[ Upstream commit 87243deb88671f70def4c52dfa7ca7830707bd31 ]
Starting with 4.1 the tracing subsystem has its own filesystem
which is automounted in the tracing subdirectory of debugfs.
Prior to this debugfs could be bind mounted in a cloned mount
namespace, but if tracefs has been mounted under debugfs this
now fails because there is a locked child mount. This creates
a regression for container software which bind mounts debugfs
to satisfy the assumption of some userspace software.
In other pseudo filesystems such as proc and sysfs we're already
creating mountpoints like this in such a way that no dirents can
be created in the directories, allowing them to be exceptions to
some MNT_LOCKED tests. In fact we're already do this for the
tracefs mountpoint in sysfs.
Do the same in debugfs_create_automount(), since the intention
here is clearly to create a mountpoint. This fixes the regression,
as locked child mounts on permanently empty directories do not
cause a bind mount to fail.
Cc: stable@vger.kernel.org # v4.1+
Signed-off-by: Seth Forshee <seth.forshee@canonical.com>
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
commit 0ee9608c89e81a1ccee52ecb58a7ff040e2522d9 upstream.
In debugfs' start_creating(), we pin the file system to safely access
its root. When we failed to create a file, we unpin the file system via
failed_creating() to release the mount count and eventually the reference
of the vfsmount.
However, when we run into an error during lookup_one_len() when still
in start_creating(), we only release the parent's mutex but not so the
reference on the mount. Looks like it was done in the past, but after
splitting portions of __create_file() into start_creating() and
end_creating() via 190afd81e4a5 ("debugfs: split the beginning and the
end of __create_file() off"), this seemed missed. Noticed during code
review.
Fixes: 190afd81e4a5 ("debugfs: split the beginning and the end of __create_file() off")
Signed-off-by: Daniel Borkmann <daniel@iogearbox.net>
commit f9bb48825a6b5d02f4cabcc78967c75db903dcdc upstream.
This allows for better documentation in the code and
it allows for a simpler and fully correct version of
fs_fully_visible to be written.
The mount points converted and their filesystems are:
/sys/hypervisor/s390/ s390_hypfs
/sys/kernel/config/ configfs
/sys/kernel/debug/ debugfs
/sys/firmware/efi/efivars/ efivarfs
/sys/fs/fuse/connections/ fusectl
/sys/fs/pstore/ pstore
/sys/kernel/tracing/ tracefs
/sys/fs/cgroup/ cgroup
/sys/kernel/security/ securityfs
/sys/fs/selinux/ selinuxfs
/sys/fs/smackfs/ smackfs
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Pull fourth vfs update from Al Viro:
"d_inode() annotations from David Howells (sat in for-next since before
the beginning of merge window) + four assorted fixes"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
RCU pathwalk breakage when running into a symlink overmounting something
fix I_DIO_WAKEUP definition
direct-io: only inc/dec inode->i_dio_count for file systems
fs/9p: fix readdir()
VFS: assorted d_backing_inode() annotations
VFS: fs/inode.c helpers: d_inode() annotations
VFS: fs/cachefiles: d_backing_inode() annotations
VFS: fs library helpers: d_inode() annotations
VFS: assorted weird filesystems: d_inode() annotations
VFS: normal filesystems (and lustre): d_inode() annotations
VFS: security/: d_inode() annotations
VFS: security/: d_backing_inode() annotations
VFS: net/: d_inode() annotations
VFS: net/unix: d_backing_inode() annotations
VFS: kernel/: d_inode() annotations
VFS: audit: d_backing_inode() annotations
VFS: Fix up some ->d_inode accesses in the chelsio driver
VFS: Cachefiles should perform fs modifications on the top layer only
VFS: AF_UNIX sockets should call mknod on the top layer only
Pull third hunk of vfs changes from Al Viro:
"This contains the ->direct_IO() changes from Omar + saner
generic_write_checks() + dealing with fcntl()/{read,write}() races
(mirroring O_APPEND/O_DIRECT into iocb->ki_flags and instead of
repeatedly looking at ->f_flags, which can be changed by fcntl(2),
check ->ki_flags - which cannot) + infrastructure bits for dhowells'
d_inode annotations + Christophs switch of /dev/loop to
vfs_iter_write()"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (30 commits)
block: loop: switch to VFS ITER_BVEC
configfs: Fix inconsistent use of file_inode() vs file->f_path.dentry->d_inode
VFS: Make pathwalk use d_is_reg() rather than S_ISREG()
VFS: Fix up debugfs to use d_is_dir() in place of S_ISDIR()
VFS: Combine inode checks with d_is_negative() and d_is_positive() in pathwalk
NFS: Don't use d_inode as a variable name
VFS: Impose ordering on accesses of d_inode and d_flags
VFS: Add owner-filesystem positive/negative dentry checks
nfs: generic_write_checks() shouldn't be done on swapout...
