kernel_kset does not need to be a kset, but a much simpler kobject now
that we have kobj_attributes.
We also rename kernel_kset to kernel_kobj to catch all users of this
symbol with a build error instead of an easy-to-ignore build warning.
Cc: Kay Sievers <kay.sievers@vrfy.org>
Dynamically create the kset instead of declaring it statically. We also
rename kernel_subsys to kernel_kset to catch all users of this symbol
We don't need a kset here, a simple kobject will do just fine, so
dynamically create the kobject and use it.
Signed-off-by: Joel Becker <joel.becker@oracle.com>
We don't need a "default" ktype for a kset. We should set this
explicitly every time for each kset. This change is needed so that we
can make ksets dynamic, and cleans up one of the odd, undocumented
assumption that the kset/kobject/ktype model has.
This patch is based on a lot of help from Kay Sievers.
Nasty bug in the block code was found by Dave Young
<hidave.darkstar@gmail.com>
Cc: Dave Young <hidave.darkstar@gmail.com>
Why do we need r/o bind mounts?
This feature allows a read-only view into a read-write filesystem. In the
process of doing that, it also provides infrastructure for keeping track of
the number of writers to any given mount.
This has a number of uses. It allows chroots to have parts of filesystems
writable. It will be useful for containers in the future because users may
have root inside a container, but should not be allowed to write to
somefilesystems. This also replaces patches that vserver has had out of the
tree for several years.
It allows security enhancement by making sure that parts of your filesystem
read-only (such as when you don't trust your FTP server), when you don't want
to have entire new filesystems mounted, or when you want atime selectively
updated. I've been using the following script to test that the feature is
working as desired. It takes a directory and makes a regular bind and a r/o
bind mount of it. It then performs some normal filesystem operations on the
three directories, including ones that are expected to fail, like creating a
file on the r/o mount.
This patch:
Some filesystems forego the vfs and may_open() and create their own 'struct
file's.
This patch creates a couple of helper functions which can be used by these
filesystems, and will provide a unified place which the r/o bind mount code
may patch.
Also, rename an existing, static-scope init_file() to a less generic name.
Signed-off-by: Dave Hansen <haveblue@us.ibm.com>
provide BDI constructor/destructor hooks
[akpm@linux-foundation.org: compile fix]
Implement new aops for some of the simpler filesystems.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Slab destructors were no longer supported after Christoph's
c59def9f222d44bb7e2f0a559f2906191a0862d7 change. They've been
BUGs for both slab and slub, and slob never supported them
either.
This rips out support for the dtor pointer from kmem_cache_create()
completely and fixes up every single callsite in the kernel (there were
about 224, not including the slab allocator definitions themselves,
or the documentation references).
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
Sometimes other drivers depend on particular configfs items. For
example, ocfs2 mounts depend on a heartbeat region item. If that
region item is removed with rmdir(2), the ocfs2 mount must BUG or go
readonly. Not happy.
This provides two additional API calls: configfs_depend_item() and
configfs_undepend_item(). A client driver can call
configfs_depend_item() on an existing item to tell configfs that it is
depended on. configfs will then return -EBUSY from rmdir(2) for that
item. When the item is no longer depended on, the client driver calls
configfs_undepend_item() on it.
These API cannot be called underneath any configfs callbacks, as
they will conflict. They can block and allocate. A client driver
probably shouldn't calling them of its own gumption. Rather it should
be providing an API that external subsystems call.
How does this work? Imagine the ocfs2 mount process. When it mounts,
it asks for a heart region item. This is done via a call into the
heartbeat code. Inside the heartbeat code, the region item is looked
up. Here, the heartbeat code calls configfs_depend_item(). If it
succeeds, then heartbeat knows the region is safe to give to ocfs2.
If it fails, it was being torn down anyway, and heartbeat can gracefully
pass up an error.
[ Fixed some bad whitespace in configfs.txt. --Mark ]
Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
Add a notification callback, ops->disconnect_notify(). It has the same
prototype as ->drop_item(), but it will be called just before the item
linkage is broken. This way, configfs users who want to do work while
the object is still in the heirarchy have a chance.
