After we moved inode_sync_wait() from end_writeback() it doesn't make sense
to call the function end_writeback() anymore. Rename it to clear_inode()
which well says what the function really does - set I_CLEAR flag.
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
vfs_create() ignores everything outside of 16bit subset of its
mode argument; switching it to umode_t is obviously equivalent
and it's the only caller of the method
Seeing that just about every destructor got that INIT_LIST_HEAD() copied into
it, there is no point whatsoever keeping this INIT_LIST_HEAD in inode_init_once();
the cost of taking it into inode_init_always() will be negligible for pipes
and sockets and negative for everything else. Not to mention the removal of
boilerplate code from ->destroy_inode() instances...
Replace remaining direct i_nlink updates with a new set_nlink()
updater function.
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com>
Bfs does not have problems with references to unlinked directories.
CC: tigran@aivazian.fsnet.co.uk
Signed-off-by: Sage Weil <sage@newdream.net>
Only a few file systems need this. Start by pushing it down into each
rename method (except gfs2 and xfs) so that it can be dealt with on a
per-fs basis.
Acked-by: Christoph Hellwig <hch@lst.de>
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits)
Documentation/iostats.txt: bit-size reference etc.
cfq-iosched: removing unnecessary think time checking
cfq-iosched: Don't clear queue stats when preempt.
blk-throttle: Reset group slice when limits are changed
blk-cgroup: Only give unaccounted_time under debug
cfq-iosched: Don't set active queue in preempt
block: fix non-atomic access to genhd inflight structures
block: attempt to merge with existing requests on plug flush
block: NULL dereference on error path in __blkdev_get()
cfq-iosched: Don't update group weights when on service tree
fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away
block: Require subsystems to explicitly allocate bio_set integrity mempool
jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
fs: make fsync_buffers_list() plug
mm: make generic_writepages() use plugging
blk-cgroup: Add unaccounted time to timeslice_used.
block: fixup plugging stubs for !CONFIG_BLOCK
block: remove obsolete comments for blkdev_issue_zeroout.
blktrace: Use rq->cmd_flags directly in blk_add_trace_rq.
Fix up conflicts in fs/{aio.c,super.c}
The usage of find_first_zero_bit() in bfs_create() is wrong for two
reasons.
The bitmap size argument to find_first_zero_bit() is info->si_lasti but
the correct bitmap size is info->si_lasti + 1 as info->si_lasti is the
last valid index in info->si_imap bitmap.
Another problem is that it is impossible to detect that info->si_imap
bitmap is full because there is an off-by-one bug in the return value
check for find_first_zero_bit(). If no zero bits exist in info->si_imap,
find_first_zero_bit() returns info->si_lasti. But the check can't catch
it due to the off-by-one.
Acked-by: "Tigran A. Aivazian" <tigran@aivazian.fsnet.co.uk>
Code has been converted over to the new explicit on-stack plugging,
and delay users have been converted to use the new API for that.
So lets kill off the old plugging along with aops->sync_page().
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
RCU free the struct inode. This will allow:
- Subsequent store-free path walking patch. The inode must be consulted for
permissions when walking, so an RCU inode reference is a must.
- sb_inode_list_lock to be moved inside i_lock because sb list walkers who want
to take i_lock no longer need to take sb_inode_list_lock to walk the list in
the first place. This will simplify and optimize locking.
- Could remove some nested trylock loops in dcache code
- Could potentially simplify things a bit in VM land. Do not need to take the
page lock to follow page->mapping.
The downsides of this is the performance cost of using RCU. In a simple
creat/unlink microbenchmark, performance drops by about 10% due to inability to
reuse cache-hot slab objects. As iterations increase and RCU freeing starts
kicking over, this increases to about 20%.
In cases where inode lifetimes are longer (ie. many inodes may be allocated
during the average life span of a single inode), a lot of this cache reuse is
not applicable, so the regression caused by this patch is smaller.
The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU,
however this adds some complexity to list walking and store-free path walking,
so I prefer to implement this at a later date, if it is shown to be a win in
real situations. I haven't found a regression in any non-micro benchmark so I
doubt it will be a problem.
Signed-off-by: Nick Piggin <npiggin@kernel.dk>
... and switch of the obvious get_sb_bdev() users to ->mount()
Clones an existing reference to inode; caller must already hold one.
The BKL is only used in put_super and fill_super that are both protected by
the superblocks s_umount rw_semaphore. Therefore it is safe to remove the BKL
entirely.
Signed-off-by: Jan Blunck <jblunck@infradead.org>
This patch is a preparation necessary to remove the BKL from do_new_mount().
