path: root/fs/Makefile
2007-05-11signal/timer/event: eventfd coreDavide Libenzi
This is a very simple and light file descriptor, that can be used as event wait/dispatch by userspace (both wait and dispatch) and by the kernel (dispatch only). It can be used instead of pipe(2) in all cases where those would simply be used to signal events. Their kernel overhead is much lower than pipes, and they do not consume two fds. When used in the kernel, it can offer an fd-bridge to enable, for example, functionalities like KAIO or syslets/threadlets to signal to an fd the completion of certain operations. But more in general, an eventfd can be used by the kernel to signal readiness, in a POSIX poll/select way, of interfaces that would otherwise be incompatible with it. The API is: int eventfd(unsigned int count); The eventfd API accepts an initial "count" parameter, and returns an eventfd fd. It supports poll(2) (POLLIN, POLLOUT, POLLERR), read(2) and write(2). The POLLIN flag is raised when the internal counter is greater than zero. The POLLOUT flag is raised when at least a value of "1" can be written to the internal counter. The POLLERR flag is raised when an overflow in the counter value is detected. The write(2) operation can never overflow the counter, since it blocks (unless O_NONBLOCK is set, in which case -EAGAIN is returned). But the eventfd_signal() function can do it, since it's supposed to not sleep during its operation. The read(2) function reads the __u64 counter value, and reset the internal value to zero. If the value read is equal to (__u64) -1, an overflow happened on the internal counter (due to 2^64 eventfd_signal() posts that has never been retired - unlickely, but possible). The write(2) call writes an __u64 count value, and adds it to the current counter. The eventfd fd supports O_NONBLOCK also. On the kernel side, we have: struct file *eventfd_fget(int fd); int eventfd_signal(struct file *file, unsigned int n); The eventfd_fget() should be called to get a struct file* from an eventfd fd (this is an fget() + check of f_op being an eventfd fops pointer). The kernel can then call eventfd_signal() every time it wants to post an event to userspace. The eventfd_signal() function can be called from any context. An eventfd() simple test and bench is available here: http://www.xmailserver.org/eventfd-bench.c This is the eventfd-based version of pipetest-4 (pipe(2) based): http://www.xmailserver.org/pipetest-4.c Not that performance matters much in the eventfd case, but eventfd-bench shows almost as double as performance than pipetest-4. [akpm@linux-foundation.org: fix i386 build] [akpm@linux-foundation.org: add sys_eventfd to sys_ni.c] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11signal/timer/event: timerfd coreDavide Libenzi
This patch introduces a new system call for timers events delivered though file descriptors. This allows timer event to be used with standard POSIX poll(2), select(2) and read(2). As a consequence of supporting the Linux f_op->poll subsystem, they can be used with epoll(2) too. The system call is defined as: int timerfd(int ufd, int clockid, int flags, const struct itimerspec *utmr); The "ufd" parameter allows for re-use (re-programming) of an existing timerfd w/out going through the close/open cycle (same as signalfd). If "ufd" is -1, s new file descriptor will be created, otherwise the existing "ufd" will be re-programmed. The "clockid" parameter is either CLOCK_MONOTONIC or CLOCK_REALTIME. The time specified in the "utmr->it_value" parameter is the expiry time for the timer. If the TFD_TIMER_ABSTIME flag is set in "flags", this is an absolute time, otherwise it's a relative time. If the time specified in the "utmr->it_interval" is not zero (.tv_sec == 0, tv_nsec == 0), this is the period at which the following ticks should be generated. The "utmr->it_interval" should be set to zero if only one tick is requested. Setting the "utmr->it_value" to zero will disable the timer, or will create a timerfd without the timer enabled. The function returns the new (or same, in case "ufd" is a valid timerfd descriptor) file, or -1 in case of error. As stated before, the timerfd file descriptor supports poll(2), select(2) and epoll(2). When a timer event happened on the timerfd, a POLLIN mask will be returned. The read(2) call can be used, and it will return a u32 variable holding the number of "ticks" that happened on the interface since the last call to read(2). The read(2) call supportes the O_NONBLOCK flag too, and EAGAIN will be returned if no ticks happened. A quick test program, shows timerfd working correctly on my amd64 box: http://www.xmailserver.org/timerfd-test.c [akpm@linux-foundation.org: add sys_timerfd to sys_ni.c] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11signal/timer/event: signalfd coreDavide Libenzi
