This patch fixes the following KASAN report:
[ 779.044746] BUG: KASAN: slab-out-of-bounds in string+0xab/0x180
[ 779.044750] Read of size 1 at addr ffff88814f327968 by task trace-cmd/2812
[ 779.044756] CPU: 1 PID: 2812 Comm: trace-cmd Not tainted 5.1.0-rc1+ #62
[ 779.044760] Hardware name: QEMU Standard PC (Q35 + ICH9, 2009), BIOS rel-1.12.0-0-ga698c89-prebuilt.qemu.org 04/01/2014
[ 779.044761] Call Trace:
[ 779.044769] dump_stack+0x5b/0x90
[ 779.044775] ? string+0xab/0x180
[ 779.044781] print_address_description+0x6c/0x23c
[ 779.044787] ? string+0xab/0x180
[ 779.044792] ? string+0xab/0x180
[ 779.044797] kasan_report.cold.3+0x1a/0x32
[ 779.044803] ? string+0xab/0x180
[ 779.044809] string+0xab/0x180
[ 779.044816] ? widen_string+0x160/0x160
[ 779.044822] ? vsnprintf+0x5bf/0x7f0
[ 779.044829] vsnprintf+0x4e7/0x7f0
[ 779.044836] ? pointer+0x4a0/0x4a0
[ 779.044841] ? seq_buf_vprintf+0x79/0xc0
[ 779.044848] seq_buf_vprintf+0x62/0xc0
[ 779.044855] trace_seq_printf+0x113/0x210
[ 779.044861] ? trace_seq_puts+0x110/0x110
[ 779.044867] ? trace_raw_output_prep+0xd8/0x110
[ 779.044876] trace_raw_output_smb3_tcon_class+0x9f/0xc0
[ 779.044882] print_trace_line+0x377/0x890
[ 779.044888] ? tracing_buffers_read+0x300/0x300
[ 779.044893] ? ring_buffer_read+0x58/0x70
[ 779.044899] s_show+0x6e/0x140
[ 779.044906] seq_read+0x505/0x6a0
[ 779.044913] vfs_read+0xaf/0x1b0
[ 779.044919] ksys_read+0xa1/0x130
[ 779.044925] ? kernel_write+0xa0/0xa0
[ 779.044931] ? __do_page_fault+0x3d5/0x620
[ 779.044938] do_syscall_64+0x63/0x150
[ 779.044944] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 779.044949] RIP: 0033:0x7f62c2c2db31
[ 779.044955] Code: fe ff ff 48 8d 3d 17 9e 09 00 48 83 ec 08 e8 96 02
02 00 66 0f 1f 44 00 00 8b 05 fa fc 2c 00 48 63 ff 85 c0 75 13 31 c0
0f 05 <48> 3d 00 f0 ff ff 77 57 f3 c3 0f 1f 44 00 00 55 53 48 89 d5 48
89
[ 779.044958] RSP: 002b:00007ffd6e116678 EFLAGS: 00000246 ORIG_RAX: 0000000000000000
[ 779.044964] RAX: ffffffffffffffda RBX: 0000560a38be9260 RCX: 00007f62c2c2db31
[ 779.044966] RDX: 0000000000002000 RSI: 00007ffd6e116710 RDI: 0000000000000003
[ 779.044969] RBP: 00007f62c2ef5420 R08: 0000000000000000 R09: 0000000000000003
[ 779.044972] R10: ffffffffffffffa8 R11: 0000000000000246 R12: 00007ffd6e116710
[ 779.044975] R13: 0000000000002000 R14: 0000000000000d68 R15: 0000000000002000
[ 779.044981] Allocated by task 1257:
[ 779.044987] __kasan_kmalloc.constprop.5+0xc1/0xd0
[ 779.044992] kmem_cache_alloc+0xad/0x1a0
[ 779.044997] getname_flags+0x6c/0x2a0
[ 779.045003] user_path_at_empty+0x1d/0x40
[ 779.045008] do_faccessat+0x12a/0x330
[ 779.045012] do_syscall_64+0x63/0x150
[ 779.045017] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 779.045019] Freed by task 1257:
[ 779.045023] __kasan_slab_free+0x12e/0x180
[ 779.045029] kmem_cache_free+0x85/0x1b0
[ 779.045034] filename_lookup.part.70+0x176/0x250
[ 779.045039] do_faccessat+0x12a/0x330
[ 779.045043] do_syscall_64+0x63/0x150
[ 779.045048] entry_SYSCALL_64_after_hwframe+0x44/0xa9
