Fix kernel-doc warnings in fs/dcache.c:
Warning(fs/dcache.c:1743): No description found for parameter 'seqp'
Warning(fs/dcache.c:1743): Excess function parameter 'seq' description in '__d_lookup_rcu'
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Pull vfs pile 1 from Al Viro:
"This is _not_ all; in particular, Miklos' and Jan's stuff is not there
yet."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits)
ext4: initialization of ext4_li_mtx needs to be done earlier
debugfs-related mode_t whack-a-mole
hfsplus: add an ioctl to bless files
hfsplus: change finder_info to u32
hfsplus: initialise userflags
qnx4: new helper - try_extent()
qnx4: get rid of qnx4_bread/qnx4_getblk
take removal of PF_FORKNOEXEC to flush_old_exec()
trim includes in inode.c
um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it
um: embed ->stub_pages[] into mmu_context
gadgetfs: list_for_each_safe() misuse
ocfs2: fix leaks on failure exits in module_init
ecryptfs: make register_filesystem() the last potential failure exit
ntfs: forgets to unregister sysctls on register_filesystem() failure
logfs: missing cleanup on register_filesystem() failure
jfs: mising cleanup on register_filesystem() failure
make configfs_pin_fs() return root dentry on success
configfs: configfs_create_dir() has parent dentry in dentry->d_parent
configfs: sanitize configfs_create()
all callers converted to d_make_root() by now
* branch 'dcache-word-accesses':
vfs: use 'unsigned long' accesses for dcache name comparison and hashing
This does the name hashing and lookup using word-sized accesses when
that is efficient, namely on x86 (although any little-endian machine
with good unaligned accesses would do).
It does very much depend on little-endian logic, but it's a very hot
couple of functions under some real loads, and this patch improves the
performance of __d_lookup_rcu() and link_path_walk() by up to about 30%.
Giving a 10% improvement on some very pathname-heavy benchmarks.
Because we do make unaligned accesses past the filename, the
optimization is disabled when CONFIG_DEBUG_PAGEALLOC is active, and we
effectively depend on the fact that on x86 we don't really ever have the
last page of usable RAM followed immediately by any IO memory (due to
ACPI tables, BIOS buffer areas etc).
Some of the bit operations we do are a bit "subtle". It's commented,
but you do need to really think about the code. Or just consider it
black magic.
Thanks to people on G+ for some of the optimized bit tricks.
For some odd historical reason, the final mixing round for the dentry
cache hash table lookup had an insane "xor with big constant" logic. In
two places.
The big constant that is being xor'ed is GOLDEN_RATIO_PRIME, which is a
fairly random-looking number that is designed to be *multiplied* with so
that the bits get spread out over a whole long-word.
But xor'ing with it is insane. It doesn't really even change the hash -
it really only shifts the hash around in the hash table. To make
matters worse, the insane big constant is different on 32-bit and 64-bit
builds, even though the name hash bits we use are always 32-bit (and the
bits from the pointer we mix in effectively are too).
It's all total voodoo programming, in other words.
Now, some testing and analysis of the hash chains shows that the rest of
the hash function seems to be fairly good. It does pick the right bits
of the parent dentry pointer, for example, and while it's generally a
bad idea to use an xor to mix down the upper bits (because if there is a
repeating pattern, the xor can cause "destructive interference"), it
seems to not have been a disaster.
For example, replacing the hash with the normal "hash_long()" code (that
uses the GOLDEN_RATIO_PRIME constant correctly, btw) actually just makes
the hash worse. The hand-picked hash knew which bits of the pointer had
the highest entropy, and hash_long() ends up mixing bits less optimally
at least in some trivial tests.
So the hash function overall seems fine, it just has that really odd
"shift result around by a constant xor".
So get rid of the silly xor, and replace the down-mixing of the bits
with an add instead of an xor that tends to not have the same kind of
destructive interference issues. Some stats on the resulting hash
chains shows that they look statistically identical before and after,
but the code is simpler and no longer makes you go "WTF?".
Also, the incoming hash really is just "unsigned int", not a long, and
there's no real point to worry about the high 26 bits of the dentry
pointer for the 64-bit case, because they are all going to be identical
anyway.
So also change the hashing to be done in the more natural 'unsigned int'
that is the real size of the actual hashed data anyway.
