path: root/fs/configfs
2019-11-12configfs: fix a deadlock in configfs_symlink()Al Viro
commit 351e5d869e5ac10cb40c78b5f2d7dfc816ad4587 upstream. Configfs abuses symlink(2). Unlike the normal filesystems, it wants the target resolved at symlink(2) time, like link(2) would've done. The problem is that ->symlink() is called with the parent directory locked exclusive, so resolving the target inside the ->symlink() is easily deadlocked. Short of really ugly games in sys_symlink() itself, all we can do is to unlock the parent before resolving the target and relock it after. However, that invalidates the checks done by the caller of ->symlink(), so we have to * check that dentry is still where it used to be (it couldn't have been moved, but it could've been unhashed) * recheck that it's still negative (somebody else might've successfully created a symlink with the same name while we were looking the target up) * recheck the permissions on the parent directory. Cc: stable@vger.kernel.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-12configfs: provide exclusion between IO and removalsAl Viro
commit b0841eefd9693827afb9888235e26ddd098f9cef upstream. Make sure that attribute methods are not called after the item has been removed from the tree. To do so, we * at the point of no return in removals, grab ->frag_sem exclusive and mark the fragment dead. * call the methods of attributes with ->frag_sem taken shared and only after having verified that the fragment is still alive. The main benefit is for method instances - they are guaranteed that the objects they are accessing *and* all ancestors are still there. Another win is that we don't need to bother with extra refcount on config_item when opening a file - the item will be alive for as long as it stays in the tree, and we won't touch it/attributes/any associated data after it's been removed from the tree. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-12configfs: new object reprsenting tree fragmentsAl Viro
commit 47320fbe11a6059ae502c9c16b668022fdb4cf76 upstream. Refcounted, hangs of configfs_dirent, created by operations that add fragments to configfs tree (mkdir and configfs_register_{subsystem,group}). Will be used in the next commit to provide exclusion between fragment removal and ->show/->store calls. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-12configfs_register_group() shouldn't be (and isn't) called in rmdirable partsAl Viro
commit f19e4ed1e1edbfa3c9ccb9fed17759b7d6db24c6 upstream. revert cc57c07343bd "configfs: fix registered group removal" It was an attempt to handle something that fundamentally doesn't work - configfs_register_group() should never be done in a part of tree that can be rmdir'ed. And in mainline it never had been, so let's not borrow trouble; the fix was racy anyway, it would take a lot more to make that work and desired semantics is not clear. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-12configfs: stash the data we need into configfs_buffer at open timeAl Viro
commit ff4dd081977da56566a848f071aed8fa92d604a1 upstream. simplifies the ->read()/->write()/->release() instances nicely Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-11-12configfs: Fix bool initialization/comparisonThomas Meyer
commit 3f6928c347707a65cee10a9f54b85ad5fb078b3f upstream. Bool initializations should use true and false. Bool tests don't need comparisons. Signed-off-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-06-22configfs: Fix use-after-free when accessing sd->s_dentrySahitya Tummala
[ Upstream commit f6122ed2a4f9c9c1c073ddf6308d1b2ac10e0781 ] In the vfs_statx() context, during path lookup, the dentry gets added to sd->s_dentry via configfs_attach_attr(). In the end, vfs_statx() kills the dentry by calling path_put(), which invokes configfs_d_iput(). Ideally, this dentry must be removed from sd->s_dentry but it doesn't if the sd->s_count >= 3. As a result, sd->s_dentry is holding reference to a stale dentry pointer whose memory is already freed up. This results in use-after-free issue, when this stale sd->s_dentry is accessed later in configfs_readdir() path. This issue can be easily reproduced, by running the LTP test case - sh fs_racer_file_list.sh /config (https://github.com/linux-test-project/ltp/blob/master/testcases/kernel/fs/racer/fs_racer_file_list.sh) Fixes: 76ae281f6307 ('configfs: fix race between dentry put and lookup') Signed-off-by: Sahitya Tummala <stummala@codeaurora.org> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-22configfs: fix possible use-after-free in configfs_register_groupYueHaibing
