Rename no_space_cache option to nospace_cache to be more consistent with
the rest, where the simple prefix 'no' is used to negate an option.
The option has been introduced during the -rc1 cycle and there are has not been
widely used, so it's safe.
Signed-off-by: David Sterba <dsterba@suse.cz>
Signed-off-by: Chris Mason <chris.mason@oracle.com>
Commits 6c41761f and 45ea6095 introduced the possibility of NULL pointer
dereference on error paths, also we would leave all devices busy and
leak fs_info with all sub-structures on error when trying to mount an
already mounted fs to a different directory.
Fix this by doing all allocations before trying to open any of the
devices, adjust error path for mount-already-mounted-fs case.
Signed-off-by: Ilya Dryomov <idryomov@gmail.com>
btrfs_parse_early_options() can fail due to error while scanning devices
(-o device= option), but still strdup() subvol_name string:
mount -o subvol=SUBV,device=BAD_DEVICE <dev> <mnt>
So free subvol_name string on error.
Don't leak subvol_name string in case multiple subvol= options are
given. "The lastest option is effective" behavior (consistent with
subvolid= and subvolrootid= options) is preserved.
On error path 'tree_root' is treed in 'free_fs_info()'.
No need to free it explicitely. Noticed by SLUB in debug mode:
Complete reproducer under usermode linux (discovered on real
machine):
bdev=/dev/ubda
btr_root=/btr
/mkfs.btrfs $bdev
mount $bdev $btr_root
mkdir $btr_root/subvols/
cd $btr_root/subvols/
/btrfs su cr foo
/btrfs su cr bar
mount $bdev -osubvol=subvols/foo $btr_root/subvols/bar
umount $btr_root/subvols/bar
which gives
device fsid 4d55aa28-45b1-474b-b4ec-da912322195e devid 1 transid 7 /dev/ubda
BUG kmalloc-2048: Object already free
INFO: Allocated in btrfs_mount+0x389/0x7f0 age=0 cpu=0 pid=277
INFO: Freed in btrfs_mount+0x51c/0x7f0 age=0 cpu=0 pid=277
INFO: Slab 0x0000000062886200 objects=15 used=9 fp=0x0000000070b4d2d0 flags=0x4081
INFO: Object 0x0000000070b4d2d0 @offset=21200 fp=0x0000000070b4a968
Call Trace:
70b31948: [<6008c522>] print_trailer+0xe2/0x130
70b31978: [<6008c5aa>] object_err+0x3a/0x50
70b319a8: [<6008e242>] free_debug_processing+0x142/0x2a0
70b319e0: [<600ebf6f>] btrfs_mount+0x55f/0x7f0
70b319f8: [<6008e5c1>] __slab_free+0x221/0x2d0
Signed-off-by: Sergei Trofimovich <slyfox@gentoo.org>
Cc: Arne Jansen <sensille@gmx.net>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: David Sterba <dsterba@suse.cz>
This takes some of the free space in the btrfs super block
to record information about most of the roots in the last four
commits.
It also adds a -o recovery to use the root history log when
we're not able to read the tree of tree roots, the extent
tree root, the device tree root or the csum root.
fs_info has now ~9kb, more than fits into one page. This will cause
mount failure when memory is too fragmented. Top space consumers are
super block structures super_copy and super_for_commit, ~2.8kb each.
Allocate them dynamically. fs_info will be ~3.5kb. (measured on x86_64)
Add a wrapper for freeing fs_info and all of it's dynamically allocated
members.
There's a missing test whether the path passed to subvol=path option
during mount is a real subvolume, allowing any directory located in
default subovlume to be passed and accepted for mount.
(current btrfs progs prevent this early)
$ btrfs subvol snapshot . p1-snap
ERROR: '.' is not a subvolume
(with "is subvolume?" test bypassed)
Create a snapshot of '.' in './p1-snap'
$ btrfs subvol list -p .
