path: root/fs/cifs
2013-01-22fs/cifs/cifs_dfs_ref.c: fix potential memory leakageCong Ding
When it goes to error through line 144, the memory allocated to *devname is not freed, and the caller doesn't free it either in line 250. So we free the memroy of *devname in function cifs_compose_mount_options() when it goes to error. Signed-off-by: Cong Ding <dinggnu@gmail.com> CC: stable <stable@kernel.org> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-01-21cifs: fix srcip_matches() for ipv6Nickolai Zeldovich
srcip_matches() previously had code like this: srcip_matches(..., struct sockaddr *rhs) { /* ... */ struct sockaddr_in6 *vaddr6 = (struct sockaddr_in6 *) &rhs; return ipv6_addr_equal(..., &vaddr6->sin6_addr); } which interpreted the values on the stack after the 'rhs' pointer as an ipv6 address. The correct thing to do is to use 'rhs', not '&rhs'. Signed-off-by: Nickolai Zeldovich <nickolai@csail.mit.edu> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2013-01-01CIFS: Don't let read only caching for mandatory byte-range locked filesPavel Shilovsky
If we have mandatory byte-range locks on a file we can't cache reads because pagereading may have conflicts with these locks on the server. That's why we should allow level2 oplocks for files without mandatory locks only. Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-01-01CIFS: Fix write after setting a read lock for read oplock filesPavel Shilovsky
If we have a read oplock and set a read lock in it, we can't write to the locked area - so, filemap_fdatawrite may fail with a no information for a userspace application even if we request a write to non-locked area. Fix this by writing directly to the server and then breaking oplock level from level2 to None. Also remove CONFIG_CIFS_SMB2 ifdefs because it's suitable for both CIFS and SMB2 protocols. Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2013-01-01Revert "CIFS: Fix write after setting a read lock for read oplock files"Pavel Shilovsky
that solution has data races and can end up two identical writes to the server: when clientCanCacheAll value can be changed during the execution of __generic_file_aio_write. Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-30cifs: adjust sequence number downward after signing NT_CANCEL requestJeff Layton
When a call goes out, the signing code adjusts the sequence number upward by two to account for the request and the response. An NT_CANCEL however doesn't get a response of its own, it just hurries the server along to get it to respond to the original request more quickly. Therefore, we must adjust the sequence number back down by one after signing a NT_CANCEL request. Cc: <stable@vger.kernel.org> Reported-by: Tim Perry <tdparmor-sambabugs@yahoo.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-30cifs: move check for NULL socket into smb_send_rqstJeff Layton
Cai reported this oops: [90701.616664] BUG: unable to handle kernel NULL pointer dereference at 0000000000000028 [90701.625438] IP: [<ffffffff814a343e>] kernel_setsockopt+0x2e/0x60 [90701.632167] PGD fea319067 PUD 103fda4067 PMD 0 [90701.637255] Oops: 0000 [#1] SMP [90701.640878] Modules linked in: des_generic md4 nls_utf8 cifs dns_resolver binfmt_misc tun sg igb iTCO_wdt iTCO_vendor_support lpc_ich pcspkr i2c_i801 i2c_core i7core_edac edac_core ioatdma dca mfd_core coretemp kvm_intel kvm crc32c_intel microcode sr_mod cdrom ata_generic sd_mod pata_acpi crc_t10dif ata_piix libata megaraid_sas dm_mirror dm_region_hash dm_log dm_mod [90701.677655] CPU 10 [90701.679808] Pid: 9627, comm: ls Tainted: G W 3.7.1+ #10 QCI QSSC-S4R/QSSC-S4R [90701.688950] RIP: 0010:[<ffffffff814a343e>] [<ffffffff814a343e>] kernel_setsockopt+0x2e/0x60 [90701.698383] RSP: 0018:ffff88177b431bb8 