path: root/fs/btrfs
2014-03-23Btrfs: fix data corruption when reading/updating compressed extentsFilipe David Borba Manana
commit a2aa75e18a21b21952dc6daa9bac7c9f4426f81f upstream. When using a mix of compressed file extents and prealloc extents, it is possible to fill a page of a file with random, garbage data from some unrelated previous use of the page, instead of a sequence of zeroes. A simple sequence of steps to get into such case, taken from the test case I made for xfstests, is: _scratch_mkfs _scratch_mount "-o compress-force=lzo" $XFS_IO_PROG -f -c "pwrite -S 0x06 -b 18670 266978 18670" $SCRATCH_MNT/foobar $XFS_IO_PROG -c "falloc 26450 665194" $SCRATCH_MNT/foobar $XFS_IO_PROG -c "truncate 542872" $SCRATCH_MNT/foobar $XFS_IO_PROG -c "fsync" $SCRATCH_MNT/foobar This results in the following file items in the fs tree: item 4 key (257 INODE_ITEM 0) itemoff 15879 itemsize 160 inode generation 6 transid 6 size 542872 block group 0 mode 100600 item 5 key (257 INODE_REF 256) itemoff 15863 itemsize 16 inode ref index 2 namelen 6 name: foobar item 6 key (257 EXTENT_DATA 0) itemoff 15810 itemsize 53 extent data disk byte 0 nr 0 gen 6 extent data offset 0 nr 24576 ram 266240 extent compression 0 item 7 key (257 EXTENT_DATA 24576) itemoff 15757 itemsize 53 prealloc data disk byte 12849152 nr 241664 gen 6 prealloc data offset 0 nr 241664 item 8 key (257 EXTENT_DATA 266240) itemoff 15704 itemsize 53 extent data disk byte 12845056 nr 4096 gen 6 extent data offset 0 nr 20480 ram 20480 extent compression 2 item 9 key (257 EXTENT_DATA 286720) itemoff 15651 itemsize 53 prealloc data disk byte 13090816 nr 405504 gen 6 prealloc data offset 0 nr 258048 The on disk extent at offset 266240 (which corresponds to 1 single disk block), contains 5 compressed chunks of file data. Each of the first 4 compress 4096 bytes of file data, while the last one only compresses 3024 bytes of file data. Therefore a read into the file region [285648 ; 286720[ (length = 4096 - 3024 = 1072 bytes) should always return zeroes (our next extent is a prealloc one). The solution here is the compression code path to zero the remaining (untouched) bytes of the last page it uncompressed data into, as the information about how much space the file data consumes in the last page is not known in the upper layer fs/btrfs/extent_io.c:__do_readpage(). In __do_readpage we were correctly zeroing the remainder of the page but only if it corresponds to the last page of the inode and if the inode's size is not a multiple of the page size. This would cause not only returning random data on reads, but also permanently storing random data when updating parts of the region that should be zeroed. For the example above, it means updating a single byte in the region [285648 ; 286720[ would store that byte correctly but also store random data on disk. A test case for xfstests follows soon. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23Btrfs: fix tree mod loggingFilipe David Borba Manana
commit 5de865eebb8330eee19c37b31fb6f315a09d4273 upstream. While running the test btrfs/004 from xfstests in a loop, it failed about 1 time out of 20 runs in my desktop. The failure happened in the backref walking part of the test, and the test's error message was like this: # btrfs/004 93s ... [failed, exit status 1] - output mismatch (see /home/fdmanana/git/hub/xfstests_2/results//btrfs/004.out.bad) # --- tests/btrfs/004.out 2013-11-26 18:25:29.263333714 +0000 # +++ /home/fdmanana/git/hub/xfstests_2/results//btrfs/004.out.bad 2013-12-10 15:25:10.327518516 +0000 # @@ -1,3 +1,8 @@ # QA output created by 004 # *** test backref walking # -*** done # +unexpected output from # + /home/fdmanana/git/hub/btrfs-progs/btrfs inspect-internal logical-resolve -P 141512704 /home/fdmanana/btrfs-tests/scratch_1 # +expected inum: 405, expected address: 454656, file: /home/fdmanana/btrfs-tests/scratch_1/snap1/p0/d6/d3d/d156/fce, got: # + ... (Run 'diff -u tests/btrfs/004.out /home/fdmanana/git/hub/xfstests_2/results//btrfs/004.out.bad' to see the entire diff) Ran: btrfs/004 Failures: btrfs/004 Failed 1 of 1 tests But immediately after the test finished, the btrfs inspect-internal command returned the expected output: $ btrfs inspect-internal logical-resolve -P 141512704 /home/fdmanana/btrfs-tests/scratch_1 inode 405 offset 454656 root 258 inode 405 offset 454656 root 5 It turned out this was because the btrfs_search_old_slot() calls performed during backref walking (backref.c:__resolve_indirect_ref) were not finding anything. The reason for this turned out to be that the tree mod logging code was not logging