path: root/fs/cramfs
2008-08-20cramfs: fix named-pipe handlingAl Viro
After commit a97c9bf33f4612e2aed6f000f6b1d268b6814f3c (fix cramfs making duplicate entries in inode cache) in kernel 2.6.14, named-pipe on cramfs does not work properly. It seems the commit make all named-pipe on cramfs share their inode (and named-pipe buffer). Make ..._test() refuse to merge inodes with ->i_ino == 1, take inode setup back to get_cramfs_inode() and make ->drop_inode() evict ones with ->i_ino == 1 immediately. Reported-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <stable@kernel.org> [2.6.14 and later] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-18fs: Remove unnecessary inclusions of asm/semaphore.hMatthew Wilcox
None of these files use any of the functionality promised by asm/semaphore.h. Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-10-18fs/cramfs/inode.c: replace hardcoded value with preprocessor constantAndi Drebes
Remove the hardcoded value 256 in fs/cramfs/inode.c and replaces it with CRAMFS_MAXPATHLEN. Tested on an i386 box. Signed-off-by: Andi Drebes <lists-receive@programmierforen.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18fs/cramfs/inode.c: remove unused variableAndi Drebes
Remove a variable that is never read. Signed-off-by: Andi Drebes <lists-receive@programmierforen.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17cramfs: error message about endianessAndi Drebes
The README file in the cramfs subdirectory says: "All data is currently in host-endian format; neither mkcramfs nor the kernel ever do swabbing." If somebody tries to mount a cramfs with the wrong endianess, cramfs only complains about a wrong magic but doesn't inform the user that only the endianess isn't right. The following patch adds an error message to the cramfs sources. If a user tries to mount a cramfs with the wrong endianess using the patched sources, cramfs will display the message "cramfs: wrong endianess". Signed-off-by: Andi Drebes <lists-receive@programmierforen.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: make read_cache_page synchronousNick Piggin
Ensure pages are uptodate after returning from read_cache_page, which allows us to cut out most of the filesystem-internal PageUptodate calls. I didn't have a great look down the call chains, but this appears to fixes 7 possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in block2mtd. All depending on whether the filler is async and/or can return with a !uptodate page. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] struct path: convert cramfsJosef Sipek
2006-12-07[PATCH] corrupted cramfs filesystems cause kernel oopsPhillip Lougher
Steve Grubb's fzfuzzer tool (http://people.redhat.com/sgrubb/files/ fsfuzzer-0.6.tar.gz) generates corrupt Cramfs filesystems which cause Cramfs to kernel oops in cramfs_uncompress_block(). The cause of the oops is an unchecked corrupted block length field read by cramfs_readpage(). This patch adds a sanity check to cramfs_readpage() which checks that the block length field is sensible. The (PAGE_CACHE_SIZE << 1) size check is intentional, even though the uncompressed data is not going to be larger than PAGE_CACHE_SIZE, gzip sometimes generates compressed data larger than the original source data. Mkcramfs checks that the compressed size is always less than or equal to PAGE_CACHE_SIZE << 1. Of course Cramfs could use the original uncompressed data in this case, but it doesn't. Signed-off-by: Phillip Lougher <phillip@lougher.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] cramfs: make cramfs_uncompress_exit() return voidAlexey Dobriyan
It always returns 0, so relying on it is useless. The only caller isn't checking return value. In general, un-, de-, -free functions should return void. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] cramfs: rewrite init_cramfs_fs()Alexey Dobriyan
Two lines -- two bugs. :-( Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] fs: Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to kzalloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Jffs2-bit-acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] read_mapping_page for address spacePekka Enberg
Add read_mapping_page() which is used for callers that pass mapping->a_ops->readpage as the filler for read_cache_page. This removes some duplication from filesystem code. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] sem2mutex: fs/Ingo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Cc: Robert Love <rml@tech9.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-06[PATCH] cramfs mounts provide corrupted content since 2.6.15Dave Johnson
Fix handling of cramfs images created by util-linux containing empty regular files. Images created by cramfstools 1.x were ok. Fill out inode contents in cramfs_iget5_set() instead of get_cramfs_inode() to prevent issues if cramfs_iget5_test() is called with I_LOCK|I_NEW still set. Signed-off-by: Dave Johnson <djohnson+linux-kernel@sw.starentnetworks.com> Cc: Olaf Hering <olh@suse.de> Cc: Chris Mason <mason@suse.com> Cc: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] fs/cramfs/uncompress.c should #include <linux/cramfs_fs.h>Adrian Bunk
Every file should #include the header with the prototypes of the global functions it is offering. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] fix cramfs making duplicate entries in inode cacheDave Johnson
Every time cramfs_lookup() is called to lookup and inode for a dentry, get_cramfs_inode() will allocate a new inode without checking to see if that inode already exists in the inode cache. This is fine the first time, but if the dentry cache entry(ies) associated with that inode are aged out, but the inode entry is not aged out (which can be quite common if the inode has buffer cache linked to it), cramfs_lookup() will be called again and another inode will be allocated and added to the inode cache creating a duplicate in the inode cache. The big issue here is that the buffers associated with each inode cache entry are not shared between the duplicates! The older inode entries are now orphaned as no dentry points to it and won't be freed until the buffer cache assoicated with them are first freed. The newest entry will have to create all new buffer cache for each part of its file as the old buffer cache is now orphaned as well. Patch below fixes this by making get_cramfs_inode() use the inode cache before blindly creating a new entry every time. This eliminates the duplicate inodes and duplicate buffer cache. Cc: Phillip Lougher <phillip@lougher.demon.co.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