This patch series implements the new signalfd() system call. I took part of the original Linus code (and you know how badly it can be broken :), and I added even more breakage ;) Signals are fetched from the same signal queue used by the process, so signalfd will compete with standard kernel delivery in dequeue_signal(). If you want to reliably fetch signals on the signalfd file, you need to block them with sigprocmask(SIG_BLOCK). This seems to be working fine on my Dual Opteron machine. I made a quick test program for it: http://www.xmailserver.org/signafd-test.c The signalfd() system call implements signal delivery into a file descriptor receiver. The signalfd file descriptor if created with the following API: int signalfd(int ufd, const sigset_t *mask, size_t masksize); The "ufd" parameter allows to change an existing signalfd sigmask, w/out going to close/create cycle (Linus idea). Use "ufd" == -1 if you want a brand new signalfd file. The "mask" allows to specify the signal mask of signals that we are interested in. The "masksize" parameter is the size of "mask". The signalfd fd supports the poll(2) and read(2) system calls. The poll(2) will return POLLIN when signals are available to be dequeued. As a direct consequence of supporting the Linux poll subsystem, the signalfd fd can use used together with epoll(2) too. The read(2) system call will return a "struct signalfd_siginfo" structure in the userspace supplied buffer. The return value is the number of bytes copied in the supplied buffer, or -1 in case of error. The read(2) call can also return 0, in case the sighand structure to which the signalfd was attached, has been orphaned. The O_NONBLOCK flag is also supported, and read(2) will return -EAGAIN in case no signal is available. If the size of the buffer passed to read(2) is lower than sizeof(struct signalfd_siginfo), -EINVAL is returned. A read from the signalfd can also return -ERESTARTSYS in case a signal hits the process. The format of the struct signalfd_siginfo is, and the valid fields depends of the (->code & __SI_MASK) value, in the same way a struct siginfo would: struct signalfd_siginfo { __u32 signo; /* si_signo */ __s32 err; /* si_errno */ __s32 code; /* si_code */ __u32 pid; /* si_pid */ __u32 uid; /* si_uid */ __s32 fd; /* si_fd */ __u32 tid; /* si_fd */ __u32 band; /* si_band */ __u32 overrun; /* si_overrun */ __u32 trapno; /* si_trapno */ __s32 status; /* si_status */ __s32 svint; /* si_int */ __u64 svptr; /* si_ptr */ __u64 utime; /* si_utime */ __u64 stime; /* si_stime */ __u64 addr; /* si_addr */ }; [akpm@linux-foundation.org: fix signalfd_copyinfo() on i386] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11signal/timer/event fds: anonymous inode sourceDavide Libenzi
This patch add an anonymous inode source, to be used for files that need and inode only in order to create a file*. We do not care of having an inode for each file, and we do not even care of having different names in the associated dentries (dentry names will be same for classes of file*). This allow code reuse, and will be used by epoll, signalfd and timerfd (and whatever else there'll be). Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-17Remove JFFS (version 1), as scheduled.Jeff Garzik
Unmaintained for years, few if any users. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-08[PATCH] fsstack: Introduce fsstack_copy_{attr,inode}_*Josef "Jeff" Sipek
Introduce several fsstack_copy_* functions which allow stackable filesystems (such as eCryptfs and Unionfs) to easily copy over (currently only) inode attributes. This prevents code duplication and allows for code reuse. [akpm@osdl.org: Remove unneeded wrapper] [bunk@stusta.de: fs/stack.c should #include <linux/fs_stack.h>] Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] jbd2: enable building of jbd2 and have ext4 use it rather than jbdMingming Cao
Reworked from a patch by Mingming Cao and Randy Dunlap Signed-off-By: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: enable building of ext4Mingming Cao
Originally part of a patch from Mingming Cao and Randy Dunlap. Reorganized by Shaggy. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Mingming Cao<cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6: (292 commits) [GFS2] Fix endian bug for de_type [GFS2] Initialize SELinux extended attributes at inode creation time. [GFS2] Move logging code into log.c (mostly) [GFS2] Mark nlink cleared so VFS sees it happen [GFS2] Two redundant casts removed [GFS2] Remove uneeded endian conversion [GFS2] Remove duplicate sb reading code [GFS2] Mark metadata reads for blktrace [GFS2] Remove iflags.h, use FS_ [GFS2] Fix code style/indent in ops_file.c [GFS2] streamline-generic_file_-interfaces-and-filemap gfs fix [GFS2] Remove readv/writev methods and use aio_read/aio_write instead (gfs bits) [GFS2] inode-diet: Eliminate i_blksize from the inode structure [GFS2] inode_diet: Replace inode.u.generic_ip with inode.i_private (gfs) [GFS2] Fix typo in last patch [GFS2] Fix direct i/o logic in filemap.c [GFS2] Fix bug in Makefiles for lock modules [GFS2] Remove (extra) fs_subsys declaration [GFS2/DLM] Fix trailing whitespace [GFS2] Tidy up meta_io code ...
