The @found is always false when it comes to the if branch. Besides, the
bool type is more suitable for @found. Change the return value of the
function and its caller to bool as well.
Reviewed-by: Nikolay Borisov <nborisov@suse.com>
Signed-off-by: Lu Fengqi <lufq.fnst@cn.fujitsu.com>
Reviewed-by: David Sterba <dsterba@suse.com>
Signed-off-by: David Sterba <dsterba@suse.com>
Several functions in BTRFS are only used inside the source file they are
declared if CONFIG_BTRFS_FS_RUN_SANITY_TESTS is not defined. However if
CONFIG_BTRFS_FS_RUN_SANITY_TESTS is defined these functions are shared
with the unit tests code.
Before the introduction of the EXPORT_FOR_TESTS macro, these functions
could not be declared as static and the compiler had a harder task when
optimizing and inlining them.
As we have EXPORT_FOR_TESTS now, use it where appropriate to support the
compiler.
Signed-off-by: Johannes Thumshirn <jthumshirn@suse.de>
All callers of this function pass BTRFS_MAX_EXTENT_SIZE (128M) so let's
reduce the argument count and make that a local variable. No functional
changes.
Reviewed-by: Qu Wenruo <wqu@suse.com>
Reviewed-by: Anand Jain <anand.jain@oracle.com>
Signed-off-by: Nikolay Borisov <nborisov@suse.com>
The loop construct in free_extent_buffer was added in
242e18c7c1a8 ("Btrfs: reduce lock contention on extent buffer locks")
as means of reducing the times the eb lock is taken, the non-last ref
count is decremented and lock is released. As the special handling
of UNMAPPED extent buffers was removed now there is only one decrement
op which is happening for EXTENT_BUFFER_UNMAPPED case.
This commit modifies the loop condition so that in case of UNMAPPED
buffers the eb's lock is taken only if we are 100% sure the eb is going
to be freed by the current executor of the code. Additionally, remove
superfluous ref count ops in btrfs test.
Now that the whole of btrfs code has been audited for eb reference count
management it's time to remove the hunk in free_extent_buffer that
essentially considered the condition
"eb->ref == 2 && EXTENT_BUFFER_DUMMY"
to equal "eb->ref = 1". Also remove the last location
which takes an extra reference count in alloc_test_extent_buffer.
In extent-io self test, we need 2 ordered extents at its maximum size to
do the test.
Instead of using the intermediate numbers, use BTRFS_MAX_EXTENT_SIZE for
@max_bytes, and twice @max_bytes for @total_dirty. This should explain
why we need all these magic numbers and prevent people to modify them by
accident.
Signed-off-by: Qu Wenruo <wqu@suse.com>
This callback is used to properly account delalloc extents for data
inodes (ordinary file inodes and freespace v1 inodes). Those can be
easily identified since they have their extent_io trees ->private_data
member point to the inode. Let's exploit this fact to remove the
needless indirection through extent_io_hooks and directly call the
function. Also give the function a name which reflects its purpose -
btrfs_set_delalloc_extent.
This patch also modified test_find_delalloc so that the extent_io_tree
used for testing doesn't have its ->private_data set which would have
caused a crash in btrfs_set_delalloc_extent due to the btrfs_inode->root
member not being initialised. The old version of the code also didn't
call set_bit_hook since the extent_io ops weren't set for the inode. No
functional changes.
Reviewed-by: Josef Bacik <josef@toxicpanda.com>
The helper find_lock_delalloc_range is now conditionally built static,
dpending on whether the self-tests are enabled or not. There's a macro
that is supposed to hide the export, used only once. To discourage
further use, drop it an add a public wrapper for the helper needed by
tests.
Reviewed-by: Omar Sandoval <osandov@fb.com>
rb_first_cached() trades an extra pointer "leftmost" for doing the
same job as rb_first() but in O(1).
As evict_inode_truncate_pages() removes all extent mapping by always
looking for the first rb entry, it's helpful to use rb_first_cached
instead.
