path: root/drivers
2016-05-11Thermal / ACPI / video: add INT3406 thermal driverAaron Lu
INT3406 ACPI device object resembles an ACPI video output device, but its _BCM is said to be deprecated and should not be used. So we will make use of the raw interface to do the actual cooling. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Acked-by: Zhang Rui <rui.zhang@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-05-04ACPI/video: export acpi_video_get_levelsAaron Lu
The acpi_video_get_levels is useful for other drivers, i.e. the to-be-added int3406 thermal driver, so export it. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-05-04video / backlight: remove the backlight_device_registered APIAaron Lu
Since we will need the backlight_device_get_by_type API, we can use it instead of the backlight_device_registered API whenever necessary so remove the backlight_device_registered API. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Acked-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-05-04video / backlight: add two APIs for drivers to useAaron Lu
It is useful to get the backlight device's pointer and use it to set backlight in some cases(the following patch will make use of it) so add the two APIs and export them. Signed-off-by: Aaron Lu <aaron.lu@intel.com> Acked-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-04-30Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal Pull thermal fixes from Eduardo Valentin: "A couple of minor fixes for the thermal subsystem. Specifics in this pull request: - Fixes in hisilicon thermal driver - More fixes of unsigned to int type change in thermal_core.c" * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/evalenti/linux-soc-thermal: thermal: use %d to print S32 parameters thermal: hisilicon: increase temperature resolution
2016-04-29Merge tag 'powerpc-4.6-4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc fixes from Michael Ellerman: "A few more powerpc fixes for 4.6: - cxl: Keep IRQ mappings on context teardown from Michael Neuling - cxl: Poll for outstanding IRQs when detaching a context from Michael Neuling - Wire up preadv2 and pwritev2 syscalls from Rui Salvaterra" * tag 'powerpc-4.6-4' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: powerpc: wire up preadv2 and pwritev2 syscalls cxl: Poll for outstanding IRQs when detaching a context cxl: Keep IRQ mappings on context teardown
2016-04-29Merge tag 'edac_fix_for_4.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp Pull EDAC fix from Borislav Petkov: "Make sure sb_edac and i7core_edac do not terminate MCE processing on the decoding callchain prematurely" * tag 'edac_fix_for_4.6' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: EDAC: i7core, sb_edac: Don't return NOTIFY_BAD from mce_decoder callback
2016-04-29Merge tag 'pm+acpi-4.6-rc6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management fixes from Rafael Wysocki: "One revert of a recent cpufreq commit that introduced a regression and a fix for intel_pstate's Turbo Activation Ratio handling code. Specifics: - Revert cpufreq commit that attempted to fix a problem in the ondemand/conservative governor code, but did that incorrectly and introduced another problem instead (Rafael Wysocki). - Fix incorrect decoding of MSR contents related to the Turbo Activation Ratio (TAR) handling in the intel_pstate driver (Srinivas Pandruvada)" * tag 'pm+acpi-4.6-rc6' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: cpufreq: intel_pstate: Fix processing for turbo activation ratio Revert "cpufreq: governor: Fix negative idle_time when configured with CONFIG_HZ_PERIODIC"
2016-04-29Merge tag 'mmc-v4.6-rc4' of git://git.linaro.org/people/ulf.hansson/mmcLinus Torvalds
Pull MMC fixes from Ulf Hansson: "Here are a two MMC host fixes: - sdhci-acpi: Reduce Baytrail eMMC/SD/SDIO hangs - sunxi: Disable eMMC HS-DDR for Allwinner A80" * tag 'mmc-v4.6-rc4' of git://git.linaro.org/people/ulf.hansson/mmc: mmc: sunxi: Disable eMMC HS-DDR (MMC_CAP_1_8V_DDR) for Allwinner A80 mmc: sdhci-acpi: Reduce Baytrail eMMC/SD/SDIO hangs