ocfs2: use __generic_file_write_iter()
mirror O_APPEND and O_DIRECT into iocb->ki_flags
switch generic_write_checks() to iocb and iter
ocfs2: move generic_write_checks() before the alignment checks
ocfs2_file_write_iter: stop messing with ppos
udf_file_write_iter: reorder and simplify
fuse: ->direct_IO() doesn't need generic_write_checks()
ext4_file_write_iter: move generic_write_checks() up
xfs_file_aio_write_checks: switch to iocb/iov_iter
generic_write_checks(): drop isblk argument
blkdev_write_iter: expand generic_file_checks() call in there
that's the bulk of filesystem drivers dealing with inodes of their own
Fix up debugfs to use d_is_dir(dentry) in place of
S_ISDIR(dentry->d_inode->i_mode).
If something went wrong with creating a debugfs file/symlink/directory,
that value could be passed down into debugfs again as a parent dentry.
To make caller code simpler, just error out if this happens, and don't
crash the kernel.
Reported-by: Alex Elder <elder@linaro.org>
Reviewed-by: Viresh Kumar <viresh.kumar@linaro.org>
Reviewed-by: Alex Elder <elder@linaro.org>
As it is, we have debugfs_remove() racing with symlink traversals.
Supply ->evict_inode() and do freeing there - inode will remain
pinned until we are done with the symlink body.
And rip the idiocy with checking if dentry is positive right after
we'd verified debugfs_positive(), which is a stronger check...
Convert the following where appropriate:
(1) S_ISLNK(dentry->d_inode) to d_is_symlink(dentry).
(2) S_ISREG(dentry->d_inode) to d_is_reg(dentry).
(3) S_ISDIR(dentry->d_inode) to d_is_dir(dentry). This is actually more
complicated than it appears as some calls should be converted to
d_can_lookup() instead. The difference is whether the directory in
question is a real dir with a ->lookup op or whether it's a fake dir with
a ->d_automount op.
In some circumstances, we can subsume checks for dentry->d_inode not being
NULL into this, provided we the code isn't in a filesystem that expects
d_inode to be NULL if the dirent really *is* negative (ie. if we're going to
use d_inode() rather than d_backing_inode() to get the inode pointer).
Note that the dentry type field may be set to something other than
DCACHE_MISS_TYPE when d_inode is NULL in the case of unionmount, where the VFS
manages the fall-through from a negative dentry to a lower layer. In such a
case, the dentry type of the negative union dentry is set to the same as the
type of the lower dentry.
However, if you know d_inode is not NULL at the call site, then you can use
the d_is_xxx() functions even in a filesystem.
There is one further complication: a 0,0 chardev dentry may be labelled
DCACHE_WHITEOUT_TYPE rather than DCACHE_SPECIAL_TYPE. Strictly, this was
intended for special directory entry types that don't have attached inodes.
The following perl+coccinelle script was used:
use strict;
my @callers;
open($fd, 'git grep -l \'S_IS[A-Z].*->d_inode\' |') ||
die "Can't grep for S_ISDIR and co. callers";
@callers = <$fd>;
close($fd);
unless (@callers) {
print "No matches\n";
exit(0);
my @cocci = (
'expression E;',
'- S_ISLNK(E->d_inode->i_mode)',
'+ d_is_symlink(E)',
'expression E;',
'- S_ISDIR(E->d_inode->i_mode)',
'+ d_is_dir(E)',
'expression E;',
'- S_ISREG(E->d_inode->i_mode)',
'+ d_is_reg(E)' );
my $coccifile = "tmp.sp.cocci";
open($fd, ">$coccifile") || die $coccifile;
print($fd "$_\n") || die $coccifile foreach (@cocci);
close($fd);
foreach my $file (@callers) {
chomp $file;
print "Processing ", $file, "\n";
system("spatch", "--sp-file", $coccifile, $file, "--in-place", "--no-show-diff") == 0 ||
die "spatch failed";
[AV: overlayfs parts skipped]
Provide a file creation function that also takes an initial size so that the
caller doesn't have to set i_size, thus meaning that we don't have to call
deal with ->d_inode in the callers.
