btrfs_find_name_in_ext_backref returns either 0/1 depending on whether it
found a backref for the given name. If it returns true then the actual
inode_ref struct is returned in one of its parameters. That's pointless,
instead refactor the function such that it returns either a pointer
to the btrfs_inode_extref or NULL it it didn't find anything. This
streamlines the function calling convention.
Signed-off-by: Nikolay Borisov <nborisov@suse.com>
Reviewed-by: David Sterba <dsterba@suse.com>
Signed-off-by: David Sterba <dsterba@suse.com>
btrfs_find_name_in_backref returns either 0/1 depending on whether it
to the btrfs_inode_ref or NULL it it didn't find anything. This
Remove GPL boilerplate text (long, short, one-line) and keep the rest,
ie. personal, company or original source copyright statements. Add the
SPDX header.
The custom crc32 init code was introduced in
14a958e678cd ("Btrfs: fix btrfs boot when compiled as built-in") to
enable using btrfs as a built-in. However, later as pointed out by
60efa5eb2e88 ("Btrfs: use late_initcall instead of module_init") this
wasn't enough and finally btrfs was switched to late_initcall which
comes after the generic crc32c implementation is initiliased. The
latter commit superseeded the former. Now that we don't have to
maintain our own code let's just remove it and switch to using the
generic implementation.
Despite touching a lot of files the patch is really simple. Here is the gist of
the changes:
1. Select LIBCRC32C rather than the low-level modules.
2. s/btrfs_crc32c/crc32c/g
3. replace hash.h with linux/crc32c.h
4. Move the btrfs namehash funcs to ctree.h and change the tree accordingly.
I've tested this with btrfs being both a module and a built-in and xfstest
doesn't complain.
Does seem to fix the longstanding problem of not automatically selectiong
the crc32c module when btrfs is used. Possibly there is a workaround in
dracut.
The modinfo confirms that now all the module dependencies are there:
before:
depends: zstd_compress,zstd_decompress,raid6_pq,xor,zlib_deflate
after:
depends: libcrc32c,zstd_compress,zstd_decompress,raid6_pq,xor,zlib_deflate
[ add more info to changelog from mails ]
If we have a file with 2 (or more) hard links in the same directory,
remove one of the hard links, create a new file (or link an existing file)
in the same directory with the name of the removed hard link, and then
finally fsync the new file, we end up with a log that fails to replay,
causing a mount failure.
Example:
$ mkfs.btrfs -f /dev/sdb
$ mount /dev/sdb /mnt
$ mkdir /mnt/testdir
$ touch /mnt/testdir/foo
$ ln /mnt/testdir/foo /mnt/testdir/bar
$ sync
$ unlink /mnt/testdir/bar
$ touch /mnt/testdir/bar
$ xfs_io -c "fsync" /mnt/testdir/bar
<power failure>
mount: mount(2) failed: /mnt: No such file or directory
When replaying the log, for that example, we also see the following in
dmesg/syslog:
[71813.671307] BTRFS info (device dm-0): failed to delete reference to bar, inode 258 parent 257
[71813.674204] ------------[ cut here ]------------
[71813.675694] BTRFS: Transaction aborted (error -2)
[71813.677236] WARNING: CPU: 1 PID: 13231 at fs/btrfs/inode.c:4128 __btrfs_unlink_inode+0x17b/0x355 [btrfs]
[71813.679669] Modules linked in: btrfs xfs f2fs dm_flakey dm_mod dax ghash_clmulni_intel ppdev pcbc aesni_intel aes_x86_64 crypto_simd cryptd glue_helper evdev psmouse i2c_piix4 parport_pc i2c_core pcspkr sg serio_raw parport button sunrpc loop autofs4 ext4 crc16 mbcache jbd2 zstd_decompress zstd_compress xxhash raid10 raid456 async_raid6_recov async_memcpy async_pq async_xor async_tx xor raid6_pq libcrc32c crc32c_generic raid1 raid0 multipath linear md_mod ata_generic sd_mod virtio_scsi ata_piix libata virtio_pci virtio_ring crc32c_intel floppy virtio e1000 scsi_mod [last unloaded: btrfs]
[71813.679669] CPU: 1 PID: 13231 Comm: mount Tainted: G W 4.15.0-rc9-btrfs-next-56+ #1
[71813.679669] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.10.2-0-g5f4c7b1-prebuilt.qemu-project.org 04/01/2014
[71813.679669] RIP: 0010:__btrfs_unlink_inode+0x17b/0x355 [btrfs]
[71813.679669] RSP: 0018:ffffc90001cef738 EFLAGS: 00010286
