path: root/fs/compat_ioctl.c
2008-02-14d_path: Make d_path() use a struct pathJan Blunck
d_path() is used on a <dentry,vfsmount> pair. Lets use a struct path to reflect this. [akpm@linux-foundation.org: fix build in mm/memory.c] Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Bryan Wu <bryan.wu@analog.com> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08dm ioctl: move compat codeMilan Broz
Move compat_ioctl handling into dm-ioctl.c. Signed-off-by: Milan Broz <mbroz@redhat.com> Signed-off-by: Alasdair G Kergon <agk@redhat.com>
2008-02-07VFS: swap do_ioctl and vfs_ioctl namesErez Zadok
Rename old vfs_ioctl to do_ioctl, because the comment above it clearly indicates that it is an internal function not to be exported to modules; therefore it should have a more traditional do_XXX name. The new do_ioctl is exported in fs.h but not to modules. Rename the old do_ioctl to vfs_ioctl because the names vfs_XXX should preferably be reserved to callable VFS functions which modules may call, as many other vfs_XXX functions already do. Export the new vfs_ioctl to GPL modules so others can use it (including Unionfs and eCryptfs). Add DocBook for new vfs_ioctl. [akpm@linux-foundation.org: fix build] Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-28remove __attribute_used__Adrian Bunk
Remove the deprecated __attribute_used__. [Introduce __section in a few places to silence checkpatch /sam] Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2008-01-06fix: using joysticks in 32 bit applications on 64 bit systemsAkos Maroy
unfortunately 32 bit apps don't see the joysticks on a 64 bit system. this prevents one playing X-Plane (http://www.x-plane.com/) or other 32-bit games with joysticks. this is a known issue, and already raised several times: http://readlist.com/lists/vger.kernel.org/linux-kernel/28/144411.html http://www.brettcsmith.org/wiki/wiki.cgi?action=browse&diff=1&id=OzyComputer/Joystick unfortunately this is still not fixed in the mainline kernel. it would be nice to have this fixed, so that people can play these games without having to patch their kernel. the following patch solves the problem on 2.6.22. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-29tty: add the new termios2 ioctls to the compatible list.Heiko Carstens
Make them depend on TCGETS2. If that one is implemented the rest should be there as well. Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-30[COMPAT]: Fix new dev_ifname32 returning -EFAULTBenjamin Herrenschmidt
A stray semicolon slipped in the patch that updated dev_ifname32 to not be inline, causing it to always return -EFAULT. This fixes it. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-18sparse pointer use of zero as nullStephen Hemminger
Get rid of sparse related warnings from places that use integer as NULL pointer. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org> Cc: Andi Kleen <ak@suse.de> Cc: Jeff Garzik <jeff@garzik.org> Cc: Matt Mackall <mpm@selenic.com> Cc: Ian Kent <raven@themaw.net> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Clean up duplicate includes in fs/Jesper Juhl
This patch cleans up duplicate includes in fs/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-11Merge branch 'master' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6 * 'master' of git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (867 commits) [SKY2]: status polling loop (post merge) [NET]: Fix NAPI completion handling in some drivers. [TCP]: Limit processing lost_retrans loop to work-to-do cases [TCP]: Fix lost_retrans loop vs fastpath problems [TCP]: No need to re-count fackets_out/sacked_out at RTO [TCP]: Extract tcp_match_queue_to_sack from sacktag code [TCP]: Kill almost unused variable pcount from sacktag [TCP]: Fix mark_head_lost to ignore R-bit when trying to mark L [TCP]: Add bytes_acked (ABC) clearing to FRTO too [IPv6]: Update setsockopt(IPV6_MULTICAST_IF) to support RFC 3493, try2 [NETFILTER]: x_tables: add missing ip6t_modulename aliases [NETFILTER]: nf_conntrack_tcp: fix connection reopening [QETH]: fix qeth_main.c [NETLINK]: fib_frontend build fixes [IPv6]: Export userland ND options through netlink (RDNSS support) [9P]: build fix with !CONFIG_SYSCTL [NET]: Fix dev_put() and dev_hold() comments [NET]: make netlink user -> kernel interface synchronious [NET]: unify netlink kernel socket recognition [NET]: cleanup 3rd argument in netlink_sendskb ... Fix up conflicts manually in Documentation/feature-removal-schedule.txt and my new least favourite crap, the "mod_devicetable" support in the files include/linux/mod_devicetable.h and scripts/mod/file2alias.c. (The latter files seem to be explicitly _designed_ to get conflicts when different subsystems work with them - that have an absolutely horrid lack of subsystem separation!) