path: root/fs/ext3
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-27Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (24 commits) quota: Fix possible oops in __dquot_initialize() ext3: Update kernel-doc comments jbd/2: fixed typos ext2: fixed typo. ext3: Fix debug messages in ext3_group_extend() jbd: Convert atomic_inc() to get_bh() ext3: Remove misplaced BUFFER_TRACE() in ext3_truncate() jbd: Fix debug message in do_get_write_access() jbd: Check return value of __getblk() ext3: Use DIV_ROUND_UP() on group desc block counting ext3: Return proper error code on ext3_fill_super() ext3: Remove unnecessary casts on bh->b_data ext3: Cleanup ext3_setup_super() quota: Fix issuing of warnings from dquot_transfer quota: fix dquot_disable vs dquot_transfer race v2 jbd: Convert bitops to buffer fns ext3/jbd: Avoid WARN() messages when failing to write the superblock jbd: Use offset_in_page() instead of manual calculation jbd: Remove unnecessary goto statement jbd: Use printk_ratelimited() in journal_alloc_journal_head() ...
2010-10-28ext3: Update kernel-doc commentsNamhyung Kim
Update missing/broken argument descriptions and fix formatting. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-28ext3: Fix debug messages in ext3_group_extend()Namhyung Kim
Fix a typo, break long lines and use E3FSBLK on ext3_fsblk_t. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-28ext3: Remove misplaced BUFFER_TRACE() in ext3_truncate()Namhyung Kim
2010-10-28ext3: Use DIV_ROUND_UP() on group desc block countingNamhyung Kim
2010-10-28ext3: Return proper error code on ext3_fill_super()Namhyung Kim
2010-10-28ext3: Remove unnecessary casts on bh->b_dataNamhyung Kim
bh->b_data is already a pointer to char so casts to 'char *' should be meaningless. Remove them. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-28ext3: Cleanup ext3_setup_super()Namhyung Kim
Fix mount-count check to emit warning only if s_max_mnt_count is greater than 0 according to man tune2fs(8). Also removes unnecessary casts. Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-28ext3/jbd: Avoid WARN() messages when failing to write the superblockDarrick J. Wong
This fixes a WARN backtrace in mark_buffer_dirty() that occurs during unmount when the underlying block device is removed. This bug has been seen on System Z when removing all paths from a multipath-backed ext3 mount; on System P when injecting enough PCI EEH errors to make the SCSI controller go offline; and similar warnings have been seen (and patched) with ext2/ext4. The super block update from a previous operation has marked the buffer as in error, and the flag has to be cleared before doing the update. Similar changes have been made to ext4 by commit 914258bf2cb22bf4336a1b1d90c551b4b11ca5aa. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25fs: kill block_prepare_writeChristoph Hellwig
__block_write_begin and block_prepare_write are identical except for slightly different calling conventions. Convert all callers to the __block_write_begin calling conventions and drop block_prepare_write. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-22Merge branch 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.37/barrier' of git://git.kernel.dk/linux-2.6-block: (46 commits) xen-blkfront: disable barrier/flush write support Added blk-lib.c and blk-barrier.c was renamed to blk-flush.c block: remove BLKDEV_IFL_WAIT aic7xxx_old: removed unused 'req' variable block: remove the BH_Eopnotsupp flag block: remove the BLKDEV_IFL_BARRIER flag block: remove the WRITE_BARRIER flag swap: do not send discards as barriers fat: do not send discards as barriers ext4: do not send discards as barriers jbd2: replace barriers with explicit flush / FUA usage jbd2: Modify ASYNC_COMMIT code to not rely on queue draining on barrier jbd: replace barriers with explicit flush / FUA usage nilfs2: replace barriers with explicit flush / FUA usage reiserfs: replace barriers with explicit flush / FUA usage gfs2: replace barriers with explicit flush / FUA usage btrfs: replace barriers with explicit flush / FUA usage xfs: replace barriers with explicit flush / FUA usage block: pass gfp_mask and flags to sb_issue_discard dm: convey that all flushes are processed as empty ...
