Missed unlock_super()call is added in error condition code path.
Signed-off-by: Leonid Ananiev <leonid.i.ananiev@intel.com>
One can do "chattr +j" on a file to change its journalling mode. Fix
writeback mode with "nobh" handling for it.
Even though, we mount ext3 filesystem in writeback mode with "nobh" option,
some one can do "chattr +j" on a single file to force it to do journalled
mode. In order to do journaling, ext3_block_truncate_page() need to
fallback to default case of creating buffers and adding them to transaction
etc.
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
This patch fixes illegal __GFP_FS allocation inside ext3 transaction in
ext3_symlink(). Such allocation may re-enter ext3 code from
try_to_free_pages. But JBD/ext3 code keeps a pointer to current journal
handle in task_struct and, hence, is not reentrable.
This bug led to "Assertion failure in journal_dirty_metadata()" messages.
http://bugzilla.openvz.org/show_bug.cgi?id=115
Signed-off-by: Andrey Savochkin <saw@saw.sw.com.sg>
Signed-off-by: Kirill Korotaev <dev@openvz.org>
There is a code path that passed size to ext2_xattr_set
(ext3_xattr_set_handle) before initializing it. The callees don't use the
value in that case, but gcc cannot tell. Always initialize size to get rid
of the warnings.
Signed-off-by: Andreas Gruenbacher <agruen@suse.de>
Migrate a page with buffers without requiring writeback
This introduces a new address space operation migratepage() that may be used
by a filesystem to implement its own version of page migration.
A version is provided that migrates buffers attached to pages. Some
filesystems (ext2, ext3, xfs) are modified to utilize this feature.
The swapper address space operation are modified so that a regular
migrate_page() will occur for anonymous pages without writeback (migrate_pages
forces every anonymous page to have a swap entry).
Signed-off-by: Mike Kravetz <kravetz@us.ibm.com>
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Remove redundant NULL check in ext3_lookup() as d_splice_alias() can take NULL
inode as input.
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
fs: Use <linux/capability.h> where capable() is used.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de>
This patch contains the following cleanups:
- there's no need for ext3_count_free() #ifndef EXT3FS_DEBUG
- having prototypes for ext3_count_free() in two different headers is
nonsense
remove checks now in the VFS
This patch converts the superblock-lock semaphore to a mutex, affecting
lock_super()/unlock_super(). Tested on ext3 and XFS.
This patch converts the inode semaphore to a mutex. I have tested it on
XFS and compiled as much as one can consider on an ia64. Anyway your
luck with it might be different.
Modified-by: Ingo Molnar <mingo@elte.hu>
(finished the conversion)
Signed-off-by: Jes Sorensen <jes@sgi.com>
There are places in the resize code in which EXT3_SB() macro is used after
an statement like sbi = EXT3_SB(sb) is done. Inside the same function,
both sbi and EXT3_SB() are used to reference the super block Altough it is
not wrong, keeping it coherent increases legibility, IMHO.
Signed-off-by: Glauber de Oliveira Costa <glommer@br.ibm.com>
Cc: "Stephen C. Tweedie" <sct@redhat.com>
Cc: Andreas Dilger <adilger@clusterfs.com>
Remove the trailing newlines in calls to ext3_warning(). This function
already adds a trailing newline to the end of messages.
The patch below adds a new mount option to allow the external journal
device to be specified.
The syntax is as follows:
# mount -t ext3 -o journal_dev=0x0820 ...
where 0x0820 means major=8 and minor=32.
Signed-off-by: Johann Lombardi <johann.lombardi@bull.net>
This patch corrects the return value for the EXT3_IOC_GROUP_ADD in case it
fails due to the presence of multiple resizers at the filesystem.
The problem is a little bit more serious than a wrong return value in this
case, since the clause err=0 in the exit_journal path will lead to a call
to update_backups which in turns causes a NULL pointer dereference.
This patch fixes lost referrence on ext3 current handle in
ext3_journalled_writepage().
Signed-Off-By: Denis Lunev <den@sw.ru>
Cc: Kirill Korotaev <dev@sw.ru>
The CONFIG_EXT{2,3}_CHECK options where were never available, and all they
did was to implement a subset of e2fsck in the kernel.
