path: root/fs/bio.c
2010-01-28block: fix bio_add_page for non trivial merge_bvec_fn caseDmitry Monakhov
We have to properly decrease bi_size in order to merge_bvec_fn return right result. Otherwise this result in false merge rejects for two absolutely valid bio_vecs. This may cause significant performance penalty for example fs_block_size == 1k and block device is raid0 with small chunk_size = 8k. Then it is impossible to merge 7-th fs-block in to bio which already has 6 fs-blocks. Cc: <stable@kernel.org> Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2010-01-19fs/bio.c: fix shadows sparse warningThiago Farina
fs/bio.c:81:33: warning: symbol 'bslab' shadows an earlier one fs/bio.c:74:25: originally declared here Signed-off-by: Thiago Farina <tfransosi@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-11-26block: add helpers to run flush_dcache_page() against a bio and a request's ↵Ilya Loginov
pages Mtdblock driver doesn't call flush_dcache_page for pages in request. So, this causes problems on architectures where the icache doesn't fill from the dcache or with dcache aliases. The patch fixes this. The ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE symbol was introduced to avoid pointless empty cache-thrashing loops on architectures for which flush_dcache_page() is a no-op. Every architecture was provided with this flush pages on architectires where ARCH_IMPLEMENTS_FLUSH_DCACHE_PAGE is equal 1 or do nothing otherwise. See "fix mtd_blkdevs problem with caches on some architectures" discussion on LKML for more information. Signed-off-by: Ilya Loginov <isloginov@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Peter Horton <phorton@bitbox.co.uk> Cc: "Ed L. Cashin" <ecashin@coraid.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-11-02Fix bio_alloc() and bio_kmalloc() documentationAlberto Bertogli
Commit 451a9ebf accidentally broke bio_alloc() and bio_kmalloc() comments by (almost) swapping them. This patch fixes that, by placing the comments in the right place. Signed-off-by: Alberto Bertogli <albertito@blitiri.com.ar> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-11-02bio_put(): add bio_clone() to the list of functions in the commentAlberto Bertogli
In bio_put()'s comment, add bio_clone() to the list of functions that can give you a bio reference. Signed-off-by: Alberto Bertogli <albertito@blitiri.com.ar> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-10-01fs/bio.c: move EXPORT* macros to line after functionH Hartley Sweeten
As mentioned in Documentation/CodingStyle, move EXPORT* macro's to the line immediately after the closing function brace line. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-10block: fix sg SG_DXFER_TO_FROM_DEV regressionFUJITA Tomonori
I overlooked SG_DXFER_TO_FROM_DEV support when I converted sg to use the block layer mapping API (2.6.28). Douglas Gilbert explained SG_DXFER_TO_FROM_DEV: http://www.spinics.net/lists/linux-scsi/msg37135.html = The semantics of SG_DXFER_TO_FROM_DEV were: - copy user space buffer to kernel (LLD) buffer - do SCSI command which is assumed to be of the DATA_IN (data from device) variety. This would overwrite some or all of the kernel buffer - copy kernel (LLD) buffer back to the user space. The idea was to detect short reads by filling the original user space buffer with some marker bytes ("0xec" it would seem in this report). The "resid" value is a better way of detecting short reads but that was only added this century and requires co-operation from the LLD. = This patch changes the block layer mapping API to support this semantics. This simply adds another field to struct rq_map_data and enables __bio_copy_iov() to copy data from user space even with READ requests. It's better to add the flags field and kills null_mapped and the new from_user fields in struct rq_map_data but that approach makes it difficult to send this patch to stable trees because st and osst drivers use struct rq_map_data (they were converted to use the block layer in 2.6.29 and 2.6.30). Well, I should clean up the block layer mapping API. zhou sf reported this regiression and tested this patch: http://www.spinics.net/lists/linux-scsi/msg37128.html http://www.spinics.net/lists/linux-scsi/msg37168.html Reported-by: zhou sf <sxzzsf@gmail.com> Tested-by: zhou sf <sxzzsf@gmail.com> Cc: stable@kernel.org Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-07-01block: Create bip slabs with embedded integrity vectorsMartin K. Petersen
This patch restores stacking ability to the block layer integrity infrastructure by creating a set of dedicated bip slabs. Each bip slab has an embedded bio_vec array at the end. This cuts down on memory allocations and also simplifies the code compared to the original bvec version. Only the largest bip slab is backed by a mempool. The pool is contained in the bio_set so stacking drivers can ensure forward progress. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <axboe@carl.(none)>
2009-06-16block: remove some includings of blktrace_api.hLi Zefan
