path: root/fs/btrfs/volumes.c
2012-08-29Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "I've split out the big send/receive update from my last pull request and now have just the fixes in my for-linus branch. The send/recv branch will wander over to linux-next shortly though. The largest patches in this pull are Josef's patches to fix DIO locking problems and his patch to fix a crash during balance. They are both well tested. The rest are smaller fixes that we've had queued. The last rc came out while I was hacking new and exciting ways to recover from a misplaced rm -rf on my dev box, so these missed rc3." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (25 commits) Btrfs: fix that repair code is spuriously executed for transid failures Btrfs: fix ordered extent leak when failing to start a transaction Btrfs: fix a dio write regression Btrfs: fix deadlock with freeze and sync V2 Btrfs: revert checksum error statistic which can cause a BUG() Btrfs: remove superblock writing after fatal error Btrfs: allow delayed refs to be merged Btrfs: fix enospc problems when deleting a subvol Btrfs: fix wrong mtime and ctime when creating snapshots Btrfs: fix race in run_clustered_refs Btrfs: don't run __tree_mod_log_free_eb on leaves Btrfs: increase the size of the free space cache Btrfs: barrier before waitqueue_active Btrfs: fix deadlock in wait_for_more_refs btrfs: fix second lock in btrfs_delete_delayed_items() Btrfs: don't allocate a seperate csums array for direct reads Btrfs: do not strdup non existent strings Btrfs: do not use missing devices when showing devname Btrfs: fix that error value is changed by mistake Btrfs: lock extents as we map them in DIO ...
2012-08-28Btrfs: revert checksum error statistic which can cause a BUG()Stefan Behrens
Commit 442a4f6308e694e0fa6025708bd5e4e424bbf51c added btrfs device statistic counters for detected IO and checksum errors to Linux 3.5. The statistic part that counts checksum errors in end_bio_extent_readpage() can cause a BUG() in a subfunction: "kernel BUG at fs/btrfs/volumes.c:3762!" That part is reverted with the current patch. However, the counting of checksum errors in the scrub context remains active, and the counting of detected IO errors (read, write or flush errors) in all contexts remains active. Cc: stable <stable@vger.kernel.org> # 3.5 Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2012-08-28Btrfs: barrier before waitqueue_activeJosef Bacik
We need a barrir before calling waitqueue_active otherwise we will miss wakeups. So in places that do atomic_dec(); then atomic_read() use atomic_dec_return() which imply a memory barrier (see memory-barriers.txt) and then add an explicit memory barrier everywhere else that need them. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2012-08-28Btrfs: do not strdup non existent stringsJosef Bacik
When we close devices we add back empty devices for some reason that escapes me. In the case of a missing dev we don't allocate an rcu_string for it's name, so check to see if the device has a name and if it doesn't don't bother strdup()'ing it. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2012-08-04btrfs: nuke write_super from commentsArtem Bityutskiy
The '->write_super' superblock method is gone, and this patch removes all the references to 'write_super' from btrfs. Cc: Chris Mason <chris.mason@fusionio.com> Cc: linux-btrfs@vger.kernel.org Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-23Btrfs: suppress printk() if all device I/O stats are zeroStefan Behrens
Code is added to suppress the I/O stats printing at mount time if all statistic values are zero. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de>
2012-07-23Btrfs: remove unwanted printk() for btrfs device I/O statsStefan Behrens
People complained about the annoying kernel log message "btrfs: no dev_stats entry found ... (OK on first mount after mkfs)" everytime a filesystem is mounted for the first time after running mkfs. Since the distribution of the btrfs-progs is not synchronized to the kernel version, mkfs like it is now will be used also in the future. Then this message is not useful to find errors, it is just annoying. This commit removes the printk(). Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de>
2012-07-23Btrfs: add DEVICE_READY ioctlJosef Bacik
This will be used in conjunction with btrfs device ready <dev>. This is needed for initrd's to have a nice and lightweight way to tell if all of the devices needed for a file system are in the cache currently. This keeps them from having to do mount+sleep loops waiting for devices to show up. Thanks, Signed-off-by: Josef Bacik <jbacik@fusionio.com>
2012-07-23btrfs: join DEV_STATS ioctls to oneDavid Sterba
Commit c11d2c236cc260b36 (Btrfs: add ioctl to get and reset the device stats) introduced two ioctls doing almost the same thing distinguished by just the ioctl number which encodes "do reset after read". I have suggested http://www.mail-archive.com/linux-btrfs@vger.kernel.org/msg16604.html to implement it via the ioctl args. This hasn't happen, and I think we should use a more clean way to pass flags and should not waste ioctl numbers. CC: Stefan Behrens <sbehrens@giantdisaster.de> Signed-off-by: David Sterba <dsterba@suse.cz>
2012-07-02Btrfs: resume balance on rw (re)mounts properlyIlya Dryomov
This introduces btrfs_resume_balance_async(), which, given that restriper state was recovered earlier by btrfs_recover_balance(), resumes balance in btrfs-balance kthread. Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2012-07-02Btrfs: restore restriper state on all mountsIlya Dryomov
