[ Upstream commit 92fba084b79e6bc7b12fc118209f1922c1a2df56 ]
In exfat_truncate(), the computation of inode->i_blocks is wrong if
the file is larger than 4 GiB because a 32-bit variable is used as a
mask. This is fixed and simplified by using round_up().
Also fix the same buggy computation in exfat_read_root() and another
(correct) one in exfat_fill_inode(). The latter was fixed another way
last month but can be simplified by using round_up() as well. See:
commit 0c336d6e33f4 ("exfat: fix incorrect loading of i_blocks for
large files")
Fixes: 98d917047e8b ("exfat: add file operations")
Cc: stable@vger.kernel.org # v5.7+
Suggested-by: Matthew Wilcox <willy@infradead.org>
Reviewed-by: Sungjong Seo <sj1557.seo@samsung.com>
Signed-off-by: Christophe Vu-Brugier <christophe.vu-brugier@seagate.com>
Signed-off-by: Namjae Jeon <linkinjeon@kernel.org>
[ Upstream commit 7dee6f57d7f22a89dd214518c778aec448270d4c ]
Also add a local "struct exfat_inode_info *ei" variable to
exfat_truncate() to simplify the code.
commit 0c336d6e33f4bedc443404c89f43c91c8bd9ee11 upstream.
When calculating i_blocks, there was a mistake that was masked with a
32-bit variable. So i_blocks for files larger than 4 GiB had incorrect
values. Mask with a 64-bit variable instead of 32-bit one.
Fixes: 5f2aa075070c ("exfat: add inode operations")
Reported-by: Ganapathi Kamath <hgkamath@hotmail.com>
Signed-off-by: Sungjong Seo <sj1557.seo@samsung.com>
Remove the CONFIG_BLOCK default to __set_page_dirty_buffers and just wire
that method up for the missing instances.
[hch@lst.de: ecryptfs: add a ->set_page_dirty cludge]
Link: https://lkml.kernel.org/r/20210624125250.536369-1-hch@lst.de
Link: https://lkml.kernel.org/r/20210614061512.3966143-4-hch@lst.de
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Cc: Matthew Wilcox (Oracle) <willy@infradead.org>
Cc: Tyler Hicks <code@tyhicks.com>
Degradation of write speed caused by frequent disk access for cluster
bitmap update on every cluster allocation could be improved by
selective syncing bitmap buffer. Change to flush bitmap buffer only
for the directory related operations.
Signed-off-by: Hyeongseok Kim <hyeongseok@gmail.com>
Acked-by: Sungjong Seo <sj1557.seo@samsung.com>
Signed-off-by: Namjae Jeon <namjae.jeon@samsung.com>
Remove 'rwoffset' in exfat_inode_info and replace it with the parameter of
exfat_readdir().
Since rwoffset is referenced only by exfat_readdir(), it is not necessary
a exfat_inode_info's member.
Also, change cpos to point to the next of entry-set, and return the index
of dir-entry via dir_entry->entry.
Signed-off-by: Tetsuhiro Kohada <kohada.t2@gmail.com>
Use structure assignment instead of memcpy.
syzbot reported warning message:
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0x1d6/0x29e lib/dump_stack.c:118
register_lock_class+0xf06/0x1520 kernel/locking/lockdep.c:893
__lock_acquire+0xfd/0x2ae0 kernel/locking/lockdep.c:4320
lock_acquire+0x148/0x720 kernel/locking/lockdep.c:5029
__raw_spin_lock include/linux/spinlock_api_smp.h:142 [inline]
_raw_spin_lock+0x2a/0x40 kernel/locking/spinlock.c:151
spin_lock include/linux/spinlock.h:354 [inline]
exfat_cache_inval_inode+0x30/0x280 fs/exfat/cache.c:226
exfat_evict_inode+0x124/0x270 fs/exfat/inode.c:660
evict+0x2bb/0x6d0 fs/inode.c:576
exfat_fill_super+0x1e07/0x27d0 fs/exfat/super.c:681
get_tree_bdev+0x3e9/0x5f0 fs/super.c:1342
vfs_get_tree+0x88/0x270 fs/super.c:1547
do_new_mount fs/namespace.c:2875 [inline]
path_mount+0x179d/0x29e0 fs/namespace.c:3192
do_mount fs/namespace.c:3205 [inline]
__do_sys_mount fs/namespace.c:3413 [inline]
__se_sys_mount+0x126/0x180 fs/namespace.c:3390
do_syscall_64+0x31/0x70 arch/x86/entry/common.c:46
entry_SYSCALL_64_after_hwframe+0x44/0xa9
If exfat_read_root() returns an error, spinlock is used in
exfat_evict_inode() without initialization. This patch combines
exfat_cache_init_inode() with exfat_inode_init_once() to initialize
spinlock by slab constructor.