ID 258 parent 5 top level 5 path subvol
ID 259 parent 5 top level 5 path subvol1
ID 260 parent 5 top level 5 path default-subvol1
ID 262 parent 5 top level 5 path p1/p1-snapshot
ID 263 parent 259 top level 5 path subvol1/subvol1-snap
The problem I see is that this makes a false impression of snapshotting the
given subvolume but in fact snapshots the default one: a user expects outcome
like ID 263 but in fact gets ID 262 .
This patch makes mount fail with EINVAL with a message in syslog.
Initialize fs_info->bdev_holder a bit earlier to be able to pass a
correct holder id to blkdev_get() when opening seed devices with O_EXCL.
Signed-off-by: Jie Liu <jeff.liu@oracle.com>
Some users have requested this and I've found I needed a way to disable cache
loading without actually clearing the cache, so introduce the no_space_cache
option. Before we check the super blocks cache generation field and if it was
populated we always turned space caching on. Now we check this and set the
space cache option on, and then parse the mount options so that if we want it
off it get's turned off. Then we check the mount option all the places we do
the caching work instead of checking the super's cache generation. This makes
things more consistent and lets us turn space caching off. Thanks,
Signed-off-by: Josef Bacik <josef@redhat.com>
We've only been able to mount with subvol=<whatever> where whatever was a subvol
within whatever root we had as the default. This allows us to mount -o
subvol=path/to/subvol/you/want relative from the normal fs_tree root. Thanks,
Currently what we do is just wrong. We either
1) Alloc a new "root" dentry with sb->s_root as it's parent which is just wrong
as we could walk into this subvol later on via another path and hilarity could
ensue. Also we don't check the return value of d_splice_alias which isn't good
either.
or
2) Do a d_find_alias() which we could have lost our dentry from cache at this
point and found nothing.
So use d_obtain_alias(). In the case that we already have the inode/dentry in
cache we will get the correct dentry. If not we will get a disconnected dentry
tree so if we walk into it later on everything will be connected up properly.
Thanks,
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable:
btrfs: fix oops when doing space balance
Btrfs: don't panic if we get an error while balancing V2
btrfs: add missing options displayed in mount output
There are three missed mount options settable by user which are not
currently displayed in mount output.
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus-2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
vfs: make unlink() and rmdir() return ENOENT in preference to EROFS
lmLogOpen() broken failure exit
usb: remove bad dput after dentry_unhash
more conservative S_NOSEC handling
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (25 commits)
btrfs: fix uninitialized variable warning
btrfs: add helper for fs_info->closing
Btrfs: add mount -o inode_cache
btrfs: scrub: add explicit plugging
btrfs: use btrfs_ino to access inode number
Btrfs: don't save the inode cache if we are deleting this root
btrfs: false BUG_ON when degraded
Btrfs: don't save the inode cache in non-FS roots
Btrfs: make sure we don't overflow the free space cache crc page
Btrfs: fix uninit variable in the delayed inode code
btrfs: scrub: don't reuse bios and pages
Btrfs: leave spinning on lookup and map the leaf
Btrfs: check for duplicate entries in the free space cache
Btrfs: don't try to allocate from a block group that doesn't have enough space
Btrfs: don't always do readahead
Btrfs: try not to sleep as much when doing slow caching
Btrfs: kill BTRFS_I(inode)->block_group
Btrfs: don't look at the extent buffer level 3 times in a row
Btrfs: map the node block when looking for readahead targets
Btrfs: set range_start to the right start in count_range_bits
This makes the inode map cache default to off until we
fix the overflow problem when the free space crcs don't fit
inside a single page.
Caching "we have already removed suid/caps" was overenthusiastic as merged.
On network filesystems we might have had suid/caps set on another client,
silently picked by this client on revalidate, all of that *without* clearing
the S_NOSEC flag.
AFAICS, the only reasonably sane way to deal with that is
* new superblock flag; unless set, S_NOSEC is not going to be set.
