path: root/fs/ext2
2007-10-17ext2 reservationsMartin J. Bligh
Val's cross-port of the ext3 reservations code into ext2. [mbligh@mbligh.org: Small type error for printk [akpm@linux-foundation.org: fix types, sync with ext3] [mbligh@mbligh.org: Bring ext2 reservations code in line with latest ext3] [akpm@linux-foundation.org: kill noisy printk] [akpm@linux-foundation.org: remember to dirty the gdp's block] [akpm@linux-foundation.org: cross-port the missed 5dea5176e5c32ef9f0d1a41d28427b3bf6881b3a] [akpm@linux-foundation.org: cross-port e6022603b9aa7d61d20b392e69edcdbbc1789969] [akpm@linux-foundation.org: Port the omitted 08fb306fe63d98eb86e3b16f4cc21816fa47f18e] [akpm@linux-foundation.org: Backport the missed 20acaa18d0c002fec180956f87adeb3f11f635a6] [akpm@linux-foundation.org: fixes] [cmm@us.ibm.com: fix reservation extension] [bunk@stusta.de: make ext2_get_blocks() static] [hugh@veritas.com: fix hang] [hugh@veritas.com: ext2_new_blocks should reset the reservation window size] [hugh@veritas.com: ext2 balloc: fix off-by-one against rsv_end] [hugh@veritas.com: grp_goal 0 is a genuine goal (unlike -1), so ext2_try_to_allocate_with_rsv should treat it as such] [hugh@veritas.com: rbtree usage cleanup] [pbadari@us.ibm.com: Fix for ext2 reservation] [bunk@kernel.org: remove fs/ext2/balloc.c:reserve_blocks()] [hugh@veritas.com: ext2 balloc: use io_error label] Cc: "Martin J. Bligh" <mbligh@mbligh.org> Cc: Valerie Henson <val_henson@linux.intel.com> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17ext2/4: use is_power_of_2()vignesh babu
Replace n & (n - 1) with is_power_of_2(n) Signed-off-by: vignesh babu <vignesh.babu@wipro.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17ext2/ext3/ext4: add block bitmap validationAneesh Kumar K.V
When a new block bitmap is read from disk in read_block_bitmap() there are a few bits that should ALWAYS be set. In particular, the blocks given by ext4_blk_bitmap, ext4_inode_bitmap and ext4_inode_table. Validate the block bitmap against these blocks. [akpm@linux-foundation.org: cleanups] Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Andreas Dilger <adilger@clusterfs.com> Acked-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17remove unused bh in calls to ext234_get_group_descEric Sandeen
ext[234]_get_group_desc never tests the bh argument, and only sets it if it is passed in; it is perfectly happy with a NULL bh argument. But, many callers send one in and never use it. May as well call with NULL like other callers who don't use the bh. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17ext2: show all mount optionsMiklos Szeredi
Using mtab is problematic for various reasons, one of them is that unprivileged mounts won't turn up in there. So we want to get rid of it, and use /proc/mounts instead. But most filesystems are lazy, and are not showing all mount options. Which means, that without mtab, the user won't be able to see some or all of the options. It would be nice if the generic code could remember the mount options, and show them without the need to add extra code to filesystems. But this is not easy, because different filesystems handle mount options given options, and not tough the rest. This is not taken into account by mount(8) either, so /etc/mtab will be broken in this case. This series fixes up ->show_options() in ext[234]. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17fs: mark nibblemap constPhilippe De Muyter
Signed-off-by: Philippe De Muyter <phdm@macqel.be> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: percpu_counter_init error handlingPeter Zijlstra
alloc_percpu can fail, propagate that error. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: percpu_counter_subPeter Zijlstra
Hugh spotted that some code does: percpu_counter_add(&counter, -unsignedlong) which, when the amount argument is of type s32, sort-of works thanks to two's-complement. However when we'd change the type to s64 this breaks on 32bit machines, because the promotion rules zero extend the unsigned number. Provide percpu_counter_sub() to hide the s64 cast. That is: percpu_counter_sub(&counter, foo) is equal to: percpu_counter_add(&counter, -(s64)foo); Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: percpu_counter_addPeter Zijlstra
s/percpu_counter_mod/percpu_counter_add/ Because its a better name, _mod implies modulo. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16fs: restore nobhNick Piggin
