path: root/fs/ext2
2012-03-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 1 from Al Viro: "This is _not_ all; in particular, Miklos' and Jan's stuff is not there yet." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits) ext4: initialization of ext4_li_mtx needs to be done earlier debugfs-related mode_t whack-a-mole hfsplus: add an ioctl to bless files hfsplus: change finder_info to u32 hfsplus: initialise userflags qnx4: new helper - try_extent() qnx4: get rid of qnx4_bread/qnx4_getblk take removal of PF_FORKNOEXEC to flush_old_exec() trim includes in inode.c um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it um: embed ->stub_pages[] into mmu_context gadgetfs: list_for_each_safe() misuse ocfs2: fix leaks on failure exits in module_init ecryptfs: make register_filesystem() the last potential failure exit ntfs: forgets to unregister sysctls on register_filesystem() failure logfs: missing cleanup on register_filesystem() failure jfs: mising cleanup on register_filesystem() failure make configfs_pin_fs() return root dentry on success configfs: configfs_create_dir() has parent dentry in dentry->d_parent configfs: sanitize configfs_create() ...
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-03-20vfs: check i_nlink limits in vfs_{mkdir,rename_dir,link}Al Viro
New field of struct super_block - ->s_max_links. Maximal allowed value of ->i_nlink or 0; in the latter case all checks still need to be done in ->link/->mkdir/->rename instances. Note that this limit applies both to directoris and to non-directories. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-20ext2: remove the second argument of k[un]map_atomic()Cong Wang
Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Cong Wang <amwang@redhat.com>
2012-01-11ext2: protect inode changes in the SETVERSION and SETFLAGS ioctlsDjalal Harouni
Unlock mutex after i_flags and i_ctime updates in the EXT2_IOC_SETFLAGS ioctl. Use i_mutex in the EXT2_IOC_SETVERSION ioctl to protect i_ctime and i_generation updates and make the ioctl consistent since i_mutex is also used in other places to protect timestamps and inode changes. Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Djalal Harouni <tixxdz@opendz.org> Signed-off-by: Jan Kara <jack@suse.cz>
2012-01-09Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: ext2/3/4: delete unneeded includes of module.h ext{3,4}: Fix potential race when setversion ioctl updates inode udf: Mark LVID buffer as uptodate before marking it dirty ext3: Don't warn from writepage when readonly inode is spotted after error jbd: Remove j_barrier mutex reiserfs: Force inode evictions before umount to avoid crash reiserfs: Fix quota mount option parsing udf: Treat symlink component of type 2 as / udf: Fix deadlock when converting file from in-ICB one to normal one udf: Cleanup calling convention of inode_getblk() ext2: Fix error handling on inode bitmap corruption ext3: Fix error handling on inode bitmap corruption ext3: replace ll_rw_block with other functions ext3: NULL dereference in ext3_evict_inode() jbd: clear revoked flag on buffers before a new transaction started ext3: call ext3_mark_recovery_complete() when recovery is really needed
2012-01-09ext2/3/4: delete unneeded includes of module.hPaul Gortmaker
Delete any instances of include module.h that were not strictly required. In the case of ext2, the declaration of MODULE_LICENSE etc. were in inode.c but the module_init/exit were in super.c, so relocate the MODULE_LICENCE/AUTHOR block to super.c which makes it consistent with ext3 and ext4 at the same time. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Jan Kara <jack@suse.cz>
2012-01-09ext2: Fix error handling on inode bitmap corruptionJan Kara
When insert_inode_locked() fails in ext2_new_inode() it most likely means inode bitmap got corrupted and we allocated again inode which is already in use. Also doing unlock_new_inode() during error recovery is wrong since the inode does not have I_NEW set. Fix the problem by informing about filesystem error and jumping to fail: (instead of fail_drop:) which doesn't call unlock_new_inode(). Reviewed-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2012-01-06vfs: switch ->show_options() to struct dentry *Al Viro
2012-01-03ext2: propagate umode_tAl Viro
2012-01-03switch ->mknod() to umode_tAl Viro
2012-01-03switch ->create() to umode_tAl Viro
vfs_create() ignores everything outside of 16bit subset of its mode argument; switching it to umode_t is obviously equivalent and it's the only caller of the method Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch vfs_mkdir() and ->mkdir() to umode_tAl Viro
vfs_mkdir() gets int, but immediately drops everything that might not fit into umode_t and that's the only caller of ->mkdir()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03vfs: fix the stupidity with i_dentry in inode destructorsAl Viro
