path: root/fs/exofs
2013-03-23block: Add bio_for_each_segment_all()Kent Overstreet
__bio_for_each_segment() iterates bvecs from the specified index instead of bio->bv_idx. Currently, the only usage is to walk all the bvecs after the bio has been advanced by specifying 0 index. For immutable bvecs, we need to split these apart; bio_for_each_segment() is going to have a different implementation. This will also help document the intent of code that's using it - bio_for_each_segment_all() is only legal to use for code that owns the bio. Signed-off-by: Kent Overstreet <koverstreet@google.com> CC: Jens Axboe <axboe@kernel.dk> CC: Neil Brown <neilb@suse.de> CC: Boaz Harrosh <bharrosh@panasas.com>
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-22new helper: file_inode(file)Al Viro
2012-12-14exofs: don't leak io_state and pages on read errorBoaz Harrosh
Same bug as fixed by Idan for write_exec was in read_exec. Fix the io_state leak and pages state on read error. Also while at it: The if (!pcol->read_4_write) at the error path is redundant because all goto err; are after the if (pcol->read_4_write) bale out. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-12-11exofs: clean up the correct page collection on write errorIdan Kedar
if ore_write() fails, we would unlock the pages of pcol, which is now empty, rather than pcol_copy which owns the pages when ore_write() is called. this means that no pages will actually be unlocked (pcol.nr_pages == 0) and the writing process (more accurately, the syncing process) will hang waiting for a writeback notification that never comes. moreover, if ore_write() fails, pcol_free() is called for pcol, whereas pcol_copy is the object owning the ore_io_state, thus leaking the ore_io_state. [Boaz] I have simplified Idan's original patch a bit, everything else still holds Signed-off-by: Idan Kedar <idank@tonian.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-10-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull pile 2 of vfs updates from Al Viro: "Stuff in this one - assorted fixes, lglock tidy-up, death to lock_super(). There'll be a VFS pile tomorrow (with patches from Jeff Layton, sanitizing getname() and related parts of audit and preparing for ESTALE fixes), but I'd rather push the stuff in this one ASAP - some of the bugs closed here are quite unpleasant." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: vfs: bogus warnings in fs/namei.c consitify do_mount() arguments lglock: add DEFINE_STATIC_LGLOCK() lglock: make the per_cpu locks static lglock: remove unused DEFINE_LGLOCK_LOCKDEP() MAX_LFS_FILESIZE definition for 64bit needs LL... tmpfs,ceph,gfs2,isofs,reiserfs,xfs: fix fh_len checking vfs: drop lock/unlock super ufs: drop lock/unlock super sysv: drop lock/unlock super hpfs: drop lock/unlock super fat: drop lock/unlock super ext3: drop lock/unlock super exofs: drop lock/unlock super dup3: Return an error when oldfd == newfd. fs: handle failed audit_log_start properly fs: prevent use after free in auditing when symlink following was denied
2012-10-11Merge branch 'for-3.7/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block IO update from Jens Axboe: "Core block IO bits for 3.7. Not a huge round this time, it contains: - First series from Kent cleaning up and generalizing bio allocation and freeing. - WRITE_SAME support from Martin. - Mikulas patches to prevent O_DIRECT crashes when someone changes the block size of a device. - Make bio_split() work on data-less bio's (like trim/discards). - A few other minor fixups." Fixed up silent semantic mis-merge as per Mikulas Patocka and Andrew Morton. It is due to the VM no longer using a prio-tree (see commit 6b2dbba8b6ac: "mm: replace vma prio_tree with an interval tree"). So make set_blocksize() use mapping_mapped() instead of open-coding the internal VM knowledge that has changed. * 'for-3.7/core' of git://git.kernel.dk/linux-block: (26 commits) block: makes bio_split support bio without data scatterlist: refactor the sg_nents scatterlist: add sg_nents fs: fix include/percpu-rwsem.h export error percpu-rw-semaphore: fix documentation typos fs/block_dev.c:1644:5: sparse: symbol 'blkdev_mmap' was not declared blockdev: turn a rw semaphore into a percpu rw semaphore Fix a crash when block device is read and block size is changed at the same time block: fix request_queue->flags initialization block: lift the initial queue bypass mode on blk_register_queue() instead of blk_init_allocated_queue() block: ioctl to zero block ranges block: Make blkdev_issue_zeroout use WRITE SAME block: Implement support for WRITE SAME block: Consolidate command flag and queue limit checks for merges block: Clean up special command handling logic block/blk-tag.c: Remove useless kfree block: remove the duplicated setting for congestion_threshold block: reject invalid queue attribute values block: Add bio_clone_bioset(), bio_clone_kmalloc() block: Consolidate bio_alloc_bioset(), bio_kmalloc() ...
