path: root/fs/debugfs
2017-08-06dentry name snapshotsAl Viro
commit 49d31c2f389acfe83417083e1208422b4091cd9e upstream. take_dentry_name_snapshot() takes a safe snapshot of dentry name; if the name is a short one, it gets copied into caller-supplied structure, otherwise an extra reference to external name is grabbed (those are never modified). In either case the pointer to stable string is stored into the same structure. dentry must be held by the caller of take_dentry_name_snapshot(), but may be freely dropped afterwards - the snapshot will stay until destroyed by release_dentry_name_snapshot(). Intended use: struct name_snapshot s; take_dentry_name_snapshot(&s, dentry); ... access s.name ... release_dentry_name_snapshot(&s); Replaces fsnotify_oldname_...(), gets used in fsnotify to obtain the name to pass down with event. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-05-04debugfs: Make automount point inodes permanently emptySeth Forshee
commit 87243deb88671f70def4c52dfa7ca7830707bd31 upstream. Starting with 4.1 the tracing subsystem has its own filesystem which is automounted in the tracing subdirectory of debugfs. Prior to this debugfs could be bind mounted in a cloned mount namespace, but if tracefs has been mounted under debugfs this now fails because there is a locked child mount. This creates a regression for container software which bind mounts debugfs to satisfy the assumption of some userspace software. In other pseudo filesystems such as proc and sysfs we're already creating mountpoints like this in such a way that no dirents can be created in the directories, allowing them to be exceptions to some MNT_LOCKED tests. In fact we're already do this for the tracefs mountpoint in sysfs. Do the same in debugfs_create_automount(), since the intention here is clearly to create a mountpoint. This fixes the regression, as locked child mounts on permanently empty directories do not cause a bind mount to fail. Signed-off-by: Seth Forshee <seth.forshee@canonical.com> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-11-11debugfs: fix refcount imbalance in start_creatingDaniel Borkmann
In debugfs' start_creating(), we pin the file system to safely access its root. When we failed to create a file, we unpin the file system via failed_creating() to release the mount count and eventually the reference of the vfsmount. However, when we run into an error during lookup_one_len() when still in start_creating(), we only release the parent's mutex but not so the reference on the mount. Looks like it was done in the past, but after splitting portions of __create_file() into start_creating() and end_creating() via 190afd81e4a5 ("debugfs: split the beginning and the end of __create_file() off"), this seemed missed. Noticed during code review. Fixes: 190afd81e4a5 ("debugfs: split the beginning and the end of __create_file() off") Cc: stable@vger.kernel.org # v4.0+ Signed-off-by: Daniel Borkmann <daniel@iogearbox.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-10-18debugfs: Add debugfs_create_ulong()Viresh Kumar
Add debugfs_create_ulong() for the users of type 'unsigned long'. These will be 32 bits long on a 32 bit machine and 64 bits long on a 64 bit machine. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17debugfs: Add read-only/write-only bool file opsStephen Boyd
There aren't any read-only or write-only bool file ops, but there is a caller of debugfs_create_bool() that calls it with mode equal to 0400. This leads to the possibility of userspace modifying the file, so let's use the newly created debugfs_create_mode() helper here to fix this. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17debugfs: Add read-only/write-only size_t file opsStephen Boyd
There aren't any read-only or write-only size_t file ops, but there is a caller of debugfs_create_size_t() that calls it with mode equal to 0400. This leads to the possibility of userspace modifying the file, so let's use the newly created debugfs_create_mode() helper here to fix this. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17debugfs: Add read-only/write-only x64 file opsStephen Boyd
There aren't any read-only or write-only x64 file ops, but there is a caller of debugfs_create_x64() that calls it with mode equal to S_IRUGO. This leads to the possibility of userspace modifying the file, so let's use the newly created debugfs_create_mode() helper here to fix this. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-17debugfs: Consolidate file mode checks in debugfs_create_*()Stephen Boyd
The code that creates debugfs file with different file ops based on the file mode is duplicated in each debugfs_create_*() API. Consolidate that code into debugfs_create_mode(), that takes three file ops structures so that we don't have to keep copy/pasting that logic. Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-04debugfs: document that debugfs_remove*() accepts NULL and error valuesUlf Magnusson