EFLAGS: 00010206 [90701.704309] RAX: ffff88177b431fd8 RBX: 00007ffffffff000 RCX: ffff88177b431bec [90701.712271] RDX: 0000000000000003 RSI: 0000000000000006 RDI: 0000000000000000 [90701.720223] RBP: ffff88177b431bc8 R08: 0000000000000004 R09: 0000000000000000 [90701.728185] R10: 0000000000000001 R11: 0000000000000000 R12: 0000000000000001 [90701.736147] R13: ffff88184ef92000 R14: 0000000000000023 R15: ffff88177b431c88 [90701.744109] FS: 00007fd56a1a47c0(0000) GS:ffff88105fc40000(0000) knlGS:0000000000000000 [90701.753137] CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b [90701.759550] CR2: 0000000000000028 CR3: 000000104f15f000 CR4: 00000000000007e0 [90701.767512] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [90701.775465] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [90701.783428] Process ls (pid: 9627, threadinfo ffff88177b430000, task ffff88185ca4cb60) [90701.792261] Stack: [90701.794505] 0000000000000023 ffff88177b431c50 ffff88177b431c38 ffffffffa014fcb1 [90701.802809] ffff88184ef921bc 0000000000000000 00000001ffffffff ffff88184ef921c0 [90701.811123] ffff88177b431c08 ffffffff815ca3d9 ffff88177b431c18 ffff880857758000 [90701.819433] Call Trace: [90701.822183] [<ffffffffa014fcb1>] smb_send_rqst+0x71/0x1f0 [cifs] [90701.828991] [<ffffffff815ca3d9>] ? schedule+0x29/0x70 [90701.834736] [<ffffffffa014fe6d>] smb_sendv+0x3d/0x40 [cifs] [90701.841062] [<ffffffffa014fe96>] smb_send+0x26/0x30 [cifs] [90701.847291] [<ffffffffa015801f>] send_nt_cancel+0x6f/0xd0 [cifs] [90701.854102] [<ffffffffa015075e>] SendReceive+0x18e/0x360 [cifs] [90701.860814] [<ffffffffa0134a78>] CIFSFindFirst+0x1a8/0x3f0 [cifs] [90701.867724] [<ffffffffa013f731>] ? build_path_from_dentry+0xf1/0x260 [cifs] [90701.875601] [<ffffffffa013f731>] ? build_path_from_dentry+0xf1/0x260 [cifs] [90701.883477] [<ffffffffa01578e6>] cifs_query_dir_first+0x26/0x30 [cifs] [90701.890869] [<ffffffffa015480d>] initiate_cifs_search+0xed/0x250 [cifs] [90701.898354] [<ffffffff81195970>] ? fillonedir+0x100/0x100 [90701.904486] [<ffffffffa01554cb>] cifs_readdir+0x45b/0x8f0 [cifs] [90701.911288] [<ffffffff81195970>] ? fillonedir+0x100/0x100 [90701.917410] [<ffffffff81195970>] ? fillonedir+0x100/0x100 [90701.923533] [<ffffffff81195970>] ? fillonedir+0x100/0x100 [90701.929657] [<ffffffff81195848>] vfs_readdir+0xb8/0xe0 [90701.935490] [<ffffffff81195b9f>] sys_getdents+0x8f/0x110 [90701.941521] [<ffffffff815d3b99>] system_call_fastpath+0x16/0x1b [90701.948222] Code: 66 90 55 65 48 8b 04 25 f0 c6 00 00 48 89 e5 53 48 83 ec 08 83 fe 01 48 8b 98 48 e0 ff ff 48 c7 80 48 e0 ff ff ff ff ff ff 74 22 <48> 8b 47 28 ff 50 68 65 48 8b 14 25 f0 c6 00 00 48 89 9a 48 e0 [90701.970313] RIP [<ffffffff814a343e>] kernel_setsockopt+0x2e/0x60 [90701.977125] RSP <ffff88177b431bb8> [90701.981018] CR2: 0000000000000028 [90701.984809] ---[ end trace 24bd602971110a43 ]--- This is likely due to a race vs. a reconnection event. The current code checks for a NULL socket in smb_send_kvec, but that's too late. By the time that check is done, the socket will already have been passed to kernel_setsockopt. Move the check into smb_send_rqst, so that it's checked earlier. In truth, this is a bit of a half-assed fix. The -ENOTSOCK error return here looks like it could bubble back up to userspace. The locking rules around the ssocket pointer are really unclear as well. There are cases where the ssocket pointer is changed without holding the srv_mutex, but I'm not clear whether there's a potential race here yet or not. This code seems like it could benefit from some fundamental re-think of how the socket handling should behave. Until then though, this patch should at least fix the above oops in most cases. Cc: <stable@vger.kernel.org> # 3.7+ Reported-and-Tested-by: CAI Qian <caiqian@redhat.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-20cifs: eliminate cifsERROR variableJeff Layton