2010-10-22Merge branch 'vfs' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bklLinus Torvalds
* 'vfs' of git://git.kernel.org/pub/scm/linux/kernel/git/arnd/bkl: (30 commits) BKL: remove BKL from freevxfs BKL: remove BKL from qnx4 autofs4: Only declare function when CONFIG_COMPAT is defined autofs: Only declare function when CONFIG_COMPAT is defined ncpfs: Lock socket in ncpfs while setting its callbacks fs/locks.c: prepare for BKL removal BKL: Remove BKL from ncpfs BKL: Remove BKL from OCFS2 BKL: Remove BKL from squashfs BKL: Remove BKL from jffs2 BKL: Remove BKL from ecryptfs BKL: Remove BKL from afs BKL: Remove BKL from USB gadgetfs BKL: Remove BKL from autofs4 BKL: Remove BKL from isofs BKL: Remove BKL from fat BKL: Remove BKL from ext2 filesystem BKL: Remove BKL from do_new_mount() BKL: Remove BKL from cgroup BKL: Remove BKL from NTFS ...
2010-10-05ext3: Fix lost extented attributes for inode with ino == 11Jan Kara
If a filesystem has inode size > 128 and someone deletes lost+found and reuses inode 11 for some other file, extented attributes set for this inode before umount will get lost after remounting the filesystem. This is because extended attributes will get stored in an inode but ext3_iget will ignore them due to workaround of a bug in an old mkfs. Fix the problem by initializing i_extra_isize to 0 for freshly allocated inodes where mkfs workaround in ext3_iget applies. This way these inodes will always store extended attributes in a special block and no problems occur. The bug was spotted and a reproduction test provided by: Masayoshi MIZUMA <m.mizuma@jp.fujitsu.com> Reviewed-by: Andreas Dilger <adilger.kernel@dilger.ca> Signed-off-by: Jan Kara <jack@suse.cz>
2010-10-04BKL: Remove BKL from ext3_put_super() and ext3_remount()Jan Blunck
The BKL lock is protecting the remounting against a potential call to ext3_put_super(). This could not happen, since this is protected by the s_umount rw semaphore of struct super_block. Therefore I think the BKL is protecting nothing here. Signed-off-by: Jan Blunck <jblunck@infradead.org> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-04BKL: Remove BKL from ext3 fill_super()Jan Blunck
The BKL is protecting nothing than two memory allocations here. Signed-off-by: Jan Blunck <jblunck@infradead.org> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2010-10-04BKL: Explicitly add BKL around get_sb/fill_superJan Blunck
This patch is a preparation necessary to remove the BKL from do_new_mount(). It explicitly adds calls to lock_kernel()/unlock_kernel() around get_sb/fill_super operations for filesystems that still uses the BKL. I've read through all the code formerly covered by the BKL inside do_kern_mount() and have satisfied myself that it doesn't need the BKL any more. do_kern_mount() is already called without the BKL when mounting the rootfs and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called from various places without BKL: simple_pin_fs(), nfs_do_clone_mount() through nfs_follow_mountpoint(), afs_mntpt_do_automount() through afs_mntpt_follow_link(). Both later functions are actually the filesystems follow_link inode operation. vfs_kern_mount() is calling the specified get_sb function and lets the filesystem do its job by calling the given fill_super function. Therefore I think it is safe to push down the BKL from the VFS to the low-level filesystems get_sb/fill_super operation. [arnd: do not add the BKL to those file systems that already don't use it elsewhere] Signed-off-by: Jan Blunck <jblunck@infradead.org> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Christoph Hellwig <hch@infradead.org>
2010-09-16block: remove BLKDEV_IFL_WAITChristoph Hellwig
All the blkdev_issue_* helpers can only sanely be used for synchronous caller. To issue cache flushes or barriers asynchronously the caller needs to set up a bio by itself with a completion callback to move the asynchronous state machine ahead. So drop the BLKDEV_IFL_WAIT flag that is always specified when calling blkdev_issue_* and also remove the now unused flags argument to blkdev_issue_flush and blkdev_issue_zeroout. For blkdev_issue_discard we need to keep it for the secure discard flag, which gains a more descriptive name and loses the bitops vs flag confusion. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-09-10ext3/ext4: Factor out disk addressability checkPatrick J. LoPresti