2016-04-29Merge branch 'drm-fixes' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm fixes from Dave Airlie: "A few fixes all over the place: radeon is probably the biggest standout, it's a fix for screen corruption or hung black outputs so I thought it was worth pulling in. Otherwise some amdgpu power control fixes, some misc vmwgfx fixes, one etnaviv fix, one virtio-gpu fix, two DP MST fixes, and a single TTM fix" * 'drm-fixes' of git://people.freedesktop.org/~airlied/linux: drm/vmwgfx: Fix order of operation drm/vmwgfx: use vmw_cmd_dx_cid_check for query commands. drm/vmwgfx: Enable SVGA_3D_CMD_DX_SET_PREDICATION drm/amdgpu: disable vm interrupts with vm_fault_stop=2 drm/amdgpu: print a message if ATPX dGPU power control is missing Revert "drm/amdgpu: disable runtime pm on PX laptops without dGPU power control" drm/radeon: fix vertical bars appear on monitor (v2) drm/ttm: fix kref count mess in ttm_bo_move_to_lru_tail drm/virtio: send vblank event after crtc updates drm/dp/mst: Restore primary hub guid on resume drm/dp/mst: Get validated port ref in drm_dp_update_payload_part1() drm/etnaviv: don't move linear memory window on 3D cores without MC2.0
2016-04-29Merge tag 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma Pull rdma fixes from Doug Ledford: "Final set of -rc fixes for 4.6. I've collected up a number of patches that are all pretty small with the exception of only a couple. The hfi1 driver has a number of important patches, and it is what really drives the line count of this pull request up. These are all small and I've got this kernel built and running in the test lab (I have most of the hardware, I think nes is the only thing in this patch set that I can't say I've personally tested and have up and running). Summary: - A number of collected fixes for oopses, memory corruptions, deadlocks, etc. All of these fixes are small (many only 5-10 lines), obvious, and tested. - Fix for the security issue related to the use of write for bi-directional communications" * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dledford/rdma: RDMA/nes: don't leak skb if carrier down IB/security: Restrict use of the write() interface IB/hfi1: Use kernel default llseek for ui device IB/hfi1: Don't attempt to free resources if initialization failed IB/hfi1: Fix missing lock/unlock in verbs drain callback IB/rdmavt: Fix send scheduling IB/hfi1: Prevent unpinning of wrong pages IB/hfi1: Fix deadlock caused by locking with wrong scope IB/hfi1: Prevent NULL pointer deferences in caching code MAINTAINERS: Update iser/isert maintainer contact info IB/mlx5: Expose correct max_sge_rd limit RDMA/iw_cxgb4: Fix bar2 virt addr calculation for T4 chips iw_cxgb4: handle draining an idle qp iw_cxgb3: initialize ibdev.iwcm->ifname for port mapping iw_cxgb4: initialize ibdev.iwcm->ifname for port mapping IB/core: Don't drain non-existent rq queue-pair IB/core: Fix oops in ib_cache_gid_set_default_gid
2016-04-29Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge fixes from Andrew Morton: "20 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: Documentation/sysctl/vm.txt: update numa_zonelist_order description lib/stackdepot.c: allow the stack trace hash to be zero rapidio: fix potential NULL pointer dereference mm/memory-failure: fix race with compound page split/merge ocfs2/dlm: return zero if deref_done message is successfully handled Ananth has moved kcov: don't profile branches in kcov kcov: don't trace the code coverage code mm: wake kcompactd before kswapd's short sleep .mailmap: add Frank Rowand mm/hwpoison: fix wrong num_poisoned_pages accounting mm: call swap_slot_free_notify() with page lock held mm: vmscan: reclaim highmem zone if buffer_heads is over limit numa: fix /proc/<pid>/numa_maps for THP mm/huge_memory: replace VM_NO_THP VM_BUG_ON with actual VMA check mailmap: fix Krzysztof Kozlowski's misspelled name thp: keep huge zero page pinned until tlb flush mm: exclude HugeTLB pages from THP page_mapped() logic kexec: export OFFSET(page.compound_head) to find out compound tail page kexec: update VMCOREINFO for compound_order/dtor
2016-04-29EDAC: i7core, sb_edac: Don't return NOTIFY_BAD from mce_decoder callbackTony Luck
Both of these drivers can return NOTIFY_BAD, but this terminates processing other callbacks that were registered later on the chain. Since the driver did nothing to log the error it seems wrong to prevent other interested parties from seeing it. E.g. neither of them had even bothered to check the type of the error to see if it was a memory error before the return NOTIFY_BAD. Signed-off-by: Tony Luck <tony.luck@intel.com> Acked-by: Aristeu Rozanski <aris@redhat.com> Acked-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> Cc: linux-edac <linux-edac@vger.kernel.org> Cc: <stable@vger.kernel.org> Link: http://lkml.kernel.org/r/72937355dd92318d2630979666063f8a2853495b.1461864507.git.tony.luck@intel.com Signed-off-by: Borislav Petkov <bp@suse.de>
2016-04-29Merge branch 'pm-cpufreq-fixes'Rafael J. Wysocki
