path: root/fs/Kconfig
2007-10-15Merge git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/pub/linux/nfs-2.6: (131 commits) NFSv4: Fix a typo in nfs_inode_reclaim_delegation NFS: Add a boot parameter to disable 64 bit inode numbers NFS: nfs_refresh_inode should clear cache_validity flags on success NFS: Fix a connectathon regression in NFSv3 and NFSv4 NFS: Use nfs_refresh_inode() in ops that aren't expected to change the inode SUNRPC: Don't call xprt_release in call refresh SUNRPC: Don't call xprt_release() if call_allocate fails SUNRPC: Fix buggy UDP transmission [23/37] Clean up duplicate includes in [2.6 patch] net/sunrpc/rpcb_clnt.c: make struct rpcb_program static SUNRPC: Use correct type in buffer length calculations SUNRPC: Fix default hostname created in rpc_create() nfs: add server port to rpc_pipe info file NFS: Get rid of some obsolete macros NFS: Simplify filehandle revalidation NFS: Ensure that nfs_link() returns a hashed dentry NFS: Be strict about dentry revalidation when doing exclusive create NFS: Don't zap the readdir caches upon error NFS: Remove the redundant nfs_reval_fsid() NFSv3: Always use directory post-op attributes in nfs3_proc_lookup ... Fix up trivial conflict due to sock_owned_by_user() cleanup manually in net/sunrpc/xprtsock.c
2007-10-13Merge Linux 2.6.23David Woodhouse
2007-10-09SUNRPC: Add RDMA dependency to SUNRPC_XPRT_RDMA\"Talpey, Thomas\
Add a dependency on RDMA before enabling SUNRPC_XPRT_RDMA Yes, "INFINIBAND" also turns on iWARP and other RDMA support. Signed-off-by: Tom Talpey <talpey@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-10-09RPCRDMA: Kconfig and header file with rpcrdma protocol definitions\"Talpey, Thomas\
This file implements the configuration target, protocol template and constants for the rpcrdma transport framing, for use by the xprtrdma rpc transport implementation. Signed-off-by: Tom Talpey <talpey@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-09-11ocfs2: update docs for new featuresMark Fasheh
Update documentation listing ocfs2 features to reflect the current state of the file system. Add missing descriptions for some mount options which ocfs2 supports. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-08-02[JFFS2] LZO compression should default off for compatibility.David Woodhouse
2007-07-23Merge branch 'master' of ↵David Woodhouse
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6
2007-07-19NFSD/SUNRPC: Fix the automatic selection of RPCSEC_GSSTrond Myklebust
Bruce's patch broke the ability to compile RPCSEC_GSS as a module. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-07-18jbd2: Move jbd2-debug file to debugfsJose R. Santos
The jbd2-debug file used to be located in /proc/sys/fs/jbd2-debug, but it incorrectly used create_proc_entry() instead of the sysctl routines, and no proc entry was ever created. Instead of fixing this we might as well move the jbd2-debug file to debugfs which would be the preferred location for this kind of tunable. The new location is now /sys/kernel/debug/jbd2/jbd2-debug. Signed-off-by: Jose R. Santos <jrs@us.ibm.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2007-07-17knfsd: nfsd4: build rpcsec_gss whenever nfsd4 is builtJ. Bruce Fields
Select rpcsec_gss support whenever asked for NFSv4 support. The rfc actually requires gss, and gss is also the main reason to migrate to v4. We already do this on the client side. Signed-off-by: "J. Bruce Fields" <bfields@citi.umich.edu> Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Merge master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh-2.6: (68 commits) sh: sh-rtc support for SH7709. sh: Revert __xdiv64_32 size change. sh: Update r7785rp defconfig. sh: Export div symbols for GCC 4.2 and ST GCC. sh: fix race in parallel out-of-tree build sh: Kill off dead mach.c for hp6xx. sh: hd64461.h cleanup and added comments. sh: Update the alignment when 4K stacks are used. sh: Add a .bss.page_aligned section for 4K stacks. sh: Don't let SH-4A clobber SH-4 CFLAGS. sh: Add parport stub for SuperIO ports. sh: Drop -Wa,-dsp for DSP tuning. sh: Update dreamcast defconfig. fb: pvr2fb: A few more __devinit annotations for PCI. fb: pvr2fb: Fix up section mismatch warnings. sh: Select IPR-IRQ for SH7091. sh: Correct __xdiv64_32/div64_32 return value size. sh: Fix timer-tmu build for SH-3. sh: Add cpu and mach links to CLEAN_FILES. sh: Preliminary support for the SH-X3 CPU. ...
