path: root/fs/compat_ioctl.c
2018-10-29Merge tag 'media/v4.20-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - new dvb frontend driver: lnbh29 - new sensor drivers: imx319 and imx 355 - some old soc_camera driver renames to avoid conflict with new drivers - new i.MX Pixel Pipeline (PXP) mem-to-mem platform driver - a new V4L2 frontend for the FWHT codec - several other improvements, bug fixes, code cleanups, etc * tag 'media/v4.20-1' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (289 commits) media: rename soc_camera I2C drivers media: cec: forgot to cancel delayed work media: vivid: Support 480p for webcam capture media: v4l2-tpg: fix kernel oops when enabling HFLIP and OSD media: vivid: Add 16-bit bayer to format list media: v4l2-tpg-core: Add 16-bit bayer media: pvrusb2: replace `printk` with `pr_*` media: venus: vdec: fix decoded data size media: cx231xx: fix potential sign-extension overflow on large shift media: dt-bindings: media: rcar_vin: add device tree support for r8a7744 media: isif: fix a NULL pointer dereference bug media: exynos4-is: make const array config_ids static media: cx23885: make const array addr_list static media: ivtv: make const array addr_list static media: bttv-input: make const array addr_list static media: cx18: Don't check for address of video_dev media: dw9807-vcm: Fix probe error handling media: dw9714: Remove useless error message media: dw9714: Fix error handling in probe function media: cec: name for RC passthrough device does not need 'RC for' ...
2018-10-25Merge branch 'work.compat' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull compat_ioctl fixes from Al Viro: "A bunch of compat_ioctl fixes, mostly in bluetooth. Hopefully, most of fs/compat_ioctl.c will get killed off over the next few cycles; between this, tty series already merged and Arnd's work this cycle ought to take a good chunk out of the damn thing..." * 'work.compat' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: hidp: fix compat_ioctl hidp: constify hidp_connection_add() cmtp: fix compat_ioctl bnep: fix compat_ioctl compat_ioctl: trim the pointless includes
2018-10-13compat_ioctl - kill keyboard ioctl handlingAl Viro
all of those are provided only by vt and s390 tty3270; both have proper ->compat_ioctl() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2018-10-13gigaset: add ->compat_ioctl()Al Viro
... and get rid of COMPAT_IOCTL() for its private ioctls Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2018-10-13kill the rest of tty COMPAT_IOCTL() entriesAl Viro
TIOCLINUX is handled by ->compat_ioctl() in the only place that has native ->ioctl() recognizing it, TIOC{START,STOP} are simply useless these days - unrecognized compat ioctl won't spew into syslog anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2018-10-13take compat TIOC[SG]SERIAL treatment into tty_compat_ioctl()Al Viro
2018-09-14move compat handling of tty ioctls to tty_compat_ioctl()Al Viro
ioctls that are * callable only via tty_ioctl() * not driver-specific * not demand data structure conversions * either always need passing arg as is or always demand compat_ptr() get intercepted in tty_compat_ioctl() from the very beginning and redirecter to tty_ioctl(). As the result, their entries in fs/compat_ioctl.c (some of those had been missing, BTW) got removed, as well as n_tty_compat_ioctl_helper() (now it's never called with any cmd it would accept). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2018-09-12media: dvb: move compat handlers into driversArnd Bergmann
The VIDEO_STILLPICTURE is only implemented by one driver, while VIDEO_GET_EVENT has two users in tree. In both cases, it is fairly easy to handle the compat ioctls in the native handler rather than relying on translation in fs/compat_ioctls. In effect, this means that now the drivers implement both structure layouts in both native and compat mode, but I don't see anything wrong with that. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2018-09-12media: dvb: move most compat_ioctl handling into driversArnd Bergmann
Most DVB audio and video ioctl commands are completely compatible, and are implemented by just two drivers: ttpci and ivtv. In both cases, we can use the same ioctl handler for both native and compat ioctl handling, and remove the entries from the global lookup table. In case of ttpci, this directly hooks into the file_operations structure, and for ivtv, we have to set the compat_ioctl32 method in v4l2_file_operations. For all I can tell, setting it to video_ioctl2 will still do the right thing for all commands. Note that for the VIDEO_STILLPICTURE and VIDEO_GET_EVENT commands, a translation handler in fs/compat_ioctl.c is still used. This works because the command numbers are different on 32-bit systems. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2018-09-12media: cec: move compat_ioctl handling to cec-api.cArnd Bergmann
