path: root/fs/dlm
2009-07-14dlm: free socket in error exit pathCasey Dahlin
In the tcp_connect_to_sock() error exit path, the socket allocated at the top of the function was not being freed. Signed-off-by: Casey Dahlin <cdahlin@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2009-06-18dlm: fix plock use-after-freeDavid Teigland
Fix a regression from the original addition of nfs lock support 586759f03e2e9031ac5589912a51a909ed53c30a. When a synchronous (non-nfs) plock completes, the waiting thread will wake up and free the op struct. This races with the user thread in dev_write() which goes on to read the op's callback field to check if the lock is async and needs a callback. This check can happen on the freed op. The fix is to note the callback value before the op can be freed. Signed-off-by: David Teigland <teigland@redhat.com>
2009-06-17dlm: Fix uninitialised variable warning in lock.cSteven Whitehouse
CC [M] fs/dlm/lock.o fs/dlm/lock.c: In function ‘find_rsb’: fs/dlm/lock.c:438: warning: ‘r’ may be used uninitialized in this function Since r is used on the error path to set r_ret, set it to NULL. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2009-05-15dlm: use more NOFS allocationDavid Teigland
Change some GFP_KERNEL allocations to use either GFP_NOFS or ls_allocation (when available) which the fs sets to GFP_NOFS. The point is to prevent allocations from going back into the cluster fs in places where that might lead to deadlock. Signed-off-by: David Teigland <teigland@redhat.com>
2009-05-15dlm: connect to nodes earlierChristine Caulfield
Make network connections to other nodes earlier, in the context of dlm_recoverd. This avoids connecting to nodes from dlm_send where we try to avoid allocations which could possibly deadlock if memory reclaim goes into the cluster fs which may try to do a dlm operation. Signed-off-by: Christine Caulfield <ccaulfie@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2009-05-07dlm: fix use count with multiple joinsDavid Teigland
When a lockspace was joined multiple times, the global dlm use count was incremented when it should not have been. This caused the global dlm threads to not be stopped when all lockspaces were eventually be removed. Signed-off-by: David Teigland <teigland@redhat.com>
2009-05-07dlm: Make name input parameter of {,dlm_}new_lockspace() constGeert Uytterhoeven
| fs/gfs2/lock_dlm.c:207: warning: passing argument 1 of 'dlm_new_lockspace' discards qualifiers from pointer target type Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: David Teigland <teigland@redhat.com>
2009-03-11dlm: fix length calculation in compat codeDavid Teigland
Using offsetof() to calculate name length does not work because it does not produce consistent results with with structure packing. This caused memcpy to corrupt memory by copying 4 extra bytes off the end of the buffer on 64 bit kernels with 32 bit userspace (the only case where this 32/64 compat code is used). The fix is to calculate name length directly from the start instead of trying to derive it later using count and offsetof. Signed-off-by: David Teigland <teigland@redhat.com>
2009-03-11dlm: ignore cancel on granted lockDavid Teigland
Return immediately from dlm_unlock(CANCEL) if the lock is granted and not being converted; there's nothing to cancel. Signed-off-by: David Teigland <teigland@redhat.com>
2009-03-11dlm: clear defunct cancel stateDavid Teigland
When a conversion completes successfully and finds that a cancel of the convert is still in progress (which is now a moot point), preemptively clear the state associated with outstanding cancel. That state could cause a subsequent conversion to be ignored. Also, improve the consistency and content of error and debug messages in this area. Signed-off-by: David Teigland <teigland@redhat.com>
2009-03-11dlm: replace idr with hash table for connectionsChristine Caulfield
Integer nodeids can be too large for the idr code; use a hash table instead. Signed-off-by: Christine Caulfield <ccaulfie@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2009-01-28dlm: comment typo fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David Teigland <teigland@redhat.com>
2009-01-28dlm: use ipv6_addr_copyJoe Perches
2009-01-28dlm: Change rwlock which is only used in write mode to a spinlockSteven Whitehouse
The ls_dirtbl[].lock was an rwlock, but since it was only used in write mode a spinlock will suffice. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2009-01-21dlm: initialize file_lock struct in GETLK before copying conflicting lockJeff Layton
dlm_posix_get fills out the relevant fields in the file_lock before returning when there is a lock conflict, but doesn't clean out any of the other fields in the file_lock. When nfsd does a NFSv4 lockt call, it sets the fl_lmops to nfsd_posix_mng_ops before calling the lower fs. When the lock comes back after testing a lock on GFS2, it still has that field set. This confuses nfsd into thinking that the file_lock is a nfsd4 lock. Fix this by making DLM reinitialize the file_lock before copying the fields from the conflicting lock. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2009-01-21dlm: fix plock notify callback to lockdDavid Teigland