* pm-cpufreq-fixes: cpufreq: intel_pstate: Fix processing for turbo activation ratio Revert "cpufreq: governor: Fix negative idle_time when configured with CONFIG_HZ_PERIODIC"
2016-04-29Merge branch 'drm-fixes-4.6' of git://people.freedesktop.org/~agd5f/linux ↵Dave Airlie
into drm-fixes A few fixes for 4.6. - revert amdgpu PX commit that was previously reverted on the radeon side - cleaned up version of the NI+ MC update display fix for radeon - TTM kref fix * 'drm-fixes-4.6' of git://people.freedesktop.org/~agd5f/linux: drm/amdgpu: disable vm interrupts with vm_fault_stop=2 drm/amdgpu: print a message if ATPX dGPU power control is missing Revert "drm/amdgpu: disable runtime pm on PX laptops without dGPU power control" drm/radeon: fix vertical bars appear on monitor (v2) drm/ttm: fix kref count mess in ttm_bo_move_to_lru_tail
2016-04-29Merge branch 'drm-vmwgfx-fixes' of ↵Dave Airlie
git://people.freedesktop.org/~syeh/repos_linux into drm-fixes three misc vmwgfx fixes * 'drm-vmwgfx-fixes' of git://people.freedesktop.org/~syeh/repos_linux: drm/vmwgfx: Fix order of operation drm/vmwgfx: use vmw_cmd_dx_cid_check for query commands. drm/vmwgfx: Enable SVGA_3D_CMD_DX_SET_PREDICATION
2016-04-28Merge branch 'efi-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull EFI fix from Ingo Molnar: "This fixes a bug in the efivars code" * 'efi-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: efi: Fix out-of-bounds read in variable_matches()
2016-04-28Merge tag 'media/v4.6-4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media fixes from Mauro Carvalho Chehab: "Some regression fixes: - videobuf2 core: avoid the risk of going past buffer on multi-planes and fix rw mode - fix support for 4K formats at V4L2 core - fix a trouble at davinci_fpe, caused by a bad patch - usbvision: revert a patch with a partial fixup. The fixup patch was merged already, and this one has some issues" * tag 'media/v4.6-4' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: [media] vb2-memops: Fix over allocation of frame vectors [media] media: vb2: Fix regression on poll() for RW mode [media] v4l2-dv-timings.h: fix polarity for 4k formats [media] davinci_vpfe: Revert "staging: media: davinci_vpfe: remove,unnecessary ret variable" [media] usbvision: revert commit 588afcc1 [media] videobuf2-v4l2: Verify planes array in buffer dequeueing [media] videobuf2-core: Check user space planes array in dqbuf
2016-04-28rapidio: fix potential NULL pointer dereferenceVladimir Zapolskiy
The change fixes improper check for a returned error value by class_create() function, which on error returns ERR_PTR() value, thus the original check always results in a dead code on error path. Signed-off-by: Vladimir Zapolskiy <vz@mleia.com> Signed-off-by: Alexandre Bounine <alexandre.bounine@idt.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-04-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull Ceph fixes from Sage Weil: "There is a lifecycle fix in the auth code, a fix for a narrow race condition on map, and a helpful message in the log when there is a feature mismatch (which happens frequently now that the default server-side options have changed)" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: rbd: report unsupported features to syslog rbd: fix rbd map vs notify races libceph: make authorizer destruction independent of ceph_auth_client
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 fixes from Martin Schwidefsky: "Three more bug fixes for 4.6 - Due to a race in the dynamic page table code a multi-threaded program can cause a translation specification exception. With panic_on_oops a user space program can crash the system. - An information leak with the /dev/sclp device. - A use after free in the s390 PCI code" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: s390/sclp_ctl: fix potential information leak with /dev/sclp s390/mm: fix asce_bits handling with dynamic pagetable levels s390/pci: fix use after free in dma_init
2016-04-28RDMA/nes: don't leak skb if carrier downFlorian Westphal
Alternatively one could free the skb, OTOH I don't think this test is useful so just remove it. Cc: <linux-rdma@vger.kernel.org> Signed-off-by: Florian Westphal <fw@strlen.de> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-04-28drm/vmwgfx: Fix order of operationSinclair Yeh
mode->hdisplay * (var->bits_per_pixel + 7) gets evaluated before the division, potentially making the pitch larger than it should be. Since the original intention is to do a div-round-up, just use the macro instead. Signed-off-by: Sinclair Yeh <syeh@vmware.com> Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com>