2007-07-149p: Reorganization of 9p file system codeLatchesar Ionkov
This patchset moves non-filesystem interfaces of v9fs from fs/9p to net/9p. It moves the transport, packet marshalling and connection layers to net/9p leaving only the VFS related files in fs/9p. This work is being done in preparation for in-kernel 9p servers as well as alternate 9p clients (other than VFS). Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-07-11[JFFS2] Add a "favourlzo" compression modeRichard Purdie
Add a "favourlzo" compression mode to jffs2 which tries to optimise by size but gives lzo an advantage when comparing sizes. This means the faster lzo algorithm can be preferred when there isn't much difference in compressed size (the exact threshold can be changed). Signed-off-by: Richard Purdie <rpurdie@openedhand.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-07-11[JFFS2] Add LZO compression support.Richard Purdie
Add LZO1X compression/decompression support to jffs2. LZO's interface doesn't entirely match that required by jffs2 so a buffer and memcpy is unavoidable. Signed-off-by: Richard Purdie <rpurdie@openedhand.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-07-11[JFFS2] Add support for write-buffer verification.David Woodhouse
We've seen some evil corruption issues, where the corruption seems to be introduced after the JFFS2 crc32 is calculated but before the NAND controller calculates the ECC. So it's in RAM or in the PCI DMA transfer; not on the flash. Attempt to catch it earlier by (optionally) reading back from the flash immediately after writing it. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-07-10[JFFS2] Whitespace cleanups.David Woodhouse
Convert many spaces to tabs; one or two other minor cosmetic fixes. Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2007-06-11fs: hugetlbfs: Disable for shnommu.Paul Mundt
SH can turn CONFIG_MMU on and off, don't let us get to a state where hugetlbfs/hugetlbpage gets built when building for nommu. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2007-05-09Remove obsolete fat_cvf help textAlexander E. Patrakov
The text removed by the following patch refers to functionality that never worked, to non-existing documentation file, and to mount options marked as obsolete in the module. Signed-off-by: Alexander E. Patrakov <patrakov@ums.usu.ru> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08reiserfs: proc support requires PROC_FSRandy Dunlap
REISER_FS /proc option needs to depend on PROC_FS. fs/reiserfs/procfs.c: In function 'show_super': fs/reiserfs/procfs.c:134: error: 'reiserfs_proc_info_data_t' has no member named 'max_hash_collisions' fs/reiserfs/procfs.c:134: error: 'reiserfs_proc_info_data_t' has no member named 'breads' fs/reiserfs/procfs.c:135: error: 'reiserfs_proc_info_data_t' has no member named 'bread_miss' fs/reiserfs/procfs.c:135: error: 'reiserfs_proc_info_data_t' has no member named 'search_by_key' fs/reiserfs/procfs.c:136: error: 'reiserfs_proc_info_data_t' has no member named 'search_by_key_fs_changed' fs/reiserfs/procfs.c:136: error: 'reiserfs_proc_info_data_t' has no member named 'search_by_key_restarted' fs/reiserfs/procfs.c:137: error: 'reiserfs_proc_info_data_t' has no member named 'insert_item_restarted' fs/reiserfs/procfs.c:137: error: 'reiserfs_proc_info_data_t' has no member named 'paste_into_item_restarted' fs/reiserfs/procfs.c:138: error: 'reiserfs_proc_info_data_t' has no member named 'cut_from_item_restarted' fs/reiserfs/procfs.c:139: error: 'reiserfs_proc_info_data_t' has no member named 'delete_solid_item_restarted' fs/reiserfs/procfs.c:139: error: 'reiserfs_proc_info_data_t' has no member named 'delete_item_restarted' fs/reiserfs/procfs.c:140: error: 'reiserfs_proc_info_data_t' has no member named 'leaked_oid' fs/reiserfs/procfs.c:140: error: 'reiserfs_proc_info_data_t' has no member named 'leaves_removable' fs/reiserfs/procfs.c: In function 'show_per_level': fs/reiserfs/procfs.c:184: error: 'reiserfs_proc_info_data_t' has no member named 'balance_at' fs/reiserfs/procfs.c:185: error: 'reiserfs_proc_info_data_t' has