2006-10-04[PATCH] ecryptfs: fs/Makefile and fs/KconfigMichael Halcrow
eCryptfs is a stacked cryptographic filesystem for Linux. It is derived from Erez Zadok's Cryptfs, implemented through the FiST framework for generating stacked filesystems. eCryptfs extends Cryptfs to provide advanced key management and policy features. eCryptfs stores cryptographic metadata in the header of each file written, so that encrypted files can be copied between hosts; the file will be decryptable with the proper key, and there is no need to keep track of any additional information aside from what is already in the encrypted file itself. [akpm@osdl.org: updates for ongoing API changes] [bunk@stusta.de: cleanups] [akpm@osdl.org: alpha build fix] [akpm@osdl.org: cleanups] [tytso@mit.edu: inode-diet updates] [pbadari@us.ibm.com: generic_file_*_read/write() interface updates] [rdunlap@xenotime.net: printk format fixes] [akpm@osdl.org: make slab creation and teardown table-driven] Signed-off-by: Phillip Hellewell <phillip@hellewell.homeip.net> Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-02Merge branch 'master' into gfs2Steven Whitehouse
2006-10-01[PATCH] Create fs/utimes.cAlexey Dobriyan
* fs/open.c is getting bit crowdy * preparation to lutimes(2) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-30[PATCH] BLOCK: Make it possible to disable the block layer [try #6]David Howells
Make it possible to disable the block layer. Not all embedded devices require it, some can make do with just JFFS2, NFS, ramfs, etc - none of which require the block layer to be present. This patch does the following: (*) Introduces CONFIG_BLOCK to disable the block layer, buffering and blockdev support. (*) Adds dependencies on CONFIG_BLOCK to any configuration item that controls an item that uses the block layer. This includes: (*) Block I/O tracing. (*) Disk partition code. (*) All filesystems that are block based, eg: Ext3, ReiserFS, ISOFS. (*) The SCSI layer. As far as I can tell, even SCSI chardevs use the block layer to do scheduling. Some drivers that use SCSI facilities - such as USB storage - end up disabled indirectly from this. (*) Various block-based device drivers, such as IDE and the old CDROM drivers. (*) MTD blockdev handling and FTL. (*) JFFS - which uses set_bdev_super(), something it could avoid doing by taking a leaf out of JFFS2's book. (*) Makes most of the contents of linux/blkdev.h, linux/buffer_head.h and linux/elevator.h contingent on CONFIG_BLOCK being set. sector_div() is, however, still used in places, and so is still available. (*) Also made contingent are the contents of linux/mpage.h, linux/genhd.h and parts of linux/fs.h. (*) Makes a number of files in fs/ contingent on CONFIG_BLOCK. (*) Makes mm/bounce.c (bounce buffering) contingent on CONFIG_BLOCK. (*) set_page_dirty() doesn't call __set_page_dirty_buffers() if CONFIG_BLOCK is not enabled. (*) fs/no-block.c is created to hold out-of-line stubs and things that are required when CONFIG_BLOCK is not set: (*) Default blockdev file operations (to give error ENODEV on opening). (*) Makes some /proc changes: (*) /proc/devices does not list any blockdevs. (*) /proc/diskstats and /proc/partitions are contingent on CONFIG_BLOCK. (*) Makes some compat ioctl handling contingent on CONFIG_BLOCK. (*) If CONFIG_BLOCK is not defined, makes sys_quotactl() return -ENODEV if given command other than Q_SYNC or if a special device is specified. (*) In init/do_mounts.c, no reference is made to the blockdev routines if CONFIG_BLOCK is not defined. This does not prohibit NFS roots or JFFS2. (*) The bdflush, ioprio_set and ioprio_get syscalls can now be absent (return error ENOSYS by way of cond_syscall if so). (*) The seclvl_bd_claim() and seclvl_bd_release() security calls do nothing if CONFIG_BLOCK is not set, since they can't then happen. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-29[PATCH] Generic infrastructure for aclsAndreas Gruenbacher
The patches solve the following problem: We want to grant access to devices based on who is logged in from where, etc. This includes switching back and forth between multiple user sessions, etc. Using ACLs to define device access for logged-in users gives us all the flexibility we need in order to fully solve the problem. Device special files nowadays usually live on tmpfs, hence tmpfs ACLs. Different distros have come up with solutions that solve the problem to different degrees: SUSE uses a resource manager which tracks login sessions and sets ACLs on device inodes as appropriate. RedHat uses pam_console, which changes the primary file ownership to the logged-in user. Others use a set of groups that users must be in in order to be granted the appropriate accesses. The freedesktop.org project plans to implement a combination of a console-tracker and a HAL-device-list based solution to grant access to devices to users, and more distros will likely follow this approach. These patches have first been posted here on 2 February 2005, and again on 8 January 2006. We have been shipping them in SLES9 and SLES10 with no problems reported. The previous submission is archived here: http://lkml.org/lkml/2006/1/8/229 http://lkml.org/lkml/2006/1/8/230 http://lkml.org/lkml/2006/1/8/231 This patch: Add some infrastructure for access control lists on in-memory filesystems such as tmpfs. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03Merge rsync://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6Steven Whitehouse
