path: root/fs/Kconfig
2006-11-16[PATCH] AFS: Amend the AFS configuration optionsDavid Howells
Amend the text of AFS configuration options. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-25[CRYPTO] users: Select ECB/CBC where neededPatrick McHardy
CRYPTO_MANAGER is selected automatically by CONFIG_ECB and CONFIG_CBC. config CRYPTO_ECB tristate "ECB support" select CRYPTO_BLKCIPHER select CRYPTO_MANAGER I've added CONFIG_ECB to the ones you mentioned and CONFIG_CBC to gssapi. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2006-10-20[PATCH] fs/Kconfig: move GENERIC_ACL, fix acl() call errorsRandy Dunlap
GENERIC_ACL shouldn't be under Network File Systems (which made it depend on NET) as far as I can tell. Having it there and having many (FS) config symbols disabled gives this (which the patch fixes): mm/built-in.o: In function `shmem_check_acl': shmem_acl.c:(.text.shmem_check_acl+0x33): undefined reference to `posix_acl_permission' fs/built-in.o: In function `generic_acl_get': (.text.generic_acl_get+0x30): undefined reference to `posix_acl_to_xattr' fs/built-in.o: In function `generic_acl_set': (.text.generic_acl_set+0x75): undefined reference to `posix_acl_from_xattr' fs/built-in.o: In function `generic_acl_set': (.text.generic_acl_set+0x94): undefined reference to `posix_acl_valid' fs/built-in.o: In function `generic_acl_set': (.text.generic_acl_set+0xc1): undefined reference to `posix_acl_equiv_mode' fs/built-in.o: In function `generic_acl_init': (.text.generic_acl_init+0x7a): undefined reference to `posix_acl_clone' fs/built-in.o: In function `generic_acl_init': (.text.generic_acl_init+0xb4): undefined reference to `posix_acl_clone' fs/built-in.o: In function `generic_acl_init': (.text.generic_acl_init+0xc8): undefined reference to `posix_acl_create_masq' fs/built-in.o: In function `generic_acl_chmod': (.text.generic_acl_chmod+0x49): undefined reference to `posix_acl_clone' fs/built-in.o: In function `generic_acl_chmod': (.text.generic_acl_chmod+0x76): undefined reference to `posix_acl_chmod_masq' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Andreas Gruenbacher <agruen@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: (27 commits) [CIFS] Missing flags2 for DFS [CIFS] Workaround incomplete byte length returned by some [CIFS] cifs Kconfig: don't select CONNECTOR [CIFS] Level 1 QPathInfo needed for proper OS2 support [CIFS] fix typo in previous patch [CIFS] Fix old DOS time conversion to handle timezone [CIFS] Do not need to adjust for Jan/Feb for leap day [CIFS] Fix leaps year calculation for years after 2100 [CIFS] readdir (ffirst) enablement of accurate timestamps from legacy servers [CIFS] Fix compiler warning with previous patch [CIFS] Fix typo [CIFS] Allow for 15 minute TZs (e.g. Nepal) and be more explicit about [CIFS] Fix readdir of large directories for backlevel servers [CIFS] Allow LANMAN21 support even in both POSIX non-POSIX path [CIFS] Make use of newer QFSInfo dependent on capability bit instead of [CIFS] Do not send newer QFSInfo to legacy servers which can not support it [CIFS] Fix typo in name of new cifs_show_stats [CIFS] Rename server time zone field [CIFS] Handle legacy servers which return undefined time zone [CIFS] CIFS support for /proc/<pid>/mountstats part 1 ... Manual conflict resolution in fs/cifs/connect.c
2006-10-12[CIFS] cifs Kconfig: don't select CONNECTORAndrew Morton
`select' is a bit obnoxious: the option keeps on coming back and it's hard to work out what to do to make it go away again. The use of `depends on' is preferred (although it has usability problems too..) Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-10-11[PATCH] jbd2: enable building of jbd2 and have ext4 use it rather than jbdMingming Cao
Reworked from a patch by Mingming Cao and Randy Dunlap Signed-off-By: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-11[PATCH] ext4: enable building of ext4Mingming Cao
Originally part of a patch from Mingming Cao and Randy Dunlap. Reorganized by Shaggy. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Mingming Cao<cmm@us.ibm.com> Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6: (292 commits) [GFS2] Fix endian bug for de_type [GFS2] Initialize SELinux extended attributes at inode creation time. [GFS2] Move logging code into log.c (mostly) [GFS2] Mark nlink cleared so VFS sees it happen [GFS2] Two redundant casts removed [GFS2] Remove uneeded endian conversion [GFS2] Remove duplicate sb reading code [GFS2] Mark metadata reads for blktrace [GFS2] Remove iflags.h, use FS_ [GFS2] Fix code style/indent in ops_file.c [GFS2] streamline-generic_file_-interfaces-and-filemap gfs fix [GFS2] Remove readv/writev methods and use aio_read/aio_write instead (gfs bits) [GFS2] inode-diet: Eliminate i_blksize from the inode structure [GFS2] inode_diet: Replace inode.u.generic_ip with inode.i_private (gfs) [GFS2] Fix typo in last patch [GFS2] Fix direct i/o logic in filemap.c [GFS2] Fix bug in Makefiles for lock modules [GFS2] Remove (extra) fs_subsys declaration [GFS2/DLM] Fix trailing whitespace [GFS2] Tidy up meta_io code ...