... and don't bother with dput(dentry) in the former and with
dget(dentry) preceding all its calls.
... and trim the arguments list
dev is always zero, dir was only used to get its ->i_sb, which is
equal to ->d_sb of dentry...
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core
Pull driver core update from Greg KH:
"Here's the set of driver core patches for 3.19-rc1.
They are dominated by the removal of the .owner field in platform
drivers. They touch a lot of files, but they are "simple" changes,
just removing a line in a structure.
Other than that, a few minor driver core and debugfs changes. There
are some ath9k patches coming in through this tree that have been
acked by the wireless maintainers as they relied on the debugfs
changes.
Everything has been in linux-next for a while"
* tag 'driver-core-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (324 commits)
Revert "ath: ath9k: use debugfs_create_devm_seqfile() helper for seq_file entries"
fs: debugfs: add forward declaration for struct device type
firmware class: Deletion of an unnecessary check before the function call "vunmap"
firmware loader: fix hung task warning dump
devcoredump: provide a one-way disable function
device: Add dev_<level>_once variants
ath: use seq_file api for ath9k debugfs files
debugfs: add helper function to create device related seq_file
drivers/base: cacheinfo: remove noisy error boot message
Revert "core: platform: add warning if driver has no owner"
drivers: base: support cpu cache information interface to userspace via sysfs
drivers: base: add cpu_device_create to support per-cpu devices
topology: replace custom attribute macros with standard DEVICE_ATTR*
cpumask: factor out show_cpumap into separate helper function
driver core: Fix unbalanced device reference in drivers_probe
driver core: fix race with userland in device_add()
sysfs/kernfs: make read requests on pre-alloc files use the buffer.
sysfs/kernfs: allow attributes to request write buffer be pre-allocated.
fs: sysfs: return EGBIG on write if offset is larger than file size
This patch adds a helper function that simplifies adding a
so-called single_open sequence file for device drivers. The
calling device driver needs to provide a read function and
a device pointer. The field struct seq_file::private will
reference the device pointer upon call to the read function
so the driver can obtain his data from it and do its task
of providing the file content using seq_printf() calls and
alike. Using this helper function also gets rid of the need
to specify file operations per debugfs file.
Signed-off-by: Arend van Spriel <arend@broadcom.com>
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace into for-next
Pull the beginning of seq_file cleanup from Steven:
"I'm looking to clean up the seq_file code and to eventually merge the
trace_seq code with seq_file as well, since they basically do the same thing.
Part of this process is to remove the return code of seq_printf() and friends
as they are rather inconsistent. It is better to use the new function
seq_has_overflowed() if you want to stop processing when the buffer
is full. Note, if the buffer is full, the seq_file code will throw away
the contents, allocate a bigger buffer, and then call your code again
to fill in the data. The only thing that breaking out of the function
early does is to save a little time which is probably never noticed.
I started with patches from Joe Perches and modified them as well.
There's many more places that need to be updated before we can convert
seq_printf() and friends to return void. But this patch set introduces
the seq_has_overflowed() and does some initial updates."
The seq_printf() will soon just return void, and seq_has_overflowed()
should be used instead to see if the seq can no longer accept input.
As the return value of debugfs_print_regs32() has no users and
the seq_file descriptor should be checked with seq_has_overflowed()
instead of return values of functions, it is better to just have
debugfs_print_regs32() also return void.
Link: http://lkml.kernel.org/p/2634b19eb1c04a9d31148c1fe6f1f3819be95349.1412031505.git.joe@perches.com
[ original change only updated seq_printf() return, added return of
void to debugfs_print_regs32() as well ]
fixes checkpatch.pl trailing whitespace errors
Signed-off-by: Rahul Bedarkar <rahulbedarkar89@gmail.com>
[ I'm currently running my tests on it now, and so far, after a few
hours it has yet to blow up. I'll run it for 24 hours which it never
succeeded in the past. ]
The tracing code has a way to make directories within the debugfs file
system as well as deleting them using mkdir/rmdir in the instance
directory. This is very limited in functionality, such as there is
no renames, and the parent directory "instance" can not be modified.