2016-04-28drm/vmwgfx: use vmw_cmd_dx_cid_check for query commands.Charmaine Lee
Instead of calling vmw_cmd_ok, call vmw_cmd_dx_cid_check to validate the context id for query commands. Signed-off-by: Charmaine Lee <charmainel@vmware.com> Reviewed-by: Sinclair Yeh <syeh@vmware.com>
2016-04-28drm/vmwgfx: Enable SVGA_3D_CMD_DX_SET_PREDICATIONCharmaine Lee
Fixes piglit tests nv_conditional_render-* crashes. Signed-off-by: Charmaine Lee <charmainel@vmware.com> Reviewed-by: Brian Paul <brianp@vmware.com> Reviewed-by: Sinclair Yeh <syeh@vmware.com>
2016-04-28IB/security: Restrict use of the write() interfaceJason Gunthorpe
The drivers/infiniband stack uses write() as a replacement for bi-directional ioctl(). This is not safe. There are ways to trigger write calls that result in the return structure that is normally written to user space being shunted off to user specified kernel memory instead. For the immediate repair, detect and deny suspicious accesses to the write API. For long term, update the user space libraries and the kernel API to something that doesn't present the same security vulnerabilities (likely a structured ioctl() interface). The impacted uAPI interfaces are generally only available if hardware from drivers/infiniband is installed in the system. Reported-by: Jann Horn <jann@thejh.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Jason Gunthorpe <jgunthorpe@obsidianresearch.com> [ Expanded check to all known write() entry points ] Cc: stable@vger.kernel.org Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-04-28IB/hfi1: Use kernel default llseek for ui deviceDean Luick
The ui device llseek had a mistake with SEEK_END and did not fully follow seek semantics. Correct all this by using a kernel supplied function for fixed size devices. Cc: Al Viro <viro@ZenIV.linux.org.uk> Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Dean Luick <dean.luick@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-04-28IB/hfi1: Don't attempt to free resources if initialization failedMitko Haralanov
Attempting to free resources which have not been allocated and initialized properly led to the following kernel backtrace: BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffffa09658fe>] unlock_exp_tids.isra.8+0x2e/0x120 [hfi1] PGD 852a43067 PUD 85d4a6067 PMD 0 Oops: 0000 [#1] SMP CPU: 0 PID: 2831 Comm: osu_bw Tainted: G IO 3.12.18-wfr+ #1 task: ffff88085b15b540 ti: ffff8808588fe000 task.ti: ffff8808588fe000 RIP: 0010:[<ffffffffa09658fe>] [<ffffffffa09658fe>] unlock_exp_tids.isra.8+0x2e/0x120 [hfi1] RSP: 0018:ffff8808588ffde0 EFLAGS: 00010282 RAX: 0000000000000000 RBX: ffff880858a31800 RCX: 0000000000000000 RDX: ffff88085d971bc0 RSI: ffff880858a318f8 RDI: ffff880858a318c0 RBP: ffff8808588ffe20 R08: 0000000000000000 R09: 0000000000000000 R10: ffff88087ffd6f40 R11: 0000000001100348 R12: ffff880852900000 R13: ffff880858a318c0 R14: 0000000000000000 R15: ffff88085d971be8 FS: 00007f4674e83740(0000) GS:ffff88087f400000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000000 CR3: 000000085c377000 CR4: 00000000001407f0 Stack: ffffffffa0941a71 ffff880858a318f8 ffff88085d971bc0 ffff880858a31800 ffff880852900000 ffff880858a31800 00000000003ffff7 ffff88085d971bc0 ffff8808588ffe60 ffffffffa09663fc ffff8808588ffe60 ffff880858a31800 Call Trace: [<ffffffffa0941a71>] ? find_mmu_handler+0x51/0x70 [hfi1] [<ffffffffa09663fc>] hfi1_user_exp_rcv_free+0x6c/0x120 [hfi1] [<ffffffffa0932809>] hfi1_file_close+0x1a9/0x340 [hfi1] [<ffffffff8116c189>] __fput+0xe9/0x270 [<ffffffff8116c35e>] ____fput+0xe/0x10 [<ffffffff81065707>] task_work_run+0xa7/0xe0 [<ffffffff81002969>] do_notify_resume+0x59/0x80 [<ffffffff814ffc1a>] int_signal+0x12/0x17 This commit re-arranges the context initialization code in a way that would allow for context event flags to be used to determine whether the context has been successfully initialized. In turn, this can be used to skip the resource de-allocation if they were never allocated in the first place. Fixes: 3abb33ac6521 ("staging/hfi1: Add TID cache receive init and free funcs") Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Signed-off-by: Mitko Haralanov <mitko.haralanov@intel.com> Reviewed-by: Leon Romanovsky <leonro@mellanox.com. Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-04-28IB/hfi1: Fix missing lock/unlock in verbs drain callbackMike Marciniszyn
