path: root/fs/configfs
2019-09-04configfs: provide exclusion between IO and removalsAl Viro
Make sure that attribute methods are not called after the item has been removed from the tree. To do so, we * at the point of no return in removals, grab ->frag_sem exclusive and mark the fragment dead. * call the methods of attributes with ->frag_sem taken shared and only after having verified that the fragment is still alive. The main benefit is for method instances - they are guaranteed that the objects they are accessing *and* all ancestors are still there. Another win is that we don't need to bother with extra refcount on config_item when opening a file - the item will be alive for as long as it stays in the tree, and we won't touch it/attributes/any associated data after it's been removed from the tree. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de>
2019-09-02configfs: new object reprsenting tree fragmentsAl Viro
Refcounted, hangs of configfs_dirent, created by operations that add fragments to configfs tree (mkdir and configfs_register_{subsystem,group}). Will be used in the next commit to provide exclusion between fragment removal and ->show/->store calls. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de>
2019-09-02configfs_register_group() shouldn't be (and isn't) called in rmdirable partsAl Viro
revert cc57c07343bd "configfs: fix registered group removal" It was an attempt to handle something that fundamentally doesn't work - configfs_register_group() should never be done in a part of tree that can be rmdir'ed. And in mainline it never had been, so let's not borrow trouble; the fix was racy anyway, it would take a lot more to make that work and desired semantics is not clear. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de>
2019-09-02configfs: stash the data we need into configfs_buffer at open timeAl Viro
simplifies the ->read()/->write()/->release() instances nicely Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de>
2019-07-19Merge branch 'work.mount0' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs mount updates from Al Viro: "The first part of mount updates. Convert filesystems to use the new mount API" * 'work.mount0' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) mnt_init(): call shmem_init() unconditionally constify ksys_mount() string arguments don't bother with registering rootfs init_rootfs(): don't bother with init_ramfs_fs() vfs: Convert smackfs to use the new mount API vfs: Convert selinuxfs to use the new mount API vfs: Convert securityfs to use the new mount API vfs: Convert apparmorfs to use the new mount API vfs: Convert openpromfs to use the new mount API vfs: Convert xenfs to use the new mount API vfs: Convert gadgetfs to use the new mount API vfs: Convert oprofilefs to use the new mount API vfs: Convert ibmasmfs to use the new mount API vfs: Convert qib_fs/ipathfs to use the new mount API vfs: Convert efivarfs to use the new mount API vfs: Convert configfs to use the new mount API vfs: Convert binfmt_misc to use the new mount API convenience helper: get_tree_single() convenience helper get_tree_nodev() vfs: Kill sget_userns() ...
2019-07-10Merge tag 'fsnotify_for_v5.3-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs Pull fsnotify updates from Jan Kara: "This contains cleanups of the fsnotify name removal hook and also a patch to disable fanotify permission events for 'proc' filesystem" * tag 'fsnotify_for_v5.3-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs: fsnotify: get rid of fsnotify_nameremove() fsnotify: move fsnotify_nameremove() hook out of d_delete() configfs: call fsnotify_rmdir() hook debugfs: call fsnotify_{unlink,rmdir}() hooks debugfs: simplify __debugfs_remove_file() devpts: call fsnotify_unlink() hook tracefs: call fsnotify_{unlink,rmdir}() hooks rpc_pipefs: call fsnotify_{unlink,rmdir}() hooks btrfs: call fsnotify_rmdir() hook fsnotify: add empty fsnotify_{unlink,rmdir}() hooks fanotify: Disallow permission events for proc filesystem
2019-07-04vfs: Convert configfs to use the new mount APIDavid Howells
Convert the configfs filesystem to the new internal mount API as the old one will be obsoleted and removed. This allows greater flexibility in communication of mount parameters between userspace, the VFS and the filesystem. See Documentation/filesystems/mount_api.txt for more information. Signed-off-by: David Howells <dhowells@redhat.com> cc: Joel Becker <jlbec@evilplan.org> cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2019-06-20configfs: call fsnotify_rmdir() hookAmir Goldstein
This will allow generating fsnotify delete events on unregister of group/subsystem after the fsnotify_nameremove() hook is removed from d_delete(). The rest of the d_delete() calls from this filesystem are either called recursively from within debugfs_unregister_{group,subsystem}, called from a vfs function that already has delete hooks or are called from shutdown/cleanup code. Cc: Joel Becker <jlbec@evilplan.org> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Amir Goldstein <amir73il@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz>
2019-05-31Merge tag 'spdx-5.2-rc3-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull yet more SPDX updates from Greg KH: "Here is another set of reviewed patches that adds SPDX tags to different kernel files, based on a set of rules that are being used to parse the comments to try to determine that the license of the file is "GPL-2.0-or-later" or "GPL-2.0-only". Only the "obvious" versions of these matches are included here, a number of "non-obvious" variants of text have been found but those have been postponed for later review and analysis. There is also a patch in here to add the proper SPDX header to a bunch of Kbuild files that we have missed in the past due to new files being added and forgetting that Kbuild uses two different file names for Makefiles. This issue was reported by the Kbuild maintainer. These patches have been out for review on the linux-spdx@vger mailing list, and while they were created by automatic tools, they were hand-verified by a bunch of different people, all whom names are on the patches are reviewers" * tag 'spdx-5.2-rc3-1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (82 commits) treewide: Add SPDX license identifier - Kbuild treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 225 treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 224 treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 223 treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 222 treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 221 treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 220 treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 218 treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 217 treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 216 treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 215 treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 214 treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 213 treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 211 treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 210 treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 209 treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 207 treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 206 treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 203 treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 201 ...