Conflicts: include/linux/kernel.h
2006-06-26[PATCH] devfs: Remove devfs from the kernel treeGreg Kroah-Hartman
This is the first patch in a series of patches that removes devfs support from the kernel. This patch removes the core devfs code, and its private header file. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-20[PATCH] inotify (1/5): split kernel API from userspace supportAmy Griffis
The following series of patches introduces a kernel API for inotify, making it possible for kernel modules to benefit from inotify's mechanism for watching inodes. With these patches, inotify will maintain for each caller a list of watches (via an embedded struct inotify_watch), where each inotify_watch is associated with a corresponding struct inode. The caller registers an event handler and specifies for which filesystem events their event handler should be called per inotify_watch. Signed-off-by: Amy Griffis <amy.griffis@hp.com> Acked-by: Robert Love <rml@novell.com> Acked-by: John McCutchan <john@johnmccutchan.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-05-25Merge branch 'master'Steven Whitehouse
2006-05-17configfs: Make sure configfs_init() is called before consumers.Joel Becker
configfs_init() needs to be called first to register configfs before anyconsumers try to access it. Move up configfs in fs/Makefile to make sure it is initialized early. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-04-03Merge branch 'master'Steven Whitehouse
2006-03-31Merge branch 'master'Steven Whitehouse
2006-03-31[PATCH] sys_sync_file_range()Andrew Morton
Remove the recently-added LINUX_FADV_ASYNC_WRITE and LINUX_FADV_WRITE_WAIT fadvise() additions, do it in a new sys_sync_file_range() syscall instead. Reasons: - It's more flexible. Things which would require two or three syscalls with fadvise() can be done in a single syscall. - Using fadvise() in this manner is something not covered by POSIX. The patch wires up the syscall for x86. The sycall is implemented in the new fs/sync.c. The intention is that we can move sys_fsync(), sys_fdatasync() and perhaps sys_sync() into there later. Documentation for the syscall is in fs/sync.c. A test app (sync_file_range.c) is in http://www.zip.com.au/~akpm/linux/patches/stuff/ext3-tools.tar.gz. The available-to-GPL-modules do_sync_file_range() is for knfsd: "A COMMIT can say NFS_DATA_SYNC or NFS_FILE_SYNC. I can skip the ->fsync call for NFS_DATA_SYNC which is hopefully the more common." Note: the `async' writeout mode SYNC_FILE_RANGE_WRITE will turn synchronous if the queue is congested. This is trivial to fix: add a new flag bit, set wbc->nonblocking. But I'm not sure that we want to expose implementation details down to that level. Note: it's notable that we can sync an fd which wasn't opened for writing. Same with fsync() and fdatasync()). Note: the code takes some care to handle attempts to sync file contents outside the 16TB offset on 32-bit machines. It makes such attempts appear to succeed, for best 32-bit/64-bit compatibility. Perhaps it should make such requests fail... Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-30[PATCH] Introduce sys_splice() system callJens Axboe
This adds support for the sys_splice system call. Using a pipe as a transport, it can connect to files or sockets (latter as output only). From the splice.c comments: "splice": joining two ropes together by interweaving their strands. This is the "extended pipe" functionality, where a pipe is used as an arbitrary in-memory buffer. Think of a pipe as a small kernel buffer that you can use to transfer data from one end to the other. The traditional unix read/write is extended with a "splice()" operation that transfers data buffers to or from a pipe buffer. Named by Larry McVoy, original implementation from Linus, extended by Jens to support splicing to files and fixing the initial implementation bugs. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] relay: migrate from relayfs to a generic relay APIJens Axboe
Original patch from Paul Mundt, sysfs parts removed by me since they were broken. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-01-18[DLM] The core of the DLM for GFS2/CLVMDavid Teigland