When porting blktrace to tracepoints, we changed to trace/block.h for trace prober declarations. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-12trivial: fix typo in bio_alloc kernel docNikanth Karthikesan
Fix typo in bio_alloc kernel doc. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-11Merge branch 'for-2.6.31' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.31' of git://git.kernel.dk/linux-2.6-block: (153 commits) block: add request clone interface (v2) floppy: fix hibernation ramdisk: remove long-deprecated "ramdisk=" boot-time parameter fs/bio.c: add missing __user annotation block: prevent possible io_context->refcount overflow Add serial number support for virtio_blk, V4a block: Add missing bounce_pfn stacking and fix comments Revert "block: Fix bounce limit setting in DM" cciss: decode unit attention in SCSI error handling code cciss: Remove no longer needed sendcmd reject processing code cciss: change SCSI error handling routines to work with interrupts enabled. cciss: separate error processing and command retrying code in sendcmd_withirq_core() cciss: factor out fix target status processing code from sendcmd functions cciss: simplify interface of sendcmd() and sendcmd_withirq() cciss: factor out core of sendcmd_withirq() for use by SCSI error handling code cciss: Use schedule_timeout_uninterruptible in SCSI error handling code block: needs to set the residual length of a bidi request Revert "block: implement blkdev_readpages" block: Fix bounce limit setting in DM Removed reference to non-existing file Documentation/PCI/PCI-DMA-mapping.txt ... Manually fix conflicts with tracing updates in: block/blk-sysfs.c drivers/ide/ide-atapi.c drivers/ide/ide-cd.c drivers/ide/ide-floppy.c drivers/ide/ide-tape.c include/trace/events/block.h kernel/trace/blktrace.c
2009-06-10fs/bio.c: add missing __user annotationMichal Simek
As reported by sparse: fs/bio.c:720:13: warning: incorrect type in assignment (different address spaces) fs/bio.c:720:13: expected char *iov_addr fs/bio.c:720:13: got void [noderef] <asn:1>* fs/bio.c:724:36: warning: incorrect type in argument 2 (different address spaces) fs/bio.c:724:36: expected void const [noderef] <asn:1>*from fs/bio.c:724:36: got char *iov_addr Signed-off-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-06-09tracing/events: convert block trace points to TRACE_EVENT()Li Zefan
TRACE_EVENT is a more generic way to define tracepoints. Doing so adds these new capabilities to this tracepoint: - zero-copy and per-cpu splice() tracing - binary tracing without printf overhead - structured logging records exposed under /debug/tracing/events - trace events embedded in function tracer output and other plugins - user-defined, per tracepoint filter expressions ... Cons: - no dev_t info for the output of plug, unplug_timer and unplug_io events. no dev_t info for getrq and sleeprq events if bio == NULL. no dev_t info for rq_abort,...,rq_requeue events if rq->rq_disk == NULL. This is mainly because we can't get the deivce from a request queue. But this may change in the future. - A packet command is converted to a string in TP_assign, not TP_print. While blktrace do the convertion just before output. Since pc requests should be rather rare, this is not a big issue. - In blktrace, an event can have 2 different print formats, but a TRACE_EVENT has a unique format, which means we have some unused data in a trace entry. The overhead is minimized by using __dynamic_array() instead of __array(). I've benchmarked the ioctl blktrace vs the splice based TRACE_EVENT tracing: dd dd + ioctl blktrace dd + TRACE_EVENT (splice) 1 7.36s, 42.7 MB/s 7.50s, 42.0 MB/s 7.41s, 42.5 MB/s 2 7.43s, 42.3 MB/s 7.48s, 42.1 MB/s 7.43s, 42.4 MB/s 3 7.38s, 42.6 MB/s 7.45s, 42.2 MB/s 7.41s, 42.5 MB/s So the overhead of tracing is very small, and no regression when using those trace events vs blktrace. And the binary output of TRACE_EVENT is much smaller than blktrace: # ls -l -h -rw-r--r-- 1 root root 8.8M 06-09 13:24 sda.blktrace.0 -rw-r--r-- 1 root root 195K 06-09 13:24 sda.blktrace.1 -rw-r--r-- 1 root root 2.7M 06-09 13:25 trace_splice.out Following are some comparisons between TRACE_EVENT and blktrace: plug: kjournald-480 [000] 303.084981: block_plug: [kjournald] kjournald-480 [000] 303.084981: 8,0 P N [kjournald] unplug_io: kblockd/0-118 [000] 300.052973: block_unplug_io: [kblockd/0] 1 kblockd/0-118 [000] 300.052974: 8,0 U N [kblockd/0] 1 remap: kjournald-480 [000] 303.085042: block_remap: 8,0 W 102736992 + 8 <- (8,8) 33384 kjournald-480 [000] 303.085043: 8,0 A W 102736992 + 8 <- (8,8) 33384 bio_backmerge: kjournald-480 [000] 303.085086: block_bio_backmerge: 8,0 W 102737032 + 8 [kjournald] kjournald-480 [000] 303.085086: 8,0 M W 102737032 + 8 [kjournald] getrq: kjournald-480 [000] 303.084974: block_getrq: 8,0 W 102736984 + 8 [kjournald] kjournald-480 [000] 303.084975: 8,0 G W 102736984 + 8 [kjournald] bash-2066 [001] 1072.953770: 8,0 G N [bash] bash-2066 [001] 