Implement nobh in new aops. This is a bit tricky. FWIW, nobh_truncate is now implemented in a way that does not create blocks in sparse regions, which is a silly thing for it to have been doing (isn't it?) ext2 survives fsx and fsstress. jfs is converted as well... ext3 should be easy to do (but not done yet). [akpm@linux-foundation.org: coding-style fixes] Cc: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16ext2: convert to new aopsNick Piggin
Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26fix inode_table test in ext234_check_descriptorsEric Sandeen
ext[234]_check_descriptors sanity checks block group descriptor geometry at mount time, testing whether the block bitmap, inode bitmap, and inode table reside wholly within the blockgroup. However, the inode table test is off by one so that if the last block in the inode table resides on the last block of the block group, the test incorrectly fails. This is because it tests the last block as (start + length) rather than (start + length - 1). This can be seen by trying to mount a filesystem made such as: mkfs.ext2 -F -b 1024 -m 0 -g 256 -N 3744 fsfile 1024 which yields: EXT2-fs error (device loop0): ext2_check_descriptors: Inode table for group 0 not in group (block 101)! EXT2-fs: group descriptors corrupted! There is a similar bug in e2fsprogs, patch already sent for that. (I wonder if inside(), outside(), and/or in_range() should someday be used in this and other tests throughout the ext filesystems...) Signed-off-by: Eric Sandeen <sandeen@redhat.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19some kmalloc/memset ->kzalloc (tree wide)Yoann Padioleau
Transform some calls to kmalloc/memset to a single kzalloc (or kcalloc). Here is a short excerpt of the semantic patch performing this transformation: @@ type T2; expression x; identifier f,fld; expression E; expression E1,E2; expression e1,e2,e3,y; statement S; @@ x = - kmalloc + kzalloc (E1,E2) ... when != \(x->fld=E;\|y=f(...,x,...);\|f(...,x,...);\|x=E;\|while(...) S\|for(e1;e2;e3) S\) - memset((T2)x,0,E1); @@ expression E1,E2,E3; @@ - kzalloc(E1 * E2,E3) + kcalloc(E1,E2,E3) [akpm@linux-foundation.org: get kcalloc args the right way around] Signed-off-by: Yoann Padioleau <padator@wanadoo.fr> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Bryan Wu <bryan.wu@analog.com> Acked-by: Jiri Slaby <jirislaby@gmail.com> Cc: Dave Airlie <airlied@linux.ie> Acked-by: Roland Dreier <rolandd@cisco.com> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Dmitry Torokhov <dtor@mail.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Acked-by: Pierre Ossman <drzeus-list@drzeus.cx> Cc: Jeff Garzik <jeff@garzik.org> Cc: "David S. Miller" <davem@davemloft.net> Acked-by: Greg KH <greg@kroah.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Introduce is_owner_or_cap() to wrap CAP_FOWNER use with fsuid checkSatyam Sharma
Introduce is_owner_or_cap() macro in fs.h, and convert over relevant users to it. This is done because we want to avoid bugs in the future where we check for only effective fsuid of the current task against a file's owning uid, without simultaneously checking for CAP_FOWNER as well, thus violating its semantics. [ XFS uses special macros and structures, and in general looked ... untouchable, so we leave it alone -- but it has been looked over. ] The (current->fsuid != inode->i_uid) check in generic_permission() and exec_permission_lite() is left alone, because those operations are covered by CAP_DAC_OVERRIDE and CAP_DAC_READ_SEARCH. Similarly operations falling under the purview of CAP_CHOWN and CAP_LEASE are also left alone. Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: exportfs: add exportfs.h headerChristoph Hellwig
currently the export_operation structure and helpers related to it are in fs.h. fs.h is already far too large and there are very few places needing the export bits, so split them off into a separate header. [akpm@linux-foundation.org: fix cifs build] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16ext2: statfs speed upBadari Pulavarty
This is a patch that speeds up statfs. It is very simple - the "overhead" calculation, which takes a huge amount of time for large filesystems, never changes unless the size of the filesystem itself changes. That means we can store it in memory and only recalculate if the filesystem has been resized (almost never). It also fixes a minor problem that we never update the on-disk superblock free blocks/inodes counts until the filesystem is unmounted. While not fatal, we may as well update that on disk when we have the information, and it makes things like debugfs and dumpe2fs report a bit more accurate info. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Andreas Dilger <adilger@clusterfs.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16ext2: fix a comment when ext2_release_file() is calledJan Kara