This is the core of the distributed lock manager which is required to use GFS2 as a cluster filesystem. It is also used by CLVM and can be used as a standalone lock manager independantly of either of these two projects. It implements VAX-style locking modes. Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steve Whitehouse <swhiteho@redhat.com>
2006-01-16[GFS2] Hook GFS2 into the Kbuild systemDavid Teigland
Adds GFS2 into fs/Kconfig and adds a Makefile entry Signed-off-by: David Teigland <teigland@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2006-01-10[PATCH] sanitize building of fs/compat_ioctl.cChristoph Hellwig
Now that all these entries in the arch ioctl32.c files are gone [1], we can build fs/compat_ioctl.c as a normal object and kill tons of cruft. We need a special do_ioctl32_pointer handler for s390 so the compat_ptr call is done. This is not needed but harmless on all other architectures. Also remove some superflous includes in fs/compat_ioctl.c Tested on ppc64. [1] parisc still had it's PPP handler left, which is not fully correct for ppp and besides that ppp uses the generic SIOCPRIV ioctl so it'd kick in for all netdevice users. We can introduce a proper handler in one of the next patch series by adding a compat_ioctl method to struct net_device but for now let's just kill it - parisc doesn't compile in mainline anyway and I don't want this to block this patchset. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Matthew Wilcox <willy@debian.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] drop-pagecacheAndrew Morton
Add /proc/sys/vm/drop_caches. When written to, this will cause the kernel to discard as much pagecache and/or reclaimable slab objects as it can. THis operation requires root permissions. It won't drop dirty data, so the user should run `sync' first. Caveats: a) Holds inode_lock for exorbitant amounts of time. b) Needs to be taught about NUMA nodes: propagate these all the way through so the discarding can be controlled on a per-node basis. This is a debugging feature: useful for getting consistent results between filesystem benchmarks. We could possibly put it under a config option, but it's less than 300 bytes. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-03[PATCH] OCFS2: The Second Oracle Cluster FilesystemMark Fasheh
Link the code into the kernel build system. OCFS2 is marked as experimental. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com>
2006-01-03[PATCH] configfs: User-driven configuration filesystemJoel Becker
Configfs, a file system for userspace-driven kernel object configuration. The OCFS2 stack makes extensive use of this for propagation of cluster configuration information into kernel. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2005-11-07[PATCH] beginning of the shared-subtree properRam Pai
A private mount does not forward or receive propagation. This patch provides user the ability to convert any mount to private. Signed-off-by: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] FUSE - MAINTAINERS, Kconfig and Makefile changesMiklos Szeredi
This patch adds FUSE filesystem to MAINTAINERS, fs/Kconfig and fs/Makefile. Signed-off-by: Miklos Szeredi <miklos@szeredi.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: Documentation, Makefiles, ConfigurationEric Van Hensbergen
OVERVIEW V9FS is a distributed file system for Linux which provides an implementation of the Plan 9 resource sharing protocol 9P. It can be used to share all sorts of resources: static files, synthetic file servers (such as /proc or /sys), devices, and application file servers (such as FUSE). BACKGROUND Plan 9 (http://plan9.bell-labs.com/plan9) is a research operating system and associated applications suite developed by the Computing Science Research Center of AT&T Bell Laboratories (now a part of Lucent Technologies), the same group that developed UNIX , C, and C++. Plan 9 was initially released in 1993 to universities, and then made generally available in 1995. Its core operating systems code laid the foundation for the Inferno Operating System released as a product by Lucent Bell-Labs in 1997. The Inferno venture was the only commercial embodiment of Plan 9 and is currently maintained as a product by Vita Nuova (http://www.vitanuova.com). After updated releases in 2000 and 2002, Plan 9 was open-sourced under the OSI approved Lucent Public License in 2003. The Plan 9 project was started by Ken Thompson and Rob Pike in 1985. Their intent was to explore potential solutions to some of the shortcomings of UNIX in the face of the widespread use of high-speed networks to connect machines. In UNIX, networking was an afterthought and UNIX clusters became little more than a network of stand-alone systems. Plan 9 was designed from first principles as a seamless distributed system with integrated secure network resource sharing. Applications and services were architected in such a way as to allow for implicit distribution across a cluster of systems. Configuring an environment to use remote application components or