some node multi-step operations atomically, therefore btrfs_search_old_slot() callers iterated often over an incomplete tree that wasn't fully consistent with any tree state from the past. Besides missing items, this often (but not always) resulted in -EIO errors during old slot searches, reported in dmesg like this: [ 4299.933936] ------------[ cut here ]------------ [ 4299.933949] WARNING: CPU: 0 PID: 23190 at fs/btrfs/ctree.c:1343 btrfs_search_old_slot+0x57b/0xab0 [btrfs]() [ 4299.933950] Modules linked in: btrfs raid6_pq xor pci_stub vboxpci(O) vboxnetadp(O) vboxnetflt(O) vboxdrv(O) bnep rfcomm bluetooth parport_pc ppdev binfmt_misc joydev snd_hda_codec_h [ 4299.933977] CPU: 0 PID: 23190 Comm: btrfs Tainted: G W O 3.12.0-fdm-btrfs-next-16+ #70 [ 4299.933978] Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./Z77 Pro4, BIOS P1.50 09/04/2012 [ 4299.933979] 000000000000053f ffff8806f3fd98f8 ffffffff8176d284 0000000000000007 [ 4299.933982] 0000000000000000 ffff8806f3fd9938 ffffffff8104a81c ffff880659c64b70 [ 4299.933984] ffff880659c643d0 ffff8806599233d8 ffff880701e2e938 0000160000000000 [ 4299.933987] Call Trace: [ 4299.933991] [<ffffffff8176d284>] dump_stack+0x55/0x76 [ 4299.933994] [<ffffffff8104a81c>] warn_slowpath_common+0x8c/0xc0 [ 4299.933997] [<ffffffff8104a86a>] warn_slowpath_null+0x1a/0x20 [ 4299.934003] [<ffffffffa065d3bb>] btrfs_search_old_slot+0x57b/0xab0 [btrfs] [ 4299.934005] [<ffffffff81775f3b>] ? _raw_read_unlock+0x2b/0x50 [ 4299.934010] [<ffffffffa0655001>] ? __tree_mod_log_search+0x81/0xc0 [btrfs] [ 4299.934019] [<ffffffffa06dd9b0>] __resolve_indirect_refs+0x130/0x5f0 [btrfs] [ 4299.934027] [<ffffffffa06a21f1>] ? free_extent_buffer+0x61/0xc0 [btrfs] [ 4299.934034] [<ffffffffa06de39c>] find_parent_nodes+0x1fc/0xe40 [btrfs] [ 4299.934042] [<ffffffffa06b13e0>] ? defrag_lookup_extent+0xe0/0xe0 [btrfs] [ 4299.934048] [<ffffffffa06b13e0>] ? defrag_lookup_extent+0xe0/0xe0 [btrfs] [ 4299.934056] [<ffffffffa06df980>] iterate_extent_inodes+0xe0/0x250 [btrfs] [ 4299.934058] [<ffffffff817762db>] ? _raw_spin_unlock+0x2b/0x50 [ 4299.934065] [<ffffffffa06dfb82>] iterate_inodes_from_logical+0x92/0xb0 [btrfs] [ 4299.934071] [<ffffffffa06b13e0>] ? defrag_lookup_extent+0xe0/0xe0 [btrfs] [ 4299.934078] [<ffffffffa06b7015>] btrfs_ioctl+0xf65/0x1f60 [btrfs] [ 4299.934080] [<ffffffff811658b8>] ? handle_mm_fault+0x278/0xb00 [ 4299.934083] [<ffffffff81075563>] ? up_read+0x23/0x40 [ 4299.934085] [<ffffffff8177a41c>] ? __do_page_fault+0x20c/0x5a0 [ 4299.934088] [<ffffffff811b2946>] do_vfs_ioctl+0x96/0x570 [ 4299.934090] [<ffffffff81776e23>] ? error_sti+0x5/0x6 [ 4299.934093] [<ffffffff810b71e8>] ? trace_hardirqs_off_caller+0x28/0xd0 [ 4299.934096] [<ffffffff81776a09>] ? retint_swapgs+0xe/0x13 [ 4299.934098] [<ffffffff811b2eb1>] SyS_ioctl+0x91/0xb0 [ 4299.934100] [<ffffffff813eecde>] ? trace_hardirqs_on_thunk+0x3a/0x3f [ 4299.934102] [<ffffffff8177ef12>] system_call_fastpath+0x16/0x1b [ 4299.934102] [<ffffffff8177ef12>] system_call_fastpath+0x16/0x1b [ 4299.934104] ---[ end trace 48f0cfc902491414 ]--- [ 4299.934378] btrfs bad fsid on block 0 These tree mod log operations that must be performed atomically, tree_mod_log_free_eb, tree_mod_log_eb_copy, tree_mod_log_insert_root and tree_mod_log_insert_move, used to be performed atomically before the following commit: c8cc6341653721b54760480b0d0d9b5f09b46741 (Btrfs: stop using GFP_ATOMIC for the tree mod log allocations) That change removed the atomicity of such operations. This patch restores the atomicity while still not doing the GFP_ATOMIC allocations of tree_mod_elem structures, so it has to do the allocations using GFP_NOFS before acquiring the mod log lock. This issue has been experienced by several users recently, such as for example: http://www.spinics.net/lists/linux-btrfs/msg28574.html After running the btrfs/004 test for 679 consecutive iterations with this patch applied, I didn't ran into the issue anymore. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-23Btrfs: return immediately if tree log mod is not necessaryFilipe David Borba Manana
commit 783577663507411e36e459390ef056556e93ef29 upstream. In ctree.c:tree_mod_log_set_node_key() we were calling __tree_mod_log_insert_key() even when the modification doesn't need to be logged. This would allocate a tree_mod_elem structure, fill it and pass it to __tree_mod_log_insert(), which would just acquire the tree mod log write lock and then free the tree_mod_elem structure and return (that is, a no-op). Therefore call tree_mod_log_insert() instead of __tree_mod_log_insert() which just returns immediately if the modification doesn't need to be logged (without allocating the structure, fill it, acquire write lock, free structure). Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-03-06fs: fix iversion handlingChristoph Hellwig