The iowait_sdma_drained() callback lacked locking to protect the qp s_flags field. This causes the s_flags to be out of sync on multiple CPUs, potentially corrupting the s_flags. Fixes: a545f5308b6c ("staging/rdma/hfi: fix CQ completion order issue") Reviewed-by: Sebastian Sanchez <sebastian.sanchez@intel.com> Signed-off-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Reviewed-by: Leon Romanovsky <leonro@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-04-28IB/rdmavt: Fix send schedulingJubin John
call_send is used to determine whether to send immediately or schedule a send for later. The current logic in rdmavt is inverted and has a negative impact on the latency of the hfi1 and qib drivers. Fix this regression by correctly calling send immediately when call_send is set. Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Reviewed-by: Mike Marciniszyn <mike.marciniszyn@intel.com> Signed-off-by: Jubin John <jubin.john@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-04-28IB/hfi1: Prevent unpinning of wrong pagesMitko Haralanov
The routine used by the SDMA cache to handle already cached nodes can extend an already existing node. In its error handling code, the routine will unpin pages when not all pages of the buffer extension were pinned. There was a bug in that part of the routine, which would mistakenly unpin pages from the original set rather than the newly pinned pages. This commit fixes that bug by offsetting the page array to the proper place pointing at the beginning of the newly pinned pages. Reviewed-by: Dean Luick <dean.luick@intel.com> Signed-off-by: Mitko Haralanov <mitko.haralanov@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-04-28IB/hfi1: Fix deadlock caused by locking with wrong scopeMitko Haralanov
The locking around the interval RB tree is designed to prevent access to the tree while it's being modified. The locking in its current form is too overzealous, which is causing a deadlock in certain cases with the following backtrace: Kernel panic - not syncing: Watchdog detected hard LOCKUP on cpu 0 CPU: 0 PID: 5836 Comm: IMB-MPI1 Tainted: G O 3.12.18-wfr+ #1 0000000000000000 ffff88087f206c50 ffffffff814f1caa ffffffff817b53f0 ffff88087f206cc8 ffffffff814ecd56 0000000000000010 ffff88087f206cd8 ffff88087f206c78 0000000000000000 0000000000000000 0000000000001662 Call Trace: <NMI> [<ffffffff814f1caa>] dump_stack+0x45/0x56 [<ffffffff814ecd56>] panic+0xc2/0x1cb [<ffffffff810d4370>] ? restart_watchdog_hrtimer+0x50/0x50 [<ffffffff810d4432>] watchdog_overflow_callback+0xc2/0xd0 [<ffffffff81109b4e>] __perf_event_overflow+0x8e/0x2b0 [<ffffffff8110a714>] perf_event_overflow+0x14/0x20 [<ffffffff8101c906>] intel_pmu_handle_irq+0x1b6/0x390 [<ffffffff814f927b>] perf_event_nmi_handler+0x2b/0x50 [<ffffffff814f8ad8>] nmi_handle.isra.3+0x88/0x180 [<ffffffff814f8d39>] do_nmi+0x169/0x310 [<ffffffff814f8177>] end_repeat_nmi+0x1e/0x2e [<ffffffff81272600>] ? unmap_single+0x30/0x30 [<ffffffff814f780d>] ? _raw_spin_lock_irqsave+0x2d/0x40 [<ffffffff814f780d>] ? _raw_spin_lock_irqsave+0x2d/0x40 [<ffffffff814f780d>] ? _raw_spin_lock_irqsave+0x2d/0x40 <<EOE>> <IRQ> [<ffffffffa056c4a8>] hfi1_mmu_rb_search+0x38/0x70 [hfi1] [<ffffffffa05919cb>] user_sdma_free_request+0xcb/0x120 [hfi1] [<ffffffffa0593393>] user_sdma_txreq_cb+0x263/0x350 [hfi1] [<ffffffffa057fad7>] ? sdma_txclean+0x27/0x1c0 [hfi1] [<ffffffffa0593130>] ? user_sdma_send_pkts+0x1710/0x1710 [hfi1] [<ffffffffa057fdd6>] sdma_make_progress+0x166/0x480 [hfi1] [<ffffffff810762c9>] ? ttwu_do_wakeup+0x19/0xd0 [<ffffffffa0581c7e>] sdma_engine_interrupt+0x8e/0x100 [hfi1] [<ffffffffa0546bdd>] sdma_interrupt+0x5d/0xa0 [hfi1] [<ffffffff81097e57>] handle_irq_event_percpu+0x47/0x1d0 [<ffffffff81098017>] handle_irq_event+0x37/0x60 [<ffffffff8109aa5f>] handle_edge_irq+0x6f/0x120 [<ffffffff810044af>] handle_irq+0xbf/0x150 [<ffffffff8104c9b7>] ? irq_enter+0x17/0x80 [<ffffffff8150168d>] do_IRQ+0x4d/0xc0 [<ffffffff814f7c6a>] common_interrupt+0x6a/0x6a <EOI> [<ffffffff81073524>] ? finish_task_switch+0x54/0xe0 [<ffffffff814f56c6>] __schedule+0x3b6/0x7e0 [<ffffffff810763a6>] __cond_resched+0x26/0x30 [<ffffffff814f5eda>] _cond_resched+0x3a/0x50 [<ffffffff814f4f82>] down_write+0x12/0x30 [<ffffffffa0591619>] hfi1_release_user_pages+0x69/0x90 [hfi1] [<ffffffffa059173a>] sdma_rb_remove+0x9a/0xc0 [hfi1] [<ffffffffa056c00d>] __mmu_rb_remove.isra.5+0x5d/0x70 [hfi1] [<ffffffffa056c536>] hfi1_mmu_rb_remove+0x56/0x70 [hfi1] [<ffffffffa059427b>] hfi1_user_sdma_process_request+0x74b/0x1160 [hfi1] [<ffffffffa055c763>] hfi1_aio_write+0xc3/0x100 [hfi1] [<ffffffff8116a14c>] do_sync_readv_writev+0x4c/0x80 [<ffffffff8116b58b>] do_readv_writev+0xbb/0x230 [<ffffffff811a9da1>] ? fsnotify+0x241/0x320 [<ffffffff81073524>] ? finish_task_switch+0x54/0xe0 [<ffffffff8116b795>] vfs_writev+0x35/0x60 [<ffffffff8116b8c9>] SyS_writev+0x49/0xc0 [<ffffffff810cd876>] ? __audit_syscall_exit+0x1f6/0x2a0 [<ffffffff814ff992>] system_call_fastpath+0x16/0x1b As evident from the backtrace above, the process was being put to sleep while holding the lock. Limiting the scope of the lock only to the RB tree operation fixes the above error allowing for proper locking and the process being put to sleep when needed. Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Reviewed-by: Dean Luick <dean.luick@intel.com> Signed-off-by: Mitko Haralanov <mitko.haralanov@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-04-28IB/hfi1: Prevent NULL pointer deferences in caching codeMitko Haralanov
There is a potential kernel crash when the MMU notifier calls the invalidation routines in the hfi1 pinned page caching code for sdma. The invalidation routine could call the remove callback for the node, which in turn ends up dereferencing the current task_struct to get a pointer to the mm_struct. However, the mm_struct pointer could be NULL resulting in the following backtrace: BUG: unable to handle kernel NULL pointer dereference at 00000000000000a8 IP: [<ffffffffa041f75a>] sdma_rb_remove+0xaa/0x100 [hfi1] 15 task: ffff88085e66e080 ti: ffff88085c244000 task.ti: ffff88085c244000 RIP: 0010:[<ffffffffa041f75a>] [<ffffffffa041f75a>] sdma_rb_remove+0xaa/0x100 [hfi1] RSP: 0000:ffff88085c245878 EFLAGS: 00010002 RAX: 0000000000000000 RBX: ffff88105b9bbd40 RCX: ffffea003931a830 RDX: 0000000000000004 RSI: ffff88105754a9c0 RDI: ffff88105754a9c0 RBP: ffff88085c245890 R08: ffff88105b9bbd70 R09: 00000000fffffffb R10: ffff88105b9bbd58 R11: 0000000000000013 R12: ffff88105754a9c0 R13: 0000000000000001 R14: 0000000000000001 R15: ffff88105b9bbd40 FS: 0000000000000000(0000) GS:ffff88107ef40000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 00000000000000a8 CR3: 0000000001a0b000 CR4: 00000000001407e0 Stack: ffff88105b9bbd40 ffff88080ec481a8 ffff88080ec481b8 ffff88085c2458c0 ffffffffa03fa00e ffff88080ec48190 ffff88080ed9cd00 0000000001024000 0000000000000000 ffff88085c245920 ffffffffa03fa0e7 0000000000000282 Call Trace: [<ffffffffa03fa00e>] __mmu_rb_remove.isra.5+0x5e/0x70 [hfi1] [<ffffffffa03fa0e7>] mmu_notifier_mem_invalidate+0xc7/0xf0 [hfi1] [<ffffffffa03fa143>] mmu_notifier_page+0x13/0x20 [hfi1] [<ffffffff81156dd0>] __mmu_notifier_invalidate_page+0x50/0x70 [<ffffffff81140bbb>] try_to_unmap_one+0x20b/0x470 [<ffffffff81141ee7>] try_to_unmap_anon+0xa7/0x120 [<ffffffff81141fad>] try_to_unmap+0x4d/0x60 [<ffffffff8111fd7b>] shrink_page_list+0x2eb/0x9d0 [<ffffffff81120ab3>] shrink_inactive_list+0x243/0x490 [<ffffffff81121491>] shrink_lruvec+0x4c1/0x640 [<ffffffff81121641>] shrink_zone+0x31/0x100 [<ffffffff81121b0f>] kswapd_shrink_zone.constprop.62+0xef/0x1c0 [<ffffffff811229e3>] kswapd+0x403/0x7e0 [<ffffffff811225e0>] ? shrink_all_memory+0xf0/0xf0 [<ffffffff81068ac0>] kthread+0xc0/0xd0 [<ffffffff81068a00>] ? insert_kthread_work+0x40/0x40 [<ffffffff814ff8ec>] ret_from_fork+0x7c/0xb0 [<ffffffff81068a00>] ? insert_kthread_work+0x40/0x40 To correct this, the mm_struct passed to us by the MMU notifier is used (which is what should have been done to begin with). This avoids the broken derefences and ensures that the correct mm_struct is used. Reviewed-by: Dennis Dalessandro <dennis.dalessandro@intel.com> Reviewed-by: Dean Luick <dean.luick@intel.com> Signed-off-by: Mitko Haralanov <mitko.haralanov@intel.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-04-28IB/mlx5: Expose correct max_sge_rd limitSagi Grimberg
mlx5 devices (Connect-IB, ConnectX-4, ConnectX-4-LX) has a limitation where rdma read work queue entries cannot exceed 512 bytes. A rdma_read wqe needs to fit in 512 bytes: - wqe control segment (16 bytes) - rdma segment (16 bytes) - scatter elements (16 bytes each) So max_sge_rd should be: (512 - 16 - 16) / 16 = 30. Cc: linux-stable@vger.kernel.org Reported-by: Christoph Hellwig <hch@lst.de> Tested-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sagi Grimberg <sagig@grimberg.me> Signed-off-by: Leon Romanovsky <leonro@mellanox.com> Signed-off-by: Doug Ledford <dledford@redhat.com>
2016-04-28mmc: sunxi: Disable eMMC HS-DDR (MMC_CAP_1_8V_DDR) for Allwinner A80Chen-Yu Tsai
eMMC HS-DDR no longer works on the A80, despite it working when support for this developed. Disable it for now. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org>
2016-04-28rbd: report unsupported features to syslogIlya Dryomov