According to commit a59d6293e537 ("debugfs: change parameter check in debugfs_remove() functions"), this is meant to make cleanup easier for callers. In that case it ought to be documented. Signed-off-by: Ulf Magnusson <ulfalizer@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-10-04debugfs: Pass bool pointer to debugfs_create_bool()Viresh Kumar
Its a bit odd that debugfs_create_bool() takes 'u32 *' as an argument, when all it needs is a boolean pointer. It would be better to update this API to make it accept 'bool *' instead, as that will make it more consistent and often more convenient. Over that bool takes just a byte. That required updates to all user sites as well, in the same commit updating the API. regmap core was also using debugfs_{read|write}_file_bool(), directly and variable types were updated for that to be bool as well. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Acked-by: Mark Brown <broonie@kernel.org> Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-07-20debugfs: Export bool read/write functionsRichard Fitzgerald
The file read/write functions for bools have no special dependencies on debugfs internals and are sufficiently non-trivial to be worth exporting so clients can re-use the implementation. Signed-off-by: Richard Fitzgerald <rf@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: "Assorted VFS fixes and related cleanups (IMO the most interesting in that part are f_path-related things and Eric's descriptor-related stuff). UFS regression fixes (it got broken last cycle). 9P fixes. fs-cache series, DAX patches, Jan's file_remove_suid() work" [ I'd say this is much more than "fixes and related cleanups". The file_table locking rule change by Eric Dumazet is a rather big and fundamental update even if the patch isn't huge. - Linus ] * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits) 9p: cope with bogus responses from server in p9_client_{read,write} p9_client_write(): avoid double p9_free_req() 9p: forgetting to cancel request on interrupted zero-copy RPC dax: bdev_direct_access() may sleep block: Add support for DAX reads/writes to block devices dax: Use copy_from_iter_nocache dax: Add block size note to documentation fs/file.c: __fget() and dup2() atomicity rules fs/file.c: don't acquire files->file_lock in fd_install() fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation vfs: avoid creation of inode number 0 in get_next_ino namei: make set_root_rcu() return void make simple_positive() public ufs: use dir_pages instead of ufs_dir_pages() pagemap.h: move dir_pages() over there remove the pointless include of lglock.h fs: cleanup slight list_entry abuse xfs: Correctly lock inode when removing suid and file capabilities fs: Call security_ops->inode_killpriv on truncate fs: Provide function telling whether file_remove_privs() will do anything ...
2015-07-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace updates from Eric Biederman: "Long ago and far away when user namespaces where young it was realized that allowing fresh mounts of proc and sysfs with only user namespace permissions could violate the basic rule that only root gets to decide if proc or sysfs should be mounted at all. Some hacks were put in place to reduce the worst of the damage could be done, and the common sense rule was adopted that fresh mounts of proc and sysfs should allow no more than bind mounts of proc and sysfs. Unfortunately that rule has not been fully enforced. There are two kinds of gaps in that enforcement. Only filesystems mounted on empty directories of proc and sysfs should be ignored but the test for empty directories was insufficient. So in my tree directories on proc, sysctl and sysfs that will always be empty are created specially. Every other technique is imperfect as an ordinary directory can have entries added even after a readdir returns and shows that the directory is empty. Special creation of directories for mount points makes the code in the kernel a smidge clearer about it's purpose. I asked container developers from the various container projects to help test this and no holes were found in the set of mount points on proc and sysfs that are created specially. This set of changes also starts enforcing the mount flags of fresh mounts of proc and sysfs are consistent with the existing mount of proc and sysfs. I expected this to be the boring part of the work but unfortunately unprivileged userspace winds up mounting fresh copies of proc and sysfs with noexec and nosuid clear when root set those flags on the previous mount of proc and sysfs. So for now only the atime, read-only and nodev attributes which userspace happens to keep consistent are enforced. Dealing with the noexec and nosuid attributes remains for another time. This set of changes also addresses an issue with how open file descriptors from /proc/<pid>/ns/* are displayed. Recently readlink of /proc/<pid>/fd has been triggering a WARN_ON that has not been meaningful since it was added (as all of the code in the kernel was converted) and is not now actively wrong. There is also a short list of issues that have not been fixed yet that I will mention briefly. It is possible to rename a directory from below to above a bind mount. At which point any directory pointers below the renamed