[ 779.045052] The buggy address belongs to the object at ffff88814f326600
which belongs to the cache names_cache of size 4096
[ 779.045057] The buggy address is located 872 bytes to the right of
4096-byte region [ffff88814f326600, ffff88814f327600)
[ 779.045058] The buggy address belongs to the page:
[ 779.045062] page:ffffea00053cc800 count:1 mapcount:0 mapping:ffff88815b191b40 index:0x0 compound_mapcount: 0
[ 779.045067] flags: 0x200000000010200(slab|head)
[ 779.045075] raw: 0200000000010200 dead000000000100 dead000000000200 ffff88815b191b40
[ 779.045081] raw: 0000000000000000 0000000000070007 00000001ffffffff 0000000000000000
[ 779.045083] page dumped because: kasan: bad access detected
[ 779.045085] Memory state around the buggy address:
[ 779.045089] ffff88814f327800: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 779.045093] ffff88814f327880: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 779.045097] >ffff88814f327900: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 779.045099] ^
[ 779.045103] ffff88814f327980: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 779.045107] ffff88814f327a00: fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc fc
[ 779.045109] ==================================================================
[ 779.045110] Disabling lock debugging due to kernel taint
Correctly assign tree name str for smb3_tcon event.
Signed-off-by: Paulo Alcantara (SUSE) <paulo@paulo.ac>
Signed-off-by: Steve French <stfrench@microsoft.com>
Can be helpful in debugging various xfstests that are currently
skipped or failing due to missing features in our current
implementation of fallocate.
Reviewed-by: Ronnie Sahlberg <lsahlber@redhat.com>
Adds trace points for enter and exit (done vs. error) for:
compounded query and setinfo, hardlink, rename,
mkdir, rmdir, set_eof, delete (unlink)
To help debug credit starvation problems where we timeout
waiting for server to grant the client credits.
Reviewed-by: Pavel Shilovsky <pshilov@microsoft.com>
Adds dynamic trace points for the query_info_enter
and query_info_done (no error) case. We only had one
existing trace point related to this which was on query_info
errors. Note that these two new tracepoints are for the
non-compounded query_info paths.
Sample output (from: trace-cmd record -e smb3_query_info*)
ls-24140 [001] .... 27811.866068: smb3_query_info_enter: xid=7 sid=0xd2d00587 tid=0xb5441939 fid=0xcf082bac class=18 type=0x1
ls-24140 [001] .... 27811.867656: smb3_query_info_done: xid=7 sid=0xd2d00587 tid=0xb5441939 fid=0xcf082bac class=18 type=0x1
getcifsacl-24149 [005] .... 27854.759873: smb3_query_info_enter: xid=15 sid=0xd2d00587 tid=0xb5441939 fid=0x99896e72 class=0 type=0x3
getcifsacl-24149 [005] .... 27854.761730: smb3_query_info_done: xid=15 sid=0xd2d00587 tid=0xb5441939 fid=0x99896e72 class=0 type=0x3
Add tracepoint before sending an SMB3 command on the wire (ie add
an smb3_cmd_enter tracepoint). This allows us to look in much
more detail at response times (between request and response).
