path: root/fs/compat_ioctl.c
2006-10-11[PATCH] 32-bit compatibility HDIO IOCTLsMaciej W. Rozycki
A couple of HDIO IOCTLs are not yet handled and a few others are marked as using a pointer rather than an unsigned long. The formers include: HDIO_GET_WCACHE, HDIO_GET_ACOUSTIC, HDIO_GET_ADDRESS and HDIO_GET_BUSSTATE. The latters are: HDIO_SET_MULTCOUNT, HDIO_SET_UNMASKINTR, HDIO_SET_KEEPSETTINGS, HDIO_SET_32BIT, HDIO_SET_NOWERR, HDIO_SET_DMA, HDIO_SET_PIO_MODE and HDIO_SET_NICE. Additionally 0x330 used to be HDIO_GETGEO_BIG and may be issued by 32-bit `hdparm' run on a 64-bit kernel making Linux complain loudly. This is a fix for these issues. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Move ncpfs 32bit compat ioctl to ncpfsPetr Vandrovec
The ncp specific compat ioctls are clearly local to one file system, so the code can better live there. This version of the patch moves everything into the generic ioctl handler and uses it for both 32 and 64 bit calls. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Petr Vandrovec <petr@vandrovec.name> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] BLOCK: Make it possible to disable the block layer [try #6]David Howells
Make it possible to disable the block layer. Not all embedded devices require it, some can make do with just JFFS2, NFS, ramfs, etc - none of which require the block layer to be present. This patch does the following: (*) Introduces CONFIG_BLOCK to disable the block layer, buffering and blockdev support. (*) Adds dependencies on CONFIG_BLOCK to any configuration item that controls an item that uses the block layer. This includes: (*) Block I/O tracing. (*) Disk partition code. (*) All filesystems that are block based, eg: Ext3, ReiserFS, ISOFS. (*) The SCSI layer. As far as I can tell, even SCSI chardevs use the block layer to do scheduling. Some drivers that use SCSI facilities - such as USB storage - end up disabled indirectly from this. (*) Various block-based device drivers, such as IDE and the old CDROM drivers. (*) MTD blockdev handling and FTL. (*) JFFS - which uses set_bdev_super(), something it could avoid doing by taking a leaf out of JFFS2's book. (*) Makes most of the contents of linux/blkdev.h, linux/buffer_head.h and linux/elevator.h contingent on CONFIG_BLOCK being set. sector_div() is, however, still used in places, and so is still available. (*) Also made contingent are the contents of linux/mpage.h, linux/genhd.h and parts of linux/fs.h. (*) Makes a number of files in fs/ contingent on CONFIG_BLOCK. (*) Makes mm/bounce.c (bounce buffering) contingent on CONFIG_BLOCK. (*) set_page_dirty() doesn't call __set_page_dirty_buffers() if CONFIG_BLOCK is not enabled. (*) fs/no-block.c is created to hold out-of-line stubs and things that are required when CONFIG_BLOCK is not set: (*) Default blockdev file operations (to give error ENODEV on opening). (*) Makes some /proc changes: (*) /proc/devices does not list any blockdevs. (*) /proc/diskstats and /proc/partitions are contingent on CONFIG_BLOCK. (*) Makes some compat ioctl handling contingent on CONFIG_BLOCK. (*) If CONFIG_BLOCK is not defined, makes sys_quotactl() return -ENODEV if given command other than Q_SYNC or if a special device is specified. (*) In init/do_mounts.c, no reference is made to the blockdev routines if CONFIG_BLOCK is not defined. This does not prohibit NFS roots or JFFS2. (*) The bdflush, ioprio_set and ioprio_get syscalls can now be absent (return error ENOSYS by way of cond_syscall if so). (*) The seclvl_bd_claim() and seclvl_bd_release() security calls do nothing if CONFIG_BLOCK is not set, since they can't then happen. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Move the msdos device ioctl compat stuff to the msdos driver ↵David Howells
[try #6] Move the msdos device ioctl compat stuff from fs/compat_ioctl.c to the msdos driver so that the msdos header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Move the Ext3 device ioctl compat stuff to the Ext3 driver ↵David Howells
[try #6] Move the Ext3 device ioctl compat stuff from fs/compat_ioctl.c to the Ext3 driver so that the Ext3 header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Move the Ext2 device ioctl compat stuff to the Ext2 driver ↵David Howells
[try #6] Move the Ext2 device ioctl compat stuff from fs/compat_ioctl.c to the Ext2 driver so that the Ext2 header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Move the ReiserFS device ioctl compat stuff to the ReiserFS ↵David Howells
driver [try #6] Move the ReiserFS device ioctl compat stuff from fs/compat_ioctl.c to the ReiserFS driver so that the ReiserFS header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Move common FS-specific ioctls to linux/fs.h [try #6]David Howells
Move common FS-specific ioctls from linux/ext2_fs.h to linux/fs.h as FS_IOC_* and FS_IOC32_* and have the users of them use those as a base. Also move the GETFLAGS/SETFLAGS flags to linux/fs.h as FS_*_FL macros, and then have the other users use them as a base. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Move the loop device ioctl compat stuff to the loop driver ↵David Howells