All the CEC ioctls are compatible, and they are only implemented in one driver, so we can simply let this driver handle them natively. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2018-09-12media: dvb: dmxdev: move compat_ioctl handling to dmxdev.cArnd Bergmann
All dmx ioctls are compatible, and they are only implemented in one file, so we can replace the list of commands in fs/compat_ioctl.c with a single line in dmxdev. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2018-09-12media: dvb: fix compat ioctl translationArnd Bergmann
The VIDEO_GET_EVENT and VIDEO_STILLPICTURE was added back in 2005 but it never worked because the command number is wrong. Using the right command number means we have a better chance of them actually doing the right thing, though clearly nobody has ever tried it successfully. I noticed these while auditing the remaining users of compat_time_t for y2038 bugs. This one is fine in that regard, it just never did anything. Fixes: 6e87abd0b8cb ("[DVB]: Add compat ioctl handling.") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2018-09-11presence of RS485 ioctls has been unconditional since 2014Al Viro
2018-09-10hidp: fix compat_ioctlAl Viro
1) no point putting it into fs/compat_ioctl.c when you handle it in your ->compat_ioctl() anyway. 2) HIDPCONNADD is *not* COMPATIBLE_IOCTL() stuff at all - it does layout massage (pointer-chasing there) 3) use compat_ptr() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2018-09-10cmtp: fix compat_ioctlAl Viro
Use compat_ptr(). And don't mess with fs/compat_ioctl.c Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2018-09-10bnep: fix compat_ioctlAl Viro
use compat_ptr() properly and don't bother with fs/compat_ioctl.c - it's all handled in ->compat_ioctl() anyway. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2018-09-10compat_ioctl: trim the pointless includesAl Viro
2018-07-30media: dvb/audio.h: get rid of unused APIsMauro Carvalho Chehab
There are a number of other ioctls that aren't used anywhere inside the Kernel tree. Get rid of them. Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2018-07-30media: dvb/video.h: get rid of unused APIsMauro Carvalho Chehab
2018-07-27media: dvb: get rid of VIDEO_SET_SPU_PALETTEMauro Carvalho Chehab
No upstream drivers use it. It doesn't make any sense to have a compat32 code for something that nobody uses upstream. Reported-by: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
2018-06-07autofs: clean up includesIan Kent
Remove includes that aren't needed from autofs (and fs/compat_ioctl.c). Link: http://lkml.kernel.org/r/152635085258.5968.9743527195522188148.stgit@pluto.themaw.net Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-06-07autofs4: merge auto_fs.h and auto_fs4.hIan Kent
The autofs module has long since been removed so there's no need to have two separate include files for autofs. Link: http://lkml.kernel.org/r/152626703024.28589.9571964661718767929.stgit@pluto.themaw.net Signed-off-by: Ian Kent <raven@themaw.net> Cc: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-12-28fs: compat_ioctl: add new DVB demux ioctlsMauro Carvalho Chehab
Use trivial handling for the new DVB demux ioctls, as none of them passes a pointer inside their structures. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-12-13media: dvb_frontend: Add compat_ioctl callbackJaedon Shin
Adds compat_ioctl for 32-bit user space applications on a 64-bit system. [m.chehab@osg.samsung.com: add missing include compat.h] Signed-off-by: Jaedon Shin <jaedon.shin@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-11-17Merge branch 'work.misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull misc vfs updates from Al Viro: "Assorted stuff, really no common topic here" * 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: vfs: grab the lock instead of blocking in __fd_install during resizing vfs: stop clearing close on exec when closing a fd include/linux/fs.h: fix comment about struct address_space fs: make fiemap work from compat_ioctl coda: fix 'kernel memory exposure attempt' in fsync pstore: remove unneeded unlikely() vfs: remove unneeded unlikely() stubs for mount_bdev() and kill_block_super() in !CONFIG_BLOCK case make vfs_ustat() static do_handle_open() should be static elf_fdpic: fix unused variable warning fold destroy_super() into __put_super() new helper: destroy_unused_super() fix address space warnings in ipc/ acct.h: get rid of detritus