Client drivers will still need to config_item_put() in their
->drop_item(), if they implement it. They need do nothing in
->disconnect_notify(). They don't have to provide it if they don't
care. But someone who wants to be notified before ci_parent is set to
NULL can now be notified.
Seems copied from sysfs, but I don't see a reason here nor there to use
a semaphore instead of a mutex. Convert.
Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
Convert the su_sem member of struct configfs_subsystem to a struct
mutex, as that's what it is. Also convert all the users and update
Documentation/configfs.txt and Documentation/configfs_example.c
accordingly.
[ Conflict in fs/dlm/config.c with commit
3168b0780d06ace875696f8a648d04d6089654e5 manually resolved. --Mark ]
Inspired-by: Satyam Sharma <ssatyam@cse.iitk.ac.in>
Configfs being based upon sysfs code, config_group_find_obj() is probably
so named because of the similar kset_find_obj() in sysfs. However,
"kobject"s in sysfs become "config_item"s in configfs, so let's call it
config_group_find_item() instead, for sake of uniformity, and make
corresponding change in the users of this function.
BTW a crucial difference between kset_find_obj and config_group_find_item
is in locking expectations. kset_find_obj does its locking by itself, but
config_group_find_item expects the *caller* to do the locking. The reason
for this: kset's have their own locks, config_group's don't but instead
rely on the subsystem mutex. And, subsystem needn't necessarily be around
when config_group_find_item() is called.
So let's state these locking semantics explicitly, and rectify the comment,
otherwise bugs could continue to occur in future, as they did in the past
(refer commit d82b8191e238 in gfs2-2.6-fixes.git).
[ I also took the opportunity to fix some bad whitespace and
double-empty lines. --Joel ]
Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in>
Cc: David Teigland <teigland@redhat.com>
1. item.c:config_item_cleanup() is a private function (only called by
config_item_release() in same file). However, it is spuriously
exported in include/linux/configfs.h, so remove that export and make
it static in item.c. Also, it is no longer exported / interface
function, so no need to give comment for this function (the comment
was stating obvious thing, anyway).
2. Kernel-doc comment format does not allow empty line between end of
comment and start of function (declaration line). There were several
such spurious empty lines in item.c, so fix them.
fs/configfs/item.c | 15 +++------------
include/linux/configfs.h | 1 -
2 files changed, 3 insertions(+), 13 deletions(-)
The attribute store/show code currently limits attributes at PAGE_SIZE.
This code comes from sysfs, where it still works that way.
However, PAGE_SIZE is not constant. A 16k attribute string works on
ia64 but not on x86. Really a subsystem shouldn't allow different
attribute sizes based on platform.
As such, limit all simple attributes to 4k. This works on all
platforms, and is consistent with all current code.
First thing mm.h does is including sched.h solely for can_do_mlock() inline
function which has "current" dereference inside. By dealing with can_do_mlock()
mm.h can be detached from sched.h which is good. See below, why.
This patch
a) removes unconditional inclusion of sched.h from mm.h
b) makes can_do_mlock() normal function in mm/mlock.c
c) exports can_do_mlock() to not break compilation
d) adds sched.h inclusions back to files that were getting it indirectly.
e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were
getting them indirectly
Net result is:
a) mm.h users would get less code to open, read, preprocess, parse, ... if
they don't need sched.h
b) sched.h stops being dependency for significant number of files:
on x86_64 allmodconfig touching sched.h results in recompile of 4083 files,
after patch it's only 3744 (-8.3%).
Cross-compile tested on
all arm defconfigs, all mips defconfigs, all powerpc defconfigs,
alpha alpha-up
arm
i386 i386-up i386-defconfig i386-allnoconfig
ia64 ia64-up
m68k
mips
parisc parisc-up
powerpc powerpc-up
s390 s390-up
sparc sparc-up
sparc64 sparc64-up
um-x86_64
x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig
as well as my two usual configs.
Cleanup using simple_read_from_buffer() in binfmt_misc, configfs, and sysfs.