2012-10-09exofs: drop lock/unlock superMarco Stornelli
Removed lock/unlock super. Acked-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Acked-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Marco Stornelli <marco.stornelli@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-10-09Merge branch 'linux-next' of git://git.open-osd.org/linux-open-osdLinus Torvalds
Pull exofs update from Boaz Harrosh: "Just three one liners" * 'linux-next' of git://git.open-osd.org/linux-open-osd: pnfs_osd_xdr: Remove unused #include from pnfs_osd_xdr.h ore: signedness bug in _sp2d_min_pg() exofs: check for allocation failure in uri_store()
2012-10-03ore: signedness bug in _sp2d_min_pg()Dan Carpenter
This for loop doesn't work correctly when "p" is unsigned. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com>
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-10-02fs: push rcu_barrier() from deactivate_locked_super() to filesystemsKirill A. Shutemov
There's no reason to call rcu_barrier() on every deactivate_locked_super(). We only need to make sure that all delayed rcu free inodes are flushed before we destroy related cache. Removing rcu_barrier() from deactivate_locked_super() affects some fast paths. E.g. on my machine exit_group() of a last process in IPC namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace changes from Eric Biederman: "This is a mostly modest set of changes to enable basic user namespace support. This allows the code to code to compile with user namespaces enabled and removes the assumption there is only the initial user namespace. Everything is converted except for the most complex of the filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs, nfs, ocfs2 and xfs as those patches need a bit more review. The strategy is to push kuid_t and kgid_t values are far down into subsystems and filesystems as reasonable. Leaving the make_kuid and from_kuid operations to happen at the edge of userspace, as the values come off the disk, and as the values come in from the network. Letting compile type incompatible compile errors (present when user namespaces are enabled) guide me to find the issues. The most tricky areas have been the places where we had an implicit union of uid and gid values and were storing them in an unsigned int. Those places were converted into explicit unions. I made certain to handle those places with simple trivial patches. Out of that work I discovered we have generic interfaces for storing quota by projid. I had never heard of the project identifiers before. Adding full user namespace support for project identifiers accounts for most of the code size growth in my git tree. Ultimately there will be work to relax privlige checks from "capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing root in a user names to do those things that today we only forbid to non-root users because it will confuse suid root applications. While I was pushing kuid_t and kgid_t changes deep into the audit code I made a few other cleanups. I capitalized on the fact we process netlink messages in the context of the message sender. I removed usage of NETLINK_CRED, and started directly using current->tty. Some of these patches have also made it into maintainer trees, with no problems from identical code from different trees showing up in linux-next. After reading through all of this code I feel like I might be able to win a game of kernel trivial pursuit." Fix up some fairly trivial conflicts in netfilter uid/git logging code. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits) userns: Convert the ufs filesystem to use kuid/kgid where appropriate userns: Convert the udf filesystem to use kuid/kgid where appropriate userns: Convert ubifs to use kuid/kgid userns: Convert squashfs to use kuid/kgid where appropriate userns: Convert reiserfs to use kuid and kgid where appropriate userns: Convert jfs to use kuid/kgid where appropriate userns: Convert jffs2 to use kuid and kgid where appropriate userns: Convert hpfs to use kuid and kgid where appropriate userns: Convert btrfs to use kuid/kgid where appropriate userns: Convert bfs to use kuid/kgid where appropriate userns: Convert affs to use kuid/kgid wherwe appropriate userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids userns: On ia64 deal with current_uid and current_gid being kuid and kgid userns: On ppc convert current_uid from a kuid before printing. userns: Convert s390 getting uid and gid system calls to use kuid and kgid userns: Convert s390 hypfs to use kuid and kgid where appropriate userns: Convert binder ipc to use kuids userns: Teach security_path_chown to take kuids and kgids userns: Add user namespace support to IMA userns: Convert EVM to deal with kuids and kgids in it's hmac computation ...