Fixes: c35b6810c495 ("exfat: add exfat cache")
Reported-by: syzbot <syzbot+b91107320911a26c9a95@syzkaller.appspotmail.com>
MediaFailure and VolumeDirty should be retained if these are set before
mounting.
In '3.1.13.3 Media Failure Field' of exfat specification describe:
If, upon mounting a volume, the value of this field is 1,
implementations which scan the entire volume for media failures and
record all failures as "bad" clusters in the FAT (or otherwise resolve
media failures) may clear the value of this field to 0.
Therefore, We should not clear MediaFailure without scanning volume.
In '8.1 Recommended Write Ordering' of exfat specification describe:
Clear the value of the VolumeDirty field to 0, if its value prior to
the first step was 0.
Therefore, We should not clear VolumeDirty after mounting.
Also rename ERR_MEDIUM to MEDIA_FAILURE.
Add error check when synchronously updating dir-entries.
Suggested-by: Sungjong Seo <sj1557.seo@samsung.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linkinjeon/exfat
Pull exfat update from Namjae Jeon:
"Bug fixes:
- Fix memory leak on mount failure with iocharset= option
- Fix incorrect update of stream entry
- Fix cluster range validation error
Clean-ups:
- Remove unused code and unneeded assignment
- Rename variables in exfat structure as specification
- Reorganize boot sector analysis code
- Simplify exfat_utf8_d_hash and exfat_utf8_d_cmp()
- Optimize exfat entry cache functions
- Improve wording of EXFAT_DEFAULT_IOCHARSET config option
New Feature:
- Add boot region verification"
* tag 'exfat-for-5.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/linkinjeon/exfat:
exfat: Fix potential use after free in exfat_load_upcase_table()
exfat: fix range validation error in alloc and free cluster
exfat: fix incorrect update of stream entry in __exfat_truncate()
exfat: fix memory leak in exfat_parse_param()
exfat: remove unnecessary reassignment of p_uniname->name_len
exfat: standardize checksum calculation
exfat: add boot region verification
exfat: separate the boot sector analysis
exfat: redefine PBR as boot_sector
exfat: optimize dir-cache
exfat: replace 'time_ms' with 'time_cs'
exfat: remove the assignment of 0 to bool variable
exfat: Remove unused functions exfat_high_surrogate() and exfat_low_surrogate()
exfat: Simplify exfat_utf8_d_hash() for code points above U+FFFF
exfat: Improve wording of EXFAT_DEFAULT_IOCHARSET config option
exfat: Use a more common logging style
exfat: Simplify exfat_utf8_d_cmp() for code points above U+FFFF
Optimize directory access based on exfat_entry_set_cache.
- Hold bh instead of copied d-entry.
- Modify bh->data directly instead of the copied d-entry.
- Write back the retained bh instead of rescanning the d-entry-set.
And
- Remove unused cache related definitions.
Signed-off-by: Tetsuhiro Kohada <kohada.tetsuhiro@dc.mitsubishielectric.co.jp>
Replace time_ms with time_cs in the file directory entry structure
and related functions.
The unit of create_time_ms/modify_time_ms in File Directory Entry are not
'milli-second', but 'centi-second'.
The exfat specification uses the term '10ms', but instead use 'cs' as in
msdos_fs.h.
Implement the new readahead aop and convert all callers (block_dev,
exfat, ext2, fat, gfs2, hpfs, isofs, jfs, nilfs2, ocfs2, omfs, qnx6,
reiserfs & udf).
The callers are all trivial except for GFS2 & OCFS2.
Signed-off-by: Matthew Wilcox (Oracle) <willy@infradead.org>
Reviewed-by: Junxiao Bi <junxiao.bi@oracle.com> # ocfs2
Reviewed-by: Joseph Qi <joseph.qi@linux.alibaba.com> # ocfs2
Reviewed-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: John Hubbard <jhubbard@nvidia.com>
Reviewed-by: William Kucharski <william.kucharski@oracle.com>
Cc: Chao Yu <yuchao0@huawei.com>
Cc: Cong Wang <xiyou.wangcong@gmail.com>
Cc: Darrick J. Wong <darrick.wong@oracle.com>
Cc: Eric Biggers <ebiggers@google.com>
Cc: Gao Xiang <gaoxiang25@huawei.com>
Cc: Jaegeuk Kim <jaegeuk@kernel.org>
Cc: Michal Hocko <mhocko@suse.com>
Cc: Zi Yan <ziy@nvidia.com>
Cc: Johannes Thumshirn <johannes.thumshirn@wdc.com>
Cc: Miklos Szeredi <mszeredi@redhat.com>
Link: http://lkml.kernel.org/r/20200414150233.24495-17-willy@infradead.org
This adds the implementation of inode operations for exfat.
Reviewed-by: Pali Rohár <pali.rohar@gmail.com>