services in place of their local equivalent could be achieved with a few simple command line instructions. For the most part, application implementations operated independent of the location of their actual resources. Commercial operating systems haven't changed much in the 20 years since Plan 9 was conceived. Network and distributed systems support is provided by a patchwork of middle-ware, with an endless number of packages supplying pieces of the puzzle. Matters are complicated by the use of different complicated protocols for individual services, and separate implementations for kernel and application resources. The V9FS project (http://v9fs.sourceforge.net) is an attempt to bring Plan 9's unified approach to resource sharing to Linux and other operating systems via support for the 9P2000 resource sharing protocol. V9FS HISTORY V9FS was originally developed by Ron Minnich and Maya Gokhale at Los Alamos National Labs (LANL) in 1997. In November of 2001, Greg Watson setup a SourceForge project as a public repository for the code which supported the Linux 2.4 kernel. About a year ago, I picked up the initial attempt Ron Minnich had made to provide 2.6 support and got the code integrated into a 2.6.5 kernel. I then went through a line-for-line re-write attempting to clean-up the code while more closely following the Linux Kernel style guidelines. I co-authored a paper with Ron Minnich on the V9FS Linux support including performance comparisons to NFSv3 using Bonnie and PostMark - this paper appeared at the USENIX/FREENIX 2005 conference in April 2005: ( http://www.usenix.org/events/usenix05/tech/freenix/hensbergen.html ). CALL FOR PARTICIPATION/REQUEST FOR COMMENTS Our 2.6 kernel support is stabilizing and we'd like to begin pursuing its integration into the official kernel tree. We would appreciate any review, comments, critiques, and additions from this community and are actively seeking people to join our project and help us produce something that would be acceptable and useful to the Linux community. STATUS The code is reasonably stable, although there are no doubt corner cases our regression tests haven't discovered yet. It is in regular use by several of the developers and has been tested on x86 and PowerPC (32-bit and 64-bit) in both small and large (LANL cluster) deployments. Our current regression tests include fsx, bonnie, and postmark. It was our intention to keep things as simple as possible for this release -- trying to focus on correctness within the core of the protocol support versus a rich set of features. For example: a more complete security model and cache layer are in the road map, but excluded from this release. Additionally, we have removed support for mmap operations at Al Viro's request. PERFORMANCE Detailed performance numbers and analysis are included in the FREENIX paper, but we show comparable performance to NFSv3 for large file operations based on the Bonnie benchmark, and superior performance for many small file operations based on the PostMark benchmark. Somewhat preliminary graphs (from the FREENIX paper) are available (http://v9fs.sourceforge.net/perf/index.html). RESOURCES The source code is available in a few different forms: tarballs: http://v9fs.sf.net CVSweb: http://cvs.sourceforge.net/viewcvs.py/v9fs/linux-9p/ CVS: :pserver:anonymous@cvs.sourceforge.net:/cvsroot/v9fs/linux-9p Git: rsync://v9fs.graverobber.org/v9fs (webgit: http://v9fs.graverobber.org) 9P: tcp!v9fs.graverobber.org!6564 The user-level server is available from either the Plan 9 distribution or from http://v9fs.sf.net Other support applications are still being developed, but preliminary version can be downloaded from sourceforge. Documentation on the protocol has historically been the Plan 9 Man pages (http://plan9.bell-labs.com/sys/man/5/INDEX.html), but there is an effort under way to write a more complete Internet-Draft style specification (http://v9fs.sf.net/rfc). There are a couple of mailing lists supporting v9fs, but the most used is v9fs-developer@lists.sourceforge.net -- please direct/cc your comments there so the other v9fs contibutors can participate in the conversation. There is also an IRC channel: irc://freenode.net/#v9fs This part of the patch contains Documentation, Makefiles, and configuration file changes. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] relayfsTom Zanussi
