I hit an oops when merging reloc roots fails, the reason is that
new reloc roots may be added and we should make sure we cleanup
all reloc roots.
Signed-off-by: Wang Shilong <wangsl.fnst@cn.fujitsu.com>
Signed-off-by: Chris Mason <clm@fb.com>
relocation
Quota tree and UUID Tree is only cowed, they can not be snapshoted.
I hit an oops when inserting reloc root into @reloc_root_tree(it can be
easily triggered when forcing cow for relocation root)
[ 866.494539] [<ffffffffa0499579>] btrfs_init_reloc_root+0x79/0xb0 [btrfs]
[ 866.495321] [<ffffffffa044c240>] record_root_in_trans+0xb0/0x110 [btrfs]
[ 866.496109] [<ffffffffa044d758>] btrfs_record_root_in_trans+0x48/0x80 [btrfs]
[ 866.496908] [<ffffffffa0494da8>] select_reloc_root+0xa8/0x210 [btrfs]
[ 866.497703] [<ffffffffa0495c8a>] do_relocation+0x16a/0x540 [btrfs]
This is because reloc root inserted into @reloc_root_tree is not within one
transaction,reloc root may be cowed and root block bytenr will be reused then
oops happens.We should update reloc root in @reloc_root_tree when cow reloc
root node, fix it.
Reviewed-by: Miao Xie <miaox@cn.fujitsu.com>
rename the function -- btrfs_start_all_delalloc_inodes(), and make its
name be compatible to btrfs_wait_ordered_roots(), since they are always
used at the same place.
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
Signed-off-by: Josef Bacik <jbacik@fusionio.com>
Signed-off-by: Chris Mason <chris.mason@fusionio.com>
It is very likely that there are lots of ordered extents in the filesytem,
if we wait for the completion of all of them when we want to reclaim some
space for the metadata space reservation, we would be blocked for a long
time. The performance would drop down suddenly for a long time.
Use WARN_ON()'s return value in place of WARN_ON(1) for cleaner source
code that outputs a more descriptive warnings. Also fix the styling
warning of redundant braces that came up as a result of this fix.
Signed-off-by: Dulshani Gunawardhana <dulshani.gunawardhana89@gmail.com>
Reviewed-by: Zach Brown <zab@redhat.com>
We define a 'int' to get extent's generation by mistake,fix it.
I noticed with my horrible snapshot excercisor that we were taking forever to
relocate the larger the file system got. This appeared to be because we were
committing the transaction _constantly_. There were a few places where we do
braindead things with metadata reservation, like start a transaction and then
try to refill the block rsv, which not only keeps us from committing a
transaction during the enospc stuff, but keeps us from doing some of the harder
flushing work which will make us more likely to need to commit the transaction.
We also were checking the block rsv and committing the transaction if the block
rsv was below a certain threshold, but we were doing this in a place where we
don't actually keep anything in the block rsv so this was always ending up false
so we always committed the transaction in this case. I tested this to make sure
it didn't break anything, but it takes about 10 hours to get the box to this
state so I don't know how much of an impact it will really make. Thanks,
I noticed that if the free space cache has an error writing out it's data it
won't actually error out, it will just carry on. This is because it doesn't
check the return value of btrfs_wait_ordered_range, which didn't actually return
anything. So fix this in order to keep us from making free space cache look
valid when it really isnt. Thanks,
When we did space balance and snapshot creation at the same time, we might
meet the following oops:
kernel BUG at fs/btrfs/inode.c:3038!
[SNIP]
Call Trace:
[<ffffffffa0411ec7>] btrfs_orphan_cleanup+0x293/0x407 [btrfs]
[<ffffffffa042dc45>] btrfs_mksubvol.isra.28+0x259/0x373 [btrfs]
[<ffffffffa042de85>] btrfs_ioctl_snap_create_transid+0x126/0x156 [btrfs]
[<ffffffffa042dff1>] btrfs_ioctl_snap_create_v2+0xd0/0x121 [btrfs]
[<ffffffffa0430b2c>] btrfs_ioctl+0x414/0x1854 [btrfs]
[<ffffffff813b60b7>] ? __do_page_fault+0x305/0x379
[<ffffffff811215a9>] vfs_ioctl+0x1d/0x39
[<ffffffff81121d7c>] do_vfs_ioctl+0x32d/0x3e2
[<ffffffff81057fe7>] ? finish_task_switch+0x80/0xb8
[<ffffffff81121e88>] SyS_ioctl+0x57/0x83
[<ffffffff813b39ff>] ? do_device_not_available+0x12/0x14
[<ffffffff813b99c2>] system_call_fastpath+0x16/0x1b
[SNIP]
RIP [<ffffffffa040da40>] btrfs_orphan_add+0xc3/0x126 [btrfs]
The reason of the problem is that the relocation root creation stole
the reserved space, which was reserved for orphan item deletion.