Ok, this is hacky, and only works on little-endian machines with goo
unaligned handling. And even then only with CONFIG_DEBUG_PAGEALLOC
disabled, since it can access up to 7 bytes after the pathname.
But it runs like a bat out of hell.
It's only used inside fs/dcache.c, and we're going to play games with it
for the word-at-a-time patches. This time we really don't even want to
export it, because it really is an internal function to fs/dcache.c, and
has been since it was introduced.
Having it in that extremely hot header file (it's included in pretty
much everything, thanks to <linux/fs.h>) is a disaster for testing
different versions, and is utterly pointless.
We really should have some kind of header file diet thing, where we
figure out which parts of header files are really better off private and
only result in more expensive compiles.
These don't change any semantics, but they clean up the code a bit and
mark some arguments appropriately 'const'.
They came up as I was doing the word-at-a-time dcache name accessor
code, and cleaning this up now allows me to send out a smaller relevant
interesting patch for the experimental stuff.
When the number of dentry cache hash table entries gets too high
(2147483648 entries), as happens by default on a 16TB system, use of a
signed integer in the dcache_init() initialization loop prevents the
dentry_hashtable from getting initialized, causing a panic in
__d_lookup(). Fix this in dcache_init() and similar areas.
Signed-off-by: Dimitri Sivanich <sivanich@sgi.com>
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client:
ceph: ensure prealloc_blob is in place when removing xattr
rbd: initialize snap_rwsem in rbd_add()
ceph: enable/disable dentry complete flags via mount option
vfs: export symbol d_find_any_alias()
ceph: always initialize the dentry in open_root_dentry()
libceph: remove useless return value for osd_client __send_request()
ceph: avoid iput() while holding spinlock in ceph_dir_fsync
ceph: avoid useless dget/dput in encode_fh
ceph: dereference pointer after checking for NULL
crush: fix force for non-root TAKE
ceph: remove unnecessary d_fsdata conditional checks
ceph: Use kmemdup rather than duplicating its implementation
Fix up conflicts in fs/ceph/super.c (d_alloc_root() failure handling vs
always initialize the dentry in open_root_dentry)
Ceph needs this.
Signed-off-by: Sage Weil <sage@newdream.net>
Two (or more) concurrent calls of shrink_dcache_parent() on the same dentry may
cause shrink_dcache_parent() to loop forever.
Here's what appears to happen:
1 - CPU0: select_parent(P) finds C and puts it on dispose list, returns 1
2 - CPU1: select_parent(P) locks P->d_lock
3 - CPU0: shrink_dentry_list() locks C->d_lock
dentry_kill(C) tries to lock P->d_lock but fails, unlocks C->d_lock
4 - CPU1: select_parent(P) locks C->d_lock,
moves C from dispose list being processed on CPU0 to the new
5 - CPU0: shrink_dentry_list() finds dispose list empty, returns
6 - Goto 2 with CPU0 and CPU1 switched
Basically select_parent() steals the dentry from shrink_dentry_list() and thinks
it found a new one, causing shrink_dentry_list() to think it's making progress
and loop over and over.
One way to trigger this is to make udev calls stat() on the sysfs file while it
is going away.
Having a file in /lib/udev/rules.d/ with only this one rule seems to the trick:
ATTR{vendor}=="0x8086", ATTR{device}=="0x10ca", ENV{PCI_SLOT_NAME}="%k", ENV{MATCHADDR}="$attr{address}", RUN+="/bin/true"
Then execute the following loop:
while true; do
echo -bond0 > /sys/class/net/bonding_masters
echo +bond0 > /sys/class/net/bonding_masters
echo -bond1 > /sys/class/net/bonding_masters
echo +bond1 > /sys/class/net/bonding_masters
done
One fix would be to check all callers and prevent concurrent calls to
shrink_dcache_parent(). But I think a better solution is to stop the
stealing behavior.
This patch adds a new dentry flag that is set when the dentry is added to the
dispose list. The flag is cleared in dentry_lru_del() in case the dentry gets a
new reference just before being pruned.
If the dentry has this flag, select_parent() will skip it and let
shrink_dentry_list() retry pruning it. With select_parent() skipping those
dentries there will not be the appearance of progress (new dentries found) when
there is none, hence shrink_dcache_parent() will not loop forever.