* local block filesystems set it in their ->mount() (more accurately,
mount_bdev() does, so does btrfs ->mount(), users of mount_bdev() other than
local block ones clear it)
* if any network filesystem (or a cluster one) wants to use S_NOSEC,
it'll need to set MS_NOSEC in sb->s_flags *AND* take care to clear S_NOSEC when
inode attribute changes are picked from other clients.
It's not an earth-shattering hole (anybody that can set suid on another client
will almost certainly be able to write to the file before doing that anyway),
but it's a bug that needs fixing.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (58 commits)
Btrfs: use the device_list_mutex during write_dev_supers
Btrfs: setup free ino caching in a more asynchronous way
btrfs scrub: don't coalesce pages that are logically discontiguous
Btrfs: return -ENOMEM in clear_extent_bit
Btrfs: add mount -o auto_defrag
Btrfs: using rcu lock in the reader side of devices list
Btrfs: drop unnecessary device lock
Btrfs: fix the race between remove dev and alloc chunk
Btrfs: fix the race between reading and updating devices
Btrfs: fix bh leak on __btrfs_open_devices path
Btrfs: fix unsafe usage of merge_state
Btrfs: allocate extent state and check the result properly
fs/btrfs: Add missing btrfs_free_path
Btrfs: check return value of btrfs_inc_extent_ref()
Btrfs: return error to caller if read_one_inode() fails
Btrfs: BUG_ON is deleted from the caller of btrfs_truncate_item & btrfs_extend_item
Btrfs: return error code to caller when btrfs_del_item fails
Btrfs: return error code to caller when btrfs_previous_item fails
btrfs: fix typo 'testeing' -> 'testing'
btrfs: typo: 'btrfS' -> 'btrfs'
This will detect small random writes into files and
queue the up for an auto defrag process. It isn't well suited to
database workloads yet, but works for smaller files such as rpm, sqlite
or bdb databases.
This sixth patch of eight in this cleancache series "opts-in"
cleancache for btrfs. Filesystems must explicitly enable
cleancache by calling cleancache_init_fs anytime an instance
of the filesystem is mounted. Btrfs uses its own readpage
which must be hooked, but all other cleancache hooks are in
the VFS layer including the matching cleancache_flush_fs hook
which must be called on unmount.
Details and a FAQ can be found in Documentation/vm/cleancache.txt
[v6-v8: no changes]
[v5: jeremy@goop.org: simplify init hook and any future fs init changes]
Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com>
Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Rik Van Riel <riel@redhat.com>
Cc: Jan Beulich <JBeulich@novell.com>
Cc: Andreas Dilger <adilger@sun.com>
Cc: Ted Ts'o <tytso@mit.edu>
Cc: Mark Fasheh <mfasheh@suse.com>
Cc: Joel Becker <joel.becker@oracle.com>
Cc: Nitin Gupta <ngupta@vflare.org>
fs/btrfs/tree-log.c
fs/btrfs/volumes.c
Btrfs_alloc_path should be matched with btrfs_free_path in error-handling code.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
// <smpl>
@r exists@
local idexpression struct btrfs_path * x;
expression ra,rb;
position p1,p2;
x = btrfs_alloc_path@p1(...)
... when != btrfs_free_path(x,...)
when != if (...) { ... btrfs_free_path(x,...) ...}
when != x = ra
if(...) { ... when != x = rb
when forall
\(return <+...x...+>; \| return@p2...; \) }
@script:python@
p1 << r.p1;
p2 << r.p2;
cocci.print_main("alloc",p1)
cocci.print_secs("return",p2)
// </smpl>
git://git.kernel.org/pub/scm/linux/kernel/git/arne/btrfs-unstable-arne into inode_numbers
inode_numbers
fs/btrfs/extent-tree.c
fs/btrfs/free-space-cache.c
fs/btrfs/inode.c
fs/btrfs/tree-log.c
Changelog V5 -> V6:
- Fix oom when the memory load is high, by storing the delayed nodes into the
root's radix tree, and letting btrfs inodes go.