[ Upstream commit 35399f87e271f7cf3048eab00a421a6519ac8441 ] In configfs_register_group(), if create_default_group() failed, we forget to unlink the group. It will left a invalid item in the parent list, which may trigger the use-after-free issue seen below: BUG: KASAN: use-after-free in __list_add_valid+0xd4/0xe0 lib/list_debug.c:26 Read of size 8 at addr ffff8881ef61ae20 by task syz-executor.0/5996 CPU: 1 PID: 5996 Comm: syz-executor.0 Tainted: G C 5.0.0+ #5 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS 1.10.2-1ubuntu1 04/01/2014 Call Trace: __dump_stack lib/dump_stack.c:77 [inline] dump_stack+0xa9/0x10e lib/dump_stack.c:113 print_address_description+0x65/0x270 mm/kasan/report.c:187 kasan_report+0x149/0x18d mm/kasan/report.c:317 __list_add_valid+0xd4/0xe0 lib/list_debug.c:26 __list_add include/linux/list.h:60 [inline] list_add_tail include/linux/list.h:93 [inline] link_obj+0xb0/0x190 fs/configfs/dir.c:759 link_group+0x1c/0x130 fs/configfs/dir.c:784 configfs_register_group+0x56/0x1e0 fs/configfs/dir.c:1751 configfs_register_default_group+0x72/0xc0 fs/configfs/dir.c:1834 ? 0xffffffffc1be0000 iio_sw_trigger_init+0x23/0x1000 [industrialio_sw_trigger] do_one_initcall+0xbc/0x47d init/main.c:887 do_init_module+0x1b5/0x547 kernel/module.c:3456 load_module+0x6405/0x8c10 kernel/module.c:3804 __do_sys_finit_module+0x162/0x190 kernel/module.c:3898 do_syscall_64+0x9f/0x450 arch/x86/entry/common.c:290 entry_SYSCALL_64_after_hwframe+0x49/0xbe RIP: 0033:0x462e99 Code: f7 d8 64 89 02 b8 ff ff ff ff c3 66 0f 1f 44 00 00 48 89 f8 48 89 f7 48 89 d6 48 89 ca 4d 89 c2 4d 89 c8 4c 8b 4c 24 08 0f 05 <48> 3d 01 f0 ff ff 73 01 c3 48 c7 c1 bc ff ff ff f7 d8 64 89 01 48 RSP: 002b:00007f494ecbcc58 EFLAGS: 00000246 ORIG_RAX: 0000000000000139 RAX: ffffffffffffffda RBX: 000000000073bf00 RCX: 0000000000462e99 RDX: 0000000000000000 RSI: 0000000020000180 RDI: 0000000000000003 RBP: 00007f494ecbcc70 R08: 0000000000000000 R09: 0000000000000000 R10: 0000000000000000 R11: 0000000000000246 R12: 00007f494ecbd6bc R13: 00000000004bcefa R14: 00000000006f6fb0 R15: 0000000000000004 Allocated by task 5987: set_track mm/kasan/common.c:87 [inline] __kasan_kmalloc.constprop.3+0xa0/0xd0 mm/kasan/common.c:497 kmalloc include/linux/slab.h:545 [inline] kzalloc include/linux/slab.h:740 [inline] configfs_register_default_group+0x4c/0xc0 fs/configfs/dir.c:1829 0xffffffffc1bd0023 do_one_initcall+0xbc/0x47d init/main.c:887 do_init_module+0x1b5/0x547 kernel/module.c:3456 load_module+0x6405/0x8c10 kernel/module.c:3804 __do_sys_finit_module+0x162/0x190 kernel/module.c:3898 do_syscall_64+0x9f/0x450 arch/x86/entry/common.c:290 entry_SYSCALL_64_after_hwframe+0x49/0xbe Freed by task 5987: set_track mm/kasan/common.c:87 [inline] __kasan_slab_free+0x130/0x180 mm/kasan/common.c:459 slab_free_hook mm/slub.c:1429 [inline] slab_free_freelist_hook mm/slub.c:1456 [inline] slab_free mm/slub.c:3003 [inline] kfree+0xe1/0x270 mm/slub.c:3955 configfs_register_default_group+0x9a/0xc0 fs/configfs/dir.c:1836 0xffffffffc1bd0023 do_one_initcall+0xbc/0x47d init/main.c:887 do_init_module+0x1b5/0x547 kernel/module.c:3456 load_module+0x6405/0x8c10 kernel/module.c:3804 __do_sys_finit_module+0x162/0x190 kernel/module.c:3898 do_syscall_64+0x9f/0x450 arch/x86/entry/common.c:290 entry_SYSCALL_64_after_hwframe+0x49/0xbe The buggy address belongs to the object at ffff8881ef61ae00 which belongs to the cache kmalloc-192 of size 192 The buggy address is located 32 bytes inside of 192-byte region [ffff8881ef61ae00, ffff8881ef61aec0) The buggy address belongs to the page: page:ffffea0007bd8680 count:1 mapcount:0 mapping:ffff8881f6c03000 index:0xffff8881ef61a700 flags: 0x2fffc0000000200(slab) raw: 02fffc0000000200 ffffea0007ca4740 0000000500000005 ffff8881f6c03000 raw: ffff8881ef61a700 000000008010000c 00000001ffffffff 0000000000000000 page dumped because: kasan: bad access detected Memory state around the buggy address: ffff8881ef61ad00: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ffff8881ef61ad80: 00 00 00 00 00 00 00 00 fc fc fc fc fc fc fc fc >ffff8881ef61ae00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb ^ ffff8881ef61ae80: fb fb fb fb fb fb fb fb fc fc fc fc fc fc fc fc ffff8881ef61af00: fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb fb Fixes: 5cf6a51e6062 ("configfs: allow dynamic group creation") Reported-by: Hulk Robot <hulkci@huawei.com> Signed-off-by: YueHaibing <yuehaibing@huawei.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-11-21configfs: replace strncpy with memcpyGuenter Roeck
commit 1823342a1f2b47a4e6f5667f67cd28ab6bc4d6cd upstream. gcc 8.1.0 complains: fs/configfs/symlink.c:67:3: warning: 'strncpy' output truncated before terminating nul copying as many bytes from a string as its length fs/configfs/symlink.c: In function 'configfs_get_link': fs/configfs/symlink.c:63:13: note: length computed here Using strncpy() is indeed less than perfect since the length of data to be copied has already been determined with strlen(). Replace strncpy() with memcpy() to address the warning and optimize the code a little. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nobuhiro Iwamatsu <nobuhiro.iwamatsu@cybertrust.co.jp> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2018-09-26configfs: fix registered group removalMike Christie