2012-09-21userns: Convert exofs to use kuid/kgid where appropriateEric W. Biederman
Cc: Benny Halevy <bhalevy@tonian.com> Acked-by: Boaz Harrosh <bharrosh@panasas.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-09-09block: Add bio_clone_bioset(), bio_clone_kmalloc()Kent Overstreet
Previously, there was bio_clone() but it only allocated from the fs bio set; as a result various users were open coding it and using __bio_clone(). This changes bio_clone() to become bio_clone_bioset(), and then we add bio_clone() and bio_clone_kmalloc() as wrappers around it, making use of the functionality the last patch adedd. This will also help in a later patch changing how bio cloning works. Signed-off-by: Kent Overstreet <koverstreet@google.com> CC: Jens Axboe <axboe@kernel.dk> CC: NeilBrown <neilb@suse.de> CC: Alasdair Kergon <agk@redhat.com> CC: Boaz Harrosh <bharrosh@panasas.com> CC: Jeff Garzik <jeff@garzik.org> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-08-12exofs: check for allocation failure in uri_store()Alexey Khoroshilov
There is no memory allocation failure check in uri_store(). That can lead to NULL pointer dereference. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-08-03Merge branch 'for-linus' of git://git.open-osd.org/linux-open-osdLinus Torvalds
Pull exofs update from Boaz Harrosh: "They are all mostly fixes, except the most important patch by Artem Bityutskiy which removes the use of s_dirt. After this patch s_dirt can be completely removed from the tree." * 'for-linus' of git://git.open-osd.org/linux-open-osd: ore: Fix out-of-bounds access in _ios_obj() exofs: Use proper max_IO calculations from ore exofs: Fix __r4w_get_page when offset is beyond i_size exofs: stop using s_dirt exofs: readpage_strip: Add a BUG_ON to check for PageLocked(page)
2012-08-02ore: Fix out-of-bounds access in _ios_obj()Boaz Harrosh
_ios_obj() is accessed by group_index not device_table index. The oc->comps array is only a group_full of devices at a time it is not like ore_comp_dev() which is indexed by a global device_table index. This did not BUG until now because exofs only uses a single COMP for all devices. But with other FSs like PanFS this is not true. This bug was only in the write_path, all other users were using it correctly [This is a bug since 3.2 Kernel] CC: Stable Tree <stable@kernel.org> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-08-02exofs: Use proper max_IO calculations from oreBoaz Harrosh
exofs_max_io_pages should just use the ORE's calculated layout->max_io_length, And avoid unnecessary BUGs, calculations made here were also a layering violation. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-08-02exofs: Fix __r4w_get_page when offset is beyond i_sizeBoaz Harrosh
It is very common for the end of the file to be unaligned on stripe size. But since we know it's beyond file's end then the XOR should be preformed with all zeros. Old code used to just read zeros out of the OSD devices, which is a great waist. But what scares me more about this situation is that, we now have pages attached to the file's mapping that are beyond i_size. I don't like the kind of bugs this calls for. Fix both birds, by returning a global ZERO_PAGE, if offset is beyond i_size. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-08-02exofs: stop using s_dirtArtem Bityutskiy
Exofs has the '->write_super()' handler and makes some use of the '->s_dirt' superblock flag, but it really needs neither of them because it never sets 's_dirt' to one which means the VFS never calls its '->write_super()' handler. Thus, remove both. Note, I am trying to remove both 's_dirt' and 'write_super()' from VFS altogether once all users are gone. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-08-02exofs: readpage_strip: Add a BUG_ON to check for PageLocked(page)Kautuk Consul