Fix a bug that triggered asserts in btrfs_balance() in both normal and resume modes -- restriper state was not properly restored on read-only mounts. This factors out resuming code from btrfs_restore_balance(), which is now also called earlier in the mount sequence to avoid the problem of some early writes getting the old profile. Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2012-07-02Btrfs: don't count I/O statistic read errors for missing devicesStefan Behrens
It is normal behaviour of the low level btrfs function btrfs_map_bio() to complete a bio with -EIO if the device is missing, instead of just preventing the bio creation in an earlier step. This used to cause I/O statistic read error increments and annoying printk_ratelimited messages. This commit fixes the issue. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de> Reported-by: Carey Underwood <cwillu@cwillu.com>
2012-06-14Btrfs: use rcu to protect device->nameJosef Bacik
Al pointed out that we can just toss out the old name on a device and add a new one arbitrarily, so anybody who uses device->name in printk could possibly use free'd memory. Instead of adding locking around all of this he suggested doing it with RCU, so I've introduced a struct rcu_string that does just that and have gone through and protected all accesses to device->name that aren't under the uuid_mutex with rcu_read_lock(). This protects us and I will use it for dealing with removing the device that we used to mount the file system in a later patch. Thanks, Reviewed-by: David Sterba <dsterba@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com>
2012-05-30Btrfs: read device stats on mount, write modified ones during commitStefan Behrens
The device statistics are written into the device tree with each transaction commit. Only modified statistics are written. When a filesystem is mounted, the device statistics for each involved device are read from the device tree and used to initialize the counters. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de>
2012-05-30Btrfs: add ioctl to get and reset the device statsStefan Behrens
An ioctl interface is added to get the device statistic counters. A second ioctl is added to atomically get and reset these counters. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de>
2012-05-30Btrfs: add device counters for detected IO and checksum errorsStefan Behrens
The goal is to detect when drives start to get an increased error rate, when drives should be replaced soon. Therefore statistic counters are added that count IO errors (read, write and flush). Additionally, the software detected errors like checksum errors and corrupted blocks are counted. Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de>
2012-05-30Btrfs: fix wrong error returned by adding a deviceLiu Bo
Reproduce: $ mkfs.btrfs /dev/sdb7 $ mount /dev/sdb7 /mnt/btrfs -o ro $ btrfs dev add /dev/sdb8 /mnt/btrfs ERROR: error adding the device '/dev/sdb8' - Invalid argument Since we mount with readonly options, and /dev/sdb7 is not a seeding one, a readonly notification is preferred. Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Reviewed-by: Josef Bacik <josef@redhat.com>
2012-04-27Btrfs: fix repair code for RAID10Jan Schmidt
btrfs_map_block sets mirror_num, so that the repair code knows eventually which device gave us the read error. For RAID10, mirror_num must be 1 or 2. Before this fix mirror_num was incorrectly related to our stripe index. Signed-off-by: Jan Schmidt <list.btrfs@jan-o-sch.net> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2012-04-18fs/btrfs/volumes.c: add missing free_fs_devicesJulia Lawall
Free fs_devices as done in the error-handling code just below. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr>
2012-04-18Btrfs: fix max chunk size check in chunk allocatorIlya Dryomov
Fix a bug, where in case we need to adjust stripe_size so that the length of the resulting chunk is less than or equal to max_chunk_size, DUP chunks turn out to be only half as big as they could be. Cc: Arne Jansen <sensille@gmx.net> Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2012-04-12Btrfs: fix eof while discarding extentsLiu Bo
We miscalculate the length of extents we're discarding, and it leads to an eof of device. Reported-by: Daniel Blueman <daniel@quora.org> Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2012-03-28Btrfs: flush out and clean up any block device pages during mountChris Mason
Btrfs puts the filesystem metadata into its own address space, and somehow the block device address space isn't getting onto disk properly before a mount. The end result is that a loop of mkfs and mounting the filesystem will sometimes find stale or incorrect data. This commit should fix it by sprinkling fdatawrites and invalidate_bdev calls around. This is a short term measure to make sure it is fixed. The block devices really should be flushed and cleaned up higher in the stack. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2012-03-28Merge branch 'for-chris' of git://github.com/idryomov/btrfs-unstable into ↵Chris Mason
for-linus
2012-03-28Merge branch 'error-handling' into for-linusChris Mason
Conflicts: fs/btrfs/ctree.c fs/btrfs/disk-io.c fs/btrfs/extent-tree.c fs/btrfs/extent_io.c fs/btrfs/extent_io.h fs/btrfs/inode.c fs/btrfs/scrub.c Signed-off-by: Chris Mason <chris.mason@oracle.com>
2012-03-27Btrfs: fix infinite loop in btrfs_shrink_device()Ilya Dryomov
If relocate of block group 0 fails with ENOSPC we end up infinitely looping because key.offset -= 1 statement in that case brings us back to where we started. Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2012-03-27Btrfs: allow dup for data chunks in mixed modeIlya Dryomov