2019-05-30treewide: Replace GPLv2 boilerplate/reference with SPDX - rule 145Thomas Gleixner
Based on 1 normalized pattern(s): this program is free software you can redistribute it and or modify it under the terms of the gnu general public license as published by the free software foundation either version 2 of the license or at your option any later version this program is distributed in the hope that it will be useful but without any warranty without even the implied warranty of merchantability or fitness for a particular purpose see the gnu general public license for more details you should have received a copy of the gnu general public license along with this program if not write to the free software foundation inc 59 temple place suite 330 boston ma 021110 1307 usa extracted by the scancode license scanner the SPDX license identifier GPL-2.0-or-later has been chosen to replace the boilerplate/reference in 84 file(s). Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Richard Fontana <rfontana@redhat.com> Reviewed-by: Allison Randal <allison@lohutok.net> Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Cc: linux-spdx@vger.kernel.org Link: https://lkml.kernel.org/r/20190524100844.756442981@linutronix.de Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-28configfs: Fix use-after-free when accessing sd->s_dentrySahitya Tummala
In the vfs_statx() context, during path lookup, the dentry gets added to sd->s_dentry via configfs_attach_attr(). In the end, vfs_statx() kills the dentry by calling path_put(), which invokes configfs_d_iput(). Ideally, this dentry must be removed from sd->s_dentry but it doesn't if the sd->s_count >= 3. As a result, sd->s_dentry is holding reference to a stale dentry pointer whose memory is already freed up. This results in use-after-free issue, when this stale sd->s_dentry is accessed later in configfs_readdir() path. This issue can be easily reproduced, by running the LTP test case - sh fs_racer_file_list.sh /config (https://github.com/linux-test-project/ltp/blob/master/testcases/kernel/fs/racer/fs_racer_file_list.sh) Fixes: 76ae281f6307 ('configfs: fix race between dentry put and lookup') Signed-off-by: Sahitya Tummala <stummala@codeaurora.org> Signed-off-by: Christoph Hellwig <hch@lst.de>
2019-05-21treewide: Add SPDX license identifier - Makefile/KconfigThomas Gleixner
Add SPDX license identifiers to all Make/Kconfig files which: - Have no license information of any form These files fall under the project license, GPL v2 only. The resulting SPDX license identifier is: GPL-2.0-only Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-05-16Merge tag 'configfs-for-5.2' of git://git.infradead.org/users/hch/configfsLinus Torvalds
Pull configfs update from Christoph Hellwig: - a fix for an error path use after free (YueHaibing) * tag 'configfs-for-5.2' of git://git.infradead.org/users/hch/configfs: configfs: fix possible use-after-free in configfs_register_group
2019-05-08configfs: fix possible use-after-free in configfs_register_groupYueHaibing
In configfs_register_group(), if create_default_group() failed, we forget to unlink the group. It will left a invalid item in the parent list, which may trigger the use-after-free issue seen below: BUG: KASAN: use-after-free in __list_add_valid+0xd4/0xe0 lib/list_debug.c:26 Read of size 8 at addr ffff8881ef61ae20 by task syz-executor.0/5996 CPU: 1 PID: 5996 Comm: syz-executor.0 Tainted: G C 5.0.0+ #5 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1ubuntu1 04/01/2014 Call Trace: __dump_stack lib/dump_stack.c:77 [inline] dump_stack+0xa9/0x10e lib/dump_stack.c:113 print_address_description+0x65/0x270 mm/kasan/report.c:187 kasan_report+0x149/0x18d mm/kasan/report.c:317 __list_add_valid+0xd4/0xe0 lib/list_debug.c:26 __list_add include/linux/list.h:60 [inline] list_add_tail include/linux/list.h:93 [inline] link_obj+0xb0/0x190 fs/configfs/dir.c:759 link_group+0x1c/0x130 fs/configfs/dir.c:784 configfs_register_group+0x56/0x1e0 fs/configfs/dir.c:1751 configfs_register_default_group+0x72/0xc0 fs/configfs/dir.c:1834 ? 0xffffffffc1be0000 iio_sw_trigger_init+0x23/0x1000 [industrialio_sw_trigger] do_one_initcall+0xbc/0x47d init/main.c:887 do_init_module+0x1b5/0x547 kernel/module.c:3456 load_module+0x6405/0x8c10 kernel/module.c:3804 __do_sys_finit_module+0x162/0x190 kernel/module.c:3898 do_syscall_64+0x9f/0x450 arch/x86/entry/common.c:290 entry_SYSCALL_64_after_hwframe+0x49/0xbe RIP: 0033:0x462e99 Code: f7 d8 64 89 02 b8 ff ff ff ff c3 66 0f 1f 44 00 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 c7 c1 bc ff ff ff f7 d8 64 89 01 48 RSP: 002b:00007f494ecbcc58 EFLAGS: 00000246 ORIG_RAX: 0000000000000139 RAX: ffffffffffffffda RBX: 000000000073bf00 RCX: 0000000000462e99 RDX: 0000000000000000 RSI: 0000000020000180 RDI: 0000000000000003 RBP: 00007f494ecbcc70 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000246 R12: 00007f494ecbd6bc R13: 00000000004bcefa R14: 00000000006f6fb0 R15: 0000000000000004 Allocated by task 5987: set_track mm/kasan/common.c:87 [inline] __kasan_kmalloc.constprop.3+0xa0/0xd0 mm/kasan/common.c:497 kmalloc include/linux/slab.h:545 [inline] kzalloc include/linux/slab.h:740 [inline] configfs_register_default_group+0x4c/0xc0 fs/configfs/dir.c:1829 0xffffffffc1bd0023 do_one_initcall+0xbc/0x47d init/main.c:887 do_init_module+0x1b5/0x547 kernel/module.c:3456 load_module+0x6405/0x8c10 kernel/module.c:3804 __do_sys_finit_module+0x162/0x190 kernel/module.c:3898 do_syscall_64+0x9f/0x450 arch/x86/entry/common.c:290 entry_SYSCALL_64_after_hwframe+0x49/0xbe Freed by task 5987: set_track mm/kasan/common.c:87 [inline] __kasan_slab_free+0x130/0x180 mm/kasan/common.c:459 slab_free_hook mm/slub.c:1429 [inline] slab_free_freelist_hook mm/slub.c:1456 [inline] slab_free mm/slub.c:3003 [inline] kfree+0xe1/0x270 mm/slub.c:3955 configfs_register_default_group+0x9a/0xc0 fs/configfs/dir.c:1836 