2017-11-17Merge branch 'misc.compat' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull compat and uaccess updates from Al Viro: - {get,put}_compat_sigset() series - assorted compat ioctl stuff - more set_fs() elimination - a few more timespec64 conversions - several removals of pointless access_ok() in places where it was followed only by non-__ variants of primitives * 'misc.compat' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (24 commits) coredump: call do_unlinkat directly instead of sys_unlink fs: expose do_unlinkat for built-in callers ext4: take handling of EXT4_IOC_GROUP_ADD into a helper, get rid of set_fs() ipmi: get rid of pointless access_ok() pi433: sanitize ioctl cxlflash: get rid of pointless access_ok() mtdchar: get rid of pointless access_ok() r128: switch compat ioctls to drm_ioctl_kernel() selection: get rid of field-by-field copyin VT_RESIZEX: get rid of field-by-field copyin i2c compat ioctls: move to ->compat_ioctl() sched_rr_get_interval(): move compat to native, get rid of set_fs() mips: switch to {get,put}_compat_sigset() sparc: switch to {get,put}_compat_sigset() s390: switch to {get,put}_compat_sigset() ppc: switch to {get,put}_compat_sigset() parisc: switch to {get,put}_compat_sigset() get_compat_sigset() get rid of {get,put}_compat_itimerspec() io_getevents: Use timespec64 to represent timeouts ...
2017-11-05fs: make fiemap work from compat_ioctlJosef Bacik
We don't need to do anything special with fiemap to make it work with a 64bit kernel from 32bit userspace, so just go down to do_vfs_ioctl(). Without this patch we were incorrectly failing to do fiemap with a 32bit userspace on a 64bit kernel. Signed-off-by: Josef Bacik <jbacik@fb.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-20i2c compat ioctls: move to ->compat_ioctl()Al Viro
2017-09-05media: get rid of removed DMX_GET_CAPS and DMX_SET_SOURCE leftoversMauro Carvalho Chehab
Those two ioctls were never used within the Kernel. Still, there used to have compat32 code there (and an if #0 block at the core). Get rid of them. Fixes: 286fe1ca3fa1 ("media: dmx.h: get rid of DMX_GET_CAPS") Fixes: 13adefbe9e56 ("media: dmx.h: get rid of DMX_SET_SOURCE") Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-07-08Merge branch 'work.__copy_in_user' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull __copy_in_user removal from Al Viro: "There used to be 6 places in the entire tree calling __copy_in_user(), all of them bogus. Four got killed off in work.drm branch, this takes care of the remaining ones and kills the definition of that sucker" * 'work.__copy_in_user' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: kill __copy_in_user() sanitize do_i2c_smbus_ioctl()
2017-06-09tty: add compat_ioctl callbacksAleksa Sarai
In order to avoid future diversions between fs/compat_ioctl.c and drivers/tty/pty.c, define .compat_ioctl callbacks for the relevant tty_operations structs. Since both pty_unix98_ioctl() and pty_bsd_ioctl() are compatible between 32-bit and 64-bit userspace no special translation is required. Signed-off-by: Aleksa Sarai <asarai@suse.de> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-05-25sanitize do_i2c_smbus_ioctl()Al Viro
no need to mess with __copy_in_user() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-04-29fs: compat: Remove warning from COMPATIBLE_IOCTLMark Charlebois
cmd in COMPATIBLE_IOCTL is always a u32, so cast it so there isn't a warning about an overflow in XFORM. From: Mark Charlebois <charlebm@gmail.com> Signed-off-by: Mark Charlebois <charlebm@gmail.com> Signed-off-by: Behan Webster <behanw@converseincode.com> Signed-off-by: Matthias Kaehlcke <mka@chromium.org> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-12-24Replace <asm/uaccess.h> with <linux/uaccess.h> globallyLinus Torvalds
This was entirely automated, using the script by Al: PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>' sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \ $(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h) to do the replacement at the end of the merge window. Requested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-09-24fs: compat_ioctl: add pretimeout functions for watchdogsWolfram Sang
