path: root/fs/bio.c
2012-09-28block: makes bio_split support bio without dataShaohua Li
discard bio hasn't data attached. We hit a BUG_ON with such bio. This makes bio_split works for such bio. Signed-off-by: Shaohua Li <shli@fusionio.com> Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-09-20block: Implement support for WRITE SAMEMartin K. Petersen
The WRITE SAME command supported on some SCSI devices allows the same block to be efficiently replicated throughout a block range. Only a single logical block is transferred from the host and the storage device writes the same data to all blocks described by the I/O. This patch implements support for WRITE SAME in the block layer. The blkdev_issue_write_same() function can be used by filesystems and block drivers to replicate a buffer across a block range. This can be used to efficiently initialize software RAID devices, etc. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Mike Snitzer <snitzer@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-09-09block: Add bio_clone_bioset(), bio_clone_kmalloc()Kent Overstreet
Previously, there was bio_clone() but it only allocated from the fs bio set; as a result various users were open coding it and using __bio_clone(). This changes bio_clone() to become bio_clone_bioset(), and then we add bio_clone() and bio_clone_kmalloc() as wrappers around it, making use of the functionality the last patch adedd. This will also help in a later patch changing how bio cloning works. Signed-off-by: Kent Overstreet <koverstreet@google.com> CC: Jens Axboe <axboe@kernel.dk> CC: NeilBrown <neilb@suse.de> CC: Alasdair Kergon <agk@redhat.com> CC: Boaz Harrosh <bharrosh@panasas.com> CC: Jeff Garzik <jeff@garzik.org> Acked-by: Jeff Garzik <jgarzik@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-09-09block: Consolidate bio_alloc_bioset(), bio_kmalloc()Kent Overstreet
Previously, bio_kmalloc() and bio_alloc_bioset() behaved slightly different because there was some almost-duplicated code - this fixes some of that. The important change is that previously bio_kmalloc() always set bi_io_vec = bi_inline_vecs, even if nr_iovecs == 0 - unlike bio_alloc_bioset(). This would cause bio_has_data() to return true; I don't know if this resulted in any actual bugs but it was certainly wrong. bio_kmalloc() and bio_alloc_bioset() also have different arbitrary limits on nr_iovecs - 1024 (UIO_MAXIOV) for bio_kmalloc(), 256 (BIO_MAX_PAGES) for bio_alloc_bioset(). This patch doesn't fix that, but at least they're enforced closer together and hopefully they will be fixed in a later patch. This'll also help with some future cleanups - there are a fair number of functions that allocate bios (e.g. bio_clone()), and now they don't have to be duplicated for bio_alloc(), bio_alloc_bioset(), and bio_kmalloc(). Signed-off-by: Kent Overstreet <koverstreet@google.com> CC: Jens Axboe <axboe@kernel.dk> v7: Re-add dropped comments, improv patch description Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-09-09block: Kill bi_destructorKent Overstreet
Now that we've got generic code for freeing bios allocated from bio pools, this isn't needed anymore. This patch also makes bio_free() static, since without bi_destructor there should be no need for it to be called anywhere else. bio_free() is now only called from bio_put, so we can refactor those a bit - move some code from bio_put() to bio_free() and kill the redundant bio->bi_next = NULL. v5: Switch to BIO_KMALLOC_POOL ((void *)~0), per Boaz v6: BIO_KMALLOC_POOL now NULL, drop bio_free's EXPORT_SYMBOL v7: No #define BIO_KMALLOC_POOL anymore Signed-off-by: Kent Overstreet <koverstreet@google.com> CC: Jens Axboe <axboe@kernel.dk> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-09-09block: Add bio_reset()Kent Overstreet
Reusing bios is something that's been highly frowned upon in the past, but driver code keeps doing it anyways. If it's going to happen anyways, we should provide a generic method. This'll help with getting rid of bi_destructor - drivers/block/pktcdvd.c was open coding it, by doing a bio_init() and resetting bi_destructor. This required reordering struct bio, but the block layer is not yet nearly fast enough for any cacheline effects to matter here. v5: Add a define BIO_RESET_BITS, to be very explicit about what parts of bio->bi_flags are saved. v6: Further commenting verbosity, per Tejun v9: Add a function comment Signed-off-by: Kent Overstreet <koverstreet@google.com> CC: Jens Axboe <axboe@kernel.dk> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-09-09block: Ues bi_pool for bio_integrity_alloc()Kent Overstreet
Now that bios keep track of where they were allocated from, bio_integrity_alloc_bioset() becomes redundant. Remove bio_integrity_alloc_bioset() and drop bio_set argument from the related functions and make them use bio->bi_pool. Signed-off-by: Kent Overstreet <koverstreet@google.com> CC: Jens Axboe <axboe@kernel.dk> CC: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-09-09block: Generalized bio pool freeingKent Overstreet