There are several ways to fix this problem, one is to increasing
the reserved space size of the space balace, and then we can use
that space to create the relocation tree for each fs/file trees.
But it is hard to calculate the suitable size because we doesn't
know how many fs/file trees we need relocate.
We fixed this problem by reserving the space for relocation root creation
actively since the space it need is very small (one tree block, used for
root node copy), then we use that reserved space to create the
relocation tree. If we don't reserve space for relocation tree creation,
we will use the reserved space of the balance.
A user reported a problem where they were getting csum errors when running a
balance and running systemd's journal. This is because systemd is awesome and
fallocate()'s its log space and writes into it. Unfortunately we assume that
when we read in all the csums for an extent that they are sequential starting at
the bytenr we care about. This obviously isn't the case for prealloc extents,
where we could have written to the middle of the prealloc extent only, which
means the csum would be for the bytenr in the middle of our range and not the
front of our range. Fix this by offsetting the new bytenr we are logging to
based on the original bytenr the csum was for. With this patch I no longer see
the csum errors I was seeing. Thanks,
Cc: stable@vger.kernel.org
Reported-by: Chris Murphy <lists@colorremedies.com>
Not used for anything, and removing it avoids caller's need to
allocate a path structure.
Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com>
When doing space balance and subvolume destroy at the same time, we met
the following oops:
kernel BUG at fs/btrfs/relocation.c:2247!
RIP: 0010: [<ffffffffa04cec16>] prepare_to_merge+0x154/0x1f0 [btrfs]
Call Trace:
[<ffffffffa04b5ab7>] relocate_block_group+0x466/0x4e6 [btrfs]
[<ffffffffa04b5c7a>] btrfs_relocate_block_group+0x143/0x275 [btrfs]
[<ffffffffa0495c56>] btrfs_relocate_chunk.isra.27+0x5c/0x5a2 [btrfs]
[<ffffffffa0459871>] ? btrfs_item_key_to_cpu+0x15/0x31 [btrfs]
[<ffffffffa048b46a>] ? btrfs_get_token_64+0x7e/0xcd [btrfs]
[<ffffffffa04a3467>] ? btrfs_tree_read_unlock_blocking+0xb2/0xb7 [btrfs]
[<ffffffffa049907d>] btrfs_balance+0x9c7/0xb6f [btrfs]
[<ffffffffa049ef84>] btrfs_ioctl_balance+0x234/0x2ac [btrfs]
[<ffffffffa04a1e8e>] btrfs_ioctl+0xd87/0x1ef9 [btrfs]
[<ffffffff81122f53>] ? path_openat+0x234/0x4db
[<ffffffff813c3b78>] ? __do_page_fault+0x31d/0x391
[<ffffffff810f8ab6>] ? vma_link+0x74/0x94
[<ffffffff811250f5>] vfs_ioctl+0x1d/0x39
[<ffffffff811258c8>] do_vfs_ioctl+0x32d/0x3e2
[<ffffffff811259d4>] SyS_ioctl+0x57/0x83
[<ffffffff813c3bfa>] ? do_page_fault+0xe/0x10
[<ffffffff813c73c2>] system_call_fastpath+0x16/0x1b
It is because we returned the error number if the reference of the root was 0
when doing space relocation. It was not right here, because though the root
was dead(refs == 0), but the space it held still need be relocated, or we
could not remove the block group. So in this case, we should return the root
no matter it is dead or not.
This is a left over of how we used to wait for ordered extents, which was to
grab the inode and then run filemap flush on it. However if we have an ordered
extent then we already are holding a ref on the inode, and we just use
btrfs_start_ordered_extent anyway, so there is no reason to have an extra ref on
the inode to start work on the ordered extent. Thanks,
If we failed to actually allocate the correct size of the extent to relocate we
will end up in an infinite loop because we won't return an error, we'll just
move on to the next extent. So fix this up by returning an error, and then fix
all the callers to return an error up the stack rather than BUG_ON()'ing.
Thanks,
btrfs_read_fs_root_no_name() already checks if btrfs_root_refs()
is zero and returns ENOENT in this case. There is no need to do
it again in three more places.
Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de>
u64 is "unsigned long long" on all architectures now, so there's no need to
cast it when formatting it using the "ll" length modifier.