2006-10-04[PATCH] ecryptfs: fs/Makefile and fs/KconfigMichael Halcrow
eCryptfs is a stacked cryptographic filesystem for Linux. It is derived from Erez Zadok's Cryptfs, implemented through the FiST framework for generating stacked filesystems. eCryptfs extends Cryptfs to provide advanced key management and policy features. eCryptfs stores cryptographic metadata in the header of each file written, so that encrypted files can be copied between hosts; the file will be decryptable with the proper key, and there is no need to keep track of any additional information aside from what is already in the encrypted file itself. [akpm@osdl.org: updates for ongoing API changes] [bunk@stusta.de: cleanups] [akpm@osdl.org: alpha build fix] [akpm@osdl.org: cleanups] [tytso@mit.edu: inode-diet updates] [pbadari@us.ibm.com: generic_file_*_read/write() interface updates] [rdunlap@xenotime.net: printk format fixes] [akpm@osdl.org: make slab creation and teardown table-driven] Signed-off-by: Phillip Hellewell <phillip@hellewell.homeip.net> Signed-off-by: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Erez Zadok <ezk@cs.sunysb.edu> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Stephan Mueller <smueller@chronox.de> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03Still more typo fixesMatt LaPlante
2006-10-03more misc typo fixesMatt LaPlante
2006-10-03Typos in fs/KconfigMatt LaPlante
2006-10-02Merge branch 'master' into gfs2Steven Whitehouse
2006-09-30[PATCH] BLOCK: Make it possible to disable the block layer [try #6]David Howells
Make it possible to disable the block layer. Not all embedded devices require it, some can make do with just JFFS2, NFS, ramfs, etc - none of which require the block layer to be present. This patch does the following: (*) Introduces CONFIG_BLOCK to disable the block layer, buffering and blockdev support. (*) Adds dependencies on CONFIG_BLOCK to any configuration item that controls an item that uses the block layer. This includes: (*) Block I/O tracing. (*) Disk partition code. (*) All filesystems that are block based, eg: Ext3, ReiserFS, ISOFS. (*) The SCSI layer. As far as I can tell, even SCSI chardevs use the block layer to do scheduling. Some drivers that use SCSI facilities - such as USB storage - end up disabled indirectly from this. (*) Various block-based device drivers, such as IDE and the old CDROM drivers. (*) MTD blockdev handling and FTL. (*) JFFS - which uses set_bdev_super(), something it could avoid doing by taking a leaf out of JFFS2's book. (*) Makes most of the contents of linux/blkdev.h, linux/buffer_head.h and linux/elevator.h contingent on CONFIG_BLOCK being set. sector_div() is, however, still used in places, and so is still available. (*) Also made contingent are the contents of linux/mpage.h, linux/genhd.h and parts of linux/fs.h. (*) Makes a number of files in fs/ contingent on CONFIG_BLOCK. (*) Makes mm/bounce.c (bounce buffering) contingent on CONFIG_BLOCK. (*) set_page_dirty() doesn't call __set_page_dirty_buffers() if CONFIG_BLOCK is not enabled. (*) fs/no-block.c is created to hold out-of-line stubs and things that are required when CONFIG_BLOCK is not set: (*) Default blockdev file operations (to give error ENODEV on opening). (*) Makes some /proc changes: (*) /proc/devices does not list any blockdevs. (*) /proc/diskstats and /proc/partitions are contingent on CONFIG_BLOCK. (*) Makes some compat ioctl handling contingent on CONFIG_BLOCK. (*) If CONFIG_BLOCK is not defined, makes sys_quotactl() return -ENODEV if given command other than Q_SYNC or if a special device is specified. (*) In init/do_mounts.c, no reference is made to the blockdev routines if CONFIG_BLOCK is not defined. This does not prohibit NFS roots or JFFS2. (*) The bdflush, ioprio_set and ioprio_get syscalls can now be absent (return error ENOSYS by way of cond_syscall if so). (*) The seclvl_bd_claim() and seclvl_bd_release() security calls do nothing if CONFIG_BLOCK is not set, since they can't then happen. Signed-Off-By: David Howells <dhowells@redhat.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2006-09-29[PATCH] Access Control Lists for tmpfsAndreas Gruenbacher
