path: root/fs/dlm/config.c
2013-06-25dlm: config: using strlcpy instead of strncpyZhao Hongjiang
for NUL terminated string, need alway set '\0' in the end. Signed-off-by: Zhao Hongjiang <zhaohongjiang@huawei.com> Signed-off-by: David Teigland <teigland@redhat.com>
2013-02-26fs: change return values from -EACCES to -EPERMZhao Hongjiang
According to SUSv3: [EACCES] Permission denied. An attempt was made to access a file in a way forbidden by its file access permissions. [EPERM] Operation not permitted. An attempt was made to perform an operation limited to processes with appropriate privileges or to the owner of a file or other resource. So -EPERM should be returned if capability checks fails. Strictly speaking this is an API change since the error code user sees is altered. Signed-off-by: Zhao Hongjiang <zhaohongjiang@huawei.com> Acked-by: Jan Kara <jack@suse.cz> Acked-by: Steven Whitehouse <swhiteho@redhat.com> Acked-by: Ian Kent <raven@themaw.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-08-08dlm: fix deadlock between dlm_send and dlm_controldDavid Teigland
A deadlock sometimes occurs between dlm_controld closing a lowcomms connection through configfs and dlm_send looking up the address for a new connection in configfs. dlm_controld does a configfs rmdir which calls dlm_lowcomms_close which waits for dlm_send to cancel work on the workqueues. The dlm_send workqueue thread has called tcp_connect_to_sock which calls dlm_nodeid_to_addr which does a configfs lookup and blocks on a lock held by dlm_controld in the rmdir path. The solution here is to save the node addresses within the lowcomms code so that the lowcomms workqueue does not need to step through configfs to get a node address. dlm_controld: wait_for_completion+0x1d/0x20 __cancel_work_timer+0x1b3/0x1e0 cancel_work_sync+0x10/0x20 dlm_lowcomms_close+0x4c/0xb0 [dlm] drop_comm+0x22/0x60 [dlm] client_drop_item+0x26/0x50 [configfs] configfs_rmdir+0x180/0x230 [configfs] vfs_rmdir+0xbd/0xf0 do_rmdir+0x103/0x120 sys_rmdir+0x16/0x20 dlm_send: mutex_lock+0x2b/0x50 get_comm+0x34/0x140 [dlm] dlm_nodeid_to_addr+0x18/0xd0 [dlm] tcp_connect_to_sock+0xf4/0x2d0 [dlm] process_send_sockets+0x1d2/0x260 [dlm] worker_thread+0x170/0x2a0 Signed-off-by: David Teigland <teigland@redhat.com>
2012-07-16dlm: use rsbtbl as resource directoryDavid Teigland
Remove the dir hash table (dirtbl), and use the rsb hash table (rsbtbl) as the resource directory. It has always been an unnecessary duplication of information. This improves efficiency by using a single rsbtbl lookup in many cases where both rsbtbl and dirtbl lookups were needed previously. This eliminates the need to handle cases of rsbtbl and dirtbl being out of sync. In many cases there will be memory savings because the dir hash table no longer exists. Signed-off-by: David Teigland <teigland@redhat.com>
2012-01-04dlm: add recovery callbacksDavid Teigland
These new callbacks notify the dlm user about lock recovery. GFS2, and possibly others, need to be aware of when the dlm will be doing lock recovery for a failed lockspace member. In the past, this coordination has been done between dlm and file system daemons in userspace, which then direct their kernel counterparts. These callbacks allow the same coordination directly, and more simply. Signed-off-by: David Teigland <teigland@redhat.com>
2011-07-12dlm: improve rsb searchesDavid Teigland
By pre-allocating rsb structs before searching the hash table, they can be inserted immediately. This avoids always having to repeat the search when adding the struct to hash list. This also adds space to the rsb struct for a max resource name, so an rsb allocation can be used by any request. The constant size also allows us to finally use a slab for the rsb structs. Signed-off-by: David Teigland <teigland@redhat.com>
2011-07-11dlm: keep lkbs in idrDavid Teigland
This is simpler and quicker than the hash table, and avoids needing to search the hash list for every new lkid to check if it's used. Signed-off-by: David Teigland <teigland@redhat.com>
2011-06-30dlm: show addresses in configfsMasatake YAMATO
Display all addresses the dlm is using for the local node from the configfs file config/dlm/<cluster>/comms/<comm>/addr_list Also make the addr file write only. Signed-off-by: Masatake YAMATO <yamato@redhat.com> Signed-off-by: David Teigland <teigland@redhat.com>
2011-04-01dlm: delayed reply message warningDavid Teigland
Add an option (disabled by default) to print a warning message when a lock has been waiting a configurable amount of time for a reply message from another node. This is mainly for debugging. Signed-off-by: David Teigland <teigland@redhat.com>
2011-03-10dlm: increase default hash table sizesDavid Teigland
Make all three hash tables a consistent size of 1024 rather than 1024, 512, 256. All three tables, for resources, locks, and lock dir entries, will generally be filled to the same order of magnitude. Signed-off-by: David Teigland <teigland@redhat.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2009-11-30dlm: always use GFP_NOFSDavid Teigland
Replace all GFP_KERNEL and ls_allocation with GFP_NOFS. ls_allocation would be GFP_KERNEL for userland lockspaces and GFP_NOFS for file system lockspaces. It was discovered that any lockspaces on the system can affect all others by triggering memory reclaim in the file system which could in turn call back into the dlm to acquire locks, deadlocking dlm threads that were shared by all lockspaces, like dlm_recv. Signed-off-by: David Teigland <teigland@redhat.com>
2008-09-05dlm: choose better identifiersAndrew Morton