We should use the original copy of the file_lock, fl, instead of the copy, flc in the lockd notify callback. The range in flc has been modified by posix_lock_file(), so it will not match a copy of the lock in lockd. Signed-off-by: David Teigland <teigland@redhat.com>
2009-01-08dlm: change rsbtbl rwlock to spinlockDavid Teigland
The rwlock is almost always used in write mode, so there's no reason to not use a spinlock instead. Signed-off-by: David Teigland <teigland@redhat.com>
2009-01-08dlm: fix seq_file usage in debugfs lock dumpDavid Teigland
The old code would leak iterators and leave reference counts on rsbs because it was ignoring the "stop" seq callback. The code followed an example that used the seq operations differently. This new code is based on actually understanding how the seq operations work. It also improves things by saving the hash bucket in the position to avoid cycling through completed buckets in start. Siged-off-by: Davd Teigland <teigland@redhat.com>
2009-01-05Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm: dlm: fs/dlm/ast.c: fix warning dlm: add new debugfs entry dlm: add time stamp of blocking callback dlm: change lock time stamping dlm: improve how bast mode handling dlm: remove extra blocking callback check dlm: replace schedule with cond_resched dlm: remove kmap/kunmap dlm: trivial annotation of be16 value dlm: fix up memory allocation flags
2008-12-23dlm: fs/dlm/ast.c: fix warningAndrew Morton
fs/dlm/ast.c: In function 'dlm_astd': fs/dlm/ast.c:64: warning: 'bastmode' may be used uninitialized in this function Cleans code up. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Teigland <teigland@redhat.com>
2008-12-23dlm: add new debugfs entryDavid Teigland
The new debugfs entry dumps all rsb and lkb structures, and includes a lot more information than has been available before. This includes the new timestamps added by a previous patch for debugging callback issues. Signed-off-by: David Teigland <teigland@redhat.com>
2008-12-23dlm: add time stamp of blocking callbackDavid Teigland
Record the time the latest blocking callback was queued for a lock. This will be used for debugging in combination with lock queue timestamp changes in the previous patch. Signed-off-by: David Teigland <teigland@redhat.com>
2008-12-23dlm: change lock time stampingDavid Teigland
Use ktime instead of jiffies for timestamping lkb's. Also stamp the time on every lkb whenever it's added to a resource queue, instead of just stamping locks subject to timeouts. This will allow us to use timestamps more widely for debugging all locks. Signed-off-by: David Teigland <teigland@redhat.com>
2008-12-23dlm: improve how bast mode handlingDavid Teigland
The lkb bastmode value is set in the context of processing the lock, and read by the dlm_astd thread. Because it's accessed in these two separate contexts, the writing/reading ought to be done under a lock. This is simple to do by setting it and reading it when the lkb is added to and removed from dlm_astd's callback list which is properly locked. Signed-off-by: David Teigland <teigland@redhat.com>
2008-12-23dlm: remove extra blocking callback checkDavid Teigland
Just before delivering a blocking callback (bast), the dlm_astd thread checks again that the granted mode of the lkb actually blocks the mode requested by the bast. The idea behind this was originally that the granted mode may have changed since the bast was queued, making the callback now unnecessary. Reasons for removing this extra check are: - dlm_astd doesn't lock the rsb before reading the lkb grmode, so it's not technically safe (this removes the long standing FIXME) - after running some tests, it doesn't appear the check ever actually eliminates a bast - delivering an unnecessary blocking callback isn't a bad thing and can happen anyway Signed-off-by: David Teigland <teigland@redhat.com>
2008-12-23dlm: replace schedule with cond_reschedSteven Whitehouse
This is a one-liner to use cond_resched() rather than schedule() in the ast delivery loop. It should not be necessary to schedule every time, so this will save some cpu time while continuing to allow scheduling when required. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2008-12-23dlm: remove kmap/kunmapSteven Whitehouse
The pages used in lowcomms are not highmem, so kmap is not necessary. Cc: Christine Caulfield <ccaulfie@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2008-12-23dlm: trivial annotation of be16 valueHarvey Harrison
fs/dlm/dir.c:419:14: warning: incorrect type in assignment (different base types) fs/dlm/dir.c:419:14: expected unsigned short [unsigned] [addressable] [assigned] [usertype] be_namelen fs/dlm/dir.c:419:14: got restricted __be16 [usertype] <noident> Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David Teigland <teigland@redhat.com>
2008-12-23dlm: fix up memory allocation flagsSteven Whitehouse