Add access control lists for tmpfs. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-29[PATCH] Generic infrastructure for aclsAndreas Gruenbacher
The patches solve the following problem: We want to grant access to devices based on who is logged in from where, etc. This includes switching back and forth between multiple user sessions, etc. Using ACLs to define device access for logged-in users gives us all the flexibility we need in order to fully solve the problem. Device special files nowadays usually live on tmpfs, hence tmpfs ACLs. Different distros have come up with solutions that solve the problem to different degrees: SUSE uses a resource manager which tracks login sessions and sets ACLs on device inodes as appropriate. RedHat uses pam_console, which changes the primary file ownership to the logged-in user. Others use a set of groups that users must be in in order to be granted the appropriate accesses. The freedesktop.org project plans to implement a combination of a console-tracker and a HAL-device-list based solution to grant access to devices to users, and more distros will likely follow this approach. These patches have first been posted here on 2 February 2005, and again on 8 January 2006. We have been shipping them in SLES9 and SLES10 with no problems reported. The previous submission is archived here: http://lkml.org/lkml/2006/1/8/229 http://lkml.org/lkml/2006/1/8/230 http://lkml.org/lkml/2006/1/8/231 This patch: Add some infrastructure for access control lists on in-memory filesystems such as tmpfs. Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-28Merge branch 'master' into gfs2Steven Whitehouse
2006-09-27[PATCH] sysctl: Allow /proc/sys without sys_sysctlEric W. Biederman
Since sys_sysctl is deprecated start allow it to be compiled out. This should catch any remaining user space code that cares, and paves the way for further sysctl cleanups. [akpm@osdl.org: If sys_sysctl() is not compiled-in, emit a warning] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-25[GFS2] Fix up merge of Linus' kernel into GFS2Steven Whitehouse
This fixes up a couple of conflicts when merging up with Linus' latest kernel. This will hopefully allow GFS2 to be more easily merged into forthcoming -mm and FC kernels due to the "one line per header" format now used for the kernel headers. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Conflicts: include/linux/Kbuild include/linux/kernel.h
2006-09-22NFS: unmark NFS direct I/O as experimentalChuck Lever
Remove the EXPERIMENTAL flag from the NFS_DIRECTIO option. Test plan: Unset the EXPERIMENTAL kernel build option and check to see that the NFS direct I/O option is still available. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2006-09-20ocfs2: Remove EXPERIMENTAL dependencyMark Fasheh
Things have been working pretty well for a while now. We should've probably done this at least one kernel revision ago, but it doesn't hurt to be paranoid. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-07-17Merge branch 'master'Steven Whitehouse
2006-07-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: [CIFS] CIFS_DEBUG2 depends on CIFS
2006-07-08[CIFS] CIFS_DEBUG2 depends on CIFSSteve French
2006-07-03Merge rsync://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6Steven Whitehouse
Conflicts: include/linux/kernel.h
2006-06-29ocfs2: OCFS2_FS must depend on SYSFSAdrian Bunk
Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-06-29ocfs2: Compile-time disabling of ocfs2 debugging output.Joel Becker
Give gcc the chance to compile out the debug logging code in ocfs2. This saves some size at the expense of being able to debug the code. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-06-27Merge git://git.infradead.org/mtd-2.6Linus Torvalds