Add dynamic trace point for open_enter (and posix mkdir enter)
Allows tracing begin (not just completion) of read, write
and query_dir which may be helpful in finding slow requests
and other timing information
Adds two tracepoints - one for query_dir done (no err) and one for query_dir_err
Sanple output:
To start the trace in one window:
trace-cmd record -e smb3_query_dir*
Then in another window after doing an
ls /mnt
View the trace output by:
trace-cmd show
Sample output:
TASK-PID CPU# |||| TIMESTAMP FUNCTION
ls-24869 [007] .... 90695.452009: smb3_query_dir_done: xid=7 sid=0x5027d24d tid=0xb95cf25a fid=0xc41a8c3e offset=0x0 len=0x16
ls-24869 [000] .... 90695.452764: smb3_query_dir_done: xid=8 sid=0x5027d24d tid=0xb95cf25a fid=0xc41a8c3e offset=0x0 len=0x0
ls-24874 [003] .... 90701.506342: smb3_query_dir_done: xid=11 sid=0x5027d24d tid=0xb95cf25a fid=0x33ad3601 offset=0x0 len=0x8
ls-24874 [003] .... 90701.506917: smb3_query_dir_done: xid=12 sid=0x5027d24d tid=0xb95cf25a fid=0x33ad3601 offset=0x0 len=0x0
Precise and non-ambiguous license information is important. The recently
added aegis header file has a SPDX license identifier, which is nice, but
at the same time it has a contradictionary license boiler plate text.
SPDX-License-Identifier: GPL-2.0
versus
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
* the Free Software Foundation; either version 2 of the License, or
* (at your option) any later version.
Oh well.
Assuming that the SPDX identifier is correct and according to x86/hyper-v
contributions from Microsoft GPL V2 only is the usual license.
Remove the boiler plate as it is wrong and even if correct it is redundant.
Fixes: eccb4422cf97 ("smb3: Add ftrace tracepoints for improved SMB3 debugging")
Cc: Steve French <sfrench@samba.org>
Cc: linux-cifs@vger.kernel.org
In debugging certain scenarios, especially reconnect cases,
it can be helpful to have a dynamic trace point for the
result of tree connect. See sample output below
from a reconnect event. The new event is 'smb3_tcon'
cifsd-6071 [001] .... 2659.897923: smb3_reconnect: server=localhost current_mid=0xa
kworker/1:1-71 [001] .... 2666.026342: smb3_cmd_done: sid=0x0 tid=0x0 cmd=0 mid=0
kworker/1:1-71 [001] .... 2666.026576: smb3_cmd_err: sid=0xc49e1787 tid=0x0 cmd=1 mid=1 status=0xc0000016 rc=-5
kworker/1:1-71 [001] .... 2666.031677: smb3_cmd_done: sid=0xc49e1787 tid=0x0 cmd=1 mid=2
kworker/1:1-71 [001] .... 2666.031921: smb3_cmd_done: sid=0xc49e1787 tid=0x6e78f05f cmd=3 mid=3
kworker/1:1-71 [001] .... 2666.031923: smb3_tcon: xid=0 sid=0xc49e1787 tid=0x0 unc_name=\\localhost\test rc=0
kworker/1:1-71 [001] .... 2666.032097: smb3_cmd_done: sid=0xc49e1787 tid=0x6e78f05f cmd=11 mid=4
kworker/1:1-71 [001] .... 2666.032265: smb3_cmd_done: sid=0xc49e1787 tid=0x7912332f cmd=3 mid=5
kworker/1:1-71 [001] .... 2666.032266: smb3_tcon: xid=0 sid=0xc49e1787 tid=0x0 unc_name=\\localhost\IPC$ rc=0
kworker/1:1-71 [001] .... 2666.032386: smb3_cmd_done: sid=0xc49e1787 tid=0x7912332f cmd=11 mid=6
Be able to log a ftrace message on success and/or failure of
sending a lease break response to the server.
Example output:
kworker/1:1-5681 [001] .... 11123.530457: smb3_lease_done: sid=0x291e3e0f tid=0x8ba43071 lease_key=0x1852ca0d3ecd9b55847750a86716fde lease_state=0x0
Reviewed-by: Aurelien Aptel <aaptel@suse.com>
overlaps reconnect
Add tracepoint to catch potential cases where a pending operation overlapping a
reconnect could fail and incorrectly refund its credits causing the client
to think it has more credits available than the server thinks it does.