[ Upstream commit cc57c07343bd071cdf1915a91a24ab7d40c9b590 ] This patch fixes a bug where configfs_register_group had added a group in a tree, and userspace has done a rmdir on a dir somewhere above that group and we hit a kernel crash. The problem is configfs_rmdir will detach everything under it and unlink groups on the default_groups list. It will not unlink groups added with configfs_register_group so when configfs_unregister_group is called to drop its references to the group/items we crash when we try to access the freed dentrys. The patch just adds a check for if a rmdir has been done above us and if so just does the unlink part of unregistration. Sorry if you are getting this multiple times. I thouhgt I sent this to some of you and lkml, but I do not see it. Signed-off-by: Mike Christie <mchristi@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sasha Levin <alexander.levin@microsoft.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-06-24configfs: Fix race between create_link and configfs_rmdirNicholas Bellinger
commit ba80aa909c99802c428682c352b0ee0baac0acd3 upstream. This patch closes a long standing race in configfs between the creation of a new symlink in create_link(), while the symlink target's config_item is being concurrently removed via configfs_rmdir(). This can happen because the symlink target's reference is obtained by config_item_get() in create_link() before the CONFIGFS_USET_DROPPING bit set by configfs_detach_prep() during configfs_rmdir() shutdown is actually checked.. This originally manifested itself on ppc64 on v4.8.y under heavy load using ibmvscsi target ports with Novalink API: [ 7877.289863] rpadlpar_io: slot U8247.22L.212A91A-V1-C8 added [ 7879.893760] ------------[ cut here ]------------ [ 7879.893768] WARNING: CPU: 15 PID: 17585 at ./include/linux/kref.h:46 config_item_get+0x7c/0x90 [configfs] [ 7879.893811] CPU: 15 PID: 17585 Comm: targetcli Tainted: G O 4.8.17-customv2.22 #12 [ 7879.893812] task: c00000018a0d3400 task.stack: c0000001f3b40000 [ 7879.893813] NIP: d000000002c664ec LR: d000000002c60980 CTR: c000000000b70870 [ 7879.893814] REGS: c0000001f3b43810 TRAP: 0700 Tainted: G O (4.8.17-customv2.22) [ 7879.893815] MSR: 8000000000029033 <SF,EE,ME,IR,DR,RI,LE> CR: 28222242 XER: 00000000 [ 7879.893820] CFAR: d000000002c664bc SOFTE: 1 GPR00: d000000002c60980 c0000001f3b43a90 d000000002c70908 c0000000fbc06820 GPR04: c0000001ef1bd900 0000000000000004 0000000000000001 0000000000000000 GPR08: 0000000000000000 0000000000000001 d000000002c69560 d000000002c66d80 GPR12: c000000000b70870 c00000000e798700 c0000001f3b43ca0 c0000001d4949d40 GPR16: c00000014637e1c0 0000000000000000 0000000000000000 c0000000f2392940 GPR20: c0000001f3b43b98 0000000000000041 0000000000600000 0000000000000000 GPR24: fffffffffffff000 0000000000000000 d000000002c60be0 c0000001f1dac490 GPR28: 0000000000000004 0000000000000000 c0000001ef1bd900 c0000000f2392940 [ 7879.893839] NIP [d000000002c664ec] config_item_get+0x7c/0x90 [configfs] [ 7879.893841] LR [d000000002c60980] check_perm+0x80/0x2e0 [configfs] [ 7879.893842] Call Trace: [ 7879.893844] [c0000001f3b43ac0] [d000000002c60980] check_perm+0x80/0x2e0 [configfs] [ 7879.893847] [c0000001f3b43b10] [c000000000329770] do_dentry_open+0x2c0/0x460 [ 7879.893849] [c0000001f3b43b70] [c000000000344480] path_openat+0x210/0x1490 [ 7879.893851] [c0000001f3b43c80] [c00000000034708c] do_filp_open+0xfc/0x170 [ 7879.893853] [c0000001f3b43db0] [c00000000032b5bc] do_sys_open+0x1cc/0x390 [ 7879.893856] [c0000001f3b43e30] [c000000000009584] system_call+0x38/0xec [ 7879.893856] Instruction dump: [ 7879.893858] 409d0014 38210030 e8010010 7c0803a6 4e800020 3d220000 e94981e0 892a0000 [ 7879.893861] 2f890000 409effe0 39200001 992a0000 <0fe00000> 4bffffd0 60000000 60000000 [ 7879.893866] ---[ end trace 14078f0b3b5ad0aa ]--- To close this race, go ahead and obtain the symlink's target config_item reference only after the existing CONFIGFS_USET_DROPPING check succeeds. This way, if configfs_rmdir() wins create_link() will return -ENONET, and if create_link() wins configfs_rmdir() will return -EBUSY. Reported-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com> Tested-by: Bryant G. Ly <bryantly@linux.vnet.ibm.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-10Merge remote-tracking branch 'ovl/rename2' into for-linusAl Viro
2016-09-27fs: Replace current_fs_time() with current_time()Deepa Dinamani
current_fs_time() uses struct super_block* as an argument. As per Linus's suggestion, this is changed to take struct inode* as a parameter instead. This is because the function is primarily meant for vfs inode timestamps. Also the function was renamed as per Arnd's suggestion. Change all calls to current_fs_time() to use the new current_time() function instead. current_fs_time() will be deleted. Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-09-16configfs: Return -EFBIG from configfs_write_bin_file.Phil Turnbull
The check for writing more than cb_max_size bytes does not 'goto out' so it is a no-op which allows users to vmalloc an arbitrary amount. Fixes: 03607ace807b ("configfs: implement binary attributes") Cc: stable@kernel.org Signed-off-by: Phil Turnbull <phil.turnbull@oracle.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2016-07-10configfs: don't set buffer_needs_fill to zero if show() returns errorTal Shorer
