path: root/fs/bfs/dir.c
2009-06-11repair bfs_write_inode(), switch bfs to simple_fsync()Al Viro
2008-11-14CRED: Wrap task credential accesses in the BFS filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: Tigran A. Aivazian <tigran@aivazian.fsnet.co.uk> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-23[PATCH] fix ->llseek for more directoriesChristoph Hellwig
With this patch all directory fops instances that have a readdir that doesn't take the BKL are switched to generic_file_llseek. Signed-off-by: Christoph Hellwig <hch@lst.de>
2008-09-13bfs: fix Lockdep warningEric Sesterhenn
This fixes: ============================================= [ INFO: possible recursive locking detected ] 2.6.27-rc5-00283-g70bb089 #68 --------------------------------------------- touch/6855 is trying to acquire lock: (&info->bfs_lock){--..}, at: [<c02262f5>] bfs_delete_inode+0x9e/0x18c but task is already holding lock: (&info->bfs_lock){--..}, at: [<c0226c00>] bfs_create+0x45/0x187 other info that might help us debug this: 2 locks held by touch/6855: #0: (&type->i_mutex_dir_key#5){--..}, at: [<c018ad13>] do_filp_open+0x10b/0x62f #1: (&info->bfs_lock){--..}, at: [<c0226c00>] bfs_create+0x45/0x187 stack backtrace: Pid: 6855, comm: touch Not tainted 2.6.27-rc5-00283-g70bb089 #68 [<c013e769>] validate_chain+0x458/0x9f4 [<c013bece>] ? trace_hardirqs_off+0xb/0xd [<c013f36b>] __lock_acquire+0x666/0x6e0 [<c013f440>] lock_acquire+0x5b/0x77 [<c02262f5>] ? bfs_delete_inode+0x9e/0x18c [<c06aab74>] mutex_lock_nested+0xbc/0x234 [<c02262f5>] ? bfs_delete_inode+0x9e/0x18c [<c02262f5>] ? bfs_delete_inode+0x9e/0x18c [<c02262f5>] bfs_delete_inode+0x9e/0x18c [<c0226257>] ? bfs_delete_inode+0x0/0x18c [<c01925e1>] generic_delete_inode+0x94/0xfe [<c019265d>] generic_drop_inode+0x12/0x12f [<c0191b7e>] iput+0x4b/0x4e [<c0226d1e>] bfs_create+0x163/0x187 [<c0188b42>] vfs_create+0xa6/0x114 [<c018adb5>] do_filp_open+0x1ad/0x62f [<c0107cdc>] ? native_sched_clock+0x82/0x96 [<c06ac309>] ? _spin_unlock+0x27/0x3c [<c019379e>] ? alloc_fd+0xbf/0xc9 [<c06ae2f4>] ? sub_preempt_count+0x9d/0xab [<c019379e>] ? alloc_fd+0xbf/0xc9 [<c0180391>] do_sys_open+0x42/0xb8 [<c041d564>] ? trace_hardirqs_on_thunk+0xc/0x10 [<c0180449>] sys_open+0x1e/0x26 [<c01038bd>] sysenter_do_call+0x12/0x31 ======================= The problem is that we don't unlock the bfs->lock mutex before calling iput (we do in the other cases). Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Cc: Tigran Aivazian <tigran@aivazian.fsnet.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26bfs: kill BKLDmitri Vorobiev
Replace the BKL-based locking scheme used in the bfs driver by a private filesystem-wide mutex. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@movial.fi> Cc: Tigran Aivazian <tigran_aivazian@symantec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop BFS from using iget() and read_inode()David Howells
Stop the BFS filesystem from using iget() and read_inode(). Replace bfs_read_inode() with bfs_iget(), and call that instead of iget(). bfs_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. bfs_fill_super() returns any error incurred when getting the root inode instead of EINVAL. [kamalesh@linux.vnet.ibm.com: build fix] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Kamalesh Babulal <kamalesh@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14Fixes to the BFS filesystem driverDmitri Vorobiev
I found a few bugs in the BFS driver. Detailed description of the bugs as well as the steps to reproduce the errors are given in the kernel bugzilla. Please follow these links for more information: http://bugzilla.kernel.org/show_bug.cgi?id=9363 http://bugzilla.kernel.org/show_bug.cgi?id=9364 http://bugzilla.kernel.org/show_bug.cgi?id=9365 http://bugzilla.kernel.org/show_bug.cgi?id=9366 This patch fixes the bugs described above. Besides, the patch introduces coding style changes to make the BFS driver conform to the requirements specified for Linux kernel code. Finally, I made a few cosmetic changes such as removal of trivial debug output. Also, the patch removes the fields `si_lf_ioff' and `si_lf_sblk' of the in-core superblock structure. These fields are initialized but never actually used. If you are wondering why I need BFS, here is the answer: I am using this driver in the context of Linux kernel classes I am teaching in the Moscow State University and in the International Institute of Information Technology in Pune, India. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Cc: Tigran Aivazian <tigran@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] struct path: convert bfsJosef Sipek
2006-10-01[PATCH] r/o bind mount prepwork: inc_nlink() helperDave Hansen
This is mostly included for parity with dec_nlink(), where we will have some more hooks. This one should stay pretty darn straightforward for now. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mounts: unlink: monitor i_nlinkDave Hansen
When a filesystem decrements i_nlink to zero, it means that a write must be performed in order to drop the inode from the filesystem. We're shortly going to have keep filesystems from being remounted r/o between the time that this i_nlink decrement and that write occurs. So, add a little helper function to do the decrements. We'll tie into it in a bit to note when i_nlink hits zero. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-04[PATCH] bfs endianness annotationsAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] bfs: fix endianness, signedness; add trivial bugfixAndrew Stribblehill
* Makes BFS code endianness-clean. * Fixes some signedness warnings. * Fixes a problem in fs/bfs/inode.c:164 where inodes not synced to disk don't get fully marked as clean. Here's how to reproduce it: # mount -o loop -t bfs /bfs.img /mnt # df -i /mnt Filesystem Inodes IUsed IFree IUse% Mounted on /bfs.img 48 1 47 3% /mnt # df -k /mnt Filesystem 1K-blocks Used Available Use% Mounted on /bfs.img 512 5 508 1% /mnt # cp 60k-archive.zip /mnt/mt.zip # df -k /mnt Filesystem 1K-blocks Used Available Use% Mounted on /bfs.img 512 65 447 13% /mnt # df -i /mnt Filesystem Inodes IUsed IFree IUse% Mounted on /bfs.img 48 2 46 5% /mnt # rm /mnt/mt.zip # echo $? 0 [If the unlink happens before the buffers flush, the following happens:] # df -i /mnt Filesystem Inodes IUsed IFree IUse% Mounted on /bfs.img 48 2 46 5% /mnt # df -k /mnt Filesystem 1K-blocks Used Available Use% Mounted on /bfs.img 512 65 447 13% /mnt fs/bfs/bfs.h | 1 Signed-off-by: Andrew Stribblehill <ads@wompom.org> Cc: <tigran@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