With the old code, when you allocate a bio from a bio pool you have to implement your own destructor that knows how to find the bio pool the bio was originally allocated from. This adds a new field to struct bio (bi_pool) and changes bio_alloc_bioset() to use it. This makes various bio destructors unnecessary, so they're then deleted. v6: Explain the temporary if statement in bio_put Signed-off-by: Kent Overstreet <koverstreet@google.com> CC: Jens Axboe <axboe@kernel.dk> CC: NeilBrown <neilb@suse.de> CC: Alasdair Kergon <agk@redhat.com> CC: Nicholas Bellinger <nab@linux-iscsi.org> CC: Lars Ellenberg <lars.ellenberg@linbit.com> Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-08-25Merge branch 'for-linus' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull block-related fixes from Jens Axboe: - Improvements to the buffered and direct write IO plugging from Fengguang. - Abstract out the mapping of a bio in a request, and use that to provide a blk_bio_map_sg() helper. Useful for mapping just a bio instead of a full request. - Regression fix from Hugh, fixing up a patch that went into the previous release cycle (and marked stable, too) attempting to prevent a loop in __getblk_slow(). - Updates to discard requests, fixing up the sizing and how we align them. Also a change to disallow merging of discard requests, since that doesn't really work properly yet. - A few drbd fixes. - Documentation updates. * 'for-linus' of git://git.kernel.dk/linux-block: block: replace __getblk_slow misfix by grow_dev_page fix drbd: Write all pages of the bitmap after an online resize drbd: Finish requests that completed while IO was frozen drbd: fix drbd wire compatibility for empty flushes Documentation: update tunable options in block/cfq-iosched.txt Documentation: update tunable options in block/cfq-iosched.txt Documentation: update missing index files in block/00-INDEX block: move down direct IO plugging block: remove plugging at buffered write time block: disable discard request merge temporarily bio: Fix potential memory leak in bio_find_or_create_slab() block: Don't use static to define "void *p" in show_partition_start() block: Add blk_bio_map_sg() helper block: Introduce __blk_segment_map_sg() helper fs/block-dev.c:fix performance regression in O_DIRECT writes to md block devices block: split discard into aligned requests block: reorganize rounding of max_discard_sectors
2012-08-09bio: Fix potential memory leak in bio_find_or_create_slab()Alexey Khoroshilov
Do not leak memory by updating pointer with potentially NULL realloc return value. Found by Linux Driver Verification project (linuxtesting.org). Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru> Acked-by: Jeff Moyer <jmoyer@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-08-04vfs: nuke pdflush from commentsArtem Bityutskiy
The pdflush thread is long gone, so this patch removes references to pdflush from vfs comments. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-05-30Merge branch 'for-3.5/core' of git://git.kernel.dk/linux-blockLinus Torvalds
Merge block/IO core bits from Jens Axboe: "This is a bit bigger on the core side than usual, but that is purely because we decided to hold off on parts of Tejun's submission on 3.4 to give it a bit more time to simmer. As a consequence, it's seen a long cycle in for-next. It contains: - Bug fix from Dan, wrong locking type. - Relax splice gifting restriction from Eric. - A ton of updates from Tejun, primarily for blkcg. This improves the code a lot, making the API nicer and cleaner, and also includes fixes for how we handle and tie policies and re-activate on switches. The changes also include generic bug fixes. - A simple fix from Vivek, along with a fix for doing proper delayed allocation of the blkcg stats." Fix up annoying conflict just due to different merge resolution in Documentation/feature-removal-schedule.txt * 'for-3.5/core' of git://git.kernel.dk/linux-block: (92 commits) blkcg: tg_stats_alloc_lock is an irq lock vmsplice: relax alignement requirements for SPLICE_F_GIFT blkcg: use radix tree to index blkgs from blkcg blkcg: fix blkcg->css ref leak in __blkg_lookup_create() block: fix elvpriv allocation failure handling block: collapse blk_alloc_request() into get_request() blkcg: collapse blkcg_policy_ops into blkcg_policy blkcg: embed struct blkg_policy_data in policy specific data blkcg: mass rename of blkcg API blkcg: style cleanups for blk-cgroup.h blkcg: remove blkio_group->path[] blkcg: blkg_rwstat_read() was missing inline blkcg: shoot down blkgs if all policies are deactivated blkcg: drop stuff unused after per-queue policy activation update blkcg: implement per-queue policy activation blkcg: add request_queue->root_blkg blkcg: make request_queue bypassing on allocation blkcg: make sure blkg_lookup() returns %NULL if @q is bypassing blkcg: make blkg_conf_prep() take @pol and return with queue lock held blkcg: remove static policy ID enums ...