directory can be walked up to the root directory of the filesystem. With user namespaces enabled a bind mount of the bind mount can be created allowing the user to pick a directory whose children they can rename to outside of the bind mount. This is challenging to fix and doubly so because all obvious solutions must touch code that is in the performance part of pathname resolution. As mentioned above there is also a question of how to ensure that developers by accident or with purpose do not introduce exectuable files on sysfs and proc and in doing so introduce security regressions in the current userspace that will not be immediately obvious and as such are likely to require breaking userspace in painful ways once they are recognized" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: vfs: Remove incorrect debugging WARN in prepend_path mnt: Update fs_fully_visible to test for permanently empty directories sysfs: Create mountpoints with sysfs_create_mount_point sysfs: Add support for permanently empty directories to serve as mount points. kernfs: Add support for always empty directories. proc: Allow creating permanently empty directories that serve as mount points sysctl: Allow creating permanently empty directories that serve as mountpoints. fs: Add helper functions for permanently empty directories. vfs: Ignore unlocked mounts in fs_fully_visible mnt: Modify fs_fully_visible to deal with locked ro nodev and atime mnt: Refactor the logic for mounting sysfs and proc in a user namespace
2015-07-01sysfs: Create mountpoints with sysfs_create_mount_pointEric W. Biederman
This allows for better documentation in the code and it allows for a simpler and fully correct version of fs_fully_visible to be written. The mount points converted and their filesystems are: /sys/hypervisor/s390/ s390_hypfs /sys/kernel/config/ configfs /sys/kernel/debug/ debugfs /sys/firmware/efi/efivars/ efivarfs /sys/fs/fuse/connections/ fusectl /sys/fs/pstore/ pstore /sys/kernel/tracing/ tracefs /sys/fs/cgroup/ cgroup /sys/kernel/security/ securityfs /sys/fs/selinux/ selinuxfs /sys/fs/smackfs/ smackfs Cc: stable@vger.kernel.org Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2015-06-23make simple_positive() publicAl Viro
2015-05-10debugfs: switch to simple_follow_link()Al Viro
Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull fourth vfs update from Al Viro: "d_inode() annotations from David Howells (sat in for-next since before the beginning of merge window) + four assorted fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: RCU pathwalk breakage when running into a symlink overmounting something fix I_DIO_WAKEUP definition direct-io: only inc/dec inode->i_dio_count for file systems fs/9p: fix readdir() VFS: assorted d_backing_inode() annotations VFS: fs/inode.c helpers: d_inode() annotations VFS: fs/cachefiles: d_backing_inode() annotations VFS: fs library helpers: d_inode() annotations VFS: assorted weird filesystems: d_inode() annotations VFS: normal filesystems (and lustre): d_inode() annotations VFS: security/: d_inode() annotations VFS: security/: d_backing_inode() annotations VFS: net/: d_inode() annotations VFS: net/unix: d_backing_inode() annotations VFS: kernel/: d_inode() annotations VFS: audit: d_backing_inode() annotations VFS: Fix up some ->d_inode accesses in the chelsio driver VFS: Cachefiles should perform fs modifications on the top layer only VFS: AF_UNIX sockets should call mknod on the top layer only
2015-04-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull third hunk of vfs changes from Al Viro: "This contains the ->direct_IO() changes from Omar + saner generic_write_checks() + dealing with fcntl()/{read,write}() races (mirroring O_APPEND/O_DIRECT into iocb->ki_flags and instead of repeatedly looking at ->f_flags, which can be changed by fcntl(2), check ->ki_flags - which cannot) + infrastructure bits for dhowells' d_inode annotations + Christophs switch of /dev/loop to vfs_iter_write()" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (30 commits) block: loop: switch to VFS ITER_BVEC configfs: Fix inconsistent use of file_inode() vs file->f_path.dentry->d_inode VFS: Make pathwalk use d_is_reg() rather than S_ISREG() VFS: Fix up debugfs to use d_is_dir() in place of S_ISDIR() VFS: Combine inode checks with d_is_negative() and d_is_positive() in pathwalk NFS: Don't use d_inode as a variable name VFS: Impose ordering on accesses of d_inode and d_flags VFS: Add owner-filesystem positive/negative dentry checks nfs: generic_write_checks() shouldn't be done on swapout... ocfs2: use __generic_file_write_iter() mirror O_APPEND and O_DIRECT into iocb->ki_flags switch generic_write_checks() to iocb and iter ocfs2: move generic_write_checks() before the alignment checks ocfs2_file_write_iter: stop messing with ppos udf_file_write_iter: reorder and simplify fuse: ->direct_IO() doesn't need generic_write_checks() ext4_file_write_iter: move generic_write_checks() up xfs_file_aio_write_checks: switch to iocb/iov_iter generic_write_checks(): drop isblk argument blkdev_write_iter: expand generic_file_checks() call in there ...