A confgifs attribute's show() callback is called once the first time the user attempts to read from it. If it returns an error, that error is returned to the user. However, the open file's buffer_needs_fill is still set to zero and consecutive read() calls will find an empty buffer that doesn't need filling and return 0 to the user. This could give the user the wrong impression that the attribute was read successfully. Fix this by not setting buffer_needs_fill if show() returns an error, making consecutive read() calls call show() again and either get an error again or get data. Signed-off-by: Tal Shorer <tal.shorer@gmail.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2016-06-30configfs: Remove ppos increment in configfs_write_bin_fileMarek Vasut
The simple_write_to_buffer() already increments the @ppos on success, see fs/libfs.c simple_write_to_buffer() comment: " On success, the number of bytes written is returned and the offset @ppos advanced by this number, or negative value is returned on error. " If the configfs_write_bin_file() is invoked with @count smaller than the total length of the written binary file, it will be invoked multiple times. Since configfs_write_bin_file() increments @ppos on success, after calling simple_write_to_buffer(), the @ppos is incremented twice. Subsequent invocation of configfs_write_bin_file() will result in the next piece of data being written to the offset twice as long as the length of the previous write, thus creating buffer with "holes" in it. The simple testcase using DTO follows: $ mkdir /sys/kernel/config/device-tree/overlays/1 $ dd bs=1 if=foo.dtbo of=/sys/kernel/config/device-tree/overlays/1/dtbo Without this patch, the testcase will result in twice as big buffer in the kernel, which is then passed to the cfs_overlay_item_dtbo_write() . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Geert Uytterhoeven <geert+renesas@glider.be> Cc: Christoph Hellwig <hch@lst.de> Cc: Pantelis Antoniou <pantelis.antoniou@konsulko.com>
2016-05-09configfs_readdir(): make safe under shared lockAl Viro
2016-05-02parallel lookups: actual switch to rwsemAl Viro
ta-da! The main issue is the lack of down_write_killable(), so the places like readdir.c switched to plain inode_lock(); once killable variants of rwsem primitives appear, that'll be dealt with. lockdep side also might need more work Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-02configfs_detach_prep(): make sure that wait_mutex won't go awayAl Viro
grab a reference to dentry we'd got the sucker from, and return that dentry via *wait, rather than just returning the address of ->i_mutex. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-04-04mm, fs: get rid of PAGE_CACHE_* and page_cache_{get,release} macrosKirill A. Shutemov
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time ago with promise that one day it will be possible to implement page cache with bigger chunks than PAGE_SIZE. This promise never materialized. And unlikely will. We have many places where PAGE_CACHE_SIZE assumed to be equal to PAGE_SIZE. And it's constant source of confusion on whether PAGE_CACHE_* or PAGE_* constant should be used in a particular case, especially on the border between fs and mm. Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much breakage to be doable. Let's stop pretending that pages in page cache are special. They are not. The changes are pretty straight-forward: - <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN}; - page_cache_get() -> get_page(); - page_cache_release() -> put_page(); This patch contains automated changes generated with coccinelle using script below. For some reason, coccinelle doesn't patch header files. I've called spatch for them manually. The only adjustment after coccinelle is revert of changes to PAGE_CAHCE_ALIGN definition: we are going to drop it later. There are few places in the code where coccinelle didn't reach. I'll fix them manually in a separate patch. Comments and documentation also will be addressed with the separate patch. virtual patch @@ expression E; @@ - E << (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ expression E; @@ - E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ @@ - PAGE_CACHE_SHIFT + PAGE_SHIFT @@ @@ - PAGE_CACHE_SIZE + PAGE_SIZE @@ @@ - PAGE_CACHE_MASK + PAGE_MASK @@ expression E; @@ - PAGE_CACHE_ALIGN(E) + PAGE_ALIGN(E) @@ expression E; @@ - page_cache_get(E) + get_page(E) @@ expression E; @@ - page_cache_release(E) + put_page(E) Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-03-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs updates from Al Viro: - Preparations of parallel lookups (the remaining main obstacle is the need to move security_d_instantiate(); once that becomes safe, the rest will be a matter of rather short series local to fs/*.c - preadv2/pwritev2 series from Christoph - assorted fixes * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (32 commits) splice: handle zero nr_pages in splice_to_pipe() vfs: show_vfsstat: do not ignore errors from show_devname method dcache.c: new helper: __d_add() don't bother with __d_instantiate(dentry, NULL) untangle fsnotify_d_instantiate() a bit uninline d_add() replace d_add_unique() with saner primitive quota: use lookup_one_len_unlocked() cifs_get_root(): use lookup_one_len_unlocked() nfs_lookup: don't bother with d_instantiate(dentry, NULL) kill dentry_unhash() ceph_fill_trace(): don't bother with d_instantiate(dn, NULL) autofs4: don't bother with d_instantiate(dentry, NULL) in ->lookup() configfs: move d_rehash() into configfs_create() for regular files ceph: don't bother with d_rehash() in splice_dentry() namei: teach lookup_slow() to skip revalidate namei: massage lookup_slow() to be usable by lookup_one_len_unlocked() lookup_one_len_unlocked(): use lookup_dcache() namei: simplify invalidation logics in lookup_dcache() namei: change calling conventions for lookup_{fast,slow} and follow_managed() ...
2016-03-14configfs: move d_rehash() into configfs_create() for regular filesAl Viro
... and turn it into d_add in there Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-03-06configfs: switch ->default groups to a linked listChristoph Hellwig
Replace the current NULL-terminated array of default groups with a linked list. This gets rid of lots of nasty code to size and/or dynamically allocate the array. While we're at it also provide a conveniant helper to remove the default groups. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Felipe Balbi <balbi@kernel.org> [drivers/usb/gadget] Acked-by: Joel Becker <jlbec@evilplan.org> Acked-by: Nicholas Bellinger <nab@linux-iscsi.org> Reviewed-by: Sagi Grimberg <sagig@mellanox.com>
2016-02-26configfs: Replace CURRENT_TIME by current_fs_time()Deepa Dinamani
CURRENT_TIME macro is not appropriate for filesystems as it doesn't use the right granularity for filesystem timestamps. Use current_fs_time() instead. Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com> Acked-by: Joel Becker <jlbec@evilplan.org> Signed-off-by: Christoph Hellwig <hch@lst.de>
2016-01-22wrappers for ->i_mutex accessAl Viro
parallel to mutex_{lock,unlock,trylock,is_locked,lock_nested}, inode_foo(inode) being mutex_foo(&inode->i_mutex). Please, use those for access to ->i_mutex; over the coming cycle ->i_mutex will become rwsem, with ->lookup() done with it held only shared. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-20Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending Pull SCSI target updates from Nicholas Bellinger: "The highlights this round include: - Introduce configfs support for unlocked configfs_depend_item() (krzysztof + andrezej) - Conversion of usb-gadget target driver to new function registration interface (andrzej + sebastian) - Enable qla2xxx FC target mode support for Extended Logins (himansu + giridhar) - Enable qla2xxx FC target mode support for Exchange Offload (himansu + giridhar) - Add qla2xxx FC target mode irq affinity notification + selective command queuing. (quinn + himanshu) - Fix iscsi-target deadlock in se_node_acl configfs deletion (sagi + nab) - Convert se_node_acl configfs deletion + se_node_acl->queue_depth to proper se_session->sess_kref + target_get_session() usage. (hch + sagi + nab) - Fix long-standing race between se_node_acl->acl_kref get and get_initiator_node_acl() lookup. (hch + nab) - Fix target/user block-size handling, and make sure netlink reaches all network namespaces (sheng + andy) Note there is an outstanding bug-fix series for remote I_T nexus port TMR LUN_RESET has been posted and still being tested, and will likely become post -rc1 material at this point" * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (56 commits) scsi: qla2xxxx: avoid type mismatch in comparison target/user: Make sure netlink would reach all network namespaces target: Obtain se_node_acl->acl_kref during get_initiator_node_acl target: Convert ACL change queue_depth se_session reference usage iscsi-target: Fix potential dead-lock during node acl delete ib_srpt: Convert acl lookup to modern get_initiator_node_acl usage tcm_fc: Convert acl lookup to modern get_initiator_node_acl usage tcm_fc: Wait for command completion before freeing a session target: Fix a memory leak in target_dev_lba_map_store() target: Support aborting tasks with a 64-bit tag usb/gadget: Remove set-but-not-used variables target: Remove an unused variable target: Fix indentation in target_core_configfs.c target/user: Allow user to set block size before enabling device iser-target: Fix non negative ERR_PTR isert_device_get usage target/fcoe: Add tag support to tcm_fc qla2xxx: Check for online flag instead of active reset when transmitting responses qla2xxx: Set all queues to 4k qla2xxx: Disable ZIO at start time. qla2xxx: Move atioq to a different lock to reduce lock contention ...