[71813.679669] RAX: 0000000000000025 RBX: ffff880217ce4708 RCX: 0000000000000001
[71813.679669] RDX: 0000000000000000 RSI: ffffffff81c14bae RDI: 00000000ffffffff
[71813.679669] RBP: ffffc90001cef7c0 R08: 0000000000000001 R09: 0000000000000001
[71813.679669] R10: ffffc90001cef5e0 R11: ffffffff8343f007 R12: ffff880217d474c8
[71813.679669] R13: 00000000fffffffe R14: ffff88021ccf1548 R15: 0000000000000101
[71813.679669] FS: 00007f7cee84c480(0000) GS:ffff88023fc80000(0000) knlGS:0000000000000000
[71813.679669] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[71813.679669] CR2: 00007f7cedc1abf9 CR3: 00000002354b4003 CR4: 00000000001606e0
[71813.679669] Call Trace:
[71813.679669] btrfs_unlink_inode+0x17/0x41 [btrfs]
[71813.679669] drop_one_dir_item+0xfa/0x131 [btrfs]
[71813.679669] add_inode_ref+0x71e/0x851 [btrfs]
[71813.679669] ? __lock_is_held+0x39/0x71
[71813.679669] ? replay_one_buffer+0x53/0x53a [btrfs]
[71813.679669] replay_one_buffer+0x4a4/0x53a [btrfs]
[71813.679669] ? rcu_read_unlock+0x3a/0x57
[71813.679669] walk_up_log_tree+0x101/0x1d2 [btrfs]
[71813.679669] walk_log_tree+0xad/0x188 [btrfs]
[71813.679669] btrfs_recover_log_trees+0x1fa/0x31e [btrfs]
[71813.679669] ? replay_one_extent+0x544/0x544 [btrfs]
[71813.679669] open_ctree+0x1cf6/0x2209 [btrfs]
[71813.679669] btrfs_mount_root+0x368/0x482 [btrfs]
[71813.679669] ? trace_hardirqs_on_caller+0x14c/0x1a6
[71813.679669] ? __lockdep_init_map+0x176/0x1c2
[71813.679669] ? mount_fs+0x64/0x10b
[71813.679669] mount_fs+0x64/0x10b
[71813.679669] vfs_kern_mount+0x68/0xce
[71813.679669] btrfs_mount+0x13e/0x772 [btrfs]
[71813.679669] do_mount+0x6e5/0x973
[71813.679669] ? memdup_user+0x3e/0x5c
[71813.679669] SyS_mount+0x72/0x98
[71813.679669] entry_SYSCALL_64_fastpath+0x1e/0x8b
[71813.679669] RIP: 0033:0x7f7cedf150ba
[71813.679669] RSP: 002b:00007ffca71da688 EFLAGS: 00000206
[71813.679669] Code: 7f a0 e8 51 0c fd ff 48 8b 43 50 f0 0f ba a8 30 2c 00 00 02 72 17 41 83 fd fb 74 11 44 89 ee 48 c7 c7 7d 11 7f a0 e8 38 f5 8d e0 <0f> ff 44 89 e9 ba 20 10 00 00 eb 4d 48 8b 4d b0 48 8b 75 88 4c
[71813.679669] ---[ end trace 83bd473fc5b4663b ]---
[71813.854764] BTRFS: error (device dm-0) in __btrfs_unlink_inode:4128: errno=-2 No such entry
[71813.886994] BTRFS: error (device dm-0) in btrfs_replay_log:2307: errno=-2 No such entry (Failed to recover log tree)
[71813.903357] BTRFS error (device dm-0): cleaner transaction attach returned -30
[71814.128078] BTRFS error (device dm-0): open_ctree failed
This happens because the log has inode reference items for both inode 258
(the first file we created) and inode 259 (the second file created), and
when processing the reference item for inode 258, we replace the
corresponding item in the subvolume tree (which has two names, "foo" and
"bar") witht he one in the log (which only has one name, "foo") without
removing the corresponding dir index keys from the parent directory.
Later, when processing the inode reference item for inode 259, which has
a name of "bar" associated to it, we notice that dir index entries exist
for that name and for a different inode, so we attempt to unlink that
name, which fails because the inode reference item for inode 258 no longer
has the name "bar" associated to it, making a call to btrfs_unlink_inode()
fail with a -ENOENT error.
Fix this by unlinking all the names in an inode reference item from a
subvolume tree that are not present in the inode reference item found in
the log tree, before overwriting it with the item from the log tree.
Signed-off-by: Filipe Manana <fdmanana@suse.com>
There are loads of functions in btrfs that accept a root parameter
but only use it to obtain an fs_info pointer. Let's convert those to
just accept an fs_info pointer directly.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
In routines where someptr->fs_info is referenced multiple times, we
introduce a convenience variable. This makes the code considerably
more readable.
btrfs_std_error() handles errors, puts FS into readonly mode
(as of now). So its good idea to rename it to btrfs_handle_fs_error().