For more details about the optimization see patch "Btrfs: delayed-refs:
use rb_first_cached for href_root".
Tested-by: Holger Hoffstätte <holger@applied-asynchrony.com>
Signed-off-by: Liu Bo <bo.liu@linux.alibaba.com>
It can be fetched from the transaction handle.
Now that test_err strings do not need the newline, remove them also from
the test_msg.
The test failures are not clearly visible in the system log as they're
printed at INFO level. Add a new helper that is level ERROR. As this
touches almost all strings, I took the opportunity to unify them:
- decapitalize the first letter as there's a prefix and the text
continues after ":"
- glue strings split to more lines and un-indent so they fit to 80
columns
- use %llu instead of %Lu
- drop \n from the modified messages (test_msg is left untouched)
This function takes a transaction handle which holds a reference to
fs_info. So use that and remove the extra argument.
This function always takes a transaction handle which contains a
reference to fs_info. So use that and kill the extra argument.
This function already takes a transaction handle which contains a
reference to fs_info. So use that and remove the extra argument.
This function always takes a trans handle which contains a reference to
the fs_info. Use that and remove the extra argument.
We also pass in a transaction handle which has a reference to the
fs_info. Just remove the extraneous argument.
This will be necessary for future cleanups which remove the fs_info
argument from some freespace tree functions.
We really want to know to which filesystem the extent map events belong,
but as it cannot be reached from the extent_map pointers, we need to
pass it down the callchain.
Preparatory work to pass fs_info to btrfs_add_extent_mapping so we can
get a better tracepoint message. Extent maps do not need fs_info for
anything so we only add a dummy one without any other initialization.
Remove GPL boilerplate text (long, short, one-line) and keep the rest,
ie. personal, company or original source copyright statements. Add the
SPDX header.
SPDX header.
Unify the include protection macros to match the file names.
The extent tree of the test fs is like the following:
BTRFS info (device (null)): leaf 16327509003777336587 total ptrs 1 free space 3919
item 0 key (4096 168 4096) itemoff 3944 itemsize 51
extent refs 1 gen 1 flags 2
tree block key (68719476736 0 0) level 1
ref#0: tree block backref root 5
And it's using an empty tree for fs tree, so there is no way that its
level can be 1.
For REAL (created by mkfs) fs tree backref with no skinny metadata, the
result should look like:
item 3 key (30408704 EXTENT_ITEM 4096) itemoff 3845 itemsize 51
refs 1 gen 4 flags TREE_BLOCK
tree block key (256 INODE_ITEM 0) level 0
Fix the level to 0, so it won't break later tree level checker.
Fixes: faa2dbf004e8 ("Btrfs: add sanity tests for new qgroup accounting code")
Add a missing void parameter to function btrfs_test_extent_map, fixes
sparse warning:
warning: non-ANSI function declaration of function 'btrfs_test_extent_map'
The check for a non-zero ret is redundant as the goto will jump to
the very next statement anyway. Remove this extraneous code.
Detected by CoverityScan, CID#1463784 ("Identical code for different
branches")
This test case simulates the racy situation of dio write vs dio read,
and see if btrfs_get_extent() would return -EEXIST.
Signed-off-by: Liu Bo <bo.li.liu@oracle.com>
Reviewed-by: Josef Bacik <jbacik@fb.com>
This test case simulates the racy situation of buffered write vs dio
read, and see if btrfs_get_extent() would return -EEXIST.
We've observed that btrfs_get_extent() and merge_extent_mapping() could
return -EEXIST in several cases, and they are caused by some racy
condition, e.g dio read vs dio write, which makes the problem very tricky
to reproduce.
This adds extent map selftests in order to simulate those racy situations.
