path: root/fs/cifs/readdir.c
2012-01-18CIFS: Rename *UCS* functions to *UTF16*Steve French
to reflect the unicode encoding used by CIFS protocol. Signed-off-by: Pavel Shilovsky <piastry@etersoft.ru> Acked-by: Jeff Layton <jlayton@samba.org> Reviewed-by: Shirish Pargaonkar <shirishpargaonkar@gmail.com>
2011-12-08cifs: check for NULL last_entry before calling cifs_save_resume_keyJeff Layton
Prior to commit eaf35b1, cifs_save_resume_key had some NULL pointer checks at the top. It turns out that at least one of those NULL pointer checks is needed after all. When the LastNameOffset in a FIND reply appears to be beyond the end of the buffer, CIFSFindFirst and CIFSFindNext will set srch_inf.last_entry to NULL. Since eaf35b1, the code will now oops in this situation. Fix this by having the callers check for a NULL last entry pointer before calling cifs_save_resume_key. No change is needed for the call site in cifs_readdir as it's not reachable with a NULL current_entry pointer. This should fix: https://bugzilla.redhat.com/show_bug.cgi?id=750247 Cc: stable@vger.kernel.org Cc: Christoph Hellwig <hch@infradead.org> Reported-by: Adam G. Metzler <adamgmetzler@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <smfrench@gmail.com>
2011-07-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: Cleanup: check return codes of crypto api calls CIFS: Fix oops while mounting with prefixpath [CIFS] Redundant null check after dereference cifs: use cifs_dirent in cifs_save_resume_key cifs: use cifs_dirent to replace cifs_get_name_from_search_buf cifs: introduce cifs_dirent cifs: cleanup cifs_filldir
2011-07-25cifs: use cifs_dirent in cifs_save_resume_keyChristoph Hellwig
Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-25cifs: use cifs_dirent to replace cifs_get_name_from_search_bufChristoph Hellwig
This allows us to parse the on the wire structures only once in cifs_filldir. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-25cifs: introduce cifs_direntChristoph Hellwig
Introduce a generic directory entry structure, and factor the parsing of the various on the wire structures that can represent one into a common helper. Switch cifs_entry_is_dot over to use it as a start. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-25cifs: cleanup cifs_filldirChristoph Hellwig
Use sensible variable names and formatting and remove some superflous checks on entry. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-07-20don't open-code parent_ino() in assorted ->readdir()Al Viro
2011-05-27[CIFS] Rename three structures to avoid camel caseSteve French
secMode to sec_mode and cifsTconInfo to cifs_tcon and cifsSesInfo to cifs_ses Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-31cifs: clean up some compiler warningsJeff Layton
New compiler warnings that I noticed when building a patchset based on recent Fedora kernel: fs/cifs/cifssmb.c: In function 'CIFSSMBSetFileSize': fs/cifs/cifssmb.c:4813:8: warning: variable 'data_offset' set but not used [-Wunused-but-set-variable] fs/cifs/file.c: In function 'cifs_open': fs/cifs/file.c:349:24: warning: variable 'pCifsInode' set but not used [-Wunused-but-set-variable] fs/cifs/file.c: In function 'cifs_partialpagewrite': fs/cifs/file.c:1149:23: warning: variable 'cifs_sb' set but not used [-Wunused-but-set-variable] fs/cifs/file.c: In function 'cifs_iovec_write': fs/cifs/file.c:1740:9: warning: passing argument 6 of 'CIFSSMBWrite2' from incompatible pointer type [enabled by default] fs/cifs/cifsproto.h:337:12: note: expected 'unsigned int *' but argument is of type 'size_t *' fs/cifs/readdir.c: In function 'cifs_readdir': fs/cifs/readdir.c:767:23: warning: variable 'cifs_sb' set but not used [-Wunused-but-set-variable] fs/cifs/cifs_dfs_ref.c: In function 'cifs_dfs_d_automount': fs/cifs/cifs_dfs_ref.c:342:2: warning: 'rc' may be used uninitialized in this function [-Wuninitialized] fs/cifs/cifs_dfs_ref.c:278:6: note: 'rc' was declared here Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Pavel Shilovsky <piastry@etersoft.ru> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-12switch cifsAl Viro
2011-01-09cifs: use CreationTime like an i_generation fieldJeff Layton
Reduce false inode collisions by using the CreationTime like an i_generation field. This way, even if the server ends up reusing a uniqueid after a delete/create cycle, we can avoid matching the inode incorrectly. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-01-07fs: dcache reduce branches in lookup pathNick Piggin