This patch adds tests for the return value of sb_getblk() in the ext2/3
filesystems. In fs/buffer.c it is stated that the getblk() function never
fails. However, it does can return NULL in some situations due to I/O
errors, which may lead us to NULL pointer dereferences
Fix warnings from sparse due to un-declared functions that should either
have a header file or have been declared static
fs/ext2/bitmap.c:14:15: warning: symbol 'ext2_count_free' was not declared. Should it be static?
fs/ext2/namei.c:92:15: warning: symbol 'ext2_get_parent' was not declared. Should it be static?
fs/ext3/bitmap.c:15:15: warning: symbol 'ext3_count_free' was not declared. Should it be static?
fs/ext3/namei.c:1013:15: warning: symbol 'ext3_get_parent' was not declared. Should it be static?
fs/ext3/xattr.c:214:1: warning: symbol 'ext3_xattr_block_get' was not declared. Should it be static?
fs/ext3/xattr.c:358:1: warning: symbol 'ext3_xattr_block_list' was not declared. Should it be static?
fs/ext3/xattr.c:630:1: warning: symbol 'ext3_xattr_block_find' was not declared. Should it be static?
fs/ext3/xattr.c:863:1: warning: symbol 'ext3_xattr_ibody_find' was not declared. Should it be static?
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
I noticed some problems while running ext3 with the debug flag set on.
More precisely, I was unable to umount the filesystem. Some investigation
took me to the patch that follows.
At a first glance , the lock/unlock I've taken out seems really not
necessary, as the main code (outside debug) does not lock the super. The
only additional danger operations that debug code introduces seems to be
related to bitmap, but bitmap operations tends to be all atomic anyway.
I also took the opportunity to fix 2 spelling errors.
Fix compile warning in ext3 quota code.
Signed-off-by: Peter Osterlund <petero2@telia.com>
- ->releasepage() annotated (s/int/gfp_t), instances updated
- missing gfp_t in fs/* added
- fixed misannotation from the original sweep caught by bitwise checks:
XFS used __nocast both for gfp_t and for flags used by XFS allocator.
The latter left with unsigned int __nocast; we might want to add a
different type for those but for now let's leave them alone. That,
BTW, is a case when __nocast use had been actively confusing - it had
been used in the same code for two different and similar types, with
no way to catch misuses. Switch of gfp_t to bitwise had caught that
immediately...
One tricky bit is left alone to be dealt with later - mapping->flags is
a mix of gfp_t and error indications. Left alone for now.
Fix failure paths in ext3_new_inode() and clean up duplicated code: -
DQUOT_DROP() was not being called if ext3_init_security() failed.
Signed-off-by: Chris Sykes <chris@sigsegv.plus.com>
Cc: Stephen Smalley <sds@epoch.ncsc.mil>
Cc: Jan Kara <jack@ucw.cz>
Fix some warnings and a build error when EXT3_DEBUG is enabled.
EXT3_MOUNT_DATA_FLAGS is not a boolean. This fixes it.
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
This patch modifies ext3 to call the inode_init_security LSM hook to obtain
the security attribute for a newly created inode and to set the resulting
attribute on the new inode as part of the same transaction. This parallels
the existing processing for setting ACLs on newly created inodes.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Update the file systems in fs/ implementing a delete_inode() callback to
call truncate_inode_pages(). One implementation note: In developing this
patch I put the calls to truncate_inode_pages() at the very top of those
filesystems delete_inode() callbacks in order to retain the previous
behavior. I'm guessing that some of those could probably be optimized.
Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
Acked-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
If /etc/mtab is a regular file all of the mount options (of a file system)
are written to /etc/mtab by the mount command. The quota tools look there
for the quota strings for their operation. If, however, /etc/mtab is a
symlink to /proc/mounts (a "good thing" in some environments) the tools
don't write anything - they assume the kernel will take care of things.
While the quota options are sent down to the kernel via the mount system
call and the file system codes handle them properly unfortunately there is
no code to echo the quota strings into /proc/mounts and the quota tools
fail in the symlink case.