Previously we only added blocks to the list to have their backrefs checked if
the level of the block is right above the one we are searching for. This is
because we want to make sure we don't add the entire path up to the root to the
lists to make sure we process things one at a time. This assumes that if any
blocks in the path to the root are going to be not checked (shared in other
words) then they will be in the level right above the current block on up. This
isn't quite right though since we can have blocks higher up the list that are
shared because they are attached to a reloc root. But we won't add this block
to be checked and then later on we will BUG_ON(!upper->checked). So instead
keep track of wether or not we've queued a block to be checked in this current
search, and if we haven't go ahead and queue it to be checked. This patch fixed
the panic I was seeing where we BUG_ON(!upper->checked). Thanks,
If our item isn't big enough to have an actual inline item when we have skinny
metadata enabled just return 1 in find_inline_backref so we can move on to the
next item. This probably wasn't causing a problem since we check the values of
ptr and end properly, but just in case this will keep us from doing extra work.
Thanks,
I was hitting the BUG_ON() at the end of merge_reloc_roots() because we were
aborting the transaction at some point previously and then getting an error when
we tried to drop the reloc root. I fixed btrfs_drop_snapshot to re-add us to
the dead roots list if we failed, but this isn't the right thing to do for reloc
roots since it uses root->root_list for it's own stuff in order to know what
needs to be cleaned up. So fix btrfs_drop_snapshot to only do the re-add if we
aren't dropping for reloc, and handle errors from merge_reloc_root() by dropping
the reloc root we are processing since it won't be on the list of roots to
cleanup. With this patch my reproducer no longer panics. Thanks,
The function relocation.c:add_data_references() was not checking
if all calls to __add_tree_block() and find_data_references() were
succeeding or not.
Reviewed-by: David Sterba <dsterba@suse.cz>
Using the structure btrfs_sector_sum to keep the checksum value is
unnecessary, because the extents that btrfs_sector_sum points to are
continuous, we can find out the expected checksums by btrfs_ordered_sum's
bytenr and the offset, so we can remove btrfs_sector_sum's bytenr. After
removing bytenr, there is only one member in the structure, so it makes
no sense to keep the structure, just remove it, and use a u32 array to
store the checksum value.
By this change, we don't use the while loop to get the checksums one by
one. Now, we can get several checksum value at one time, it improved the
performance by ~74% on my SSD (31MB/s -> 54MB/s).
test command:
# dd if=/dev/zero of=/mnt/btrfs/file0 bs=1M count=1024 oflag=sync
We unconditionally search for the EXTENT_ITEM_KEY for metadata during balance,
and then check the key that we found to see if it is actually a
METADATA_ITEM_KEY, but this doesn't work right because METADATA is a higher key
value, so if what we are looking for happens to be the first item in the leaf
the search will dump us out at the previous leaf, and we won't find our item.
So instead do what we do everywhere else, search for the skinny extent first and
if we don't find it go back and re-search for the extent item. This patch fixes
the panic I was hitting when balancing a large file system with skinny extents.
Thanks,
Balance will create reloc_root for each fs root, and it's going to
record last_snapshot to filter shared blocks. The side effect of
setting last_snapshot is to break nocow attributes of files.
Since the extents are not shared by the relocation tree after the balance,
we can recover the old last_snapshot safely if no one snapshoted the
source tree. We fix the above problem by this way.
Reported-by: Kyle Gates <kylegates@hotmail.com>
Signed-off-by: Liu Bo <bo.li.liu@oracle.com>
The reason we introduce per-subvolume ordered extent list is the same
as the per-subvolume delalloc inode list.
When we create a snapshot, we need flush all delalloc inodes in the
fs, just flushing the inodes in the source tree is OK. So we introduce
There are several functions whose code is similar, such as
btrfs_find_last_root()
btrfs_read_fs_root_no_radix()
Besides that, some functions are invoked twice, it is unnecessary,
for example, we are sure that all roots which is found in
btrfs_find_orphan_roots()
have their orphan items, so it is unnecessary to check the orphan
item again.
So cleanup it.
Dave reported a NULL pointer deref. This is caused because he thought he'd be
smart and add sanity checks to the extent_io bit operations, but he didn't
expect a tree to have a NULL mapping. To fix this we just need to init the
relocation's processed_blocks with the btree_inode->i_mapping. Thanks,
Reported-by: David Sterba <dsterba@suse.cz>
It is very likely that there are lots of subvolumes/snapshots in the filesystem,
so if we use global block reservation to do inode cache truncation, we may hog
all the free space that is reserved in global rsv. So it is better that we do
the free space reservation for inode cache truncation by ourselves.