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Joel Becker <joel.becker@oracle.com>
We need to work on cleaning up the relationship between kobjects, ksets and
ktypes. The removal of 'struct subsystem' is the first step of this,
especially as it is not really needed at all.
Thanks to Kay for fixing the bugs in this patch.
d_alloc() failure in configfs_register_subsystem() would fail to unlock
the mutex taken above. Reorganize the exit path to ensure the unlock
happens.
Reported-by: Akinobu Mita <akinobu.mita@gmail.com>
This patch is inspired by Arjan's "Patch series to mark struct
file_operations and struct inode_operations const".
Compile tested with gcc & sparse.
Signed-off-by: Josef 'Jeff' Sipek <jsipek@cs.sunysb.edu>
Many struct inode_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Replace appropriate pairs of "kmem_cache_alloc()" + "memset(0)" with the
corresponding "kmem_cache_zalloc()" call.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Andi Kleen <ak@muc.de>
Cc: Roland McGrath <roland@redhat.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Greg KH <greg@kroah.com>
Acked-by: Joel Becker <Joel.Becker@oracle.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Jan Kara <jack@ucw.cz>
Cc: Michael Halcrow <mhalcrow@us.ibm.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
Cc: Chris Wright <chrisw@sous-sol.org>
Attributes in configfs are text files. As such, most handlers expect to be
able to call functions like simple_strtoul() without checking the bounds
of the buffer. Change the call to zero terminate the buffer before calling
the client's ->store() method. This does reduce the attribute size from
PAGE_SIZE to PAGE_SIZE-1.
Also, change get_zeroed_page() to alloc_page(), as we are handling the
termination.
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the
configfs filesystem.
Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu>
Replace all uses of kmem_cache_t with struct kmem_cache.
The patch was generated using the following script:
#!/bin/sh
# Replace one string by another in all the kernel sources.
set -e
for file in `find * -name "*.c" -o -name "*.h"|xargs grep -l $1`; do
quilt add $file
sed -e "1,\$s/$1/$2/g" $file >/tmp/$$
mv /tmp/$$ $file
quilt refresh
done
The script was run like this
sh replace kmem_cache_t "struct kmem_cache"
Signed-off-by: Christoph Lameter <clameter@sgi.com>
This patch makes the needlessly global configfs_dirent_exists() static.
configfs_unregister_subsystem() nests a pair of inode i_mutex acquisitions,
and thus needs annotation via mutex_lock_nested().
check_perm() does not drop the reference to the module when kzalloc()
failure occurs.
Signed-Off-By: Chandra Seetharaman <sekharan@us.ibm.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6: (292 commits)
[GFS2] Fix endian bug for de_type
[GFS2] Initialize SELinux extended attributes at inode creation time.
[GFS2] Move logging code into log.c (mostly)
[GFS2] Mark nlink cleared so VFS sees it happen
[GFS2] Two redundant casts removed
[GFS2] Remove uneeded endian conversion
[GFS2] Remove duplicate sb reading code
[GFS2] Mark metadata reads for blktrace
[GFS2] Remove iflags.h, use FS_
[GFS2] Fix code style/indent in ops_file.c
[GFS2] streamline-generic_file_-interfaces-and-filemap gfs fix
[GFS2] Remove readv/writev methods and use aio_read/aio_write instead (gfs bits)
[GFS2] inode-diet: Eliminate i_blksize from the inode structure
[GFS2] inode_diet: Replace inode.u.generic_ip with inode.i_private (gfs)
[GFS2] Fix typo in last patch
[GFS2] Fix direct i/o logic in filemap.c
[GFS2] Fix bug in Makefiles for lock modules
[GFS2] Remove (extra) fs_subsys declaration
[GFS2/DLM] Fix trailing whitespace
[GFS2] Tidy up meta_io code
argument
configfs: use size_t length modifier in pr_debug format argument
Signed-off-by: Zach Brown <zach.brown@oracle.com>
Acked-by: Joel Becker <joel.becker@oracle.com>
This is mostly included for parity with dec_nlink(), where we will have some
more hooks. This one should stay pretty darn straightforward for now.