Changelog V4 -> V5:
- Fix the race on adding the delayed node to the inode, which is spotted by
Chris Mason.
- Merge Chris Mason's incremental patch into this patch.
- Fix deadlock between readdir() and memory fault, which is reported by
Itaru Kitayama.
Changelog V3 -> V4:
- Fix nested lock, which is reported by Itaru Kitayama, by updating space cache
inode in time.
Changelog V2 -> V3:
- Fix the race between the delayed worker and the task which does delayed items
balance, which is reported by Tsutomu Itoh.
- Modify the patch address David Sterba's comment.
- Fix the bug of the cpu recursion spinlock, reported by Chris Mason
Changelog V1 -> V2:
- break up the global rb-tree, use a list to manage the delayed nodes,
which is created for every directory and file, and used to manage the
delayed directory name index items and the delayed inode item.
- introduce a worker to deal with the delayed nodes.
Compare with Ext3/4, the performance of file creation and deletion on btrfs
is very poor. the reason is that btrfs must do a lot of b+ tree insertions,
such as inode item, directory name item, directory name index and so on.
If we can do some delayed b+ tree insertion or deletion, we can improve the
performance, so we made this patch which implemented delayed directory name
index insertion/deletion and delayed inode update.
Implementation:
- introduce a delayed root object into the filesystem, that use two lists to
manage the delayed nodes which are created for every file/directory.
One is used to manage all the delayed nodes that have delayed items. And the
other is used to manage the delayed nodes which is waiting to be dealt with
by the work thread.
- Every delayed node has two rb-tree, one is used to manage the directory name
index which is going to be inserted into b+ tree, and the other is used to
manage the directory name index which is going to be deleted from b+ tree.
- introduce a worker to deal with the delayed operation. This worker is used
to deal with the works of the delayed directory name index items insertion
and deletion and the delayed inode update.
When the delayed items is beyond the lower limit, we create works for some
delayed nodes and insert them into the work queue of the worker, and then
go back.
When the delayed items is beyond the upper bound, we create works for all
the delayed nodes that haven't been dealt with, and insert them into the work
queue of the worker, and then wait for that the untreated items is below some
threshold value.
- When we want to insert a directory name index into b+ tree, we just add the
information into the delayed inserting rb-tree.
And then we check the number of the delayed items and do delayed items
balance. (The balance policy is above.)
- When we want to delete a directory name index from the b+ tree, we search it
in the inserting rb-tree at first. If we look it up, just drop it. If not,
add the key of it into the delayed deleting rb-tree.
Similar to the delayed inserting rb-tree, we also check the number of the
delayed items and do delayed items balance.
(The same to inserting manipulation)
- When we want to update the metadata of some inode, we cached the data of the
inode into the delayed node. the worker will flush it into the b+ tree after
dealing with the delayed insertion and deletion.
- We will move the delayed node to the tail of the list after we access the
delayed node, By this way, we can cache more delayed items and merge more
inode updates.
- If we want to commit transaction, we will deal with all the delayed node.
- the delayed node will be freed when we free the btrfs inode.
- Before we log the inode items, we commit all the directory name index items
I did a quick test by the benchmark tool[1] and found we can improve the
performance of file creation by ~15%, and file deletion by ~20%.
Before applying this patch:
Create files:
Total files: 50000
Total time: 1.096108
Average time: 0.000022
Delete files:
Total files: 50000
Total time: 1.510403
Average time: 0.000030
After applying this patch:
Create files:
Total files: 50000
Total time: 0.932899
Average time: 0.000019
Delete files:
Total files: 50000
Total time: 1.215732
Average time: 0.000024
[1] http://marc.info/?l=linux-btrfs&m=128212635122920&q=p3
Many thanks for Kitayama-san's help!