Seeing that just about every destructor got that INIT_LIST_HEAD() copied into it, there is no point whatsoever keeping this INIT_LIST_HEAD in inode_init_once(); the cost of taking it into inode_init_always() will be negligible for pipes and sockets and negative for everything else. Not to mention the removal of boilerplate code from ->destroy_inode() instances... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03vfs: mnt_drop_write_file()Al Viro
new helper (wrapper around mnt_drop_write()) to be used in pair with mnt_want_write_file(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03switch a bunch of places to mnt_want_write_file()Al Viro
it's both faster (in case when file has been opened for write) and cleaner. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-11-02Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/hch/vfs-queue * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/hch/vfs-queue: vfs: add d_prune dentry operation vfs: protect i_nlink filesystems: add set_nlink() filesystems: add missing nlink wrappers logfs: remove unnecessary nlink setting ocfs2: remove unnecessary nlink setting jfs: remove unnecessary nlink setting hypfs: remove unnecessary nlink setting vfs: ignore error on forced remount readlinkat: ensure we return ENOENT for the empty pathname for normal lookups vfs: fix dentry leak in simple_fill_super()
2011-11-02Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: udf: Cleanup metadata flags handling udf: Skip mirror metadata FE loading when metadata FE is ok ext3: Allow quota file use root reservation udf: Remove web reference from UDF MAINTAINERS entry quota: Drop path reference on error exit from quotactl udf: Neaten udf_debug uses udf: Neaten logging output, use vsprintf extension %pV udf: Convert printks to pr_<level> udf: Rename udf_warning to udf_warn udf: Rename udf_error to udf_err udf: Promote some debugging messages to udf_error ext3: Remove the obsolete broken EXT3_IOC32_WAIT_FOR_READONLY. udf: Add readpages support for udf. ext3/balloc.c: local functions should be static ext2: fix the outdated comment in ext2_nfs_get_inode() ext3: remove deprecated oldalloc fs/ext3/balloc.c: delete useless initialization fs/ext2/balloc.c: delete useless initialization ext3: fix message in ext3_remount for rw-remount case ext3: Remove i_mutex from ext3_sync_file() Fix up trivial (printf format cleanup) conflicts in fs/udf/udfdecl.h
2011-11-02filesystems: add set_nlink()Miklos Szeredi
Replace remaining direct i_nlink updates with a new set_nlink() updater function. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-11-02filesystems: add missing nlink wrappersMiklos Szeredi
Replace direct i_nlink updates with the respective updater function (inc_nlink, drop_nlink, clear_nlink, inode_dec_link_count). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
2011-10-31treewide: use __printf not __attribute__((format(printf,...)))Joe Perches
Standardize the style for compiler based printf format verification. Standardized the location of __printf too. Done via script and a little typing. $ grep -rPl --include=*.[ch] -w "__attribute__" * | \ grep -vP "^(tools|scripts|include/linux/compiler-gcc.h)" | \ xargs perl -n -i -e 'local $/; while (<>) { s/\b__attribute__\s*\(\s*\(\s*format\s*\(\s*printf\s*,\s*(.+)\s*,\s*(.+)\s*\)\s*\)\s*\)/__printf($1, $2)/g ; print; }' [akpm@linux-foundation.org: revert arch bits] Signed-off-by: Joe Perches <joe@perches.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-30ext2: fix the outdated comment in ext2_nfs_get_inode()Li Haifeng
Signed-off-by: Li Haifeng <omycle@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-08-17fs/ext2/balloc.c: delete useless initializationJulia Lawall
Delete nontrivial initialization that is immediately overwritten by the result of an allocation function. The semantic match that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ type T; identifier i; expression e; @@ ( T i = \(0\|NULL\|ERR_PTR(...)\); | -T i = e; +T i; ) ... when != i i = \(kzalloc\|kcalloc\|kmalloc\)(...); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Jan Kara <jack@suse.cz>
2011-08-09Merge branch 'next-evm' of ↵James Morris
git://git.kernel.org/pub/scm/linux/kernel/git/zohar/ima-2.6 into next Conflicts: fs/attr.c Resolve conflict manually. Signed-off-by: James Morris <jmorris@namei.org>