The tracing code creates the instance directory from the debugfs code
and then replaces the dentry->d_inode->i_op with its own to allow
for mkdir/rmdir to work.
When these are called, the d_entry and inode locks need to be released
to call the instance creation and deletion code. That code has its own
accounting and locking to serialize everything to prevent multiple
users from causing harm. As the parent "instance" directory can not
be modified this simplifies things.
I created a stress test that creates several threads that randomly
creates and deletes directories thousands of times a second. The code
stood up to this test and I submitted it a while ago.
Recently I added a new test that adds readers to the mix. While the
instance directories were being added and deleted, readers would read
from these directories and even enable tracing within them. This test
was able to trigger a bug:
general protection fault: 0000 [#1] PREEMPT SMP
Modules linked in: ...
CPU: 3 PID: 17789 Comm: rmdir Tainted: G W 3.15.0-rc2-test+ #41
Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS SDBLI944.86P 05/08/2007
task: ffff88003786ca60 ti: ffff880077018000 task.ti: ffff880077018000
RIP: 0010:[<ffffffff811ed5eb>] [<ffffffff811ed5eb>] debugfs_remove_recursive+0x1bd/0x367
RSP: 0018:ffff880077019df8 EFLAGS: 00010246
RAX: 0000000000000002 RBX: ffff88006f0fe490 RCX: 0000000000000000
RDX: dead000000100058 RSI: 0000000000000246 RDI: ffff88003786d454
RBP: ffff88006f0fe640 R08: 0000000000000628 R09: 0000000000000000
R10: 0000000000000628 R11: ffff8800795110a0 R12: ffff88006f0fe640
R13: ffff88006f0fe640 R14: ffffffff81817d0b R15: ffffffff818188b7
FS: 00007ff13ae24700(0000) GS:ffff88007d580000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 0000003054ec7be0 CR3: 0000000076d51000 CR4: 00000000000007e0
Stack:
ffff88007a41ebe0 dead000000100058 00000000fffffffe ffff88006f0fe640
0000000000000000 ffff88006f0fe678 ffff88007a41ebe0 ffff88003793a000
00000000fffffffe ffffffff810bde82 ffff88006f0fe640 ffff88007a41eb28
Call Trace:
[<ffffffff810bde82>] ? instance_rmdir+0x15b/0x1de
[<ffffffff81132e2d>] ? vfs_rmdir+0x80/0xd3
[<ffffffff81132f51>] ? do_rmdir+0xd1/0x139
[<ffffffff8124ad9e>] ? trace_hardirqs_on_thunk+0x3a/0x3c
[<ffffffff814fea62>] ? system_call_fastpath+0x16/0x1b
Code: fe ff ff 48 8d 75 30 48 89 df e8 c9 fd ff ff 85 c0 75 13 48 c7 c6 b8 cc d2 81 48 c7 c7 b0 cc d2 81 e8 8c 7a f5 ff 48 8b 54 24 08 <48> 8b 82 a8 00 00 00 48 89 d3 48 2d a8 00 00 00 48 89 44 24 08
RIP [<ffffffff811ed5eb>] debugfs_remove_recursive+0x1bd/0x367
RSP <ffff880077019df8>
It took a while, but every time it triggered, it was always in the
same place:
list_for_each_entry_safe(child, next, &parent->d_subdirs, d_u.d_child) {
Where the child->d_u.d_child seemed to be corrupted. I added lots of
trace_printk()s to see what was wrong, and sure enough, it was always
the child's d_u.d_child field. I looked around to see what touches
it and noticed that in __dentry_kill() which calls dentry_free():
static void dentry_free(struct dentry *dentry)
/* if dentry was never visible to RCU, immediate free is OK */
if (!(dentry->d_flags & DCACHE_RCUACCESS))
__d_free(&dentry->d_u.d_rcu);
else
call_rcu(&dentry->d_u.d_rcu, __d_free);
I also noticed that __dentry_kill() unlinks the child->d_u.child
under the parent->d_lock spin_lock.