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[NET]: Don't implement dev_ifname32 inlineEric W. Biederman
The current implementation of dev_ifname makes maintenance difficult because updates to the implementation of the ioctl have to made in two places. So this patch updates dev_ifname32 to do a classic 32/64 structure conversion and call sys_ioctl like the rest of the compat calls do. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-10-10compat_ioctl: move floppy handlers to block/compat_ioctl.cArnd Bergmann
The floppy ioctls are used by multiple drivers, so they should be handled in a shared location. Also, add minor cleanups. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10compat_ioctl: move cdrom handlers to block/compat_ioctl.cArnd Bergmann
These are shared by all cd-rom drivers and should have common handlers. Do slight cosmetic cleanups in the process. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10compat_ioctl: move BLKPG handling to block/compat_ioctl.cArnd Bergmann
BLKPG is common to all block devices, so it should be handled by common code. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10compat_ioctl: move hdio calls to block/compat_ioctl.cArnd Bergmann
These are common to multiple block drivers, so they should be handled by the block layer. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10compat_ioctl: handle blk_trace ioctlsArnd Bergmann
blk_trace_setup is broken on x86_64 compat systems, this makes the code work correctly on all 64 bit architectures in compat mode. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10compat_ioctl: add compat_blkdev_driver_ioctl()Arnd Bergmann
Handle those blockdev ioctl calls that are compatible directly from the compat_blkdev_ioctl() function, instead of having to go through the compat_ioctl hash lookup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-10-10compat_ioctl: move common block ioctls to compat_blkdev_ioctlArnd Bergmann
Make compat_blkdev_ioctl and blkdev_ioctl reflect the respective native versions. This is somewhat more efficient and makes it easier to keep the two in sync. Also get rid of the bogus handling for broken_blkgetsize and the duplicate entry for BLKRASET. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-09-21[PATCH] WE : Add missing auth compat-ioctlJean Tourrilhes
Johannes just found that we are missing a compat-ioctl declaration. The fix is trivial. As previous patches for compat-ioctl, this should also go to stable. More info : http://marc.info/?l=linux-wireless&m=119029667902588&w=2 Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-09-14As struct iw_point is bi-directional payload, we should copy back the contentMasakazu Mokuno
on return from ioctl calls Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-08-06[PATCH] remove duplicated ioctl entries in compat_ioctl.cMasakazu Mokuno
This patch removes some duplicated wireless ioctl entries in the array 'struct ioctl_trans ioctl_start[]' of fs/compat_ioctl.c These entries are registered twice like: COMPATIBLE_IOCTL(SIOCGIWPRIV) and HANDLE_IOCTL(SIOCGIWPRIV, do_wireless_ioctl) Signed-off-by: Masakazu Mokuno <mokuno@sm.sony.co.jp> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2007-07-30[SPARC]: Mark SBUS framebuffer ioctls as IGNORE in compat_ioctl.cDavid S. Miller
They are handled in a ->compat_ioctl() handler, so it's just noise when compat_ioctl.c warns which occurs when they are used on non-SBUS framebuffer devices. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-16compat32: ignore the LOOP_CLR_FD ioctlGeert Uytterhoeven