readpage_strip can be called from several code paths all of which require that the page be locked before any operations are carried out. Since we export the exofs_readpage callback to the VFS, add a BUG_ON to check for PageLocked(page) to make sure that this understanding is never compromised. Signed-off-by: Kautuk Consul <consul.kautuk@gmail.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-07-23Merge branch 'for-linus-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull the big VFS changes from Al Viro: "This one is *big* and changes quite a few things around VFS. What's in there: - the first of two really major architecture changes - death to open intents. The former is finally there; it was very long in making, but with Miklos getting through really hard and messy final push in fs/namei.c, we finally have it. Unlike his variant, this one doesn't introduce struct opendata; what we have instead is ->atomic_open() taking preallocated struct file * and passing everything via its fields. Instead of returning struct file *, it returns -E... on error, 0 on success and 1 in "deal with it yourself" case (e.g. symlink found on server, etc.). See comments before fs/namei.c:atomic_open(). That made a lot of goodies finally possible and quite a few are in that pile: ->lookup(), ->d_revalidate() and ->create() do not get struct nameidata * anymore; ->lookup() and ->d_revalidate() get lookup flags instead, ->create() gets "do we want it exclusive" flag. With the introduction of new helper (kern_path_locked()) we are rid of all struct nameidata instances outside of fs/namei.c; it's still visible in namei.h, but not for long. Come the next cycle, declaration will move either to fs/internal.h or to fs/namei.c itself. [me, miklos, hch] - The second major change: behaviour of final fput(). Now we have __fput() done without any locks held by caller *and* not from deep in call stack. That obviously lifts a lot of constraints on the locking in there. Moreover, it's legal now to call fput() from atomic contexts (which has immediately simplified life for aio.c). We also don't need anti-recursion logics in __scm_destroy() anymore. There is a price, though - the damn thing has become partially asynchronous. For fput() from normal process we are guaranteed that pending __fput() will be done before the caller returns to userland, exits or gets stopped for ptrace. For kernel threads and atomic contexts it's done via schedule_work(), so theoretically we might need a way to make sure it's finished; so far only one such place had been found, but there might be more. There's flush_delayed_fput() (do all pending __fput()) and there's __fput_sync() (fput() analog doing __fput() immediately). I hope we won't need them often; see warnings in fs/file_table.c for details. [me, based on task_work series from Oleg merged last cycle] - sync series from Jan - large part of "death to sync_supers()" work from Artem; the only bits missing here are exofs and ext4 ones. As far as I understand, those are going via the exofs and ext4 trees resp.; once they are in, we can put ->write_super() to the rest, along with the thread calling it. - preparatory bits from unionmount series (from dhowells). - assorted cleanups and fixes all over the place, as usual. This is not the last pile for this cycle; there's at least jlayton's ESTALE work and fsfreeze series (the latter - in dire need of fixes, so I'm not sure it'll make the cut this cycle). I'll probably throw symlink/hardlink restrictions stuff from Kees into the next pile, too. Plus there's a lot of misc patches I hadn't thrown into that one - it's large enough as it is..." * 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (127 commits) ext4: switch EXT4_IOC_RESIZE_FS to mnt_want_write_file() btrfs: switch btrfs_ioctl_balance() to mnt_want_write_file() switch dentry_open() to struct path, make it grab references itself spufs: shift dget/mntget towards dentry_open() zoran: don't bother with struct file * in zoran_map ecryptfs: don't reinvent the wheels, please - use struct completion don't expose I_NEW inodes via dentry->d_inode tidy up namei.c a bit unobfuscate follow_up() a bit ext3: pass custom EOF to generic_file_llseek_size() ext4: use core vfs llseek code for dir seeks vfs: allow custom EOF in generic_file_llseek code vfs: Avoid unnecessary WB_SYNC_NONE writeback during sys_sync and reorder sync passes vfs: Remove unnecessary flushing of block devices vfs: Make sys_sync writeout also block device inodes vfs: Create function for iterating over block devices vfs: Reorder operations during sys_sync quota: Move quota syncing to ->sync_fs method quota: Split dquot_quota_sync() to writeback and cache flushing part vfs: Move noop_backing_dev_info check from sync into writeback ...