no member named 'sbk_read_at' fs/reiserfs/procfs.c:186: error: 'reiserfs_proc_info_data_t' has no member named 'sbk_fs_changed' fs/reiserfs/procfs.c:187: error: 'reiserfs_proc_info_data_t' has no member named 'sbk_restarted' fs/reiserfs/procfs.c:188: error: 'reiserfs_proc_info_data_t' has no member named 'free_at' fs/reiserfs/procfs.c:189: error: 'reiserfs_proc_info_data_t' has no member named 'items_at' fs/reiserfs/procfs.c:190: error: 'reiserfs_proc_info_data_t' has no member named 'can_node_be_removed' fs/reiserfs/procfs.c:191: error: 'reiserfs_proc_info_data_t' has no member named 'lnum' fs/reiserfs/procfs.c:192: error: 'reiserfs_proc_info_data_t' has no member named 'rnum' fs/reiserfs/procfs.c:193: error: 'reiserfs_proc_info_data_t' has no member named 'lbytes' fs/reiserfs/procfs.c:194: error: 'reiserfs_proc_info_data_t' has no member named 'rbytes' fs/reiserfs/procfs.c:195: error: 'reiserfs_proc_info_data_t' has no member named 'get_neighbors' fs/reiserfs/procfs.c:196: error: 'reiserfs_proc_info_data_t' has no member named 'get_neighbors_restart' fs/reiserfs/procfs.c:197: error: 'reiserfs_proc_info_data_t' has no member named 'need_l_neighbor' fs/reiserfs/procfs.c:197: error: 'reiserfs_proc_info_data_t' has no member named 'need_r_neighbor' fs/reiserfs/procfs.c: In function 'show_bitmap': fs/reiserfs/procfs.c:224: error: 'reiserfs_proc_info_data_t' has no member named 'free_block' fs/reiserfs/procfs.c:225: error: 'reiserfs_proc_info_data_t' has no member named 'scan_bitmap' fs/reiserfs/procfs.c:226: error: 'reiserfs_proc_info_data_t' has no member named 'scan_bitmap' fs/reiserfs/procfs.c:227: error: 'reiserfs_proc_info_data_t' has no member named 'scan_bitmap' fs/reiserfs/procfs.c:228: error: 'reiserfs_proc_info_data_t' has no member named 'scan_bitmap' fs/reiserfs/procfs.c:229: error: 'reiserfs_proc_info_data_t' has no member named 'scan_bitmap' fs/reiserfs/procfs.c:230: error: 'reiserfs_proc_info_data_t' has no member named 'scan_bitmap' fs/reiserfs/procfs.c:230: error: 'reiserfs_proc_info_data_t' has no member named 'scan_bitmap' fs/reiserfs/procfs.c: In function 'show_journal': fs/reiserfs/procfs.c:384: error: 'reiserfs_proc_info_data_t' has no member named 'journal' fs/reiserfs/procfs.c:385: error: 'reiserfs_proc_info_data_t' has no member named 'journal' fs/reiserfs/procfs.c:386: error: 'reiserfs_proc_info_data_t' has no member named 'journal' fs/reiserfs/procfs.c:387: error: 'reiserfs_proc_info_data_t' has no member named 'journal' fs/reiserfs/procfs.c:388: error: 'reiserfs_proc_info_data_t' has no member named 'journal' fs/reiserfs/procfs.c:389: error: 'reiserfs_proc_info_data_t' has no member named 'journal' fs/reiserfs/procfs.c:390: error: 'reiserfs_proc_info_data_t' has no member named 'journal' fs/reiserfs/procfs.c:391: error: 'reiserfs_proc_info_data_t' has no member named 'journal' fs/reiserfs/procfs.c:392: error: 'reiserfs_proc_info_data_t' has no member named 'journal' fs/reiserfs/procfs.c:393: error: 'reiserfs_proc_info_data_t' has no member named 'journal' fs/reiserfs/procfs.c:394: error: 'reiserfs_proc_info_data_t' has no member named 'journal' fs/reiserfs/procfs.c:395: error: 'reiserfs_proc_info_data_t' has no member named 'journal' fs/reiserfs/procfs.c:395: error: 'reiserfs_proc_info_data_t' has no member named 'journal' fs/reiserfs/procfs.c:395: error: 'reiserfs_proc_info_data_t' has no member named 'journal' fs/reiserfs/procfs.c: In function 'reiserfs_proc_info_init': fs/reiserfs/procfs.c:504: warning: implicit declaration of function '__PINFO' fs/reiserfs/procfs.c:504: error: request for member 'lock' in something not a structure or union fs/reiserfs/procfs.c: In function 'reiserfs_proc_info_done': fs/reiserfs/procfs.c:544: error: request for member 'lock' in something not a structure or union fs/reiserfs/procfs.c:545: error: request for member 'exiting' in something not a structure or union fs/reiserfs/procfs.c:546: error: request for member 'lock' in something not a structure or union Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-04Merge