Watchdog core now handles those ioctls centrally, so we want 64 bit support, too. Signed-off-by: Wolfram Sang <wsa+renesas@sang-engineering.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: linux-fsdevel@vger.kernel.org Signed-off-by: Vladimir Zapolskiy <vladimir_zapolskiy@mentor.com> Acked-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Wim Van Sebroeck <wim@iguana.be>
2016-06-28[media] cec: add compat32 ioctl supportHans Verkuil
The CEC ioctls didn't have compat32 support, so they returned -ENOTTY when used in a 32 bit application on a 64 bit kernel. Since all the CEC ioctls are 32-bit compatible adding support for this API is trivial. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2016-02-14Merge 4.5-rc4 into char-misc-nextGreg Kroah-Hartman
We want those fixes in here as well. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-02-08fs/compat: remove useless compat ioctl for parport deviceBamvor Jian Zhang
Compat ioctl is already introduced in drivers/char/ppdev.c in order to fix y2038 issue for PP[GS]ETTIME. There is no need to define these here. Suggested-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Sudip Mukherjee <sudipm.mukherjee@gmail.com> Signed-off-by: Bamvor Jian Zhang <bamvor.zhangjian@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-01-27Bluetooth: Add missing COMPATIBLE_IOCTL for UART line disciplineMarcel Holtmann
The HCIUARTGETDEVICE, HCIUARTSETFLAGS and HCIUARTGETFLAGS ioctl are missing the COMPATIBLE_IOCTL declaration. Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
2016-01-12Merge branch 'work.misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull misc vfs updates from Al Viro: "All kinds of stuff. That probably should've been 5 or 6 separate branches, but by the time I'd realized how large and mixed that bag had become it had been too close to -final to play with rebasing. Some fs/namei.c cleanups there, memdup_user_nul() introduction and switching open-coded instances, burying long-dead code, whack-a-mole of various kinds, several new helpers for ->llseek(), assorted cleanups and fixes from various people, etc. One piece probably deserves special mention - Neil's lookup_one_len_unlocked(). Similar to lookup_one_len(), but gets called without ->i_mutex and tries to avoid ever taking it. That, of course, means that it's not useful for any directory modifications, but things like getting inode attributes in nfds readdirplus are fine with that. I really should've asked for moratorium on lookup-related changes this cycle, but since I hadn't done that early enough... I *am* asking for that for the coming cycle, though - I'm going to try and get conversion of i_mutex to rwsem with ->lookup() done under lock taken shared. There will be a patch closer to the end of the window, along the lines of the one Linus had posted last May - mechanical conversion of ->i_mutex accesses to inode_lock()/inode_unlock()/inode_trylock()/ inode_is_locked()/inode_lock_nested(). To quote Linus back then: ----- | This is an automated patch using | | sed 's/mutex_lock(&\(.*\)->i_mutex)/inode_lock(\1)/' | sed 's/mutex_unlock(&\(.*\)->i_mutex)/inode_unlock(\1)/' | sed 's/mutex_lock_nested(&\(.*\)->i_mutex,[ ]*I_MUTEX_\([A-Z0-9_]*\))/inode_lock_nested(\1, I_MUTEX_\2)/' | sed 's/mutex_is_locked(&\(.*\)->i_mutex)/inode_is_locked(\1)/' | sed 's/mutex_trylock(&\(.*\)->i_mutex)/inode_trylock(\1)/' | | with a very few manual fixups ----- I'm going to send that once the ->i_mutex-affecting stuff in -next gets mostly merged (or when Linus says he's about to stop taking merges)" * 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) nfsd: don't hold i_mutex over userspace upcalls fs:affs:Replace time_t with time64_t fs/9p: use fscache mutex rather than spinlock proc: add a reschedule point in proc_readfd_common() logfs: constify logfs_block_ops structures fcntl: allow to set O_DIRECT flag on pipe fs: __generic_file_splice_read retry lookup on AOP_TRUNCATED_PAGE fs: xattr: Use kvfree() [s390] page_to_phys() always returns a multiple of PAGE_SIZE nbd: use ->compat_ioctl() fs: use block_device name vsprintf helper lib/vsprintf: add %*pg format specifier fs: use gendisk->disk_name where possible poll: plug an unused argument to do_poll amdkfd: don't open-code memdup_user() cdrom: don't open-code memdup_user() rsxx: don't open-code memdup_user() mtip32xx: don't open-code memdup_user() [um] mconsole: don't open-code memdup_user_nul() [um] hostaudio: don't open-code memdup_user() ...