Reduce some branches and memory accesses in dcache lookup by adding dentry flags to indicate common d_ops are set, rather than having to check them. This saves a pointer memory access (dentry->d_op) in common path lookup situations, and saves another pointer load and branch in cases where we have d_op but not the particular operation. Patched with: git grep -E '[.>]([[:space:]])*d_op([[:space:]])*=' | xargs sed -e 's/\([^\t ]*\)->d_op = \(.*\);/d_set_d_op(\1, \2);/' -e 's/\([^\t ]*\)\.d_op = \(.*\);/d_set_d_op(\&\1, \2);/' -i Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: change d_hash for rcu-walkNick Piggin
Change d_hash so it may be called from lock-free RCU lookups. See similar patch for d_compare for details. For in-tree filesystems, this is just a mechanical change. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-12-08cifs: remove bogus remapping of error in cifs_filldir()Suresh Jayaraman
As the FIXME points out correctly, now filldir() itself returns -EOVERFLOW if it not possible to represent the inode number supplied by the filesystem in the field provided by userspace. Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-11-13cifs: don't take extra tlink reference in initiate_cifs_searchJeff Layton
It's possible for initiate_cifs_search to be called on a filp that already has private_data attached. If this happens, we'll end up calling cifs_sb_tlink, taking an extra reference to the tlink and attaching that to the cifsFileInfo. This leads to refcount leaks that manifest as a "stuck" cifsd at umount time. Fix this by only looking up the tlink for the cifsFile on the filp's first pass through this function. When called on a filp that already has cifsFileInfo associated with it, just use the tlink reference that it already owns. This patch fixes samba.org bug 7792: https://bugzilla.samba.org/show_bug.cgi?id=7792 Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-and-Tested-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-18cifs: convert GlobalSMBSeslock from a rwlock to regular spinlockJeff Layton
Convert this lock to a regular spinlock A rwlock_t offers little value here. It's more expensive than a regular spinlock unless you have a fairly large section of code that runs under the read lock and can benefit from the concurrency. Additionally, we need to ensure that the refcounting for files isn't racy and to do that we need to lock areas that can increment it for write. That means that the areas that can actually use a read_lock are very few and relatively infrequently used. While we're at it, change the name to something easier to type, and fix a bug in find_writable_file. cifsFileInfo_put can sleep and shouldn't be called while holding the lock. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-15cifs: handle FindFirst failure gracefullySuresh Jayaraman
FindFirst failure due to permission errors or any other errors are silently ignored by cifs_readdir(). This could cause problem to applications that depend on the error to do further processing. Reproducer: - mount a cifs share - mkdir tdir;touch tdir/1 tdir/2 tdir/3 - chmod -x tdir - ls tdir Currently, we start calling filldir() for '.' and '..' before we know we whether FindFirst could succeed or not. If FindFirst fails later, there is no way to notify VFS by setting buf.error and so VFS won't be able to catch this. Fix this by moving the call to initiate_cifs_search() before we start doing filldir(). This fixes https://bugzilla.samba.org/show_bug.cgi?id=7535 Reported-by: Tom Dexter <digitalaudiorock@gmail.com> Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-06cifs: have cifsFileInfo hold a reference to a tlink rather than tcon pointerJeff Layton
cifsFileInfo needs a pointer to a tcon, but it doesn't currently hold a reference to it. Change it to keep a pointer to a tcon_link instead and hold a reference to it. That will keep the tcon from being freed until the file is closed. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-10-06cifs: add refcounted and timestamped container for holding tconsJeff Layton
Eventually, we'll need to track the use of tcons on a per-sb basis, so that we know when it's ok to tear them down. Begin this conversion by adding a new "tcon_link" struct and accessors that get it. For now, the core data structures are untouched -- cifs_sb still just points to a single tcon and the pointers are just cast to deal with the accessor functions. A later patch will flesh this out. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-29cifs: add cifs_sb_master_tcon and convert some callers to use itJeff Layton