It's always set to "1" and there's no way to change it to anything else. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2012-12-20cifs: don't compare uniqueids in cifs_prime_dcache unless server inode ↵Jeff Layton
numbers are in use Oliver reported that commit cd60042c caused his cifs mounts to continually thrash through new inodes on readdir. His servers are not sending inode numbers (or he's not using them), and the new test in that function doesn't account for that sort of setup correctly. If we're not using server inode numbers, then assume that the inode attached to the dentry hasn't changed. Go ahead and update the attributes in place, but keep the same inode number. Cc: <stable@vger.kernel.org> # v3.5+ Reported-and-Tested-by: Oliver Mössinger <Oliver.Moessinger@ichaus.de> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2012-12-20cifs: fix double-free of "string" in cifs_parse_mount_optionsJeff Layton
Dan reported the following regression in commit d387a5c5: + fs/cifs/connect.c:1903 cifs_parse_mount_options() error: double free of 'string' That patch has some of the new option parsing code free "string" without setting the variable to NULL afterward. Since "string" is automatically freed in an error condition, fix the code to just rely on that instead of freeing it explicitly. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-17lseek: the "whence" argument is called "whence"Andrew Morton
But the kernel decided to call it "origin" instead. Fix most of the sites. Acked-by: Hugh Dickins <hughd@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-12-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates from James Morris: "A quiet cycle for the security subsystem with just a few maintenance updates." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: Smack: create a sysfs mount point for smackfs Smack: use select not depends in Kconfig Yama: remove locking from delete path Yama: add RCU to drop read locking drivers/char/tpm: remove tasklet and cleanup KEYS: Use keyring_alloc() to create special keyrings KEYS: Reduce initial permissions on keys KEYS: Make the session and process keyrings per-thread seccomp: Make syscall skipping and nr changes more consistent key: Fix resource leak keys: Fix unreachable code KEYS: Add payload preparsing opportunity prior to key instantiate or update
2012-12-13Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial branch from Jiri Kosina: "Usual stuff -- comment/printk typo fixes, documentation updates, dead code elimination." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) HOWTO: fix double words typo x86 mtrr: fix comment typo in mtrr_bp_init propagate name change to comments in kernel source doc: Update the name of profiling based on sysfs treewide: Fix typos in various drivers treewide: Fix typos in various Kconfig wireless: mwifiex: Fix typo in wireless/mwifiex driver messages: i2o: Fix typo in messages/i2o scripts/kernel-doc: check that non-void fcts describe their return value Kernel-doc: Convention: Use a "Return" section to describe return values radeon: Fix typo and copy/paste error in comments doc: Remove unnecessary declarations from Documentation/accounting/getdelays.c various: Fix spelling of "asynchronous" in comments. Fix misspellings of "whether" in comments. eisa: Fix spelling of "asynchronous". various: Fix spelling of "registered" in comments. doc: fix quite a few typos within Documentation target: iscsi: fix comment typos in target/iscsi drivers treewide: fix typo of "suport" in various comments and Kconfig treewide: fix typo of "suppport" in various comments ...