2012-05-11bio allocation failure due to bio_get_nr_vecs()Bernd Schubert
The number of bio_get_nr_vecs() is passed down via bio_alloc() to bvec_alloc_bs(), which fails the bio allocation if nr_iovecs > BIO_MAX_PAGES. For the underlying caller this causes an unexpected bio allocation failure. Limiting to queue_max_segments() is not sufficient, as max_segments also might be very large. bvec_alloc_bs(gfp_mask, nr_iovecs, ) => NULL when nr_iovecs > BIO_MAX_PAGES bio_alloc_bioset(gfp_mask, nr_iovecs, ...) bio_alloc(GFP_NOIO, nvecs) xfs_alloc_ioend_bio() Signed-off-by: Bernd Schubert <bernd.schubert@itwm.fraunhofer.de> Cc: stable@kernel.org Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-04-01Merge branch 'for-3.5' of ../cgroup into block/for-3.5/core-mergedTejun Heo
cgroup/for-3.5 contains the following changes which blk-cgroup needs to proceed with the on-going cleanup. * Dynamic addition and removal of cftypes to make config/stat file handling modular for policies. * cgroup removal update to not wait for css references to drain to fix blkcg removal hang caused by cfq caching cfqgs. Pull in cgroup/for-3.5 into block/for-3.5/core. This causes the following conflicts in block/blk-cgroup.c. * 761b3ef50e "cgroup: remove cgroup_subsys argument from callbacks" conflicts with blkiocg_pre_destroy() addition and blkiocg_attach() removal. Resolved by removing @subsys from all subsys methods. * 676f7c8f84 "cgroup: relocate cftype and cgroup_subsys definitions in controllers" conflicts with ->pre_destroy() and ->attach() updates and removal of modular config. Resolved by dropping forward declarations of the methods and applying updates to the relocated blkio_subsys. * 4baf6e3325 "cgroup: convert all non-memcg controllers to the new cftype interface" builds upon the previous item. Resolved by adding ->base_cftypes to the relocated blkio_subsys. Signed-off-by: Tejun Heo <tj@kernel.org>
2012-03-06block: implement bio_associate_current()Tejun Heo
IO scheduling and cgroup are tied to the issuing task via io_context and cgroup of %current. Unfortunately, there are cases where IOs need to be routed via a different task which makes scheduling and cgroup limit enforcement applied completely incorrectly. For example, all bios delayed by blk-throttle end up being issued by a delayed work item and get assigned the io_context of the worker task which happens to serve the work item and dumped to the default block cgroup. This is double confusing as bios which aren't delayed end up in the correct cgroup and makes using blk-throttle and cfq propio together impossible. Any code which punts IO issuing to another task is affected which is getting more and more common (e.g. btrfs). As both io_context and cgroup are firmly tied to task including userland visible APIs to manipulate them, it makes a lot of sense to match up tasks to bios. This patch implements bio_associate_current() which associates the specified bio with %current. The bio will record the associated ioc and blkcg at that point and block layer will use the recorded ones regardless of which task actually ends up issuing the bio. bio release puts the associated ioc and blkcg. It grabs and remembers ioc and blkcg instead of the task itself because task may already be dead by the time the bio is issued making ioc and blkcg inaccessible and those are all block layer cares about. elevator_set_req_fn() is updated such that the bio elvdata is being allocated for is available to the elevator. This doesn't update block cgroup policies yet. Further patches will implement the support. -v2: #ifdef CONFIG_BLK_CGROUP added around bio->bi_ioc dereference in rq_ioc() to fix build breakage. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Kent Overstreet <koverstreet@google.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2012-02-28fs: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-02-08bio: don't overflow in bio_get_nr_vecs()Kent Overstreet