Generally we don't allow dup for data, but mixed chunks are special and people seem to think this has its use cases. Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2012-03-27Btrfs: validate target profiles only if we are going to use themIlya Dryomov
Do not run sanity checks on all target profiles unless they all will be used. This came up because alloc_profile_is_valid() is now more strict than it used to be. Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2012-03-27Btrfs: move alloc_profile_is_valid() to volumes.cIlya Dryomov
Header file is not a good place to define functions. This also moves a call to alloc_profile_is_valid() down the stack and removes a redundant check from __btrfs_alloc_chunk() - alloc_profile_is_valid() takes it into account. Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2012-03-27Btrfs: make profile_is_valid() check more strictIlya Dryomov
"0" is a valid value for an on-disk chunk profile, but it is not a valid extended profile. (We have a separate bit for single chunks in extended case) Also rename it to alloc_profile_is_valid() for clarity. Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2012-03-27Btrfs: add wrappers for working with alloc profilesIlya Dryomov
Add functions to abstract the conversion between chunk and extended allocation profile formats and switch everybody to use them. Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2012-03-26Btrfs: allow metadata blocks larger than the page sizeChris Mason
A few years ago the btrfs code to support blocks lager than the page size was disabled to fix a few corner cases in the page cache handling. This fixes the code to properly support large metadata blocks again. Since current kernels will crash early and often with larger metadata blocks, this adds an incompat bit so that older kernels can't mount it. This also does away with different blocksizes for nodes and leaves. You get a single block size for all tree blocks. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2012-03-22btrfs: replace many BUG_ONs with proper error handlingJeff Mahoney
btrfs currently handles most errors with BUG_ON. This patch is a work-in- progress but aims to handle most errors other than internal logic errors and ENOMEM more gracefully. This iteration prevents most crashes but can run into lockups with the page lock on occasion when the timing "works out." Signed-off-by: Jeff Mahoney <jeffm@suse.com>
2012-03-22btrfs: Remove BUG_ON from __finish_chunk_alloc()Mark Fasheh
btrfs_alloc_chunk() unconditionally BUGs on any error returned from __finish_chunk_alloc() so there's no need for two BUG_ON lines. Remove the one from __finish_chunk_alloc(). Signed-off-by: Mark Fasheh <mfasheh@suse.de>
2012-03-22btrfs: Remove BUG_ON from __btrfs_alloc_chunk()Mark Fasheh
We BUG_ON() error from add_extent_mapping(), but that error looks pretty easy to bubble back up - as far as I can tell there have not been any permanent modifications to fs state at that point. Signed-off-by: Mark Fasheh <mfasheh@suse.de>
2012-03-22btrfs: Don't BUG_ON insert errors in btrfs_alloc_dev_extent()Mark Fasheh
The only caller of btrfs_alloc_dev_extent() is __btrfs_alloc_chunk() which already bugs on any error returned. We can remove the BUG_ON's in btrfs_alloc_dev_extent() then since __btrfs_alloc_chunk() will "catch" them anyway. Signed-off-by: Mark Fasheh <mfasheh@suse.de>
2012-03-22btrfs: Don't BUG_ON errors in __finish_chunk_alloc()Mark Fasheh
All callers of __finish_chunk_alloc() BUG_ON() return value, so it's trivial for us to always bubble up any errors caught in __finish_chunk_alloc() to be caught there. Signed-off-by: Mark Fasheh <mfasheh@suse.de>
2012-03-22btrfs: return void in functions without error conditionsJeff Mahoney
2012-02-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Quoth Chris: "This is later than I wanted because I got backed up running through btrfs bugs from the Oracle QA teams. But they are all bug fixes that we've queued and tested since rc1. Nothing in particular stands out, this just reflects bug fixing and QA done in parallel by all the btrfs developers. The most user visible of these is: Btrfs: clear the extent uptodate bits during parent transid failures Because that helps deal with out of date drives (say an iscsi disk that has gone away and come back). The old code wasn't always properly retrying the other mirror for this type of failure." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (24 commits) Btrfs: fix compiler warnings on 32 bit systems Btrfs: increase the global block reserve estimates Btrfs: clear the extent uptodate bits during parent transid failures Btrfs: add extra sanity checks on the path names in btrfs_mksubvol Btrfs: make sure we update latest_bdev Btrfs: improve error handling for btrfs_insert_dir_item callers Btrfs: be less strict on finding next node in clear_extent_bit Btrfs: fix a bug on overcommit stuff Btrfs: kick out redundant stuff in convert_extent_bit Btrfs: skip states when they does not contain bits to clear Btrfs: check return value of lookup_extent_mapping() correctly Btrfs: fix deadlock on page lock when doing auto-defragment Btrfs: fix return value check of extent_io_ops btrfs: honor umask when creating subvol root btrfs: silence warning in raid array setup btrfs: fix structs where bitfields and spinlock/atomic share 8B word btrfs: delalloc for page dirtied out-of-band in fixup worker Btrfs: fix memory leak in load_free_space_cache() btrfs: don't check DUP chunks twice Btrfs: fix trim 0 bytes after a device delete ...
