path: root/fs/cifs
2018-05-16proc: introduce proc_create_single{,_data}Christoph Hellwig
Variants of proc_create{,_data} that directly take a seq_file show callback and drastically reduces the boilerplate code in the callers. All trivial callers converted over. Signed-off-by: Christoph Hellwig <hch@lst.de>
2018-05-10smb3: directory sync should not return an errorSteve French
As with NFS, which ignores sync on directory handles, fsync on a directory handle is a noop for CIFS/SMB3. Do not return an error on it. It breaks some database apps otherwise. Signed-off-by: Steve French <smfrench@gmail.com> CC: Stable <stable@vger.kernel.org> Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
2018-05-09cifs: smb2ops: Fix listxattr() when there are no EAsPaulo Alcantara
As per listxattr(2): On success, a nonnegative number is returned indicating the size of the extended attribute name list. On failure, -1 is returned and errno is set appropriately. In SMB1, when the server returns an empty EA list through a listxattr(), it will correctly return 0 as there are no EAs for the given file. However, in SMB2+, it returns -ENODATA in listxattr() which is wrong since the request and response were sent successfully, although there's no actual EA for the given file. This patch fixes listxattr() for SMB2+ by returning 0 in cifs_listxattr() when the server returns an empty list of EAs. Signed-off-by: Paulo Alcantara <palcantara@suse.de> Reviewed-by: Aurelien Aptel <aaptel@suse.com> Signed-off-by: Steve French <smfrench@gmail.com>
2018-05-09cifs: smbd: Enable signing with smbdirectLong Li
Now signing is supported with RDMA transport. Remove the code that disabled it. Signed-off-by: Long Li <longli@microsoft.com> Signed-off-by: Steve French <stfrench@microsoft.com> Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com>
2018-05-09cifs: Allocate validate negotiation request through kmallocLong Li
The data buffer allocated on the stack can't be DMA'ed, ib_dma_map_page will return an invalid DMA address for a buffer on stack. Even worse, this incorrect address can't be detected by ib_dma_mapping_error. Sending data from this address to hardware will not fail, but the remote peer will get junk data. Fix this by allocating the request on the heap in smb3_validate_negotiate. Changes in v2: Removed duplicated code on freeing buffers on function exit. (Thanks to Parav Pandit <parav@mellanox.com>) Fixed typo in the patch title. Changes in v3: Added "Fixes" to the patch. Changed several sizeof() to use *pointer in place of struct. Changes in v4: Added detailed comments on the failure through RDMA. Allocate request buffer using GPF_NOFS. Fixed possible memory leak. Changes in v5: Removed variable ret for checking return value. Changed to use pneg_inbuf->Dialects[0] to calculate unused space in pneg_inbuf. Fixes: ff1c038addc4 ("Check SMB3 dialects against downgrade attacks") Signed-off-by: Long Li <longli@microsoft.com> Signed-off-by: Steve French <stfrench@microsoft.com> Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com> Reviewed-by: Tom Talpey <ttalpey@microsoft.com>
2018-05-04Merge tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rdma/rdmaLinus Torvalds
Pull rdma fixes from Doug Ledford: "This is our first pull request of the rc cycle. It's not that it's been overly quiet, we were just waiting on a few things before sending this off. For instance, the 6 patch series from Intel for the hfi1 driver had actually been pulled in on Tuesday for a Wednesday pull request, only to have Jason notice something I missed, so we held off for some testing, and then on Thursday had to respin the series because the very first patch needed a minor fix (unnecessary cast is all). There is a sizable hns patch series in here, as well as a reasonably largish hfi1 patch series, then all of the lines of uapi updates are just the change to the new official Linux-OpenIB SPDX tag (a bunch of our files had what amounts to a BSD-2-Clause + MIT Warranty statement as their license as a result of the initial code submission years ago, and the SPDX folks decided it was unique enough to warrant a unique tag), then the typical mlx4 and mlx5 updates, and finally some cxgb4 and core/cache/cma updates to round out the bunch. None of it was overly large by itself, but in the 2 1/2 weeks we've been collecting patches, it has added up :-/. As best I can tell, it's been through 0day (I got a notice about my last for-next push, but not for my for-rc push, but Jason seems to think that failure messages are prioritized and success messages not so much). It's also been through linux-next. And yes, we did notice in the context portion of the CMA query gid fix patch that there is a dubious BUG_ON() in the code, and