2012-12-11CIFS: Fix write after setting a read lock for read oplock filesPavel Shilovsky
If we have a read oplock and set a read lock in it, we can't write to the locked area - so, filemap_fdatawrite may fail with a no information for a userspace application even if we request a write to non-locked area. Fix this by populating the page cache without marking affected pages dirty after a successful write directly to the server. Also remove CONFIG_CIFS_SMB2 ifdefs because it's suitable for both CIFS and SMB2 protocols. Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-11cifs: parse the device name into UNC and prepathJeff Layton
This should fix a regression that was introduced when the new mount option parser went in. Also, when the unc= and prefixpath= options are provided, check their values against the ones we parsed from the device string. If they differ, then throw a warning that tells the user that we're using the values from the unc= option for now, but that that will change in 3.10. Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-11cifs: fix up handling of prefixpath= optionJeff Layton
Currently the code takes care to ensure that the prefixpath has a leading '/' delimiter. What if someone passes us a prefixpath with a leading '\\' instead? The code doesn't properly handle that currently AFAICS. Let's just change the code to skip over any leading delimiter character when copying the prepath. Then, fix up the users of the prepath option to prefix it with the correct delimiter when they use it. Also, there's no need to limit the length of the prefixpath to 1k. If the server can handle it, why bother forbidding it? Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-11cifs: clean up handling of unc= optionJeff Layton
Make sure we free any existing memory allocated for vol->UNC, just in case someone passes in multiple unc= options. Get rid of the check for too long a UNC. The check for >300 bytes seems arbitrary. We later copy this into the tcon->treeName, for instance and it's a lot shorter than 300 bytes. Eliminate an extra kmalloc and copy as well. Just set the vol->UNC directly with the contents of match_strdup. Establish that the UNC should be stored with '\\' delimiters. Use convert_delimiter to change it in place in the vol->UNC. Finally, move the check for a malformed UNC into cifs_parse_mount_options so we can catch that situation earlier. Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-11cifs: fix SID binary to string conversionJeff Layton
The authority fields are supposed to be represented by a single 48-bit value. It's also supposed to represent the value as hex if it's equal to or greater than 2^32. This is documented in MS-DTYP, section 2.4.2.1. Also, fix up the max string length to account for this fix. Acked-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-09fix "disabling echoes and oplocks" on SMB2 mountsSteve French
SMB2 and later will return only 1 credit for session setup (phase 1) not just for the negotiate protocol response. Do not disable echoes and oplocks on session setup (we only need one credit for tree connection anyway) as a resonse with only 1 credit on phase 1 of sessionsetup is expected. Fixes the "CIFS VFS: disabling echoes and oplocks" message logged to dmesg. Signed-off-by: Steve French <smfrench@gmail.com> Acked-by: Jeff Layton <jlayton@samba.org>
2012-12-09Do not send SMB2 signatures for SMB3 framesSteve French
Restructure code to make SMB2 vs. SMB3 signing a protocol specific op. SMB3 signing (AES_CMAC) is not enabled yet, but this restructuring at least makes sure we don't send an smb2 signature on an smb3 signed connection. A followon patch will add AES_CMAC and enable smb3 signing. Signed-off-by: Steve French <smfrench@gmail.com> Acked-by: Jeff Layton <jlayton@samba.org>
2012-12-08cifs: deal with id_to_sid embedded sid reply corner caseJeff Layton
A SID could potentially be embedded inside of payload.value if there are no subauthorities, and the arch has 8 byte pointers. Allow for that possibility there. While we're at it, rephrase the "embedding" check in terms of key->payload to allow for the possibility that the union might change size in the future. Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-08cifs: fix hardcoded default security descriptor lengthJeff Layton
It was hardcoded to 192 bytes, which was not enough when the max number of subauthorities went to 15. Redefine this constant in terms of sizeof the structs involved, and rename it for better clarity. While we're at it, remove a couple more unused constants from cifsacl.h. Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-08cifs: extra sanity checking for cifs.idmap keysJeff Layton
Now that we aren't so rigid about the length of the key being passed in, we need to be a bit more rigorous about checking the length of the actual data against the claimed length (a'la num_subauths field). Check for the case where userspace sends us a seemingly valid key with a num_subauths field that goes beyond the end of the array. If that happens, return -EIO and invalidate the key. Also change the other places where we check for malformed keys in this code to invalidate the key as well. Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-08cifs: avoid extra allocation for small cifs.idmap keysJeff Layton