Set the flag is also set in prune_dcache_sb() for consistency as suggested by
Linus.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
CC: stable@vger.kernel.org
d_alloc_root() with iput() in case of allocation failure...
select_parent currently abuses the dentry cache LRU to provide
cleanup features for child dentries that need to be freed. It moves
them to the tail of the LRU, then tells shrink_dcache_parent() to
calls __shrink_dcache_sb to unconditionally move them to a dispose
list (as DCACHE_REFERENCED is ignored). __shrink_dcache_sb() has to
relock the dentries to move them off the LRU onto the dispose list,
but otherwise does not touch the dentries that select_parent() moved
to the tail of the LRU. It then passses the dispose list to
shrink_dentry_list() which tries to free the dentries.
IOWs, the use of __shrink_dcache_sb() is superfluous - we can build
exactly the same list of dentries for disposal directly in
select_parent() and call shrink_dentry_list() instead of calling
__shrink_dcache_sb() to do that. This means that we avoid long holds
on the lru lock walking the LRU moving dentries to the dispose list
We also avoid the need to relock each dentry just to move it off the
LRU, reducing the numebr of times we lock each dentry to dispose of
them in shrink_dcache_parent() from 3 to 2 times.
Further, we remove one of the two callers of __shrink_dcache_sb().
This also means that __shrink_dcache_sb can be moved into back into
prune_dcache_sb() and we no longer have to handle referenced
dentries conditionally, simplifying the code.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
the second victim...
a) mount --move is checking that ->mnt_parent is non-NULL before
looking if that parent happens to be shared; ->mnt_parent is never
NULL and it's not even an misspelled !mnt_has_parent()
b) pivot_root open-codes is_path_reachable(), poorly.
c) so does path_is_under(), while we are at it.
vfsmounts have ->mnt_parent pointing either to a different vfsmount
or to itself; it's never NULL and termination condition in loops
traversing the tree towards root is mnt == mnt->mnt_parent. At least
one place (see the next patch) is confused about what's going on;
let's add an explicit helper checking it right way and use it in
all places where we need it. Not that there had been too many,
but...
__d_path() API is asking for trouble and in case of apparmor d_namespace_path()
getting just that. The root cause is that when __d_path() misses the root
it had been told to look for, it stores the location of the most remote ancestor
in *root. Without grabbing references. Sure, at the moment of call it had
been pinned down by what we have in *path. And if we raced with umount -l, we
could have very well stopped at vfsmount/dentry that got freed as soon as
prepend_path() dropped vfsmount_lock.
It is safe to compare these pointers with pre-existing (and known to be still
alive) vfsmount and dentry, as long as all we are asking is "is it the same
address?". Dereferencing is not safe and apparmor ended up stepping into
that. d_namespace_path() really wants to examine the place where we stopped,
even if it's not connected to our namespace. As the result, it looked
at ->d_sb->s_magic of a dentry that might've been already freed by that point.
All other callers had been careful enough to avoid that, but it's really
a bad interface - it invites that kind of trouble.
The fix is fairly straightforward, even though it's bigger than I'd like:
* prepend_path() root argument becomes const.
* __d_path() is never called with NULL/NULL root. It was a kludge
to start with. Instead, we have an explicit function - d_absolute_root().
Same as __d_path(), except that it doesn't get root passed and stops where
it stops. apparmor and tomoyo are using it.
* __d_path() returns NULL on path outside of root. The main
caller is show_mountinfo() and that's precisely what we pass root for - to
skip those outside chroot jail. Those who don't want that can (and do)
use d_path().
* __d_path() root argument becomes const. Everyone agrees, I hope.
* apparmor does *NOT* try to use __d_path() or any of its variants
when it sees that path->mnt is an internal vfsmount. In that case it's
definitely not mounted anywhere and dentry_path() is exactly what we want
there. Handling of sysctl()-triggered weirdness is moved to that place.
* if apparmor is asked to do pathname relative to chroot jail
and __d_path() tells it we it's not in that jail, the sucker just calls
d_absolute_path() instead. That's the other remaining caller of __d_path(),
BTW.
* seq_path_root() does _NOT_ return -ENAMETOOLONG (it's stupid anyway -
the normal seq_file logics will take care of growing the buffer and redoing
the call of ->show() just fine). However, if it gets path not reachable
from root, it returns SEQ_SKIP. The only caller adjusted (i.e. stopped
ignoring the return value as it used to do).