have plans to audit our BUG_ON usage and remove it anywhere we can. Summary: - Various build fixes (USER_ACCESS=m and ADDR_TRANS turned off) - SPDX license tag cleanups (new tag Linux-OpenIB) - RoCE GID fixes related to default GIDs - Various fixes to: cxgb4, uverbs, cma, iwpm, rxe, hns (big batch), mlx4, mlx5, and hfi1 (medium batch)" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rdma/rdma: (52 commits) RDMA/cma: Do not query GID during QP state transition to RTR IB/mlx4: Fix integer overflow when calculating optimal MTT size IB/hfi1: Fix memory leak in exception path in get_irq_affinity() IB/{hfi1, rdmavt}: Fix memory leak in hfi1_alloc_devdata() upon failure IB/hfi1: Fix NULL pointer dereference when invalid num_vls is used IB/hfi1: Fix loss of BECN with AHG IB/hfi1 Use correct type for num_user_context IB/hfi1: Fix handling of FECN marked multicast packet IB/core: Make ib_mad_client_id atomic iw_cxgb4: Atomically flush per QP HW CQEs IB/uverbs: Fix kernel crash during MR deregistration flow IB/uverbs: Prevent reregistration of DM_MR to regular MR RDMA/mlx4: Add missed RSS hash inner header flag RDMA/hns: Fix a couple misspellings RDMA/hns: Submit bad wr RDMA/hns: Update assignment method for owner field of send wqe RDMA/hns: Adjust the order of cleanup hem table RDMA/hns: Only assign dqpn if IB_QP_PATH_DEST_QPN bit is set RDMA/hns: Remove some unnecessary attr_mask judgement RDMA/hns: Only assign mtu if IB_QP_PATH_MTU bit is set ...
2018-04-27cifs: smbd: depend on INFINIBAND_ADDR_TRANSGreg Thelen
CIFS_SMB_DIRECT code depends on INFINIBAND_ADDR_TRANS provided symbols. So declare the kconfig dependency. This is necessary to allow for enabling INFINIBAND without INFINIBAND_ADDR_TRANS. Signed-off-by: Greg Thelen <gthelen@google.com> Cc: Tarick Bedeir <tarick@google.com> Reviewed-by: Long Li <longli@microsoft.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2018-04-25cifs: smbd: Avoid allocating iov on the stackLong Li
It's not necessary to allocate another iov when going through the buffers in smbd_send() through RDMA send. Remove it to reduce stack size. Thanks to Matt for spotting a printk typo in the earlier version of this. CC: Matt Redfearn <matt.redfearn@mips.com> Signed-off-by: Long Li <longli@microsoft.com> Acked-by: Ronnie Sahlberg <lsahlber@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Steve French <smfrench@gmail.com>
2018-04-25cifs: smbd: Don't use RDMA read/write when signing is usedLong Li
SMB server will not sign data transferred through RDMA read/write. When signing is used, it's a good idea to have all the data signed. In this case, use RDMA send/recv for all data transfers. This will degrade performance as this is not generally configured in RDMA environemnt. So warn the user on signing and RDMA send/recv. Signed-off-by: Long Li <longli@microsoft.com> Acked-by: Ronnie Sahlberg <lsahlber@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Steve French <smfrench@gmail.com>
2018-04-25SMB311: Fix reconnectSteve French
The preauth hash was not being recalculated properly on reconnect of SMB3.11 dialect mounts (which caused access denied repeatedly on auto-reconnect). Fixes: 8bd68c6e47ab ("CIFS: implement v3.11 preauth integrity") Signed-off-by: Steve French <smfrench@gmail.com> CC: Stable <stable@vger.kernel.org> Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com>
2018-04-24SMB3: Fix 3.11 encryption to Windows and handle encrypted smb3 tconSteve French
Temporarily disable AES-GCM, as AES-CCM is only currently enabled mechanism on client side. This fixes SMB3.11 encrypted mounts to Windows. Also the tree connect request itself should be encrypted if requested encryption ("seal" on mount), in addition we should be enabling encryption in 3.11 based on whether we got any valid encryption ciphers back in negprot (the corresponding session flag is not set as it is in 3.0 and 3.02) Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com> Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com> CC: Stable <stable@vger.kernel.org>
2018-04-24CIFS: set *resp_buf_type to NO_BUFFER on errorSteve French
Dan Carpenter had pointed this out a while ago, but the code around this had changed so wasn't causing any problems since that field was not used in this error path. Still, it is cleaner to always initialize this field, so changing the error path to set it. Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com> CC: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Steve French <smfrench@gmail.com>
2018-04-20CIFS: fix typo in cifs_dbgAurelien Aptel
Signed-off-by: Aurelien Aptel <aaptel@suse.com> Signed-off-by: Steve French <smfrench@gmail.com> Reported-by: Long Li <longli@microsoft.com>