Signed-off-by: Anand Jain <anand.jain@oracle.com>
[ edit changelog ]
btrfs_error() and btrfs_std_error() does the same thing
and calls _btrfs_std_error(), so consolidate them together.
And the main motivation is that btrfs_error() is closely
named with btrfs_err(), one handles error action the other
is to log the error, so don't closely name them.
Suggested-by: David Sterba <dsterba@suse.com>
If we have an inode with a large number of hard links, some of which may
be extrefs, turn a regular ref into an extref, fsync the inode and then
replay the fsync log (after a crash/reboot), we can endup with an fsync
log that makes the replay code always fail with -EOVERFLOW when processing
the inode's references.
This is easy to reproduce with the test case I made for xfstests. Its steps
are the following:
_scratch_mkfs "-O extref" >> $seqres.full 2>&1
_init_flakey
_mount_flakey
# Create a test file with 3001 hard links. This number is large enough to
# make btrfs start using extrefs at some point even if the fs has the maximum
# possible leaf/node size (64Kb).
echo "hello world" > $SCRATCH_MNT/foo
for i in `seq 1 3000`; do
ln $SCRATCH_MNT/foo $SCRATCH_MNT/foo_link_`printf "%04d" $i`
done
# Make sure all metadata and data are durably persisted.
sync
# Now remove one link, add a new one with a new name, add another new one with
# the same name as the one we just removed and fsync the inode.
rm -f $SCRATCH_MNT/foo_link_0001
ln $SCRATCH_MNT/foo $SCRATCH_MNT/foo_link_3001
ln $SCRATCH_MNT/foo $SCRATCH_MNT/foo_link_0001
rm -f $SCRATCH_MNT/foo_link_0002
ln $SCRATCH_MNT/foo $SCRATCH_MNT/foo_link_3002
ln $SCRATCH_MNT/foo $SCRATCH_MNT/foo_link_3003
$XFS_IO_PROG -c "fsync" $SCRATCH_MNT/foo
# Simulate a crash/power loss. This makes sure the next mount
# will see an fsync log and will replay that log.
_load_flakey_table $FLAKEY_DROP_WRITES
_unmount_flakey
_load_flakey_table $FLAKEY_ALLOW_WRITES
_mount_flakey
# Check that the number of hard links is correct, we are able to remove all
# the hard links and read the file's data. This is just to verify we don't
# get stale file handle errors (due to dangling directory index entries that
# point to inodes that no longer exist).
echo "Link count: $(stat --format=%h $SCRATCH_MNT/foo)"
[ -f $SCRATCH_MNT/foo ] || echo "Link foo is missing"
for ((i = 1; i <= 3003; i++)); do
name=foo_link_`printf "%04d" $i`
if [ $i -eq 2 ]; then
[ -f $SCRATCH_MNT/$name ] && echo "Link $name found"
else
[ -f $SCRATCH_MNT/$name ] || echo "Link $name is missing"
fi
done
rm -f $SCRATCH_MNT/foo_link_*
cat $SCRATCH_MNT/foo
status=0
exit
The fix is simply to correct the overflow condition when overwriting a
reference item because it was wrong, trying to increase the item in the
fs/subvol tree by an impossible amount. Also ensure that we don't insert
one normal ref and one ext ref for the same dentry - this happened because
processing a dir index entry from the parent in the log happened when
the normal ref item was full, which made the logic insert an extref and
later when the normal ref had enough room, it would be inserted again
when processing the ref item from the child inode in the log.
This issue has been present since the introduction of the extrefs feature
(2012).
A test case for xfstests follows soon. This test only passes if the previous
patch titled "Btrfs: fix fsync when extend references are added to an inode"
is applied too.
Signed-off-by: Chris Mason <clm@fb.com>
btrfs_set_key_type and btrfs_key_type are used inconsistently along with
open coded variants. Other members of btrfs_key are accessed directly
without any helpers anyway.