Reviewed-by: John Johansen <john.johansen@canonical.com>
ACKed-by: John Johansen <john.johansen@canonical.com>
Cc: stable@vger.kernel.org
To prevent an NFS server from being used to create a directory loop in an NFS
superblock on the client, the following patch was committed:
commit 1836750115f20b774e55c032a3893e8c5bdf41ed
Author: Al Viro <viro@zeniv.linux.org.uk>
Date: Tue Jul 12 21:42:24 2011 -0400
Subject: fix loop checks in d_materialise_unique()
This causes ELOOP to be reported to anyone trying to access the dentry that
would otherwise cause the kernel to complete the loop.
However, no indication is given to the caller as to why an operation that ought
to work doesn't. The fault is with the kernel, which doesn't want to try and
solve the problem as it gets horrendously messy if there's another mountpoint
somewhere in the trees being spliced that can't be moved[*].
[*] The real problem is that we don't handle the excision of a subtree that
gets moved _out_ of what we can see. This can happen on the server where a
directory is merely moved between two other dirs on the same filesystem, but
where destination dir is not accessible by the client.
So, given the choice to return ELOOP rather than trying to reconfigure the
dentry tree, we should give the caller some indication of why they aren't being
allowed to make what should be a legitimate request and log a message.
Acked-by: Sachin Prabhu <sprabhu@redhat.com>
This adds a d_prune dentry operation that is called by the VFS prior to
pruning (i.e. unhashing and killing) a hashed dentry from the dcache.
Wrap dentry_lru_del() and use the new _prune() helper in the cases where we
are about to unhash and kill the dentry.
This will be used by Ceph to maintain a flag indicating whether the
complete contents of a directory are contained in the dcache, allowing it
to satisfy lookups and readdir without addition server communication.
Renumber a few DCACHE_* #defines to group DCACHE_OP_PRUNE with the other
DCACHE_OP_ bits.
Gcc tends to generate better code with small integers, including the
DCACHE_xyz flag tests - so move the common ones to be first in the list.
Also just remove the unused DCACHE_INOTIFY_PARENT_WATCHED and
DCACHE_AUTOFS_PENDING values, their users no longer exists in the source
tree.
And add a "unlikely()" to the DCACHE_OP_COMPARE test, since we want the
common case to be a nice straight-line fall-through.
Fix new kernel-doc warning in fs/dcache.c:
Warning(fs/dcache.c:797): No description found for parameter 'sb'
Reorganise shrink_dcache_for_umount_subtree() in light of the demise of
dcache_lock. Without that dcache_lock, there is no need for the batching of
removal of dentries from the system under it (we wanted to make intensive use
of the locked data whilst we held it, but didn't want to hold it for long at a
time).
This works, provided the preceding patch is correct in its removal of locking
on dentry->d_lock on the basis that no one should be locking these dentries any
more as the whole superblock is defunct.
With this patch, the calls to dentry_lru_del() and __d_shrink() are placed at
the point where each dentry is detached handled.
It is possible that, as an alternative, the batching should still be done -
but only for dentry_lru_del() of all a dentry's children in one go. In such a
case, the batching would be done under dcache_lru_lock.
Locks of the dcache_lock were replaced by locks of dentry->d_lock in commits
such as:
2304450783dfde7b0b94ae234edd0dbffa865073
2fd6b7f50797f2e993eea59e0a0b8c6399c811dc
as part of the RCU-based pathwalk changes, despite the fact that the caller
(shrink_dcache_for_umount()) notes in the banner comment the reasons that
d_lock is not necessary in these functions:
* destroy the dentries attached to a superblock on unmounting
* - we don't need to use dentry->d_lock because:
* - the superblock is detached from all mountings and open files, so the
* dentry trees will not be rearranged by the VFS
* - s_umount is write-locked, so the memory pressure shrinker will ignore
* any dentries belonging to this superblock that it comes across
* - the filesystem itself is no longer permitted to rearrange the dentries
* in this superblock
So remove these locks. If the locks are actually necessary, then this banner
comment should be altered instead.
The hash table chains are protected by 1-bit locks in the hash table heads, so
those shouldn't be a problem.
Note that to make this work, __d_drop() has to be split so that the RCUwalk
barrier can be avoided. This causes problems otherwise as it has an assertion
that dentry->d_lock is locked - but there is no need for that as no one else
can be trying to access this dentry, except to step over it (and that should
be handled by d_free(), I think).