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
Reviewed-by: David Sterba <dave@jikos.cz>
Tested-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com>
Tested-by: Itaru Kitayama <kitayama@cl.bb4u.ne.jp>
this function won't be used here anymore, so move it super.c where it is
used for df-calculation
reported by gcc -Wshadow:
page_index, page_offset, new_inode, dev_name
We create two subvolumes (meego_root and meego_home) in
btrfs root directory. And set meego_root as default mount
subvolume. After we remount btrfs, meego_root is mounted
to top directory by default. Then when we try to mount
meego_home (subvol=meego_home) to a subdirectory, it failed.
The problem is when default mount subvolume is set to
meego_root, we search meego_home in meego_root but can not find
it. So the solution is to add a new mount option (subvolrootid)
to specify subvol id of root and search subvol name in it. For
our case, now we can use "-o subvolrootid=0,subvol=meego_home)
to mount meego_home.
Detail information can be found in meego bugzilla:
https://bugs.meego.com/show_bug.cgi?id=15055
Signed-off-by: Zhong, Xin <xin.zhong@intel.com>
Some mount options are not displayed by /proc/mounts.
This patch displays the option such as compress_type by /proc/mounts.
Ex.
[before]
$ mount | grep sdc2
/dev/sdc2 on /test12 type btrfs (rw,space_cache,compress=lzo)
$ cat /proc/mounts | grep sdc2
/dev/sdc2 /test12 btrfs rw,relatime,compress 0 0
[after]
$ mount | grep sdc2
/dev/sdc2 /test12 btrfs rw,relatime,compress=lzo,space_cache 0 0
Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com>
Tracepoints can provide insight into why btrfs hits bugs and be greatly
helpful for debugging, e.g
dd-7822 [000] 2121.641088: btrfs_inode_request: root = 5(FS_TREE), gen = 4, ino = 256, blocks = 8, disk_i_size = 0, last_trans = 8, logged_trans = 0
dd-7822 [000] 2121.641100: btrfs_inode_new: root = 5(FS_TREE), gen = 8, ino = 257, blocks = 0, disk_i_size = 0, last_trans = 0, logged_trans = 0
btrfs-transacti-7804 [001] 2146.935420: btrfs_cow_block: root = 2(EXTENT_TREE), refs = 2, orig_buf = 29368320 (orig_level = 0), cow_buf = 29388800 (cow_level = 0)
btrfs-transacti-7804 [001] 2146.935473: btrfs_cow_block: root = 1(ROOT_TREE), refs = 2, orig_buf = 29364224 (orig_level = 0), cow_buf = 29392896 (cow_level = 0)
btrfs-transacti-7804 [001] 2146.972221: btrfs_transaction_commit: root = 1(ROOT_TREE), gen = 8
flush-btrfs-2-7821 [001] 2155.824210: btrfs_chunk_alloc: root = 3(CHUNK_TREE), offset = 1103101952, size = 1073741824, num_stripes = 1, sub_stripes = 0, type = DATA
flush-btrfs-2-7821 [001] 2155.824241: btrfs_cow_block: root = 2(EXTENT_TREE), refs = 2, orig_buf = 29388800 (orig_level = 0), cow_buf = 29396992 (cow_level = 0)
flush-btrfs-2-7821 [001] 2155.824255: btrfs_cow_block: root = 4(DEV_TREE), refs = 2, orig_buf = 29372416 (orig_level = 0), cow_buf = 29401088 (cow_level = 0)
flush-btrfs-2-7821 [000] 2155.824329: btrfs_cow_block: root = 3(CHUNK_TREE), refs = 2, orig_buf = 20971520 (orig_level = 0), cow_buf = 20975616 (cow_level = 0)
btrfs-endio-wri-7800 [001] 2155.898019: btrfs_cow_block: root = 5(FS_TREE), refs = 2, orig_buf = 29384704 (orig_level = 0), cow_buf = 29405184 (cow_level = 0)
btrfs-endio-wri-7800 [001] 2155.898043: btrfs_cow_block: root = 7(CSUM_TREE), refs = 2, orig_buf = 29376512 (orig_level = 0), cow_buf = 29409280 (cow_level = 0)
Here is what I have added:
1) ordere_extent:
btrfs_ordered_extent_add
btrfs_ordered_extent_remove
btrfs_ordered_extent_start
btrfs_ordered_extent_put
These provide critical information to understand how ordered_extents are
updated.
