path: root/fs/ext2/xattr_trusted.c
2012-03-31migrate ext2_fs.h guts to fs/ext2/ext2.hAl Viro
2012-01-09ext2/3/4: delete unneeded includes of module.hPaul Gortmaker
Delete any instances of include module.h that were not strictly required. In the case of ext2, the declaration of MODULE_LICENSE etc. were in inode.c but the module_init/exit were in super.c, so relocate the MODULE_LICENCE/AUTHOR block to super.c which makes it consistent with ext3 and ext4 at the same time. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21ext2: constify xattr_handlerStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-16sanitize xattr handler prototypesChristoph Hellwig
Add a flags argument to struct xattr_handler and pass it to all xattr handler methods. This allows using the same methods for multiple handlers, e.g. for the ACL methods which perform exactly the same action for the access and default ACLs, just using a different underlying attribute. With a little more groundwork it'll also allow sharing the methods for the regular user/trusted/secure handlers in extN, ocfs2 and jffs2 like it's already done for xfs in this patch. Also change the inode argument to the handlers to a dentry to allow using the handlers mechnism for filesystems that require it later, e.g. cifs. [with GFS2 bits updated by Steven Whitehouse <swhiteho@redhat.com>] Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-25ext2: remove double definitions of xattr macrosShen Feng
remove the definitions of macros: XATTR_TRUSTED_PREFIX XATTR_USER_PREFIX since they are defined in linux/xattr.h Signed-off-by: Shen Feng <shen@cn.fujitsu.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-01-11[PATCH] capable/capability.h (fs/)Randy Dunlap
fs: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] remove ext2 xattr permission checksakpm@osdl.org
) From: Christoph Hellwig <hch@lst.de> remove checks now in the VFS Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