0xffffffffc1bd0023 do_one_initcall+0xbc/0x47d init/main.c:887 do_init_module+0x1b5/0x547 kernel/module.c:3456 load_module+0x6405/0x8c10 kernel/module.c:3804 __do_sys_finit_module+0x162/0x190 kernel/module.c:3898 do_syscall_64+0x9f/0x450 arch/x86/entry/common.c:290 entry_SYSCALL_64_after_hwframe+0x49/0xbe The buggy address belongs to the object at ffff8881ef61ae00 which belongs to the cache kmalloc-192 of size 192 The buggy address is located 32 bytes inside of 192-byte region [ffff8881ef61ae00, ffff8881ef61aec0) The buggy address belongs to the page: page:ffffea0007bd8680 count:1 mapcount:0 mapping:ffff8881f6c03000 index:0xffff8881ef61a700 flags: 0x2fffc0000000200(slab) raw: 02fffc0000000200 ffffea0007ca4740 0000000500000005 ffff8881f6c03000 raw: ffff8881ef61a700 000000008010000c 00000001ffffffff 0000000000000000 page dumped because: kasan: bad access detected Memory state around the buggy address: ffff8881ef61ad00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ffff8881ef61ad80: 00 00 00 00 00 00 00 00 fc fc fc fc fc fc fc fc >ffff8881ef61ae00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb ^ ffff8881ef61ae80: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc ffff8881ef61af00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb Fixes: 5cf6a51e6062 ("configfs: allow dynamic group creation") Reported-by: Hulk Robot <hulkci@huawei.com> Signed-off-by: YueHaibing <yuehaibing@huawei.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2019-04-08fs: mark expected switch fall-throughsGustavo A. R. Silva
In preparation to enabling -Wimplicit-fallthrough, mark switch cases where we are expecting to fall through. This patch fixes the following warnings: fs/affs/affs.h:124:38: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/configfs/dir.c:1692:11: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/configfs/dir.c:1694:7: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ceph/file.c:249:3: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ext4/hash.c:233:15: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ext4/hash.c:246:15: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ext2/inode.c:1237:7: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ext2/inode.c:1244:7: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ext4/indirect.c:1182:6: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ext4/indirect.c:1188:6: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ext4/indirect.c:1432:6: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ext4/indirect.c:1440:6: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/f2fs/node.c:618:8: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/f2fs/node.c:620:8: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/btrfs/ref-verify.c:522:15: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/gfs2/bmap.c:711:7: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/gfs2/bmap.c:722:7: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/jffs2/fs.c:339:6: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/nfsd/nfs4proc.c:429:12: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ufs/util.h:62:6: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/ufs/util.h:43:6: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/fcntl.c:770:7: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/seq_file.c:319:10: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/libfs.c:148:11: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/libfs.c:150:7: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/signalfd.c:178:7: warning: this statement may fall through [-Wimplicit-fallthrough=] fs/locks.c:1473:16: warning: this statement may fall through [-Wimplicit-fallthrough=] Warning level 3 was used: -Wimplicit-fallthrough=3 This patch is part of the ongoing efforts to enabling -Wimplicit-fallthrough. Reviewed-by: Kees Cook <keescook@chromium.org> Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
2018-07-17configfs: fix registered group removalMike Christie
This patch fixes a bug where configfs_register_group had added a group in a tree, and userspace has done a rmdir on a dir somewhere above that group and we hit a kernel crash. The problem is configfs_rmdir will detach everything under it and unlink groups on the default_groups list. It will not unlink groups added with configfs_register_group so when configfs_unregister_group is called to drop its references to the group/items we crash when we try to access the freed dentrys. The patch just adds a check for if a rmdir has been done above us and if so just does the unlink part of unregistration. Sorry if you are getting this multiple times. I thouhgt I sent this to some of you and lkml, but I do not see it. Signed-off-by: Mike Christie <mchristi@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Christoph Hellwig <hch@lst.de>
2018-07-02configfs: replace strncpy with memcpyGuenter Roeck
gcc 8.1.0 complains: fs/configfs/symlink.c:67:3: warning: 'strncpy' output truncated before terminating nul copying as many bytes from a string as its length fs/configfs/symlink.c: In function 'configfs_get_link': fs/configfs/symlink.c:63:13: note: length computed here Using strncpy() is indeed less than perfect since the length of data to be copied has already been determined with strlen(). Replace strncpy() with memcpy() to address the warning and optimize the code a little. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Christoph Hellwig <hch@lst.de>
2018-06-19configfs: use kvasprintf() instead of open-coding itBart Van Assche
Signed-off-by: Bart Van Assche <bart.vanassche@wdc.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2018-06-05vfs: change inode times to use struct timespec64Deepa Dinamani