2016-01-12Merge tag 'configfs-for-linus' of git://git.infradead.org/users/hch/configfsLinus Torvalds
Pull configfs updates from Christoph Hellwig: "I'm assisting Joel as co-maintainer and patch monkey now, and you will see pull reuquests from me for a while. Besides the MAINTAINERS update there is just a single change, which adds support for binary attributes to configfs, which are very similar to the sysfs binary attributes. Thanks to Pantelis Antoniou! You will see another actually bigger set of configfs changes in the SCSI target pull from Nic - those were merged before this new tree even existed" * tag 'configfs-for-linus' of git://git.infradead.org/users/hch/configfs: configfs: add myself as co-maintainer, updated git tree configfs: implement binary attributes
2016-01-04configfs: implement binary attributesPantelis Antoniou
ConfigFS lacked binary attributes up until now. This patch introduces support for binary attributes in a somewhat similar manner of sysfs binary attributes albeit with changes that fit the configfs usage model. Problems that configfs binary attributes fix are everything that requires a binary blob as part of the configuration of a resource, such as bitstream loading for FPGAs, DTBs for dynamically created devices etc. Look at Documentation/filesystems/configfs/configfs.txt for internals and howto use them. This patch is against linux-next as of today that contains Christoph's configfs rework. Signed-off-by: Pantelis Antoniou <pantelis.antoniou@konsulko.com> [hch: folded a fix from Geert Uytterhoeven <geert+renesas@glider.be>] [hch: a few tiny updates based on review feedback] Signed-off-by: Christoph Hellwig <hch@lst.de>
2015-12-30switch ->get_link() to delayed_call, kill ->put_link()Al Viro
2015-12-29kill free_page_put_link()Al Viro
all callers are better off with kfree_put_link() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-20fs: configfs: Add unlocked version of configfs_depend_item()Krzysztof Opasiak
This change is necessary for the SCSI target usb gadget composed with configfs. In this case configfs will be used for two different purposes: to compose a usb gadget and to configure the target part. If an instance of tcm function is created in $CONFIGFS_ROOT/usb_gadget/<gadget>/functions a tpg can be created in $CONFIGFS_ROOT/target/usb_gadget/<wwn>/, but after a tpg is created the tcm function must not be removed until its corresponding tpg is gone. While the configfs_depend/undepend_item() are meant exactly for creating this kind of dependencies, they are not suitable if the other kernel subsystem happens to be another subsystem in configfs, so this patch adds unlocked versions meant for configfs callbacks. Above description has been provided by: Andrzej Pietrasiewicz <andrzej.p@samsung.com> In configfs_depend_item() we have to consider two possible cases: 1) When we are called to depend another item in the same subsystem as caller In this case we should skip locking configfs root as we know that configfs is in valid state and our subsystem will not be unregistered during this call. 2) When we are called to depend item in different subsystem than our caller In this case we are also sure that configfs is in valid state but we have to lock root of configfs to avoid unregistration of target's subsystem. As it is other than caller's subsystem, there may be nothing what protects us against unregistration of that subsystem. Signed-off-by: Krzysztof Opasiak <k.opasiak@samsung.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2015-12-20fs: configfs: Factor out configfs_find_subsys_dentry()Krzysztof Opasiak
configfs_depend_item() is quite complicated and should be split up into smaller functions. This also allow to share this code with other functions. Signed-off-by: Krzysztof Opasiak <k.opasiak@samsung.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2015-12-20fs: configfs: Factor out configfs_do_depend_item()Krzysztof Opasiak
2015-12-20fs: configfs: Drop unused parameter from configfs_undepend_item()Krzysztof Opasiak
subsys parameter is never used by configfs_undepend_item() so there is no point in passing it to this function. Signed-off-by: Krzysztof Opasiak <k.opasiak@samsung.com> Cc: Joel Becker <jlbec@evilplan.org> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2015-12-08replace ->follow_link() with new method that could stay in RCU modeAl Viro
new method: ->get_link(); replacement of ->follow_link(). The differences are: * inode and dentry are passed separately * might be called both in RCU and non-RCU mode; the former is indicated by passing it a NULL dentry. * when called that way it isn't allowed to block and should return ERR_PTR(-ECHILD) if it needs to be called in non-RCU mode. It's a flagday change - the old method is gone, all in-tree instances converted. Conversion isn't hard; said that, so far very few instances do not immediately bail out when called in RCU mode. That'll change in the next commits. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-11-20configfs: allow dynamic group creationDaniel Baluta