Signed-off-by: David Sterba <dsterba@suse.cz>
Found by uselex.rb:
> btrfs_get_inode_ref_index: [R]: exported from:
fs/btrfs/inode-item.o fs/btrfs/btrfs.o fs/btrfs/built-in.o
Signed-off-by: Sergei Trofimovich <slyfox@gentoo.org>
Reviewed-by: David Stebra <dsterba@suse.cz>
Signed-off-by: Wang Shilong <wangsl.fnst@cn.fujitsu.com>
Signed-off-by: Josef Bacik <jbacik@fusionio.com>
Remove unused eb parameter from btrfs_item_nr
Signed-off-by: Ross Kirk <ross.kirk@gmail.com>
Reviewed-by: David Sterba <dsterba@suse.cz>
Signed-off-by: Chris Mason <chris.mason@fusionio.com>
Big patch, but all it does is add statics to functions which
are in fact static, then remove the associated dead-code fallout.
removed functions:
btrfs_iref_to_path()
__btrfs_lookup_delayed_deletion_item()
__btrfs_search_delayed_insertion_item()
__btrfs_search_delayed_deletion_item()
find_eb_for_page()
btrfs_find_block_group()
range_straddles_pages()
extent_range_uptodate()
btrfs_file_extent_length()
btrfs_scrub_cancel_devid()
btrfs_start_transaction_lflush()
btrfs_print_tree() is left because it is used for debugging.
btrfs_start_transaction_lflush() and btrfs_reada_detach() are
left for symmetry.
ulist.c functions are left, another patch will take care of those.
Signed-off-by: Eric Sandeen <sandeen@redhat.com>
Argument 'trans' is not used in btrfs_extend_item().
Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com>
If argument 'trans' is unnecessary in the function where
fixup_low_keys() is called, 'trans' is deleted.
This patch adds basic support for extended inode refs. This includes support
for link and unlink of the refs, which basically gets us support for rename
as well.
Inode creation does not need changing - extended refs are only added after
the ref array is full.
Signed-off-by: Mark Fasheh <mfasheh@suse.de>
fs/btrfs/ctree.c
fs/btrfs/disk-io.c
fs/btrfs/extent-tree.c
fs/btrfs/extent_io.c
fs/btrfs/extent_io.h
fs/btrfs/inode.c
fs/btrfs/scrub.c
Signed-off-by: Chris Mason <chris.mason@oracle.com>
A few years ago the btrfs code to support blocks lager than
the page size was disabled to fix a few corner cases in the
page cache handling. This fixes the code to properly support
large metadata blocks again.
Since current kernels will crash early and often with larger
metadata blocks, this adds an incompat bit so that older kernels
can't mount it.
This also does away with different blocksizes for nodes and leaves.
You get a single block size for all tree blocks.
btrfs currently handles most errors with BUG_ON. This patch is a work-in-
progress but aims to handle most errors other than internal logic
errors and ENOMEM more gracefully.
This iteration prevents most crashes but can run into lockups with
the page lock on occasion when the timing "works out."
btrfs_extend_item
Currently, btrfs_truncate_item and btrfs_extend_item returns only 0.
So, the check by BUG_ON in the caller is unnecessary.
Besides simplify the code, this change makes sure all metadata
reservation for normal metadata operations are released after
committing transaction.
Changes since V1:
Add code that check if unlink and rmdir will free space.
Add ENOSPC handling for clone ioctl.
Signed-off-by: Yan Zheng <zheng.yan@oracle.com>
For every hardlink in btrfs, there is a corresponding inode back
reference. All inode back references for hardlinks in a given
directory are stored in single b-tree item. The size of b-tree item
is limited by the size of b-tree leaf, so we can only create limited
number of hardlinks to a given file in a directory.
The original code lacks of the check, it oops if the number of
hardlinks goes over the limit. This patch fixes the issue by adding
check to btrfs_link and btrfs_rename.
The new back reference format does not allow reusing objectid of
deleted snapshot/subvol. So we use ++highest_objectid to allocate
objectid for new snapshot/subvol.
Now we use ++highest_objectid to allocate objectid for both new inode
and new snapshot/subvolume, so this patch removes 'find hole' code in
btrfs_find_free_objectid.
btrfs_mark_buffer dirty would set dirty bits in the extent_io tree
for the buffers it was dirtying. This may require a kmalloc and it
was not atomic. So, anyone who called btrfs_mark_buffer_dirty had to
set any btree locks they were holding to blocking first.
This commit changes dirty tracking for extent buffers to just use a flag
in the extent buffer. Now that we have one and only one extent buffer
per page, this can be safely done without losing dirty bits along the way.
This also introduces a path->leave_spinning flag that callers of
btrfs_search_slot can use to indicate they will properly deal with a
path returned where all the locks are spinning instead of blocking.
Many of the btree search callers now expect spinning paths,
resulting in better btree concurrency overall.
Shut up various sparse warnings about symbols that should be either
static or have their declarations in scope.
Almost none of the files including module.h need to do so,
remove them.
Include sched.h in extent-tree.c to silence a warning about cond_resched()
being undeclared.
Signed-off-by: Zach Brown <zach.brown@oracle.com>
Attaching below is some of the code cleanups that i came across while
reading the code.
a) alloc_path already calls init_path.
b) Mention that btrfs_inode is the in memory copy.Ext4 have ext4_inode_info as
the in memory copy ext4_inode as the disk copy