At mount time, we'll always need to create a tcon that will serve as a template for others that are associated with the mount. This tcon is known as the "master" tcon. In some cases, we'll need to use that tcon regardless of who's accessing the mount. Add an accessor function for the master tcon and go ahead and switch the appropriate places to use it. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-29cifs: add function to get a tcon from cifs_sbJeff Layton
When we convert cifs to do multiple sessions per mount, we'll need more than one tcon per superblock. At that point "cifs_sb->tcon" will make no sense. Add a new accessor function that gets a tcon given a cifs_sb. For now, it just returns cifs_sb->tcon. Later it'll do more. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-29cifs: make various routines use the cifsFileInfo->tcon pointerJeff Layton
...where it's available and appropriate. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-09-29cifs: use Minshall+French symlink functionsStefan Metzmacher
If configured, Minshall+French Symlinks are used against all servers. If the server supports UNIX Extensions, we still create Minshall+French Symlinks on write, but on read we fallback to UNIX Extension symlinks. Signed-off-by: Stefan Metzmacher <metze@samba.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-08-02fs: cifs: check kmalloc() resultKulikov Vasiliy
If kmalloc() fails exit with -ENOMEM. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Acked-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-04-21[CIFS] Neaten cERROR and cFYI macros, reduce text spaceJoe Perches
Neaten cERROR and cFYI macros, reduce text space ~2.5K Convert '__FILE__ ": " fmt' to '"%s: " fmt', __FILE__' to save text space Surround macros with do {} while Add parentheses to macros Make statement expression macro from macro with assign Remove now unnecessary parentheses from cFYI and cERROR uses defconfig with CIFS support old $ size fs/cifs/built-in.o text data bss dec hex filename 156012 1760 148 157920 268e0 fs/cifs/built-in.o defconfig with CIFS support old $ size fs/cifs/built-in.o text data bss dec hex filename 153508 1760 148 155416 25f18 fs/cifs/built-in.o allyesconfig old: $ size fs/cifs/built-in.o text data bss dec hex filename 309138 3864 74824 387826 5eaf2 fs/cifs/built-in.o allyesconfig new $ size fs/cifs/built-in.o text data bss dec hex filename 305655 3864 74824 384343 5dd57 fs/cifs/built-in.o Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-08cifs: fix dentry hash calculation for case-insensitive mountsJeff Layton
case-insensitive mounts shouldn't use full_name_hash(). Make sure we use the parent dentry's d_hash routine when one is set. Reported-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2010-02-06cifs: fix length calculation for converted unicode readdir namesJeff Layton
cifs_from_ucs2 returns the length of the converted name, including the length of the NULL terminator. We don't want to include the NULL terminator in the dentry name length however since that'll throw off the hash calculation for the dentry cache. I believe that this is the root cause of several problems that have cropped up recently that seem to be papered over with the "noserverino" mount option. More confirmation of that would be good, but this is clearly a bug and it fixes at least one reproducible problem that was reported. This patch fixes at least this reproducer in this kernel.org bug: http://bugzilla.kernel.org/show_bug.cgi?id=15088#c12 Reported-by: Bjorn Tore Sund <bjorn.sund@it.uib.no> Acked-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Cc: stable@kernel.org Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-11-06cifs: clean up handling when server doesn't consistently support inode numbersJeff Layton
It's possible that a server will return a valid FileID when we query the FILE_INTERNAL_INFO for the root inode, but then zeroed out inode numbers when we do a FindFile with an infolevel of SMB_FIND_FILE_ID_FULL_DIR_INFO. In this situation turn off querying for server inode numbers, generate a warning for the user and just generate an inode number using iunique. Once we generate any inode number with iunique we can no longer use any server inode numbers or we risk collisions, so ensure that we don't do that in cifs_get_inode_info either. Cc: Stable <stable@kernel.org> Reported-by: Timothy Normand Miller <theosib@gmail.com> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-09-25[CIFS] Remove build warningSteve French