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-15VFS: Fix up debugfs to use d_is_dir() in place of S_ISDIR()David Howells
Fix up debugfs to use d_is_dir(dentry) in place of S_ISDIR(dentry->d_inode->i_mode). Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-03debugfs: allow bad parent pointers to be passed inGreg KH
If something went wrong with creating a debugfs file/symlink/directory, that value could be passed down into debugfs again as a parent dentry. To make caller code simpler, just error out if this happens, and don't crash the kernel. Reported-by: Alex Elder <elder@linaro.org> Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Reviewed-by: Alex Elder <elder@linaro.org>
2015-02-22debugfs: leave freeing a symlink body until inode evictionAl Viro
As it is, we have debugfs_remove() racing with symlink traversals. Supply ->evict_inode() and do freeing there - inode will remain pinned until we are done with the symlink body. And rip the idiocy with checking if dentry is positive right after we'd verified debugfs_positive(), which is a stronger check... Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-22VFS: (Scripted) Convert S_ISLNK/DIR/REG(dentry->d_inode) to d_is_*(dentry)David Howells
Convert the following where appropriate: (1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry). (2) S_ISREG(dentry->d_inode) to d_is_reg(dentry). (3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more complicated than it appears as some calls should be converted to d_can_lookup() instead. The difference is whether the directory in question is a real dir with a ->lookup op or whether it's a fake dir with a ->d_automount op. In some circumstances, we can subsume checks for dentry->d_inode not being NULL into this, provided we the code isn't in a filesystem that expects d_inode to be NULL if the dirent really *is* negative (ie. if we're going to use d_inode() rather than d_backing_inode() to get the inode pointer). Note that the dentry type field may be set to something other than DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS manages the fall-through from a negative dentry to a lower layer. In such a case, the dentry type of the negative union dentry is set to the same as the type of the lower dentry. However, if you know d_inode is not NULL at the call site, then you can use the d_is_xxx() functions even in a filesystem. There is one further complication: a 0,0 chardev dentry may be labelled DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was intended for special directory entry types that don't have attached inodes. The following perl+coccinelle script was used: use strict; my @callers; open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') || die "Can't grep for S_ISDIR and co. callers"; @callers = <$fd>; close($fd); unless (@callers) { print "No matches\n"; exit(0); } my @cocci = ( '@@', 'expression E;', '@@', '', '- S_ISLNK(E->d_inode->i_mode)', '+ d_is_symlink(E)', '', '@@', 'expression E;', '@@', '', '- S_ISDIR(E->d_inode->i_mode)', '+ d_is_dir(E)', '', '@@', 'expression E;', '@@', '', '- S_ISREG(E->d_inode->i_mode)', '+ d_is_reg(E)' ); my $coccifile = "tmp.sp.cocci"; open($fd, ">$coccifile") || die $coccifile; print($fd "$_\n") || die $coccifile foreach (@cocci); close($fd); foreach my $file (@callers) { chomp $file; print "Processing ", $file, "\n"; system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 || die "spatch failed"; } [AV: overlayfs parts skipped] Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-02-17debugfs: Provide a file creation function that also takes an initial sizeDavid Howells
Provide a file creation function that also takes an initial size so that the caller doesn't have to set i_size, thus meaning that we don't have to call deal with ->d_inode in the callers. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-01-25new primitive: debugfs_create_automount()Al Viro
2015-01-25debugfs: split end_creating() into success and failure casesAl Viro
... and don't bother with dput(dentry) in the former and with dget(dentry) preceding all its calls. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-01-25debugfs: take mode-dependent parts of debugfs_get_inode() into callersAl Viro