commit dff6efc326a4d5f305797d4a6bba14f374fdd633 upstream. Currently notify_change directly updates i_version for size updates, which not only is counter to how all other fields are updated through struct iattr, but also breaks XFS, which need inode updates to happen under its own lock, and synchronized to the structure that gets written to the log. Remove the update in the common code, and it to btrfs and ext4, XFS already does a proper updaste internally and currently gets a double update with the existing code. IMHO this is 3.13 and -stable material and should go in through the XFS tree. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Andreas Dilger <adilger@dilger.ca> Acked-by: Jan Kara <jack@suse.cz> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: Ben Myers <bpm@sgi.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-20Btrfs: disable snapshot aware defrag for nowJosef Bacik
commit 8101c8dbf6243ba517aab58d69bf1bc37d8b7b9c upstream. It's just broken and it's taking a lot of effort to fix it, so for now just disable it so people can defrag in peace. Thanks, Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-06btrfs: restrict snapshotting to own subvolumesDavid Sterba
commit d024206133ce21936b3d5780359afc00247655b7 upstream. Currently, any user can snapshot any subvolume if the path is accessible and thus indirectly create and keep files he does not own under his direcotries. This is not possible with traditional directories. In security context, a user can snapshot root filesystem and pin any potentially buggy binaries, even if the updates are applied. All the snapshots are visible to the administrator, so it's possible to verify if there are suspicious snapshots. Another more practical problem is that any user can pin the space used by eg. root and cause ENOSPC. Original report: https://bugs.launchpad.net/ubuntu/+source/apparmor/+bug/484786 Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-06Btrfs: setup inode location during btrfs_init_inode_lockedChris Mason
commit 90d3e592e99b8e374ead2b45148abf506493a959 upstream. We have a race during inode init because the BTRFS_I(inode)->location is setup after the inode hash table lock is dropped. btrfs_find_actor uses the location field, so our search might not find an existing inode in the hash table if we race with the inode init code. This commit changes things to setup the location field sooner. Also the find actor now uses only the location objectid to match inodes. For inode hashing, we just need a unique and stable test, it doesn't have to reflect the inode numbers we show to userland. Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-06Btrfs: handle EAGAIN case properly in btrfs_drop_snapshot()Wang Shilong
commit 90515e7f5d7d24cbb2a4038a3f1b5cfa2921aa17 upstream. We may return early in btrfs_drop_snapshot(), we shouldn't call btrfs_std_err() for this case, fix it. Signed-off-by: Wang Shilong <wangsl.fnst@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fb.com> Signed-off-by: Chris Mason <clm@fb.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-12-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "This is a small collection of fixes. It was rebased this morning, but I was just fixing signed-off-by tags with the wrong email" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: fix access_ok() check in btrfs_ioctl_send() Btrfs: make sure we cleanup all reloc roots if error happens Btrfs: skip building backref tree for uuid and quota tree when doing balance relocation Btrfs: fix an oops when doing balance relocation Btrfs: don't miss skinny extent items on delayed ref head contention btrfs: call mnt_drop_write after interrupted subvol deletion Btrfs: don't clear the default compression type
2013-12-12Btrfs: fix access_ok() check in btrfs_ioctl_send()Dan Carpenter
The closing parenthesis is in the wrong place. We want to check "sizeof(*arg->clone_sources) * arg->clone_sources_count" instead of "sizeof(*arg->clone_sources * arg->clone_sources_count)". Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Jie Liu <jeff.liu@oracle.com> Signed-off-by: Chris Mason <clm@fb.com> cc: stable@vger.kernel.org
2013-12-12Btrfs: make sure we cleanup all reloc roots if error happensWang Shilong
I hit an oops when merging reloc roots fails, the reason is that new reloc roots may be added and we should make sure we cleanup all reloc roots. Signed-off-by: Wang Shilong <wangsl.fnst@cn.fujitsu.com> Signed-off-by: Chris Mason <clm@fb.com>