Here's the latest version of relayfs, against linux-2.6.11-mm2. I'm hoping you'll consider putting this version back into your tree - the previous rounds of comment seem to have shaken out all the API issues and the number of comments on the code itself have also steadily dwindled. This patch is essentially the same as the relayfs redux part 5 patch, with some minor changes based on reviewer comments. Thanks again to Pekka Enberg for those. The patch size without documentation is now a little smaller at just over 40k. Here's a detailed list of the changes: - removed the attribute_flags in relay open and changed it to a boolean specifying either overwrite or no-overwrite mode, and removed everything referencing the attribute flags. - added a check for NULL names in relayfs_create_entry() - got rid of the unnecessary multiple labels in relay_create_buf() - some minor simplification of relay_alloc_buf() which got rid of a couple params - updated the Documentation In addition, this version (through code contained in the relay-apps tarball linked to below, not as part of the relayfs patch) tries to make it as easy as possible to create the cooperating kernel/user pieces of a typical and common type of logging application, one where kernel logging is kicked off when a user space data collection app starts and stops when the collection app exits, with the data being automatically logged to disk in between. To create this type of application, you basically just include a header file (relay-app.h, included in the relay-apps tarball) in your kernel module, define a couple of callbacks and call an initialization function, and on the user side call a single function that sets up and continuously monitors the buffers, and writes data to files as it becomes available. Channels are created when the collection app is started and destroyed when it exits, not when the kernel module is inserted, so different channel buffer sizes can be specified for each separate run via command-line options. See the README in the relay-apps tarball for details. Also included in the relay-apps tarball are a couple examples demonstrating how you can use this to create quick and dirty kernel logging/debugging applications. They are: - tprintk, short for 'tee printk', which temporarily puts a kprobe on printk() and writes a duplicate stream of printk output to a relayfs channel. This could be used anywhere there's printk() debugging code in the kernel which you'd like to exercise, but would rather not have your system logs cluttered with debugging junk. You'd probably want to kill klogd while you do this, otherwise there wouldn't be much point (since putting a kprobe on printk() doesn't change the output of printk()). I've used this method to temporarily divert the packet logging output of the iptables LOG target from the system logs to relayfs files instead, for instance. - klog, which just provides a printk-like formatted logging function on top of relayfs. Again, you can use this to keep stuff out of your system logs if used in place of printk. The example applications can be found here: http://prdownloads.sourceforge.net/dprobes/relay-apps.tar.gz?download From: Christoph Hellwig <hch@lst.de> avoid lookup_hash usage in relayfs Signed-off-by: Tom Zanussi <zanussi@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] inotifyRobert Love
inotify is intended to correct the deficiencies of dnotify, particularly its inability to scale and its terrible user interface: * dnotify requires the opening of one fd per each directory that you intend to watch. This quickly results in too many open files and pins removable media, preventing unmount. * dnotify is directory-based. You only learn about changes to directories. Sure, a change to a file in a directory affects the directory, but you are then forced to keep a cache of stat structures. * dnotify's interface to user-space is awful. Signals? inotify provides a more usable, simple, powerful solution to file change notification: * inotify's interface is a system call that returns a fd, not SIGIO. You get a single fd, which is select()-able. * inotify has an event that says "the filesystem that the item you were watching is on was unmounted." * inotify can watch directories or files. Inotify is currently used by Beagle (a desktop search infrastructure), Gamin (a FAM replacement), and other projects. See Documentation/filesystems/inotify.txt. Signed-off-by: Robert Love <rml@novell.com> Cc: John McCutchan <ttb@tentacle.dhs.org> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] Update cfq io scheduler to time sliced designJens Axboe
This updates the CFQ io scheduler to the new time sliced design (cfq v3). It provides full process fairness, while giving excellent aggregate system throughput even for many competing processes. It supports io priorities, either inherited from the cpu nice value or set directly with the ioprio_get/set syscalls. The latter closely mimic set/getpriority. This import is based on my latest from -mm. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-22[PATCH] NFSD: Add server support for NFSv3 ACLs.Andreas Gruenbacher
This adds functions for encoding and decoding POSIX ACLs for the NFSACL protocol extension, and the GETACL and SETACL RPCs. The implementation is compatible with NFSACL in Solaris. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Olaf Kirch <okir@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