Looking back at the loop in debugfs_remove_recursive() it never takes the
parent->d_lock to do the list walk. Adding more tracing, I was able to
prove this was the issue:
ftrace-t-15385 1.... 246662024us : dentry_kill <ffffffff81138b91>: free ffff88006d573600
rmdir-15409 2.... 246662024us : debugfs_remove_recursive <ffffffff811ec7e5>: child=ffff88006d573600 next=dead000000100058
The dentry_kill freed ffff88006d573600 just as the remove recursive was walking
it.
In order to fix this, the list walk needs to be modified a bit to take
the parent->d_lock. The safe version is no longer necessary, as every
time we remove a child, the parent->d_lock must be released and the
list walk must start over. Each time a child is removed, even though it
may still be on the list, it should be skipped by the first check
in the loop:
if (!debugfs_positive(child))
continue;
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
Pull ext4 updates from Ted Ts'o:
"Major changes for 3.14 include support for the newly added ZERO_RANGE
and COLLAPSE_RANGE fallocate operations, and scalability improvements
in the jbd2 layer and in xattr handling when the extended attributes
spill over into an external block.
Other than that, the usual clean ups and minor bug fixes"
* tag 'ext4_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (42 commits)
ext4: fix premature freeing of partial clusters split across leaf blocks
ext4: remove unneeded test of ret variable
ext4: fix comment typo
ext4: make ext4_block_zero_page_range static
ext4: atomically set inode->i_flags in ext4_set_inode_flags()
ext4: optimize Hurd tests when reading/writing inodes
ext4: kill i_version support for Hurd-castrated file systems
ext4: each filesystem creates and uses its own mb_cache
fs/mbcache.c: doucple the locking of local from global data
fs/mbcache.c: change block and index hash chain to hlist_bl_node
ext4: Introduce FALLOC_FL_ZERO_RANGE flag for fallocate
ext4: refactor ext4_fallocate code
ext4: Update inode i_size after the preallocation
ext4: fix partial cluster handling for bigalloc file systems
ext4: delete path dealloc code in ext4_ext_handle_uninitialized_extents
ext4: only call sync_filesystm() when remounting read-only
fs: push sync_filesystem() down to the file system's remount_fs()
jbd2: improve error messages for inconsistent journal heads
jbd2: minimize region locked by j_list_lock in jbd2_journal_forget()
jbd2: minimize region locked by j_list_lock in journal_get_create_access()
Previously, the no-op "mount -o mount /dev/xxx" operation when the
file system is already mounted read-write causes an implied,
unconditional syncfs(). This seems pretty stupid, and it's certainly
documented or guaraunteed to do this, nor is it particularly useful,
except in the case where the file system was mounted rw and is getting
remounted read-only.
However, it's possible that there might be some file systems that are
actually depending on this behavior. In most file systems, it's
probably fine to only call sync_filesystem() when transitioning from
read-write to read-only, and there are some file systems where this is
not needed at all (for example, for a pseudo-filesystem or something
like romfs).
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Cc: linux-fsdevel@vger.kernel.org
Cc: Artem Bityutskiy <dedekind1@gmail.com>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Evgeniy Dushistov <dushistov@mail.ru>
Cc: Jan Kara <jack@suse.cz>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Anders Larsen <al@alarsen.net>
Cc: Phillip Lougher <phillip@squashfs.org.uk>
Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz>
Cc: Petr Vandrovec <petr@vandrovec.name>
Cc: xfs@oss.sgi.com
Cc: linux-btrfs@vger.kernel.org
Cc: linux-cifs@vger.kernel.org
Cc: samba-technical@lists.samba.org
Cc: codalist@coda.cs.cmu.edu
Cc: linux-ext4@vger.kernel.org
Cc: linux-f2fs-devel@lists.sourceforge.net
Cc: fuse-devel@lists.sourceforge.net
Cc: cluster-devel@redhat.com
Cc: linux-mtd@lists.infradead.org
Cc: jfs-discussion@lists.sourceforge.net
Cc: linux-nfs@vger.kernel.org
Cc: linux-nilfs@vger.kernel.org
Cc: linux-ntfs-dev@lists.sourceforge.net
Cc: ocfs2-devel@oss.oracle.com
Cc: reiserfs-devel@vger.kernel.org
This patch fix spelling typo in Documentation/DocBook.