The cifs.idmap keytype always allocates memory to hold the payload from userspace. In the common case where we're translating a SID to a UID or GID, we're allocating memory to hold something that's less than or equal to the size of a pointer. When the payload is the same size as a pointer or smaller, just store it in the payload.value union member instead. That saves us an extra allocation on the sid_to_id upcall. Note that we have to take extra care to check the datalen when we go to dereference the .data pointer in the union, but the callers now check that as a matter of course anyway. Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-08cifs: simplify id_to_sid and sid_to_id mapping codeJeff Layton
The cifs.idmap handling code currently causes the kernel to cache the data from userspace twice. It first looks in a rbtree to see if there is a matching entry for the given id. If there isn't then it calls request_key which then checks its cache and then calls out to userland if it doesn't have one. If the userland program establishes a mapping and downcalls with that info, it then gets cached in the keyring and in this rbtree. Aside from the double memory usage and the performance penalty in doing all of these extra copies, there are some nasty bugs in here too. The code declares four rbtrees and spinlocks to protect them, but only seems to use two of them. The upshot is that the same tree is used to hold (eg) uid:sid and sid:uid mappings. The comparitors aren't equipped to deal with that. I think we'd be best off to remove a layer of caching in this code. If this was originally done for performance reasons, then that really seems like a premature optimization. This patch does that -- it removes the rbtrees and the locks that protect them and simply has the code do a request_key call on each call into sid_to_id and id_to_sid. This greatly simplifies this code and should roughly halve the memory utilization from using the idmapping code. Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-07CIFS: Fix possible data coherency problem after oplock break to NonePavel Shilovsky
by using cifs_invalidate_mapping rather than invalidate_remote_inode in cifs_oplock_break - this invalidates all inode pages and resets fscache cookies. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-07CIFS: Do not permit write to a range mandatory locked with a read lockPavel Shilovsky
We don't need to permit a write to the area locked with a read lock by any process including the process that issues the write. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-05cifs: rename cifs_readdir_lookup to cifs_prime_dcache and make it void returnJeff Layton
The caller doesn't do anything with the dentry, so there's no point in holding a reference to it on return. Also cifs_prime_dcache better describes the actual purpose of the function. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-05cifs: Add CONFIG_CIFS_DEBUG and rename use of CIFS_DEBUGJoe Perches
This can reduce the size of the module by ~120KB which could be useful for embedded systems. $ size fs/cifs/built-in.o* text data bss dec hex filename 388567 34459 100440 523466 7fcca fs/cifs/built-in.o.new 495970 34599 117904 648473 9e519 fs/cifs/built-in.o.old Signed-off-by: Joe Perches <joe@perches.com> Reviewed-by: Jeff Layton <jlayton@redhat.com>
2012-12-05cifs: Make CIFS_DEBUG possible to undefineJoe Perches
Make the compilation work again when CIFS_DEBUG is not #define'd. Add format and argument verification for the various macros when CIFS_DEBUG is not #define'd. Signed-off-by: Joe Perches <joe@perches.com> Reviewed-by: Jeff Layton <jlayton@redhat.com>
2012-12-05SMB3 mounts fail with access denied to some serversSteve French
We were checking incorrectly if signatures were required to be sent, so were always sending signatures after the initial session establishment. For SMB3 mounts (vers=3.0) this was a problem because we were putting SMB2 signatures in SMB3 requests which would cause access denied on mount (the tree connection would fail). This might also be worth considering for stable (for 3.7), as the error message on mount (access denied) is confusing to users and there is no workaround if the server is configured to only support smb3.0. I am ok either way. CC: stable <stable@kernel.org> Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com>
2012-12-05cifs: Remove unused cEVENT macroJoe Perches
It uses an undefined KERN_EVENT and is itself unused. Signed-off-by: Joe Perches <joe@perches.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-05cifs: always zero out smb_vol before parsing optionsJeff Layton
Currently, the code relies on the callers to do that and they all do, but this will ensure that it's always done. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-05cifs: remove unneeded address argument from cifs_find_tcp_session and ↵Jeff Layton