There were two places bio_get_nr_vecs() could overflow: First, it did a left shift to convert from sectors to bytes immediately before dividing by PAGE_SIZE. If PAGE_SIZE ever was less than 512 a great many things would break, so dividing by PAGE_SIZE >> 9 is safe and will generate smaller code too. The nastier overflow was in the DIV_ROUND_UP() (that's what the code was effectively doing, anyways). If n + d overflowed, the whole thing would return 0 which breaks things rather effectively. bio_get_nr_vecs() doesn't claim to give an exact value anyways, so the DIV_ROUND_UP() is silly; we could do a straight divide except if a device's queue_max_sectors was less than PAGE_SIZE we'd return 0. So we just add 1; this should always be safe - things will break badly if bio_get_nr_vecs() returns > BIO_MAX_PAGES (bio_alloc() will suddenly start failing) but it's queue_max_segments that must guard against this, if queue_max_sectors is preventing this from happen things are going to explode on architectures with different PAGE_SIZE. Signed-off-by: Kent Overstreet <koverstreet@google.com> Cc: Tejun Heo <tj@kernel.org> Acked-by: Valdis Kletnieks <Valdis.Kletnieks@vt.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-11-16bio: change some signed vars to unsignedDan Carpenter
This is just a cleanup patch to silence a static checker warning. The problem is that we cap "nr_iovecs" so it can't be larger than "UIO_MAXIOV" but we don't check for negative values. It turns out this is prevented at other layers, but logically it doesn't make sense to have negative nr_iovecs so making it unsigned is nicer. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-10-24block: Remove the control of complete cpu from bio.Tao Ma
bio originally has the functionality to set the complete cpu, but it is broken. Chirstoph said that "This code is unused, and from the all the discussions lately pretty obviously broken. The only thing keeping it serves is creating more confusion and possibly more bugs." And Jens replied with "We can kill bio_set_completion_cpu(). I'm fine with leaving cpu control to the request based drivers, they are the only ones that can toggle the setting anyway". So this patch tries to remove all the work of controling complete cpu from a bio. Cc: Shaohua Li <shaohua.li@intel.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2011-05-27vfs: Improve the bio_add_page() and bio_add_pc_page() descriptionsAndreas Gruenbacher
The descriptions of bio_add_page() and bio_add_pc_page() are slightly inconsistent; improve them. Signed-off-by: Andreas Gruenbacher <agruen@kernel.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-22fs: use appropriate printk priority levelsMandeep Singh Baines
printk()s without a priority level default to KERN_WARNING. To reduce noise at KERN_WARNING, this patch set the priority level appriopriately for unleveled printks()s. This should be useful to folks that look at dmesg warnings closely. Signed-off-by: Mandeep Singh Baines <msb@chromium.org> Cc: Jens Axboe <axboe@kernel.dk> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-17block: Require subsystems to explicitly allocate bio_set integrity mempoolMartin K. Petersen
MD and DM create a new bio_set for every metadevice. Each bio_set has an integrity mempool attached regardless of whether the metadevice is capable of passing integrity metadata. This is a waste of memory. Instead we defer the allocation decision to MD and DM since we know at metadevice creation time whether integrity passthrough is needed or not. Automatic integrity mempool allocation can then be removed from bioset_create() and we make an explicit integrity allocation for the fs_bio_set. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Reported-by: Zdenek Kabelac <zkabelac@redhat.com> Acked-by: Mike Snitzer <snizer@redhat.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-08block: biovec_slab vs. CONFIG_BLK_DEV_INTEGRITYMartin K. Petersen
The block integrity subsystem no longer uses the bio_vec slabs so this code can safely be compiled in. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-10bio: take care not overflow page count when mapping/copying user dataJens Axboe
If the iovec is being set up in a way that causes uaddr + PAGE_SIZE to overflow, we could end up attempting to map a huge number of pages. Check for this invalid input type. Reported-by: Dan Rosenberg <drosenberg@vsecurity.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-11-10block: limit vec count in bio_kmalloc() and bio_alloc_map_data()Jens Axboe
2010-08-07block: unify flags for struct bio and struct requestChristoph Hellwig
