[ Upstream commit 58fed94dfb17e89556b5705f20f90e5b2971b6a1 ]
Flush outstanding writes in afs when an fd is closed. This is what NFS and
CIFS do.
Reported-by: Marc Dionne <marc.c.dionne@gmail.com>
All places outside of core VFS that checked ->read and ->write for being NULL or
called the methods directly are gone now, so NULL {read,write} with non-NULL
{read,write}_iter will do the right thing in all cases.
Currently there is no way to truncate partial page where the end
truncate point is not at the end of the page. This is because it was not
needed and the functionality was enough for file system truncate
operation to work properly. However more file systems now support punch
hole feature and it can benefit from mm supporting truncating page just
up to the certain point.
Specifically, with this functionality truncate_inode_pages_range() can
be changed so it supports truncating partial page at the end of the
range (currently it will BUG_ON() if 'end' is not at the end of the
page).
This commit changes the invalidatepage() address space operation
prototype to accept range to be invalidated and update all the instances
for it.
We also change the block_invalidatepage() in the same way and actually
make a use of the new length argument implementing range invalidation.
Actual file system implementations will follow except the file systems
where the changes are really simple and should not change the behaviour
in any way .Implementation for truncate_page_range() which will be able
to accept page unaligned ranges will follow as well.
Signed-off-by: Lukas Czerner <lczerner@redhat.com>
We should be testing "if (vnode->flags & (1 << 4))" instead of
"if (vnode->flags & 4) {". The current test checks if the data was
modified instead of deleted.
Don't put struct file on the stack as it takes up quite a lot of space
and violates lifetime rules for struct file.
Rather than calling afs_readpage() indirectly from the directory routines by
way of read_mapping_page(), split afs_readpage() to have afs_page_filler()
that's given a key instead of a file and call read_cache_page(), specifying the
new function directly. Use it in afs_readpages() as well.
Also make use of this in afs_mntpt_check_symlink() too for the same reason.
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Handle netfs pages that the vmscan algorithm wants to evict from the pagecache
under OOM conditions, but that are waiting for write to the cache. Under these
conditions, vmscan calls the releasepage() function of the netfs, asking if a
page can be discarded.
The problem is typified by the following trace of a stuck process:
kslowd005 D 0000000000000000 0 4253 2 0x00000080
ffff88001b14f370 0000000000000046 ffff880020d0d000 0000000000000007
0000000000000006 0000000000000001 ffff88001b14ffd8 ffff880020d0d2a8
000000000000ddf0 00000000000118c0 00000000000118c0 ffff880020d0d2a8
Call Trace:
[<ffffffffa00782d8>] __fscache_wait_on_page_write+0x8b/0xa7 [fscache]
[<ffffffff8104c0f1>] ? autoremove_wake_function+0x0/0x34
[<ffffffffa0078240>] ? __fscache_check_page_write+0x63/0x70 [fscache]
[<ffffffffa00b671d>] nfs_fscache_release_page+0x4e/0xc4 [nfs]
[<ffffffffa00927f0>] nfs_release_page+0x3c/0x41 [nfs]
[<ffffffff810885d3>] try_to_release_page+0x32/0x3b
[<ffffffff81093203>] shrink_page_list+0x316/0x4ac
[<ffffffff8109372b>] shrink_inactive_list+0x392/0x67c
[<ffffffff813532fa>] ? __mutex_unlock_slowpath+0x100/0x10b
[<ffffffff81058df0>] ? trace_hardirqs_on_caller+0x10c/0x130
[<ffffffff8135330e>] ? mutex_unlock+0x9/0xb
[<ffffffff81093aa2>] shrink_list+0x8d/0x8f
[<ffffffff81093d1c>] shrink_zone+0x278/0x33c
[<ffffffff81052d6c>] ? ktime_get_ts+0xad/0xba
[<ffffffff81094b13>] try_to_free_pages+0x22e/0x392
[<ffffffff81091e24>] ? isolate_pages_global+0x0/0x212
[<ffffffff8108e743>] __alloc_pages_nodemask+0x3dc/0x5cf
[<ffffffff81089529>] grab_cache_page_write_begin+0x65/0xaa
[<ffffffff8110f8c0>] ext3_write_begin+0x78/0x1eb
[<ffffffff81089ec5>] generic_file_buffered_write+0x109/0x28c
[<ffffffff8103cb69>] ? current_fs_time+0x22/0x29
[<ffffffff8108a509>] __generic_file_aio_write+0x350/0x385
[<ffffffff8108a588>] ? generic_file_aio_write+0x4a/0xae
[<ffffffff8108a59e>] generic_file_aio_write+0x60/0xae
[<ffffffff810b2e82>] do_sync_write+0xe3/0x120
[<ffffffff810b18e1>] ? __dentry_open+0x1a5/0x2b8
[<ffffffff810b1a76>] ? dentry_open+0x82/0x89
[<ffffffffa00e693c>] cachefiles_write_page+0x298/0x335 [cachefiles]
[<ffffffffa0077147>] fscache_write_op+0x178/0x2c2 [fscache]
[<ffffffffa0075656>] fscache_op_execute+0x7a/0xd1 [fscache]
[<ffffffff81082093>] slow_work_execute+0x18f/0x2d1
[<ffffffff8108239a>] slow_work_thread+0x1c5/0x308
[<ffffffff810821d5>] ? slow_work_thread+0x0/0x308
[<ffffffff8104be91>] kthread+0x7a/0x82
[<ffffffff8100beda>] child_rip+0xa/0x20
[<ffffffff8100b87c>] ? restore_args+0x0/0x30
[<ffffffff8102ef83>] ? tg_shares_up+0x171/0x227
[<ffffffff8104be17>] ? kthread+0x0/0x82
[<ffffffff8100bed0>] ? child_rip+0x0/0x20
In the above backtrace, the following is happening:
(1) A page storage operation is being executed by a slow-work thread
(fscache_write_op()).