Cc: Nick Piggin <npiggin@kernel.dk>
Remove the detached-dentry counter from shrink_dcache_for_umount_subtree() as
the value it computes is no longer used as of commit
312d3ca856d369bb04d0443846b85b4cdde6fa8a which made the nr_dentry counters
summed per-CPU rather than global atomic.
Adding a comment to d_materialise_unique per Al's request...
d_move and __d_move have some pretty substantial locking requirements,
but they are not clearly documented. Add some comments spelling them
out. Also, document the requirement for the i_mutex of the parent in
d_materialise_unique.
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Signed-off-by: Jeff Layton <jlayton@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits)
vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp
isofs: Remove global fs lock
jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory
fix IN_DELETE_SELF on overwriting rename() on ramfs et.al.
mm/truncate.c: fix build for CONFIG_BLOCK not enabled
fs:update the NOTE of the file_operations structure
Remove dead code in dget_parent()
AFS: Fix silly characters in a comment
switch d_add_ci() to d_splice_alias() in "found negative" case as well
simplify gfs2_lookup()
jfs_lookup(): don't bother with . or ..
get rid of useless dget_parent() in btrfs rename() and link()
get rid of useless dget_parent() in fs/btrfs/ioctl.c
fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers
drivers: fix up various ->llseek() implementations
fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek
Ext4: handle SEEK_HOLE/SEEK_DATA generically
Btrfs: implement our own ->llseek
fs: add SEEK_HOLE and SEEK_DATA flags
reiserfs: make reiserfs default to barrier=flush
Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new
shrinker callout for the inode cache, that clashed with the xfs code to
start the periodic workers later.
It seems to hurt performance in real life. Yes, the inode will be used
later, but the conditional doesn't seem to predict all that well
(negative dentries are not uncommon) and it looks like the cost of
prefetching is simply higher than depending on the cache doing the right
thing.
As usual.
->d_parent is never NULL...
With context based shrinkers, we can implement a per-superblock
shrinker that shrinks the caches attached to the superblock. We
currently have global shrinkers for the inode and dentry caches that
split up into per-superblock operations via a coarse proportioning
method that does not batch very well. The global shrinkers also
have a dependency - dentries pin inodes - so we have to be very
careful about how we register the global shrinkers so that the
implicit call order is always correct.
With a per-sb shrinker callout, we can encode this dependency
directly into the per-sb shrinker, hence avoiding the need for
strictly ordering shrinker registrations. We also have no need for
any proportioning code for the shrinker subsystem already provides
this functionality across all shrinkers. Allowing the shrinker to
operate on a single superblock at a time means that we do less
superblock list traversals and locking and reclaim should batch more
effectively. This should result in less CPU overhead for reclaim and
potentially faster reclaim of items from each filesystem.
... and simplify the living hell out of callers
New helper (non-exported, fs/internal.h-only): __d_alloc(sb, name).
Allocates dentry, sets its ->d_sb to given superblock and sets
->d_op accordingly. Old d_alloc(NULL, name) callers are converted
to that (all of them know what superblock they want). d_alloc()
itself is left only for parent != NULl case; uses __d_alloc(),
inserts result into the list of parent's children.
Note that now ->d_sb is assign-once and never NULL *and*
->d_parent is never NULL either.
Btrfs (and I'd venture most other fs's) stores its indexes in nice disk order
for readdir, but unfortunately in the case of anything that stats the files in
order that readdir spits back (like oh say ls) that means we still have to do
the normal lookup of the file, which means looking up our other index and then
looking up the inode. What I want is a way to create dummy dentries when we
find them in readdir so that when ls or anything else subsequently does a
stat(), we already have the location information in the dentry and can go
straight to the inode itself. The lookup stuff just assumes that if it finds a
dentry it is done, it doesn't perform a lookup. So add a DCACHE_NEED_LOOKUP
flag so that the lookup code knows it still needs to run i_op->lookup() on the
parent to get the inode for the dentry. I have tested this with btrfs and I
went from something that looks like this
http://people.redhat.com/jwhiter/ls-noreada.png
To this
http://people.redhat.com/jwhiter/ls-good.png
Thats a savings of 1300 seconds, or 22 minutes. That is a significant savings.
Thanks,
Signed-off-by: Josef Bacik <josef@redhat.com>
Both __d_unalias() and __d_materialise_dentry() need loop prevention.