struct timespec is not y2038 safe. Transition vfs to use y2038 safe struct timespec64 instead. The change was made with the help of the following cocinelle script. This catches about 80% of the changes. All the header file and logic changes are included in the first 5 rules. The rest are trivial substitutions. I avoid changing any of the function signatures or any other filesystem specific data structures to keep the patch simple for review. The script can be a little shorter by combining different cases. But, this version was sufficient for my usecase. virtual patch @ depends on patch @ identifier now; @@ - struct timespec + struct timespec64 current_time ( ... ) { - struct timespec now = current_kernel_time(); + struct timespec64 now = current_kernel_time64(); ... - return timespec_trunc( + return timespec64_trunc( ... ); } @ depends on patch @ identifier xtime; @@ struct \( iattr \| inode \| kstat \) { ... - struct timespec xtime; + struct timespec64 xtime; ... } @ depends on patch @ identifier t; @@ struct inode_operations { ... int (*update_time) (..., - struct timespec t, + struct timespec64 t, ...); ... } @ depends on patch @ identifier t; identifier fn_update_time =~ "update_time$"; @@ fn_update_time (..., - struct timespec *t, + struct timespec64 *t, ...) { ... } @ depends on patch @ identifier t; @@ lease_get_mtime( ... , - struct timespec *t + struct timespec64 *t ) { ... } @te depends on patch forall@ identifier ts; local idexpression struct inode *inode_node; identifier i_xtime =~ "^i_[acm]time$"; identifier ia_xtime =~ "^ia_[acm]time$"; identifier fn_update_time =~ "update_time$"; identifier fn; expression e, E3; local idexpression struct inode *node1; local idexpression struct inode *node2; local idexpression struct iattr *attr1; local idexpression struct iattr *attr2; local idexpression struct iattr attr; identifier i_xtime1 =~ "^i_[acm]time$"; identifier i_xtime2 =~ "^i_[acm]time$"; identifier ia_xtime1 =~ "^ia_[acm]time$"; identifier ia_xtime2 =~ "^ia_[acm]time$"; @@ ( ( - struct timespec ts; + struct timespec64 ts; | - struct timespec ts = current_time(inode_node); + struct timespec64 ts = current_time(inode_node); ) <+... when != ts ( - timespec_equal(&inode_node->i_xtime, &ts) + timespec64_equal(&inode_node->i_xtime, &ts) | - timespec_equal(&ts, &inode_node->i_xtime) + timespec64_equal(&ts, &inode_node->i_xtime) | - timespec_compare(&inode_node->i_xtime, &ts) + timespec64_compare(&inode_node->i_xtime, &ts) | - timespec_compare(&ts, &inode_node->i_xtime) + timespec64_compare(&ts, &inode_node->i_xtime) | ts = current_time(e) | fn_update_time(..., &ts,...) | inode_node->i_xtime = ts | node1->i_xtime = ts | ts = inode_node->i_xtime | <+... attr1->ia_xtime ...+> = ts | ts = attr1->ia_xtime | ts.tv_sec | ts.tv_nsec | btrfs_set_stack_timespec_sec(..., ts.tv_sec) | btrfs_set_stack_timespec_nsec(..., ts.tv_nsec) | - ts = timespec64_to_timespec( + ts = ... -) | - ts = ktime_to_timespec( + ts = ktime_to_timespec64( ...) | - ts = E3 + ts = timespec_to_timespec64(E3) | - ktime_get_real_ts(&ts) + ktime_get_real_ts64(&ts) | fn(..., - ts + timespec64_to_timespec(ts) ,...) ) ...+> ( <... when != ts - return ts; + return timespec64_to_timespec(ts); ...> ) | - timespec_equal(&node1->i_xtime1, &node2->i_xtime2) + timespec64_equal(&node1->i_xtime2, &node2->i_xtime2) | - timespec_equal(&node1->i_xtime1, &attr2->ia_xtime2) + timespec64_equal(&node1->i_xtime2, &attr2->ia_xtime2) | - timespec_compare(&node1->i_xtime1, &node2->i_xtime2) + timespec64_compare(&node1->i_xtime1, &node2->i_xtime2) | node1->i_xtime1 = - timespec_trunc(attr1->ia_xtime1, + timespec64_trunc(attr1->ia_xtime1, ...) | - attr1->ia_xtime1 = timespec_trunc(attr2->ia_xtime2, + attr1->ia_xtime1 = timespec64_trunc(attr2->ia_xtime2, ...) | - ktime_get_real_ts(&attr1->ia_xtime1) + ktime_get_real_ts64(&attr1->ia_xtime1) | - ktime_get_real_ts(&attr.ia_xtime1) + ktime_get_real_ts64(&attr.ia_xtime1) ) @ depends on patch @ struct inode *node; struct iattr *attr; identifier fn; identifier i_xtime =~ "^i_[acm]time$"; identifier ia_xtime =~ "^ia_[acm]time$"; expression e; @@ ( - fn(node->i_xtime); + fn(timespec64_to_timespec(node->i_xtime)); | fn(..., - node->i_xtime); + timespec64_to_timespec(node->i_xtime)); | - e = fn(attr->ia_xtime); + e = fn(timespec64_to_timespec(attr->ia_xtime)); ) @ depends on patch forall @ struct inode *node; struct iattr *attr; identifier i_xtime =~ "^i_[acm]time$"; identifier ia_xtime =~ "^ia_[acm]time$"; identifier fn; @@ { + struct timespec ts; <+... ( + ts = timespec64_to_timespec(node->i_xtime); fn (..., - &node->i_xtime, + &ts, ...); | + ts = timespec64_to_timespec(attr->ia_xtime); fn (..., - &attr->ia_xtime, + &ts, ...); ) ...+> } @ depends on patch forall @ struct inode *node; struct iattr *attr; struct kstat *stat; identifier ia_xtime =~ "^ia_[acm]time$"; identifier i_xtime =~ "^i_[acm]time$"; identifier xtime =~ "^[acm]time$"; identifier fn, ret; @@ { + struct timespec ts; <+... ( + ts = timespec64_to_timespec(node->i_xtime); ret = fn (..., - &node->i_xtime, + &ts, ...); | + ts = timespec64_to_timespec(node->i_xtime); ret = fn (..., - &node->i_xtime); + &ts); | + ts = timespec64_to_timespec(attr->ia_xtime); ret = fn (..., - &attr->ia_xtime, + &ts, ...); | + ts = timespec64_to_timespec(attr->ia_xtime); ret = fn (..., - &attr->ia_xtime); + &ts); | + ts = timespec64_to_timespec(stat->xtime); ret = fn (..., - &stat->xtime); + &ts); ) ...