(2) FS-Cache farms the operation out to the cache to perform
(cachefiles_write_page()).
(3) CacheFiles is then calling Ext3 to perform the actual write, using Ext3's
standard write (do_sync_write()) under KERNEL_DS directly from the netfs
page.
(4) However, for Ext3 to perform the write, it must allocate some memory, in
particular, it must allocate at least one page cache page into which it
can copy the data from the netfs page.
(5) Under OOM conditions, the memory allocator can't immediately come up with
a page, so it uses vmscan to find something to discard
(try_to_free_pages()).
(6) vmscan finds a clean netfs page it might be able to discard (possibly the
one it's trying to write out).
(7) The netfs is called to throw the page away (nfs_release_page()) - but it's
called with __GFP_WAIT, so the netfs decides to wait for the store to
complete (__fscache_wait_on_page_write()).
(8) This blocks a slow-work processing thread - possibly against itself.
The system ends up stuck because it can't write out any netfs pages to the
cache without allocating more memory.
To avoid this, we make FS-Cache cancel some writes that aren't in the middle of
actually being performed. This means that some data won't make it into the
cache this time. To support this, a new FS-Cache function is added
fscache_maybe_release_page() that replaces what the netfs releasepage()
functions used to do with respect to the cache.
The decisions fscache_maybe_release_page() makes are counted and displayed
through /proc/fs/fscache/stats on a line labelled "VmScan". There are four
counters provided: "nos=N" - pages that weren't pending storage; "gon=N" -
pages that were pending storage when we first looked, but weren't by the time
we got the object lock; "bsy=N" - pages that we ignored as they were actively
being written when we looked; and "can=N" - pages that we cancelled the storage
of.
What I'd really like to do is alter the behaviour of the cancellation
heuristics, depending on how necessary it is to expel pages. If there are
plenty of other pages that aren't waiting to be written to the cache that
could be ejected first, then it would be nice to hold up on immediate
cancellation of cache writes - but I don't see a way of doing that.
kAFS crashes when asked to read a symbolic link because page_getlink()
passes a NULL file pointer to read_mapping_page(), but afs_readpage()
expects a file pointer from which to extract a key.
Modify afs_readpage() to request the appropriate key from the calling
process's keyrings if a file struct is not supplied with one attached.
Acked-by: Anton Blanchard <anton@samba.org>
If CONFIG_AFS_FSCACHE is not defined, the following warning is displayed when
fs/afs/file.c is compiled:
fs/afs/file.c:111: warning: ‘afs_file_readpage_read_complete’ defined but not used
This occurs because all calls to this function are guarded by
CONFIG_AFS_FSCACHE. Thus, guard its definition as well.
Signed-off-by: Matt Kraai <kraai@ftbfs.org>
The attached patch makes the kAFS filesystem in fs/afs/ use FS-Cache, and
through it any attached caches. The kAFS filesystem will use caching
automatically if it's available.
Acked-by: Steve Dickson <steved@redhat.com>
Acked-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Acked-by: Al Viro <viro@zeniv.linux.org.uk>
Tested-by: Daire Byrne <Daire.Byrne@framestore.com>
Cannot assume writes will fully complete, so this conversion goes the easy
way and always brings the page uptodate before the write.
[dhowells@redhat.com: style tweaks]
Signed-off-by: Nick Piggin <npiggin@suse.de>
Implement file locking for AFS.
They can use generic_file_splice_read() instead. Since sys_sendfile() now
prefers that, there should be no change in behaviour.
Fix a couple of problems with unlinking AFS files.
(1) The parent directory wasn't being updated properly between unlink() and
the following lookup().
It seems that, for some reason, invalidate_remote_inode() wasn't
discarding the directory contents correctly, so this patch calls
invalidate_inode_pages2() instead on non-regular files.
(2) afs_vnode_deleted_remotely() should handle vnodes that don't have a
source server recorded without oopsing.
Implement support for writing to regular AFS files, including:
(1) write
(2) truncate
(3) fsync, fdatasync
(4) chmod, chown, chgrp, utime.