2009-07-09cifs: convert cifs_get_inode_info and non-posix readdir to use cifs_igetJeff Layton
cifs: convert cifs_get_inode_info and non-posix readdir to use cifs_iget Rather than allocating an inode and filling it out, have cifs_get_inode_info fill out a cifs_fattr and call cifs_iget. This means a pretty hefty reorganization of cifs_get_inode_info. For the readdir codepath, add a couple of new functions for filling out cifs_fattr's from different FindFile response infolevels. Finally, remove cifs_new_inode since there are no more callers. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-07-01cifs: add new cifs_iget function and convert unix codepath to use itJeff Layton
cifs: add new cifs_iget function and convert unix codepath to use it In order to unify some codepaths, introduce a common cifs_fattr struct for storing inode attributes. The different codepaths (unix, legacy, normal, etc...) can fill out this struct with inode info. It can then be passed as an arg to a common set of routines to get and update inodes. Add a new cifs_iget function that uses iget5_locked to identify inodes. This will compare inodes based on the uniqueid value in a cifs_fattr struct. Rather than filling out an already-created inode, have cifs_get_inode_info_unix instead fill out cifs_fattr and hand that off to cifs_iget. cifs_iget can then properly look for hardlinked inodes. On the readdir side, add a new cifs_readdir_lookup function that spawns populated dentries. Redefine FILE_UNIX_INFO so that it's basically a FILE_UNIX_BASIC_INFO that has a few fields wrapped around it. This allows us to more easily use the same function for filling out the fattr as the non-readdir codepath. With this, we should then have proper hardlink detection and can eventually get rid of some nasty CIFS-specific hacks for handing them. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-05-28cifs: make cnvrtDosUnixTm take a little-endian args and an offsetJeff Layton
The callers primarily end up converting the args from le anyway. Also, most of the callers end up needing to add an offset to the result. The exception to these rules is cnvrtDosCifsTm, but there are no callers of that function, so we might as well remove it. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-05-28cifs: have cifs_NTtimeToUnix take a little-endian argJeff Layton
...and just have the function call le64_to_cpu. Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-05-01[CIFS] Remove trailing whitespaceSteve French
2009-05-01[CIFS] Remove sparse endian warningsSteve French
Removes two sparse CHECK_ENDIAN warnings from Jeffs earlier patch, and removes the dead readlink code (after noting where in findfirst we will need to add something like that in the future to handle the newly discovered unexpected error on FindFirst of NTFS symlinks. Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-05-01cifs: fix length handling in cifs_get_name_from_search_bufJeff Layton
The earlier patch to move this code to use the new unicode helpers assumed that the filename strings would be null terminated. That's not always the case. Instead of passing "max_len" to the string converter, pass "min(len, max_len)", which makes it do the right thing while still keeping the parser confined to the response. Also fix up the prototypes of this function and the callers so that max_len is unsigned (like len is). Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-04-30cifs: change cifs_get_name_from_search_buf to use new unicode helperJeff Layton
...and remove cifs_convertUCSpath. There are no more callers. Also add a #define for the buffer used in the readdir path so that we don't have so many magic numbers floating around. Signed-off-by: Jeff Layton <jlayton@redhat.com> Acked-by: Suresh Jayaraman <sjayaraman@suse.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-04-20cifs: Increase size of tmp_buf in cifs_readdir to avoid potential overflowsSuresh Jayaraman
Increase size of tmp_buf to possible maximum to avoid potential overflows. Pointed-out-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Suresh Jayaraman <sjayaraman@suse.de> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-04-17cifs: vary timeout on writes past EOF based on offset (try #5)Jeff Layton