+> } @ depends on patch @ struct inode *node; struct inode *node2; identifier i_xtime1 =~ "^i_[acm]time$"; identifier i_xtime2 =~ "^i_[acm]time$"; identifier i_xtime3 =~ "^i_[acm]time$"; struct iattr *attrp; struct iattr *attrp2; struct iattr attr ; identifier ia_xtime1 =~ "^ia_[acm]time$"; identifier ia_xtime2 =~ "^ia_[acm]time$"; struct kstat *stat; struct kstat stat1; struct timespec64 ts; identifier xtime =~ "^[acmb]time$"; expression e; @@ ( ( node->i_xtime2 \| attrp->ia_xtime2 \| attr.ia_xtime2 \) = node->i_xtime1 ; | node->i_xtime2 = \( node2->i_xtime1 \| timespec64_trunc(...) \); | node->i_xtime2 = node->i_xtime1 = node->i_xtime3 = \(ts \| current_time(...) \); | node->i_xtime1 = node->i_xtime3 = \(ts \| current_time(...) \); | stat->xtime = node2->i_xtime1; | stat1.xtime = node2->i_xtime1; | ( node->i_xtime2 \| attrp->ia_xtime2 \) = attrp->ia_xtime1 ; | ( attrp->ia_xtime1 \| attr.ia_xtime1 \) = attrp2->ia_xtime2; | - e = node->i_xtime1; + e = timespec64_to_timespec( node->i_xtime1 ); | - e = attrp->ia_xtime1; + e = timespec64_to_timespec( attrp->ia_xtime1 ); | node->i_xtime1 = current_time(...); | node->i_xtime2 = node->i_xtime1 = node->i_xtime3 = - e; + timespec_to_timespec64(e); | node->i_xtime1 = node->i_xtime3 = - e; + timespec_to_timespec64(e); | - node->i_xtime1 = e; + node->i_xtime1 = timespec_to_timespec64(e); ) Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Cc: <anton@tuxera.com> Cc: <balbi@kernel.org> Cc: <bfields@fieldses.org> Cc: <darrick.wong@oracle.com> Cc: <dhowells@redhat.com> Cc: <dsterba@suse.com> Cc: <dwmw2@infradead.org> Cc: <hch@lst.de> Cc: <hirofumi@mail.parknet.co.jp> Cc: <hubcap@omnibond.com> Cc: <jack@suse.com> Cc: <jaegeuk@kernel.org> Cc: <jaharkes@cs.cmu.edu> Cc: <jslaby@suse.com> Cc: <keescook@chromium.org> Cc: <mark@fasheh.com> Cc: <miklos@szeredi.hu> Cc: <nico@linaro.org> Cc: <reiserfs-devel@vger.kernel.org> Cc: <richard@nod.at> Cc: <sage@redhat.com> Cc: <sfrench@samba.org> Cc: <swhiteho@redhat.com> Cc: <tj@kernel.org> Cc: <trond.myklebust@primarydata.com> Cc: <tytso@mit.edu> Cc: <viro@zeniv.linux.org.uk>
2017-10-19configfs: make ci_type field, some pointers and function arguments constBhumika Goyal
The ci_type field of the config_item structure do not modify the fields of the config_item_type structure it points to. And the other pointers initialized with ci_type do not modify the fields as well. So, make the ci_type field and the pointers initialized with ci_type as const. Make the struct config_item_type *type function argument of functions config_{item/group}_init_type_name const as the argument in both the functions is only stored in the ci_type field of a config_item structure which is now made const. Make the argument of configfs_register_default_group const as it is only passed to the argument of the function config_group_init_type_name which is now const. Signed-off-by: Bhumika Goyal <bhumirks@gmail.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Christoph Hellwig <hch@lst.de>
2017-10-19configfs: Fix bool initialization/comparisonThomas Meyer
Bool initializations should use true and false. Bool tests don't need comparisons. Signed-off-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Christoph Hellwig <hch@lst.de>
2017-06-12configfs: Introduce config_item_get_unless_zero()Bart Van Assche
Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> [hch: minor style tweak] Signed-off-by: Christoph Hellwig <hch@lst.de>
2017-06-12configfs: Fix race between create_link and configfs_rmdirNicholas Bellinger
This patch closes a long standing race in configfs between the creation of a new symlink in create_link(), while the symlink target's config_item is being concurrently removed via configfs_rmdir(). This can happen because the symlink target's reference is obtained by config_item_get() in create_link() before the CONFIGFS_USET_DROPPING bit set by configfs_detach_prep() during configfs_rmdir() shutdown is actually checked.. This originally manifested itself on ppc64 on v4.8.y under heavy load using ibmvscsi target ports with Novalink API: [ 7877.289863] rpadlpar_io: slot U8247.22L.212A91A-V1-C8 added [ 7879.893760] ------------[ cut here ]------------ [ 7879.893768] WARNING: CPU: 15 PID: 17585 at ./include/linux/kref.h:46 config_item_get+0x7c/0x90 [configfs] [ 7879.893811] CPU: 15 PID: 17585 Comm: targetcli Tainted: G O 4.8.17-customv2.22 #12 [ 7879.893812] task: c00000018a0d3400 task.stack: c0000001f3b40000 [ 7879.893813] NIP: d000000002c664ec LR: d000000002c60980 CTR: c000000000b70870 [ 7879.893814] REGS: c0000001f3b43810 TRAP: 0700 Tainted: G O (4.8.17-customv2.22) [ 7879.893815] MSR: 8000000000029033 <SF,EE,ME,IR,DR,RI,LE> CR: 28222242 XER: 00000000 [ 7879.893820] CFAR: d000000002c664bc SOFTE: 1 GPR00: d000000002c60980 c0000001f3b43a90 d000000002c70908 c0000000fbc06820 GPR04: c0000001ef1bd900 0000000000000004 0000000000000001 0000000000000000 GPR08: 0000000000000000 0000000000000001 d000000002c69560 d000000002c66d80 GPR12: c000000000b70870 c00000000e798700 c0000001f3b43ca0 c0000001d4949d40 GPR16: c00000014637e1c0 0000000000000000 0000000000000000 c0000000f2392940 GPR20: c0000001f3b43b98 0000000000000041 0000000000600000 0000000000000000 GPR24: fffffffffffff000 0000000000000000 d000000002c60be0 c0000001f1dac490 GPR28: 0000000000000004 0000000000000000 c0000001ef1bd900 c0000000f2392940 [ 7879.893839] NIP [d000000002c664ec] config_item_get+0x7c/0x90 [configfs] [ 7879.893841] LR [d000000002c60980] check_perm+0x80/0x2e0 [configfs] [ 7879.893842] Call Trace: [ 7879.893844] [c0000001f3b43ac0] [d000000002c60980] check_perm+0x80/0x2e0 [configfs] [ 7879.893847] [c0000001f3b43b10] [c000000000329770] do_dentry_open+0x2c0/0x460 [ 7879.893849] [c0000001f3b43b70] [c000000000344480] path_openat+0x210/0x1490 [ 7879.893851] [c0000001f3b43c80] [c00000000034708c] do_filp_open+0xfc/0x170 [ 7879.893853] [c0000001f3b43db0] [c00000000032b5bc] do_sys_open+0x1cc/0x390 [ 7879.893856] [c0000001f3b43e30] [c000000000009584] system_call+0x38/0xec [ 7879.893856] Instruction dump: [ 7879.893858] 409d0014 38210030 e8010010 7c0803a6 4e800020 3d220000 e94981e0 892a0000 [ 7879.893861] 2f890000 409effe0 39200001 992a0000 <0fe00000> 4bffffd0 60000000 60000000 [ 7879.893866] ---[ end trace 14078f0b3b5ad0aa ]--- To close this race, go ahead and obtain the symlink's target config_item reference only after the existing CONFIGFS_USET_DROPPING check succeeds. This way, if configfs_rmdir() wins create_link() will return -ENONET, and if create_link() wins configfs_rmdir() will return -EBUSY. Reported-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com> Tested-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: stable@vger.kernel.org