git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/pub/linux/nfs-2.6: (28 commits) NFS: Fix a compile glitch on 64-bit systems NFS: Clean up nfs_create_request comments spkm3: initialize hash spkm3: remove bad kfree, unnecessary export spkm3: fix spkm3's use of hmac NFS4: invalidate cached acl on setacl NFS: Fix directory caching problem - with test case and patch. NFS: Set meaningful value for fattr->time_start in readdirplus results. NFS: Added support to turn off the NFSv3 READDIRPLUS RPC. SUNRPC: RPC client should retry with different versions of rpcbind SUNRPC: remove old portmapper NFS: switch NFSROOT to use new rpcbind client SUNRPC: switch the RPC server to use the new rpcbind registration API SUNRPC: switch socket-based RPC transports to use rpcbind SUNRPC: introduce rpcbind: replacement for in-kernel portmapper SUNRPC: Eliminate side effects from rpc_malloc SUNRPC: RPC buffer size estimates are too large NLM: Shrink the maximum request size of NLM4 requests NFS: Use pgoff_t in structures and functions that pass page cache offsets NFS: Clean up nfs_sync_mapping_wait() ...
2007-05-03[AFS/AF_RXRPC]: Miscellaneous fixes.David Howells
Make miscellaneous fixes to AFS and AF_RXRPC: (*) Make AF_RXRPC select KEYS rather than RXKAD or AFS_FS in Kconfig. (*) Don't use FS_BINARY_MOUNTDATA. (*) Remove a done 'TODO' item in a comemnt on afs_get_sb(). (*) Don't pass a void * as the page pointer argument of kmap_atomic() as this breaks on m68k. Patch from Geert Uytterhoeven <geert@linux-m68k.org>. (*) Use match_*() functions rather than doing my own parsing. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-30SUNRPC: RPC client should retry with different versions of rpcbindChuck Lever
Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2007-04-27[AF_RXRPC/AFS]: Arch-specific fixes.David Howells
Fixes for various arch compilation problems: (*) Missing module exports. (*) Variable name collision when rxkad and af_rxrpc both built in (rxrpc_debug). (*) Large constant representation problem (AFS_UUID_TO_UNIX_TIME). (*) Configuration dependencies. (*) printk() format warnings. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AF_RXRPC]: Delete the old RxRPC code.David Howells
Delete the old RxRPC code as it's now no longer used. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-26[AF_RXRPC]: Make the in-kernel AFS filesystem use AF_RXRPC.David Howells
Make the in-kernel AFS filesystem use AF_RXRPC instead of the old RxRPC code. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-02-17Remove JFFS (version 1), as scheduled.Jeff Garzik
Unmaintained for years, few if any users. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-02-13Merge master.kernel.org:/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/sfrench/cifs-2.6: [CIFS] on reconnect to Samba - reset the unix capabilities [CIFS] Allow update of EOF on remote extend of file [CIFS] POSIX CIFS Extensions (continued) - POSIX Open [CIFS] Additional POSIX CIFS Extensions infolevels
2007-02-14[CIFS] on reconnect to Samba - reset the unix capabilitiesSteve French
After temporary server or network failure and reconneciton, we were not resending the unix capabilities via SetFSInfo - which confused Samba posix byte range locking code. Discovered by jra Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-02-12[PATCH] eCryptfs: Public key transport mechanismMichael Halcrow
This is the transport code for public key functionality in eCryptfs. It manages encryption/decryption request queues with a transport mechanism. Currently, netlink is the only implemented transport. Each inode has a unique File Encryption Key (FEK). Under passphrase, a File Encryption Key Encryption Key (FEKEK) is generated from a salt/passphrase combo on mount. This FEKEK encrypts each FEK and writes it into the header of each file using the packet format specified in RFC 2440. This is all symmetric key encryption, so it can all be done via the kernel crypto API. These new patches introduce public key encryption of the FEK. There is no asymmetric key encryption support in the kernel crypto