2018-04-20cifs: do not allow creating sockets except with SMB1 posix exensionsSteve French
RHBZ: 1453123 Since at least the 3.10 kernel and likely a lot earlier we have not been able to create unix domain sockets in a cifs share when mounted using the SFU mount option (except when mounted with the cifs unix extensions to Samba e.g.) Trying to create a socket, for example using the af_unix command from xfstests will cause : BUG: unable to handle kernel NULL pointer dereference at 00000000 00000040 Since no one uses or depends on being able to create unix domains sockets on a cifs share the easiest fix to stop this vulnerability is to simply not allow creation of any other special files than char or block devices when sfu is used. Added update to Ronnie's patch to handle a tcon link leak, and to address a buf leak noticed by Gustavo and Colin. Acked-by: Gustavo A. R. Silva <gustavo@embeddedor.com> CC: Colin Ian King <colin.king@canonical.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com> Reported-by: Eryu Guan <eguan@redhat.com> Signed-off-by: Ronnie Sahlberg <lsahlber@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Cc: stable@vger.kernel.org
2018-04-20cifs: smbd: Dump SMB packet when configuredLong Li
When sending through SMB Direct, also dump the packet in SMB send path. Also fixed a typo in debug message. Signed-off-by: Long Li <longli@microsoft.com> Cc: stable@vger.kernel.org Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com>
2018-04-18cifs: smbd: Check for iov length on sending the last iovLong Li
When sending the last iov that breaks into smaller buffers to fit the transfer size, it's necessary to check if this is the last iov. If this is the latest iov, stop and proceed to send pages. Signed-off-by: Long Li <longli@microsoft.com> Cc: stable@vger.kernel.org Signed-off-by: Steve French <stfrench@microsoft.com> Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com>
2018-04-17fs: cifs: Adding new return type vm_fault_tSouptick Joarder
Use new return type vm_fault_t for page_mkwrite handler. Signed-off-by: Souptick Joarder <jrdr.linux@gmail.com> Reviewed-by: Matthew Wilcox <mawilcox@microsoft.com> Signed-off-by: Steve French <stfrench@microsoft.com>
2018-04-17cifs: smb2ops: Fix NULL check in smb2_query_symlinkGustavo A. R. Silva
The current code null checks variable err_buf, which is always null when it is checked, hence utf16_path is free'd and the function returns -ENOENT everytime it is called, making it impossible for the execution path to reach the following code: err_buf = err_iov.iov_base; Fix this by null checking err_iov.iov_base instead of err_buf. Also, notice that err_buf no longer needs to be initialized to NULL. Addresses-Coverity-ID: 1467876 ("Logically dead code") Fixes: 2d636199e400 ("cifs: Change SMB2_open to return an iov for the error parameter") Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com> Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
2018-04-12cifs: change validate_buf to validate_iovRonnie Sahlberg
Signed-off-by: Ronnie Sahlberg <lsahlber@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
2018-04-12cifs: remove rfc1002 hardcoded constants from cifs_discard_remaining_data()Ronnie Sahlberg
2018-04-12cifs: Change SMB2_open to return an iov for the error parameterRonnie Sahlberg
2018-04-12cifs: add resp_buf_size to the mid_q_entry structureRonnie Sahlberg
and get rid of some more calls to get_rfc1002_length() Signed-off-by: Ronnie Sahlberg <lsahlber@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
2018-04-12smb3.11: replace a 4 with server->vals->header_preamble_sizeSteve French
More cleanup of use of hardcoded 4 byte RFC1001 field size Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com> Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com>
2018-04-12cifs: replace a 4 with server->vals->header_preamble_sizeRonnie Sahlberg
2018-04-12cifs: add pdu_size to the TCP_Server_Info structureRonnie Sahlberg
and get rid of some get_rfc1002_length() in smb2 Signed-off-by: Ronnie Sahlberg <lsahlber@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
2018-04-12SMB311: Improve checking of negotiate security contextsSteve French
SMB3.11 crypto and hash contexts were not being checked strictly enough. Add parsing and validity checking for the security contexts in the SMB3.11 negotiate response. Signed-off-by: Steve French <smfrench@gmail.com> CC: Stable <stable@vger.kernel.org> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
2018-04-12SMB3: Fix length checking of SMB3.11 negotiate requestSteve French