Remove the current bio flags and reuse the request flags for the bio, too. This allows to more easily trace the type of I/O from the filesystem down to the block driver. There were two flags in the bio that were missing in the requests: BIO_RW_UNPLUG and BIO_RW_AHEAD. Also I've renamed two request flags that had a superflous RW in them. Note that the flags are in bio.h despite having the REQ_ name - as blkdev.h includes bio.h that is the only way to go for now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-03-19Merge branch 'master' into for-linusJens Axboe
Conflicts: block/Kconfig Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-08blkdev: fix merge_bvec_fn return value checks v2Dmitry Monakhov
merge_bvec_fn() returns bvec->bv_len on success. So we have to check against this value. But in case of fs_optimization merge we compare with wrong value. This patch must be included in b428cd6da7e6559aca69aa2e3a526037d3f20403 But accidentally i've forgot to add this in the initial patch. To make things straight let's replace all such checks. In fact this makes code easy to understand. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-03-02Revert "blkdev: fix merge_bvec_fn return value checks"Jens Axboe
This reverts commit 9f7cdbc33f36d28e57eaba0093f68f0d14c38c5b. It's causing oopses om dm setups, so revert it until we investigate. Reported-by: Dmitry Torokhov <dmitry.torokhov@gmail.com> Tested-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-02-28blkdev: fix merge_bvec_fn return value checksDmitry Monakhov
2010-02-26block: Consolidate phys_segment and hw_segment limitsMartin K. Petersen
Except for SCSI no device drivers distinguish between physical and hardware segment limits. Consolidate the two into a single segment limit. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-02-05bio: Fix outdated comment about bio_alloc_bioset()Jaak Ristioja
In commit 451a9ebf653d28337ba53ed5b4b70b0b9543cca1 bio_alloc_bioset() was refactored not to take NULL as a valid argument for bs. This patch changes the comment for that function accordingly. Currently, passing NULL as argument to parameter bs would result in a NULL pointer dereference. Signed-off-by: Jaak Ristioja <ristioja@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-28block: fix bio_add_page for non trivial merge_bvec_fn caseDmitry Monakhov
We have to properly decrease bi_size in order to merge_bvec_fn return right result. Otherwise this result in false merge rejects for two absolutely valid bio_vecs. This may cause significant performance penalty for example fs_block_size == 1k and block device is raid0 with small chunk_size = 8k. Then it is impossible to merge 7-th fs-block in to bio which already has 6 fs-blocks. Cc: <stable@kernel.org> Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-01-19fs/bio.c: fix shadows sparse warningThiago Farina
fs/bio.c:81:33: warning: symbol 'bslab' shadows an earlier one fs/bio.c:74:25: originally declared here Signed-off-by: Thiago Farina <tfransosi@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-26block: add helpers to run flush_dcache_page() against a bio and a request's ↵Ilya Loginov
pages Mtdblock driver doesn't call flush_dcache_page for pages in request. So, this causes problems on architectures where the icache doesn't fill from the dcache or with dcache aliases. The patch fixes this. The ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE symbol was introduced to avoid pointless empty cache-thrashing loops on architectures for which flush_dcache_page() is a no-op. Every architecture was provided with this flush pages on architectires where ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE is equal 1 or do nothing otherwise. See "fix mtd_blkdevs problem with caches on some architectures" discussion on LKML for more information. Signed-off-by: Ilya Loginov <isloginov@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Peter Horton <phorton@bitbox.co.uk> Cc: "Ed L. Cashin" <ecashin@coraid.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-11-02Fix bio_alloc() and bio_kmalloc() documentationAlberto Bertogli
Commit 451a9ebf accidentally broke bio_alloc() and bio_kmalloc() comments by (almost) swapping them. This patch fixes that, by placing the comments in the right place. Signed-off-by: Alberto Bertogli <albertito@blitiri.com.ar> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-11-02bio_put(): add bio_clone() to the list of functions in the commentAlberto Bertogli