If responses take longer than one second from the server,
we can optionally log them to dmesg in current cifs.ko code
(CONFIG_CIFS_STATS2 must be configured and a
/proc/fs/cifs/cifsFYI flag must be set), but can be more useful
to log these via ftrace (tracepoint is smb3_slow_rsp) which
is easier and more granular (still requires CONFIG_CIFS_STATS2
to be configured in the build though).
Add tracepoints for reconnecting an smb3 session
Example output (from trace-cmd) with the patch
(showing the session marked for reconnect, the stat failing, and then
the subsequent SMB3 commands after the server comes back up).
The "smb3_reconnect" event is the new one.
cifsd-25993 [000] .... 29635.368265: smb3_reconnect: server=localhost current_mid=0x1e
stat-26200 [001] .... 29638.516403: smb3_enter: cifs_revalidate_dentry_attr: xid=22
stat-26200 [001] .... 29648.723296: smb3_exit_err: cifs_revalidate_dentry_attr: xid=22 rc=-112
kworker/0:1-22830 [000] .... 29653.850947: smb3_cmd_done: sid=0x0 tid=0x0 cmd=0 mid=0
kworker/0:1-22830 [000] .... 29653.851191: smb3_cmd_err: sid=0x8ae4683c tid=0x0 cmd=1 mid=1 status=0xc0000016 rc=-5
kworker/0:1-22830 [000] .... 29653.855254: smb3_cmd_done: sid=0x8ae4683c tid=0x0 cmd=1 mid=2
kworker/0:1-22830 [000] .... 29653.855482: smb3_cmd_done: sid=0x8ae4683c tid=0x8084f30d cmd=3 mid=3
In debugging reconnection problems, want to be able to more easily
trace cases in which the server has marked the SMB3 session
expired or deleted (to distinguish from timeout cases).
mkdir was not passing the mode on smb3.11 mounts with posix extensions
add two tracepoints for open completion. One for error one for completion (open_done).
Sample output below
bash-15348 [007] .... 42441.027492: smb3_enter: cifs_lookup: xid=45
bash-15348 [007] .... 42441.028214: smb3_cmd_err: sid=0x6173e4ce tid=0xa05150e6 cmd=5 mid=105 status=0xc0000034 rc=-2
bash-15348 [007] .... 42441.028219: smb3_open_err: xid=45 sid=0x6173e4ce tid=0xa05150e6 cr_opts=0x0 des_access=0x80 rc=-2
bash-15348 [007] .... 42441.028225: smb3_exit_done: cifs_lookup: xid=45
fop777-24560 [002] .... 42442.627617: smb3_enter: cifs_revalidate_dentry_attr: xid=46
fop777-24560 [003] .... 42442.628301: smb3_cmd_err: sid=0x6173e4ce tid=0xa05150e6 cmd=5 mid=106 status=0xc0000034 rc=-2
fop777-24560 [003] .... 42442.628319: smb3_open_err: xid=46 sid=0x6173e4ce tid=0xa05150e6 cr_opts=0x0 des_access=0x80 rc=-2
fop777-24560 [003] .... 42442.628335: smb3_enter: cifs_atomic_open: xid=47
fop777-24560 [003] .... 42442.629587: smb3_cmd_done: sid=0x6173e4ce tid=0xa05150e6 cmd=5 mid=107
fop777-24560 [003] .... 42442.629592: smb3_open_done: xid=47 sid=0x6173e4ce tid=0xa05150e6 fid=0xb8a0984d cr_opts=0x40 des_access=0x40000080
Signed-off-by: Steve French <smfrench@gmail.com>
Although dmesg logs and wireshark network traces can be
helpful, being able to dynamically enable/disable tracepoints
(in this case via the kernel ftrace mechanism) can also be
helpful in more quickly debugging problems, and more
selectively tracing the events related to the bug report.
This patch adds 12 ftrace tracepoints to cifs.ko for SMB3 events
in some obvious locations. Subsequent patches will add more
as needed.
Example use:
trace-cmd record -e cifs
<run test case>
trace-cmd show
Various trace events can be filtered. See:
trace-cmd list | grep cifs
for the current list of cifs tracepoints.