1072.953773: block_getrq: 0,0 N 0 + 0 [bash] rq_complete: konsole-2065 [001] 300.053184: block_rq_complete: 8,0 W () 103669040 + 16 [0] konsole-2065 [001] 300.053191: 8,0 C W 103669040 + 16 [0] ksoftirqd/1-7 [001] 1072.953811: 8,0 C N (5a 00 08 00 00 00 00 00 24 00) [0] ksoftirqd/1-7 [001] 1072.953813: block_rq_complete: 0,0 N (5a 00 08 00 00 00 00 00 24 00) 0 + 0 [0] rq_insert: kjournald-480 [000] 303.084985: block_rq_insert: 8,0 W 0 () 102736984 + 8 [kjournald] kjournald-480 [000] 303.084986: 8,0 I W 102736984 + 8 [kjournald] Changelog from v2 -> v3: - use the newly introduced __dynamic_array(). Changelog from v1 -> v2: - use __string() instead of __array() to minimize the memory required to store hex dump of rq->cmd(). - support large pc requests. - add missing blk_fill_rwbs_rq() in block_rq_requeue TRACE_EVENT. - some cleanups. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> LKML-Reference: <4A2DF669.5070905@cn.fujitsu.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-05-22block: Use accessor functions for queue limitsMartin K. Petersen
Convert all external users of queue limits to using wrapper functions instead of poking the request queue variables directly. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-22block: Do away with the notion of hardsect_sizeMartin K. Petersen
Until now we have had a 1:1 mapping between storage device physical block size and the logical block sized used when addressing the device. With SATA 4KB drives coming out that will no longer be the case. The sector size will be 4KB but the logical block size will remain 512-bytes. Hence we need to distinguish between the physical block size and the logical ditto. This patch renames hardsect_size to logical_block_size. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-22Merge branch 'master' into for-2.6.31Jens Axboe
Conflicts: drivers/block/hd.c drivers/block/mg_disk.c Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-19bio: always copy back data for copied kernel requestsTejun Heo
When a read bio_copy_kern() request fails, the content of the bounce buffer is not copied back. However, as request failure doesn't necessarily mean complete failure, the buffer state can be useful. This behavior is also inconsistent with the user map counterpart and causes the subtle difference between bounced and unbounced IO causes confusion. This patch makes bio_copy_kern_endio() ignore @err and always copy back data on request completion. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Boaz Harrosh <bharrosh@panasas.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28bio: fix memcpy corruption in bio_copy_user_iov()FUJITA Tomonori
st driver uses blk_rq_map_user() in order to just build a request out of page frames. In this case, map_data->offset is a non zero value and iov[0].iov_base is NULL. We need to increase nr_pages for that. Cc: stable@kernel.org Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-22bio: use bio_kmalloc() in copy/map functionsTejun Heo
Impact: remove possible deadlock condition There is no reason to use mempool backed allocation for map functions. Also, because kern mapping is used inside LLDs (e.g. for EH), using mempool backed allocation can lead to deadlock under extreme conditions (mempool already consumed by the time a request reached EH and requests are blocked on EH). Switch copy/map functions to bio_kmalloc(). Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-22bio: fix bio_kmalloc()Tejun Heo
Impact: fix bio_kmalloc() and its destruction path bio_kmalloc() was broken in two ways. * bvec_alloc_bs() first allocates bvec using kmalloc() and then ignores it and allocates again like non-kmalloc bvecs. * bio_kmalloc_destructor() didn't check for and free bio integrity data. This patch fixes the above problems. kmalloc patch is separated out from bio_alloc_bioset() and allocates the requested number of bvecs as inline bvecs. * bio_alloc_bioset() no longer takes NULL @bs. None other than bio_kmalloc() used it and outside users can't know how it was allocated anyway. * Define and use BIO_POOL_NONE so that pool index check in bvec_free_bs() triggers if inline or kmalloc allocated bvec gets there. * Relocate destructors on top of each allocation function so that how they're used is more clear. Jens Axboe suggested allocating bvecs inline. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-15bio: add documentation to bio_alloc()Jens Axboe
Explain that with __GFP_WAIT set it will not fail, and that the caller must never allocate more than 1 bio at the time. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-30trivial: Fix typo in bio_split()'s documentationAlberto Bertogli
Signed-off-by: Alberto Bertogli <albertito@blitiri.com.ar> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-24block: add private bio_set for bio integrity allocationsMartin K. Petersen
The integrity bio allocation needs its own bio_set to avoid violating the mempool allocation rules and risking deadlocks. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-24block: don't create bio_vec slabs of less than the inline numberJens Axboe