... instead of just returning an error. Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Reviewed-by: Josh Durgin <jdurgin@redhat.com>
2016-04-28rbd: fix rbd map vs notify racesIlya Dryomov
A while ago, commit 9875201e1049 ("rbd: fix use-after free of rbd_dev->disk") fixed rbd unmap vs notify race by introducing an exported wrapper for flushing notifies and sticking it into do_rbd_remove(). A similar problem exists on the rbd map path, though: the watch is registered in rbd_dev_image_probe(), while the disk is set up quite a few steps later, in rbd_dev_device_setup(). Nothing prevents a notify from coming in and crashing on a NULL rbd_dev->disk: BUG: unable to handle kernel NULL pointer dereference at 0000000000000050 Call Trace: [<ffffffffa0508344>] rbd_watch_cb+0x34/0x180 [rbd] [<ffffffffa04bd290>] do_event_work+0x40/0xb0 [libceph] [<ffffffff8109d5db>] process_one_work+0x17b/0x470 [<ffffffff8109e3ab>] worker_thread+0x11b/0x400 [<ffffffff8109e290>] ? rescuer_thread+0x400/0x400 [<ffffffff810a5acf>] kthread+0xcf/0xe0 [<ffffffff810b41b3>] ? finish_task_switch+0x53/0x170 [<ffffffff810a5a00>] ? kthread_create_on_node+0x140/0x140 [<ffffffff81645dd8>] ret_from_fork+0x58/0x90 [<ffffffff810a5a00>] ? kthread_create_on_node+0x140/0x140 RIP [<ffffffffa050828a>] rbd_dev_refresh+0xfa/0x180 [rbd] If an error occurs during rbd map, we have to error out, potentially tearing down a watch. Just like on rbd unmap, notifies have to be flushed, otherwise rbd_watch_cb() may end up trying to read in the image header after rbd_dev_image_release() has run: Assertion failure in rbd_dev_header_info() at line 4722: rbd_assert(rbd_image_format_valid(rbd_dev->image_format)); Call Trace: [<ffffffff81cccee0>] ? rbd_parent_request_create+0x150/0x150 [<ffffffff81cd4e59>] rbd_dev_refresh+0x59/0x390 [<ffffffff81cd5229>] rbd_watch_cb+0x69/0x290 [<ffffffff81fde9bf>] do_event_work+0x10f/0x1c0 [<ffffffff81107799>] process_one_work+0x689/0x1a80 [<ffffffff811076f7>] ? process_one_work+0x5e7/0x1a80 [<ffffffff81132065>] ? finish_task_switch+0x225/0x640 [<ffffffff81107110>] ? pwq_dec_nr_in_flight+0x2b0/0x2b0 [<ffffffff81108c69>] worker_thread+0xd9/0x1320 [<ffffffff81108b90>] ? process_one_work+0x1a80/0x1a80 [<ffffffff8111b02d>] kthread+0x21d/0x2e0 [<ffffffff8111ae10>] ? kthread_stop+0x550/0x550 [<ffffffff82022802>] ret_from_fork+0x22/0x40 [<ffffffff8111ae10>] ? kthread_stop+0x550/0x550 RIP [<ffffffff81ccd8f9>] rbd_dev_header_info+0xa19/0x1e30 To fix this, a) check if RBD_DEV_FLAG_EXISTS is set before calling revalidate_disk(), b) move ceph_osdc_flush_notifies() call into rbd_dev_header_unwatch_sync() to cover rbd map error paths and c) turn header read-in into a critical section. The latter also happens to take care of rbd map foo@bar vs rbd snap rm foo@bar race. Fixes: http://tracker.ceph.com/issues/15490 Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Reviewed-by: Josh Durgin <jdurgin@redhat.com>
2016-04-27thermal: use %d to print S32 parametersLeo Yan
Power allocator's parameters are S32 type, so use %d to print them. Acked-by: Javi Merino <javi.merino@arm.com> Signed-off-by: Leo Yan <leo.yan@linaro.org> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2016-04-27thermal: hisilicon: increase temperature resolutionLeo Yan
When calculate temperature, old code firstly do division and then convert to "millicelsius" unit. This will lose resolution and only can read back temperature with "Celsius" unit. So firstly scale step value to "millicelsius" and then do division, so finally we can increase resolution for temperature value. Also refine the calculation from temperature value to step value. Signed-off-by: Leo Yan <leo.yan@linaro.org> Signed-off-by: Eduardo Valentin <edubezval@gmail.com>
2016-04-27Merge branch 'i2c/for-current' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux Pull i2c fixes from Wolfram Sang: "I2C has one buildfix, one ABBA deadlock fix, and three simple 'add ID' patches" * 'i2c/for-current' of git://git.kernel.org/pub/scm/linux/kernel/git/wsa/linux: i2c: exynos5: Fix possible ABBA deadlock by keeping I2C clock prepared i2c: cpm: Fix build break due to incompatible pointer types i2c: ismt: Add Intel DNV PCI ID i2c: xlp9xx: add support for Broadcom Vulcan i2c: rk3x: add support for rk3228
2016-04-27drm/amdgpu: disable vm interrupts with vm_fault_stop=2Flora Cui
V2: disable all vm interrupts in late_init() Signed-off-by: Flora Cui <Flora.Cui@amd.com> Reviewed-by: Ken Wang <Qingqing.Wang@amd.com> Reviewed-by: Christian König <christian.koenig@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2016-04-27drm/amdgpu: print a message if ATPX dGPU power control is missingAlex Deucher
