path: root/fs/ecryptfs/super.c
2009-09-23ecryptfs: Remove unneeded locking that triggers lockdep false positivesRoland Dreier
In ecryptfs_destroy_inode(), inode_info->lower_file_mutex is locked, and just after the mutex is unlocked, the code does: kmem_cache_free(ecryptfs_inode_info_cache, inode_info); This means that if another context could possibly try to take the same mutex as ecryptfs_destroy_inode(), then it could end up getting the mutex just before the data structure containing the mutex is freed. So any such use would be an obvious use-after-free bug (catchable with slab poisoning or mutex debugging), and therefore the locking in ecryptfs_destroy_inode() is not needed and can be dropped. Similarly, in ecryptfs_destroy_crypt_stat(), crypt_stat->keysig_list_mutex is locked, and then the mutex is unlocked just before the code does: memset(crypt_stat, 0, sizeof(struct ecryptfs_crypt_stat)); Therefore taking this mutex is similarly not necessary. Removing this locking fixes false-positive lockdep reports such as the following (and they are false-positives for exactly the same reason that the locking is not needed): ================================= [ INFO: inconsistent lock state ] 2.6.31-2-generic #14~rbd3 --------------------------------- inconsistent {RECLAIM_FS-ON-W} -> {IN-RECLAIM_FS-W} usage. kswapd0/323 [HC0[0]:SC0[0]:HE1:SE1] takes: (&inode_info->lower_file_mutex){+.+.?.}, at: [<ffffffff81210d34>] ecryptfs_destroy_inode+0x34/0x100 {RECLAIM_FS-ON-W} state was registered at: [<ffffffff8108c02c>] mark_held_locks+0x6c/0xa0 [<ffffffff8108c10f>] lockdep_trace_alloc+0xaf/0xe0 [<ffffffff81125a51>] kmem_cache_alloc+0x41/0x1a0 [<ffffffff8113117a>] get_empty_filp+0x7a/0x1a0 [<ffffffff8112dd46>] dentry_open+0x36/0xc0 [<ffffffff8121a36c>] ecryptfs_privileged_open+0x5c/0x2e0 [<ffffffff81210283>] ecryptfs_init_persistent_file+0xa3/0xe0 [<ffffffff8120e838>] ecryptfs_lookup_and_interpose_lower+0x278/0x380 [<ffffffff8120f97a>] ecryptfs_lookup+0x12a/0x250 [<ffffffff8113930a>] real_lookup+0xea/0x160 [<ffffffff8113afc8>] do_lookup+0xb8/0xf0 [<ffffffff8113b518>] __link_path_walk+0x518/0x870 [<ffffffff8113bd9c>] path_walk+0x5c/0xc0 [<ffffffff8113be5b>] do_path_lookup+0x5b/0xa0 [<ffffffff8113bfe7>] user_path_at+0x57/0xa0 [<ffffffff811340dc>] vfs_fstatat+0x3c/0x80 [<ffffffff8113424b>] vfs_stat+0x1b/0x20 [<ffffffff81134274>] sys_newstat+0x24/0x50 [<ffffffff81013132>] system_call_fastpath+0x16/0x1b [<ffffffffffffffff>] 0xffffffffffffffff irq event stamp: 7811 hardirqs last enabled at (7811): [<ffffffff810c037f>] call_rcu+0x5f/0x90 hardirqs last disabled at (7810): [<ffffffff810c0353>] call_rcu+0x33/0x90 softirqs last enabled at (3764): [<ffffffff810631da>] __do_softirq+0x14a/0x220 softirqs last disabled at (3751): [<ffffffff8101440c>] call_softirq+0x1c/0x30 other info that might help us debug this: 2 locks held by kswapd0/323: #0: (shrinker_rwsem){++++..}, at: [<ffffffff810f67ed>] shrink_slab+0x3d/0x190 #1: (&type->s_umount_key#35){.+.+..}, at: [<ffffffff811429a1>] prune_dcache+0xd1/0x1b0 stack backtrace: Pid: 323, comm: kswapd0 Tainted: G C 2.6.31-2-generic #14~rbd3 Call Trace: [<ffffffff8108ad6c>] print_usage_bug+0x18c/0x1a0 [<ffffffff8108aff0>] ? check_usage_forwards+0x0/0xc0 [<ffffffff8108bac2>] mark_lock_irq+0xf2/0x280 [<ffffffff8108bd87>] mark_lock+0x137/0x1d0 [<ffffffff81164710>] ? fsnotify_clear_marks_by_inode+0x30/0xf0 [<ffffffff8108bee6>] mark_irqflags+0xc6/0x1a0 [<ffffffff8108d337>] __lock_acquire+0x287/0x430 [<ffffffff8108d585>] lock_acquire+0xa5/0x150 [<ffffffff81210d34>] ? ecryptfs_destroy_inode+0x34/0x100 [<ffffffff8108d2e7>] ? __lock_acquire+0x237/0x430 [<ffffffff815526ad>] __mutex_lock_common+0x4d/0x3d0 [<ffffffff81210d34>] ? ecryptfs_destroy_inode+0x34/0x100 [<ffffffff81164710>] ? fsnotify_clear_marks_by_inode+0x30/0xf0 [<ffffffff81210d34>] ? ecryptfs_destroy_inode+0x34/0x100 [<ffffffff8129a91e>] ? _raw_spin_unlock+0x5e/0xb0 [<ffffffff81552b36>] mutex_lock_nested+0x46/0x60 [<ffffffff81210d34>] ecryptfs_destroy_inode+0x34/0x100 [<ffffffff81145d27>] destroy_inode+0x87/0xd0 [<ffffffff81146b4c>] generic_delete_inode+0x12c/0x1a0 [<ffffffff81145832>] iput+0x62/0x70 [<ffffffff811423c8>] dentry_iput+0x98/0x110 [<ffffffff81142550>] d_kill+0x50/0x80 [<ffffffff81142623>] prune_one_dentry+0xa3/0xc0 [<ffffffff811428b1>] __shrink_dcache_sb+0x271/0x290 [<ffffffff811429d9>] prune_dcache+0x109/0x1b0 [<ffffffff81142abf>] shrink_dcache_memory+0x3f/0x50 [<ffffffff810f68dd>] shrink_slab+0x12d/0x190 [<ffffffff810f9377>] balance_pgdat+0x4d7/0x640 [<ffffffff8104c4c0>] ? finish_task_switch+0x40/0x150 [<ffffffff810f63c0>] ? isolate_pages_global+0x0/0x60 [<ffffffff810f95f7>] kswapd+0x117/0x170 [<ffffffff810777a0>] ? autoremove_wake_function+0x0/0x40 [<ffffffff810f94e0>] ? kswapd+0x0/0x170 [<ffffffff810773be>] kthread+0x9e/0xb0 [<ffffffff8101430a>] child_rip+0xa/0x20 [<ffffffff81013c90>] ? restore_args+0x0/0x30 [<ffffffff81077320>] ? kthread+0x0/0xb0 [<ffffffff81014300>] ? child_rip+0x0/0x20 Signed-off-by: Roland Dreier <roland@digitalvampire.org> Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2009-06-11push BKL down into ->put_superChristoph Hellwig
Move BKL into ->put_super from the only caller. A couple of filesystems had trivial enough ->put_super (only kfree and NULLing of s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs, hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most of them probably don't need it, but I'd rather sort that out individually. Preferably after all the other BKL pushdowns in that area. [AV: original used to move lock_super() down as well; these changes are removed since we don't do lock_super() at all in generic_shutdown_super() now] [AV: fuse, btrfs and xfs are known to need no damn BKL, exempt] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-22eCryptfs: Remove ecryptfs_unlink_sigs warningsTyler Hicks
A feature was added to the eCryptfs umount helper to automatically unlink the keys used for an eCryptfs mount from the kernel keyring upon umount. This patch keeps the unrecognized mount option warnings for ecryptfs_unlink_sigs out of the logs. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2009-04-22eCryptfs: Print FNEK sig properly in /proc/mountsTyler Hicks
The filename encryption key signature is not properly displayed in /proc/mounts. The "ecryptfs_sig=" mount option name is displayed for all global authentication tokens, included those for filename keys. This patch checks the global authentication token flags to determine if the key is a FEKEK or FNEK and prints the appropriate mount option name before the signature. Signed-off-by: Tyler Hicks <tyhicks@linux.vnet.ibm.com>
2008-02-06ecryptfs: remove debug as mount option, and warn if set via modprobeEric Sandeen
ecryptfs_debug really should not be a mount option; it is not per-mount, but rather sets a global "ecryptfs_verbosity" variable which affects all mounted filesysytems. It's already settable as a module load option, I think we can leave it at that. Also, if set, since secret values come out in debug messages, kick things off with a stern warning. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Acked-by: Mike Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06ecryptfs: make show_options reflect actual mount optionsEric Sandeen
