path: root/fs/autofs/inode.c
2009-01-05zero i_uid/i_gid on inode allocationAl Viro
... and don't bother in callers. Don't bother with zeroing i_blocks, while we are at it - it's already been zeroed. i_mode is not worth the effort; it has no common default value. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-11-14CRED: Wrap task credential accesses in the autofs filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: autofs@linux.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2008-10-13vfs: Use const for kernel parser tableSteven Whitehouse
This is a much better version of a previous patch to make the parser tables constant. Rather than changing the typedef, we put the "const" in all the various places where its required, allowing the __initconst exception for nfsroot which was the cause of the previous trouble. This was posted for review some time ago and I believe its been in -mm since then. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Cc: Alexander Viro <aviro@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08mount options: fix autofsMiklos Szeredi
Add a .show_options super operation to autofs. Use generic_show_options() and save the complete option string in autofs_fill_super(). Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Acked-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop autofs from using iget() and read_inode()David Howells
Stop the autofs filesystem from using iget() and read_inode(). Replace autofs_read_inode() with autofs_iget(), and call that instead of iget(). autofs_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Ian Kent <raven@themaw.net> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19pid namespaces: round up the APIPavel Emelianov
The set of functions process_session, task_session, process_group and task_pgrp is confusing, as the names can be mixed with each other when looking at the code for a long time. The proposals are to * equip the functions that return the integer with _nr suffix to represent that fact, * and to make all functions work with task (not process) by making the common prefix of the same name. For monotony the routines signal_session() and set_signal_session() are replaced with task_session_nr() and set_task_session(), especially since they are only used with the explicit task->signal dereference. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Kirill Korotaev <dev@openvz.org> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Herbert Poetzl <herbert@13thfloor.at> Cc: Sukadev Bhattiprolu <sukadev@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11Replace pid_t in autofs with struct pid referenceSukadev Bhattiprolu
Make autofs container-friendly by caching struct pid reference rather than pid_t and using pid_nr() to retreive a task's pid_t. ChangeLog: - Fix Eric Biederman's comments - Use find_get_pid() to hold a reference to oz_pgrp and release while unmounting; separate out changes to autofs and autofs4. - Fix Cedric's comments: retain old prototype of parse_options() and move necessary change to its caller. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: Eric Biederman <ebiederm@xmission.com> Cc: containers@lists.osdl.org Acked-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11Fix some coding-style errors in autofsSukadev Bhattiprolu
Fix coding style errors (extra spaces, long lines) in autofs and autofs4 files being modified for container/pidspace issues. Signed-off-by: Sukadev Bhattiprolu <sukadev@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: Serge Hallyn <serue@us.ibm.com> Cc: <containers@lists.osdl.org> Cc: Eric W. Biederman <ebiederm@xmission.com> Cc: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-07[PATCH] autofs: fix error code path in autofs_fill_sb()Jiri Kosina
When kernel is compiled with old version of autofs (CONFIG_AUTOFS_FS), and new (observed at least with 5.x.x) automount deamon is started, kernel correctly reports incompatible version of kernel and userland daemon, but then screws things up instead of correct handling of the error: autofs: kernel does not match daemon version ===================================== [ BUG: bad unlock balance detected! ] ------------------------------------- automount/4199 is trying to release lock (&type->s_umount_key) at: [<c0163b9e>] get_sb_nodev+0x76/0xa4 but there are no more locks to release! other info that might help us debug this: no locks held by automount/4199. stack backtrace: [<c0103b15>] dump_trace+0x68/0x1b2 [<c0103c77>] show_trace_log_lvl+0x18/0x2c [<c01041db>] show_trace+0xf/0x11 [<c010424d>] dump_stack+0x12/0x14 [<c012e02c>] print_unlock_inbalance_bug+0xe7/0xf3 [<c012fd4f>] lock_release+0x8d/0x164 [<c012b452>] up_write+0x14/0x27 [<c0163b9e>] get_sb_nodev+0x76/0xa4 [<c0163689>] vfs_kern_mount+0x83/0xf6 [<c016373e>] do_kern_mount+0x2d/0x3e [<c017513f>] do_mount+0x607/0x67a [<c0175224>] sys_mount+0x72/0xa4 [<c0102b96>] sysenter_past_esp+0x5f/0x99 DWARF2 unwinder stuck at sysenter_past_esp+0x5f/0x99 Leftover inexact backtrace: ======================= and then deadlock comes. The problem: autofs_fill_super() returns EINVAL to get_sb_nodev(), but before that, it calls kill_anon_super() to destroy the superblock which won't be needed. This is however way too soon to call kill_anon_super(), because get_sb_nodev() has to perform its own cleanup of the superblock first (deactivate_super(), etc.). The correct time to call kill_anon_super() is in the autofs_kill_sb() callback, which is called by deactivate_super() at proper time, when the superblock is ready to be killed. I can see the same faulty codepath also in autofs4. This patch solves issues in both filesystems in a same way - it postpones the kill_anon_super() until the proper time is signalized by deactivate_super() calling the kill_sb() callback. [raven@themaw.net: update comment] Signed-off-by: Jiri Kosina <jkosina@suse.cz> Acked-by: Ian Kent <raven@themaw.net> Cc: <stable@kernel.org> Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-14[PATCH] autofs4: panic after mount failIan Kent
Resolve the panic on failed mount of an autofs filesystem originally reported by Mao Bibo. It addresses two issues that happen after the mount fail. The first a NULL pointer reference to a field (pipe) in the autofs superblock info structure and second the lack of super block cleanup by the autofs and autofs4 modules. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-20[PATCH] autofs3: Make sure all dentries refs are released before calling ↵David Howells
kill_anon_super() Make sure all dentries refs are released before calling kill_anon_super() so that the assumption that generic_shutdown_super() can completely destroy the dentry tree for there will be no external references holds true. What was being done in the put_super() superblock op, is now done in the kill_sb() filesystem op instead, prior to calling kill_anon_super(). The call to shrink_dcache_sb() is removed as it is redundant since shrink_dcache_for_umount() will now be called after the cleanup routine. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ian Kent <raven@themaw.net> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] inode_diet: Replace inode.u.generic_ip with inode.i_privateTheodore Ts'o
The following patches reduce the size of the VFS inode structure by 28 bytes on a UP x86. (It would be more on an x86_64 system). This is a 10% reduction in the inode size on a UP kernel that is configured in a production mode (i.e., with no spinlock or other debugging functions enabled; if you want to save memory taken up by in-core inodes, the first thing you should do is disable the debugging options; they are responsible for a huge amount of bloat in the VFS inode structure). This patch: The filesystem or device-specific pointer in the inode is inside a union, which is pretty pointless given that all 30+ users of this field have been using the void pointer. Get rid of the union and rename it to i_private, with a comment to explain who is allowed to use the void pointer. This is just a cleanup, but it allows us to reuse the union 'u' for something something where the union will actually be used. [judith@osdl.org: powerpc build fix] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Judith Lebzelter <judith@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] fs: Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to kzalloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Jffs2-bit-acked-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-24Move several *_SUPER_MAGIC symbols to include/linux/magic.h.Jeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org>
2005-09-09[PATCH] autofs: fix "busy inodes after umount..."Alexander Krizhanovsky
This patch for old autofs (version 3) cleans dentries which are not putted after killing the automount daemon (it's analogue of recent patch for autofs4). Signed-off-by: Alexander Krizhanovsky <klx@yandex.ru> Cc: Ian Kent <raven@themaw.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