It explicitly adds calls to lock_kernel()/unlock_kernel() around
get_sb/fill_super operations for filesystems that still uses the BKL.
I've read through all the code formerly covered by the BKL inside
do_kern_mount() and have satisfied myself that it doesn't need the BKL
any more.
do_kern_mount() is already called without the BKL when mounting the rootfs
and in nfsctl. do_kern_mount() calls vfs_kern_mount(), which is called
from various places without BKL: simple_pin_fs(), nfs_do_clone_mount()
through nfs_follow_mountpoint(), afs_mntpt_do_automount() through
afs_mntpt_follow_link(). Both later functions are actually the filesystems
follow_link inode operation. vfs_kern_mount() is calling the specified
get_sb function and lets the filesystem do its job by calling the given
fill_super function.
Therefore I think it is safe to push down the BKL from the VFS to the
low-level filesystems get_sb/fill_super operation.
[arnd: do not add the BKL to those file systems that already
don't use it elsewhere]
Cc: Matthew Wilcox <matthew@wil.cx>
BFS is a very simple FS and its superblocks contains only static
information and is never changed. However, the BFS code for some
misterious reasons marked its buffer head as dirty from time to
time, but nothing in that buffer was ever changed.
This patch removes all the BFS superblock manipulation, simply
because it is not needed. It removes:
1. The si_sbh filed from 'struct bfs_sb_info' because it is not
needed. We only need to read the SB once on mount to get the
start of data blocks and the FS size. After this, we can forget
about the SB.
2. All instances of 'mark_buffer_dirty(sbh)' for BFS SB because
it is never changed.
3. The '->sync_fs()' method because there is nothing to sync
(inodes are synched by VFS).
4. The '->write_super()' method, again, because the SB is never
changed.
Tested-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
Move the call to vmtruncate to get rid of accessive blocks to the callers
in preparation of the new truncate sequence and rename the non-truncating
version to block_write_begin.
While we're at it also remove several unused arguments to block_write_begin.
We don't name our generic fsync implementations very well currently.
The no-op implementation for in-memory filesystems currently is called
simple_sync_file which doesn't make too much sense to start with,
the the generic one for simple filesystems is called simple_fsync
which can lead to some confusion.
This patch renames the generic file fsync method to generic_file_fsync
to match the other generic_file_* routines it is supposed to be used
with, and the no-op implementation to noop_fsync to make it obvious
what to expect. In addition add some documentation for both methods.
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org>
This gives the filesystem more information about the writeback that
is happening. Trond requested this for the NFS unstable write handling,
and other filesystems might benefit from this too by beeing able to
distinguish between the different callers in more detail.
double iput(), leaks...
* Remove smp_lock.h from files which don't need it (including some headers!)
* Add smp_lock.h to files which do need it
* Make smp_lock.h include conditional in hardirq.h
It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT
This will make hardirq.h inclusion cheaper for every PREEMPT=n config
(which includes allmodconfig/allyesconfig, BTW)
Add a ->sync_fs method for data integrity syncs, and reimplement
->write_super ontop of it.
Move BKL into ->put_super from the only caller. A couple of
filesystems had trivial enough ->put_super (only kfree and NULLing of
s_fs_info + stuff in there) to not get any locking: coda, cramfs, efs,
hugetlbfs, omfs, qnx4, shmem, all others got the full treatment. Most
of them probably don't need it, but I'd rather sort that out individually.
Preferably after all the other BKL pushdowns in that area.
[AV: original used to move lock_super() down as well; these changes are
removed since we don't do lock_super() at all in generic_shutdown_super()
now]
[AV: fuse, btrfs and xfs are known to need no damn BKL, exempt]
We just did a full fs writeout using sync_filesystem before, and if
that's not enough for the filesystem it can perform it's own writeout
in ->put_super, which many filesystems already do.
Move a call to foofs_write_super into every foofs_put_super for now to
guarantee identical behaviour until it's cleaned up by the individual
filesystem maintainers.
Exceptions:
- affs already has identical copy & pasted code at the beginning of
affs_put_super so no need to do it twice.
- xfs does the right thing without it and I have changes pending for
the xfs tree touching this are so I don't really need conflicts
here..
Since all sanity checks rely on the validity of s_start which gets only
checked to be smaller than s_end, we should also check if s_end is sane.
Now we also try to retrieve the last block of the filesystem, which is
computed by s_end. If this fails, something is bogus.
Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de>
Acked-by: Tigran Aivazian <tigran@aivazian.fsnet.co.uk>
bfs_fill_super() already touches all inodes, so we can easily add some
cheap sanity checks and check if the inode start and end blocks are
smaller than the maximum number of blocks, the inode start block lies
behind the end block or the file end offset is behind the end of the
filesystem. Also check if the start of data offset in the super block
fits the filesystem.