[try #6] Move the loop device ioctl compat stuff from fs/compat_ioctl.c to the loop driver so that the loop header file doesn't need to be included. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-30[PATCH] BLOCK: Move extern declarations out of fs/*.c into header files [try #6]David Howells
Create a new header file, fs/internal.h, for common definitions local to the sources in the fs/ directory. Move extern definitions that should be in header files from fs/*.c to fs/internal.h or other main header files where they span directories. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-06-26[PATCH] devfs: Remove devfs from the kernel treeGreg Kroah-Hartman
This is the first patch in a series of patches that removes devfs support from the kernel. This patch removes the core devfs code, and its private header file. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] i4l: Gigaset drivers: add IOCTLs to compat_ioctl.hHansjoerg Lipp
Add the IOCTLs of the Gigaset drivers to compat_ioctl.h in order to make them available for 32 bit programs on 64 bit platforms. Please merge. Signed-off-by: Hansjoerg Lipp <hjlipp@web.de> Acked-by: Tilman Schmidt <tilman@imap.cc> Cc: Karsten Keil <kkeil@suse.de> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25V4L/DVB (3809a): Remove compat stuff for DMX_GET_EVENTAndrew Morton
The ioctl were removed by: V4L/DVB (3727): Remove DMX_GET_EVENT and associated data structures due to the ioctl DMX_GET_EVENT has never been implemented, and also scrambling events can't be generated in a useful way by the hardware. This patch removes the corresponding entry at fs/compat_ioctl.c Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-24[PATCH] fs: Use ARRAY_SIZE macroTobias Klauser
Use ARRAY_SIZE macro instead of sizeof(x)/sizeof(x[0]) and remove a duplicate of ARRAY_SIZE. Some trailing whitespaces are also deleted. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Cc: David Howells <dhowells@redhat.com> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Acked-by: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] Block queue IO tracing support (blktrace) as of 2006-03-23Jens Axboe
Signed-off-by: Jens Axboe <axboe@suse.de>
2006-03-08[NET] compat ifconf: fix limitsRandy Dunlap
A recent change to compat. dev_ifconf() in fs/compat_ioctl.c causes ifconf data to be truncated 1 entry too early when copying it to userspace. The correct amount of data (length) is returned, but the final entry is empty (zero, not filled in). The for-loop 'i' check should use <= to allow the final struct ifreq32 to be copied. I also used the ifconf-corruption program in kernel bugzilla #4746 to make sure that this change does not re-introduce the corruption. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-02-26[PATCH] x86_64: Fix ioctl compat code for /dev/rtcAndi Kleen
RTC_IRQP_SET/RTC_EPOCH_SET don't take a pointer to an argument, but the argument itself. This actually simplifies the code and makes it work. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-08[PATCH] compat_ioctl __user annotationsAl Viro
2006-01-12[PATCH] Implement ioctl emulation for the parport character deviceAndi Kleen
Fixes bugzilla.kernel.org bug 2903. Cc: <tim@cyberelk.net> Cc: <andrea@suse.de> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] x86_64: Implement compat code for sg driver SG_GET_REQUEST_TABLE ioctlAndi Kleen
Apparently helps with some non SANE scanner drivers. Cc: axboe@suse.de Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] capable/capability.h (fs/)Randy Dunlap
fs: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] sanitize building of fs/compat_ioctl.cChristoph Hellwig
Now that all these entries in the arch ioctl32.c files are gone [1], we can build fs/compat_ioctl.c as a normal object and kill tons of cruft. We need a special do_ioctl32_pointer handler for s390 so the compat_ptr call is done. This is not needed but harmless on all other architectures. Also remove some superflous includes in fs/compat_ioctl.c Tested on ppc64. [1] parisc still had it's PPP handler left, which is not fully correct for ppp and besides that ppp uses the generic SIOCPRIV ioctl so it'd kick in for all netdevice users. We can introduce a proper handler in one of the next patch series by adding a compat_ioctl method to struct net_device but for now let's just kill it - parisc doesn't compile in mainline anyway and I don't want this to block this patchset. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] move rtc compat ioctl handling to fs/compat_ioctl.cChristoph Hellwig
This patch implements generic handling of RTC_IRQP_READ32, RTC_IRQP_SET32, RTC_EPOCH_READ32 and RTC_EPOCH_SET32 in fs/compat_ioctl.c. It's based on the x86_64 code which needed a little massaging to be endian-clean. parisc used COMPAT_IOCTL or generic w_long handlers for these whichce is wrong and can't work because the ioctls encode sizeof(unsigned long) in their ioctl number. parisc also duplicated COMPAT_IOCTL entries for other rtc ioctls which I remove in this patch, too. Signed-off-by: Christoph Hellwig <hch@lst.de> Acked-by: Matthew Wilcox <matthew@wil.cx> Acked-by: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09V4L (926_2): Moves compat32 functions from fs to v4l subsystemArnd Bergmann