2016-01-12Merge branch 'work.copy_file_range' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs copy_file_range updates from Al Viro: "Several series around copy_file_range/CLONE" * 'work.copy_file_range' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: btrfs: use new dedupe data function pointer vfs: hoist the btrfs deduplication ioctl to the vfs vfs: wire up compat ioctl for CLONE/CLONE_RANGE cifs: avoid unused variable and label nfsd: implement the NFSv4.2 CLONE operation nfsd: Pass filehandle to nfs4_preprocess_stateid_op() vfs: pull btrfs clone API to vfs layer locks: new locks_mandatory_area calling convention vfs: Add vfs_copy_file_range() support for pagecache copies btrfs: add .copy_file_range file operation x86: add sys_copy_file_range to syscall tables vfs: add copy_file_range syscall and vfs helper
2016-01-08nbd: use ->compat_ioctl()Al Viro
2016-01-08compat_ioctl: don't call do_ioctl under set_fs(KERNEL_DS)Jann Horn
This replaces all code in fs/compat_ioctl.c that translated ioctl arguments into a in-kernel structure, then performed do_ioctl under set_fs(KERNEL_DS), with code that allocates data on the user stack and can call the VFS ioctl handler under USER_DS. This is done as a hardening measure because the caller does not know what kind of ioctl handler will be invoked, only that no corresponding compat_ioctl handler exists and what the ioctl command number is. The accidental invocation of an unlocked_ioctl handler that unexpectedly calls copy_to_user could be a severe security issue. Signed-off-by: Jann Horn <jann@thejh.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-08compat_ioctl: don't pass fd around when not neededAl Viro
2016-01-08compat_ioctl: don't look up the fd twiceJann Horn
In code in fs/compat_ioctl.c that translates ioctl arguments into a in-kernel structure, then performs sys_ioctl, possibly under set_fs(KERNEL_DS), this commit changes the sys_ioctl calls to do_ioctl calls. do_ioctl is a new function that does the same thing as sys_ioctl, but doesn't look up the fd again. This change is made to avoid (potential) security issues because of ioctl handlers that accept one of the ioctl commands I2C_FUNCS, VIDEO_GET_EVENT, MTIOCPOS, MTIOCGET, TIOCGSERIAL, TIOCSSERIAL, RTC_IRQP_READ, RTC_EPOCH_READ. This can happen for multiple reasons: - The ioctl command number could be reused. - The ioctl handler might not check the full ioctl command. This is e.g. true for drm_ioctl. - The ioctl handler is very special, e.g. cuse_file_ioctl The real issue is that set_fs(KERNEL_DS) is used here, but that's fixed in a separate commit "compat_ioctl: don't call do_ioctl under set_fs(KERNEL_DS)". This change mitigates potential security issues by preventing a race that permits invocation of unlocked_ioctl handlers under KERNEL_DS through compat code even if a corresponding compat_ioctl handler exists. So far, no way has been identified to use this to damage kernel memory without having CAP_SYS_ADMIN in the init ns (with the capability, doing reads/writes at arbitrary kernel addresses should be easy through CUSE's ioctl handler with FUSE_IOCTL_UNRESTRICTED set). [AV: two missed sys_ioctl() taken care of] Signed-off-by: Jann Horn <jann@thejh.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-01vfs: hoist the btrfs deduplication ioctl to the vfsDarrick J. Wong
Hoist the btrfs EXTENT_SAME ioctl up to the VFS and make the name more systematic (FIDEDUPERANGE). Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-01-01vfs: wire up compat ioctl for CLONE/CLONE_RANGEDarrick J. Wong
2015-10-23i2c-dev: Fix typo in ioctl name referenceJean Delvare
The ioctl is named I2C_RDWR for "I2C read/write". But references to it were misspelled "rdrw". Fix them. Signed-off-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
2015-07-09ioctl_compat: handle FITRIMMikulas Patocka
The FITRIM ioctl has the same arguments on 32-bit and 64-bit architectures, so we can add it to the list of compatible ioctls and drop it from compat_ioctl method of various filesystems. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ted Ts'o <tytso@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