2013-12-12Btrfs: skip building backref tree for uuid and quota tree when doing balance ↵Wang Shilong
relocation Quota tree and UUID Tree is only cowed, they can not be snapshoted. Signed-off-by: Wang Shilong <wangsl.fnst@cn.fujitsu.com> Signed-off-by: Chris Mason <clm@fb.com>
2013-12-12Btrfs: fix an oops when doing balance relocationWang Shilong
I hit an oops when inserting reloc root into @reloc_root_tree(it can be easily triggered when forcing cow for relocation root) [ 866.494539] [<ffffffffa0499579>] btrfs_init_reloc_root+0x79/0xb0 [btrfs] [ 866.495321] [<ffffffffa044c240>] record_root_in_trans+0xb0/0x110 [btrfs] [ 866.496109] [<ffffffffa044d758>] btrfs_record_root_in_trans+0x48/0x80 [btrfs] [ 866.496908] [<ffffffffa0494da8>] select_reloc_root+0xa8/0x210 [btrfs] [ 866.497703] [<ffffffffa0495c8a>] do_relocation+0x16a/0x540 [btrfs] This is because reloc root inserted into @reloc_root_tree is not within one transaction,reloc root may be cowed and root block bytenr will be reused then oops happens.We should update reloc root in @reloc_root_tree when cow reloc root node, fix it. Signed-off-by: Wang Shilong <wangsl.fnst@cn.fujitsu.com> Reviewed-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Chris Mason <clm@fb.com>
2013-12-12Btrfs: don't miss skinny extent items on delayed ref head contentionFilipe David Borba Manana
Currently extent-tree.c:btrfs_lookup_extent_info() can miss the lookup of skinny extent items. This can happen when the execution flow is the following: * We do an extent tree lookup and fail to find a skinny extent item; * As a result, we attempt to see if a non-skinny extent item exists, either by looking at previous item in the leaf or by doing another full extent tree search; * We have a transaction and then we check for a matching delayed ref head in the transaction's delayed refs rbtree; * We find such delayed ref head and then we try to lock it with a call to mutex_trylock(); * The lock was contended so we jump to the label "again", which repeats the extent tree search but for a non-skinny extent item, because we set previously metadata variable to 0 and the search key to look for a non-skinny extent-item; * After the jump (and after releasing the transaction's delayed refs lock), a skinny extent item might have been added to the extent tree but we will miss it because metadata is set to 0 and the search key is set for a non-skinny extent-item. The fix here is to not reset metadata to 0 and to jump to the initial search key setup if the delayed ref head is contended, instead of jumping directly to the extent tree search label ("again"). This issue was found while investigating the issue reported at Bugzilla 64961. David Sterba suspected this function was missing extent items, and that this could be caused by the last change to this function, which was made in the following patch: [PATCH] Btrfs: optimize btrfs_lookup_extent_info() (commit 74be9510876a66ad9826613ac8a526d26f9e7f01) But in fact this issue already existed before, because after failing to find a skinny extent item, the code set the search key for a non-skinny extent item, and on contention of a matching delayed ref head it would not search the extent tree for a skinny extent item anymore. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Reviewed-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Chris Mason <clm@fb.com>
2013-12-12btrfs: call mnt_drop_write after interrupted subvol deletionDavid Sterba
If btrfs_ioctl_snap_destroy blocks on the mutex and the process is killed, mnt_write count is unbalanced and leads to unmountable filesystem. CC: stable@vger.kernel.org Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <clm@fb.com>
2013-12-12Btrfs: don't clear the default compression typeMiao Xie
We met a oops caused by the wrong compression type: [ 556.512356] BUG: unable to handle kernel NULL pointer dereference at (null) [ 556.512370] IP: [<ffffffff811dbaa0>] __list_del_entry+0x1/0x98 [SNIP] [ 556.512490] [<ffffffff811dbb44>] ? list_del+0xd/0x2b [ 556.512539] [<ffffffffa05dd5ce>] find_workspace+0x97/0x175 [btrfs] [ 556.512546] [<ffffffff813c14b5>] ? _raw_spin_lock+0xe/0x10 [ 556.512576] [<ffffffffa05de276>] btrfs_compress_pages+0x2d/0xa2 [btrfs] [ 556.512601] [<ffffffffa05af060>] compress_file_range.constprop.54+0x1f2/0x4e8 [btrfs] [ 556.512627] [<ffffffffa05af388>] async_cow_start+0x32/0x4d [btrfs] [ 556.512655] [<ffffffffa05cc7a1>] worker_loop+0x144/0x4c3 [btrfs] [ 556.512661] [<ffffffff81059404>] ? finish_task_switch+0x80/0xb8 [ 556.512689] [<ffffffffa05cc65d>] ? btrfs_queue_worker+0x244/0x244 [btrfs] [ 556.512695] [<ffffffff8104fa4e>] kthread+0x8d/0x95 [ 556.512699] [<ffffffff81050000>] ? bit_waitqueue+0x34/0x7d [ 556.512704] [<ffffffff8104f9c1>] ? __kthread_parkme+0x65/0x65 [ 556.512709] [<ffffffff813c7eec>] ret_from_fork+0x7c/0xb0 [ 556.512713] [<ffffffff8104f9c1>] ? __kthread_parkme+0x65/0x65 Steps to reproduce: # mkfs.btrfs -f <dev> # mount -o nodatacow <dev> <mnt> # touch <mnt>/<file> # chattr =c <mnt>/<file> # dd if=/dev/zero of=<mnt>/<file> bs=1M count=10 It is because we cleared the default compression type when setting the nodatacow. In fact, we needn't do it because we have used COMPRESS flag to indicate if we need compressed the file data or not, needn't use the variant -- compress_type -- in btrfs_info to do the same thing, and just use it to hold the default compression type. Or we would get a wrong compress type for a file whose own compress flag is set but the compress flag of its filesystem is not set. Reported-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Reviewed-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Chris Mason <clm@fb.com>
2013-12-05Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block layer fixes from Jens Axboe: "A small collection of fixes for the current series. It contains: - A fix for a use-after-free of a request in blk-mq. From Ming Lei - A fix for a blk-mq bug that could attempt to dereference a NULL rq if allocation failed - Two xen-blkfront small fixes - Cleanup of submit_bio_wait() type uses in the kernel, unifying that. From Kent - A fix for 32-bit blkg_rwstat reading. I apologize for this one looking mangled in the shortlog, it's entirely my fault for missing an empty line between the description and body of the text" * 'for-linus' of git://git.kernel.dk/linux-block: blk-mq: fix use-after-free of request blk-mq: fix dereference of rq->mq_ctx if allocation fails block: xen-blkfront: Fix possible NULL ptr dereference xen-blkfront: Silence pfn maybe-uninitialized warning block: submit_bio_wait() conversions Update of blkg_stat and blkg_rwstat may happen in bh context
2013-11-24block: submit_bio_wait() conversionsKent Overstreet
It was being open coded in a few places. Signed-off-by: Kent Overstreet <kmo@daterainc.com> Cc: Jens Axboe <axboe@kernel.dk> Cc: Joern Engel <joern@logfs.org> Cc: Prasad Joshi <prasadjoshi.linux@gmail.com> Cc: Neil Brown <neilb@suse.de> Cc: Chris Mason <chris.mason@fusionio.com> Acked-by: NeilBrown <neilb@suse.de> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2013-11-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "Almost all of these are bug fixes. Dave Sterba's documentation update is the big exception because he removed our promises to set any machine running Btrfs on fire" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Documentation: filesystems: update btrfs tools section Documentation: filesystems: add new btrfs mount options btrfs: update kconfig help text btrfs: fix bio_size_ok() for max_sectors > 0xffff btrfs: Use trace condition for get_extent tracepoint btrfs: fix typo in the log message Btrfs: fix list delete warning when removing ordered root from the list Btrfs: print bytenr instead of page pointer in check-int Btrfs: remove dead codes from ctree.h Btrfs: don't wait for ordered data outside desired range Btrfs: fix lockdep error in async commit Btrfs: avoid heavy operations in btrfs_commit_super Btrfs: fix __btrfs_start_workers retval Btrfs: disable online raid-repair on ro mounts Btrfs: do not inc uncorrectable_errors counter on ro scrubs Btrfs: only drop modified extents if we logged the whole inode Btrfs: make sure to copy everything if we rename Btrfs: don't BUG_ON() if we get an error walking backrefs
2013-11-20btrfs: update kconfig help textDavid Sterba
Reflect the current status. Portions of the text taken from the wiki pages. Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-20btrfs: fix bio_size_ok() for max_sectors > 0xffffAkinobu Mita
The data type of max_sectors in queue settings is unsigned int. But this value is stored to the local variable whose type is unsigned short in bio_size_ok(). This can cause unexpected result when max_sectors > 0xffff. Cc: Chris Mason <chris.mason@fusionio.com> Cc: linux-btrfs@vger.kernel.org Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-20btrfs: Use trace condition for get_extent tracepointSteven Rostedt