It is because .html and .xml files are generated by make htmldocs,
I have to fix a typo within the source files.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Change debugfs_remove_recursive() to use list_next_entry(child), no
changes in generated code.
Cc: Eilon Greenstein <eilong@broadcom.com>
debugfs_remove_recursive() is wrong,
1. it wrongly assumes that !list_empty(d_subdirs) means that this
dir should be removed.
This is not that bad by itself, but:
2. if d_subdirs does not becomes empty after __debugfs_remove()
it gives up and silently fails, it doesn't even try to remove
other entries.
However ->d_subdirs can be non-empty because it still has the
already deleted !debugfs_positive() entries.
3. simple_release_fs() is called even if __debugfs_remove() fails.
Suppose we have
dir1/
dir2/
file2
file1
and someone opens dir1/dir2/file2.
Now, debugfs_remove_recursive(dir1/dir2) succeeds, and dir1/dir2 goes
away.
But debugfs_remove_recursive(dir1) silently fails and doesn't remove
this directory. Because it tries to delete (the already deleted)
dir1/dir2/file2 again and then fails due to "Avoid infinite loop"
logic.
Test-case:
#!/bin/sh
cd /sys/kernel/debug/tracing
echo 'p:probe/sigprocmask sigprocmask' >> kprobe_events
sleep 1000 < events/probe/sigprocmask/id &
echo -n >| kprobe_events
[ -d events/probe ] && echo "ERR!! failed to rm probe"
And after that it is not possible to create another probe entry.
With this patch debugfs_remove_recursive() skips !debugfs_positive()
files although this is not strictly needed. The most important change
is that it does not try to make ->d_subdirs empty, it simply scans
the whole list(s) recursively and removes as much as possible.
Link: http://lkml.kernel.org/r/20130726151256.GC19472@redhat.com
In case, userland writes an empty string to a bool debugfs file, buf[]
will still be uninitialized when being passed to strtobool() making the
outcome of that function purely random.
Fix this by always zero-terminating the buffer.
Signed-off-by: Mathias Krause <minipli@googlemail.com>
debugfs currently lack the ability to create attributes
that set/get atomic_t values.
This patch adds support for this through a new
debugfs_create_atomic_t() function.
Signed-off-by: Seth Jennings <sjenning@linux.vnet.ibm.com>
Acked-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Modify the request_module to prefix the file system type with "fs-"
and add aliases to all of the filesystems that can be built as modules
to match.
A common practice is to build all of the kernel code and leave code
that is not commonly needed as modules, with the result that many
users are exposed to any bug anywhere in the kernel.
Looking for filesystems with a fs- prefix limits the pool of possible
modules that can be loaded by mount to just filesystems trivially
making things safer with no real cost.
Using aliases means user space can control the policy of which
filesystem modules are auto-loaded by editing /etc/modprobe.d/*.conf
with blacklist and alias directives. Allowing simple, safe,
well understood work-arounds to known problematic software.
This also addresses a rare but unfortunate problem where the filesystem
name is not the same as it's module name and module auto-loading
would not work. While writing this patch I saw a handful of such
cases. The most significant being autofs that lives in the module
autofs4.
This is relevant to user namespaces because we can reach the request
module in get_fs_type() without having any special permissions, and
people get uncomfortable when a user specified string (in this case
the filesystem type) goes all of the way to request_module.
After having looked at this issue I don't think there is any
particular reason to perform any filtering or permission checks beyond
making it clear in the module request that we want a filesystem
module. The common pattern in the kernel is to call request_module()
without regards to the users permissions. In general all a filesystem
module does once loaded is call register_filesystem() and go to sleep.
Which means there is not much attack surface exposed by loading a
filesytem module unless the filesystem is mounted. In a user
namespace filesystems are not mounted unless .fs_flags = FS_USERNS_MOUNT,
which most filesystems do not set today.
Reported-by: Kees Cook <keescook@google.com>
This is to fix up a build problem with a wireless driver due to the
dynamic-debug patches in this branch.
We already initialize it to NULL when declaring it, no need to do
that twice.
This patch technically breaks userspace, but I suspect that anyone who
actually used this flag would have encountered this brokenness, declared
it lunacy, and already sent a patch.