This is the fourth version of this patch: The first three generated a compiler warning asking for explicit curly braces. The first two didn't handle update the size correctly when writes that didn't start at the eof were done. The first patch also didn't update the size correctly when it explicitly set via truncate(). This patch adds code to track the client's current understanding of the size of the file on the server separate from the i_size, and then to use this info to semi-intelligently set the timeout for writes past the EOF. This helps prevent timeouts when trying to write large, sparse files on windows servers. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-04-17[CIFS] Endian convert UniqueId when reporting inode numbers from server filesSteve French
Jeff made a good point that we should endian convert the UniqueId when we use it to set i_ino Even though this value is opaque to the client, when comparing the inode numbers of the same server file from two different clients (one big endian, one little endian) or when we compare a big endian client's view of i_ino with what the server thinks - we should get the same value Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-02-21cifs: properly handle case where CIFSGetSrvInodeNumber failsJeff Layton
...if it does then we pass a pointer to an unintialized variable for the inode number to cifs_new_inode. Have it pass a NULL pointer instead. Also tweak the function prototypes to reduce the amount of casting. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2009-02-21cifs: refactor new_inode() calls and inode initializationJeff Layton
Move new inode creation into a separate routine and refactor the callers to take advantage of it. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-11-20[CIFS] Do not attempt to close invalidated file handlesSteve French
If a connection with open file handles has gone down and come back up and reconnected without reopening the file handle yet, do not attempt to send an SMB close request for this handle in cifs_close. We were checking for the connection being invalid in cifs_close but since the connection may have been reconnected we also need to check whether the file handle was marked invalid (otherwise we could close the wrong file handle by accident). Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-10-21[CIFS] fix saving of resume key before CIFSFindNextJeff Layton
We recently fixed the cifs readdir code so that it saves the resume key before calling CIFSFindNext. Unfortunately, this assumes that we have just done a CIFSFindFirst (or FindNext) and have resume info to save. This isn't necessarily the case. Fix the code to save resume info if we had to reinitiate the search, and after a FindNext. This fixes connectathon basic test6 against NetApp filers. Signed-off-by: Jeff Layton <jlayton@redhat.com> CC: Stable <stable@kernel.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-10-07[CIFS] make sure we have the right resume info before calling CIFSFindNextSteve French
When we do a seekdir() or equivalent, we usually end up doing a FindFirst call and then call FindNext until we get to the offset that we want. The problem is that when we call FindNext, the code usually doesn't have the proper info (mostly, the filename of the entry from the last search) to resume the search. Add a "last_entry" field to the cifs_search_info that points to the last entry in the search. We calculate this pointer by using the LastNameOffset field from the search parms that are returned. We then use that info to do a cifs_save_resume_key before we call CIFSFindNext. This patch allows CIFS to reliably pass the "telldir" connectathon test. Signed-off-by: Jeff Layton <jlayton@redhat.com> CC: Stable <stable@kernel.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-07-24[CIFS] Fix possible double free if search immediately after search rewind failsShirish Pargaonkar
Signed-off-by: Shirish Pargaonkar <shirishp@us.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-23on non-posix shares, clear write bits in mode when ATTR_READONLY is setJeff Layton
When mounting a share with posix extensions disabled, cifs_get_inode_info turns off all the write bits in the mode for regular files if ATTR_READONLY is set. Directories and other inode types, however, can also have ATTR_READONLY set, but the mode gives no indication of this. This patch makes this apply to other inode types besides regular files. It also cleans up how modes are set in cifs_get_inode_info for both the "normal" and "dynperm" cases. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2008-05-23[CIFS] remove unused variablesSteve French
CC: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