The added sanity checks catch softlockup issues early when we try to
sb_bread() lots of blocks in a loop in bfs_readdir() and bfs_find_entry().
In addition an oom issue in bfs_fill_super() is prevented by this when
s_start is corrupted, which influences imap_len and we try to allocate a
huge info->si_imap.
Wrap access to task credentials so that they can be separated more easily from
the task_struct during the introduction of COW creds.
Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id().
Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more
sense to use RCU directly rather than a convenient wrapper; these will be
addressed by later patches.
Reviewed-by: James Morris <jmorris@namei.org>
Acked-by: Serge Hallyn <serue@us.ibm.com>
Cc: Tigran A. Aivazian <tigran@aivazian.fsnet.co.uk>
Signed-off-by: James Morris <jmorris@namei.org>
With this patch all directory fops instances that have a readdir
that doesn't take the BKL are switched to generic_file_llseek.
This fixes:
[ INFO: possible recursive locking detected ]
2.6.27-rc5-00283-g70bb089 #68
touch/6855 is trying to acquire lock:
(&info->bfs_lock){--..}, at: [<c02262f5>] bfs_delete_inode+0x9e/0x18c
but task is already holding lock:
(&info->bfs_lock){--..}, at: [<c0226c00>] bfs_create+0x45/0x187
2 locks held by touch/6855:
#0: (&type->i_mutex_dir_key#5){--..}, at: [<c018ad13>] do_filp_open+0x10b/0x62f
#1: (&info->bfs_lock){--..}, at: [<c0226c00>] bfs_create+0x45/0x187
stack backtrace:
Pid: 6855, comm: touch Not tainted 2.6.27-rc5-00283-g70bb089 #68
[<c013e769>] validate_chain+0x458/0x9f4
[<c013bece>] ? trace_hardirqs_off+0xb/0xd
[<c013f36b>] __lock_acquire+0x666/0x6e0
[<c013f440>] lock_acquire+0x5b/0x77
[<c02262f5>] ? bfs_delete_inode+0x9e/0x18c
[<c06aab74>] mutex_lock_nested+0xbc/0x234
[<c0226257>] ? bfs_delete_inode+0x0/0x18c
[<c01925e1>] generic_delete_inode+0x94/0xfe
[<c019265d>] generic_drop_inode+0x12/0x12f
[<c0191b7e>] iput+0x4b/0x4e
[<c0226d1e>] bfs_create+0x163/0x187
[<c0188b42>] vfs_create+0xa6/0x114
[<c018adb5>] do_filp_open+0x1ad/0x62f
[<c0107cdc>] ? native_sched_clock+0x82/0x96
[<c06ac309>] ? _spin_unlock+0x27/0x3c
[<c019379e>] ? alloc_fd+0xbf/0xc9
[<c06ae2f4>] ? sub_preempt_count+0x9d/0xab
[<c0180391>] do_sys_open+0x42/0xb8
[<c041d564>] ? trace_hardirqs_on_thunk+0xc/0x10
[<c0180449>] sys_open+0x1e/0x26
[<c01038bd>] sysenter_do_call+0x12/0x31
The problem is that we don't unlock the bfs->lock mutex before calling
iput (we do in the other cases).
Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk>
Kmem cache passed to constructor is only needed for constructors that are
themselves multiplexeres. Nobody uses this "feature", nor does anybody uses
passed kmem cache in non-trivial way, so pass only pointer to object.
Non-trivial places are:
arch/powerpc/mm/init_64.c
arch/powerpc/mm/hugetlbpage.c
This is flag day, yes.
Acked-by: Pekka Enberg <penberg@cs.helsinki.fi>
Acked-by: Christoph Lameter <cl@linux-foundation.org>
Cc: Jon Tollefson <kniht@linux.vnet.ibm.com>
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Cc: Matt Mackall <mpm@selenic.com>
[akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c]
[akpm@linux-foundation.org: fix mm/slab.c]
[akpm@linux-foundation.org: fix ubifs]
Replace the BKL-based locking scheme used in the bfs driver by a private
filesystem-wide mutex.
Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi>
Cc: Tigran Aivazian <tigran_aivazian@symantec.com>
This patch makes the following cleanups:
o removing an unused variable from bfs_fill_super();
o removing unneeded blank spaces from pointer
definitions.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Stop the BFS filesystem from using iget() and read_inode(). Replace
bfs_read_inode() with bfs_iget(), and call that instead of iget(). bfs_iget()
then uses iget_locked() directly and returns a proper error code instead of an
inode in the event of an error.
bfs_fill_super() returns any error incurred when getting the root inode
instead of EINVAL.