2) extent_map:
btrfs_get_extent
extent_map is used in both read and write cases, and it is useful for tracking
how btrfs specific IO is running.
3) writepage:
__extent_writepage
btrfs_writepage_end_io_hook
Pages are cirtical resourses and produce a lot of corner cases during writeback,
so it is valuable to know how page is written to disk.
4) inode:
btrfs_inode_new
btrfs_inode_request
btrfs_inode_evict
These can show where and when a inode is created, when a inode is evicted.
5) sync:
btrfs_sync_file
btrfs_sync_fs
These show sync arguments.
6) transaction:
In transaction based filesystem, it will be useful to know the generation and
who does commit.
7) back reference and cow:
btrfs_delayed_tree_ref
btrfs_delayed_data_ref
btrfs_delayed_ref_head
btrfs_cow_block
Btrfs natively supports back references, these tracepoints are helpful on
understanding btrfs's COW mechanism.
8) chunk:
btrfs_chunk_alloc
btrfs_chunk_free
Chunk is a link between physical offset and logical offset, and stands for space
infomation in btrfs, and these are helpful on tracing space things.
9) reserved_extent:
btrfs_reserved_extent_alloc
btrfs_reserved_extent_free
These can show how btrfs uses its space.
Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable:
Btrfs: fix fiemap bugs with delalloc
Btrfs: set FMODE_EXCL in btrfs_device->mode
Btrfs: make btrfs_rm_device() fail gracefully
Btrfs: Avoid accessing unmapped kernel address
Btrfs: Fix BTRFS_IOC_SUBVOL_SETFLAGS ioctl
Btrfs: allow balance to explicitly allocate chunks as it relocates
Btrfs: put ENOSPC debugging under a mount option
ENOSPC in btrfs is getting to the point where the extra debugging isn't
required. I've put it under mount -o enospc_debug just in case someone
is having difficult problems.
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (33 commits)
Btrfs: Fix page count calculation
btrfs: Drop __exit attribute on btrfs_exit_compress
btrfs: cleanup error handling in btrfs_unlink_inode()
Btrfs: exclude super blocks when we read in block groups
Btrfs: make sure search_bitmap finds something in remove_from_bitmap
btrfs: fix return value check of btrfs_start_transaction()
btrfs: checking NULL or not in some functions
Btrfs: avoid uninit variable warnings in ordered-data.c
Btrfs: catch errors from btrfs_sync_log
Btrfs: make shrink_delalloc a little friendlier
Btrfs: handle no memory properly in prepare_pages
Btrfs: do error checking in btrfs_del_csums
Btrfs: use the global block reserve if we cannot reserve space
Btrfs: do not release more reserved bytes to the global_block_rsv than we need
Btrfs: fix check_path_shared so it returns the right value
btrfs: check return value of btrfs_start_ioctl_transaction() properly
btrfs: fix return value check of btrfs_join_transaction()
fs/btrfs/inode.c: Add missing IS_ERR test
btrfs: fix missing break in switch phrase
btrfs: fix several uncheck memory allocations
The error check of btrfs_start_transaction() is added, and the mistake
of the error check on several places is corrected.
We must save and free the original kstrdup()'ed pointer
because strsep() modifies its first argument.
Signed-off-by: Tero Roponen <tero.roponen@gmail.com>
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
We missed a memory deallocation in commit 450ba0ea.
If an existing super block is found at mount and there is no
error condition then the pre-allocated tree_root and fs_info
are no not used and are not freeded.