Acked-by: Christoph Hellwig <hch@lst.de>
This eliminates the i_blksize field from struct inode. Filesystems that want
to provide a per-inode st_blksize can do so by providing their own getattr
routine instead of using the generic_fillattr() function.
Note that some filesystems were providing pretty much random (and incorrect)
values for i_blksize.
[bunk@stusta.de: cleanup]
[akpm@osdl.org: generic_fillattr() fix]
Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
Conversions from kmalloc+memset to kzalloc.
Signed-off-by: Panagiotis Issaris <takis@issaris.org>
Jffs2-bit-acked-by: David Woodhouse <dwmw2@infradead.org>
This fixes up a couple of conflicts when merging up with
Linus' latest kernel. This will hopefully allow GFS2 to
be more easily merged into forthcoming -mm and FC kernels
due to the "one line per header" format now used for the
kernel headers.
Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
include/linux/Kbuild
include/linux/kernel.h
For all child objects, creation comes through mkdir(2), so duplicate names
are prevented.
Subsystems, though, are registered by client drivers at init_module()/__init
time. This patch prevents duplicate subsystem names.
Same as with already do with the file operations: keep them in .rodata and
prevents people from doing runtime patching.
Cc: Steven French <sfrench@us.ibm.com>
This patch converts the combination of list_del(A) and list_add(A, B) to
list_move(A, B) under fs/.
Cc: Ian Kent <raven@themaw.net>
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Cc: Hans Reiser <reiserfs-dev@namesys.com>
Cc: Urban Widmark <urban@teststation.com>
Acked-by: Mark Fasheh <mark.fasheh@oracle.com>
Signed-off-by: Akinobu Mita <mita@miraclelinux.com>
fs/nfs/inode.c
fs/super.c
Fix conflicts between patch 'NFS: Split fs/nfs/inode.c' and patch
'VFS: Permit filesystem to override root dentry on mount'
Extend the get_sb() filesystem operation to take an extra argument that
permits the VFS to pass in the target vfsmount that defines the mountpoint.
The filesystem is then required to manually set the superblock and root dentry
pointers. For most filesystems, this should be done with simple_set_mnt()
which will set the superblock pointer and then set the root dentry to the
superblock's s_root (as per the old default behaviour).
The get_sb() op now returns an integer as there's now no need to return the
superblock pointer.
This patch permits a superblock to be implicitly shared amongst several mount
points, such as can be done with NFS to avoid potential inode aliasing. In
such a case, simple_set_mnt() would not be called, and instead the mnt_root
and mnt_sb would be set directly.
The patch also makes the following changes:
(*) the get_sb_*() convenience functions in the core kernel now take a vfsmount
pointer argument and return an integer, so most filesystems have to change
very little.
(*) If one of the convenience function is not used, then get_sb() should
normally call simple_set_mnt() to instantiate the vfsmount. This will
always return 0, and so can be tail-called from get_sb().
(*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the
dcache upon superblock destruction rather than shrink_dcache_anon().
This is required because the superblock may now have multiple trees that
aren't actually bound to s_root, but that still need to be cleaned up. The
currently called functions assume that the whole tree is rooted at s_root,
and that anonymous dentries are not the roots of trees which results in
dentries being left unculled.
However, with the way NFS superblock sharing are currently set to be
implemented, these assumptions are violated: the root of the filesystem is
simply a dummy dentry and inode (the real inode for '/' may well be
inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries
with child trees.
[*] Anonymous until discovered from another tree.
(*) The documentation has been adjusted, including the additional bit of
changing ext2_* into foo_* in the documentation.
[akpm@osdl.org: convert ipath_fs, do other stuff]
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Cc: Nathan Scott <nathans@sgi.com>
Cc: Roland Dreier <rolandd@cisco.com>
Replace all module uses with the new vfs_kern_mount() interface, and fix up
simple_pin_fs().
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
If configfs_mkdir() errored in certain ways after the parent<->child
linkage was already created, it would not undo the linkage. Also,
comment the reference counting for clarity.
configfs_mkdir() failed to release the working parent reference in most
exit paths. Also changed the exit path for readability.
We check the "group" pointer after we dereference it. This check is
bogus, as it cannot be NULL coming in.
