path: root/fs/ext2/ialloc.c
2009-03-26ext2: Use lowercase names of quota functionsJan Kara
Use lowercase names of quota functions instead of old uppercase ones. Signed-off-by: Jan Kara <jack@suse.cz> CC: linux-ext4@vger.kernel.org
2009-01-08ext2: tighten restrictions on inode flagsDuane Griffin
At the moment there are few restrictions on which flags may be set on which inodes. Specifically DIRSYNC may only be set on directories and IMMUTABLE and APPEND may not be set on links. Tighten that to disallow TOPDIR being set on non-directories and only NODUMP and NOATIME to be set on non-regular file, non-directories. Introduces a flags masking function which masks flags based on mode and use it during inode creation and when flags are set via the ioctl to facilitate future consistency. Signed-off-by: Duane Griffin <duaneg@dghda.com> Acked-by: Andreas Dilger <adilger@sun.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08ext2: don't inherit inappropriate inode flags from parentDuane Griffin
At present BTREE/INDEX is the only flag that new ext2 inodes do NOT inherit from their parent. In addition prevent the flags DIRTY, ECOMPR, INDEX, IMAGIC and TOPDIR from being inherited. List inheritable flags explicitly to prevent future flags from accidentally being inherited. This fixes the TOPDIR flag inheritance bug reported at http://bugzilla.kernel.org/show_bug.cgi?id=9866. Signed-off-by: Duane Griffin <duaneg@dghda.com> Acked-by: Andreas Dilger <adilger@sun.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-12-31nfsd race fixes: ext2Al Viro
* make ext2_new_inode() put the inode into icache in locked state * do not unlock until the inode is fully set up; otherwise nfsd might pick it in half-baked state. * make sure that ext2_new_inode() does *not* lead to two inodes with the same inumber hashed at the same time; otherwise a bogus fhandle coming from nfsd might race with inode creation: nfsd: iget_locked() creates inode nfsd: try to read from disk, block on that. ext2_new_inode(): allocate inode with that inumber ext2_new_inode(): insert it into icache, set it up and dirty ext2_write_inode(): get the relevant part of inode table in cache, set the entry for our inode (and start writing to disk) nfsd: get CPU again, look into inode table, see nice and sane on-disk inode, set the in-core inode from it oops - we have two in-core inodes with the same inumber live in icache, both used for IO. Welcome to fs corruption... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-11-14CRED: Wrap task credential accesses in the Ext2 filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: linux-ext4@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2008-04-28ext2: le*_add_cpu conversionMarcin Slusarz
replace all: little_endian_variable = cpu_to_leX(leX_to_cpu(little_endian_variable) + expression_in_cpu_byteorder); with: leX_add_cpu(&little_endian_variable, expression_in_cpu_byteorder); generated with semantic patch Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-21ext*: spelling fix prefered -> preferredBenoit Boissinot
Spelling fix: prefered -> preferred Signed-off-by: Benoit Boissinot <benoit.boissinot@ens-lyon.org> Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
2007-10-17ext2 reservationsMartin J. Bligh
Val's cross-port of the ext3 reservations code into ext2. [mbligh@mbligh.org: Small type error for printk [akpm@linux-foundation.org: fix types, sync with ext3] [mbligh@mbligh.org: Bring ext2 reservations code in line with latest ext3] [akpm@linux-foundation.org: kill noisy printk] [akpm@linux-foundation.org: remember to dirty the gdp's block] [akpm@linux-foundation.org: cross-port the missed 5dea5176e5c32ef9f0d1a41d28427b3bf6881b3a] [akpm@linux-foundation.org: cross-port e6022603b9aa7d61d20b392e69edcdbbc1789969] [akpm@linux-foundation.org: Port the omitted 08fb306fe63d98eb86e3b16f4cc21816fa47f18e] [akpm@linux-foundation.org: Backport the missed 20acaa18d0c002fec180956f87adeb3f11f635a6] [akpm@linux-foundation.org: fixes] [cmm@us.ibm.com: fix reservation extension] [bunk@stusta.de: make ext2_get_blocks() static] [hugh@veritas.com: fix hang] [hugh@veritas.com: ext2_new_blocks should reset the reservation window size] [hugh@veritas.com: ext2 balloc: fix off-by-one against rsv_end] [hugh@veritas.com: grp_goal 0 is a genuine goal (unlike -1), so ext2_try_to_allocate_with_rsv should treat it as such] [hugh@veritas.com: rbtree usage cleanup] [pbadari@us.ibm.com: Fix for ext2 reservation] [bunk@kernel.org: remove fs/ext2/balloc.c:reserve_blocks()] [hugh@veritas.com: ext2 balloc: use io_error label] Cc: "Martin J. Bligh" <mbligh@mbligh.org> Cc: Valerie Henson <val_henson@linux.intel.com> Cc: Mingming Cao <cmm@us.ibm.com> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17remove unused bh in calls to ext234_get_group_descEric Sandeen
ext[234]_get_group_desc never tests the bh argument, and only sets it if it is passed in; it is perfectly happy with a NULL bh argument. But, many callers send one in and never use it. May as well call with NULL like other callers who don't use the bh. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17lib: percpu_counter_addPeter Zijlstra
s/percpu_counter_mod/percpu_counter_add/ Because its a better name, _mod implies modulo. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-19[PATCH] EXT2: Remove superblock lock contention in ext2_statfsDave Kleikamp
Fix a performance degradation introduced in 2.6.17. (30% degradation running dbench with 16 threads) Commit 21730eed11de42f22afcbd43f450a1872a0b5ea1, which claims to make EXT2_DEBUG work again, moves the taking of the kernel lock out of debug-only code in ext2_count_free_inodes and ext2_count_free_blocks and into ext2_statfs. The same problem was fixed in ext3 by removing the lock completely (commit 5b11687924e40790deb0d5f959247ade82196665) Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Make EXT2_DEBUG work againValerie Henson
This patch makes EXT2_DEBUG work again. Due to lack of proper include file, EXT2_DEBUG was undefined in bitmap.c and ext2_count_free() is left out. Moved to balloc.c and removed bitmap.c entirely. Second, debug versions of ext2_count_free_{inodes/blocks} reacquires superblock lock. Moved lock into callers. Signed-off-by: Val Henson <val_henson@linux.intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] quota: fix error code for ext2_new_inode()Herbert Poetzl
The quota check in ext2_new_inode() returns ENOSPC where it should return EDQUOT instead. Signed-off-by: Herbert Pötzl <herbert@13thfloor.at> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] remove CONFIG_EXT{2,3}_CHECKAdrian Bunk
The CONFIG_EXT{2,3}_CHECK options where were never available, and all they did was to implement a subset of e2fsck in the kernel. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-28[PATCH] Fix ext2_new_inode() failure pathsChris Sykes
Fix failure paths in ext2_new_inode() and clean up duplicated code: - DQUOT_DROP() was not being called if ext2_init_security() failed. Signed-off-by: Chris Sykes <chris@sigsegv.plus.com> Cc: Stephen Smalley <sds@epoch.ncsc.mil> Cc: Jan Kara <jack@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] ext2: Enable atomic inode security labelingStephen Smalley
This patch modifies ext2 to call the inode_init_security LSM hook to obtain the security attribute for a newly created inode and to set the resulting attribute on the new inode. This parallels the existing processing for setting ACLs on newly created inodes. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] ext2: drop quota reference before releasing inodeJan Kara
We must drop references to quota structures before releasing the inode. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