The attached patchs modify the EXT[2|3] and JFS codes to add the necessary
hooks. The show_options function of each file system in these patches
currently deal with only those things that seemed related to quotas;
especially in the EXT3 case more can be done (later?).
Jan Kara also noted the difficulty in moving these changes above the FS
codes responding similarly to myself to Andrew's comment about possible
VFS migration. Issue summary:
- FS codes have to process the entire string of options anyway.
- Only FS codes that use quotas must have a show_options function (for
quotas to work properly) however quotas are only used in a small number
of FS.
- Since most of the quota using FS support other options these FS codes
should have the a show_options function to show those options - and the
quota echoing becomes virtually negligible.
Based on feedback I have modified my patches from the original:
JFS a missing patch has been restored to the posting
EXT[2|3] and JFS always use the show_options function
- Each FS has at least one FS specific option displayed
- QUOTA output is under a CONFIG_QUOTA ifdef
- a follow-on patch will add a multitude of options for each FS
EXT[2|3] and JFS "quota" is treated as "usrquota"
EXT3 journalled data check for journalled quota removed
EXT[2|3] mount when quota specified but not compiled in
- no changes from my original patch. I tested the patch and the codes
warn but
- still mount. With all due respection I believe the comments
otherwise were a
- misread of the patch. Please reread/test and comment. XFS patch
removed - the XFS team already made the necessary changes EXT3 mixing
old and new quotas are handled differently (not purely exclusive)
- if old and new quotas for the same type are used together the old
type is silently depricated for compatability (e.g. usrquota and
usrjquota)
- mixing of old and new quotas is an error (e.g. usrjquota and
grpquota)
Signed-off-by: Mark Bellon <mbellon@mvista.com>
Acked-by: Dave Kleikamp <shaggy@austin.ibm.com>
This bug could cause oopses and page state corruption, because ncpfs
used the generic page-cache symlink handlign functions. But those
functions only work if the page cache is guaranteed to be "stable", ie a
page that was installed when the symlink walk was started has to still
be installed in the page cache at the end of the walk.
We could have fixed ncpfs to not use the generic helper routines, but it
is in many ways much cleaner to instead improve on the symlink walking
helper routines so that they don't require that absolute stability.
We do this by allowing "follow_link()" to return a error-pointer as a
cookie, which is fed back to the cleanup "put_link()" routine. This
also simplifies NFS symlink handling.
The cache parameter to mb_cache_shrink isn't used. We may as well remove
it.
We must drop references to quota structures before releasing the inode.
Fix a problem with ext3 mount option parsing. When remount of a filesystem
fails, old options are now restored.
We are not using the in-inode space for xattrs in reserved inodes because
mkfs.ext3 doesn't initialize it properly. For those inodes, we set
i_extra_isize to 0. Make sure that we also don't overwrite the
i_extra_isize field when writing out the inode in that case. This is for
cleanliness only, and doesn't fix an actual bug.
Currently in ext3 block reservation code, the global filesystem reservation
tree lock (rsv_block) is hold during the process of searching for a space
to make a new reservation window, including while scaning the block bitmap
to verify if the avalible window has a free block. Holding the lock during
bitmap scan is unnecessary and could possibly cause scalability issue and
latency issues.
This patch tries to address this by dropping the lock before scan the
bitmap. Before that we need to reserve the open window in case someone
else is targetting at the same window. Question was should we reserve the
whole free reservable space or just the window size we need. Reserve the
whole free reservable space will possibly force other threads which
intended to do block allocation nearby move to another block group(cause
bad layout). In this patch, we just reserve the desired size before drop
the lock and scan the block bitmap. This patch fixed a ext3 reservation
latency issue seen on a cvs check out test. Patch is tested with many fsx,
tiobench, dbench and untar a kernel test.
Signed-Off-By: Mingming Cao <cmm@us.ibm.com>
The return value of "match_int" is checked 27 out of 28 times
In lib/parser.c
142 /**
143 * match_int: - scan a decimal representation of an integer from a substring_t
144 * @s: substring_t to be scanned
145 * @result: resulting integer on success
146 *
147 * Description: Attempts to parse the &substring_t @s as a decimal integer. On
148 * success, sets @result to the integer represented by the string and returns 0.