... and trim the arguments list Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-01-25fold debugfs_mknod() into callersAl Viro
2015-01-25fold debugfs_create() into callerAl Viro
2015-01-25fold debugfs_mkdir() into callerAl Viro
2015-01-25debugfs_mknod(): get rid useless argumentsAl Viro
dev is always zero, dir was only used to get its ->i_sb, which is equal to ->d_sb of dentry... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-01-25fold debugfs_link() into callerAl Viro
2015-01-25debugfs: kill __create_file()Al Viro
2015-01-25debugfs: split the beginning and the end of __create_file() offAl Viro
2015-01-25debugfs_{mkdir,create,link}(): get rid of redundant argumentAl Viro
2014-12-14Merge tag 'driver-core-3.19-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core update from Greg KH: "Here's the set of driver core patches for 3.19-rc1. They are dominated by the removal of the .owner field in platform drivers. They touch a lot of files, but they are "simple" changes, just removing a line in a structure. Other than that, a few minor driver core and debugfs changes. There are some ath9k patches coming in through this tree that have been acked by the wireless maintainers as they relied on the debugfs changes. Everything has been in linux-next for a while" * tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits) Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries" fs: debugfs: add forward declaration for struct device type firmware class: Deletion of an unnecessary check before the function call "vunmap" firmware loader: fix hung task warning dump devcoredump: provide a one-way disable function device: Add dev_<level>_once variants ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries ath: use seq_file api for ath9k debugfs files debugfs: add helper function to create device related seq_file drivers/base: cacheinfo: remove noisy error boot message Revert "core: platform: add warning if driver has no owner" drivers: base: support cpu cache information interface to userspace via sysfs drivers: base: add cpu_device_create to support per-cpu devices topology: replace custom attribute macros with standard DEVICE_ATTR* cpumask: factor out show_cpumap into separate helper function driver core: Fix unbalanced device reference in drivers_probe driver core: fix race with userland in device_add() sysfs/kernfs: make read requests on pre-alloc files use the buffer. sysfs/kernfs: allow attributes to request write buffer be pre-allocated. fs: sysfs: return EGBIG on write if offset is larger than file size ...
2014-11-26debugfs: add helper function to create device related seq_fileArend van Spriel
This patch adds a helper function that simplifies adding a so-called single_open sequence file for device drivers. The calling device driver needs to provide a read function and a device pointer. The field struct seq_file::private will reference the device pointer upon call to the read function so the driver can obtain his data from it and do its task of providing the file content using seq_printf() calls and alike. Using this helper function also gets rid of the need to specify file operations per debugfs file. Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-19Merge tag 'trace-seq-file-cleanup' of ↵Al Viro
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into for-next Pull the beginning of seq_file cleanup from Steven: "I'm looking to clean up the seq_file code and to eventually merge the trace_seq code with seq_file as well, since they basically do the same thing. Part of this process is to remove the return code of seq_printf() and friends as they are rather inconsistent. It is better to use the new function seq_has_overflowed() if you want to stop processing when the buffer is full. Note, if the buffer is full, the seq_file code will throw away the contents, allocate a bigger buffer, and then call your code again to fill in the data. The only thing that breaking out of the function early does is to save a little time which is probably never noticed. I started with patches from Joe Perches and modified them as well. There's many more places that need to be updated before we can convert seq_printf() and friends to return void. But this patch set introduces the seq_has_overflowed() and does some initial updates."