sparc32: fs/dlm/config.c:397: error: expected identifier or '(' before '{' token fs/dlm/config.c: In function 'drop_node': fs/dlm/config.c:589: warning: initialization from incompatible pointer type fs/dlm/config.c:589: warning: initialization from incompatible pointer type fs/dlm/config.c: In function 'release_node': fs/dlm/config.c:601: warning: initialization from incompatible pointer type fs/dlm/config.c:601: warning: initialization from incompatible pointer type fs/dlm/config.c: In function 'show_node': fs/dlm/config.c:717: warning: initialization from incompatible pointer type fs/dlm/config.c:717: warning: initialization from incompatible pointer type fs/dlm/config.c: In function 'store_node': fs/dlm/config.c:726: warning: initialization from incompatible pointer type fs/dlm/config.c:726: warning: initialization from incompatible pointer type Cc: Christine Caulfield <ccaulfie@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Teigland <teigland@redhat.com>
2008-09-02dlm: fix address compareDavid Teigland
Compare only the addr and port fields of sockaddr structures. Fixes a problem with ipv6 where sin6_scope_id does not match. Signed-off-by: David Teigland <teigland@redhat.com>
2008-08-13dlm: rename structsDavid Teigland
Add a dlm_ prefix to the struct names in config.c. This resolves a conflict with struct node in particular, when include/linux/node.h happens to be included. Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Teigland <teigland@redhat.com>
2008-07-17configfs: Allow ->make_item() and ->make_group() to return detailed errors.Joel Becker
The configfs operations ->make_item() and ->make_group() currently return a new item/group. A return of NULL signifies an error. Because of this, -ENOMEM is the only return code bubbled up the stack. Multiple folks have requested the ability to return specific error codes when these operations fail. This patch adds that ability by changing the ->make_item/group() ops to return ERR_PTR() values. These errors are bubbled up appropriately. NULL returns are changed to -ENOMEM for compatibility. Also updated are the in-kernel users of configfs. This is a rework of reverted commit 11c3b79218390a139f2d474ee1e983a672d5839a. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2008-07-17Revert "configfs: Allow ->make_item() and ->make_group() to return detailed ↵Joel Becker
errors." This reverts commit 11c3b79218390a139f2d474ee1e983a672d5839a. The code will move to PTR_ERR(). Signed-off-by: Joel Becker <joel.becker@oracle.com>
2008-07-14configfs: Allow ->make_item() and ->make_group() to return detailed errors.Joel Becker
The configfs operations ->make_item() and ->make_group() currently return a new item/group. A return of NULL signifies an error. Because of this, -ENOMEM is the only return code bubbled up the stack. Multiple folks have requested the ability to return specific error codes when these operations fail. This patch adds that ability by changing the ->make_item/group() ops to return an int. Also updated are the in-kernel users of configfs. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2008-04-21dlm: recover nodes that are removed and re-addedDavid Teigland
If a node is removed from a lockspace, and then added back before the dlm is notified of the removal, the dlm will not detect the removal and won't clear the old state from the node. This is fixed by using a list of added nodes so the membership recovery can detect when a newly added node is already in the member list. Signed-off-by: David Teigland <teigland@redhat.com>
2008-04-21dlm: match signedness between dlm_config_info and cluster_setHarvey Harrison
cluster_set is only called from the macro CLUSTER_ATTR which defines read/write access functions. Make the signedness match to avoid sparse warnings every time CLUSTER_ATTR is used (lines 149-159) all of the form: fs/dlm/config.c:149:1: warning: incorrect type in argument 3 (different signedness) fs/dlm/config.c:149:1: expected unsigned int *info_field fs/dlm/config.c:149:1: got int extern [toplevel] *<noident> Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: David Teigland <teigland@redhat.com>
2008-02-06dlm: add __init and __exit marks to init and exit functionsDenis Cheng
it moves 365 bytes from .text to .init.text, and 30 bytes from .text to .exit.text, saves memory. Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: David Teigland <teigland@redhat.com>
2007-07-10configfs: Convert subsystem semaphore to mutexJoel Becker
Convert the su_sem member of struct configfs_subsystem to a struct mutex, as that's what it is. Also convert all the users and update Documentation/configfs.txt and Documentation/configfs_example.c accordingly. [ Conflict in fs/dlm/config.c with commit 3168b0780d06ace875696f8a648d04d6089654e5 manually resolved. --Mark ] Inspired-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-07-10[PATCH] configfs+dlm: Rename config_group_find_obj and state semantics clearlySatyam Sharma