Change ecryptfs_show_options to reflect the actual mount options in use. Note that this does away with the "dir=" output, which is not a valid mount option and appears to be unused. Mount options such as "ecryptfs_verbose" and "ecryptfs_xattr_metadata" are somewhat indeterminate for a given fs, but in any case the reported mount options can be used in a new mount command to get the same behavior. [akpm@linux-foundation.org: fix printk warning] Signed-off-by: Eric Sandeen <sandeen@redhat.com> Acked-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-08eCryptfs: fix dentry handling on create error, unlink, and inode destroyMichael Halcrow
This patch corrects some erroneous dentry handling in eCryptfs. If there is a problem creating the lower file, then there is nothing that the persistent lower file can do to really help us. This patch makes a vfs_create() failure in the lower filesystem always lead to an unconditional do_create failure in eCryptfs. Under certain sequences of operations, the eCryptfs dentry can remain in the dcache after an unlink. This patch calls d_drop() on the eCryptfs dentry to correct this. eCryptfs has no business calling d_delete() directly on a lower filesystem's dentry. This patch removes the call to d_delete() on the lower persistent file's dentry in ecryptfs_destroy_inode(). (Thanks to David Kleikamp, Eric Sandeen, and Jeff Moyer for helping identify and resolve this issue) Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Eric Sandeen <sandeen@redhat.com> Cc: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: initialize persistent lower file on inode createMichael Halcrow
Initialize persistent lower file on inode create. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: set up and destroy persistent lower fileMichael Halcrow
This patch sets up and destroys the persistent lower file for each eCryptfs inode. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16eCryptfs: grammatical fix (destruct to destroy)Michael Halcrow
Andrew Morton wrote: > > +int ecryptfs_destruct_crypto(void) > > ecryptfs_destroy_crypto would be more grammatically correct ;) Grammatical fix for some function names. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-31[PATCH] eCryptfs: Remove ecryptfs_umount_beginMichael Halcrow
There is no point to calling the lower umount_begin when the eCryptfs umount_begin is called. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04[PATCH] ecryptfs: fs/Makefile and fs/KconfigMichael Halcrow
eCryptfs is a stacked cryptographic filesystem for Linux. It is derived from Erez Zadok's Cryptfs, implemented through the FiST framework for generating stacked filesystems. eCryptfs extends Cryptfs to provide advanced key management and policy features. eCryptfs stores cryptographic metadata in the header of each file written, so that encrypted files can be copied between hosts; the file will be decryptable with the proper key, and there is no need to keep track of any additional information aside from what is already in the encrypted file itself. [akpm@osdl.org: updates for ongoing API changes] [bunk@stusta.de: cleanups] [akpm@osdl.org: alpha build fix] [akpm@osdl.org: cleanups] [tytso@mit.edu: inode-diet updates] [pbadari@us.ibm.com: generic_file_*_read/write() interface updates] [rdunlap@xenotime.net: printk format fixes] [akpm@osdl.org: make slab creation and teardown table-driven] Signed-off-by: Phillip Hellewell <phillip@hellewell.homeip.net> Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