[ minor string adjustments ]
Commit 9036c10208e1 ("Btrfs: update hole handling v2") added the
FLAG_VACANCY to denote holes, however there was already a consistent way
of flagging extents which represent hole - ->block_start =
EXTENT_MAP_HOLE. And also the only place where this flag is checked is
in the fiemap code, but the block_start value is also checked and every
other place in the filesystem detects holes by using block_start
value's. So remove the extra flag. This survived a full xfstest run.
All callers use GFP_NOFS, we don't have to pass it as an argument. The
built-in tests pass GFP_KERNEL, but they run only at module load time
and NOFS works there as well.
The patch from commit a7e3b975a0f9 ("Btrfs: fix reported number of inode
blocks") introduced a regression where if we do a buffered write starting
at position equal to or greater than the file's size and then stat(2) the
file before writeback is triggered, the number of used blocks does not
change (unless there's a prealloc/unwritten extent). Example:
$ xfs_io -f -c "pwrite -S 0xab 0 64K" foobar
$ du -h foobar
0 foobar
$ sync
$ du -h foobar
64K foobar
The first version of that patch didn't had this regression and the second
version, which was the one committed, was made only to address some
performance regression detected by the intel test robots using fs_mark.
This fixes the regression by setting the new delaloc bit in the range, and
doing it at btrfs_dirty_pages() while setting the regular dealloc bit as
well, so that this way we set both bits at once avoiding navigation of the
inode's io tree twice. Doing it at btrfs_dirty_pages() is also the most
meaninful place, as we should set the new dellaloc bit when if we set the
delalloc bit, which happens only if we copied bytes into the pages at
__btrfs_buffered_write().
This was making some of LTP's du tests fail, which can be quickly run
using a command line like the following:
$ ./runltp -q -p -l /ltp.log -f commands -s du -d /mnt
Fixes: a7e3b975a0f9 ("Btrfs: fix reported number of inode blocks")
Signed-off-by: Filipe Manana <fdmanana@suse.com>
Right now we do a lot of weird hoops around outstanding_extents in order
to keep the extent count consistent. This is because we logically
transfer the outstanding_extent count from the initial reservation
through the set_delalloc_bits. This makes it pretty difficult to get a
handle on how and when we need to mess with outstanding_extents.
Fix this by revamping the rules of how we deal with outstanding_extents.
Now instead everybody that is holding on to a delalloc extent is
required to increase the outstanding extents count for itself. This
means we'll have something like this
btrfs_delalloc_reserve_metadata - outstanding_extents = 1
btrfs_set_extent_delalloc - outstanding_extents = 2
btrfs_release_delalloc_extents - outstanding_extents = 1
for an initial file write. Now take the append write where we extend an
existing delalloc range but still under the maximum extent size
btrfs_delalloc_reserve_metadata - outstanding_extents = 2
btrfs_set_bit_hook - outstanding_extents = 3
btrfs_merge_extent_hook - outstanding_extents = 2
btrfs_delalloc_release_extents - outstanding_extnets = 1
In order to make the ordered extent transition we of course must now
make ordered extents carry their own outstanding_extent reservation, so
for cow_file_range we end up with
btrfs_add_ordered_extent - outstanding_extents = 2
clear_extent_bit - outstanding_extents = 1
btrfs_remove_ordered_extent - outstanding_extents = 0
This makes all manipulations of outstanding_extents much more explicit.
Every successful call to btrfs_delalloc_reserve_metadata _must_ now be
combined with btrfs_release_delalloc_extents, even in the error case, as
that is the only function that actually modifies the
outstanding_extents counter.
The drawback to this is now we are much more likely to have transient
cases where outstanding_extents is much larger than it actually should
be. This could happen before as we manipulated the delalloc bits, but
now it happens basically at every write. This may put more pressure on
the ENOSPC flushing code, but I think making this code simpler is worth
the cost. I have another change coming to mitigate this side-effect
somewhat.
I also added trace points for the counter manipulation. These were used
by a bpf script I wrote to help track down leak issues.