If we don't have CONFIG_BLK_DEV_INTEGRITY set, then we don't have any external dependencies on the bio_vec slabs. So don't create the ones that we will inline anyway. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-24block: cleanup bio_alloc_bioset()Ingo Molnar
this warning (which got fixed by commit b2bf968): fs/bio.c: In function ‘bio_alloc_bioset’: fs/bio.c:305: warning: ‘p’ may be used uninitialized in this function Triggered because the code flow in bio_alloc_bioset() is correct but a bit complex for the compiler to see through. Streamline it a bit - this also makes the code a tiny bit more compact: text data bss dec hex filename 7540 256 40 7836 1e9c bio.o.before 7539 256 40 7835 1e9b bio.o.after Also remove an older compiler-warnings annotation from this function, it's not needed. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-14block: fix memory leak in bio_clone()Li Zefan
If bio_integrity_clone() fails, bio_clone() returns NULL without freeing the newly allocated bio. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-03-14block: Add gfp_mask parameter to bio_integrity_clone()un'ichi Nomura
Stricter gfp_mask might be required for clone allocation. For example, request-based dm may clone bio in interrupt context so it has to use GFP_ATOMIC. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Acked-by: Martin K. Petersen <martin.petersen@oracle.com> Cc: Alasdair G Kergon <agk@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-02-26block: fix bogus gcc warning for uninitialized var usageJens Axboe
Newer gcc throw this warning: fs/bio.c: In function ?bio_alloc_bioset?: fs/bio.c:305: warning: ?p? may be used uninitialized in this function since it cannot figure out that 'p' is only ever used if 'bs' is non-NULL. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-02-18fs/bio: bio_alloc_bioset: pass right object ptr to mempool_freeSubhash Peddamallu
When freeing from bio pool use right ptr to account for bs->front_pad, instead of bio ptr, Signed-off-by: Subhash Peddamallu <subhash.peddamallu@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-01-02[SCSI] block: make blk_rq_map_user take a NULL user-space buffer for WRITEFUJITA Tomonori
The commit 818827669d85b84241696ffef2de485db46b0b5e (block: make blk_rq_map_user take a NULL user-space buffer) extended blk_rq_map_user to accept a NULL user-space buffer with a READ command. It was necessary to convert sg to use the block layer mapping API. This patch extends blk_rq_map_user again for a WRITE command. It is necessary to convert st and osst drivers to use the block layer apping API. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] block: fix the partial mappings with struct rq_map_dataFUJITA Tomonori
This fixes bio_copy_user_iov to properly handle the partial mappings with struct rq_map_data (which only sg uses for now but st and osst will shortly). It adds the offset member to struct rq_map_data and changes blk_rq_map_user to update it so that bio_copy_user_iov can add an appropriate page frame via bio_add_pc_page(). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-01-02[SCSI] block: fix bio_add_page misuse with rq_map_dataFUJITA Tomonori
This fixes bio_add_page misuse in bio_copy_user_iov with rq_map_data, which only sg uses now. rq_map_data carries page frames for bio_add_pc_page. bio_copy_user_iov uses bio_add_pc_page with a larger size than PAGE_SIZE. It's clearly wrong. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-12-29bio: get rid of bio_vec clearingJens Axboe
We don't need to clear the memory used for adding bio_vec entries, since nobody should be looking at members unitialized. Any valid use should be below bio->bi_vcnt, and that members up until that count must be valid since they were added through bio_add_page(). Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29bio: add support for inlining a number of bio_vecs inside the bioJens Axboe
When we go and allocate a bio for IO, we actually do two allocations. One for the bio itself, and one for the bi_io_vec that holds the actual pages we are interested in. This feature inlines a definable amount of io vecs inside the bio itself, so we eliminate the bio_vec array allocation for IO's up to a certain size. It defaults to 4 vecs, which is typically 16k of IO. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29bio: allow individual slabs in the bio_setJens Axboe
Instead of having a global bio slab cache, add a reference to one in each bio_set that is created. This allows for personalized slabs in each bio_set, so that they can have bios of different sizes. This means we can personalize the bios we return. File systems may want to embed the bio inside another structure, to avoid allocation more items (and stuffing them in ->bi_private) after the get a bio. Or we may want to embed a number of bio_vecs directly at the end of a bio, to avoid doing two allocations to return a bio. This is now possible. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29bio: move the slab pointer inside the bio_setJens Axboe