Doing an if statement to test some condition to know if we should trigger a tracepoint is pointless when tracing is disabled. This just adds overhead and wastes a branch prediction. This is why the TRACE_EVENT_CONDITION() was created. It places the check inside the jump label so that the branch does not happen unless tracing is enabled. That is, instead of doing: if (em) trace_btrfs_get_extent(root, em); Which is basically this: if (em) if (static_key(trace_btrfs_get_extent)) { Using a TRACE_EVENT_CONDITION() we can just do: trace_btrfs_get_extent(root, em); And the condition trace event will do: if (static_key(trace_btrfs_get_extent)) { if (em) { ... The static key is a non conditional jump (or nop) that is faster than having to check if em is NULL or not. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-20btrfs: fix typo in the log messageAnand Jain
Signed-off-by: Anand Jain <anand.jain@oracle.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-20Btrfs: fix list delete warning when removing ordered root from the listMiao Xie
Commit b02441999efcc6152b87cd58e7970bb7843f76cf "Btrfs: don't wait for the completion of all the ordered extents" introduced a bug that broke the ordered root list: WARNING: CPU: 1 PID: 7119 at lib/list_debug.c:59 __list_del_entry+0x5a/0x98() It is because we forgot to return the roots in the splice list to the ordered list of the fs. Fix it. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-20Btrfs: print bytenr instead of page pointer in check-intStefan Behrens
The page pointer information was useless. The bytenr is what you want when you search for submitted write bios. Additionally, a new bit in the print mask is added that allows to selectively enable the check-int submit_bio verbose mode. Before, the global verbose mode had to be enabled leading to many million useless lines in the kernel log. And a comment is added that explains that LOG_BUF_SHIFT needs to be set to a really high value. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-20Btrfs: remove dead codes from ctree.hWang Shilong
These two functions are only stated but undefined. Signed-off-by: Wang Shilong <wangsl.fnst@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-20Btrfs: don't wait for ordered data outside desired rangeFilipe David Borba Manana
In btrfs_wait_ordered_range(), if we found an extent to the left of the start of our desired wait range and the last byte of that extent is 1 less than the desired range's start, we would would wait for the IO completion of that extent unnecessarily. Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-20Btrfs: fix lockdep error in async commitLiu Bo
Lockdep complains about btrfs's async commit: [ 2372.462171] [ BUG: bad unlock balance detected! ] [ 2372.462191] 3.12.0+ #32 Tainted: G W [ 2372.462209] ------------------------------------- [ 2372.462228] ceph-osd/14048 is trying to release lock (sb_internal) at: [ 2372.462275] [<ffffffffa022cb10>] btrfs_commit_transaction_async+0x1b0/0x2a0 [btrfs] [ 2372.462305] but there are no more locks to release! [ 2372.462324] [ 2372.462324] other info that might help us debug this: [ 2372.462349] no locks held by ceph-osd/14048. [ 2372.462367] [ 2372.462367] stack backtrace: [ 2372.462386] CPU: 2 PID: 14048 Comm: ceph-osd Tainted: G W 3.12.0+ #32 [ 2372.462414] Hardware name: To Be Filled By O.E.M. To Be Filled By O.E.M./To be filled by O.E.M., BIOS 080015 11/09/2011 [ 2372.462455] ffffffffa022cb10 ffff88007490fd28 ffffffff816f094a ffff8800378aa320 [ 2372.462491] ffff88007490fd50 ffffffff810adf4c ffff8800378aa320 ffff88009af97650 [ 2372.462526] ffffffffa022cb10 ffff88007490fd88 ffffffff810b01ee ffff8800898c0000 [ 2372.462562] Call Trace: [ 2372.462584] [<ffffffffa022cb10>] ? btrfs_commit_transaction_async+0x1b0/0x2a0 [btrfs] [ 2372.462619] [<ffffffff816f094a>] dump_stack+0x45/0x56 [ 2372.462642] [<ffffffff810adf4c>] print_unlock_imbalance_bug+0xec/0x100 [ 2372.462677] [<ffffffffa022cb10>] ? btrfs_commit_transaction_async+0x1b0/0x2a0 [btrfs] [ 2372.462710] [<ffffffff810b01ee>] lock_release+0x18e/0x210 [ 2372.462742] [<ffffffffa022cb36>] btrfs_commit_transaction_async+0x1d6/0x2a0 [btrfs] [ 2372.462783] [<ffffffffa025a7ce>] btrfs_ioctl_start_sync+0x3e/0xc0 [btrfs] [ 2372.462822] [<ffffffffa025f1d3>] btrfs_ioctl+0x4c3/0x1f70 [btrfs] [ 2372.462849] [<ffffffff812c0321>] ? avc_has_perm+0x121/0x1b0 [ 2372.462873] [<ffffffff812c0224>] ? avc_has_perm+0x24/0x1b0 [ 2372.462897] [<ffffffff8107ecc8>] ? sched_clock_cpu+0xa8/0x100 [ 2372.462922] [<ffffffff8117b145>] do_vfs_ioctl+0x2e5/0x4e0 [ 2372.462946] [<ffffffff812c19e6>] ? file_has_perm+0x86/0xa0 [ 2372.462969] [<ffffffff8117b3c1>] SyS_ioctl+0x81/0xa0 [ 2372.462991] [<ffffffff817045a4>] tracesys+0xdd/0xe2 ==================================================== It's because that we don't do the right thing when checking if it's ok to tell lockdep that we're trying to release the rwsem. If the trans handle's type is TRANS_ATTACH, we won't acquire the freeze rwsem, but as TRANS_ATTACH fits the check (trans < TRANS_JOIN_NOLOCK), we'll release the freeze rwsem, which makes lockdep complains a lot. Reported-by: Ma Jianpeng <majianpeng@gmail.com> Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-20Btrfs: avoid heavy operations in btrfs_commit_superLiu Bo