The length checking for SMB3.11 negotiate request includes "negotiate contexts" which caused a buffer validation problem and a confusing warning message on SMB3.11 mount e.g.: SMB2 server sent bad RFC1001 len 236 not 170 Fix the length checking for SMB3.11 negotiate to account for the new negotiate context so that we don't log a warning on SMB3.11 mount by default but do log warnings if lengths returned by the server are incorrect. CC: Stable <stable@vger.kernel.org> Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Aurelien Aptel <aaptel@suse.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
2018-04-11CIFS: add ONCE flag for cifs_dbg typeAurelien Aptel
* Since cifs_vfs_error was just using pr_debug_ratelimited like the rest of cifs_dbg, move it there too * Add a ONCE type flag to call the pr_xxx_once() debug function instead of the ratelimited ones. To convert existing printk_once() calls to this we can run: perl -i -pE \ 's/printk_once\s*\(([^" \n]+)(.*)/cifs_dbg(VFS|ONCE,$2/g' \ fs/cifs/*.c Signed-off-by: Aurelien Aptel <aaptel@suse.com> Signed-off-by: Steve French <stfrench@microsoft.com>
2018-04-11cifs: Use ULL suffix for 64-bit constantGeert Uytterhoeven
On 32-bit (e.g. with m68k-linux-gnu-gcc-4.1): fs/cifs/inode.c: In function ‘simple_hashstr’: fs/cifs/inode.c:713: warning: integer constant is too large for ‘long’ type Fixes: 7ea884c77e5c97f1 ("smb3: Fix root directory when server returns inode number of zero") Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Steve French <stfrench@microsoft.com> Reviewed-by: Aurelien Aptel <aaptel@suse.com>
2018-04-11SMB3: Log at least once if tree connect fails during reconnectSteve French
Adding an extra debug message to show if a tree connect failure during reconnect (and made it a log once so it doesn't spam the logs). Saw a case recently where tree connect repeatedly returned access denied on reconnect and it wasn't as easy to spot as it should have been. Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Aurelien Aptel <aaptel@suse.com>
2018-04-11cifs: smb2pdu: Fix potential NULL pointer dereferenceGustavo A. R. Silva
tcon->ses is being dereferenced before it is null checked, hence there is a potential null pointer dereference. Fix this by moving the pointer dereference after tcon->ses has been properly null checked. Addresses-Coverity-ID: 1467426 ("Dereference before null check") Fixes: 93012bf98416 ("cifs: add server->vals->header_preamble_size") Signed-off-by: Gustavo A. R. Silva <garsilva@embeddedor.com> Reviewed-by: Aurelien Aptel <aaptel@suse.com> Signed-off-by: Steve French <stfrench@microsoft.com>
2018-04-11page cache: use xa_lockMatthew Wilcox
Remove the address_space ->tree_lock and use the xa_lock newly added to the radix_tree_root. Rename the address_space ->page_tree to ->i_pages, since we don't really care that it's a tree. [willy@infradead.org: fix nds32, fs/dax.c] Link: http://lkml.kernel.org/r/20180406145415.GB20605@bombadil.infradead.orgLink: http://lkml.kernel.org/r/20180313132639.17387-9-willy@infradead.org Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com> Acked-by: Jeff Layton <jlayton@redhat.com> Cc: Darrick J. Wong <darrick.wong@oracle.com> Cc: Dave Chinner <david@fromorbit.com> Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Cc: Will Deacon <will.deacon@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2018-04-07Merge tag 'fscache-next-20180406' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs Pull fscache updates from David Howells: "Three patches that fix some of AFS's usage of fscache: (1) Need to invalidate the cache if a foreign data change is detected on the server. (2) Move the vnode ID uniquifier (equivalent to i_generation) from the auxiliary data to the index key to prevent a race between file delete and a subsequent file create seeing the same index key. (3) Need to retire cookies that correspond to files that we think got deleted on the server. Four patches to fix some things in fscache and cachefiles: (4) Fix a couple of checker warnings. (5) Correctly indicate to the end-of-operation callback whether an operation completed or was cancelled. (6) Add a check for multiple cookie relinquishment. (7) Fix a path through the asynchronous write that doesn't wake up a waiter for a page if the cache decides not to write that page, but discards it instead. A couple of patches to add tracepoints to fscache and cachefiles: (8) Add tracepoints for cookie operators, object state machine execution, cachefiles object management and cachefiles VFS operations. (9) Add tracepoints for fscache operation management and page wrangling. And then three development patches: (10) Attach the index key and auxiliary data to the cookie, pass this information through various fscache-netfs API functions and get rid of the callbacks to the netfs to get it. This means that the cache can get at this information, even if the netfs goes away. It also means that the cache can be lazy