Configfs being based upon sysfs code, config_group_find_obj() is probably so named because of the similar kset_find_obj() in sysfs. However, "kobject"s in sysfs become "config_item"s in configfs, so let's call it config_group_find_item() instead, for sake of uniformity, and make corresponding change in the users of this function. BTW a crucial difference between kset_find_obj and config_group_find_item is in locking expectations. kset_find_obj does its locking by itself, but config_group_find_item expects the *caller* to do the locking. The reason for this: kset's have their own locks, config_group's don't but instead rely on the subsystem mutex. And, subsystem needn't necessarily be around when config_group_find_item() is called. So let's state these locking semantics explicitly, and rectify the comment, otherwise bugs could continue to occur in future, as they did in the past (refer commit d82b8191e238 in gfs2-2.6-fixes.git). [ I also took the opportunity to fix some bad whitespace and double-empty lines. --Joel ] [ Conflict in fs/dlm/config.c with commit 3168b0780d06ace875696f8a648d04d6089654e5 manually resolved. --Mark ] Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Cc: David Teigland <teigland@redhat.com> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-07-10[PATCH] configfs+dlm: Separate out __CONFIGFS_ATTR into configfs.hSatyam Sharma
fs/dlm/config.c contains a useful generic macro called __CONFIGFS_ATTR that is similar to sysfs' __ATTR macro that makes defining attributes easy for any user of configfs. Separate it out into configfs.h so that other users (forthcoming in dynamic netconsole patchset) can use it too. Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Cc: David Teigland <teigland@redhat.com> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-07-09[DLM] show default protocolDavid Teigland
Display the initial value of the "protocol" config value in configfs. The default value has always been 0 in the past anyway, so it's always appeared to be correct. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-07-09[DLM] timeout fixesDavid Teigland
Various fixes related to the new timeout feature: - add_timeout() missed setting TIMEWARN flag on lkb's when the TIMEOUT flag was already set - clear_proc_locks should remove a dead process's locks from the timeout list - the end-of-life calculation for user locks needs to consider that ETIMEDOUT is equivalent to -DLM_ECANCEL - make initial default timewarn_cs config value visible in configfs - change bit position of TIMEOUT_CANCEL flag so it's not copied to a remote master node - set timestamp on remote lkb's so a lock dump will display the time they've been waiting Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-07-09[DLM] add lock timeouts and warnings [2/6]David Teigland
New features: lock timeouts and time warnings. If the DLM_LKF_TIMEOUT flag is set, then the request/conversion will be canceled after waiting the specified number of centiseconds (specified per lock). This feature is only available for locks requested through libdlm (can be enabled for kernel dlm users if there's a use for it.) If the new DLM_LSFL_TIMEWARN flag is set when creating the lockspace, then a warning message will be sent to userspace (using genetlink) after a request/conversion has been waiting for a given number of centiseconds (configurable per node). The time warnings will be used in the future to do deadlock detection in userspace. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-07-09[DLM] fix a couple of racesSatyam Sharma
Fix two races in fs/dlm/config.c: (1) Grab the configfs subsystem semaphore before calling config_group_find_obj() in get_space(). This solves a potential race between get_space() and concurrent mkdir(2) or rmdir(2). (2) Grab a reference on the found config_item _while_ holding the configfs subsystem semaphore in get_comm(), and not after it. This solves a potential race between get_comm() and concurrent rmdir(2). Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-05-01[DLM] Consolidate transport protocolsPatrick Caulfield
This patch consolidates the TCP & SCTP protocols for the DLM into a single file and makes it switchable at run-time (well, at least before the DLM actually starts up!) For RHEL5 this patch requires Neil Horman's patch that expands the in-kernel socket API but that has already been twice ACKed so it should be OK. The patch adds a new lowcomms.c file that replaces the existing lowcomms-sctp.c & lowcomms-tcp.c files. Signed-off-By: Patrick Caulfield <pcaulfie@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-02-05[DLM] expose dlm_config_info fields in configfsDavid Teigland
Make the dlm_config_info values readable and writeable via configfs entries. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-02-05[DLM] add config entry to enable log_debugDavid Teigland
Add a new dlm_config_info field to enable log_debug output and change log_debug() to use it. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2007-02-05[DLM] rename dlm_config_info fieldsDavid Teigland
Add a "ci_" prefix to the fields in the dlm_config_info struct so that we can use macros to add configfs functions to access them (in a later patch). No functional changes in this patch, just naming changes. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-04-28[DLM] PATCH 2/3 dlm: lowcomms closeDavid Teigland
When a node is removed from a lockspace configuration, close our connection to it, clearing any remaining messages for it. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Patrick Caulfield <pcaulfie@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-01-20[DLM] Update DLM to the latest patch levelDavid Teigland
Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steve Whitehouse <swhiteho@redhat.com>
2006-01-18[DLM] The core of the DLM for GFS2/CLVMDavid Teigland
This is the core of the distributed lock manager which is required to use GFS2 as a cluster filesystem. It is also used by CLVM and can be used as a standalone lock manager independantly of either of these two projects. It implements VAX-style locking modes. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steve Whitehouse <swhiteho@redhat.com>