[kamalesh@linux.vnet.ibm.com: build fix]
Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com>
BFS_FILEBLOCKS() expects struct bfs_inode * (on-disk data, with little-
endian fields), not struct bfs_inode_info * (in-core stuff, with host-
endian ones).
It's a macro and fields with the right names are present in
bfs_inode_info, so it compiles, but on big-endian host it gives bogus
results.
Introduced in commit f433dc56344cb72cc3de5ba0819021cec3aef807 ("Fixes to
the BFS filesystem driver").
I found a few bugs in the BFS driver. Detailed description of the bugs as
well as the steps to reproduce the errors are given in the kernel bugzilla.
Please follow these links for more information:
http://bugzilla.kernel.org/show_bug.cgi?id=9363
http://bugzilla.kernel.org/show_bug.cgi?id=9364
http://bugzilla.kernel.org/show_bug.cgi?id=9365
http://bugzilla.kernel.org/show_bug.cgi?id=9366
This patch fixes the bugs described above. Besides, the patch introduces
coding style changes to make the BFS driver conform to the requirements
specified for Linux kernel code. Finally, I made a few cosmetic changes
such as removal of trivial debug output.
Also, the patch removes the fields `si_lf_ioff' and `si_lf_sblk' of the
in-core superblock structure. These fields are initialized but never
actually used.
If you are wondering why I need BFS, here is the answer: I am using this
driver in the context of Linux kernel classes I am teaching in the Moscow
State University and in the International Institute of Information
Technology in Pune, India.
Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com>
Cc: Tigran Aivazian <tigran@veritas.com>
Slab constructors currently have a flags parameter that is never used. And
the order of the arguments is opposite to other slab functions. The object
pointer is placed before the kmem_cache pointer.
Convert
ctor(void *object, struct kmem_cache *s, unsigned long flags)
to
ctor(struct kmem_cache *s, void *object)
throughout the kernel
[akpm@linux-foundation.org: coupla fixes]
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Signed-off-by: Nick Piggin <npiggin@suse.de>
Slab destructors were no longer supported after Christoph's
c59def9f222d44bb7e2f0a559f2906191a0862d7 change. They've been
BUGs for both slab and slub, and slob never supported them
either.
This rips out support for the dtor pointer from kmem_cache_create()
completely and fixes up every single callsite in the kernel (there were
about 224, not including the slab allocator definitions themselves,
or the documentation references).
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
They can use generic_file_splice_read() instead. Since sys_sendfile() now
prefers that, there should be no change in behaviour.
SLAB_CTOR_CONSTRUCTOR is always specified. No point in checking it.
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Steven French <sfrench@us.ibm.com>
Cc: Michael Halcrow <mhalcrow@us.ibm.com>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
Cc: Dave Kleikamp <shaggy@austin.ibm.com>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Anton Altaparmakov <aia21@cantab.net>
Cc: Mark Fasheh <mark.fasheh@oracle.com>
Cc: Jan Kara <jack@ucw.cz>
Cc: David Chinner <dgc@sgi.com>
I have never seen a use of SLAB_DEBUG_INITIAL. It is only supported by
SLAB.
I think its purpose was to have a callback after an object has been freed
to verify that the state is the constructor state again? The callback is
performed before each freeing of an object.
I would think that it is much easier to check the object state manually
before the free. That also places the check near the code object
manipulation of the object.
Also the SLAB_DEBUG_INITIAL callback is only performed if the kernel was
compiled with SLAB debugging on. If there would be code in a constructor
handling SLAB_DEBUG_INITIAL then it would have to be conditional on
SLAB_DEBUG otherwise it would just be dead code. But there is no such code
in the kernel. I think SLUB_DEBUG_INITIAL is too problematic to make real
use of, difficult to understand and there are easier ways to accomplish the
same effect (i.e. add debug code before kfree).
There is a related flag SLAB_CTOR_VERIFY that is frequently checked to be
clear in fs inode caches. Remove the pointless checks (they would even be
pointless without removeal of SLAB_DEBUG_INITIAL) from the fs constructors.
This is the last slab flag that SLUB did not support. Remove the check for
unimplemented flags from SLUB.
This patch is inspired by Arjan's "Patch series to mark struct
file_operations and struct inode_operations const".
Compile tested with gcc & sparse.
Signed-off-by: Josef 'Jeff' Sipek <jsipek@cs.sunysb.edu>
Many struct inode_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
As Adrian pointed out recently, there were still a couple of places where
I should have fixed my email address.
Signed-off-by: Josef Sipek <jsipek@fsl.cs.sunysb.edu>