149 * Returns either -ENOMEM or -EINVAL on failure.
150 */
151 int match_int(substring_t *s, int *result)
152 {
153 return match_number(s, result, 0);
154 }
Signed-off-by: Zaur Kambarov <zkambarov@coverity.com>
Use improved credits estimates for quota operations. Also reserve a space
for a quota operation in a transaction only if filesystem was mounted with
some quota options.
This file duplicates <linux/posix_acl_xattr.h>, using slightly different
names.
Henrik Grubbstrom noted:
The 2.6.10 ext3_get_parent attempts to use ext3_find_entry to look up the
entry "..", which fails for dx directories since ".." is not present in the
directory hash table. The patch below solves this by looking up the dotdot
entry in the dx_root block.
Typical symptoms of the above bug are intermittent claims by nfsd that
files or directories are missing on exported ext3 filesystems.
cf https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=3D150759 and
https://bugzilla.redhat.com/bugzilla/show_bug.cgi?id=3D144556
ext3_get_parent() is IMHO the wrong place to fix this bug as it introduces
a lot of internals from htree into that function. Instead, I think this
should be fixed in ext3_find_entry() as in the below patch. This has the
added advantage that it works for any callers of ext3_find_entry() and not
just ext3_lookup_parent().
Signed-off-by: Andreas Dilger <adilger@clusterfs.com>
Signed-off-by: Henrik Grubbstrom <grubba@grubba.org>
Cc: <ext2-devel@lists.sourceforge.net>
Move some code duplicated in both callers into vfs_quota_on_mount
Acked-by: Jan Kara <jack@ucw.cz>
Avoid console spam with ext3 aborted journal.
ext3 usually reports error conditions that it detects in its environment.
But when its journal gets aborted due to such errors, it can sometimes
continue to report that condition forever, spamming the console to such
an extent that the initial first cause of the journal abort can be lost.
When the journal aborts, we put the filesystem into readonly mode. Most
subsequent filesystem operations will get rejected immediately by checks
for MS_RDONLY either in the filesystem or in the VFS. But some paths do
not have such checks --- for example, if we continue to write to a file
handle that was opened before the fs went readonly. (We only check for
the ROFS condition when the file is first opened.) In these cases, we
can continue to generate log errors similar to
EXT3-fs error (device $DEV) in start_transaction: Journal has aborted
for each subsequent write.
There is really no point in generating these errors after the initial
error has been fully reported. Specifically, if we're starting a
completely new filesystem operation, and the filesystem is *already*
readonly (ie. the ext3 layer has already detected and handled the
underlying jbd abort), and we see an EROFS error, then there is simply
no point in reporting it again.
Signed-off-by: Stephen Tweedie <sct@redhat.com>
This had a fatal lock ranking bug: we do journal_start outside
mpage_writepages()'s lock_page().
Revert the whole thing, think again.
Credit-to: Jan Kara <jack@suse.cz>
For identifying the bug.
Cc: Badari Pulavarty <pbadari@us.ibm.com>
The extra race-with-truncate-then-retry logic around
ext3_get_block_handle(), which was inherited from ext2, becomes unecessary
for ext3, since we have already obtained the ei->truncate_sem in
ext3_get_block_handle() before calling ext3_alloc_branch(). The
ei->truncate_sem is already there to block concurrent truncate and block
allocation on the same inode. So the inode's indirect addressing tree
won't be changed after we grab that semaphore.
We could, after get the semaphore, re-verify the branch is up-to-date or
not. If it has been changed, then get the updated branch. If we still
need block allocation, we will have a safe version of the branch to work
with in the ext3_find_goal()/ext3_splice_branch().
The code becomes more readable after remove those retry logic. The patch
also clean up some gotos in ext3_get_block_handle() to make it more
readable.
Signed-off-by: Mingming Cao <cmm@us.ibm.com>
ext[23]_get_acl will return an error when reading the attribute fails or
out-of-memory occurs. Catch this case.
infrastructure for it.
Let it rip!