2014-11-05debugfs: Have debugfs_print_regs32() return voidJoe Perches
The seq_printf() will soon just return void, and seq_has_overflowed() should be used instead to see if the seq can no longer accept input. As the return value of debugfs_print_regs32() has no users and the seq_file descriptor should be checked with seq_has_overflowed() instead of return values of functions, it is better to just have debugfs_print_regs32() also return void. Link: http://lkml.kernel.org/p/2634b19eb1c04a9d31148c1fe6f1f3819be95349.1412031505.git.joe@perches.com Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Joe Perches <joe@perches.com> [ original change only updated seq_printf() return, added return of void to debugfs_print_regs32() as well ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2014-11-03move d_rcu from overlapping d_child to overlapping d_aliasAl Viro
2014-07-09fs: debugfs: remove trailing whitespaceRahul Bedarkar
fixes checkpatch.pl trailing whitespace errors Signed-off-by: Rahul Bedarkar <rahulbedarkar89@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-07-09debugfs: Fix corrupted loop in debugfs_remove_recursiveSteven Rostedt
[ I'm currently running my tests on it now, and so far, after a few hours it has yet to blow up. I'll run it for 24 hours which it never succeeded in the past. ] The tracing code has a way to make directories within the debugfs file system as well as deleting them using mkdir/rmdir in the instance directory. This is very limited in functionality, such as there is no renames, and the parent directory "instance" can not be modified. The tracing code creates the instance directory from the debugfs code and then replaces the dentry->d_inode->i_op with its own to allow for mkdir/rmdir to work. When these are called, the d_entry and inode locks need to be released to call the instance creation and deletion code. That code has its own accounting and locking to serialize everything to prevent multiple users from causing harm. As the parent "instance" directory can not be modified this simplifies things. I created a stress test that creates several threads that randomly creates and deletes directories thousands of times a second. The code stood up to this test and I submitted it a while ago. Recently I added a new test that adds readers to the mix. While the instance directories were being added and deleted, readers would read from these directories and even enable tracing within them. This test was able to trigger a bug: general protection fault: 0000 [#1] PREEMPT SMP Modules linked in: ... CPU: 3 PID: 17789 Comm: rmdir Tainted: G W 3.15.0-rc2-test+ #41 Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS SDBLI944.86P 05/08/2007 task: ffff88003786ca60 ti: ffff880077018000 task.ti: ffff880077018000 RIP: 0010:[<ffffffff811ed5eb>] [<ffffffff811ed5eb>] debugfs_remove_recursive+0x1bd/0x367 RSP: 0018:ffff880077019df8 EFLAGS: 00010246 RAX: 0000000000000002 RBX: ffff88006f0fe490 RCX: 0000000000000000 RDX: dead000000100058 RSI: 0000000000000246 RDI: ffff88003786d454 RBP: ffff88006f0fe640 R08: 0000000000000628 R09: 0000000000000000 R10: 0000000000000628 R11: ffff8800795110a0 R12: ffff88006f0fe640 R13: ffff88006f0fe640 R14: ffffffff81817d0b R15: ffffffff818188b7 FS: 00007ff13ae24700(0000) GS:ffff88007d580000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b CR2: 0000003054ec7be0 CR3: 0000000076d51000 CR4: 00000000000007e0 Stack: ffff88007a41ebe0 dead000000100058 00000000fffffffe ffff88006f0fe640 0000000000000000 ffff88006f0fe678 ffff88007a41ebe0 ffff88003793a000 00000000fffffffe ffffffff810bde82 ffff88006f0fe640 ffff88007a41eb28 Call Trace: [<ffffffff810bde82>] ? instance_rmdir+0x15b/0x1de [<ffffffff81132e2d>] ? vfs_rmdir+0x80/0xd3 [<ffffffff81132f51>] ? do_rmdir+0xd1/0x139 [<ffffffff8124ad9e>] ? trace_hardirqs_on_thunk+0x3a/0x3c [<ffffffff814fea62>] ? system_call_fastpath+0x16/0x1b Code: fe ff ff 48 8d 75 30 48 89 df e8 c9 fd ff ff 85 c0 75 13 48 c7 c6 b8 cc d2 81 48 c7 c7 b0 cc d2 81 e8 8c 7a f5 ff 48 8b 54 24 08 <48> 8b 82 a8 00 00 00 48 89 d3 48 2d a8 00 00 00 48 89 44 24 08 RIP [<ffffffff811ed5eb>] debugfs_remove_recursive+0x1bd/0x367 RSP <ffff880077019df8> It took a while, but every time it triggered, it was always in the same place: list_for_each_entry_safe(child, next, &parent->d_subdirs, d_u.d_child) { Where the child->d_u.d_child seemed to be corrupted. I added lots of trace_printk()s to see what was wrong, and sure enough, it was always the child's d_u.d_child field. I looked around to see what touches it and noticed that in __dentry_kill() which calls dentry_free(): static void dentry_free(struct dentry *dentry) { /* if dentry was never visible to RCU, immediate free is OK */ if (!