Sample output (from mount and writing to a file):
root@smf:/sys/kernel/debug/tracing/events/cifs# trace-cmd show
<snip>
mount.cifs-6633 [006] .... 7246.936461: smb3_cmd_done: pid=6633 tid=0x0 sid=0x0 cmd=0 mid=0
mount.cifs-6633 [006] .... 7246.936701: smb3_cmd_err: pid=6633 tid=0x0 sid=0x3d9cf8e5 cmd=1 mid=1 status=0xc0000016 rc=-5
mount.cifs-6633 [006] .... 7246.943055: smb3_cmd_done: pid=6633 tid=0x0 sid=0x3d9cf8e5 cmd=1 mid=2
mount.cifs-6633 [006] .... 7246.943298: smb3_cmd_done: pid=6633 tid=0xf9447636 sid=0x3d9cf8e5 cmd=3 mid=3
mount.cifs-6633 [006] .... 7246.943446: smb3_cmd_done: pid=6633 tid=0xf9447636 sid=0x3d9cf8e5 cmd=11 mid=4
mount.cifs-6633 [006] .... 7246.943659: smb3_cmd_done: pid=6633 tid=0xe1b781a sid=0x3d9cf8e5 cmd=3 mid=5
mount.cifs-6633 [006] .... 7246.943766: smb3_cmd_done: pid=6633 tid=0xe1b781a sid=0x3d9cf8e5 cmd=11 mid=6
mount.cifs-6633 [006] .... 7246.943937: smb3_cmd_done: pid=6633 tid=0xe1b781a sid=0x3d9cf8e5 cmd=5 mid=7
mount.cifs-6633 [006] .... 7246.944020: smb3_cmd_done: pid=6633 tid=0xe1b781a sid=0x3d9cf8e5 cmd=16 mid=8
mount.cifs-6633 [006] .... 7246.944091: smb3_cmd_done: pid=6633 tid=0xe1b781a sid=0x3d9cf8e5 cmd=16 mid=9
mount.cifs-6633 [006] .... 7246.944163: smb3_cmd_done: pid=6633 tid=0xe1b781a sid=0x3d9cf8e5 cmd=16 mid=10
mount.cifs-6633 [006] .... 7246.944218: smb3_cmd_err: pid=6633 tid=0xf9447636 sid=0x3d9cf8e5 cmd=11 mid=11 status=0xc0000225 rc=-2
mount.cifs-6633 [006] .... 7246.944219: smb3_fsctl_err: xid=0 fid=0xffffffffffffffff tid=0xf9447636 sid=0x3d9cf8e5 class=0 type=393620 rc=-2
mount.cifs-6633 [007] .... 7246.944353: smb3_cmd_done: pid=6633 tid=0xe1b781a sid=0x3d9cf8e5 cmd=16 mid=12
bash-2071 [000] .... 7256.903844: smb3_cmd_done: pid=2071 tid=0xe1b781a sid=0x3d9cf8e5 cmd=5 mid=13
bash-2071 [000] .... 7256.904172: smb3_cmd_done: pid=2071 tid=0xe1b781a sid=0x3d9cf8e5 cmd=16 mid=14
bash-2071 [000] .... 7256.904471: smb3_cmd_done: pid=2071 tid=0xe1b781a sid=0x3d9cf8e5 cmd=17 mid=15
bash-2071 [000] .... 7256.904950: smb3_cmd_done: pid=2071 tid=0xe1b781a sid=0x3d9cf8e5 cmd=5 mid=16
bash-2071 [000] .... 7256.905305: smb3_cmd_done: pid=2071 tid=0xe1b781a sid=0x3d9cf8e5 cmd=17 mid=17
bash-2071 [000] .... 7256.905688: smb3_cmd_done: pid=2071 tid=0xe1b781a sid=0x3d9cf8e5 cmd=6 mid=18
bash-2071 [000] .... 7256.905809: smb3_write_done: xid=0 fid=0xd628f511 tid=0xe1b781a sid=0x3d9cf8e5 offset=0x0 len=0x1b
Acked-by: Ronnie Sahlberg <lsahlber@redhat.com>