* git://git.infradead.org/mtd-2.6: [MTD] NAND: Select chip before checking write protect status [MTD] CORE mtdchar.c: fix off-by-one error in lseek() [MTD] NAND: Fix typo in mtd/nand/ts7250.c [JFFS2][XATTR] coexistence between xattr and write buffering support. [JFFS2][XATTR] Fix wrong copyright [JFFS2][XATTR] Re-define xd->refcnt as atomic_t [JFFS2][XATTR] Fix memory leak with jffs2_xattr_ref [JFFS2][XATTR] rid unnecessary writing of delete marker. [JFFS2][XATTR] Fix ACL bug when updating null xattr by null ACL. [JFFS2][XATTR] using 'delete marker' for xdatum/xref deletion [MTD] Fix off-by-one error in physmap.c [MTD] Remove unused 'nr_banks' variable from ixp2000 map driver [MTD NAND] s3c2412 support in s3c2410.c [MTD] Initialize 'writesize' [MTD] NAND: ndfc fix address offset thinko [MTD] NAND: S3C2410 convert prinks to dev_*()s [MTD] NAND: Missing fixups
2006-06-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: (25 commits) [CIFS] Fix authentication choice so we do not force NTLMv2 unless the [CIFS] Fix alignment of unicode strings in previous patch [CIFS] Fix allocation of buffers for new session setup routine to allow [CIFS] Remove calls to to take f_owner.lock [CIFS] remove some redundant null pointer checks [CIFS] Fix compile warning when CONFIG_CIFS_EXPERIMENTAL is off [CIFS] Enable sec flags on mount for cifs (part one) [CIFS] Fix suspend/resume problem which causes EIO on subsequent access to [CIFS] fix minor compile warning when config_cifs_weak_security is off [CIFS] NTLMv2 support part 5 [CIFS] Add support for readdir to legacy servers [CIFS] NTLMv2 support part 4 [CIFS] NTLMv2 support part 3 [CIFS] NTLMv2 support part 2 [CIFS] Fix mask so can set new cifs security flags properly CIFS] Support for older servers which require plaintext passwords - part 2 [CIFS] Support for older servers which require plaintext passwords [CIFS] Fix mapping of old SMB return code Invalid Net Name so it is [CIFS] Missing brace [CIFS] Do not overwrite aops ...
2006-06-27[JFFS2][XATTR] coexistence between xattr and write buffering support.KaiGai Kohei
Drop '&& !JFFS2_FS_WRITEBUFFER' from fs/Kconfig. The series of previous patches enables to use those functionality at same time. Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-06-26[PATCH] nfsd kconfig: select things at the closest tristate instead of boolHerbert Xu
I noticed recently that my CONFIG_CRYPTO_MD5 turned into a y again instead of m. It turns out that CONFIG_NFSD_V4 is selecting it to be y even though I've chosen to compile nfsd as a module. In general when we have a bool sitting under a tristate it is better to select things you need from the tristate rather than the bool since that allows the things you select to be modules. The following patch does it for nfsd. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] Make procfs obligatory except under CONFIG_EMBEDDEDH. Peter Anvin
Make procfs non-optional unless EMBEDDED is set, just like sysfs. procfs is already de facto required for a large subset of Linux functionality. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: easy debugEvgeniy Dushistov
Currently to turn on debug mode "user" has to edit ~10 files, to turn off he has to do it again. This patch introduce such changes: 1)turn on(off) debug messages via ".config" 2)remove unnecessary duplication of code 3)make "UFSD" macros more similar to function 4)fix some compiler warnings Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] ufs: Unmark CONFIG_UFS_FS_WRITE as BROKENEvgeniy Dushistov
To find new bugs, I suggest revert this patch: http://lkml.org/lkml/2006/1/31/275 in -mm tree. So others can test "write support" of UFS. Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25Merge with /pub/scm/linux/kernel/git/torvalds/linux-2.6.gitSteve French
2006-06-23[PATCH] ext2 XIP won't build without MMUAl Viro
Disable Ext2 XIP if the kernel is configured in no-MMU mode as the former won't build. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-20Merge branch 'audit.b21' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current * 'audit.b21' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current: (25 commits) [PATCH] make set_loginuid obey audit_enabled [PATCH] log more info for directory entry change events [PATCH] fix AUDIT_FILTER_PREPEND handling [PATCH] validate rule fields' types [PATCH] audit: path-based rules [PATCH] Audit of POSIX Message Queue Syscalls v.2 [PATCH] fix se_sen audit filter [PATCH] deprecate AUDIT_POSSBILE [PATCH] inline more audit helpers [PATCH] proc_loginuid_write() uses simple_strtoul() on non-terminated array [PATCH] update of IPC audit record cleanup [PATCH] minor audit updates [PATCH] fix audit_krule_to_{rule,data} return values [PATCH] add filtering by ppid [PATCH] log ppid [PATCH] collect sid of those who send signals to auditd [PATCH] execve argument logging [PATCH] fix deadlocks in AUDIT_LIST/AUDIT_LIST_RULES [PATCH] audit_panic() is audit-internal [PATCH] inotify (5/5): update kernel documentation ... Manual fixup of conflict in unclude/linux/inotify.h