Cc: Tsutomu Itoh <t-itoh@jp.fujitsu.com>
In replace_path(), if read_tree_block() fails, we cannot return
directly, we should free some allocated memory otherwise memory
leak happens.
Similar to Wang's "Btrfs: fix possible memory leak in the
find_parent_nodes()" patch, the current commit fixes an issue that
is related to the "Btrfs: fix all callers of read_tree_block"
commit.
Signed-off-by: David Sterba <dsterba@suse.cz>
Big patch, but all it does is add statics to functions which
are in fact static, then remove the associated dead-code fallout.
removed functions:
btrfs_iref_to_path()
__btrfs_lookup_delayed_deletion_item()
__btrfs_search_delayed_insertion_item()
__btrfs_search_delayed_deletion_item()
find_eb_for_page()
btrfs_find_block_group()
range_straddles_pages()
extent_range_uptodate()
btrfs_file_extent_length()
btrfs_scrub_cancel_devid()
btrfs_start_transaction_lflush()
btrfs_print_tree() is left because it is used for debugging.
btrfs_start_transaction_lflush() and btrfs_reada_detach() are
left for symmetry.
ulist.c functions are left, another patch will take care of those.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
We kept leaking extent buffers when mounting a broken file system and it turns
out it's because not everybody uses read_tree_block properly. You need to check
and make sure the extent_buffer is uptodate before you use it. This patch fixes
everybody who calls read_tree_block directly to make sure they check that it is
uptodate and free it and return an error if it is not. With this we no longer
leak EB's when things go horribly wrong. Thanks,
A user sent me a btrfs-image of a file system that was panicing on mount during
the log recovery. I had originally thought these problems were from a bug in
the free space cache code, but that was just a symptom of the problem. The
problem is if your application does something like this
[prealloc][prealloc][prealloc]
the internal extent maps will merge those all together into one extent map, even
though on disk they are 3 separate extents. So if you go to write into one of
these ranges the extent map will be right since we use the physical extent when
doing the write, but when we log the extents they will use the wrong sizes for
the remainder prealloc space. If this doesn't happen to trip up the free space
cache (which it won't in a lot of cases) then you will get bogus entries in your
extent tree which will screw stuff up later. The data and such will still work,
but everything else is broken. This patch fixes this by not allowing extents
that are on the modified list to be merged. This has the side effect that we
are no longer adding everything to the modified list all the time, which means
we now have to call btrfs_drop_extents every time we log an extent into the
tree. So this allows me to drop all this speciality code I was using to get
around calling btrfs_drop_extents. With this patch the testcase I've created no
longer creates a bogus file system after replaying the log. Thanks,
Each time pick one dead root from the list and let the caller know if
it's needed to continue. This should improve responsiveness during
umount and balance which at some point waits for cleaning all currently
queued dead roots.
A new dead root is added to the end of the list, so the snapshots
disappear in the order of deletion.
The snapshot cleaning work is now done only from the cleaner thread and the
others wake it if needed.
We currently store the first key of the tree block inside the reference for the
tree block in the extent tree. This takes up quite a bit of space. Make a new
key type for metadata which holds the level as the offset and completely removes
storing the btrfs_tree_block_info inside the extent ref. This reduces the size
from 51 bytes to 33 bytes per extent reference for each tree block. In practice
this results in a 30-35% decrease in the size of our extent tree, which means we
COW less and can keep more of the extent tree in memory which makes our heavy
metadata operations go much faster. This is not an automatic format change, you
must enable it at mkfs time or with btrfstune. This patch deals with having
metadata stored as either the old format or the new format so it is easy to
convert. Thanks,
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs
Pull btrfs fixes from Chris Mason:
"These are scattered fixes and one performance improvement. The
biggest functional change is in how we throttle metadata changes. The
new code bumps our average file creation rate up by ~13% in fs_mark,
and lowers CPU usage.
Stefan bisected out a regression in our allocation code that made
balance loop on extents larger than 256MB."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs:
Btrfs: improve the delayed inode throttling
Btrfs: fix a mismerge in btrfs_balance()
Btrfs: enforce min_bytes parameter during extent allocation
Btrfs: allow running defrag in parallel to administrative tasks
Btrfs: avoid deadlock on transaction waiting list
Btrfs: do not BUG_ON on aborted situation
Btrfs: do not BUG_ON in prepare_to_reloc
Btrfs: free all recorded tree blocks on error
Btrfs: build up error handling for merge_reloc_roots
Btrfs: check for NULL pointer in updating reloc roots
Btrfs: fix unclosed transaction handler when the async transaction commitment fails
Btrfs: fix wrong handle at error path of create_snapshot() when the commit fails
Btrfs: use set_nlink if our i_nlink is 0
Btrfs balance can easily hit BUG_ON in these places, but we want
to it bail out gracefully after we force the whole filesystem to
readonly. So we use btrfs_std_error hook in place of BUG_ON.