API, so eCryptfs pushes the FEK encryption and decryption out to a userspace daemon. After considering our requirements and determining the complexity of using various transport mechanisms, we settled on netlink for this communication. eCryptfs stores authentication tokens into the kernel keyring. These tokens correlate with individual keys. For passphrase mode of operation, the authentication token contains the symmetric FEKEK. For public key, the authentication token contains a PKI type and an opaque data blob managed by individual PKI modules in userspace. Each user who opens a file under an eCryptfs partition mounted in public key mode must be running a daemon. That daemon has the user's credentials and has access to all of the keys to which the user should have access. The daemon, when started, initializes the pluggable PKI modules available on the system and registers itself with the eCryptfs kernel module. Userspace utilities register public key authentication tokens into the user session keyring. These authentication tokens correlate key signatures with PKI modules and PKI blobs. The PKI blobs contain PKI-specific information necessary for the PKI module to carry out asymmetric key encryption and decryption. When the eCryptfs module parses the header of an existing file and finds a Tag 1 (Public Key) packet (see RFC 2440), it reads in the public key identifier (signature). The asymmetrically encrypted FEK is in the Tag 1 packet; eCryptfs puts together a decrypt request packet containing the signature and the encrypted FEK, then it passes it to the daemon registered for the current->euid via a netlink unicast to the PID of the daemon, which was registered at the time the daemon was started by the user. The daemon actually just makes calls to libecryptfs, which implements request packet parsing and manages PKI modules. libecryptfs grabs the public key authentication token for the given signature from the user session keyring. This auth tok tells libecryptfs which PKI module should receive the request. libecryptfs then makes a decrypt() call to the PKI module, and it passes along the PKI block from the auth tok. The PKI uses the blob to figure out how it should decrypt the data passed to it; it performs the decryption and passes the decrypted data back to libecryptfs. libecryptfs then puts together a reply packet with the decrypted FEK and passes that back to the eCryptfs module. The eCryptfs module manages these request callouts to userspace code via message context structs. The module maintains an array of message context structs and places the elements of the array on two lists: a free and an allocated list. When eCryptfs wants to make a request, it moves a msg ctx from the free list to the allocated list, sets its state to pending, and fires off the message to the user's registered daemon. When eCryptfs receives a netlink message (via the callback), it correlates the msg ctx struct in the alloc list with the data in the message itself. The msg->index contains the offset of the array of msg ctx structs. It verifies that the registered daemon PID is the same as the PID of the process that sent the message. It also validates a sequence number between the received packet and the msg ctx. Then, it copies the contents of the message (the reply packet) into the msg ctx struct, sets the state in the msg ctx to done, and wakes up the process that was sleeping while waiting for the reply. The sleeping process was whatever was performing the sys_open(). This process originally called ecryptfs_send_message(); it is now in ecryptfs_wait_for_response(). When it wakes up and sees that the msg ctx state was set to done, it returns a pointer to the message contents (the reply packet) and returns. If all went well, this packet contains the decrypted FEK, which is then copied into the crypt_stat struct, and life continues as normal. The case for creation of a new file is very similar, only instead of a decrypt request, eCryptfs sends out an encrypt request. > - We have a great clod of key mangement code