match_server Now that the smb_vol contains the destination sockaddr, there's no need to pass it in separately. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-05make convert_delimiter use strchr instead of open-coding itSteve French
Take advantage of accelerated strchr() on arches that support it. Also, no caller ever passes in a NULL pointer. Get rid of the unneeded NULL pointer check. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-05cifs: get rid of smb_vol->UNCip and smb_vol->portJeff Layton
Passing this around as a string is contorted and painful. Instead, just convert these to a sockaddr as soon as possible, since that's how we're going to work with it later anyway. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-05cifs: ensure we revalidate the inode after readdir if cifsacl is enabledJeff Layton
Otherwise, "ls -l" will simply show the ownership of the files as the default mnt_uid/gid. This may make "ls -l" performance on large directories super-suck in some cases, but that's the cost of cifsacl. One possibility to make it suck less would be to somehow proactively dispatch the ACL requests asynchronously from readdir codepath, but that's non-trivial to implement. Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-05cifs: Add handling of blank password optionJesper Nilsson
The option to have a blank "pass=" already exists, and with a password specified both "pass=%s" and "password=%s" are supported. Also, both blank "user=" and "username=" are supported, making "password=" the odd man out. Signed-off-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-05Add SMB2.02 dialect supportSteve French
This patch enables optional for original SMB2 (SMB2.02) dialect by specifying vers=2.0 on mount. Reviewed-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-05CIFS: Fix lock consistensy bug in cifs_setlkPavel Shilovsky
If we netogiate mandatory locking style, have a read lock and try to set a write lock we end up with a write lock in vfs cache and no lock in cifs lock cache - that's wrong. Fix it by returning from cifs_setlk immediately if a error occurs during setting a lock. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-05CIFS: Implement cifs_relock_filePavel Shilovsky
that reacquires byte-range locks when a file is reopened. Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-05CIFS: Separate pushing mandatory locks and lock_sem handlingPavel Shilovsky
2012-12-05CIFS: Separate pushing posix locks and lock_sem handlingPavel Shilovsky
2012-12-05CIFS: Make use of common cifs_build_path_to_root for CIFS and SMB2Steve French
because the is no difference here. This also adds support of prefixpath mount option for SMB2. Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-05cifs: make error on lack of a unc= option more explicitJeff Layton
Error out with a clear error message if there is no unc= option. The existing code doesn't handle this in a clear fashion, and the check for a UNCip option with no UNC string is just plain wrong. Later, we'll fix the code to not require a unc= option, but for now we need this to at least clarify why people are getting errors about DFS parsing. With this change we can also get rid of some later NULL pointer checks since we know the UNC and UNCip will never be NULL there. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-05cifs: don't override the uid/gid in getattr when cifsacl is enabledJeff Layton
If we're using cifsacl, then we don't want to override the uid/gid with the current uid/gid, since that would prevent you from being able to upcall for this info. Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-05cifs: remove uneeded __KERNEL__ block from cifsacl.hJeff Layton
...and make those symbols static in cifsacl.c. Nothing outside of that file refers to them. Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-05cifs: fix the format specifiers in sid_to_strJeff Layton
The format specifiers are for signed values, but these are unsigned. Given that '-' is a delimiter between fields, I don't think you'd get what you'd expect if you got a value here that would overflow the sign bit. The version and authority fields are 8 bit values so use a "hh" length modifier there. The subauths are 32 bit values, so there's no need to use a "l" length modifier there. Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-05cifs: redefine NUM_SUBAUTH constant from 5 to 15Jeff Layton
According to several places on the Internet and the samba winbind code, this is hard limited to 15 in windows, not 5. This does balloon out the allocation of each by 40 bytes, but I don't see any alternative. Also, rename it to SID_MAX_SUB_AUTHORITIES to match the alleged name of this constant in the windows header files Finally, rename SIDLEN to SID_STRING_MAX, fix the value to reflect the change to SID_MAX_SUB_AUTHORITIES and document how it was determined. Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2012-12-05cifs: make cifs_copy_sid handle a source sid with variable size subauth arraysJeff Layton
...and lift the restriction in id_to_sid upcall that the size must be at least as big as a full cifs_sid. Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