This patchset introduces IIO software triggers, offers a way of configuring them via configfs and adds the IIO hrtimer based interrupt source to be used with software triggers. The architecture is now split in 3 parts, to remove all IIO trigger specific parts from IIO configfs core: (1) IIO configfs - creates the root of the IIO configfs subsys. (2) IIO software triggers - software trigger implementation, dynamically creating /config/iio/triggers group. (3) IIO hrtimer trigger - is the first interrupt source for software triggers (with syfs to follow). Each trigger type can implement its own set of attributes. Lockdep seems to be happy with the locking in configfs patch. This patch (of 5): We don't want to hardcode default groups at subsystem creation time. We export: * configfs_register_group * configfs_unregister_group to allow drivers to programatically create/destroy groups later, after module init time. This is needed for IIO configfs support. (akpm: the other 4 patches to be merged via the IIO tree) Signed-off-by: Daniel Baluta <daniel.baluta@intel.com> Suggested-by: Lars-Peter Clausen <lars@metafoo.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Acked-by: Joel Becker <jlbec@evilplan.org> Cc: Hartmut Knaack <knaack.h@gmx.de> Cc: Octavian Purdila <octavian.purdila@intel.com> Cc: Paul Bolle <pebolle@tiscali.nl> Cc: Adriana Reus <adriana.reus@intel.com> Cc: Cristina Opriceana <cristina.opriceana@gmail.com> Cc: Peter Meerwald <pmeerw@pmeerw.net> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-10-13configfs: remove old APIChristoph Hellwig
Remove the old show_attribute and store_attribute methods and update the documentation. Also replace the two C samples with a single new one in the proper samples directory where people expect to find it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2015-10-13configfs: add show and store methods to struct configfs_attributeChristoph Hellwig
Add methods to struct configfs_attribute to directly show and store attributes without adding boilerplate code to every user. In addition to the methods this also adds 3 helper macros to define read/write, read-only and write-only attributes with a single line of code. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Nicholas Bellinger <nab@linux-iscsi.org> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2015-07-17configfs: fix kernel infoleak through user-controlled format stringNicolas Iooss
Some modules call config_item_init_type_name() and config_group_init_type_name() with parameter "name" directly controlled by userspace. These two functions call config_item_set_name() with this name used as a format string, which can be used to leak information such as content of the stack to userspace. For example, make_netconsole_target() in netconsole module calls config_item_init_type_name() with the name of a newly-created directory. This means that the following commands give some unexpected output, with configfs mounted in /sys/kernel/config/ and on a system with a configured eth0 ethernet interface: # modprobe netconsole # mkdir /sys/kernel/config/netconsole/target_%lx # echo eth0 > /sys/kernel/config/netconsole/target_%lx/dev_name # echo 1 > /sys/kernel/config/netconsole/target_%lx/enabled # echo eth0 > /sys/kernel/config/netconsole/target_%lx/dev_name # dmesg |tail -n1 [ 142.697668] netconsole: target (target_ffffffffc0ae8080) is enabled, disable to update parameters The directory name is correct but %lx has been interpreted in the internal item name, displayed here in the error message used by store_dev_name() in drivers/net/netconsole.c. To fix this, update every caller of config_item_set_name to use "%s" when operating on untrusted input. This issue was found using -Wformat-security gcc flag, once a __printf attribute has been added to config_item_set_name(). Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Felipe Balbi <balbi@ti.com> Acked-by: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: "Assorted VFS fixes and related cleanups (IMO the most interesting in that part are f_path-related things and Eric's descriptor-related stuff). UFS regression fixes (it got broken last cycle). 9P fixes. fs-cache series, DAX patches, Jan's file_remove_suid() work" [ I'd say this is much more than "fixes and related cleanups". The file_table locking rule change by Eric Dumazet is a rather big and fundamental update even if the patch isn't huge. - Linus ] * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (49 commits) 9p: cope with bogus responses from server in p9_client_{read,write} p9_client_write(): avoid double p9_free_req() 9p: forgetting to cancel request on interrupted zero-copy RPC dax: bdev_direct_access() may sleep block: Add support for DAX reads/writes to block devices dax: Use copy_from_iter_nocache dax: Add block size note to documentation fs/file.c: __fget() and dup2() atomicity rules fs/file.c: don't acquire files->file_lock in fd_install() fs:super:get_anon_bdev: fix race condition could cause dev exceed its upper limitation vfs: avoid creation of inode number 0 in get_next_ino namei: make set_root_rcu() return void make simple_positive() public ufs: use dir_pages instead of ufs_dir_pages() pagemap.h: move dir_pages() over there remove the pointless include of lglock.h fs: cleanup slight list_entry abuse xfs: Correctly lock inode when removing suid and file capabilities fs: Call security_ops->inode_killpriv on truncate fs: Provide function telling whether file_remove_privs() will do anything ...