in-kernel. Why is that > not suitable (or growable) for public key management? eCryptfs uses Howells' keyring to store persistent key data and PKI state information. It defers public key cryptographic transformations to userspace code. The userspace data manipulation request really is orthogonal to key management in and of itself. What eCryptfs basically needs is a secure way to communicate with a particular daemon for a particular task doing a syscall, based on the UID. Nothing running under another UID should be able to access that channel of communication. > - Is it appropriate that new infrastructure for public key > management be private to a particular fs? The messaging.c file contains a lot of code that, perhaps, could be extracted into a separate kernel service. In essence, this would be a sort of request/reply mechanism that would involve a userspace daemon. I am not aware of anything that does quite what eCryptfs does, so I was not aware of any existing tools to do just what we wanted. > What happens if one of these daemons exits without sending a quit > message? There is a stale uid<->pid association in the hash table for that user. When the user registers a new daemon, eCryptfs cleans up the old association and generates a new one. See ecryptfs_process_helo(). > - _why_ does it use netlink? Netlink provides the transport mechanism that would minimize the complexity of the implementation, given that we can have multiple daemons (one per user). I explored the possibility of using relayfs, but that would involve having to introduce control channels and a protocol for creating and tearing down channels for the daemons. We do not have to worry about any of that with netlink. Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Remove unused kernel config option ZISOFS_FSRobert P. J. Day
Remove the kernel config option ZISOFS_FS, since it appears that the actual option is simply ZISOFS. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-07[PATCH] ocfs2: drop INET from Kconfig, not neededRandy Dunlap
OCFS2: drop 'depends on INET' since local mounts are now allowed. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-22[PATCH] Make JFFS depend on CONFIG_BROKENJosh Boyer
Mark JFFS as broken and provide a warning to users that it is deprecated and scheduled for removal in 2.6.21 Signed-off-by: Josh Boyer <jwboyer@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-12kconfig: Standardize "depends" -> "depends on" in Kconfig filesRobert P. J. Day
Standardize the miniscule percentage of occurrences of "depends" in Kconfig files to "depends on", and update kconfig-language.txt to reflect that. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-12-12EXT{2,3,4}_FS: remove outdated part of the help textJan Engelhardt
Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-30Fix typos in doc and commentsJan Engelhardt
Changes persistant -> persistent. www.dictionary.com does not know persistant (with an A), but should it be one of those things you can spell in more than one correct way, let me know. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-30Fix misc Kconfig typosMatt LaPlante
Fix various Kconfig typos. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-16[PATCH] AFS: Amend the AFS configuration optionsDavid Howells
Amend the text of AFS configuration options. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-25[CRYPTO] users: Select ECB/CBC where neededPatrick McHardy
CRYPTO_MANAGER is selected automatically by CONFIG_ECB and CONFIG_CBC. config CRYPTO_ECB tristate "ECB support" select CRYPTO_BLKCIPHER select CRYPTO_MANAGER I've added CONFIG_ECB to the ones you mentioned and CONFIG_CBC to gssapi. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-10-20[PATCH] fs/Kconfig: move GENERIC_ACL, fix acl() call errorsRandy Dunlap