In bio_put()'s comment, add bio_clone() to the list of functions that can give you a bio reference. Signed-off-by: Alberto Bertogli <albertito@blitiri.com.ar> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01fs/bio.c: move EXPORT* macros to line after functionH Hartley Sweeten
As mentioned in Documentation/CodingStyle, move EXPORT* macro's to the line immediately after the closing function brace line. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-10block: fix sg SG_DXFER_TO_FROM_DEV regressionFUJITA Tomonori
I overlooked SG_DXFER_TO_FROM_DEV support when I converted sg to use the block layer mapping API (2.6.28). Douglas Gilbert explained SG_DXFER_TO_FROM_DEV: http://www.spinics.net/lists/linux-scsi/msg37135.html = The semantics of SG_DXFER_TO_FROM_DEV were: - copy user space buffer to kernel (LLD) buffer - do SCSI command which is assumed to be of the DATA_IN (data from device) variety. This would overwrite some or all of the kernel buffer - copy kernel (LLD) buffer back to the user space. The idea was to detect short reads by filling the original user space buffer with some marker bytes ("0xec" it would seem in this report). The "resid" value is a better way of detecting short reads but that was only added this century and requires co-operation from the LLD. = This patch changes the block layer mapping API to support this semantics. This simply adds another field to struct rq_map_data and enables __bio_copy_iov() to copy data from user space even with READ requests. It's better to add the flags field and kills null_mapped and the new from_user fields in struct rq_map_data but that approach makes it difficult to send this patch to stable trees because st and osst drivers use struct rq_map_data (they were converted to use the block layer in 2.6.29 and 2.6.30). Well, I should clean up the block layer mapping API. zhou sf reported this regiression and tested this patch: http://www.spinics.net/lists/linux-scsi/msg37128.html http://www.spinics.net/lists/linux-scsi/msg37168.html Reported-by: zhou sf <sxzzsf@gmail.com> Tested-by: zhou sf <sxzzsf@gmail.com> Cc: stable@kernel.org Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-01block: Create bip slabs with embedded integrity vectorsMartin K. Petersen
This patch restores stacking ability to the block layer integrity infrastructure by creating a set of dedicated bip slabs. Each bip slab has an embedded bio_vec array at the end. This cuts down on memory allocations and also simplifies the code compared to the original bvec version. Only the largest bip slab is backed by a mempool. The pool is contained in the bio_set so stacking drivers can ensure forward progress. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@carl.(none)>
2009-06-16block: remove some includings of blktrace_api.hLi Zefan
When porting blktrace to tracepoints, we changed to trace/block.h for trace prober declarations. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-12trivial: fix typo in bio_alloc kernel docNikanth Karthikesan
Fix typo in bio_alloc kernel doc. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-11Merge branch 'for-2.6.31' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.31' of git://git.kernel.dk/linux-2.6-block: (153 commits) block: add request clone interface (v2) floppy: fix hibernation ramdisk: remove long-deprecated "ramdisk=" boot-time parameter fs/bio.c: add missing __user annotation block: prevent possible io_context->refcount overflow Add serial number support for virtio_blk, V4a block: Add missing bounce_pfn stacking and fix comments Revert "block: Fix bounce limit setting in DM" cciss: decode unit attention in SCSI error handling code cciss: Remove no longer needed sendcmd reject processing code cciss: change SCSI error handling routines to work with interrupts enabled. cciss: separate error processing and command retrying code in sendcmd_withirq_core() cciss: factor out fix target status processing code from sendcmd functions cciss: simplify interface of sendcmd() and sendcmd_withirq() cciss: factor out core of sendcmd_withirq() for use by SCSI error handling code cciss: Use schedule_timeout_uninterruptible in SCSI error handling code block: needs to set the residual length of a bidi request Revert "block: implement blkdev_readpages" block: Fix bounce limit setting in DM Removed reference to non-existing file Documentation/PCI/PCI-DMA-mapping.txt ... Manually fix conflicts with tracing updates in: block/blk-sysfs.c drivers/ide/ide-atapi.c drivers/ide/ide-cd.c drivers/ide/ide-floppy.c drivers/ide/ide-tape.c include/trace/events/block.h kernel/trace/blktrace.c