As part of adding support for OCFS2 to mount huge volumes, we need to check that the sector_t and page cache of the system are capable of addressing the entire volume. An identical check already appears in ext3 and ext4. This patch moves the addressability check into its own function in fs/libfs.c and modifies ext3 and ext4 to invoke it. [Edited to -EINVAL instead of BUG_ON() for bad blocksize_bits -- Joel] Signed-off-by: Patrick LoPresti <lopresti@gmail.com> Cc: linux-ext4@vger.kernel.org Acked-by: Andreas Dilger <adilger@dilger.ca> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (96 commits) no need for list_for_each_entry_safe()/resetting with superblock list Fix sget() race with failing mount vfs: don't hold s_umount over close_bdev_exclusive() call sysv: do not mark superblock dirty on remount sysv: do not mark superblock dirty on mount btrfs: remove junk sb_dirt change BFS: clean up the superblock usage AFFS: wait for sb synchronization when needed AFFS: clean up dirty flag usage cifs: truncate fallout mbcache: fix shrinker function return value mbcache: Remove unused features add f_flags to struct statfs(64) pass a struct path to vfs_statfs update VFS documentation for method changes. All filesystems that need invalidate_inode_buffers() are doing that explicitly convert remaining ->clear_inode() to ->evict_inode() Make ->drop_inode() just return whether inode needs to be dropped fs/inode.c:clear_inode() is gone fs/inode.c:evict() doesn't care about delete vs. non-delete paths now ... Fix up trivial conflicts in fs/nilfs2/super.c
2010-08-09mbcache: Remove unused featuresAndreas Gruenbacher
The mbcache code was written to support a variable number of indexes, but all the existing users use exactly one index. Simplify to code to support only that case. There are also no users of the cache entry free operation, and none of the users keep extra data in cache entries. Remove those features as well. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09convert ext3 to ->evict_inode()Al Viro
2010-08-09remove inode_setattrChristoph Hellwig
Replace inode_setattr with opencoded variants of it in all callers. This moves the remaining call to vmtruncate into the filesystem methods where it can be replaced with the proper truncate sequence. In a few cases it was obvious that we would never end up calling vmtruncate so it was left out in the opencoded variant: spufs: explicitly checks for ATTR_SIZE earlier btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above In addition to that ncpfs called inode_setattr with handcrafted iattrs, which allowed to trim down the opencoded variant. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09introduce __block_write_beginChristoph Hellwig
Split up the block_write_begin implementation - __block_write_begin is a new trivial wrapper for block_prepare_write that always takes an already allocated page and can be either called from block_write_begin or filesystem code that already has a page allocated. Remove the handling of already allocated pages from block_write_begin after switching all callers that do it to __block_write_begin. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09sort out blockdev_direct_IO variantsChristoph Hellwig
Move the call to vmtruncate to get rid of accessive blocks to the callers in prepearation of the new truncate calling sequence. This was only done for DIO_LOCKING filesystems, so the __blockdev_direct_IO_newtrunc variant was not needed anyway. Get rid of blockdev_direct_IO_no_locking and its _newtrunc variant while at it as just opencoding the two additional paramters is shorted than the name suffix. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-05ext3: Fix dirtying of journalled buffers in data=journal modeJan Kara
In data=journal mode, we still use block_write_begin() to prepare page for writing. This function can occasionally mark buffer dirty which violates journalling assumptions - when a buffer is part of a transaction, it should be dirty and a buffer can be already part of a forget list of some transaction when block_write_begin() gets called. This violation of journalling assumptions then results in "JBD: Spotted dirty metadata buffer..." warnings. In fact, temporary dirtying the buffer while the page is still locked does not really cause problems to the journalling because we won't write the buffer until the page gets unlocked. So we just have to make sure to clear dirty bits before unlocking the page. Reviewed-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Jan Kara <jack@suse.cz>
2010-07-23ext3: default to ordered modeDave Chinner