AFS writeback attempts to batch writes into as chunks as large as it can manage
up to the point that it writes back 65535 pages in one chunk or it meets a
locked page.
Furthermore, if a page has been written to using a particular key, then should
another write to that page use some other key, the first write will be flushed
before the second is allowed to take place. If the first write fails due to a
security error, then the page will be scrapped and reread before the second
write takes place.
If a page is dirty and the callback on it is broken by the server, then the
dirty data is not discarded (same behaviour as NFS).
Shared-writable mappings are not supported by this patch.
[akpm@linux-foundation.org: fix a bunch of warnings]
Make some miscellaneous changes to the AFS filesystem:
(1) Assert RCU barriers on module exit to make sure RCU has finished with
callbacks in this module.
(2) Correctly handle the AFS server returning a zero-length read.
(3) Split out data zapping calls into one function (afs_zap_data).
(4) Rename some afs_file_*() functions to afs_*() where they apply to
non-regular files too.
(5) Be consistent about the presentation of volume ID:vnode ID in debugging
output.
Add support for the create, link, symlink, unlink, mkdir, rmdir and
rename VFS operations to the in-kernel AFS filesystem.
Also:
(1) Fix dentry and inode revalidation. d_revalidate should only look at
state of the dentry. Revalidation of the contents of an inode pointed to
by a dentry is now separate.
(2) Fix afs_lookup() to hash negative dentries as well as positive ones.
Add security support to the AFS filesystem. Kerberos IV tickets are added as
RxRPC keys are added to the session keyring with the klog program. open() and
other VFS operations then find this ticket with request_key() and either use
it immediately (eg: mkdir, unlink) or attach it to a file descriptor (open).
Make the in-kernel AFS filesystem use AF_RXRPC instead of the old RxRPC code.
Clean up the AFS sources.
Also remove references to AFS keys. RxRPC keys are used instead.
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
Many struct inode_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
[try #6]
Remove inclusions of linux/buffer_head.h that are no longer necessary due to the
transfer of a number of things out of there.
Signed-Off-By: David Howells <dhowells@redhat.com>
The AFS filesystem no longer needs to override its sync_page() op.
Same as with already do with the file operations: keep them in .rodata and
prevents people from doing runtime patching.
Cc: Steven French <sfrench@us.ibm.com>
The return value of this function is never used, so let's be honest and
declare it as void.
Some places where invalidatepage returned 0, I have inserted comments
suggesting a BUG_ON.
[akpm@osdl.org: JBD BUG fix]
[akpm@osdl.org: rework for git-nfs]
[akpm@osdl.org: don't go BUG in block_invalidate_page()]
Signed-off-by: Neil Brown <neilb@suse.de>
Acked-by: Dave Kleikamp <shaggy@austin.ibm.com>
This is the fs/ part of the big kfree cleanup patch.
Remove pointless checks for NULL prior to calling kfree() in fs/.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
afs actually had a write method that returned different errors depending on
whether some flag was set - better return the standard EINVAL errno.
Christoph Lameter demonstrated very poor scalability on the SGI 512-way, with
a many-threaded application which concurrently initializes different parts of
a large anonymous area.
This patch corrects that, by using a separate spinlock per page table page, to
guard the page table entries in that page, instead of using the mm's single
page_table_lock. (But even then, page_table_lock is still used to guard page
table allocation, and anon_vma allocation.)
In this implementation, the spinlock is tucked inside the struct page of the
page table page: with a BUILD_BUG_ON in case it overflows - which it would in
the case of 32-bit PA-RISC with spinlock debugging enabled.
Splitting the lock is not quite for free: another cacheline access. Ideally,
I suppose we would use split ptlock only for multi-threaded processes on
multi-cpu machines; but deciding that dynamically would have its own costs.
So for now enable it by config, at some number of cpus - since the Kconfig
language doesn't support inequalities, let preprocessor compare that with
NR_CPUS. But I don't think it's worth being user-configurable: for good
testing of both split and unsplit configs, split now at 4 cpus, and perhaps
change that to 8 later.
There is a benefit even for singly threaded processes: kswapd can be attacking
one part of the mm while another part is busy faulting.
Signed-off-by: Hugh Dickins <hugh@veritas.com>
- ->releasepage() annotated (s/int/gfp_t), instances updated
- missing gfp_t in fs/* added
- fixed misannotation from the original sweep caught by bitwise checks:
XFS used __nocast both for gfp_t and for flags used by XFS allocator.
The latter left with unsigned int __nocast; we might want to add a
different type for those but for now let's leave them alone. That,
BTW, is a case when __nocast use had been actively confusing - it had
been used in the same code for two different and similar types, with
no way to catch misuses. Switch of gfp_t to bitwise had caught that
immediately...
One tricky bit is left alone to be dealt with later - mapping->flags is
a mix of gfp_t and error indications. Left alone for now.
Remove PAGE_BUG - repalce it with BUG and BUG_ON.
Signed-off-by: Matt Mackall <mpm@selenic.com>
infrastructure for it.
Let it rip!