GENERIC_ACL shouldn't be under Network File Systems (which made it depend on NET) as far as I can tell. Having it there and having many (FS) config symbols disabled gives this (which the patch fixes): mm/built-in.o: In function `shmem_check_acl': shmem_acl.c:(.text.shmem_check_acl+0x33): undefined reference to `posix_acl_permission' fs/built-in.o: In function `generic_acl_get': (.text.generic_acl_get+0x30): undefined reference to `posix_acl_to_xattr' fs/built-in.o: In function `generic_acl_set': (.text.generic_acl_set+0x75): undefined reference to `posix_acl_from_xattr' fs/built-in.o: In function `generic_acl_set': (.text.generic_acl_set+0x94): undefined reference to `posix_acl_valid' fs/built-in.o: In function `generic_acl_set': (.text.generic_acl_set+0xc1): undefined reference to `posix_acl_equiv_mode' fs/built-in.o: In function `generic_acl_init': (.text.generic_acl_init+0x7a): undefined reference to `posix_acl_clone' fs/built-in.o: In function `generic_acl_init': (.text.generic_acl_init+0xb4): undefined reference to `posix_acl_clone' fs/built-in.o: In function `generic_acl_init': (.text.generic_acl_init+0xc8): undefined reference to `posix_acl_create_masq' fs/built-in.o: In function `generic_acl_chmod': (.text.generic_acl_chmod+0x49): undefined reference to `posix_acl_clone' fs/built-in.o: In function `generic_acl_chmod': (.text.generic_acl_chmod+0x76): undefined reference to `posix_acl_chmod_masq' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: (27 commits) [CIFS] Missing flags2 for DFS [CIFS] Workaround incomplete byte length returned by some [CIFS] cifs Kconfig: don't select CONNECTOR [CIFS] Level 1 QPathInfo needed for proper OS2 support [CIFS] fix typo in previous patch [CIFS] Fix old DOS time conversion to handle timezone [CIFS] Do not need to adjust for Jan/Feb for leap day [CIFS] Fix leaps year calculation for years after 2100 [CIFS] readdir (ffirst) enablement of accurate timestamps from legacy servers [CIFS] Fix compiler warning with previous patch [CIFS] Fix typo [CIFS] Allow for 15 minute TZs (e.g. Nepal) and be more explicit about [CIFS] Fix readdir of large directories for backlevel servers [CIFS] Allow LANMAN21 support even in both POSIX non-POSIX path [CIFS] Make use of newer QFSInfo dependent on capability bit instead of [CIFS] Do not send newer QFSInfo to legacy servers which can not support it [CIFS] Fix typo in name of new cifs_show_stats [CIFS] Rename server time zone field [CIFS] Handle legacy servers which return undefined time zone [CIFS] CIFS support for /proc/<pid>/mountstats part 1 ... Manual conflict resolution in fs/cifs/connect.c
2006-10-12[CIFS] cifs Kconfig: don't select CONNECTORAndrew Morton
`select' is a bit obnoxious: the option keeps on coming back and it's hard to work out what to do to make it go away again. The use of `depends on' is preferred (although it has usability problems too..) Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-10-11[PATCH] jbd2: enable building of jbd2 and have ext4 use it rather than jbdMingming Cao
Reworked from a patch by Mingming Cao and Randy Dunlap Signed-off-By: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: enable building of ext4Mingming Cao
Originally part of a patch from Mingming Cao and Randy Dunlap. Reorganized by Shaggy. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Mingming Cao<cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6: (292 commits) [GFS2] Fix endian bug for de_type [GFS2] Initialize SELinux extended attributes at inode creation time. [GFS2] Move logging code into log.c (mostly) [GFS2] Mark nlink cleared so VFS sees it happen [GFS2] Two redundant casts removed [GFS2] Remove uneeded endian conversion [GFS2] Remove duplicate sb reading code [GFS2] Mark metadata reads for blktrace [GFS2] Remove iflags.h, use FS_ [GFS2] Fix code style/indent in ops_file.c [GFS2] streamline-generic_file_-interfaces-and-filemap gfs fix [GFS2] Remove readv/writev methods and use aio_read/aio_write instead (gfs bits) [GFS2] inode-diet: Eliminate i_blksize from the inode structure [GFS2] inode_diet: Replace inode.u.generic_ip with inode.i_private (gfs) [GFS2] Fix typo in last patch [GFS2] Fix direct i/o logic in filemap.c [GFS2] Fix bug in Makefiles for lock modules [GFS2] Remove (extra) fs_subsys declaration [GFS2/DLM] Fix trailing whitespace [GFS2] Tidy up meta_io code ...