in updating the coherency data. (11) Pass the object data size through various fscache-netfs API rather than calling back to the netfs for it, and store the value in the object. This makes it easier to correctly resize the object, as the size is updated on writes to the cache, rather than calling back out to the netfs. (12) Maintain a catalogue of allocated cookies. This makes it possible to catch cookie collision up front rather than down in the bowels of the cache being run from a service thread from the object state machine. This will also make it possible in the future to reconnect to a cookie that's not gone dead yet because it's waiting for finalisation of the storage and also make it possible to bring cookies online if the cache is added after the cookie has been obtained" * tag 'fscache-next-20180406' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-fs: fscache: Maintain a catalogue of allocated cookies fscache: Pass object size in rather than calling back for it fscache: Attach the index key and aux data to the cookie fscache: Add more tracepoints fscache: Add tracepoints fscache: Fix hanging wait on page discarded by writeback fscache: Detect multiple relinquishment of a cookie fscache: Pass the correct cancelled indications to fscache_op_complete() fscache, cachefiles: Fix checker warnings afs: Be more aggressive in retiring cached vnodes afs: Use the vnode ID uniquifier in the cache key not the aux data afs: Invalidate cache on server data change
2018-04-06fscache: Pass object size in rather than calling back for itDavid Howells
Pass the object size in to fscache_acquire_cookie() and fscache_write_page() rather than the netfs providing a callback by which it can be received. This makes it easier to update the size of the object when a new page is written that extends the object. The current object size is also passed by fscache to the check_aux function, obviating the need to store it in the aux data. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Anna Schumaker <anna.schumaker@netapp.com> Tested-by: Steve Dickson <steved@redhat.com>
2018-04-04fscache: Attach the index key and aux data to the cookieDavid Howells
Attach copies of the index key and auxiliary data to the fscache cookie so that: (1) The callbacks to the netfs for this stuff can be eliminated. This can simplify things in the cache as the information is still available, even after the cache has relinquished the cookie. (2) Simplifies the locking requirements of accessing the information as we don't have to worry about the netfs object going away on us. (3) The cache can do lazy updating of the coherency information on disk. As long as the cache is flushed before reboot/poweroff, there's no need to update the coherency info on disk every time it changes. (4) Cookies can be hashed or put in a tree as the index key is easily available. This allows: (a) Checks for duplicate cookies can be made at the top fscache layer rather than down in the bowels of the cache backend. (b) Caching can be added to a netfs object that has a cookie if the cache is brought online after the netfs object is allocated. A certain amount of space is made in the cookie for inline copies of the data, but if it won't fit there, extra memory will be allocated for it. The downside of this is that live cache operation requires more memory. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Anna Schumaker <anna.schumaker@netapp.com> Tested-by: Steve Dickson <steved@redhat.com>
2018-04-02cifs: Add minor debug message during negprotSteve French
Check for unknown security mode flags during negotiate protocol if debugging enabled. Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
2018-04-02smb3: Fix root directory when server returns inode number of zeroSteve French
Some servers return inode number zero for the root directory, which causes ls to display incorrect data (missing "." and ".."). If the server returns zero for the inode number of the root directory, fake an inode number for it. Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com> CC: Stable <stable@vger.kernel.org>
2018-04-02cifs: fix sparse warning on previous patch in a few printksSteve French
Signed-off-by: Steve French <smfrench@gmail.com> CC: Ronnie Sahlberg <lsahlber@redhat.com>
2018-04-02cifs: add server->vals->header_preamble_sizeRonnie Sahlberg
This variable is set to 4 for all protocol versions and replaces the hardcoded constant 4 throughought the code. This will later be updated to reflect whether a response packet has a 4 byte length preamble or not once we start removing this field from the SMB2+ dialects. Signed-off-by: Ronnie Sahlberg <lsahlber@redhat.com> Signed-off-by: Steve French <stfrench@microsoft.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
