off-by :Hisashi Hifumi <hifumi.hisashi@oss.ntt.co.jp> Acked-by: Jan Kara <jack@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2007-10-17ext4: sparse fixesAneesh Kumar K.V
Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com>