2011-08-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: xfs: Fix build breakage in xfs_iops.c when CONFIG_FS_POSIX_ACL is not set VFS: Reorganise shrink_dcache_for_umount_subtree() after demise of dcache_lock VFS: Remove dentry->d_lock locking from shrink_dcache_for_umount_subtree() VFS: Remove detached-dentry counter from shrink_dcache_for_umount_subtree() switch posix_acl_chmod() to umode_t switch posix_acl_from_mode() to umode_t switch posix_acl_equiv_mode() to umode_t * switch posix_acl_create() to umode_t * block: initialise bd_super in bdget() vfs: avoid call to inode_lru_list_del() if possible vfs: avoid taking inode_hash_lock on pipes and sockets vfs: conditionally call inode_wb_list_del() VFS: Fix automount for negative autofs dentries Btrfs: load the key from the dir item in readdir into a fake dentry devtmpfs: missing initialialization in never-hit case hppfs: missing include
2011-08-01switch posix_acl_equiv_mode() to umode_t *Al Viro
... so that &inode->i_mode could be passed to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-08-01switch posix_acl_create() to umode_t *Al Viro
so we can pass &inode->i_mode to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-29ext2: remove duplicate 'ext2_get_acl()' defineLinus Torvalds
When commit 4e34e719e457 ("fs: take the ACL checks to common code") changed the xyz_check_acl() functions into the more natural xyz_get_acl() interface, we grew two copies of the #define ext2_get_acl NULL define for the non-acl case. Remove the extra one. Reported-by: Marco Stornelli <marco.stornelli@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: jbd: change the field "b_cow_tid" of struct journal_head from type unsigned to tid_t ext3.txt: update the links in the section "useful links" to the latest ones ext3: Fix data corruption in inodes with journalled data ext2: check xattr name_len before acquiring xattr_sem in ext2_xattr_get ext3: Fix compilation with -DDX_DEBUG quota: Remove unused declaration jbd: Use WRITE_SYNC in journal checkpoint. jbd: Fix oops in journal_remove_journal_head() ext3: Return -EINVAL when start is beyond the end of fs in ext3_trim_fs() ext3/ioctl.c: silence sparse warnings about different address spaces ext3/ext4 Documentation: remove bh/nobh since it has been deprecated ext3: Improve truncate error handling ext3: use proper little-endian bitops ext2: include fs.h into ext2_fs.h ext3: Fix oops in ext3_try_to_allocate_with_rsv() jbd: fix a bug of leaking jh->b_jcount jbd: remove dependency on __GFP_NOFAIL ext3: Convert ext3 to new truncate calling convention jbd: Add fixed tracepoints ext3: Add fixed tracepoints Resolve conflicts in fs/ext3/fsync.c due to fsync locking push-down and new fixed tracepoints.
2011-07-25fs: take the ACL checks to common codeChristoph Hellwig
Replace the ->check_acl method with a ->get_acl method that simply reads an ACL from disk after having a cache miss. This means we can replace the ACL checking boilerplate code with a single implementation in namei.c. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25kill boilerplates around posix_acl_create_masq()Al Viro
new helper: posix_acl_create(&acl, gfp, mode_p). Replaces acl with modified clone, on failure releases acl and replaces with NULL. Returns 0 or -ve on error. All callers of posix_acl_create_masq() switched. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25kill boilerplate around posix_acl_chmod_masq()Al Viro
new helper: posix_acl_chmod(&acl, gfp, mode). Replaces acl with modified clone or with NULL if that has failed; returns 0 or -ve on error. All callers of posix_acl_chmod_masq() switched to that - they'd been doing exactly the same thing. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25vfs: move ACL cache lookup into generic codeLinus Torvalds
This moves logic for checking the cached ACL values from low-level filesystems into generic code. The end result is a streamlined ACL check that doesn't need to load the inode->i_op->check_acl pointer at all for the common cached case. The filesystems also don't need to check for a non-blocking RCU walk case in their acl_check() functions, because that is all handled at a VFS layer. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-22ext2: check xattr name_len before acquiring xattr_sem in ext2_xattr_getWang Sheng-Hui
In ext2_xattr_get(), the code will acquire xattr_sem first, later checks the length of xattr name_len > 255. It's unnecessarily time consuming and also ext2_xattr_set() checks the length before other checks. So move the check before acquiring xattr_sem to make these two functions consistent. Signed-off-by: Wang Sheng-Hui <shhuiw@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: simplify the blockdev_direct_IO prototypeChristoph Hellwig
Simple filesystems always pass inode->i_sb_bdev as the block device argument, and never need a end_io handler. Let's simply things for them and for my grepping activity by dropping these arguments. The only thing not falling into that scheme is ext4, which passes and end_io handler without needing special flags (yet), but given how messy the direct I/O code there is use of __blockdev_direct_IO in one instead of two out of three cases isn't going to make a large difference anyway. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: move inode_dio_wait calls into ->setattrChristoph Hellwig