This moves the 32 bit ioctl compatibility handlers for Video4Linux into a new file and adds explicit calls to them to each v4l device driver. Unfortunately, there does not seem to be any code handling the v4l2 ioctls, so quite often the code goes through two separate conversions, first from 32 bit v4l to 64 bit v4l, and from there to 64 bit v4l2. My patch does not change that, so there is still much room for improvement. Also, some drivers have additional ioctl numbers, for which the conversion should be handled internally to that driver. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-11-20[COMPAT] net: SIOCGIFCONF data corruptionAlexandra Kossovsky
From: Alexandra Kossovsky <Alexandra.Kossovsky@oktetlabs.ru> From http://bugzilla.kernel.org/show_bug.cgi?id=4746 There is user data corruption when using ioctl(SIOCGIFCONF) in 32-bit application running amd64 kernel. I do not think that this problem is exploitable, but any data corruption may lead to security problems. Following code demonstrates the problem #include <stdint.h> #include <stdio.h> #include <sys/time.h> #include <sys/socket.h> #include <net/if.h> #include <sys/ioctl.h> char buf[256]; main() { int s = socket(AF_INET, SOCK_DGRAM, 0); struct ifconf req; int i; req.ifc_buf = buf; req.ifc_len = 41; printf("Result %d\n", ioctl(s, SIOCGIFCONF, &req)); printf("Len %d\n", req.ifc_len); for (i = 41; i < 256; i++) if (buf[i] != 0) printf("Byte %d is corrupted\n", i); } Steps to reproduce: Compile the code above into 32-bit elf and run it. You'll get Result 0 Len 32 Byte 48 is corrupted Byte 52 is corrupted Byte 53 is corrupted Byte 54 is corrupted Byte 55 is corrupted Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-18[COMPAT]: EXT3_IOC_SETVERSION is _IOW() not _IOR().David S. Miller
Noticed by Helge Deller. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-17[COMPAT]: Add ext3 ioctl translations.David S. Miller
So things like on-line resizing et al. work. Based almost entirely upon a patch by Guido Günther <agx@sigxcpu.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-16[DVB]: Add compat ioctl handling.David S. Miller
Based upon a patch by Guido Guenther <agx@sigxcpu.org>. Some of these ioctls had embedded time_t objects or pointers, so needed translation. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-09[PATCH] fbdev: move ioctl32 code to fbmem.cArnd Bergmann
The frame buffer layer already had some code dealing with compat ioctls, this patch moves over the remaining code from fs/compat_ioctl.c Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Antonino Daplas <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] re-add TIOCSTART and TIOCSTOP compat_ioctl handlersChristoph Hellwig
We don't implement these ioctls, but some architectures define them in the headers. Bash picks them up and issues them frequently. Add compat_ioctl handlers to silence warnings about unhandled copat ioctls. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] kfree cleanup: fsJesper Juhl
This is the fs/ part of the big kfree cleanup patch. Remove pointless checks for NULL prior to calling kfree() in fs/. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] TIOC* compat ioctl handlingChristoph Hellwig
TIOCSTART and TIOCSTOP are defined in asm/ioctls.h and asm/termios.h by various architectures but not actually implemented anywhere but in the IRIX compatibility layer, so remove their COMPATIBLE_IOCTL from parisc, ppc64 and sparc64. Move the TIOCSLTC COMPATIBLE_IOCTL to common code, guided by an ifdef to only show up on architectures that support it (same as the code handling it in tty_ioctl.c), aswell as it's brother TIOCGLTC that wasn't handled so far. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] usb: Patch for USBDEVFS_IOCTL from 32-bit programsPete Zaitcev
Dell supplied me with the following test: #include<stdio.h> #include<errno.h> #include<sys/ioctl.h> #include<fcntl.h> #include<linux/usbdevice_fs.h> main(int argc,char*argv[]) { struct usbdevfs_hub_portinfo hubPortInfo = {0}; struct usbdevfs_ioctl command = {0}; command.ifno = 0; command.ioctl_code = USBDEVFS_HUB_PORTINFO; command.data = (void*)&hubPortInfo; int fd, ret; if(argc != 2) { fprintf(stderr,"Usage: %s /proc/bus/usb/<BusNo>/<HubID>\n",argv[0]); fprintf(stderr,"Example: %s /proc/bus/usb/001/001\n",argv[0]); exit(1); } errno = 0; fd = open(argv[1],O_RDWR); if(fd < 0) { perror("open failed:"); exit(errno); } errno = 0; ret = ioctl(fd,USBDEVFS_IOCTL,&command); printf("IOCTL return status:%d\n",ret); if(ret<0) { perror("IOCTL failed:"); close(fd); exit(3); } else { printf("IOCTL passed:Num of ports %d\n",hubPortInfo.nports); close(fd); exit(0); } return 0; } I have verified that it breaks if built in 32 bit mode on x86_64 and that the patch below fixes it. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-09[PATCH] Lost sockfd_put() in routing_ioctl()Kirill Korotaev
This patch adds lost sockfd_put() in 32bit compat rounting_ioctl() on 64bit platforms Signed-Off-By: Kirill Korotaev <dev@sw.ru> Signed-Off-By: Maxim Giryaev <gem@sw.ru> Signed-off-By: Linus Torvalds <torvalds@osdl.org>