It will help identify problematic boards. Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2016-04-27Revert "drm/amdgpu: disable runtime pm on PX laptops without dGPU power control"Alex Deucher
This reverts commit bedf2a65c1aa8fb29ba8527fd00c0f68ec1f55f1. See the radeon revert for an extended description. Cc: stable@vger.kernel.org
2016-04-27drm/radeon: fix vertical bars appear on monitor (v2)Vitaly Prosyak
When crtc/timing is disabled on boot the dig block should be stopped in order ignore timing from crtc, reset the steering fifo otherwise we get display corruption or hung in dp sst mode. v2: agd: fix coding style Signed-off-by: Vitaly Prosyak <vitaly.prosyak@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
2016-04-27drm/ttm: fix kref count mess in ttm_bo_move_to_lru_tailFlora Cui
Fixes the following scenario: 1. Page table bo allocated in vram and linked to man->lru. tbo->list_kref.refcount=2 2. Page table bo is swapped out and removed from man->lru. tbo->list_kref.refcount=1 3. Command submission from userspace. Page table bo is moved to vram. ttm_bo_move_to_lru_tail() link it to man->lru and don't increase the kref count. Reviewed-by: Thomas Hellstrom <thellstrom@vmware.com> Signed-off-by: Flora Cui <Flora.Cui@amd.com> Reviewed-by: Christian König <christian.koenig@amd.com> Signed-off-by: Alex Deucher <alexander.deucher@amd.com> Cc: stable@vger.kernel.org
2016-04-27Merge tag 'platform-drivers-x86-v4.6-3' of ↵Linus Torvalds
git://git.infradead.org/users/dvhart/linux-platform-drivers-x86 Pull x86 platform driver fix from Darren Hart: "Fix regression caused by hotkey enabling value in toshiba_acpi" * tag 'platform-drivers-x86-v4.6-3' of git://git.infradead.org/users/dvhart/linux-platform-drivers-x86: toshiba_acpi: Fix regression caused by hotkey enabling value
2016-04-27s390/sclp_ctl: fix potential information leak with /dev/sclpMartin Schwidefsky
The sclp_ctl_ioctl_sccb function uses two copy_from_user calls to retrieve the sclp request from user space. The first copy_from_user fetches the length of the request which is stored in the first two bytes of the request. The second copy_from_user gets the complete sclp request, but this copies the length field a second time. A malicious user may have changed the length in the meantime. Reported-by: Pengfei Wang <wpengfeinudt@gmail.com> Reviewed-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-04-27cxl: Poll for outstanding IRQs when detaching a contextMichael Neuling
When detaching contexts, we may still have interrupts in the system which are yet to be delivered to any CPU and be acked in the PSL. This can result in a subsequent unrelated process getting an spurious IRQ or an interrupt for a non-existent context. This polls the PSL to ensure that the PSL is clear of IRQs for the detached context, before removing the context from the idr. Signed-off-by: Michael Neuling <mikey@neuling.org> Tested-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com> Acked-by: Ian Munsie <imunsie@au1.ibm.com> Tested-by: Vaibhav Jain <vaibhav@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2016-04-27cxl: Keep IRQ mappings on context teardownMichael Neuling
Keep IRQ mappings on context teardown. This won't leak IRQs as if we allocate the mapping again, the generic code will give the same mapping used last time. Doing this works around a race in the generic code. Masking the interrupt introduces a race which can crash the kernel or result in IRQ that is never EOIed. The lost of EOI results in all subsequent mappings to the same HW IRQ never receiving an interrupt. We've seen this race with cxl test cases which are doing heavy context startup and teardown at the same time as heavy interrupt load. A fix to the generic code is being investigated also. Signed-off-by: Michael Neuling <mikey@neuling.org> Cc: stable@vger.kernel.org # 3.8 Tested-by: Andrew Donnellan <andrew.donnellan@au1.ibm.com> Acked-by: Ian Munsie <imunsie@au1.ibm.com> Tested-by: Vaibhav Jain <vaibhav@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2016-04-27drm/virtio: send vblank event after crtc updatesGustavo Padovan
virtio_gpu was failing to send vblank events when using the atomic IOCTL with the DRM_MODE_PAGE_FLIP_EVENT flag set. This patch fixes each and enables atomic pageflips updates. Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Cc: stable@vger.kernel.org Signed-off-by: Dave Airlie <airlied@redhat.com>