Use ls_allocation for memory allocations, which a cluster fs sets to GFP_NOFS. Use GFP_NOFS for allocations when no lockspace struct is available. Taking dlm locks needs to avoid calling back into the cluster fs because write-out can require taking dlm locks. Cc: Christine Caulfield <ccaulfie@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2008-11-25fix warning in fs/dlm/netlink.cIngo Molnar
this warning: fs/dlm/netlink.c: In function ‘dlm_timeout_warn’: fs/dlm/netlink.c:131: warning: ‘send_skb’ may be used uninitialized in this function triggers because GCC does not recognize the (correct) error flow between prepare_data() and send_skb. Annotate it. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-13dlm: fix shutdown cleanupDavid Teigland
Fixes a regression from commit 0f8e0d9a317406612700426fad3efab0b7bbc467, "dlm: allow multiple lockspace creates". An extraneous 'else' slipped into a code fragment being moved from release_lockspace() to dlm_release_lockspace(). The result of the unwanted 'else' is that dlm threads and structures are not stopped and cleaned up when the final dlm lockspace is removed. Trying to create a new lockspace again afterward will fail with "kmem_cache_create: duplicate cache dlm_conn" because the cache was not previously destroyed. Signed-off-by: David Teigland <teigland@redhat.com>
2008-09-05dlm: choose better identifiersAndrew Morton
sparc32: fs/dlm/config.c:397: error: expected identifier or '(' before '{' token fs/dlm/config.c: In function 'drop_node': fs/dlm/config.c:589: warning: initialization from incompatible pointer type fs/dlm/config.c:589: warning: initialization from incompatible pointer type fs/dlm/config.c: In function 'release_node': fs/dlm/config.c:601: warning: initialization from incompatible pointer type fs/dlm/config.c:601: warning: initialization from incompatible pointer type fs/dlm/config.c: In function 'show_node': fs/dlm/config.c:717: warning: initialization from incompatible pointer type fs/dlm/config.c:717: warning: initialization from incompatible pointer type fs/dlm/config.c: In function 'store_node': fs/dlm/config.c:726: warning: initialization from incompatible pointer type fs/dlm/config.c:726: warning: initialization from incompatible pointer type Cc: Christine Caulfield <ccaulfie@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Teigland <teigland@redhat.com>
2008-09-04dlm: remove bklDavid Teigland
BLK from recent pushdown is not needed. Signed-off-by: David Teigland <teigland@redhat.com>
2008-09-02dlm: fix address compareDavid Teigland
Compare only the addr and port fields of sockaddr structures. Fixes a problem with ipv6 where sin6_scope_id does not match. Signed-off-by: David Teigland <teigland@redhat.com>
2008-08-28dlm: fix locking of lockspace list in dlm_scandDavid Teigland
The dlm_scand thread needs to lock the list of lockspaces when going through it. Signed-off-by: David Teigland <teigland@redhat.com>
2008-08-28dlm: detect available userspace daemonDavid Teigland
If dlm_controld (the userspace daemon that controls the setup and recovery of the dlm) fails, the kernel should shut down the lockspaces in the kernel rather than leaving them running. This is detected by having dlm_controld hold a misc device open while running, and if the kernel detects a close while the daemon is still needed, it stops the lockspaces in the kernel. Knowing that the userspace daemon isn't running also allows the lockspace create/remove routines to avoid waiting on the daemon for join/leave operations. Signed-off-by: David Teigland <teigland@redhat.com>
2008-08-28dlm: allow multiple lockspace createsDavid Teigland
Add a count for lockspace create and release so that create can be called multiple times to use the lockspace from different places. Also add the new flag DLM_LSFL_NEWEXCL to create a lockspace with the previous behavior of returning -EEXIST if the lockspace already exists. Signed-off-by: David Teigland <teigland@redhat.com>
2008-08-13dlm: rename structsDavid Teigland
Add a dlm_ prefix to the struct names in config.c. This resolves a conflict with struct node in particular, when include/linux/node.h happens to be included. Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Teigland <teigland@redhat.com>
2008-08-13dlm: add missing kfreesDavid Teigland
A couple of unlikely error conditions were missing a kfree on the error exit path. Reported-by: Juha Leppanen <juha_motorsportcom@luukku.com> Signed-off-by: David Teigland <teigland@redhat.com>
2008-07-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/dlm: dlm: fix uninitialized variable for search_rsb_list callers dlm: release socket on error dlm: fix basts for granted CW waiting PR/CW dlm: check for null in device_write
2008-07-25locks: add special return value for asynchronous locksMiklos Szeredi