Let filesystems handle waiting for direct I/O requests themselves instead of doing it beforehand. This means filesystem-specific locks to prevent new dio referenes from appearing can be held. This is important to allow generalizing i_dio_count to non-DIO_LOCKING filesystems. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20make d_splice_alias(ERR_PTR(err), dentry) = ERR_PTR(err)Al Viro
... and simplify the living hell out of callers Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to ->check_acl()Al Viro
not used in the instances anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: pass MAY_NOT_BLOCK to ->check_acl()Al Viro
2011-07-18security: new security_inode_init_security API adds function callbackMimi Zohar
This patch changes the security_inode_init_security API by adding a filesystem specific callback to write security extended attributes. This change is in preparation for supporting the initialization of multiple LSM xattrs and the EVM xattr. Initially the callback function walks an array of xattrs, writing each xattr separately, but could be optimized to write multiple xattrs at once. For existing security_inode_init_security() calls, which have not yet been converted to use the new callback function, such as those in reiserfs and ocfs2, this patch defines security_old_inode_init_security(). Signed-off-by: Mimi Zohar <zohar@us.ibm.com>
2011-05-17ext2: fix error msg when mounting fs with too-large blocksizeRobin Dong
When ext2 mounts a filesystem, it attempts to set the block device blocksize with a call to sb_set_blocksize, which can fail for several reasons. The current failure message in ext2 prints: EXT2-fs (loop1): error: blocksize is too small which is not correct in all cases. This can be demonstrated by creating a filesystem with # mkfs.ext2 -b 8192 on a 4k page system, and attempting to mount it. Change the error message to a more generic: EXT2-fs (loop1): bad blocksize 8192 to match the error message in ext3. Signed-off-by: Robin Dong <sanbai@taobao.com> Reviewed-by: Coly Li <bosong.ly@taobao.com> Reviewed-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-23userns: rename is_owner_or_cap to inode_owner_or_capableSerge E. Hallyn
And give it a kernel-doc comment. [akpm@linux-foundation.org: btrfs changed in linux-next] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-23bitops: remove ext2 non-atomic bitops from asm/bitops.hAkinobu Mita
As the result of conversions, there are no users of ext2 non-atomic bit operations except for ext2 filesystem itself. Now we can put them into architecture independent code in ext2 filesystem, and remove from asm/bitops.h for all architectures. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-08Merge branch 'master' of git://git.infradead.org/users/eparis/selinux into nextJames Morris
2011-03-02ext2: Fix link count corruption under heavy link+rename loadJosh Hunt
vfs_rename_other() does not lock renamed inode with i_mutex. Thus changing i_nlink in a non-atomic manner (which happens in ext2_rename()) can corrupt it as reported and analyzed by Josh. In fact, there is no good reason to mess with i_nlink of the moved file. We did it presumably to simulate linking into the new directory and unlinking from an old one. But the practical effect of this is disputable because fsck can possibly treat file as being properly linked into both directories without writing any error which is confusing. So we just stop increment-decrement games with i_nlink which also fixes the corruption. CC: stable@kernel.org CC: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Josh Hunt <johunt@akamai.com> Signed-off-by: Jan Kara <jack@suse.cz>
2011-02-01fs/vfs/security: pass last path component to LSM on inode creationEric Paris
SELinux would like to implement a new labeling behavior of newly created inodes. We currently label new inodes based on the parent and the creating process. This new behavior would also take into account the name of the new object when deciding the new label. This is not the (supposed) full path, just the last component of the path. This is very useful because creating /etc/shadow is different than creating /etc/passwd but the kernel hooks are unable to differentiate these operations. We currently require that userspace realize it is doing some difficult operation like that and than userspace jumps through SELinux hoops to get things set up correctly. This patch does not implement new behavior, that is obviously contained in a seperate SELinux patch, but it does pass the needed name down to the correct LSM hook. If no such name exists it is fine to pass NULL. Signed-off-by: Eric Paris <eparis@redhat.com>