Signed-off-by: Jan Kara <jack@suse.cz> Acked-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10xip sendfile removalCarsten Otte
This patch removes xip_file_sendfile, the sendfile implementation for xip without replacement. Those customers that use xip on s390 are not using sendfile() as far as we know, and so far s390 is the only platform this could potentially be used on so far. Having sendfile is not a popular feature for execute in place file systems, however we have a working implementation of splice_read() based on fs/splice.c if anyone asks for it. At this point in time, it does not seem preferable to merge splice_read() for xip because it causes extra maintenence effort due to code duplication and it requires struct page behind the xip memory segment. We'd like to get rid of that in favor of supporting flash based embedded platforms (Monta Vista work) soon. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-06-28ext2: fix return of uninitialised variableAndrew Morton
gcc correctly says fs/ext2/super.c: In function 'ext2_remount': fs/ext2/super.c:1055: warning: 'err' may be used uninitialized in this function Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-24ext2: disallow setting xip on remountCarsten Otte
Yan Zheng pointed out that ext2_remount lacks checking if -o xip should be enabled or not. This patch checks for presence of direct_access on the backing block device and if the blocksize meets the requirements. Signed-off-by: Carsten Otte <cotte@de.ibm.com> Cc: Yan Zheng <yanzheng@21cn.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08ext3: copy i_flags to inode flags on writeJan Kara
Propagate flags such as S_APPEND, S_IMMUTABLE, etc. from i_flags into ext2-specific i_flags. Hence, when someone sets these flags via a different interface than ioctl, they are stored correctly. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08ext2/3/4: fix file date underflow on ext2 3 filesystems on 64 bit systemsMarkus Rechberger
Taken from http://bugzilla.kernel.org/show_bug.cgi?id=5079 signed long ranges from -2.147.483.648 to 2.147.483.647 on x86 32bit 10000011110110100100111110111101 .. -2,082,844,739 10000011110110100100111110111101 .. 2,212,122,557 <- this currently gets stored on the disk but when converting it to a 64bit signed long value it loses its sign and becomes positive. Cc: Andreas Dilger <adilger@dilger.ca> Cc: <linux-ext4@vger.kernel.org> Andreas says: This patch is now treating timestamps with the high bit set as negative times (before Jan 1, 1970). This means we lose 1/2 of the possible range of timestamps (lopping off 68 years before unix timestamp overflow - now only 30 years away :-) to handle the extremely rare case of setting timestamps into the distant past. If we are only interested in fixing the underflow case, we could just limit the values to 0 instead of storing negative values. At worst this will skew the timestamp by a few hours for timezones in the far east (files would still show Jan 1, 1970 in "ls -l" output). That said, it seems 32-bit systems (mine at least) allow files to be set into the past (01/01/1907 works fine) so it seems this patch is bringing the x86_64 behaviour into sync with other kernels. On the plus side, we have a patch that is ready to add nanosecond timestamps to ext3 and as an added bonus adds 2 high bits to the on-disk timestamp so this extends the maximum date to 2242. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: make read_cache_page synchronousNick Piggin
Ensure pages are uptodate after returning from read_cache_page, which allows us to cut out most of the filesystem-internal PageUptodate calls. I didn't have a great look down the call chains, but this appears to fixes 7 possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in block2mtd. All depending on whether the filler is async and/or can return with a !uptodate page. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] ext[234]: update documentationAneesh Kumar K.V
Signed-off-by: "Aneesh Kumar K.V" <aneesh.kumar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] fix umask when noACL kernel meets extN tuned for ACLsHugh Dickins