2012-07-20ore: Unlock r4w pages in exact reverse order of lockingBoaz Harrosh
The read-4-write pages are locked in address ascending order. But where unlocked in a way easiest for coding. Fix that, locks should be released in opposite order of locking, .i.e descending address order. I have not hit this dead-lock. It was found by inspecting the dbug print-outs. I suspect there is an higher lock at caller that protects us, but fix it regardless. Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-07-20ore: Remove support of partial IO request (NFS crash)Boaz Harrosh
Do to OOM situations the ore might fail to allocate all resources needed for IO of the full request. If some progress was possible it would proceed with a partial/short request, for the sake of forward progress. Since this crashes NFS-core and exofs is just fine without it just remove this contraption, and fail. TODO: Support real forward progress with some reserved allocations of resources, such as mem pools and/or bio_sets [Bug since 3.2 Kernel] CC: Stable Tree <stable@kernel.org> CC: Benny Halevy <bhalevy@tonian.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-07-20ore: Fix NFS crash by supporting any unaligned RAID IOBoaz Harrosh
In RAID_5/6 We used to not permit an IO that it's end byte is not stripe_size aligned and spans more than one stripe. .i.e the caller must check if after submission the actual transferred bytes is shorter, and would need to resubmit a new IO with the remainder. Exofs supports this, and NFS was supposed to support this as well with it's short write mechanism. But late testing has exposed a CRASH when this is used with none-RPC layout-drivers. The change at NFS is deep and risky, in it's place the fix at ORE to lift the limitation is actually clean and simple. So here it is below. The principal here is that in the case of unaligned IO on both ends, beginning and end, we will send two read requests one like old code, before the calculation of the first stripe, and also a new site, before the calculation of the last stripe. If any "boundary" is aligned or the complete IO is within a single stripe. we do a single read like before. The code is clean and simple by splitting the old _read_4_write into 3 even parts: 1._read_4_write_first_stripe 2. _read_4_write_last_stripe 3. _read_4_write_execute And calling 1+3 at the same place as before. 2+3 before last stripe, and in the case of all in a single stripe then 1+2+3 is preformed additively. Why did I not think of it before. Well I had a strike of genius because I have stared at this code for 2 years, and did not find this simple solution, til today. Not that I did not try. This solution is much better for NFS than the previous supposedly solution because the short write was dealt with out-of-band after IO_done, which would cause for a seeky IO pattern where as in here we execute in order. At both solutions we do 2 separate reads, only here we do it within a single IO request. (And actually combine two writes into a single submission) NFS/exofs code need not change since the ORE API communicates the new shorter length on return, what will happen is that this case would not occur anymore. hurray!! [Stable this is an NFS bug since 3.2 Kernel should apply cleanly] CC: Stable Tree <stable@kernel.org> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-07-14don't pass nameidata to ->create()Al Viro
boolean "does it have to be exclusive?" flag is passed instead; Local filesystem should just ignore it - the object is guaranteed not to be there yet. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-12exofs: fix sparse non-ANSI function warningRandy Dunlap
Fix sparse non-ANSI function warning: fs/exofs/sys.c:112:28: warning: non-ANSI function declaration of function 'exofs_sysfs_dbg_print' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-05-28Merge branch 'for-linus' of git://git.open-osd.org/linux-open-osdLinus Torvalds
Pull exofs updates from Boaz Harrosh: "Just a couple of patches. The first is a BUG fix destined for stable which missed the 3.4-rc7 Kernel. The second is just a fixture addition so exofs is able to be better exported as a cluster file system via pNFS." * 'for-linus' of git://git.open-osd.org/linux-open-osd: exofs: Add SYSFS info for autologin/pNFS export exofs: Fix CRASH on very early IO errors.