2015-07-03Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace Pull user namespace updates from Eric Biederman: "Long ago and far away when user namespaces where young it was realized that allowing fresh mounts of proc and sysfs with only user namespace permissions could violate the basic rule that only root gets to decide if proc or sysfs should be mounted at all. Some hacks were put in place to reduce the worst of the damage could be done, and the common sense rule was adopted that fresh mounts of proc and sysfs should allow no more than bind mounts of proc and sysfs. Unfortunately that rule has not been fully enforced. There are two kinds of gaps in that enforcement. Only filesystems mounted on empty directories of proc and sysfs should be ignored but the test for empty directories was insufficient. So in my tree directories on proc, sysctl and sysfs that will always be empty are created specially. Every other technique is imperfect as an ordinary directory can have entries added even after a readdir returns and shows that the directory is empty. Special creation of directories for mount points makes the code in the kernel a smidge clearer about it's purpose. I asked container developers from the various container projects to help test this and no holes were found in the set of mount points on proc and sysfs that are created specially. This set of changes also starts enforcing the mount flags of fresh mounts of proc and sysfs are consistent with the existing mount of proc and sysfs. I expected this to be the boring part of the work but unfortunately unprivileged userspace winds up mounting fresh copies of proc and sysfs with noexec and nosuid clear when root set those flags on the previous mount of proc and sysfs. So for now only the atime, read-only and nodev attributes which userspace happens to keep consistent are enforced. Dealing with the noexec and nosuid attributes remains for another time. This set of changes also addresses an issue with how open file descriptors from /proc/<pid>/ns/* are displayed. Recently readlink of /proc/<pid>/fd has been triggering a WARN_ON that has not been meaningful since it was added (as all of the code in the kernel was converted) and is not now actively wrong. There is also a short list of issues that have not been fixed yet that I will mention briefly. It is possible to rename a directory from below to above a bind mount. At which point any directory pointers below the renamed directory can be walked up to the root directory of the filesystem. With user namespaces enabled a bind mount of the bind mount can be created allowing the user to pick a directory whose children they can rename to outside of the bind mount. This is challenging to fix and doubly so because all obvious solutions must touch code that is in the performance part of pathname resolution. As mentioned above there is also a question of how to ensure that developers by accident or with purpose do not introduce exectuable files on sysfs and proc and in doing so introduce security regressions in the current userspace that will not be immediately obvious and as such are likely to require breaking userspace in painful ways once they are recognized" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/user-namespace: vfs: Remove incorrect debugging WARN in prepend_path mnt: Update fs_fully_visible to test for permanently empty directories sysfs: Create mountpoints with sysfs_create_mount_point sysfs: Add support for permanently empty directories to serve as mount points. kernfs: Add support for always empty directories. proc: Allow creating permanently empty directories that serve as mount points sysctl: Allow creating permanently empty directories that serve as mountpoints. fs: Add helper functions for permanently empty directories. vfs: Ignore unlocked mounts in fs_fully_visible mnt: Modify fs_fully_visible to deal with locked ro nodev and atime mnt: Refactor the logic for mounting sysfs and proc in a user namespace
2015-07-01sysfs: Create mountpoints with sysfs_create_mount_pointEric W. Biederman
This allows for better documentation in the code and it allows for a simpler and fully correct version of fs_fully_visible to be written. The mount points converted and their filesystems are: /sys/hypervisor/s390/ s390_hypfs /sys/kernel/config/ configfs /sys/kernel/debug/ debugfs /sys/firmware/efi/efivars/ efivarfs /sys/fs/fuse/connections/ fusectl /sys/fs/pstore/ pstore /sys/kernel/tracing/ tracefs /sys/fs/cgroup/ cgroup /sys/kernel/security/ securityfs /sys/fs/selinux/ selinuxfs /sys/fs/smackfs/ smackfs Cc: stable@vger.kernel.org Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2015-06-24configfs: unexport/make static config_item_init()Fabian Frederick
config_item_init() is only used in item.c Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-06-23make simple_positive() publicAl Viro
2015-05-11new helper: free_page_put_link()Al Viro
similar to kfree_put_link() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-05-11switch ->put_link() from dentry to inodeAl Viro
only one instance looks at that argument at all; that sole exception wants inode rather than dentry. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-05-10don't pass nameidata to ->follow_link()Al Viro
its only use is getting passed to nd_jump_link(), which can obtain it from current->nameidata Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-05-10new ->follow_link() and ->put_link() calling conventionsAl Viro
a) instead of storing the symlink body (via nd_set_link()) and returning an opaque pointer later passed to ->put_link(), ->follow_link() _stores_ that opaque pointer (into void * passed by address by caller) and returns the symlink body. Returning ERR_PTR() on error, NULL on jump (procfs magic symlinks) and pointer to symlink body for normal symlinks. Stored pointer is ignored in all cases except the last one. Storing NULL for opaque pointer (or not storing it at all) means no call of ->put_link(). b) the body used to be passed to ->put_link() implicitly (via nameidata). Now only the opaque pointer is. In the cases when we used the symlink body to free stuff, ->follow_link() now should store it as opaque pointer in addition to returning it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-05-05configfs: init configfs module earlier at boot timeDaniel Baluta
We need this earlier in the boot process to allow various subsystems to use configfs (e.g Industrial IIO). Also, debugfs is at core_initcall level and configfs should be on the same level from infrastructure point of view. Signed-off-by: Daniel Baluta <daniel.baluta@intel.com> Suggested-by: Lars-Peter Clausen <lars@metafoo.de> Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
