Rename the current posix_acl_created to __posix_acl_create and add
a fully featured helper to set up the ACLs on file creation that
uses get_acl().
Rename the current posix_acl_chmod to __posix_acl_chmod and add
a fully featured ACL chmod helper that uses the ->set_acl inode
operation.
Convert ext2, ext3, and ext4 to fully support the posix acl changes,
using e_uid e_gid instead e_id.
Enabled building with posix acls enabled, all filesystems supporting
user namespaces, now also support posix acls when user namespaces are enabled.
Cc: Theodore Tso <tytso@mit.edu>
Cc: Andreas Dilger <adilger.kernel@dilger.ca>
Cc: Jan Kara <jack@suse.cz>
- Pass the user namespace the uid and gid values in the xattr are stored
in into posix_acl_from_xattr.
- Pass the user namespace kuid and kgid values should be converted into
when storing uid and gid values in an xattr in posix_acl_to_xattr.
- Modify all callers of posix_acl_from_xattr and posix_acl_to_xattr to
pass in &init_user_ns.
In the short term this change is not strictly needed but it makes the
code clearer. In the longer term this change is necessary to be able to
mount filesystems outside of the initial user namespace that natively
store posix acls in the linux xattr format.
... so that &inode->i_mode could be passed to it
so we can pass &inode->i_mode to it
Replace the ->check_acl method with a ->get_acl method that simply reads an
ACL from disk after having a cache miss. This means we can replace the ACL
checking boilerplate code with a single implementation in namei.c.
new helper: posix_acl_create(&acl, gfp, mode_p). Replaces acl with
modified clone, on failure releases acl and replaces with NULL.
Returns 0 or -ve on error. All callers of posix_acl_create_masq()
switched.
new helper: posix_acl_chmod(&acl, gfp, mode). Replaces acl with modified
clone or with NULL if that has failed; returns 0 or -ve on error. All
callers of posix_acl_chmod_masq() switched to that - they'd been doing
exactly the same thing.
This moves logic for checking the cached ACL values from low-level
filesystems into generic code. The end result is a streamlined ACL
check that doesn't need to load the inode->i_op->check_acl pointer at
all for the common cached case.
The filesystems also don't need to check for a non-blocking RCU walk
case in their acl_check() functions, because that is all handled at a
VFS layer.
not used in the instances anymore.
And give it a kernel-doc comment.
[akpm@linux-foundation.org: btrfs changed in linux-next]
Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Daniel Lezcano <daniel.lezcano@free.fr>
This simple implementation just checks for no ACLs on the inode, and
if so, then the rcu-walk may proceed, otherwise fail it.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
ext2 didn't update the ctime of the file when its permission was changed.
Steps to reproduce:
# touch aaa
# stat -c %Z aaa
1275289822
# setfacl -m 'u::x,g::x,o::x' aaa
# stat -c %Z aaa
1275289822 <- unchanged
But, according to the spec of the ctime, ext2 must update it.
Port of ext3 patch by Miao Xie <miaox@cn.fujitsu.com>.
Add a flags argument to struct xattr_handler and pass it to all xattr
handler methods. This allows using the same methods for multiple
handlers, e.g. for the ACL methods which perform exactly the same action
for the access and default ACLs, just using a different underlying
attribute. With a little more groundwork it'll also allow sharing the
methods for the regular user/trusted/secure handlers in extN, ocfs2 and
jffs2 like it's already done for xfs in this patch.
Also change the inode argument to the handlers to a dentry to allow
using the handlers mechnism for filesystems that require it later,
e.g. cifs.
[with GFS2 bits updated by Steven Whitehouse <swhiteho@redhat.com>]
Reviewed-by: James Morris <jmorris@namei.org>
Acked-by: Joel Becker <joel.becker@oracle.com>
Don't implement per-filesystem 'extX_permission()' functions that have
to be called for every path component operation, and instead just expose
the actual ACL checking so that the VFS layer can now do it for us.
Acked-by: Serge Hallyn <serue@us.ibm.com>
helpers: get_cached_acl(inode, type), set_cached_acl(inode, type, acl),
forget_cached_acl(inode, type).
ubifs/xattr.c needed includes reordered, the rest is a plain switchover.
current->fs->umask is what most of fs_struct users are doing.
Put that into a helper function.
* kill nameidata * argument; map the 3 bits in ->flags anybody cares
about to new MAY_... ones and pass with the mask.
* kill redundant gfs2_iop_permission()
* sanitize ecryptfs_permission()
* fix remaining places where ->permission() instances might barf on new
MAY_... found in mask.
The obvious next target in that direction is permission(9)
folded fix for nfs_permission() breakage from Miklos Szeredi <mszeredi@suse.cz>
Introduce is_owner_or_cap() macro in fs.h, and convert over relevant
users to it. This is done because we want to avoid bugs in the future
where we check for only effective fsuid of the current task against a
file's owning uid, without simultaneously checking for CAP_FOWNER as
well, thus violating its semantics.
[ XFS uses special macros and structures, and in general looked ...
untouchable, so we leave it alone -- but it has been looked over. ]
The (current->fsuid != inode->i_uid) check in generic_permission() and
exec_permission_lite() is left alone, because those operations are
covered by CAP_DAC_OVERRIDE and CAP_DAC_READ_SEARCH. Similarly operations
falling under the purview of CAP_CHOWN and CAP_LEASE are also left alone.
Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in>
Cc: Al Viro <viro@ftp.linux.org.uk>
Acked-by: Serge E. Hallyn <serge@hallyn.com>
* Removing useless casts
* Removing useless wrapper
* Conversion from kmalloc+memset to kzalloc
Signed-off-by: Panagiotis Issaris <takis@issaris.org>
Acked-by: Dave Kleikamp <shaggy@austin.ibm.com>
There is a code path that passed size to ext2_xattr_set
(ext3_xattr_set_handle) before initializing it. The callees don't use the
value in that case, but gcc cannot tell. Always initialize size to get rid
of the warnings.
Signed-off-by: Andreas Gruenbacher <agruen@suse.de>
fs: Use <linux/capability.h> where capable() is used.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de>
This patch converts the inode semaphore to a mutex. I have tested it on
XFS and compiled as much as one can consider on an ia64. Anyway your
luck with it might be different.
Modified-by: Ingo Molnar <mingo@elte.hu>
(finished the conversion)
Signed-off-by: Jes Sorensen <jes@sgi.com>
This is the fs/ part of the big kfree cleanup patch.
Remove pointless checks for NULL prior to calling kfree() in fs/.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
This file duplicates <linux/posix_acl_xattr.h>, using slightly different
names.
ext[23]_get_acl will return an error when reading the attribute fails or
out-of-memory occurs. Catch this case.
infrastructure for it.
Let it rip!