Grab rename_lock in caller, check for loops there...
As a side benefit, we have dentry_lock_for_move() called only under
rename_lock, which seriously reduces deadlock potential of the
execrable "locking order" used for ->d_lock.
Change each shrinker's API by consolidating the existing parameters into
shrink_control struct. This will simplify any further features added w/o
touching each file of shrinker.
[akpm@linux-foundation.org: fix build]
[akpm@linux-foundation.org: fix warning]
[kosaki.motohiro@jp.fujitsu.com: fix up new shrinker API]
[akpm@linux-foundation.org: fix xfs warning]
[akpm@linux-foundation.org: update gfs2]
Signed-off-by: Ying Han <yinghan@google.com>
Cc: Minchan Kim <minchan.kim@gmail.com>
Acked-by: Pavel Emelyanov <xemul@openvz.org>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Commit e66eed651fd1 ("list: remove prefetching from regular list
iterators") removed the include of prefetch.h from list.h, which
uncovered several cases that had apparently relied on that rather
obscure header file dependency.
So this fixes things up a bit, using
grep -L linux/prefetch.h $(git grep -l '[^a-z_]prefetchw*(' -- '*.[ch]')
grep -L 'prefetchw*(' $(git grep -l 'linux/prefetch.h' -- '*.[ch]')
to guide us in finding files that either need <linux/prefetch.h>
inclusion, or have it despite not needing it.
There are more of them around (mostly network drivers), but this gets
many core ones.
Now that the whole dcache_hash_bucket crap is gone, go all the way and
also remove the weird locking layering violations for locking the hash
buckets. Add hlist_bl_lock/unlock helpers to move the locking into the
list abstraction instead of requiring each caller to open code it.
After all allowing for the bit locks is the whole point of these helpers
over the plain hlist variant.
The dentry hashing rules have been really quite complicated for a long
while, in odd ways. That made functions like __d_drop() very fragile
and non-obvious.
In particular, whether a dentry was hashed or not was indicated with an
explicit DCACHE_UNHASHED bit. That's despite the fact that the hash
abstraction that the dentries use actually have a 'is this entry hashed
or not' model (which is a simple test of the 'pprev' pointer).
The reason that was done is because we used the normal 'is this entry
unhashed' model to mark whether the dentry had _ever_ been hashed in the
dentry hash tables, and that logic goes back many years (commit
b3423415fbc2: "dcache: avoid RCU for never-hashed dentries").
That, in turn, meant that __d_drop had totally different unhashing logic
for the dentry hash table case and for the anonymous dcache case,
because in order to use the "is this dentry hashed" logic as a flag for
whether it had ever been on the RCU hash table, we had to unhash such a
dentry differently so that we'd never think that it wasn't 'unhashed'
and wouldn't be free'd correctly.
That's just insane. It made the logic really hard to follow, when there
were two different kinds of "unhashed" states, and one of them (the one
that used "list_bl_unhashed()") really had nothing at all to do with
being unhashed per se, but with a very subtle lifetime rule instead.
So turn all of it around, and make it logical.
Instead of having a DENTRY_UNHASHED bit in d_flags to indicate whether
the dentry is on the hash chains or not, use the hash chain unhashed
logic for that. Suddenly "d_unhashed()" just uses "list_bl_unhashed()",
and everything makes sense.
And for the lifetime rule, just use an explicit DENTRY_RCUACCEES bit.
If we ever insert the dentry into the dentry hash table so that it is
visible to RCU lookup, we mark it DENTRY_RCUACCESS to show that it now
needs the RCU lifetime rules. Now suddently that test at dentry free
time makes sense too.
And because unhashing now is sane and doesn't depend on where the dentry
got unhashed from (because the dentry hash chain details doesn't have
some subtle side effects), we can re-unify the __d_drop() logic and use
common code for the unhashing.
Also fix one more open-coded hash chain bit_spin_lock() that I missed in
the previous chain locking cleanup commit.
It's a useless abstraction for 'hlist_bl_head', and it doesn't actually
help anything - quite the reverse. All the users end up having to know
about the hlist_bl_head details anyway, using 'struct hlist_bl_node *'
etc. So it just makes the code look confusing.
And the cost of it is extra '&b->head' syntactic noise, but more
importantly it spuriously makes the hash table dentry list look
different from the per-superblock DCACHE_DISCONNECTED dentry list.