2012-02-23Btrfs: make sure we update latest_bdevChris Mason
When we are setting up the mount, we close all the devices that were not actually part of the metadata we found. But, we don't make sure that one of those devices wasn't fs_devices->latest_bdev, which means we can do a use after free on the one we closed. This updates latest_bdev as it goes. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2012-02-16Btrfs: check return value of lookup_extent_mapping() correctlyTsutomu Itoh
This patch corrects error checking of lookup_extent_mapping(). Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com>
2012-02-15btrfs: silence warning in raid array setupDavid Sterba
Raid array setup code creates an extent buffer in an usual way. When the PAGE_CACHE_SIZE is > super block size, the extent pages are not marked up-to-date, which triggers a WARN_ON in the following write_extent_buffer call. Add an explicit up-to-date call to silence the warning. Signed-off-by: David Sterba <dsterba@suse.cz>
2012-01-17Merge branch 'btrfs' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfsLinus Torvalds
* 'btrfs' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: btrfs: take allocation of ->tree_root into open_ctree() btrfs: let ->s_fs_info point to fs_info, not root... btrfs: consolidate failure exits in btrfs_mount() a bit btrfs: make free_fs_info() call ->kill_sb() unconditional btrfs: merge free_fs_info() calls on fill_super failures btrfs: kill pointless reassignment of ->s_fs_info in btrfs_fill_super() btrfs: make open_ctree() return int btrfs: sanitizing ->fs_info, part 5 btrfs: sanitizing ->fs_info, part 4 btrfs: sanitizing ->fs_info, part 3 btrfs: sanitizing ->fs_info, part 2 btrfs: sanitizing ->fs_info, part 1 btrfs: fix a deadlock in btrfs_scan_one_device() btrfs: fix mount/umount race btrfs: get ->kill_sb() of its own btrfs: preparation to fixing mount/umount race
2012-01-16Btrfs: use larger system chunksChris Mason
system chunks by default are very small. This makes them slightly larger and also fixes the conditional checks to make sure we don't allocate a billion of them at once. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2012-01-16Merge branch 'integrity-check-patch-v2' of ↵Chris Mason
git://btrfs.giantdisaster.de/git/btrfs into integration Conflicts: fs/btrfs/ctree.h fs/btrfs/super.c Signed-off-by: Chris Mason <chris.mason@oracle.com>
2012-01-16Merge branch 'for-chris' of git://repo.or.cz/linux-btrfs-devel into integrationChris Mason
Conflicts: fs/btrfs/volumes.c Signed-off-by: Chris Mason <chris.mason@oracle.com>
2012-01-16Merge branch 'restriper' of git://github.com/idryomov/btrfs-unstable into ↵Chris Mason
integration
2012-01-16Btrfs: add balance progress reportingIlya Dryomov
2012-01-16Btrfs: allow for canceling restriperIlya Dryomov
Implement an ioctl for canceling restriper. Currently we wait until relocation of the current block group is finished, in future this can be done by triggering a commit. Balance item is deleted and no memory about the interrupted balance is kept. Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2012-01-16Btrfs: allow for pausing restriperIlya Dryomov
Implement an ioctl for pausing restriper. This pauses the relocation, but balance is still considered to be "in progress": balance item is not deleted, other volume operations cannot be started, etc. If paused in the middle of profile changing operation we will continue making allocations with the target profile. Add a hook to close_ctree() to pause restriper and free its data structures on unmount. (It's safe to unmount when restriper is in "paused" state, we will resume with the same parameters on the next mount) Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
2012-01-16Btrfs: add skip_balance mount optionIlya Dryomov
Since restriper kthread starts involuntarily on mount and can suck cpu and memory bandwidth add a mount option to forcefully skip it. The restriper in that case hangs around in paused state and can be resumed from userspace when it's convenient. Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