2018-04-01cifs: smbd: disconnect transport on RDMA errorsLong Li
On RDMA errors, transport should disconnect the RDMA CM connection. This will notify the upper layer, and it will attempt transport reconnect. Signed-off-by: Long Li <longli@microsoft.com> Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com> CC: Stable <stable@vger.kernel.org>
2018-04-01cifs: smbd: avoid reconnect lockupLong Li
During transport reconnect, other processes may have registered memory and blocked on transport. This creates a deadlock situation because the transport resources can't be freed, and reconnect is blocked. Fix this by returning to upper layer on timeout. Before returning, transport status is set to reconnecting so other processes will release memory registration resources. Upper layer will retry the reconnect. This is not in fast I/O path so setting the timeout to 5 seconds. Signed-off-by: Long Li <longli@microsoft.com> Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com> CC: Stable <stable@vger.kernel.org>
2018-04-01Don't log confusing message on reconnect by defaultSteve French
Change the following message (which can occur on reconnect) from a warning to an FYI message. It is confusing to users. [58360.523634] CIFS VFS: Free previous auth_key.response = 00000000a91cdc84 By default this message won't show up on reconnect unless the user bumps up the log level to include FYI messages. Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
2018-04-01Don't log expected error on DFS referral requestSteve French
STATUS_FS_DRIVER_REQUIRED is expected when DFS is not turned on on the server. Do not log it on DFS referral response. It clutters the dmesg log unnecessarily at mount time. Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Aurelien Aptel <aaptel@suse.com Reviewed-by: Ronnie sahlberg <lsahlber@redhat.com>
2018-04-01fs: cifs: Replace _free_xid call in cifs_root_iget functionPhillip Potter
Modify end of cifs_root_iget function in fs/cifs/inode.c to call free_xid(xid) instead of _free_xid(xid), thereby allowing debug notification of this action when enabled. Signed-off-by: Phillip Potter <phil@philpotter.co.uk> Signed-off-by: Steve French <smfrench@gmail.com>
2018-04-01SMB3.1.1 dialect is no longer experimentalSteve French
SMB3.1.1 is a very important dialect, with much improved security. We can remove the ExPERIMENTAL comments about it. It is widely supported by servers. Signed-off-by: Steve French <smfrench@gmail.com> CC: Stable <stable@vger.kernel.org>
2018-04-01Tree connect for SMB3.1.1 must be signed for non-encrypted sharesSteve French
SMB3.1.1 tree connect was only being signed when signing was mandatory but needs to always be signed (for non-guest users). See MS-SMB2 section 3.2.4.1.1 Signed-off-by: Steve French <smfrench@gmail.com> Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com> CC: Stable <stable@vger.kernel.org>
2018-04-01fix smb3-encryption breakage when CONFIG_DEBUG_SG=yRonnie Sahlberg
We can not use the standard sg_set_buf() fucntion since when CONFIG_DEBUG_SG=y this adds a check that will BUG_ON for cifs.ko when we pass it an object from the stack. Create a new wrapper smb2_sg_set_buf() which avoids doing that particular check and use it for smb3 encryption instead. Signed-off-by: Ronnie Sahlberg <lsahlber@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com> CC: Stable <stable@vger.kernel.org>
2018-04-01CIFS: fix sha512 check in cifs_crypto_secmech_releaseGustavo A. R. Silva
It seems this is a copy-paste error and that the proper variable to use in this particular case is _sha512_ instead of _md5_. Addresses-Coverity-ID: 1465358 ("Copy-paste error") Fixes: 1c6614d229e7 ("CIFS: add sha512 secmech") Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com> Reviewed-by: Aurelien Aptel <aaptel@suse.com> CC: Stable <stable@vger.kernel.org> Signed-off-by: Steve French <smfrench@gmail.com>
2018-04-01CIFS: implement v3.11 preauth integrityAurelien Aptel
SMB3.11 clients must implement pre-authentification integrity. * new mechanism to certify requests/responses happening before Tree Connect. * supersedes VALIDATE_NEGOTIATE * fixes signing for SMB3.11 Signed-off-by: Aurelien Aptel <aaptel@suse.com> Signed-off-by: Steve French <smfrench@gmail.com> CC: Stable <stable@vger.kernel.org> Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com>
2018-04-01CIFS: add sha512 secmechAurelien Aptel
* prepare for SMB3.11 pre-auth integrity * enable sha512 when SMB311 is enabled in Kconfig * add sha512 as a soft dependency Signed-off-by: Aurelien Aptel <aaptel@suse.com> Signed-off-by: Steve French <smfrench@gmail.com> CC: Stable <stable@vger.kernel.org> Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com>