compat32: Ignore the LOOP_CLR_FD ioctl for the loop block device, to kill an annoying kernel message when e.g. busybox umount is used. Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-25fix compat console unimap regressionHugh Dickins
Why is it that since the 2f1a2ccb9c0de632ab07193becf5f7121794f6ae console UTF-8 fixes went into 2.6.22-rc1, the PowerMac G5 shows only inverse video question marks for the text on tty2-6? whereas tty1 is fine, and so is x86. No fault of that patch: by removing the old fallback behaviour, it reveals that 32-bit setfont running on 64-bit kernels has only really worked on the current console, the rest getting faked by that inadequate fallback. Bring the compat do_unimap_ioctl into line with the main one: PIO_UNIMAP and GIO_UNIMAP apply to the specified tty, not redirected to fg_console. Use the same checks, and most particularly, remember to check access_ok: con_set_unimap and con_get_unimap are using __get_user and __put_user. And the compat vt_check should ask for the same capability as the main one, CAP_SYS_TTY_CONFIG rather than CAP_SYS_ADMIN. Added in vt_ioctl's vc_cons_allocated check for safety, though failure may well be impossible. Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-10Allow compat_ioctl.c to compile without CONFIG_NETSimon Horman
A small regression appears to have been introduced in the recent patch "cleanup compat ioctl handling", which was included in Linus' tree after 2.6.20. siocdevprivate_ioctl() is no longer defined if CONFIG_NET is undefined, whereas previously it was a dummy function in this case. This causes compilation with CONFIG_COMPAT but without CONFIG_NET to fail. fs/compat_ioctl.c: In function `compat_sys_ioctl': fs/compat_ioctl.c:3571: warning: implicit declaration of function `siocdevprivate_ioctl' Cc: Christoph Hellwig <hch@lst.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08Fix error handling in HDIO_GETGEO compat wrapperAndreas Schwab
Don't clobber error from sys_ioctl in HDIO_GETGEO compat wrapper. Signed-off-by: Andreas Schwab <schwab@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08cleanup compat ioctl handlingChristoph Hellwig
Merge all compat ioctl handling into compat_ioctl.c instead of splitting it over compat.c and compat_ioctl.c. This also allows to get rid of ioctl32.h Signed-off-by: Christoph Hellwig <hch@lst.de> Looks-good-to: Andi Kleen <ak@suse.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08merge compat_ioctl.h into compat_ioctl.cChristoph Hellwig
Now that there is no arch-specific compat ioctl handling left there is not point in having a separate copat_ioctl.h, so merge it into compat_ioctl.c Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-02[PATCH] x86-64: Shut up warnings for vfat compat ioctls on other file systemsAndi Kleen
vfat implements compat handlers for these ioctls, but when they were executed on other file systems the kernel would still complain about an unknown compat ioctl. Just declare them as compatible and let them be rejected when not needed by the normal path. This makes wine runs a lot quieter Signed-off-by: Andi Kleen <ak@suse.de>
2007-05-02[PATCH] x86-64: Shut up 32bit emulation for SIOCGIFCOUNTAndi Kleen
The kernel doesn't implement it, but some programs like java use it anyways. Shut the code up. Signed-off-by: Andi Kleen <ak@suse.de>
2007-05-02[PATCH] x86-64: Define IGNORE_IOCTL() macro for compat_ioctlsAndi Kleen
Define a new IGNORE_IOCTL() to let a compat ioctl not be warned about even when it is not implemented. This is the same as COMPATIBLE_IOCTL internally, but better self documentng. Valid reasons to use this: - It is implemented with ->compat_ioctl on some device, but programs call it on others too. - The ioctl is not implemented in the native kernel, but programs call it commonly anyways. Most other reasons are not valid. Signed-off-by: Andi Kleen <ak@suse.de>
2007-04-25[NET]: Introduce SIOCGSTAMPNS ioctl to get timestamps with nanosec resolutionEric Dumazet
Now network timestamps use ktime_t infrastructure, we can add a new ioctl() SIOCGSTAMPNS command to get timestamps in 'struct timespec'. User programs can thus access to nanosecond resolution. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> CC: Stephen Hemminger <shemminger@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-03-27[PATCH] wext: Add missing ioctls to 64<->32 conversionJean Tourrilhes