As a result, the code ended up using ad-hoc locking for one case and
special helper functions for what is really another totally identical
case in the very same function.
Make it all look and work the same.
The case we should be verifying when updating the dentry name is that
the _parent_ inode (the directory) semaphore is held, not the semaphore
for the dentry itself. It's the directory locking that rename and
readdir() etc all care about.
The comment just above even says so - but then the BUG_ON() still
checked the dentry inode itself.
Very few people noticed, because this helper function really isn't used
for very much, so you had to be using ncpfs to ever hit it.
I think I should just remove the BUG_ON (the function really has just
one user), but let's run with it fixed for a while before getting rid of
it entirely.
Reported-and-tested-by: Bongani Hlope <bonganih@bankservafrica.com>
Reported-and-tested-by: Bernd Feige <bernd.feige@uniklinik-freiburg.de>
Cc: Petr Vandrovec <petr@vandrovec.name>,
fs: call security_d_instantiate in d_obtain_alias V2
lose 'mounting_here' argument in ->d_manage()
don't pass 'mounting_here' flag to follow_down()
change the locking order for namespace_sem
fix deadlock in pivot_root()
vfs: split off vfsmount-related parts of vfs_kern_mount()
Some fixes for pstore
kill simple_set_mnt()
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (47 commits)
doc: CONFIG_UNEVICTABLE_LRU doesn't exist anymore
Update cpuset info & webiste for cgroups
dcdbas: force SMI to happen when expected
arch/arm/Kconfig: remove one to many l's in the word.
asm-generic/user.h: Fix spelling in comment
drm: fix printk typo 'sracth'
Remove one to many n's in a word
Documentation/filesystems/romfs.txt: fixing link to genromfs
drivers:scsi Change printk typo initate -> initiate
serial, pch uart: Remove duplicate inclusion of linux/pci.h header
fs/eventpoll.c: fix spelling
mm: Fix out-of-date comments which refers non-existent functions
drm: Fix printk typo 'failled'
coh901318.c: Change initate to initiate.
mbox-db5500.c Change initate to initiate.
edac: correct i82975x error-info reported
edac: correct i82975x mci initialisation
edac: correct commented info
fs: update comments to point correct document
target: remove duplicate include of target/target_core_device.h from drivers/target/target_core_hba.c
Trivial conflict in fs/eventpoll.c (spelling vs addition)
While trying to track down some NFS problems with BTRFS, I kept noticing I was
getting -EACCESS for no apparent reason. Eric Paris and printk() helped me
figure out that it was SELinux that was giving me grief, with the following
denial
type=AVC msg=audit(1290013638.413:95): avc: denied { 0x800000 } for pid=1772
comm="nfsd" name="" dev=sda1 ino=256 scontext=system_u:system_r:kernel_t:s0
tcontext=system_u:object_r:unlabeled_t:s0 tclass=file
Turns out this is because in d_obtain_alias if we can't find an alias we create
one and do all the normal instantiation stuff, but we don't do the
security_d_instantiate.
Usually we are protected from getting a hashed dentry that hasn't yet run
security_d_instantiate() by the parent's i_mutex, but obviously this isn't an
option there, so in order to deal with the case that a second thread comes in
and finds our new dentry before we get to run security_d_instantiate(), we go
ahead and call it if we find a dentry already. Eric assures me that this is ok
as the code checks to see if the dentry has been initialized already so calling
security_d_instantiate() against the same dentry multiple times is ok. With
this patch I'm no longer getting errant -EACCESS values.
The new vfs locking scheme introduced in 2.6.38 breaks NFS sillyrename
because the latter relies on being able to determine the parent
directory of the dentry in the ->iput() callback in order to send the
appropriate unlink rpc call.
Looking at the code that cares about races with dput(), there doesn't
seem to be anything that specifically uses d_parent as a test for
whether or not there is a race:
- __d_lookup_rcu(), __d_lookup() all test for d_hashed() after d_parent
- shrink_dcache_for_umount() is safe since nothing else can rearrange
the dentries in that super block.
- have_submount(), select_parent() and d_genocide() can test for a
deletion if we set the DCACHE_DISCONNECTED flag when the dentry
is removed from the parent's d_subdirs list.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Cc: stable@kernel.org (2.6.38, needs commit c826cb7dfce8 "dcache.c:
create helper function for duplicated functionality" )