2012-05-21exofs: Add SYSFS info for autologin/pNFS exportSachin Bhamare
Introduce sysfs infrastructure for exofs cluster filesystem. Each OSD target shows up as below in the sysfs hierarchy: /sys/fs/exofs/<osdname>_<partition_id>/devX Where <osdname>_<partition_id> is the unique identification of a Superblock. Where devX: 0 <= X < device_table_size. They are ordered in device-table order as specified to the mkfs.exofs command Each OSD device devX has following attributes : osdname - ReadOnly systemid - ReadOnly uri - Read/Write It is up to user-mode to update devX/uri for support of autologin. These sysfs information are used both for autologin as well as support for exporting exofs via a pNFSD server in user-mode. (.eg NFS-Ganesha) Signed-off-by: Sachin Bhamare <sbhamare@panasas.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-05-20exofs: Fix CRASH on very early IO errors.Boaz Harrosh
If at exofs_fill_super() we had an early termination do to any error, like an IO error while reading the super-block. We would crash inside exofs_free_sbi(). This is because sbi->oc.numdevs was set to 1, before we actually have a device table at all. Fix it by moving the sbi->oc.numdevs = 1 to after the allocation of the device table. Reported-by: Johannes Schild <JSchild@gmx.de> Stable: This is a bug since v3.2.0 CC: Stable Tree <stable@kernel.org> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-05-06vfs: Rename end_writeback() to clear_inode()Jan Kara
After we moved inode_sync_wait() from end_writeback() it doesn't make sense to call the function end_writeback() anymore. Rename it to clear_inode() which well says what the function really does - set I_CLEAR flag. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
2012-03-28Merge branch 'for-linus' of git://git.open-osd.org/linux-open-osdLinus Torvalds
Pull trivial exofs changes from Boaz Harrosh: "Just nothingness really. The big exofs changes are reserved for the next merge window." * 'for-linus' of git://git.open-osd.org/linux-open-osd: exofs: Cap on the memcpy() size exofs: (trivial) Fix typo in super.c exofs: fix endian conversion in exofs_sync_fs()
2012-03-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 1 from Al Viro: "This is _not_ all; in particular, Miklos' and Jan's stuff is not there yet." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits) ext4: initialization of ext4_li_mtx needs to be done earlier debugfs-related mode_t whack-a-mole hfsplus: add an ioctl to bless files hfsplus: change finder_info to u32 hfsplus: initialise userflags qnx4: new helper - try_extent() qnx4: get rid of qnx4_bread/qnx4_getblk take removal of PF_FORKNOEXEC to flush_old_exec() trim includes in inode.c um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it um: embed ->stub_pages[] into mmu_context gadgetfs: list_for_each_safe() misuse ocfs2: fix leaks on failure exits in module_init ecryptfs: make register_filesystem() the last potential failure exit ntfs: forgets to unregister sysctls on register_filesystem() failure logfs: missing cleanup on register_filesystem() failure jfs: mising cleanup on register_filesystem() failure make configfs_pin_fs() return root dentry on success configfs: configfs_create_dir() has parent dentry in dentry->d_parent configfs: sanitize configfs_create() ...