Signed-off-by: Ian Kent <raven@themaw.net>
Btrfs: forced readonly mounts on errors
btrfs: Require CAP_SYS_ADMIN for filesystem rebalance
Btrfs: don't warn if we get ENOSPC in btrfs_block_rsv_check
btrfs: Fix memory leak in btrfs_read_fs_root_no_radix()
btrfs: check NULL or not
btrfs: Don't pass NULL ptr to func that may deref it.
btrfs: mount failure return value fix
btrfs: Mem leak in btrfs_get_acl()
btrfs: fix wrong free space information of btrfs
btrfs: make the chunk allocator utilize the devices better
btrfs: restructure find_free_dev_extent()
btrfs: fix wrong calculation of stripe size
btrfs: try to reclaim some space when chunk allocation fails
btrfs: fix wrong data space statistics
fs/btrfs: Fix build of ctree
Btrfs: fix off by one while setting block groups readonly
Btrfs: Add BTRFS_IOC_SUBVOL_GETFLAGS/SETFLAGS ioctls
Btrfs: Add readonly snapshots support
Btrfs: Refactor btrfs_ioctl_snap_create()
btrfs: Extract duplicate decompress code
This patch comes from "Forced readonly mounts on errors" ideas.
As we know, this is the first step in being more fault tolerant of disk
corruptions instead of just using BUG() statements.
The major content:
- add a framework for generating errors that should result in filesystems
going readonly.
- keep FS state in disk super block.
- make sure that all of resource will be freed and released at umount time.
- make sure that fter FS is forced readonly on error, there will be no more
disk change before FS is corrected. For this, we should stop write operation.
After this patch is applied, the conversion from BUG() to such a framework can
happen incrementally.
When we store data by raid profile in btrfs with two or more different size
disks, df command shows there is some free space in the filesystem, but the
user can not write any data in fact, df command shows the wrong free space
information of btrfs.
# mkfs.btrfs -d raid1 /dev/sda9 /dev/sda10
# btrfs-show
Label: none uuid: a95cd49e-6e33-45b8-8741-a36153ce4b64
Total devices 2 FS bytes used 28.00KB
devid 1 size 5.01GB used 2.03GB path /dev/sda9
devid 2 size 10.00GB used 2.01GB path /dev/sda10
# btrfs device scan /dev/sda9 /dev/sda10
# mount /dev/sda9 /mnt
# dd if=/dev/zero of=tmpfile0 bs=4K count=9999999999
(fill the filesystem)
# sync
# df -TH
Filesystem Type Size Used Avail Use% Mounted on
/dev/sda9 btrfs 17G 8.6G 5.4G 62% /mnt
# btrfs-show
Total devices 2 FS bytes used 3.99GB
devid 1 size 5.01GB used 5.01GB path /dev/sda9
devid 2 size 10.00GB used 4.99GB path /dev/sda10
It is because btrfs cannot allocate chunks when one of the pairing disks has
no space, the free space on the other disks can not be used for ever, and should
be subtracted from the total space, but btrfs doesn't subtract this space from
the total. It is strange to the user.
This patch fixes it by calcing the free space that can be used to allocate
chunks.
Implementation:
1. get all the devices free space, and align them by stripe length.
2. sort the devices by the free space.
3. check the free space of the devices,
3.1. if it is not zero, and then check the number of the devices that has
more free space than this device,
if the number of the devices is beyond the min stripe number, the free
space can be used, and add into total free space.
if the number of the devices is below the min stripe number, we can not
use the free space, the check ends.
3.2. if the free space is zero, check the next devices, goto 3.1
This implementation is just likely fake chunk allocation.
After appling this patch, df can show correct space information:
# df -TH
/dev/sda9 btrfs 17G 8.6G 0 100% /mnt
Josef has implemented mixed data/metadata chunks, we must add those chunks'
space just like data chunks.
Reviewed-by: Josef Bacik <josef@redhat.com>
Lzo is a much faster compression algorithm than gzib, so would allow
more users to enable transparent compression, and some users can
choose from compression ratio and speed for different applications
Usage:
# mount -t btrfs -o compress[=<zlib,lzo>] dev /mnt
or
# mount -t btrfs -o compress-force[=<zlib,lzo>] dev /mnt
"-o compress" without argument is still allowed for compatability.