Signed-off-by: Josef Bacik <jbacik@fb.com>
uncompressed extents
The LOGICAL_INO ioctl provides a backward mapping from extent bytenr and
offset (encoded as a single logical address) to a list of extent refs.
LOGICAL_INO complements TREE_SEARCH, which provides the forward mapping
(extent ref -> extent bytenr and offset, or logical address). These are
useful capabilities for programs that manipulate extents and extent
references from userspace (e.g. dedup and defrag utilities).
When the extents are uncompressed (and not encrypted and not other),
check_extent_in_eb performs filtering of the extent refs to remove any
extent refs which do not contain the same extent offset as the 'logical'
parameter's extent offset. This prevents LOGICAL_INO from returning
references to more than a single block.
To find the set of extent references to an uncompressed extent from [a, b),
userspace has to run a loop like this pseudocode:
for (i = a; i < b; ++i)
extent_ref_set += LOGICAL_INO(i);
At each iteration of the loop (up to 32768 iterations for a 128M extent),
data we are interested in is collected in the kernel, then deleted by
the filter in check_extent_in_eb.
When the extents are compressed (or encrypted or other), the 'logical'
parameter must be an extent bytenr (the 'a' parameter in the loop).
No filtering by extent offset is done (or possible?) so the result is
the complete set of extent refs for the entire extent. This removes
the need for the loop, since we get all the extent refs in one call.
Add an 'ignore_offset' argument to iterate_inodes_from_logical,
[...several levels of function call graph...], and check_extent_in_eb, so
that we can disable the extent offset filtering for uncompressed extents.
This flag can be set by an improved version of the LOGICAL_INO ioctl to
get either behavior as desired.
There is no functional change in this patch. The new flag is always
false.
Signed-off-by: Zygo Blaxell <ce3g8jdj@umail.furryterror.org>
[ minor coding style fixes ]
Currently btrfs' code uses a mix of opencoded sizes and defines from sizes.h.
Let's unifiy the code base to always use the symbolic constants. No functional
changes
If 'btrfs_alloc_path()' fails, we must free the resources already
allocated, as done in the other error handling paths in this function.
Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr>
Reviewed-by: Qu Wenruo <quwenruo.btrfs@gmx.com>
The sectorsize member of btrfs_block_group_cache is unused. So remove it, this
reduces the number of holes in the struct.
With patch:
/* size: 856, cachelines: 14, members: 40 */
/* sum members: 837, holes: 4, sum holes: 19 */
/* bit holes: 1, sum bit holes: 29 bits */
/* last cacheline: 24 bytes */
Without patch:
/* size: 864, cachelines: 14, members: 41 */
/* sum members: 841, holes: 5, sum holes: 23 */
/* last cacheline: 32 bytes */
For extent_io tree's we have carried the address_mapping of the inode
around in the io tree in order to pull the inode back out for calling
into various tree ops hooks. This works fine when everything that has
an extent_io_tree has an inode. But we are going to remove the
btree_inode, so we need to change this. Instead just have a generic
void * for private data that we can initialize with, and have all the
tree ops use that instead. This had a lot of cascading changes but
should be relatively straightforward.
Reviewed-by: Chandan Rajendra <chandan@linux.vnet.ibm.com>
[ minor reordering of the callback prototypes ]
The members have been effectively unused since "Btrfs: rework qgroup
accounting" (fcebe4562dec83b3), there's no substitute for
assert_qgroups_uptodate so it's removed as well.
Reviewed-by: Qu Wenruo <quwenruo@cn.fujitsu.com>
In addition to changing the signature, this patch also switches
all the functions which are used as an argument to also take btrfs_inode.
Namely those are: btrfs_get_extent and btrfs_get_extent_filemap.
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs updates from Chris Mason:
"Jeff Mahoney and Dave Sterba have a really nice set of cleanups in
here, and Christoph pitched in corrections/improvements to make btrfs
use proper helpers for bio walking instead of doing it by hand.