2012-03-20switch open-coded instances of d_make_root() to new helperAl Viro
2012-03-20vfs: check i_nlink limits in vfs_{mkdir,rename_dir,link}Al Viro
New field of struct super_block - ->s_max_links. Maximal allowed value of ->i_nlink or 0; in the latter case all checks still need to be done in ->link/->mkdir/->rename instances. Note that this limit applies both to directoris and to non-directories. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-20exofs: remove the second argument of k[un]map_atomic()Cong Wang
Ack-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Cong Wang <amwang@redhat.com>
2012-03-19exofs: Cap on the memcpy() sizeDan Carpenter
This data comes from the device, so probably it's fairly trustworthy but it makes the static checkers happy if we check it. [Boaz] the system_id_len is zero, if not present, or always OSD_SYSTEMID_LEN. So always copy OSD_SYSTEMID_LEN bytes. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-03-19exofs: (trivial) Fix typo in super.cMasanari Iida
Correct spelling "faild" to "failed" in fs/exofs/super.c Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-03-19exofs: fix endian conversion in exofs_sync_fs()Dan Carpenter
fscb->s_numfiles is an __le64 field so we need to use cpu_to_le64() to get a little endian 64 bit on big endian systems. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-01-09Merge branch 'for-linus' of git://git.open-osd.org/linux-open-osdLinus Torvalds
* 'for-linus' of git://git.open-osd.org/linux-open-osd: ore: Must support none-PAGE-aligned IO ore: fix BUG_ON, too few sgs when reading ore: Fix crash in case of an IO error. ore: FIX breakage when MISC_FILESYSTEMS is not set
2012-01-08exofs: oops after late failure in mountAl Viro
We have already set ->s_root, so ->put_super() is going to be called. Freeing ->s_fs_info is a bloody bad idea when it's going to be dereferenced very shortly... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-08ore: Must support none-PAGE-aligned IOBoaz Harrosh
NFS might send us offsets that are not PAGE aligned. So we must read in the reminder of the first/last pages, in cases we need it for Parity calculations. We only add an sg segments to read the partial page. But we don't mark it as read=true because it is a lock-for-write page. TODO: In some cases (IO spans a single unit) we can just adjust the raid_unit offset/length, but this is left for later Kernels. [Bug in 3.2.0 Kernel] CC: Stable Tree <stable@kernel.org> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-01-06ore: fix BUG_ON, too few sgs when readingBoaz Harrosh
When reading RAID5 files, in rare cases, we calculated too few sg segments. There should be two extra for the beginning and end partial units. Also "too few sg segments" should not be a BUG_ON there is all the mechanics in place to handle it, as a short read. So just return -ENOMEM and the rest of the code will gracefully split the IO. [Bug in 3.2.0 Kernel] CC: Stable Tree <stable@kernel.org> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-01-06ore: Fix crash in case of an IO error.Boaz Harrosh
The users of ore_check_io() expect the reported device (In case of error) to be indexed relative to the passed-in ore_components table, and not the logical dev index. This causes a crash inside objlayoutdriver in case of an IO error. [Bug in 3.2.0 Kernel] CC: Stable Tree <stable@kernel.org> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-01-06ore: FIX breakage when MISC_FILESYSTEMS is not setBoaz Harrosh
As Reported by Randy Dunlap When MISC_FILESYSTEMS is not enabled and NFS4.1 is: fs/built-in.o: In function `objio_alloc_io_state': objio_osd.c:(.text+0xcb525): undefined reference to `ore_get_rw_state' fs/built-in.o: In function `_write_done': objio_osd.c:(.text+0xcb58d): undefined reference to `ore_check_io' fs/built-in.o: In function `_read_done': ... When MISC_FILESYSTEMS, which is more of a GUI thing then anything else, is not selected. exofs/Kconfig is never examined during Kconfig, and it can not do it's magic stuff to automatically select everything needed. We must split exofs/Kconfig in two. The ore one is always included. And the exofs one is left in it's old place in the menu. [Needed for the 3.2.0 Kernel] CC: Stable Tree <stable@kernel.org> Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com>
2012-01-03exofs: propagate umode_tAl Viro
2012-01-03switch ->mknod() to umode_tAl Viro
2012-01-03switch ->create() to umode_tAl Viro
vfs_create() ignores everything outside of 16bit subset of its mode argument; switching it to umode_t is obviously equivalent and it's the only caller of the method Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