(dentry->d_flags & DCACHE_RCUACCESS)) __d_free(&dentry->d_u.d_rcu); else call_rcu(&dentry->d_u.d_rcu, __d_free); } I also noticed that __dentry_kill() unlinks the child->d_u.child under the parent->d_lock spin_lock. Looking back at the loop in debugfs_remove_recursive() it never takes the parent->d_lock to do the list walk. Adding more tracing, I was able to prove this was the issue: ftrace-t-15385 1.... 246662024us : dentry_kill <ffffffff81138b91>: free ffff88006d573600 rmdir-15409 2.... 246662024us : debugfs_remove_recursive <ffffffff811ec7e5>: child=ffff88006d573600 next=dead000000100058 The dentry_kill freed ffff88006d573600 just as the remove recursive was walking it. In order to fix this, the list walk needs to be modified a bit to take the parent->d_lock. The safe version is no longer necessary, as every time we remove a child, the parent->d_lock must be released and the list walk must start over. Each time a child is removed, even though it may still be on the list, it should be skipped by the first check in the loop: if (!debugfs_positive(child)) continue; Cc: stable@vger.kernel.org Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-04Merge tag 'ext4_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 Pull ext4 updates from Ted Ts'o: "Major changes for 3.14 include support for the newly added ZERO_RANGE and COLLAPSE_RANGE fallocate operations, and scalability improvements in the jbd2 layer and in xattr handling when the extended attributes spill over into an external block. Other than that, the usual clean ups and minor bug fixes" * tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (42 commits) ext4: fix premature freeing of partial clusters split across leaf blocks ext4: remove unneeded test of ret variable ext4: fix comment typo ext4: make ext4_block_zero_page_range static ext4: atomically set inode->i_flags in ext4_set_inode_flags() ext4: optimize Hurd tests when reading/writing inodes ext4: kill i_version support for Hurd-castrated file systems ext4: each filesystem creates and uses its own mb_cache fs/mbcache.c: doucple the locking of local from global data fs/mbcache.c: change block and index hash chain to hlist_bl_node ext4: Introduce FALLOC_FL_ZERO_RANGE flag for fallocate ext4: refactor ext4_fallocate code ext4: Update inode i_size after the preallocation ext4: fix partial cluster handling for bigalloc file systems ext4: delete path dealloc code in ext4_ext_handle_uninitialized_extents ext4: only call sync_filesystm() when remounting read-only fs: push sync_filesystem() down to the file system's remount_fs() jbd2: improve error messages for inconsistent journal heads jbd2: minimize region locked by j_list_lock in jbd2_journal_forget() jbd2: minimize region locked by j_list_lock in journal_get_create_access() ...
2014-03-13fs: push sync_filesystem() down to the file system's remount_fs()Theodore Ts'o
Previously, the no-op "mount -o mount /dev/xxx" operation when the file system is already mounted read-write causes an implied, unconditional syncfs(). This seems pretty stupid, and it's certainly documented or guaraunteed to do this, nor is it particularly useful, except in the case where the file system was mounted rw and is getting remounted read-only. However, it's possible that there might be some file systems that are actually depending on this behavior. In most file systems, it's probably fine to only call sync_filesystem() when transitioning from read-write to read-only, and there are some file systems where this is not needed at all (for example, for a pseudo-filesystem or something like romfs). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: linux-fsdevel@vger.kernel.org Cc: Christoph Hellwig <hch@infradead.org> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Cc: Jan Kara <jack@suse.cz> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Anders Larsen <al@alarsen.net> Cc: Phillip Lougher <phillip@squashfs.org.uk> Cc: Kees Cook <keescook@chromium.org> Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: xfs@oss.sgi.com Cc: linux-btrfs@vger.kernel.org Cc: linux-cifs@vger.kernel.org Cc: samba-technical@lists.samba.org Cc: codalist@coda.cs.cmu.edu Cc: linux-ext4@vger.kernel.org Cc: linux-f2fs-devel@lists.sourceforge.net Cc: fuse-devel@lists.sourceforge.net Cc: cluster-devel@redhat.com Cc: linux-mtd@lists.infradead.org Cc: jfs-discussion@lists.sourceforge.net Cc: linux-nfs@vger.kernel.org Cc: linux-nilfs@vger.kernel.org Cc: linux-ntfs-dev@lists.sourceforge.net Cc: ocfs2-devel@oss.oracle.com Cc: reiserfs-devel@vger.kernel.org
2014-02-19treewide: Fix typo in Documentation/DocBookMasanari Iida
This patch fix spelling typo in Documentation/DocBook. It is because .html and .xml files are generated by make htmldocs, I have to fix a typo within the source files. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-11-13debugfs: use list_next_entry() in debugfs_remove_recursive()Oleg Nesterov