data=writeback mode is dangerous as it leads to higher data loss and stale data exposure when systems crash. It should not be the default, especially when all major distros ensure their ext3 filesystems default to ordered mode. Change the default mode to the safer data=ordered mode, because we should be caring far more about avoiding stale data exposure than performance. CC: linux-ext4@vger.kernel.org Signed-off-by: Dave Chinner <dchinner@redhat.com> Acked-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-07-21ext3: Avoid filesystem corruption after a crash under heavy delete loadJan Kara
It can happen that ext3_free_branches calls ext3_forget() for an indirect block in an earlier transaction than a transaction in which we clear pointer to this indirect block. Thus if we crash before a transaction clearing the block pointer is committed, we will see indirect block pointing to already freed blocks and complain during orphan list cleanup. The fix is simple: Make sure ext3_forget() is called in the transaction doing block pointer clearing. This is a backport of an ext4 fix by Amir G. <amir73il@users.sourceforge.net> Signed-off-by: Jan Kara <jack@suse.cz>
2010-07-21ext3: remove vestiges of nobh supportChristoph Hellwig
The nobh option was only supported for writeback mode, but given that all write paths (except mmapped writed) actually create buffer heads, it effectively was a no-op already. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-07-21ext3: Fix set but unused variablesAndi Kleen
[tytso@mit.edu: Fix compilation with CONFIG_JBD_DEBUG enabled] Acked-by: tytso@mit.edu cc: linux-ext4@vger.kernel.org Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-06-25ext3: update ctime when changing the file's permission by setfaclMiao Xie
ext3 didn't update the ctime of the file when its permission was changed. Steps to reproduce: # touch aaa # stat -c %Z aaa 1275289822 # setfacl -m 'u::x,g::x,o::x' aaa # stat -c %Z aaa 1275289822 <- unchanged But, according to the spec of the ctime, ext3 must update it. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-30Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: quota: Convert quota statistics to generic percpu_counter ext3 uses rb_node = NULL; to zero rb_root. quota: Fixup dquot_transfer reiserfs: Fix resuming of quotas on remount read-write pohmelfs: Remove dead quota code ufs: Remove dead quota code udf: Remove dead quota code quota: rename default quotactl methods to dquot_ quota: explicitly set ->dq_op and ->s_qcop quota: drop remount argument to ->quota_on and ->quota_off quota: move unmount handling into the filesystem quota: kill the vfs_dq_off and vfs_dq_quota_on_remount wrappers quota: move remount handling into the filesystem ocfs2: Fix use after free on remount read-only Fix up conflicts in fs/ext4/super.c and fs/ufs/file.c
2010-05-27drop unused dentry argument to ->fsyncChristoph Hellwig
2010-05-27ext3 uses rb_node = NULL; to zero rb_root.Venkatesh Pallipadi
The problem with this is that 17d9ddc72fb8bba0d4f678 ("rbtree: Add support for augmented rbtrees") in the linux-next tree adds a new field to that struct which needs to be NULLas well. This patch uses RB_ROOT as the intializer so all of the relevant fields will be NULL'd. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Cc: Eric Paris <eparis@redhat.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: rename default quotactl methods to dquot_Christoph Hellwig
Follow the dquot_* style used elsewhere in dquot.c. [Jan Kara: Fixed up missing conversion of ext2] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: drop remount argument to ->quota_on and ->quota_offChristoph Hellwig
Remount handling has fully moved into the filesystem, so all this is superflous now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: move unmount handling into the filesystemChristoph Hellwig
Currently the VFS calls into the quotactl interface for unmounting filesystems. This means filesystems with their own quota handling can't easily distinguish between user-space originating quotaoff and an unount. Instead move the responsibily of the unmount handling into the filesystem to be consistent with all other dquot handling. Note that we do call dquot_disable a lot later now, e.g. after a sync_filesystem. But this is fine as the quota code does all its writes via blockdev's mapping and that is synced even later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: kill the vfs_dq_off and vfs_dq_quota_on_remount wrappersChristoph Hellwig