We can bail out from here gracefully instead of a cold BUG_ON.
We've missed the 'free blocks' part on ENOMEM error.
We first use btrfs_std_error hook to replace with BUG_ON, and we
also need to cleanup what is left, including reloc roots rbtree
and reloc roots list.
Here we use a helper function to cleanup both rbtree and list, and
since this function can also be used in the balance recover path,
we also make the change as well to keep code simple.
Add a check for NULL pointer to avoid invalid reference.
Pull btrfs update from Chris Mason:
"The biggest feature in the pull is the new (and still experimental)
raid56 code that David Woodhouse started long ago. I'm still working
on the parity logging setup that will avoid inconsistent parity after
a crash, so this is only for testing right now. But, I'd really like
to get it out to a broader audience to hammer out any performance
issues or other problems.
scrub does not yet correct errors on raid5/6 either.
Josef has another pass at fsync performance. The big change here is
to combine waiting for metadata with waiting for data, which is a big
latency win. It is also step one toward using atomics from the
hardware during a commit.
Mark Fasheh has a new way to use btrfs send/receive to send only the
metadata changes. SUSE is using this to make snapper more efficient
at finding changes between snapshosts.
Snapshot-aware defrag is also included.
Otherwise we have a large number of fixes and cleanups. Eric Sandeen
wins the award for removing the most lines, and I'm hoping we steal
this idea from XFS over and over again."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (118 commits)
btrfs: fixup/remove module.h usage as required
Btrfs: delete inline extents when we find them during logging
btrfs: try harder to allocate raid56 stripe cache
Btrfs: cleanup to make the function btrfs_delalloc_reserve_metadata more logic
Btrfs: don't call btrfs_qgroup_free if just btrfs_qgroup_reserve fails
Btrfs: remove reduplicate check about root in the function btrfs_clean_quota_tree
Btrfs: return ENOMEM rather than use BUG_ON when btrfs_alloc_path fails
Btrfs: fix missing deleted items in btrfs_clean_quota_tree
btrfs: use only inline_pages from extent buffer
Btrfs: fix wrong reserved space when deleting a snapshot/subvolume
Btrfs: fix wrong reserved space in qgroup during snap/subv creation
Btrfs: remove unnecessary dget_parent/dput when creating the pending snapshot
btrfs: remove a printk from scan_one_device
Btrfs: fix NULL pointer after aborting a transaction
Btrfs: fix memory leak of log roots
Btrfs: copy everything if we've created an inline extent
btrfs: cleanup for open-coded alignment
Btrfs: do not change inode flags in rename
Btrfs: use reserved space for creating a snapshot
clear chunk_alloc flag on retryable failure
Use wrapper page_offset to get byte-offset into filesystem object for page.
Signed-off-by: Liu Bo <liubo2009@cn.fujitsu.com>
drivers/devfreq/exynos4_bus.c
Sync with Linus' tree to be able to apply patches that are
against newer code (mvneta).
Convert 'hepler' to 'helper'.
- 'nr' is no more used.
- btrfs_btree_balance_dirty() and __btrfs_btree_balance_dirty() can share
a bunch of code.
This patch introduce a new worker pool named "flush_workers", and if we
want to force all the inode with pending delalloc to the disks, we can
queue those inodes into the work queue of the worker pool, in this way,
those inodes will be flushed by multi-task.
In some places(such as: evicting inode), we just can not flush the reserved
space of delalloc, flushing the delayed directory index and delayed inode
is OK, but we don't try to flush those things and just go back when there is
no enough space to be reserved. This patch fixes this problem.
We defined 3 types of the flush operations: NO_FLUSH, FLUSH_LIMIT and FLUSH_ALL.
If we can in the transaction, we should not flush anything, or the deadlock
would happen, so use NO_FLUSH. If we flushing the reserved space of delalloc
would cause deadlock, use FLUSH_LIMIT. In the other cases, FLUSH_ALL is used,
and we will flush all things.
Everytime we write out dirty pages we search for an offset in the tree,
convert the bits in the state, and then when we wait we search for the
offset again and clear the bits. So for every dirty range in the io tree we
are doing 4 rb searches, which is suboptimal. With this patch we are only
doing 2 searches for every cycle (modulo weird things happening). Thanks,