Fix insecure default behaviour reported by Tigran Aivazian: if an ext2 or ext3 or ext4 filesystem is tuned to mount with "acl", but mounted by a kernel built without ACL support, then umask was ignored when creating inodes - though root or user has umask 022, touch creates files as 0666, and mkdir creates directories as 0777. This appears to have worked right until 2.6.11, when a fix to the default mode on symlinks (always 0777) assumed VFS applies umask: which it does, unless the mount is marked for ACLs; but ext[234] set MS_POSIXACL in s_flags according to s_mount_opt set according to def_mount_opts. We could revert to the 2.6.10 ext[234]_init_acl (adding an S_ISLNK test); but other filesystems only set MS_POSIXACL when ACLs are configured. We could fix this at another level; but it seems most robust to avoid setting the s_mount_opt flag in the first place (at the expense of more ifdefs). Likewise don't set the XATTR_USER flag when built without XATTR support. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Cc: <linux-ext4@vger.kernel.org> Cc: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] ext2: skip pages past number of blocks in ext2_find_entryEric Sandeen
This one was pointed out on the MOKB site: http://kernelfun.blogspot.com/2006/11/mokb-09-11-2006-linux-26x-ext2checkpage.html If a directory's i_size is corrupted, ext2_find_entry() will keep processing pages until the i_size is reached, even if there are no more blocks associated with the directory inode. This patch puts in some minimal sanity-checking so that we don't keep checking pages (and issuing errors) if we know there can be no more data to read, based on the block count of the directory inode. This is somewhat similar in approach to the ext3 patch I sent earlier this year. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] LOG2: Implement a general integer log2 facility in the kernelDavid Howells
This facility provides three entry points: ilog2() Log base 2 of unsigned long ilog2_u32() Log base 2 of u32 ilog2_u64() Log base 2 of u64 These facilities can either be used inside functions on dynamic data: int do_something(long q) { ...; y = ilog2(x) ...; } Or can be used to statically initialise global variables with constant values: unsigned n = ilog2(27); When performing static initialisation, the compiler will report "error: initializer element is not constant" if asked to take a log of zero or of something not reducible to a constant. They treat negative numbers as unsigned. When not dealing with a constant, they fall back to using fls() which permits them to use arch-specific log calculation instructions - such as BSR on x86/x86_64 or SCAN on FRV - if available. [akpm@osdl.org: MMC fix] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Herbert Xu <herbert@gondor.apana.org.au> Cc: David Howells <dhowells@redhat.com> Cc: Wojtek Kaniewski <wojtekka@toxygen.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] ext2: change uses of f_{dentry, vfsmnt} to use f_pathJosef "Jeff" Sipek
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the ext2 filesystem. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] protect ext2 ioctl modifying append_only immutable etc with i_mutexAndrew Morton
Port commit a090d9132c1e53e3517111123680c15afb25c0a4 into ext2: All modifications of ->i_flags in inodes that might be visible to somebody else must be under ->i_mutex. That patch fixes ext2 ioctl() setting S_APPEND. Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] Remove superfluous lock_super() in extN xattr codeAndreas Gruenbacher
lock_super() is unnecessary for setting super-block feature flags. Use the provided *_SET_COMPAT_FEATURE() macros as well. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] ext2: fsid for statvfsPekka Enberg
Update ext2_statfs to return an FSID that is a 64 bit XOR of the 128 bit filesystem UUID as suggested by Andreas Dilger. See the following Bugzilla entry for details: http://bugzilla.kernel.org/show_bug.cgi?id=136 Cc: Andreas Dilger <adilger@clusterfs.com> Cc: Stephen Tweedie <sct@redhat.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext2: errors behaviour fixVasily Averin