2016-12-24Replace <asm/uaccess.h> with <linux/uaccess.h> globallyLinus Torvalds
This was entirely automated, using the script by Al: PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>' sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \ $(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h) to do the replacement at the end of the merge window. Requested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-09vfs: remove ".readlink = generic_readlink" assignmentsMiklos Szeredi
If .readlink == NULL implies generic_readlink(). Generated by: to_del="\.readlink.*=.*generic_readlink" for i in `git grep -l $to_del`; do sed -i "/$to_del"/d $i; done Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2016-10-10Merge remote-tracking branch 'ovl/rename2' into for-linusAl Viro
2016-09-27fs: Replace current_fs_time() with current_time()Deepa Dinamani
current_fs_time() uses struct super_block* as an argument. As per Linus's suggestion, this is changed to take struct inode* as a parameter instead. This is because the function is primarily meant for vfs inode timestamps. Also the function was renamed as per Arnd's suggestion. Change all calls to current_fs_time() to use the new current_time() function instead. current_fs_time() will be deleted. Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-16configfs: Return -EFBIG from configfs_write_bin_file.Phil Turnbull
The check for writing more than cb_max_size bytes does not 'goto out' so it is a no-op which allows users to vmalloc an arbitrary amount. Fixes: 03607ace807b ("configfs: implement binary attributes") Cc: stable@kernel.org Signed-off-by: Phil Turnbull <phil.turnbull@oracle.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2016-07-10configfs: don't set buffer_needs_fill to zero if show() returns errorTal Shorer
A confgifs attribute's show() callback is called once the first time the user attempts to read from it. If it returns an error, that error is returned to the user. However, the open file's buffer_needs_fill is still set to zero and consecutive read() calls will find an empty buffer that doesn't need filling and return 0 to the user. This could give the user the wrong impression that the attribute was read successfully. Fix this by not setting buffer_needs_fill if show() returns an error, making consecutive read() calls call show() again and either get an error again or get data. Signed-off-by: Tal Shorer <tal.shorer@gmail.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2016-06-30configfs: Remove ppos increment in configfs_write_bin_fileMarek Vasut
The simple_write_to_buffer() already increments the @ppos on success, see fs/libfs.c simple_write_to_buffer() comment: " On success, the number of bytes written is returned and the offset @ppos advanced by this number, or negative value is returned on error. " If the configfs_write_bin_file() is invoked with @count smaller than the total length of the written binary file, it will be invoked multiple times. Since configfs_write_bin_file() increments @ppos on success, after calling simple_write_to_buffer(), the @ppos is incremented twice. Subsequent invocation of configfs_write_bin_file() will result in the next piece of data being written to the offset twice as long as the length of the previous write, thus creating buffer with "holes" in it. The simple testcase using DTO follows: $ mkdir /sys/kernel/config/device-tree/overlays/1 $ dd bs=1 if=foo.dtbo of=/sys/kernel/config/device-tree/overlays/1/dtbo Without this patch, the testcase will result in twice as big buffer in the kernel, which is then passed to the cfs_overlay_item_dtbo_write() . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Geert Uytterhoeven <geert+renesas@glider.be> Cc: Christoph Hellwig <hch@lst.de> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
2016-05-09configfs_readdir(): make safe under shared lockAl Viro
2016-05-02parallel lookups: actual switch to rwsemAl Viro
ta-da! The main issue is the lack of down_write_killable(), so the places like readdir.c switched to plain inode_lock(); once killable variants of rwsem primitives appear, that'll be dealt with. lockdep side also might need more work Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-02configfs_detach_prep(): make sure that wait_mutex won't go awayAl Viro
grab a reference to dentry we'd got the sucker from, and return that dentry via *wait, rather than just returning the address of ->i_mutex. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-04-04mm, fs: get rid of PAGE_CACHE_* and page_cache_{get,release} macrosKirill A. Shutemov
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time ago with promise that one day it will be possible to implement page cache with bigger chunks than PAGE_SIZE. This promise never materialized. And unlikely will. We have many places where PAGE_CACHE_SIZE assumed to be equal to PAGE_SIZE. And it's constant source of confusion on whether PAGE_CACHE_* or PAGE_* constant should be used in a particular case, especially on the border between fs and mm. Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much breakage to be doable. Let's stop pretending that pages in page cache are special. They are not. The changes are pretty straight-forward: - <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN}; - page_cache_get() -> get_page(); - page_cache_release() -> put_page(); This patch contains automated changes generated with coccinelle using script below. For some reason, coccinelle doesn't patch header files. I've called spatch for them manually. The only adjustment after coccinelle is revert of changes to PAGE_CAHCE_ALIGN definition: we are going to drop it later. There are few places in the code where coccinelle didn't reach. I'll fix them manually in a separate patch. Comments and documentation also will be addressed with the separate patch. virtual patch @@ expression E; @@ - E << (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ expression E; @@ - E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ @@ - PAGE_CACHE_SHIFT + PAGE_SHIFT @@ @@ - PAGE_CACHE_SIZE + PAGE_SIZE @@ @@ - PAGE_CACHE_MASK + PAGE_MASK @@ expression E; @@ - PAGE_CACHE_ALIGN(E) + PAGE_ALIGN(E) @@ expression E; @@ - page_cache_get(E) + get_page(E) @@ expression E; @@ - page_cache_release(E) + put_page(E) Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: - Preparations of parallel lookups (the remaining main obstacle is the need to move security_d_instantiate(); once that becomes safe, the rest will be a matter of rather short series local to fs/*.c - preadv2/pwritev2 series from Christoph - assorted fixes * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (32 commits) splice: handle zero nr_pages in splice_to_pipe() vfs: show_vfsstat: do not ignore errors from show_devname method dcache.c: new helper: __d_add() don't bother with __d_instantiate(dentry, NULL) untangle fsnotify_d_instantiate() a bit uninline d_add() replace d_add_unique() with saner primitive quota: use lookup_one_len_unlocked() cifs_get_root(): use lookup_one_len_unlocked() nfs_lookup: don't bother with d_instantiate(dentry, NULL) kill dentry_unhash() ceph_fill_trace(): don't bother with d_instantiate(dn, NULL) autofs4: don't bother with d_instantiate(dentry, NULL) in ->lookup() configfs: move d_rehash() into configfs_create() for regular files ceph: don't bother with d_rehash() in splice_dentry() namei: teach lookup_slow() to skip revalidate namei: massage lookup_slow() to be usable by lookup_one_len_unlocked() lookup_one_len_unlocked(): use lookup_dcache() namei: simplify invalidation logics in lookup_dcache() namei: change calling conventions for lookup_{fast,slow} and follow_managed() ...
2016-03-14configfs: move d_rehash() into configfs_create() for regular filesAl Viro
... and turn it into d_add in there Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-03-06configfs: switch ->default groups to a linked listChristoph Hellwig
Replace the current NULL-terminated array of default groups with a linked list. This gets rid of lots of nasty code to size and/or dynamically allocate the array. While we're at it also provide a conveniant helper to remove the default groups. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Felipe Balbi <balbi@kernel.org> [drivers/usb/gadget] Acked-by: Joel Becker <jlbec@evilplan.org> Acked-by: Nicholas Bellinger <nab@linux-iscsi.org> Reviewed-by: Sagi Grimberg <sagig@mellanox.com>
2016-02-26configfs: Replace CURRENT_TIME by current_fs_time()Deepa Dinamani
CURRENT_TIME macro is not appropriate for filesystems as it doesn't use the right granularity for filesystem timestamps. Use current_fs_time() instead. Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Acked-by: Joel Becker <jlbec@evilplan.org> Signed-off-by: Christoph Hellwig <hch@lst.de>
2016-01-22wrappers for ->i_mutex accessAl Viro
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested}, inode_foo(inode) being mutex_foo(&inode->i_mutex). Please, use those for access to ->i_mutex; over the coming cycle ->i_mutex will become rwsem, with ->lookup() done with it held only shared. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-20Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "The highlights this round include: - Introduce configfs support for unlocked configfs_depend_item() (krzysztof + andrezej) - Conversion of usb-gadget target driver to new function registration interface (andrzej + sebastian) - Enable qla2xxx FC target mode support for Extended Logins (himansu + giridhar) - Enable qla2xxx FC target mode support for Exchange Offload (himansu + giridhar) - Add qla2xxx FC target mode irq affinity notification + selective command queuing. (quinn + himanshu) - Fix iscsi-target deadlock in se_node_acl configfs deletion (sagi + nab) - Convert se_node_acl configfs deletion + se_node_acl->queue_depth to proper se_session->sess_kref + target_get_session() usage. (hch + sagi + nab) - Fix long-standing race between se_node_acl->acl_kref get and get_initiator_node_acl() lookup. (hch + nab) - Fix target/user block-size handling, and make sure netlink reaches all network namespaces (sheng + andy) Note there is an outstanding bug-fix series for remote I_T nexus port TMR LUN_RESET has been posted and still being tested, and will likely become post -rc1 material at this point" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (56 commits) scsi: qla2xxxx: avoid type mismatch in comparison target/user: Make sure netlink would reach all network namespaces target: Obtain se_node_acl->acl_kref during get_initiator_node_acl target: Convert ACL change queue_depth se_session reference usage iscsi-target: Fix potential dead-lock during node acl delete ib_srpt: Convert acl lookup to modern get_initiator_node_acl usage tcm_fc: Convert acl lookup to modern get_initiator_node_acl usage tcm_fc: Wait for command completion before freeing a session target: Fix a memory leak in target_dev_lba_map_store() target: Support aborting tasks with a 64-bit tag usb/gadget: Remove set-but-not-used variables target: Remove an unused variable target: Fix indentation in target_core_configfs.c target/user: Allow user to set block size before enabling device iser-target: Fix non negative ERR_PTR isert_device_get usage target/fcoe: Add tag support to tcm_fc qla2xxx: Check for online flag instead of active reset when transmitting responses qla2xxx: Set all queues to 4k qla2xxx: Disable ZIO at start time. qla2xxx: Move atioq to a different lock to reduce lock contention ...