There are some key fixes as well, including some long standing bugs
that took forever to track down in btrfs_drop_extents and during
balance"
* 'for-linus-4.10' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (77 commits)
btrfs: limit async_work allocation and worker func duration
Revert "Btrfs: adjust len of writes if following a preallocated extent"
Btrfs: don't WARN() in btrfs_transaction_abort() for IO errors
btrfs: opencode chunk locking, remove helpers
btrfs: remove root parameter from transaction commit/end routines
btrfs: split btrfs_wait_marked_extents into normal and tree log functions
btrfs: take an fs_info directly when the root is not used otherwise
btrfs: simplify btrfs_wait_cache_io prototype
btrfs: convert extent-tree tracepoints to use fs_info
btrfs: root->fs_info cleanup, access fs_info->delayed_root directly
btrfs: root->fs_info cleanup, add fs_info convenience variables
btrfs: root->fs_info cleanup, update_block_group{,flags}
btrfs: root->fs_info cleanup, lock/unlock_chunks
btrfs: root->fs_info cleanup, btrfs_calc_{trans,trunc}_metadata_size
btrfs: pull node/sector/stripe sizes out of root and into fs_info
btrfs: root->fs_info cleanup, io_ctl_init
btrfs: root->fs_info cleanup, use fs_info->dev_root everywhere
btrfs: struct reada_control.root -> reada_control.fs_info
btrfs: struct btrfsic_state->root should be an fs_info
btrfs: alloc_reserved_file_extent trace point should use extent_root
This fixes several interlinked problems with the iterators in the
presence of multiorder entries.
1. radix_tree_iter_next() would only advance by one slot, which would
result in the iterators returning the same entry more than once if
there were sibling entries.
2. radix_tree_next_slot() could return an internal pointer instead of
a user pointer if a tagged multiorder entry was immediately followed by
an entry of lower order.
3. radix_tree_next_slot() expanded to a lot more code than it used to
when multiorder support was compiled in. And I wasn't comfortable with
entry_to_node() being in a header file.
Fixing radix_tree_iter_next() for the presence of sibling entries
necessarily involves examining the contents of the radix tree, so we now
need to pass 'slot' to radix_tree_iter_next(), and we need to change the
calling convention so it is called *before* dropping the lock which
protects the tree. Also rename it to radix_tree_iter_resume(), as some
people thought it was necessary to call radix_tree_iter_next() each time
around the loop.
radix_tree_next_slot() becomes closer to how it looked before multiorder
support was introduced. It only checks to see if the next entry in the
chunk is a sibling entry or a pointer to a node; this should be rare
enough that handling this case out of line is not a performance impact
(and such impact is amortised by the fact that the entry we just
processed was a multiorder entry). Also, radix_tree_next_slot() used to
force a new chunk lookup for untagged entries, which is more expensive
than the out of line sibling entry skipping.
Link: http://lkml.kernel.org/r/1480369871-5271-55-git-send-email-mawilcox@linuxonhyperv.com
Signed-off-by: Matthew Wilcox <mawilcox@microsoft.com>
Tested-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: Konstantin Khlebnikov <koct9i@gmail.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
We drop the lock which protects the radix tree, so we must call
radix_tree_iter_next() in order to avoid a modification to the tree
invalidating the iterator state.
Link: http://lkml.kernel.org/r/1480369871-5271-54-git-send-email-mawilcox@linuxonhyperv.com
We track the node sizes per-root, but they never vary from the values
in the superblock. This patch messes with the 80-column style a bit,
but subsequent patches to factor out root->fs_info into a convenience
variable fix it up again.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
The only memset we do is to 0, so sink the parameter to the function and
simplify all calls. Rename the function to reflect the behaviour.
git://git.kernel.org/pub/scm/linux/kernel/git/kdave/linux into for-linus-4.9
Signed-off-by: Chris Mason <clm@fb.com>
The recommended way is to put all members on separate lines.
We don't change the given extent ranges, mark them const to catch
accidental changes.