Change debugfs_remove_recursive() to use list_next_entry(child), no changes in generated code. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Eilon Greenstein <eilong@broadcom.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-07-31debugfs: debugfs_remove_recursive() must not rely on list_empty(d_subdirs)Oleg Nesterov
debugfs_remove_recursive() is wrong, 1. it wrongly assumes that !list_empty(d_subdirs) means that this dir should be removed. This is not that bad by itself, but: 2. if d_subdirs does not becomes empty after __debugfs_remove() it gives up and silently fails, it doesn't even try to remove other entries. However ->d_subdirs can be non-empty because it still has the already deleted !debugfs_positive() entries. 3. simple_release_fs() is called even if __debugfs_remove() fails. Suppose we have dir1/ dir2/ file2 file1 and someone opens dir1/dir2/file2. Now, debugfs_remove_recursive(dir1/dir2) succeeds, and dir1/dir2 goes away. But debugfs_remove_recursive(dir1) silently fails and doesn't remove this directory. Because it tries to delete (the already deleted) dir1/dir2/file2 again and then fails due to "Avoid infinite loop" logic. Test-case: #!/bin/sh cd /sys/kernel/debug/tracing echo 'p:probe/sigprocmask sigprocmask' >> kprobe_events sleep 1000 < events/probe/sigprocmask/id & echo -n >| kprobe_events [ -d events/probe ] && echo "ERR!! failed to rm probe" And after that it is not possible to create another probe entry. With this patch debugfs_remove_recursive() skips !debugfs_positive() files although this is not strictly needed. The most important change is that it does not try to make ->d_subdirs empty, it simply scans the whole list(s) recursively and removes as much as possible. Link: http://lkml.kernel.org/r/20130726151256.GC19472@redhat.com Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2013-06-03debugfs: write_file_bool() - ensure strtobool() operates on valid dataMathias Krause
In case, userland writes an empty string to a bool debugfs file, buf[] will still be uninitialized when being passed to strtobool() making the outcome of that function purely random. Fix this by always zero-terminating the buffer. Signed-off-by: Mathias Krause <minipli@googlemail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-03debugfs: add get/set for atomic typesSeth Jennings
debugfs currently lack the ability to create attributes that set/get atomic_t values. This patch adds support for this through a new debugfs_create_atomic_t() function. Signed-off-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Mel Gorman <mgorman@suse.de> Acked-by: Rik van Riel <riel@redhat.com> Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-03-03fs: Limit sys_mount to only request filesystem modules.Eric W. Biederman
Modify the request_module to prefix the file system type with "fs-" and add aliases to all of the filesystems that can be built as modules to match. A common practice is to build all of the kernel code and leave code that is not commonly needed as modules, with the result that many users are exposed to any bug anywhere in the kernel. Looking for filesystems with a fs- prefix limits the pool of possible modules that can be loaded by mount to just filesystems trivially making things safer with no real cost. Using aliases means user space can control the policy of which filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf with blacklist and alias directives. Allowing simple, safe, well understood work-arounds to known problematic software. This also addresses a rare but unfortunate problem where the filesystem name is not the same as it's module name and module auto-loading would not work. While writing this patch I saw a handful of such cases. The most significant being autofs that lives in the module autofs4. This is relevant to user namespaces because we can reach the request module in get_fs_type() without having any special permissions, and people get uncomfortable when a user specified string (in this case the filesystem type) goes all of the way to request_module. After having looked at this issue I don't think there is any particular reason to perform any filtering or permission checks beyond making it clear in the module request that we want a filesystem module. The common pattern in the kernel is to call request_module() without regards to the users permissions. In general all a filesystem module does once loaded is call register_filesystem() and go to sleep. Which means there is not much attack surface exposed by loading a filesytem module unless the filesystem is mounted. In a user namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT, which most filesystems do not set today. Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Acked-by: Kees Cook <keescook@chromium.org> Reported-by: Kees Cook <keescook@google.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