The 'git blame' history shows that, the old transaction commit code has to do twice to ensure roots are updated and we have to flush metadata and super block manually, however, right now all of these can be handled well inside the transaction commit code without extra efforts. And the error handling part remains same with the current code, -- 'return to caller once we get error'. This saves us a transaction commit and a flush of super block, which are both heavy operations according to ftrace output analysis. Signed-off-by: Liu Bo <bo.li.liu@oracle.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-20Btrfs: fix __btrfs_start_workers retvalIlya Dryomov
__btrfs_start_workers returns 0 in case it raced with btrfs_stop_workers and lost the race. This is wrong because worker in this case is not allowed to start and is in fact destroyed. Return -EINVAL instead. Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-20Btrfs: disable online raid-repair on ro mountsIlya Dryomov
This disables the "if needed, write the good copy back before the read is completed" part of the read sequence for read-only mounts. Cc: Jan Schmidt <list.btrfs@jan-o-sch.net> Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-20Btrfs: do not inc uncorrectable_errors counter on ro scrubsIlya Dryomov
Currently if we discover an error when scrubbing in ro mode we a) blindly increment the uncorrectable_errors counter, and b) spam the dmesg with the 'unable to fixup (regular) error at ...' message, even though a) we haven't tried to determine if the error is correctable or not, and b) we haven't tried to fixup anything. Fix this. Cc: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-20Btrfs: only drop modified extents if we logged the whole inodeJosef Bacik
If we fsync, seek and write, rename and then fsync again we will lose the modified hole extent because the rename will drop all of the modified extents since we didn't do the fast search. We need to only drop the modified extents if we didn't do the fast search and we were logging the entire inode as we don't need them anymore, otherwise this is being premature. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-20Btrfs: make sure to copy everything if we renameJosef Bacik
If we rename a file that is already in the log and we fsync again we will lose the new name. This is because we just log the inode update and not the new ref. To fix this we just need to check if we are logging the new name of the inode and copy all the metadata instead of just updating the inode itself. With this patch my testcase now passes. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-20Btrfs: don't BUG_ON() if we get an error walking backrefsJosef Bacik
We can just return false for this so we stop doing the snapshot aware defrag stuff. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "This pull fixes the empty_zero_page bug that Heiko reported, and includes one more cleanup from Al Viro" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: btrfs: get rid of fdentry() btrfs: fix empty_zero_page misusage
2013-11-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree updates from Jiri Kosina: "Usual earth-shaking, news-breaking, rocket science pile from trivial.git" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits) doc: usb: Fix typo in Documentation/usb/gadget_configs.txt doc: add missing files to timers/00-INDEX timekeeping: Fix some trivial typos in comments mm: Fix some trivial typos in comments irq: Fix some trivial typos in comments NUMA: fix typos in Kconfig help text mm: update 00-INDEX doc: Documentation/DMA-attributes.txt fix typo DRM: comment: `halve' -> `half' Docs: Kconfig: `devlopers' -> `developers' doc: typo on word accounting in kprobes.c in mutliple architectures treewide: fix "usefull" typo treewide: fix "distingush" typo mm/Kconfig: Grammar s/an/a/ kexec: Typo s/the/then/ Documentation/kvm: Update cpuid documentation for steal time and pv eoi treewide: Fix common typo in "identify" __page_to_pfn: Fix typo in comment Correct some typos for word frequency clk: fixed-factor: Fix a trivial typo ...