2006-10-04[PATCH] ecryptfs: fs/Makefile and fs/KconfigMichael Halcrow
eCryptfs is a stacked cryptographic filesystem for Linux. It is derived from Erez Zadok's Cryptfs, implemented through the FiST framework for generating stacked filesystems. eCryptfs extends Cryptfs to provide advanced key management and policy features. eCryptfs stores cryptographic metadata in the header of each file written, so that encrypted files can be copied between hosts; the file will be decryptable with the proper key, and there is no need to keep track of any additional information aside from what is already in the encrypted file itself. [akpm@osdl.org: updates for ongoing API changes] [bunk@stusta.de: cleanups] [akpm@osdl.org: alpha build fix] [akpm@osdl.org: cleanups] [tytso@mit.edu: inode-diet updates] [pbadari@us.ibm.com: generic_file_*_read/write() interface updates] [rdunlap@xenotime.net: printk format fixes] [akpm@osdl.org: make slab creation and teardown table-driven] Signed-off-by: Phillip Hellewell <phillip@hellewell.homeip.net> Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03Still more typo fixesMatt LaPlante
2006-10-03more misc typo fixesMatt LaPlante
2006-10-03Typos in fs/KconfigMatt LaPlante
2006-10-02Merge branch 'master' into gfs2Steven Whitehouse
2006-09-30[PATCH] BLOCK: Make it possible to disable the block layer [try #6]David Howells
Make it possible to disable the block layer. Not all embedded devices require it, some can make do with just JFFS2, NFS, ramfs, etc - none of which require the block layer to be present. This patch does the following: (*) Introduces CONFIG_BLOCK to disable the block layer, buffering and blockdev support. (*) Adds dependencies on CONFIG_BLOCK to any configuration item that controls an item that uses the block layer. This includes: (*) Block I/O tracing. (*) Disk partition code. (*) All filesystems that are block based, eg: Ext3, ReiserFS, ISOFS. (*) The SCSI layer. As far as I can tell, even SCSI chardevs use the block layer to do scheduling. Some drivers that use SCSI facilities - such as USB storage - end up disabled indirectly from this. (*) Various block-based device drivers, such as IDE and the old CDROM drivers. (*) MTD blockdev handling and FTL. (*) JFFS - which uses set_bdev_super(), something it could avoid doing by taking a leaf out of JFFS2's book. (*) Makes most of the contents of linux/blkdev.h, linux/buffer_head.h and linux/elevator.h contingent on CONFIG_BLOCK being set. sector_div() is, however, still used in places, and so is still available. (*) Also made contingent are the contents of linux/mpage.h, linux/genhd.h and parts of linux/fs.h. (*) Makes a number of files in fs/ contingent on CONFIG_BLOCK. (*) Makes mm/bounce.c (bounce buffering) contingent on CONFIG_BLOCK. (*) set_page_dirty() doesn't call __set_page_dirty_buffers() if CONFIG_BLOCK is not enabled. (*) fs/no-block.c is created to hold out-of-line stubs and things that are required when CONFIG_BLOCK is not set: (*) Default blockdev file operations (to give error ENODEV on opening). (*) Makes some /proc changes: (*) /proc/devices does not list any blockdevs. (*) /proc/diskstats and /proc/partitions are contingent on CONFIG_BLOCK. (*) Makes some compat ioctl handling contingent on CONFIG_BLOCK. (*) If CONFIG_BLOCK is not defined, makes sys_quotactl() return -ENODEV if given command other than Q_SYNC or if a special device is specified. (*) In init/do_mounts.c, no reference is made to the blockdev routines if CONFIG_BLOCK is not defined. This does not prohibit NFS roots or JFFS2. (*) The bdflush, ioprio_set and ioprio_get syscalls can now be absent (return error ENOSYS by way of cond_syscall if so). (*) The seclvl_bd_claim() and seclvl_bd_release() security calls do nothing if CONFIG_BLOCK is not set, since they can't then happen. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