2006-06-20[PATCH] inotify (1/5): split kernel API from userspace supportAmy Griffis
The following series of patches introduces a kernel API for inotify, making it possible for kernel modules to benefit from inotify's mechanism for watching inodes. With these patches, inotify will maintain for each caller a list of watches (via an embedded struct inotify_watch), where each inotify_watch is associated with a corresponding struct inode. The caller registers an event handler and specifies for which filesystem events their event handler should be called per inotify_watch. Signed-off-by: Amy Griffis <amy.griffis@hp.com> Acked-by: Robert Love <rml@novell.com> Acked-by: John McCutchan <john@johnmccutchan.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-06-18[JFFS2] Mark XATTR support as experimental, for nowDavid Woodhouse
2006-06-01[CIFS] Fix minor build breaks due to cifs kconfig issuesSteve French
2006-05-31[CIFS] Support for setting up SMB sessions to legacy lanman serversSteve French
2006-05-13[JFFS2][XATTR] XATTR support on JFFS2 (version. 5)KaiGai Kohei
This attached patches provide xattr support including POSIX-ACL and SELinux support on JFFS2 (version.5). There are some significant differences from previous version posted at last December. The biggest change is addition of EBS(Erase Block Summary) support. Currently, both kernel and usermode utility (sumtool) can recognize xattr nodes which have JFFS2_NODETYPE_XATTR/_XREF nodetype. In addition, some bugs are fixed. - A potential race condition was fixed. - Unexpected fail when updating a xattr by same name/value pair was fixed. - A bug when removing xattr name/value pair was fixed. The fundamental structures (such as using two new nodetypes and exclusion mechanism by rwsem) are unchanged. But most of implementation were reviewed and updated if necessary. Espacially, we had to change several internal implementations related to load_xattr_datum() to avoid a potential race condition. [1/2] xattr_on_jffs2.kernel.version-5.patch [2/2] xattr_on_jffs2.utils.version-5.patch Signed-off-by: KaiGai Kohei <kaigai@ak.jp.nec.com> Signed-off-by: David Woodhouse <dwmw2@infradead.org>
2006-04-21Merge branch 'master'Steven Whitehouse
2006-04-19[PATCH] hugetlbfs: add Kconfig help textArthur Othieno
In kernel bugzilla #6248 (http://bugzilla.kernel.org/show_bug.cgi?id=6248), Adrian Bunk <bunk@stusta.de> notes that CONFIG_HUGETLBFS is missing Kconfig help text. Signed-off-by: Arthur Othieno <apgo@patchbomb.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-11[PATCH] kdump: enable CONFIG_PROC_VMCORE by defaultVivek Goyal
Everybody seems to be using /proc/vmcore as a method to access the kernel crash dump. Hence probably it makes sense to enable CONFIG_PROC_VMCORE by default if CONFIG_CRASH_DUMP is selected. This makes kdump configuration further easier for a user. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-10[PATCH] CONFIGFS_FS must depend on SYSFSAdrian Bunk
This patch fixes the a compile error with CONFIG_SYSFS=n Configfs is creating, as a matter of policy, the /sys/kernel/config mountpoint. This means it requires CONFIG_SYSFS. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-03-31Merge branch 'master'Steven Whitehouse
2006-03-23Merge branch 'linus'Trond Myklebust
2006-03-23[PATCH] relay: migrate from relayfs to a generic relay APIJens Axboe
Original patch from Paul Mundt, sysfs parts removed by me since they were broken. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-03-20SUNRPC,RPCSEC_GSS: spkm3--fix config dependenciesJ. Bruce Fields
Add default selection of CRYPTO_CAST5 when selecting RPCSEC_GSS_SPKM3. Signed-off-by: Kevin Coffman <kwc@citi.umich.edu> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
