path: root/fs/9p/conv.h
2006-03-25[PATCH] v9fs: update license boilerplateEric Van Hensbergen
Update license boilerplate to specify GPLv2 and remove the (at your option clause). This change was agreed to by all the copyright holders (approvals can be found on v9fs-developer mailing list). Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] v9fs: add extension field to TcreateLatchesar Ionkov
Implement a new way of creating special files. Instead of Tcreate+Twstat, add one more field to Tcreate that contains special file description. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] fs/9p/: possible cleanupsAdrian Bunk
- mux.c: v9fs_poll_mux() was inline but not static resuling in needless object size bloat - mux.c: remove all "inline"s: gcc should know best what to inline - #if 0 the following unused global functions: - 9p.c: v9fs_v9fs_t_flush() - conv.c: v9fs_create_tauth() - mux.c: v9fs_mux_rpcnb() Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] v9fs: zero copy implementationLatchesar Ionkov
Performance enhancement reducing the number of copies in the data and stat paths. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] v9fs: new multiplexer implementationLatchesar Ionkov
New multiplexer implementation. Decreases the number of kernel threads required. Better handling when the user process receives a signal. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Cc: Eric Van Hensbergen <ericvh@ericvh.myip.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] v9fs: 9P protocol implementationEric Van Hensbergen
This part of the patch contains the 9P protocol functions. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