Johannes Berg and Michael Buesch noticed that the WPA ioctls were missing from the 64<->32 bit conversion. This means that when using a 32 bits userspace on a 64 bit kernel, those ioctls fail. Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-12-08[PATCH] VFS: change struct file to use struct pathJosef "Jeff" Sipek
This patch changes struct file to use struct path instead of having independent pointers to struct dentry and struct vfsmount, and converts all users of f_{dentry,vfsmnt} in fs/ to use f_path.{dentry,mnt}. Additionally, it adds two #define's to make the transition easier for users of the f_dentry and f_vfsmnt. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07Merge branch 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6Linus Torvalds
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6: (156 commits) [PATCH] x86-64: Export smp_call_function_single [PATCH] i386: Clean up smp_tune_scheduling() [PATCH] unwinder: move .eh_frame to RODATA [PATCH] unwinder: fully support linker generated .eh_frame_hdr section [PATCH] x86-64: don't use set_irq_regs() [PATCH] x86-64: check vector in setup_ioapic_dest to verify if need setup_IO_APIC_irq [PATCH] x86-64: Make ix86 default to HIGHMEM4G instead of NOHIGHMEM [PATCH] i386: replace kmalloc+memset with kzalloc [PATCH] x86-64: remove remaining pc98 code [PATCH] x86-64: remove unused variable [PATCH] x86-64: Fix constraints in atomic_add_return() [PATCH] x86-64: fix asm constraints in i386 atomic_add_return [PATCH] x86-64: Correct documentation for bzImage protocol v2.05 [PATCH] x86-64: replace kmalloc+memset with kzalloc in MTRR code [PATCH] x86-64: Fix numaq build error [PATCH] x86-64: include/asm-x86_64/cpufeature.h isn't a userspace header [PATCH] unwinder: Add debugging output to the Dwarf2 unwinder [PATCH] x86-64: Clarify error message in GART code [PATCH] x86-64: Fix interrupt race in idle callback (3rd try) [PATCH] x86-64: Remove unwind stack pointer alignment forcing again ... Fixed conflict in include/linux/uaccess.h manually Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] compat: fix uaccess handlingHeiko Carstens
Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] x86-64: Implement compat code for SIOCSIFHWBROADCASTAndi Kleen
This network ioctl wasn't handled before. Reported by Alexandra.Kossovsky@oktetlabs.ru (Alexandra Kossovsky) Signed-off-by: Andi Kleen <ak@suse.de>
2006-10-11[PATCH] 32-bit compatibility HDIO IOCTLsMaciej W. Rozycki
A couple of HDIO IOCTLs are not yet handled and a few others are marked as using a pointer rather than an unsigned long. The formers include: HDIO_GET_WCACHE, HDIO_GET_ACOUSTIC, HDIO_GET_ADDRESS and HDIO_GET_BUSSTATE. The latters are: HDIO_SET_MULTCOUNT, HDIO_SET_UNMASKINTR, HDIO_SET_KEEPSETTINGS, HDIO_SET_32BIT, HDIO_SET_NOWERR, HDIO_SET_DMA, HDIO_SET_PIO_MODE and HDIO_SET_NICE. Additionally 0x330 used to be HDIO_GETGEO_BIG and may be issued by 32-bit `hdparm' run on a 64-bit kernel making Linux complain loudly. This is a fix for these issues. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Move ncpfs 32bit compat ioctl to ncpfsPetr Vandrovec
The ncp specific compat ioctls are clearly local to one file system, so the code can better live there. This version of the patch moves everything into the generic ioctl handler and uses it for both 32 and 64 bit calls. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] BLOCK: Make it possible to disable the block layer [try #6]David Howells