Current error behaviour for ext2 and ext3 filesystems does not fully correspond to the documentation and should be fixed. According to man 8 mount, ext2 and ext3 file systems allow to set one of 3 different on-errors behaviours: ---- start of quote man 8 mount ---- errors=continue / errors=remount-ro / errors=panic Define the behaviour when an error is encountered. (Either ignore errors and just mark the file system erroneous and continue, or remount the file system read-only, or panic and halt the system.) The default is set in the filesystem superblock, and can be changed using tune2fs(8). ---- end of quote ---- However EXT3_ERRORS_CONTINUE is not read from the superblock, and thus ERRORS_CONT is not saved on the sbi->s_mount_opt. It leads to the incorrect handle of errors on ext3. Then we've checked corresponding code in ext2 and discovered that it is buggy as well: - EXT2_ERRORS_CONTINUE is not read from the superblock (the same); - parse_option() does not clean the alternative values and thus something like (ERRORS_CONT|ERRORS_RO) can be set; - if options are omitted, parse_option() does not set any of these options. Therefore it is possible to set any combination of these options on the ext2: - none of them may be set: EXT2_ERRORS_CONTINUE on superblock / empty mount options; - any of them may be set using mount options; - 2 any options may be set: by using EXT2_ERRORS_RO/EXT2_ERRORS_PANIC on the superblock and other value in mount options; - and finally all three options may be set by adding third option in remount. Currently ext2 uses these values only in ext2_error() and it is not leading to any noticeable troubles. However somebody may be discouraged when he will try to workaround EXT2_ERRORS_PANIC on the superblock by using errors=continue in mount options. This patch: EXT2_ERRORS_CONTINUE should be read from the superblock as default value for error behaviour. parse_option() should clean the alternative options and should not change default value taken from the superblock. Signed-off-by: Vasily Averin <vvs@sw.ru> Acked-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mounts: unlink: monitor i_nlinkDave Hansen
When a filesystem decrements i_nlink to zero, it means that a write must be performed in order to drop the inode from the filesystem. We're shortly going to have keep filesystems from being remounted r/o between the time that this i_nlink decrement and that write occurs. So, add a little helper function to do the decrements. We'll tie into it in a bit to note when i_nlink hits zero. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Streamline generic_file_* interfaces and filemap cleanupsBadari Pulavarty
This patch cleans up generic_file_*_read/write() interfaces. Christoph Hellwig gave me the idea for this clean ups. In a nutshell, all filesystems should set .aio_read/.aio_write methods and use do_sync_read/ do_sync_write() as their .read/.write methods. This allows us to cleanup all variants of generic_file_* routines. Final available interfaces: generic_file_aio_read() - read handler generic_file_aio_write() - write handler generic_file_aio_write_nolock() - no lock write handler __generic_file_aio_write_nolock() - internal worker routine Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Remove readv/writev methods and use aio_read/aio_write insteadBadari Pulavarty
This patch removes readv() and writev() methods and replaces them with aio_read()/aio_write() methods. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] BLOCK: Move the Ext2 device ioctl compat stuff to the Ext2 driver ↵David Howells
[try #6] Move the Ext2 device ioctl compat stuff from fs/compat_ioctl.c to the Ext2 driver so that the Ext2 header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-27[PATCH] Really ignore kmem_cache_destroy return valueAlexey Dobriyan
* Rougly half of callers already do it by not checking return value * Code in drivers/acpi/osl.c does the following to be sure: (void)kmem_cache_destroy(cache); * Those who check it printk something, however, slab_error already printed the name of failed cache. * XFS BUGs on failed kmem_cache_destroy which is not the decision low-level filesystem driver should make. Converted to ignore. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] fs: Removing useless castsPanagiotis Issaris
* Removing useless casts * Removing useless wrapper * Conversion from kmalloc+memset to kzalloc Signed-off-by: Panagiotis Issaris <takis@issaris.org> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] fs: Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to kzalloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Jffs2-bit-acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