Instead of having wrappers in the VFS namespace export the dquot_suspend and dquot_resume helpers directly. Also rename vfs_quota_disable to dquot_disable while we're at it. [Jan Kara: Moved dquot_suspend to quotaops.h and made it inline] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: move remount handling into the filesystemChristoph Hellwig
Currently do_remount_sb calls into the dquot code to tell it about going from rw to ro and ro to rw. Move this code into the filesystem to not depend on the dquot code in the VFS - note ocfs2 already ignores these calls and handles remount by itself. This gets rid of overloading the quotactl calls and allows to unify the VFS and XFS codepaths in that area later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (69 commits) fix handling of offsets in cris eeprom.c, get rid of fake on-stack files get rid of home-grown mutex in cris eeprom.c switch ecryptfs_write() to struct inode *, kill on-stack fake files switch ecryptfs_get_locked_page() to struct inode * simplify access to ecryptfs inodes in ->readpage() and friends AFS: Don't put struct file on the stack Ban ecryptfs over ecryptfs logfs: replace inode uid,gid,mode initialization with helper function ufs: replace inode uid,gid,mode initialization with helper function udf: replace inode uid,gid,mode init with helper ubifs: replace inode uid,gid,mode initialization with helper function sysv: replace inode uid,gid,mode initialization with helper function reiserfs: replace inode uid,gid,mode initialization with helper function ramfs: replace inode uid,gid,mode initialization with helper function omfs: replace inode uid,gid,mode initialization with helper function bfs: replace inode uid,gid,mode initialization with helper function ocfs2: replace inode uid,gid,mode initialization with helper function nilfs2: replace inode uid,gid,mode initialization with helper function minix: replace inode uid,gid,mode init with helper ext4: replace inode uid,gid,mode init with helper ... Trivial conflict in fs/fs-writeback.c (mark bitfields unsigned)
2010-05-21ext3: replace inode uid,gid,mode init with helperDmitry Monakhov
Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21ext3: constify xattr handlersStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21Merge branch 'master' into for-2.6.35Jens Axboe
Conflicts: fs/ext3/fsync.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-05-21quota: unify quota init condition in setattrDmitry Monakhov
Quota must being initialized if size or uid/git changes requested. But initialization performed in two different places: in case of i_size file system is responsible for dquot init , but in case of uid/gid init will be called internally in dquot_transfer(). This ambiguity makes code harder to understand. Let's move this logic to one common helper function. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21ext3: make barrier options consistent with ext4Eric Sandeen
ext4 was updated to accept barrier/nobarrier mount options in addition to the older barrier=0/1. The barrier story is complex enough, we should help people by making the options the same at least, even if the defaults are different. This patch allows the barrier/nobarrier mount options for ext3, while keeping nobarrier the default. It also unconditionally displays barrier status in show_options, and prints a message at mount time if barriers are not enabled, just as ext4 does. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21ext3: Fix waiting on transaction during fsyncJan Kara
log_start_commit() returns 1 only when it started a transaction commit. Thus in case transaction commit is already running, we fail to wait for the commit to finish. Fix the issue by always waiting for the commit regardless of the log_start_commit return value. Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21ext3: init statistics after journal recovery v2Dmitry Monakhov
Currently block/inode/dir counters are initialized before journal was recovered. In fact after journal recovery this info will probably change which results in incorrect numbers returned from statfs(2). BUG:#15768 Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21ext3: Avoid loading bitmaps for full groups during block allocationFrans van de Wiel
There is no point in loading bitmap for groups which are completely full. This causes noticeable performance problems (and memory pressure) on small systems with large full filesystem (http://marc.info/?l=linux-ext4&m=126843108314310&w=2). Jan Kara: Added a comment and changed check to use cpu-endian value. Signed-off-by: "Frans van de Wiel" <fvdw@fvdw.eu> Signed-off-by: Jan Kara <jack@suse.cz>