Compatibility:
If we mount a filesystem with lzo compression, it will not be able be
mounted in old kernels. One reason is, otherwise btrfs will directly
dump compressed data, which sits in inline extent, to user.
Performance:
The test copied a linux source tarball (~400M) from an ext4 partition
to the btrfs partition, and then extracted it.
(time in second)
lzo zlib nocompress
copy: 10.6 21.7 14.9
extract: 70.1 94.4 66.6
(data size in MB)
lzo zlib nocompress
copy: 185.87 108.69 394.49
extract: 193.80 132.36 381.21
Changelog:
v1 -> v2:
- Select LZO_COMPRESS and LZO_DECOMPRESS in btrfs Kconfig.
- Add incompability flag.
- Fix error handling in compress code.
Make the code aware of compression type, instead of always assuming
zlib compression.
Also make the zlib workspace function as common code for all
compression types.
Btrfs: prevent RAID level downgrades when space is low
Btrfs: account for missing devices in RAID allocation profiles
Btrfs: EIO when we fail to read tree roots
Btrfs: fix compiler warnings
Btrfs: Make async snapshot ioctl more generic
Btrfs: pwrite blocked when writing from the mmaped buffer of the same page
Btrfs: Fix a crash when mounting a subvolume
Btrfs: fix sync subvol/snapshot creation
Btrfs: Fix page leak in compressed writeback path
Btrfs: do not BUG if we fail to remove the orphan item for dead snapshots
Btrfs: fixup return code for btrfs_del_orphan_item
Btrfs: do not do fast caching if we are allocating blocks for tree_root
Btrfs: deal with space cache errors better
Btrfs: fix use after free in O_DIRECT
We should drop dentry before deactivating the superblock, otherwise
we can hit this bug:
BUG: Dentry f349a690{i=100,n=/} still in use (1) [unmount of btrfs loop1]
Steps to reproduce the bug:
# mount /dev/loop1 /mnt
# mkdir save
# btrfs subvolume snapshot /mnt save/snap1
# umount /mnt
# mount -o subvol=save/snap1 /dev/loop1 /mnt
(crash)
Reported-by: Michael Niederle <mniederle@gmx.at>
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (24 commits)
Btrfs: don't use migrate page without CONFIG_MIGRATION
Btrfs: deal with DIO bios that span more than one ordered extent
Btrfs: setup blank root and fs_info for mount time
Btrfs: fix fiemap
Btrfs - fix race between btrfs_get_sb() and umount
Btrfs: update inode ctime when using links
Btrfs: make sure new inode size is ok in fallocate
Btrfs: fix typo in fallocate to make it honor actual size
Btrfs: avoid NULL pointer deref in try_release_extent_buffer
Btrfs: make btrfs_add_nondir take parent inode as an argument
Btrfs: hold i_mutex when calling btrfs_log_dentry_safe
Btrfs: use dget_parent where we can UPDATED
Btrfs: fix more ESTALE problems with NFS
Btrfs: handle NFS lookups properly
btrfs: make 1-bit signed fileds unsigned
btrfs: Show device attr correctly for symlinks
btrfs: Set file size correctly in file clone
btrfs: Check if dest_offset is block-size aligned before cloning file
Btrfs: handle the space_cache option properly
btrfs: Fix early enospc because 'unused' calculated with wrong sign.
There is a problem with how we use sget, it searches through the list of supers
attached to the fs_type looking for a super with the same fs_devices as what
we're trying to mount. This depends on sb->s_fs_info being filled, but we don't
fill that in until we get to btrfs_fill_super, so we could hit supers on the
fs_type super list that have a null s_fs_info. In order to fix that we need to
go ahead and setup a blank root with a blank fs_info to hold fs_devices, that
way our test will work out right and then we can set s_fs_info in
btrfs_set_super, and then open_ctree will simply use our pre-allocated root and
fs_info when setting everything up. Thanks,