In preparation for adding differently sized bios. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-12-29bio: only mempool back the largest bio_vec slab cacheJens Axboe
We only very rarely need the mempool backing, so it makes sense to get rid of all but one of the mempool in a bio_set. So keep the largest bio_vec count mempool so we can always honor the largest allocation, and "upgrade" callers that fail. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-11-26blktrace: port to tracepoints, updateIngo Molnar
Port to the new tracepoints API: split DEFINE_TRACE() and DECLARE_TRACE() sites. Spread them out to the usage sites, as suggested by Mathieu Desnoyers. Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca>
2008-11-26blktrace: port to tracepointsArnaldo Carvalho de Melo
This was a forward port of work done by Mathieu Desnoyers, I changed it to encode the 'what' parameter on the tracepoint name, so that one can register interest in specific events and not on classes of events to then check the 'what' parameter. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-09block: mark bio_split_pool staticDenis ChengRq
Since all bio_split calls refer the same single bio_split_pool, the bio_split function can use bio_split_pool directly instead of the mempool_t parameter; then the mempool_t parameter can be removed from bio_split param list, and bio_split_pool is only referred in fs/bio.c file, can be marked static. Signed-off-by: Denis ChengRq <crquan@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: Find bio sector offset given idx and offsetMartin K. Petersen
Helper function to find the sector offset in a bio given bvec index and page offset. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: add bio_kmalloc()Jens Axboe
Not all callers need (or want!) the mempool backing guarentee, it essentially means that you can only use bio_alloc() for short allocations and not for preallocating some bio's at setup or init time. So add bio_kmalloc() which does the same thing as bio_alloc(), except it just uses kmalloc() as the backing instead of the bio mempools. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: make blk_rq_map_user take a NULL user-space bufferFUJITA Tomonori
This patch changes blk_rq_map_user to accept a NULL user-space buffer with a READ command if rq_map_data is not NULL. Thus a caller can pass page frames to lk_rq_map_user to just set up a request and bios with page frames propely. bio_uncopy_user (called via blk_rq_unmap_user) doesn't copy data to user space with such request. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09bio: convert bio_copy_kern to use bio_copy_userFUJITA Tomonori
bio_copy_kern and bio_copy_user are very similar. This converts bio_copy_kern to use bio_copy_user. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: introduce struct rq_map_data to use reserved pagesFUJITA Tomonori
This patch introduces struct rq_map_data to enable bio_copy_use_iov() use reserved pages. Currently, bio_copy_user_iov allocates bounce pages but drivers/scsi/sg.c wants to allocate pages by itself and use them. struct rq_map_data can be used to pass allocated pages to bio_copy_user_iov. The current users of bio_copy_user_iov simply passes NULL (they don't want to use pre-allocated pages). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Douglas Gilbert <dougg@torque.net> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: add gfp_mask argument to blk_rq_map_user and blk_rq_map_user_iovFUJITA Tomonori
Currently, blk_rq_map_user and blk_rq_map_user_iov always do GFP_KERNEL allocation. This adds gfp_mask argument to blk_rq_map_user and blk_rq_map_user_iov so sg can use it (sg always does GFP_ATOMIC allocation). Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Douglas Gilbert <dougg@torque.net> Cc: Mike Christie <michaelc@cs.wisc.edu> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: add support for IO CPU affinityJens Axboe
This patch adds support for controlling the IO completion CPU of either all requests on a queue, or on a per-request basis. We export a sysfs variable (rq_affinity) which, if set, migrates completions of requests to the CPU that originally submitted it. A bio helper (bio_set_completion_cpu()) is also added, so that queuers can ask for completion on that specific CPU. In testing, this has been show to cut the system time by as much as 20-40% on synthetic workloads where CPU affinity is desired. This requires a little help from the architecture, so it'll only work as designed for archs that are using the new generic smp helper infrastructure. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09drop vmerge accountingMikulas Patocka
Remove hw_segments field from struct bio and struct request. Without virtual merge accounting they have no purpose. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