Make it possible to disable the block layer. Not all embedded devices require it, some can make do with just JFFS2, NFS, ramfs, etc - none of which require the block layer to be present. This patch does the following: (*) Introduces CONFIG_BLOCK to disable the block layer, buffering and blockdev support. (*) Adds dependencies on CONFIG_BLOCK to any configuration item that controls an item that uses the block layer. This includes: (*) Block I/O tracing. (*) Disk partition code. (*) All filesystems that are block based, eg: Ext3, ReiserFS, ISOFS. (*) The SCSI layer. As far as I can tell, even SCSI chardevs use the block layer to do scheduling. Some drivers that use SCSI facilities - such as USB storage - end up disabled indirectly from this. (*) Various block-based device drivers, such as IDE and the old CDROM drivers. (*) MTD blockdev handling and FTL. (*) JFFS - which uses set_bdev_super(), something it could avoid doing by taking a leaf out of JFFS2's book. (*) Makes most of the contents of linux/blkdev.h, linux/buffer_head.h and linux/elevator.h contingent on CONFIG_BLOCK being set. sector_div() is, however, still used in places, and so is still available. (*) Also made contingent are the contents of linux/mpage.h, linux/genhd.h and parts of linux/fs.h. (*) Makes a number of files in fs/ contingent on CONFIG_BLOCK. (*) Makes mm/bounce.c (bounce buffering) contingent on CONFIG_BLOCK. (*) set_page_dirty() doesn't call __set_page_dirty_buffers() if CONFIG_BLOCK is not enabled. (*) fs/no-block.c is created to hold out-of-line stubs and things that are required when CONFIG_BLOCK is not set: (*) Default blockdev file operations (to give error ENODEV on opening). (*) Makes some /proc changes: (*) /proc/devices does not list any blockdevs. (*) /proc/diskstats and /proc/partitions are contingent on CONFIG_BLOCK. (*) Makes some compat ioctl handling contingent on CONFIG_BLOCK. (*) If CONFIG_BLOCK is not defined, makes sys_quotactl() return -ENODEV if given command other than Q_SYNC or if a special device is specified. (*) In init/do_mounts.c, no reference is made to the blockdev routines if CONFIG_BLOCK is not defined. This does not prohibit NFS roots or JFFS2. (*) The bdflush, ioprio_set and ioprio_get syscalls can now be absent (return error ENOSYS by way of cond_syscall if so). (*) The seclvl_bd_claim() and seclvl_bd_release() security calls do nothing if CONFIG_BLOCK is not set, since they can't then happen. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Move the msdos device ioctl compat stuff to the msdos driver ↵David Howells
[try #6] Move the msdos device ioctl compat stuff from fs/compat_ioctl.c to the msdos driver so that the msdos header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Move the Ext3 device ioctl compat stuff to the Ext3 driver ↵David Howells
[try #6] Move the Ext3 device ioctl compat stuff from fs/compat_ioctl.c to the Ext3 driver so that the Ext3 header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Move the Ext2 device ioctl compat stuff to the Ext2 driver ↵David Howells
[try #6] Move the Ext2 device ioctl compat stuff from fs/compat_ioctl.c to the Ext2 driver so that the Ext2 header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Move the ReiserFS device ioctl compat stuff to the ReiserFS ↵David Howells
driver [try #6] Move the ReiserFS device ioctl compat stuff from fs/compat_ioctl.c to the ReiserFS driver so that the ReiserFS header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Move common FS-specific ioctls to linux/fs.h [try #6]David Howells
Move common FS-specific ioctls from linux/ext2_fs.h to linux/fs.h as FS_IOC_* and FS_IOC32_* and have the users of them use those as a base. Also move the GETFLAGS/SETFLAGS flags to linux/fs.h as FS_*_FL macros, and then have the other users use them as a base. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Move the loop device ioctl compat stuff to the loop driver ↵David Howells
[try #6] Move the loop device ioctl compat stuff from fs/compat_ioctl.c to the loop driver so that the loop header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Move extern declarations out of fs/*.c into header files [try #6]David Howells
Create a new header file, fs/internal.h, for common definitions local to the sources in the fs/ directory. Move extern definitions that should be in header files from fs/*.c to fs/internal.h or other main header files where they span directories. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-06-26[PATCH] devfs: Remove devfs from the kernel treeGreg Kroah-Hartman
This is the first patch in a series of patches that removes devfs support from the kernel. This patch removes the core devfs code, and its private header file. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