2016-01-12Merge tag 'configfs-for-linus' of git://git.infradead.org/users/hch/configfsLinus Torvalds
Pull configfs updates from Christoph Hellwig: "I'm assisting Joel as co-maintainer and patch monkey now, and you will see pull reuquests from me for a while. Besides the MAINTAINERS update there is just a single change, which adds support for binary attributes to configfs, which are very similar to the sysfs binary attributes. Thanks to Pantelis Antoniou! You will see another actually bigger set of configfs changes in the SCSI target pull from Nic - those were merged before this new tree even existed" * tag 'configfs-for-linus' of git://git.infradead.org/users/hch/configfs: configfs: add myself as co-maintainer, updated git tree configfs: implement binary attributes
2016-01-04configfs: implement binary attributesPantelis Antoniou
ConfigFS lacked binary attributes up until now. This patch introduces support for binary attributes in a somewhat similar manner of sysfs binary attributes albeit with changes that fit the configfs usage model. Problems that configfs binary attributes fix are everything that requires a binary blob as part of the configuration of a resource, such as bitstream loading for FPGAs, DTBs for dynamically created devices etc. Look at Documentation/filesystems/configfs/configfs.txt for internals and howto use them. This patch is against linux-next as of today that contains Christoph's configfs rework. Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> [hch: folded a fix from Geert Uytterhoeven <geert+renesas@glider.be>] [hch: a few tiny updates based on review feedback] Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-12-30switch ->get_link() to delayed_call, kill ->put_link()Al Viro
2015-12-29kill free_page_put_link()Al Viro
all callers are better off with kfree_put_link() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-20fs: configfs: Add unlocked version of configfs_depend_item()Krzysztof Opasiak
This change is necessary for the SCSI target usb gadget composed with configfs. In this case configfs will be used for two different purposes: to compose a usb gadget and to configure the target part. If an instance of tcm function is created in $CONFIGFS_ROOT/usb_gadget/<gadget>/functions a tpg can be created in $CONFIGFS_ROOT/target/usb_gadget/<wwn>/, but after a tpg is created the tcm function must not be removed until its corresponding tpg is gone. While the configfs_depend/undepend_item() are meant exactly for creating this kind of dependencies, they are not suitable if the other kernel subsystem happens to be another subsystem in configfs, so this patch adds unlocked versions meant for configfs callbacks. Above description has been provided by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> In configfs_depend_item() we have to consider two possible cases: 1) When we are called to depend another item in the same subsystem as caller In this case we should skip locking configfs root as we know that configfs is in valid state and our subsystem will not be unregistered during this call. 2) When we are called to depend item in different subsystem than our caller In this case we are also sure that configfs is in valid state but we have to lock root of configfs to avoid unregistration of target's subsystem. As it is other than caller's subsystem, there may be nothing what protects us against unregistration of that subsystem. Signed-off-by: Krzysztof Opasiak <k.opasiak@samsung.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2015-12-20fs: configfs: Factor out configfs_find_subsys_dentry()Krzysztof Opasiak
configfs_depend_item() is quite complicated and should be split up into smaller functions. This also allow to share this code with other functions. Signed-off-by: Krzysztof Opasiak <k.opasiak@samsung.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2015-12-20fs: configfs: Factor out configfs_do_depend_item()Krzysztof Opasiak
2015-12-20fs: configfs: Drop unused parameter from configfs_undepend_item()Krzysztof Opasiak
subsys parameter is never used by configfs_undepend_item() so there is no point in passing it to this function. Signed-off-by: Krzysztof Opasiak <k.opasiak@samsung.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2015-12-08replace ->follow_link() with new method that could stay in RCU modeAl Viro
new method: ->get_link(); replacement of ->follow_link(). The differences are: * inode and dentry are passed separately * might be called both in RCU and non-RCU mode; the former is indicated by passing it a NULL dentry. * when called that way it isn't allowed to block and should return ERR_PTR(-ECHILD) if it needs to be called in non-RCU mode. It's a flagday change - the old method is gone, all in-tree instances converted. Conversion isn't hard; said that, so far very few instances do not immediately bail out when called in RCU mode. That'll change in the next commits. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-11-20configfs: allow dynamic group creationDaniel Baluta
This patchset introduces IIO software triggers, offers a way of configuring them via configfs and adds the IIO hrtimer based interrupt source to be used with software triggers. The architecture is now split in 3 parts, to remove all IIO trigger specific parts from IIO configfs core: (1) IIO configfs - creates the root of the IIO configfs subsys. (2) IIO software triggers - software trigger implementation, dynamically creating /config/iio/triggers group. (3) IIO hrtimer trigger - is the first interrupt source for software triggers (with syfs to follow). Each trigger type can implement its own set of attributes. Lockdep seems to be happy with the locking in configfs patch. This patch (of 5): We don't want to hardcode default groups at subsystem creation time. We export: * configfs_register_group * configfs_unregister_group to allow drivers to programatically create/destroy groups later, after module init time. This is needed for IIO configfs support. (akpm: the other 4 patches to be merged via the IIO tree) Signed-off-by: Daniel Baluta <daniel.baluta@intel.com> Suggested-by: Lars-Peter Clausen <lars@metafoo.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Acked-by: Joel Becker <jlbec@evilplan.org> Cc: Hartmut Knaack <knaack.h@gmx.de> Cc: Octavian Purdila <octavian.purdila@intel.com> Cc: Paul Bolle <pebolle@tiscali.nl> Cc: Adriana Reus <adriana.reus@intel.com> Cc: Cristina Opriceana <cristina.opriceana@gmail.com> Cc: Peter Meerwald <pmeerw@pmeerw.net> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