Signed-off-by: Dave Reisner <dreisner@archlinux.org>
Reviewed-by: Vasiliy Kulikov <segoon@openwall.com>
inode->i_private is promised to be NULL on allocation, no need to set it
explicitly.
Signed-off-by: Yan Hong <clouds.yan@gmail.com>
Cc: Greg KH <greg@kroah.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace
Pull user namespace changes from Eric Biederman:
"This is a mostly modest set of changes to enable basic user namespace
support. This allows the code to code to compile with user namespaces
enabled and removes the assumption there is only the initial user
namespace. Everything is converted except for the most complex of the
filesystems: autofs4, 9p, afs, ceph, cifs, coda, fuse, gfs2, ncpfs,
nfs, ocfs2 and xfs as those patches need a bit more review.
The strategy is to push kuid_t and kgid_t values are far down into
subsystems and filesystems as reasonable. Leaving the make_kuid and
from_kuid operations to happen at the edge of userspace, as the values
come off the disk, and as the values come in from the network.
Letting compile type incompatible compile errors (present when user
namespaces are enabled) guide me to find the issues.
The most tricky areas have been the places where we had an implicit
union of uid and gid values and were storing them in an unsigned int.
Those places were converted into explicit unions. I made certain to
handle those places with simple trivial patches.
Out of that work I discovered we have generic interfaces for storing
quota by projid. I had never heard of the project identifiers before.
Adding full user namespace support for project identifiers accounts
for most of the code size growth in my git tree.
Ultimately there will be work to relax privlige checks from
"capable(FOO)" to "ns_capable(user_ns, FOO)" where it is safe allowing
root in a user names to do those things that today we only forbid to
non-root users because it will confuse suid root applications.
While I was pushing kuid_t and kgid_t changes deep into the audit code
I made a few other cleanups. I capitalized on the fact we process
netlink messages in the context of the message sender. I removed
usage of NETLINK_CRED, and started directly using current->tty.
Some of these patches have also made it into maintainer trees, with no
problems from identical code from different trees showing up in
linux-next.
After reading through all of this code I feel like I might be able to
win a game of kernel trivial pursuit."
Fix up some fairly trivial conflicts in netfilter uid/git logging code.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: (107 commits)
userns: Convert the ufs filesystem to use kuid/kgid where appropriate
userns: Convert the udf filesystem to use kuid/kgid where appropriate
userns: Convert ubifs to use kuid/kgid
userns: Convert squashfs to use kuid/kgid where appropriate
userns: Convert reiserfs to use kuid and kgid where appropriate
userns: Convert jfs to use kuid/kgid where appropriate
userns: Convert jffs2 to use kuid and kgid where appropriate
userns: Convert hpfs to use kuid and kgid where appropriate
userns: Convert btrfs to use kuid/kgid where appropriate
userns: Convert bfs to use kuid/kgid where appropriate
userns: Convert affs to use kuid/kgid wherwe appropriate
userns: On alpha modify linux_to_osf_stat to use convert from kuids and kgids
userns: On ia64 deal with current_uid and current_gid being kuid and kgid
userns: On ppc convert current_uid from a kuid before printing.
userns: Convert s390 getting uid and gid system calls to use kuid and kgid
userns: Convert s390 hypfs to use kuid and kgid where appropriate
userns: Convert binder ipc to use kuids
userns: Teach security_path_chown to take kuids and kgids
userns: Add user namespace support to IMA
userns: Convert EVM to deal with kuids and kgids in it's hmac computation
Pull driver core merge from Greg Kroah-Hartman:
"Here is the big driver core update for 3.7-rc1.
A number of firmware_class.c updates (as you saw a month or so ago),
and some hyper-v updates and some printk fixes as well. All patches
that are outside of the drivers/base area have been acked by the
respective maintainers, and have all been in the linux-next tree for a
while.
Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>"
* tag 'driver-core-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (95 commits)
memory: tegra{20,30}-mc: Fix reading incorrect register in mc_readl()
device.h: Add missing inline to #ifndef CONFIG_PRINTK dev_vprintk_emit
memory: emif: Add ifdef CONFIG_DEBUG_FS guard for emif_debugfs_[init|exit]
Documentation: Fixes some translation error in Documentation/zh_CN/gpio.txt
Documentation: Remove 3 byte redundant code at the head of the Documentation/zh_CN/arm/booting
Documentation: Chinese translation of Documentation/video4linux/omap3isp.txt
device and dynamic_debug: Use dev_vprintk_emit and dev_printk_emit
dev: Add dev_vprintk_emit and dev_printk_emit
netdev_printk/netif_printk: Remove a superfluous logging colon
netdev_printk/dynamic_netdev_dbg: Directly call printk_emit
dev_dbg/dynamic_debug: Update to use printk_emit, optimize stack
driver-core: Shut up dev_dbg_reatelimited() without DEBUG
tools/hv: Parse /etc/os-release
tools/hv: Check for read/write errors
tools/hv: Fix exit() error code
tools/hv: Fix file handle leak
Tools: hv: Implement the KVP verb - KVP_OP_GET_IP_INFO
Tools: hv: Rename the function kvp_get_ip_address()
Tools: hv: Implement the KVP verb - KVP_OP_SET_IP_INFO
Tools: hv: Add an example script to configure an interface
The format_array_alloc() function is fundamentally racy, in that it
prints the array twice: once to figure out how much space to allocate
for the buffer, and the second time to actually print out the data.
If any of the array contents changes in between, the allocation size may
be wrong, and the end result may be truncated in odd ways.
Just don't do it. Allocate a maximum-sized array up-front, and just
format the array contents once. The only user of the u32_array
interfaces is the Xen spinlock statistics code, and it has 31 entries in
the arrays, so the maximum size really isn't that big, and the end
result is much simpler code without the bug.
u32_array_open() is racy when multiple threads read from a file with a
seek position of zero, i.e. when two or more simultaneous reads are
occurring after the non-seekable files are created. It is possible that
file->private_data is double-freed because the threads races between
kfree(file->private-data);
and
file->private_data = NULL;
The fix is to only do format_array_alloc() when the file is opened and
free it when it is closed.
Note that because the file has always been non-seekable, you can't open
it and read it multiple times anyway, so the data has always been
generated just once. The difference is that now it is generated at open
time rather than at the time of the first read, and that avoids the
race.
Reported-by: Dave Jones <davej@redhat.com>
Tested-by: Raghavendra <raghavendra.kt@linux.vnet.ibm.com>
Signed-off-by: David Rientjes <rientjes@google.com>
Since the debugfs is mostly only used by root, make the default mount
mode 0700. Most system owners do not need a more permissive value,
but they can choose to weaken the restrictions via their fstab.
It's only used locally, no need to pollute global namespace.
Signed-off-by: Chris Wright <chrisw@sous-sol.org>
Pull driver core changes from Greg Kroah-Hartman:
"Here's the big driver core pull request for 3.6-rc1.
Unlike 3.5, this kernel should be a lot tamer, with the printk changes
now settled down. All we have here is some extcon driver updates, w1
driver updates, a few printk cleanups that weren't needed for 3.5, but
are good to have now, and some other minor fixes/changes in the driver
core.
All of these have been in the linux-next releases for a while now.
* tag 'driver-core-3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (38 commits)
printk: Export struct log size and member offsets through vmcoreinfo
Drivers: hv: Change the hex constant to a decimal constant
driver core: don't trigger uevent after failure
extcon: MAX77693: Add extcon-max77693 driver to support Maxim MAX77693 MUIC device
sysfs: fail dentry revalidation after namespace change fix
extcon: spelling of detach in function doc
extcon: arizona: Stop microphone detection if we give up on it
extcon: arizona: Update cable reporting calls and split headset
PM / Runtime: Do not increment device usage counts before probing
kmsg - do not flush partial lines when the console is busy
kmsg - export "continuation record" flag to /dev/kmsg
kmsg - avoid warning for CONFIG_PRINTK=n compilations
kmsg - properly print over-long continuation lines
driver-core: Use kobj_to_dev instead of re-implementing it
driver-core: Move kobj_to_dev from genhd.h to device.h
driver core: Move deferred devices to the end of dpm_list before probing
driver core: move uevent call to driver_register
driver core: fix shutdown races with probe/remove(v3)
Extcon: Arizona: Add driver for Wolfson Arizona class devices