2009-06-10fs/bio.c: add missing __user annotationMichal Simek
As reported by sparse: fs/bio.c:720:13: warning: incorrect type in assignment (different address spaces) fs/bio.c:720:13: expected char *iov_addr fs/bio.c:720:13: got void [noderef] <asn:1>* fs/bio.c:724:36: warning: incorrect type in argument 2 (different address spaces) fs/bio.c:724:36: expected void const [noderef] <asn:1>*from fs/bio.c:724:36: got char *iov_addr Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-09tracing/events: convert block trace points to TRACE_EVENT()Li Zefan
TRACE_EVENT is a more generic way to define tracepoints. Doing so adds these new capabilities to this tracepoint: - zero-copy and per-cpu splice() tracing - binary tracing without printf overhead - structured logging records exposed under /debug/tracing/events - trace events embedded in function tracer output and other plugins - user-defined, per tracepoint filter expressions ... Cons: - no dev_t info for the output of plug, unplug_timer and unplug_io events. no dev_t info for getrq and sleeprq events if bio == NULL. no dev_t info for rq_abort,...,rq_requeue events if rq->rq_disk == NULL. This is mainly because we can't get the deivce from a request queue. But this may change in the future. - A packet command is converted to a string in TP_assign, not TP_print. While blktrace do the convertion just before output. Since pc requests should be rather rare, this is not a big issue. - In blktrace, an event can have 2 different print formats, but a TRACE_EVENT has a unique format, which means we have some unused data in a trace entry. The overhead is minimized by using __dynamic_array() instead of __array(). I've benchmarked the ioctl blktrace vs the splice based TRACE_EVENT tracing: dd dd + ioctl blktrace dd + TRACE_EVENT (splice) 1 7.36s, 42.7 MB/s 7.50s, 42.0 MB/s 7.41s, 42.5 MB/s 2 7.43s, 42.3 MB/s 7.48s, 42.1 MB/s 7.43s, 42.4 MB/s 3 7.38s, 42.6 MB/s 7.45s, 42.2 MB/s 7.41s, 42.5 MB/s So the overhead of tracing is very small, and no regression when using those trace events vs blktrace. And the binary output of TRACE_EVENT is much smaller than blktrace: # ls -l -h -rw-r--r-- 1 root root 8.8M 06-09 13:24 sda.blktrace.0 -rw-r--r-- 1 root root 195K 06-09 13:24 sda.blktrace.1 -rw-r--r-- 1 root root 2.7M 06-09 13:25 trace_splice.out Following are some comparisons between TRACE_EVENT and blktrace: plug: kjournald-480 [000] 303.084981: block_plug: [kjournald] kjournald-480 [000] 303.084981: 8,0 P N [kjournald] unplug_io: kblockd/0-118 [000] 300.052973: block_unplug_io: [kblockd/0] 1 kblockd/0-118 [000] 300.052974: 8,0 U N [kblockd/0] 1 remap: kjournald-480 [000] 303.085042: block_remap: 8,0 W 102736992 + 8 <- (8,8) 33384 kjournald-480 [000] 303.085043: 8,0 A W 102736992 + 8 <- (8,8) 33384 bio_backmerge: kjournald-480 [000] 303.085086: block_bio_backmerge: 8,0 W 102737032 + 8 [kjournald] kjournald-480 [000] 303.085086: 8,0 M W 102737032 + 8 [kjournald] getrq: kjournald-480 [000] 303.084974: block_getrq: 8,0 W 102736984 + 8 [kjournald] kjournald-480 [000] 303.084975: 8,0 G W 102736984 + 8 [kjournald] bash-2066 [001] 1072.953770: 8,0 G N [bash] bash-2066 [001] 1072.953773: block_getrq: 0,0 N 0 + 0 [bash] rq_complete: konsole-2065 [001] 300.053184: block_rq_complete: 8,0 W () 103669040 + 16 [0] konsole-2065 [001] 300.053191: 8,0 C W 103669040 + 16 [0] ksoftirqd/1-7 [001] 1072.953811: 8,0 C N (5a 00 08 00 00 00 00 00 24 00) [0] ksoftirqd/1-7 [001] 1072.953813: block_rq_complete: 0,0 N (5a 00 08 00 00 00 00 00 24 00) 0 + 0 [0] rq_insert: kjournald-480 [000] 303.084985: block_rq_insert: 8,0 W 0 () 102736984 + 8 [kjournald] kjournald-480 [000] 303.084986: 8,0 I W 102736984 + 8 [kjournald] Changelog from v2 -> v3: - use the newly introduced __dynamic_array(). Changelog from v1 -> v2: - use __string() instead of __array() to minimize the memory required to store hex dump of rq->cmd(). - support large pc requests. - add missing blk_fill_rwbs_rq() in block_rq_requeue TRACE_EVENT. - some cleanups. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4A2DF669.5070905@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