Use a special error value FILE_LOCK_DEFERRED to mean that a locking operation returned asynchronously. This is returned by posix_lock_file() for sleeping locks to mean that the lock has been queued on the block list, and will be woken up when it might become available and needs to be retried (either fl_lmops->fl_notify() is called or fl_wait is woken up). f_op->lock() to mean either the above, or that the filesystem will call back with fl_lmops->fl_grant() when the result of the locking operation is known. The filesystem can do this for sleeping as well as non-sleeping locks. This is to make sure, that return values of -EAGAIN and -EINPROGRESS by filesystems are not mistaken to mean an asynchronous locking. This also makes error handling in fs/locks.c and lockd/svclock.c slightly cleaner. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: David Teigland <teigland@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-17configfs: Allow ->make_item() and ->make_group() to return detailed errors.Joel Becker
The configfs operations ->make_item() and ->make_group() currently return a new item/group. A return of NULL signifies an error. Because of this, -ENOMEM is the only return code bubbled up the stack. Multiple folks have requested the ability to return specific error codes when these operations fail. This patch adds that ability by changing the ->make_item/group() ops to return ERR_PTR() values. These errors are bubbled up appropriately. NULL returns are changed to -ENOMEM for compatibility. Also updated are the in-kernel users of configfs. This is a rework of reverted commit 11c3b79218390a139f2d474ee1e983a672d5839a. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2008-07-17Revert "configfs: Allow ->make_item() and ->make_group() to return detailed ↵Joel Becker
errors." This reverts commit 11c3b79218390a139f2d474ee1e983a672d5839a. The code will move to PTR_ERR(). Signed-off-by: Joel Becker <joel.becker@oracle.com>
2008-07-17Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mfasheh/ocfs2: [PATCH] ocfs2: fix oops in mmap_truncate testing configfs: call drop_link() to cleanup after create_link() failure configfs: Allow ->make_item() and ->make_group() to return detailed errors. configfs: Fix failing mkdir() making racing rmdir() fail configfs: Fix deadlock with racing rmdir() and rename() configfs: Make configfs_new_dirent() return error code instead of NULL configfs: Protect configfs_dirent s_links list mutations configfs: Introduce configfs_dirent_lock ocfs2: Don't snprintf() without a format. ocfs2: Fix CONFIG_OCFS2_DEBUG_FS #ifdefs ocfs2/net: Silence build warnings on sparc64 ocfs2: Handle error during journal load ocfs2: Silence an error message in ocfs2_file_aio_read() ocfs2: use simple_read_from_buffer() ocfs2: fix printk format warnings with OCFS2_FS_STATS=n [PATCH 2/2] ocfs2: Instrument fs cluster locks [PATCH 1/2] ocfs2: Add CONFIG_OCFS2_FS_STATS config option
2008-07-14Merge commit 'v2.6.26' into bkl-removalJonathan Corbet
2008-07-14configfs: Allow ->make_item() and ->make_group() to return detailed errors.Joel Becker
The configfs operations ->make_item() and ->make_group() currently return a new item/group. A return of NULL signifies an error. Because of this, -ENOMEM is the only return code bubbled up the stack. Multiple folks have requested the ability to return specific error codes when these operations fail. This patch adds that ability by changing the ->make_item/group() ops to return an int. Also updated are the in-kernel users of configfs. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2008-07-14dlm: fix uninitialized variable for search_rsb_list callersBenny Halevy
gcc 4.3.0 correctly emits the following warning. search_rsb_list does not *r_ret if no dlm_rsb is found and _search_rsb may pass the uninitialized value upstream on the error path when both calls to search_rsb_list return non-zero error. The fix sets *r_ret to NULL on search_rsb_list's not-found path. Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: David Teigland <teigland@redhat.com>
2008-07-14dlm: release socket on errorMasatake YAMATO
It seems that `sock' allocated by sock_create_kern in tcp_connect_to_sock() of dlm/fs/lowcomms.c is not released if dlm_nodeid_to_addr an error. Acked-by: Christine Caulfield <ccaulfie@redhat.com> Signed-off-by: Masatake YAMATO <yamato@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2008-07-14dlm: fix basts for granted CW waiting PR/CWDavid Teigland
The fix in commit 3650925893469ccb03dbcc6a440c5d363350f591 was addressing the case of a granted PR lock with waiting PR and CW locks. It's a special case that requires forcing a CW bast. However, that forced CW bast was incorrectly applying to a second condition where the granted lock was CW. So, the holder of a CW lock could receive an extraneous CW bast instead of a PR bast. This fix narrows the original special case to what was intended. Signed-off-by: David Teigland <teigland@redhat.com>
2008-07-14dlm: check for null in device_writeMasatake YAMATO
If `device_write' method is called via "dlm-control", file->private_data is NULL. (See ctl_device_open() in user.c. ) Through proc->flags is read. Signed-off-by: Masatake YAMATO <yamato@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