2013-11-15btrfs: get rid of fdentry()Al Viro
3 of 4 callers actually want file_inode()... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-15btrfs: fix empty_zero_page misusageChris Mason
Heiko Carstens noticed that btrfs was using empty_zero_page incorrectly. He explained: The definition of empty_zero_page is architecture specific. It is (currently) either a character array, an unsigned long containing the address of the empty_zero_page, or even worse only the address of the struct page belonging to the empty_zero_page. This commit changes btrfs to use a for-loop instead. On x86 the resulting .ko is smaller, and we're no longer worrying about how each arch builds its zeros. Reported-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: rename btrfs_start_all_delalloc_inodesMiao Xie
rename the function -- btrfs_start_all_delalloc_inodes(), and make its name be compatible to btrfs_wait_ordered_roots(), since they are always used at the same place. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: don't wait for the completion of all the ordered extentsMiao Xie
It is very likely that there are lots of ordered extents in the filesytem, if we wait for the completion of all of them when we want to reclaim some space for the metadata space reservation, we would be blocked for a long time. The performance would drop down suddenly for a long time. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: don't wait for all the async delalloc when shrinking delallocMiao Xie
It was very likely that there were lots of async delalloc pages in the filesystem, if we waited until all the pages were flushed, we would be blocked for a long time, and the performance would also drop down. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: fix the confusion between delalloc bytes and metadata bytesMiao Xie
In shrink_delalloc(), what we need reclaim is the metadata space, so flushing pages by to_reclaim is not reasonable, it is very likely that the pages we flush are not enough. And then we had to invoke the flush function for several times, at the worst, we need call flush_space for several times. It wasted time. We improve this problem by converting the metadata space size we need reserve to the delalloc bytes, By this way, we can flush the pages by a reasonable number. (Now we use a fixed number to do conversion, it is not flexible, maybe we can find a good way to improve it in the future.) Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: pick up the code for the item number calculation in flush_space()Miao Xie
This patch picked up the code that was used to calculate the number of the items for which we need reserve space, and we will use it in the next patch. Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: wait for the ordered extent only when we wantMiao Xie
2013-11-11Btrfs: remove unnecessary initialization and memory barrior in shrink_delalloc()Miao Xie
2013-11-11Btrfs: avoid unnecessary scrub workers allocationWang Shilong
We only allocate scrub workers if we pass all the necessary checks, for example, there are no operation in progress. Besides, move mutex lock protection outside of scrub_workers_get() /scrub_workers_put(). Signed-off-by: Wang Shilong <wangsl.fnst@cn.fujitsu.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11Btrfs: check file extent type before anything elseJosef Bacik
I hit this problem with my no holes patch and it made me realize what the problem was for bz 60834. If the first item in the leaf is an inline extent and we try to read anything starting from disk_bytenr onward we will read off the end of the leaf. So we need to check to see what it's type is, and if it's not REG we can just break out. This should fix this problem. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11btrfs: Remove useless variable in write_ctree_super()Rashika
The function write_ctree_super() in disk-io.c uses variable ret to return the result of function write_all_supers(). Since, this variable serves no purpose, hence the patch removes it and returns the call of the called function. Reviewed-by: Zach Brown <zab@redhat.com> Signed-off-by: Rashika Kheria <rashika.kheria@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
2013-11-11btrfs: Fix checkpatch.pl warning of spacing issuesDulshani Gunawardhana
Fix spacing issues detected via checkpatch.pl in accordance with the kernel style guidelines. Signed-off-by: Dulshani Gunawardhana <dulshani.gunawardhana89@gmail.com> Signed-off-by: Josef Bacik <jbacik@fusionio.com> Signed-off-by: Chris Mason <chris.mason@fusionio.com>
